SM912LV
SM912LV
    BANNER(邦纳)
    PHOTO SEN RETRO 0.15-9M BIPOLAR
SM912LV 数据手册
t ns uc tio od ca Pr ne ifi Li pec S VALU-BEAM® Sensors Rugged, self-contained photoelectric sensors for industrial applications Printed in USA • Economy, performance, and durability in a family of rugged, self-contained sensors for demanding industrial applications • 912 Series sensors have solid-state outputs; models for either 10-30V dc or 24-250V ac operation (pages 4 to 9) • 915 Series sensors have electromechanical relay output; models for 12-28V ac/dc, 90-130V ac, or 210-250V ac (pages 10 to 13) • 990 Series sensors output to a built-in 6-digit totalizing counter; operate from both 12-115V dc and 10-250V ac (pages 14 to 17) • Many models available in opposed, retroreflective, diffuse, convergent beam, and fiber optic sensing modes • Highly-visible top-mounted LED output indicator; 912 Series sensors have Banner's exclusive, patented AID™ indicator system P/N 32894 VALU-BEAM® Sensors VALU-BEAMs are a family of rugged, self-contained photoelectric sensors designed for especially demanding industrial applications where economy, performance, and durability are important. VALU-BEAMs are built in a variety of operating voltages (both dc and ac) and output types (solid state and electromechanical relay). SM912 and SM2A912 Series VALU-BEAMs have solid state outputs and are available in either 10-30V dc-powered or 24-250V ac-powered models (see specifications, page 4). SMW915, SMA915, and SMB915 Series VALU-BEAMs have electromechanical relay output and operate from 12-28V ac/dc, 90-130V ac, or 210 to 250V ac respectively. SMA990 Series VALU-BEAMs have a built-in 6-digit totalizing counter and operate on 12 to 115V dc or 10 to 250V ac. A fourth VALU-BEAM line, SMI912 Series intrinsically safe sensors (low voltage dc sensors having Factory Mutual approval for use with intrinsic-safe barriers in hazardous areas) is covered in data sheet P/N 03396 and the Banner catalog. Powerful, modulated LED light sources give VALU-BEAM sensors greater sensing range than competitive units and a high degree of immunity to ambient light. All models are totally epoxyencapsulated and housed in molded VALOX® housings for the ultimate in shock, vibration, moisture, and corrosion resistance. All VALU-BEAM sensors conform to NEMA standards 1, 2, 3, 3S, 4, 4X, 12, and 13. VALU-BEAM sensors may be mounted from either the front or the rear using their two through-mounting holes, or by the outside threads of their M30x1.5 threaded base (mounting nut supplied), making them ideal for conveyor and other production line applications. A versatile 2-axis steel accessory mounting bracket (model SMB900) simplifies mounting and alignment. Model SMB30SM swivel-mount bracket offers the ultimate in flexibility and convenience. The bases of standard VALU-BEAMs have a 1/2" NPS integral internal conduit thread, and are supplied with a 6-foot PVC-covered cable. Models with a NEMA-4 rated quick-disconnect connector (QD models) are available optionally. All VALU-BEAM sensors have an easily-visible top-mounted red LED indicator to assist in alignment and system monitoring. On SMA915, SMB915, SMW915, and SMA990 Series VALUBEAMs, this indicator lights whenever the sensor "sees" its modulated light source. On SM2A912 Series 2-wire sensors, the LED lights whenever the load is energized. SM912 Series sensors have Banner's exclusive, patented "AID" system (Alignment Indicating Device, US patent #4356393) which lights the indicator LED whenever the sensor "sees" its modulated light source, and also pulses the LED at a rate proportional to the received light signal strength. This feature greatly simplifies alignment: in most situations, alignment becomes simply a matter of positioning the sensor for maximum LED pulse rate. VALU-BEAMs offer a choice of light or dark operate in the same sensor. This is done via a rear panel control or, in the relay output units, by offering both N/O and N/C output relay contacts. WARNING VALU-BEAM photoelectric presence sensors do NOT include the self-checking redundant circuitry necessary ! to allow their use in personnel safety applications. A sensor failure or malfunction can result in either an energized or a de-energized sensor output condition. Never use these products as sensing devices for personnel protection. Their use as safety devices may create an unsafe condition which could lead to serious injury or death. Only MACHINE-GUARD and PERIMETER-GUARD Systems, and other systems so designated, are designed to meet OSHA and ANSI machine safety standards for point-of-operation guarding devices. No other Banner sensors or controls are designed to meet these standards, and they must NOT be used as sensing devices for personnel protection. WARRANTY: Banner Engineering Corporation warrants its products to be free from defects for one year. Banner Engineering Corporation will repair or replace, free of charge, any product of its manufacture found to be defective at the time it is returned to the factory during the warranty period. This warranty does not cover damage or liability for the improper application of Banner products. This warranty is in lieu of any other warranty either expressed or implied. 2 VALU-BEAM Sensors *NOTE: Emitter voltage range is 10-250V ac or dc Series Model Sensing Mode Range Operating Voltage* Page 912 Series SMA91E & SM91R SMA91E & SM2A91R SMA91ESR & SM91RSR SMA91ESR & SM2A91RSR Opposed: long range Opposed: long range Opposed: short range Opposed: short range 200 feet 200 feet 10 feet 10 feet 10 to 30V dc* 24 to 250V ac* 10 to 30V dc* 24 to 250V ac* p. 5 p. 5 p. 5 p. 5 SM912LV SM2A912LV SM912LVAG SM2A912LVAG Retroreflective: visible beam Retroreflective: visible beam Retroreflective: polarized beam Retroreflective: polarized beam 30 feet 30 feet 15 feet 15 feet 10 to 30V dc 24 to 250V ac 10 to 30V dc 24 to 250V ac p. 5 p. 5 p. 5 p. 5 SM912D SM2A912D SM912DSR SM2A912DSR Diffuse (proximity): long range Diffuse (proximity): long range Diffuse (proximity): short range Diffuse (proximity): short range 30 inches 30 inches 15 inches 15 inches 10 to 30V dc 24 to 250V ac 10 to 30V dc 24 to 250V ac p. 6 p. 6 p. 6 p. 6 SM912CV SM2A912CV SM912C SM2A912C Convergent beam: visible red Convergent beam: visible red Convergent beam: infrared Convergent beam: infrared 1.5-inch focus 1.5-inch focus 1.5-inch focus 1.5-inch focus 10 to 30V dc 24 to 250V ac 10 to 30V dc 24 to 250V ac p. 6 p. 6 p. 7 p. 7 SMA91EF & SM91RF SMA91EF & SM2A91RF Opposed fiber optic: glass fibers Opposed fiber optic: glass fibers see specs see specs 10 to 30V dc* 24 to 250V ac* p. 6 p. 6 SM912F SM2A912F Fiber optic: glass fibers Fiber optic: glass fibers see specs see specs 10 to 30V dc 24 to 250V ac p. 7 p. 7 SMA91E & SMW95R SMA91E & SMA95R SMA91E & SMB95R SMA91ESR & SMW95RSR SMA91ESR & SMA95RSR SMA91ESR & SMB95RSR Opposed: long range Opposed; long range Opposed: long range Opposed: short range Opposed: short range Opposed: short range 200 feet 200 feet 200 feet 10 feet 10 feet 10 feet 12 to 28V ac/dc* 90 to 130V ac* 210 to 250V ac* 12 to 28V ac/dc* 90 to 130V ac* 210 to 250V ac* p. 11 p. 11 p. 11 p. 11 p. 11 p. 11 SMW915LV SMA915LV SMB915LV SMW915LVAG SMA915LVAG SMB915LVAG Retroreflective: visible beam Retroreflective: visible beam Retroreflective: visible beam Retroreflective: polarized beam Retroreflective: polarized beam Retroreflective: polarized beam 30 feet 30 feet 30 feet 15 feet 15 feet 15 feet 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac p. 11 p. 11 p. 11 p. 11 p. 11 p. 11 SMW915D SMA915D SMB915D SMW915DSR SMA915DSR SMB915DSR Diffuse (proximity): long range Diffuse (proximity): long range Diffuse (proximity): long range Diffuse (proximity): short range Diffuse (proximity): short range Diffuse (proximity): short range 30 inches 30 inches 30 inches 15 inches 15 inches 15 inches 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac p. 12 p. 12 p. 12 p. 12 p. 12 p. 12 SMW915CV SMA915CV SMB915CV Convergent: visible red Convergent: visible red Convergent: visible red 1.5-inch focus 1.5-inch focus 1.5-inch focus 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac p. 12 p. 12 p. 12 SMW915F SMA915F SMB915F Fiber optic: glass fibers Fiber optic: glass fibers Fiber optic: glass fibers see specs see specs see specs 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac p. 13 p. 13 p. 13 SMW915FP SMA915FP SMB915FP Fiber optic: plastic fibers Fiber optic: plastic fibers Fiber optic: plastic fibers see specs see specs see specs 12 to 28V ac/dc 90 to 130V ac 210 to 250V ac p. 13 p. 13 p. 13 SMA91E & SMA99R SMA91ESR & SMA99RSR Opposed: long range Opposed: narrow beam 200 feet* 10 feet* SMA990LV SMA990LVAG SMA990LT Retroreflective: visible beam Retroreflective: polarized beam Retroreflective: infrared beam (used for "people counting") 30 feet 15 feet 30 feet SMA990CV Convergent beam: visible red 1.5-inch focus p. 16 SMA990F SMA990FP Fiber optic: glass fibers Fiber optic: plastic fibers see specs see specs p. 17 p. 16 Sensors with infinite-life solid-state output relay 915 Series Sensors with SPDT electromechanical output relay 990 Series Sensors with built-in 6-digit totalizing counter All 990 Series sensors operate from 10 to 250V ac or 12 to 115V dc p. 15 p. 15 p. 15 p. 15 p. 16 3 VALU-BEAM 912 Series Sensors dc sensor specifications ac sensor specifications SUPPLY VOLTAGE: 10 to 30V dc at 20mA, exclusive of load (except for SMA91E, ESR, and EF emitters, which operate from 10 to 250V ac or dc, 10mA max.). OUTPUT CONFIGURATION: one current sourcing (PNP) and one current sinking (NPN) open-collector transistor. SUPPLY VOLTAGE: 24 to 250V ac (50/60Hz), except for SMA91E, ESR, and EF emitters, which operate from 10 to 250V ac or dc. OUTPUT RATING: 250mA continuous, each output. Off-state leakage current less than 10 microamps. Output saturation voltage: for PNP output,
SM912LV 价格&库存
很抱歉,暂时无法提供与“SM912LV”相匹配的价格&库存,您可以联系我们找货
SM912LV
  • 1+2830.611141+366.24746
