ICM7555CBA-T
ICM7555CBA-T
    L3HARRIS
    SOIC8_150MIL
    GENERAL PURPOSE RC TIMER
ICM7555CBA-T 数据手册
Dat asheet Rochest erEl ect r oni cs Manuf act ur edComponent s Rochest er br anded component s ar e manuf act ur ed usi ng ei t herdi e/ waf er s pur chased f r om t he or i gi nalsuppl i er s or Rochest er waf er sr ecr eat ed f r om t he or i gi nal I P. Al lr ecr eat i ons ar e donewi t ht heappr ovaloft heOCM. Par t sar et est ed usi ngor i gi nalf act or y t estpr ogr amsorRochest erdevel oped t est sol ut i ons t o guar ant ee pr oduct meet sorexceedt heOCM dat asheet . Qual i t yOver vi ew •I SO9001 • AS9120cer t icat i on • Qual iedManuf act ur er sLi st( QML)MI LPRF35835 •Cl assQ Mi l i t ar y •Cl assVSpaceLevel • Qual iedSuppl i er sLi stofDi st r i but or s( QSLD) •Rochest eri sacr i t i calsuppl i ert oDLA and meet sal li ndust r yandDLA st andar ds. Rochest erEl ect r oni cs,LLC i scommi t t edt o suppl yi ngpr oduct st hatsat i sf ycust omerexpect at i onsf orqual i t yandar eequalt ot hoseor i gi nal l y suppl i edbyi ndust r ymanuf act ur er s. Theor i gi nalmanuf act ur er ’ sdat asheetaccompanyi ngt hi sdocumentr e ect st heper f or mance andspecicat i onsoft heRochest ermanuf act ur edver si onoft hi sdevi ce.Rochest erEl ect r oni csguar ant eest heper f or manceofi t ssemi conduct orpr oduct st ot heor i gi nalOEM specicat i ons.‘ Typi cal ’val uesar ef orr ef er encepur posesonl y.Cer t ai nmi ni mum ormaxi mum r at i ngs maybebasedonpr oductchar act er i zat i on,desi gn,si mul at i on,orsampl et est i ng. © 2013Roc hes t erEl ec t r oni c s ,LLC.Al lRi ght sRes er v ed07112013 Tol ear nmor e,pl eas ev i s i twww. r oc el ec . c om ICM7555, ICM7556 ® Data Sheet August 24, 2006 FN2867.9 General Purpose Timers Features The ICM7555 and ICM7556 are CMOS RC timers providing significantly improved performance over the standard SE/NE 555/6 and 355 timers, while at the same time being direct replacements for those devices in most applications. Improved parameters include low supply current, wide operating supply voltage range, low THRESHOLD, TRIGGER and RESET currents, no crowbarring of the supply current during output transitions, higher frequency performance and no requirement to decouple CONTROL VOLTAGE for stable operation. • Exact Equivalent in Most Cases for SE/NE555/556 or TLC555/556 Specifically, the ICM7555 and ICM7556 are stable controllers capable of producing accurate time delays or frequencies. The ICM7556 is a dual ICM7555, with the two timers operating independently of each other, sharing only V+ and GND. In the one shot mode, the pulse width of each circuit is precisely controlled by one external resistor and capacitor. For astable operation as an oscillator, the free running frequency and the duty cycle are both accurately controlled by two external resistors and one capacitor. Unlike the regular bipolar SE/NE 555/6 devices, the CONTROL VOLTAGE terminal need not be decoupled with a capacitor. The circuits are triggered and reset on falling (negative) waveforms, and the output inverter can source or sink currents large enough to drive TTL loads, or provide minimal offsets to drive CMOS loads. • Low Supply Current - ICM7555 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60μA - ICM7556 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 120μA • Extremely Low Input Currents . . . . . . . . . . . . . . . . . 20pA • High Speed Operation . . . . . . . . . . . . . . . . . . . . . . . 1MHz • Guaranteed Supply Voltage Range . . . . . . . . . 2V to 18V • Temperature Stability . . . . . . . . . . . . 0.005%/°C at +25°C • Normal Reset Function - No Crowbarring of Supply During Output Transition • Can be Used with Higher Impedance Timing Elements than Regular 555/6 for Longer RC Time Constants • Timing from Microseconds through Hours • Operates in Both Astable and Monostable Modes • Adjustable Duty Cycle • High Output Source/Sink Driver can Drive TTL/CMOS • Outputs have Very Low Offsets, HI and LO • Pb-Free Plus Anneal Available (RoHS Compliant) Applications • Precision Timing • Pulse Generation • Sequential Timing • Time Delay Generation • Pulse Width Modulation • Pulse Position Modulation • Missing Pulse Detector Pinouts ICM7555 (8 LD PDIP, SOIC) TOP VIEW ICM7556 (14 LD PDIP, CERDIP) TOP VIEW DISCHARGE 1 GND 1 8 VDD TRIGGER 2 7 DISCHARGE OUTPUT 3 6 THRESHOLD 5 CONTROL VOLTAGE RESET 4 THRESH- 2 OLD CONTROL 3 VOLTAGE RESET 4 OUTPUT 5 TRIGGER 6 GND 7 1 14 VDD 13 DISCHARGE 12 THRESHOLD 11 CONTROL VOLTAGE 10 RESET 9 OUTPUT 8 TRIGGER CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright © Intersil Americas Inc. 2002, 2004, 2005, 2006. All Rights Reserved All other trademarks mentioned are the property of their respective owners. ICM7555, ICM7556 Ordering Information PART NUMBER PART MARKING TEMP. RANGE (°C) PACKAGE PKG. DWG. # ICM7555CBA 7555 CBA 0 to +70 8 Ld SOIC M8.15 ICM7555CBA-T 7555 CBA 0 to +70 8 Ld SOIC Tape and Reel M8.15 ICM7555CBAZ (Note) 7555 CBAZ 0 to +70 8 Ld SOIC (Pb-free) M8.15 ICM7555CBAZ-T (Note) 7555 CBAZ 0 to +70 8 Ld SOIC (Pb-free) Tape and Reel M8.15 ICM7555IBA 7555 IBA -25 to +85 8 Ld SOIC M8.15 ICM7555IBAT 7555 IBA -25 to +85 8 Ld SOIC Tape and Reel M8.15 ICM7555IBAZ (Note) 7555 IBAZ -25 to +85 8 Ld SOIC (Pb-free) M8.15 ICM7555IBAZ-T (Note) 7555 IBAZ -25 to +85 8 Ld SOIC (Pb-free) Tape and Reel M8.15 ICM7555IPA 7555 IPA -25 to +85 8 Ld PDIP E8.3 ICM7555IPAZ (Note) 7555 IPAZ -25 to +85 8 Ld PDIP** (Pb-free) E8.3 ICM7556IPD ICM7556IPD -25 to +85 14 Ld PDIP E14.3 ICM7556IPDZ (Note) ICM7556IPDZ -25 to +85 14 Ld PDIP** (Pb-free) E14.3 ICM7556MJD ICM7556MJD -55 to +125 14 Ld Cerdip F14.3 **Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. NOTE: Intersil Pb-free products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. 2 FN2867.9 August 24, 2006 ICM7555, ICM7556 Absolute Maximum Ratings Thermal Information Supply Voltage. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .+18V Input Voltage Trigger, Control Voltage, Threshold, Reset (Note 1) . . . . . . . . . . . . . . . . . . . . . V+ +0.3V to GND -0.3V Output Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100mA Thermal Resistance (Typical, Note 2) θJA (°C/W) θJC (°C/W) 14 Lead CERDIP Package. . . . . . . . . . 80 24 14 Lead PDIP Package* . . . . . . . . . . . 115 N/A 8 Lead PDIP Package* . . . . . . . . . . . . 130 N/A 8 Lead SOIC Package . . . . . . . . . . . . . 170 N/A Maximum Junction Temperature (Hermetic Package) . . . . . . . +175°C Maximum Junction Temperature (Plastic Package) . . . . . . . +150°C Maximum Storage Temperature Range . . . . . . . . -65°C to +150°C Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . +300°C (SOIC - Lead Tips Only) * Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. Operating Conditions Temperature Range ICM7555C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to +70°C ICM7555I, ICM7556I . . . . . . . . . . . . . . . . . . . . . . -25°C to +85°C ICM7556M . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -55°C to +125°C CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 1. Due to the SCR structure inherent in the CMOS process used to fabricate these devices, connecting any terminal to a voltage greater than V+ +0.3V or less than V- -0.3V may cause destructive latchup. For this reason it is recommended that no inputs from external sources not operating from the same power supply be applied to the device before its power supply is established. In multiple supply systems, the supply of the ICM7555 and ICM7556 must be turned on first. 2. θJA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief 379 for details. Electrical Specifications Applies to ICM7555 and ICM7556, unless otherwise specified (NOTE 4) -55°C TO +125°C TA = +25°C PARAMETER SYMBOL Static Supply Current IDD ICM7555 ICM7556 Monostable Timing Accuracy TYP MAX MAX UNITS VDD = 5V 40 200 300 μA VDD = 15V 60 300 300 μA VDD = 5V 80 400 600 μA VDD = 15V 120 600 600 μA TEST CONDITIONS MIN RA = 10K, C = 0.1μF, VDD = 5V MIN TYP 2 % 858 Drift with Temperature (Note 3) Drift with Supply (Note 3) 150 ppm/°C VDD = 10V 200 ppm/°C VDD = 15V 250 ppm/°C 0.5 %/V 0.5 RA = RB = 10K, C = 0.1μF, VDD = 5V 2 % 1717 Drift with Temperature (Note 3) Drift with Supply (Note 3) 2323 μs VDD = 5V 150 ppm/°C VDD = 10V 200 ppm/°C VDD = 15V 250 ppm/°C 0.5 %/V VDD = 5V to 15V Threshold Voltage μs VDD = 5V VDD = 5V to 15V Astable Timing Accuracy 1161 0.5 VTH VDD = 15V 62 67 71 61 72 % VDD Trigger Voltage VTRIG VDD = 15V 28 32 36 27 37 % VDD Trigger Current ITRIG VDD = 15V 10 50 nA Threshold Current ITH VDD = 15V 10 50 nA Control Voltage VCV VDD = 15V 72 % VDD 3 62 67 71 61 FN2867.9 August 24, 2006 ICM7555, ICM7556 Electrical Specifications Applies to ICM7555 and ICM7556, unless otherwise specified (Continued) (NOTE 4) -55°C TO +125°C TA = +25°C PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX MIN 1.0 0.2 MAX UNITS 1.2 V Reset Voltage VRST VDD = 2V to 15V Reset Current IRST VDD = 15V 10 50 nA Discharge Leakage IDIS VDD = 15V 10 50 nA Output Voltage VOL VDD = 15V, ISINK = 20mA 0.4 1.0 1.25 V VDD = 5V, ISINK = 3.2mA 0.2 0.4 0.5 V VOH Discharge Output Voltage VDIS 0.4 TYP VDD = 15V, ISOURCE = 0.8mA 14.3 14.6 14.2 V VDD = 5V, ISOURCE = 0.8mA 4.0 4.3 3.8 V VDD = 5V, ISINK = 15mA 0.2 0.4 VDD = 15V, ISINK = 15mA Supply Voltage (Note 3) Functional Operation VDD 2.0 18.0 3.0 0.6 V 0.4 V 16.0 V Output Rise Time (Note 3) tR RL = 10M, CL = 10pF, VDD = 5V 75 ns Output Fall Time (Note 3) tF RL = 10M, CL = 10pF, VDD = 5V 75 ns VDD = 5V, RA = 470Ω, RB = 270Ω, C = 200pF 1 MHz Oscillator Frequency (Note 3) fMAX NOTES: 3. These parameters are based upon characterization data and are not tested. 4. Applies only to military temperature range product (M suffix). Functional Diagram VDD 8 R THRESHOLD 6 5 CONTROL VOLTAGE 4 FLIP-FLOP RESET OUTPUT DRIVERS COMPARATOR A + OUTPUT - 3 7 R DISCHARGE n + TRIGGER 2 1 COMPARATOR B 1 GND R NOTE: This functional diagram reduces the circuitry down to its simplest equivalent components. Tie down unused inputs. TRUTH TABLE THRESHOLD VOLTAGE TRIGGER VOLTAGE RESET OUTPUT DISCHARGE SWITCH Don’t Care Don’t Care Low Low On >2/3(V+) >1/3(V+) High Low On 1/3(V+) High Stable Stable Don’t Care
ICM7555CBA-T 价格&库存
很抱歉,暂时无法提供与“ICM7555CBA-T”相匹配的价格&库存,您可以联系我们找货
