QS18VP6DVSQ8
QS18VP6DVSQ8
    BANNER(邦纳)
    PHOTO SEN DIFFUSED 250MM PNP
QS18VP6DVSQ8 数据手册
WORLD-BEAM® QS18 Series Sensor Instruction Manual Miniature Self-Contained Photoelectric Sensors in Universal Housing • • • • • • • • Easily fits (or retrofits) almost any mounting situation Exceptional optical performance, comparable to larger “MINI-style” or barrel sensors 10 V dc to 30 V dc operation, with complementary (SPDT) NPN or PNP outputs, depending on model Bright LED operating status indicators are visible from 360° Rugged sealed housing, protected circuitry Models available with or without 18 mm threaded “nose” Less than 1 millisecond output response for excellent sensing repeatability Choose 2 m (6.5 ft) or 9 m (30 ft) cable or 150 mm (6 inch) Pico-style cabled QD WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Model 1 Opposed Mode QS186EV (624 nm Visible red) Range — Effective beam: 13 mm (0.5 inch) QS186E (940 nm Infrared) — QS18VN6R 20 m (66 ft) QS18VP6R OPPOSED QS186EB (940 nm Infrared) Output NPN PNP OPPOSED Effective beam: 13 mm (0.5 inch) — QS18VN6RB NPN 3 m (10 ft) QS18VP6RB PNP OPPOSED Model 1 Polarized Retroreflective Mode QS18VN6LP Range 630 nm Visible red P QS18VP6LP Output NPN 3.5 m (12 ft) PNP POLAR RETRO 1 • • • • • • To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, QS186E W/30. To order the 4-pin M12/Euro-style integral quick disconnect model, add the suffix "Q8" to the model number. For example, QS186EQ8. To order the 4-pin M8/Pico-style integral quick disconnect model, add the suffix "Q7" to the model number. For example, QS186EQ7. To order the 150 mm (6 in) PVC cable model with a 4-pin M12/Euro-style quick disconnect, add the suffix "Q5" to the model number. For example, QS186EQ5. To order the 150 mm (6 in) PVC cable model with a 4-pin M8/Pico-style quick disconnect, add the suffix "Q" to the model number. For example, QS186EQ. Models with a quick disconnect require a mating cordset. Original Document 197052 Rev. F 29 September 2020 197052 WORLD-BEAM® QS18 Series Sensor Model 1 QS18VN6LV Retroreflective Mode Range Output NPN 628 nm Visible red 6.5 m (21 ft) QS18VP6LV PNP RETRO Model 1 Convergent Mode QS18VN6CV15 630 nm Visible red Range 16 mm (0.63 in) QS18VP6CV15 QS18VN6CV45 QS18VP6CV45 Model 1 QS18VN6D CONVERGENT VISIBLE RED Diffuse Mode Range 940 nm Infrared 450 mm (18 in) QS18VN6DL QS18VN6DVS (Diffuse, Visible red) NPN PNP NPN 43 mm (1.7 in) QS18VP6D QS18VP6DL Output PNP Output NPN PNP NPN 600 mm (24 in) DIFFUSE PNP 630 nm Visible red NPN 250 mm (10 in) QS18VP6DVS (Diffuse, Visible red) PNP DIFFUSE QS18VN6DB (Diffuse, wide) NPN 450 mm (18 in) QS18VP6DB (Diffuse, wide) PNP DIFFUSE Model 1 Divergent Mode QS18VN6W (Divergent, Infrared) 940 nm Infrared Range Output NPN DIVERGENT 100 mm (4 in) QS18VP6W (Divergent, Infrared) PNP DIFFUSE Model 1 Fixed Field Mode Range QS18VN6FF50 QS18VP6FF50 50 mm (2 in) 630 nm Visible red QS18VN6FF100 100 mm (4 in) QS18VP6FF100 QS18VP6FF125 QS18VN6FF150 125 mm (5 in) FIXED-FIELD 150 mm (6 in) QS18VP6FF150 Model 1 QS18VN6FP Plastic Fiber Optic Mode Range 660 nm Visible Red NPN PNP NPN PNP PNP NPN PNP Output NPN Range varies by sensing mode and fiber optics used QS18VP6FP Output PNP PLASTIC FIBER 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 197052 Rev. F WORLD-BEAM® QS18 Series Sensor Model 1 Glass Fiber Optic Mode QS18VN6F Range Output NPN 940 nm Infrared Range varies by sensing mode and fiber optics used QS18VP6F PNP GLASS FIBER Wiring Diagrams QS18 with NPN Outputs bu (3) wh (2) bn (1) – 10–30 V dc + bn (1) bk (4) QS18 with PNP Outputs bk (4) wh (2) Load 4-pin M12/Euro-style Models (Male) 2 3 + 10–30 V dc – bu (3) Load QS18 Emitters brown + 10–30 V DC Load blue Load 4-pin M8/Pico-style Models (Male) 1 2 4 4 1 3 – Key 1 = Brown 2 = White 3 = Blue 4 = Black Installing Fibers Cutting Unterminated Plastic Fibers QS18V..6FP Unterminated plastic fibers are designed to be cut by the user to the length required for the application. To facilitate cutting, a Banner model PFC-1 cutting device is supplied with the fiber. Cut the fiber as follows: Lift to Open Ports Cutting Ports Use small ports for fiber sizes: • 0.25 mm (0.01 inches) • 0.5 mm (0.02 inches) Use large ports for fiber sizes: • 0.75 mm (0.03 inches) • 1.0 mm (0.04 inches) • 1.5 mm (0.06 inches) Figure 1. PFC-1 Cutting Device 1. Locate the control end of the fiber (the unfinished end). 2. Determine the length of fiber required for the application. If using a bifurcated fiber, separate the two halves of the fiber at least 51 mm (2 inches) beyond the fiber cutting location. 3. Lift the top (blade) of the cutter to open the cutting ports. 4. Insert one of the control ends through one of the cutting ports on the cutter so that the excess fiber protrudes from the back of the cutter. 5. Double-check the fiber length, and close the cutter until the fiber is cut. 6. Using a different cutting port, cut the second control end to the required length. Note: To ensure a clean cut each time, do not use a cutting port more than once. 7. Gently wipe the cut ends of the fiber with a clean, dry cloth to remove any contamination. Do not use solvents or abrasives on any exposed optical fiber. P/N 197052 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 3 WORLD-BEAM® QS18 Series Sensor Installing Plastic Fibers QS18V..6FP Follow these steps to install the plastic fibers. A C Fiber end Adapter B Adapter Installation Figure 2. Installing Plastic Fibers 1. 2. 3. 4. Slide the fiber gripper up to unlock it (A). If using 0.25 mm or 0.5 mm core fibers, slide the plastic fiber adapters onto the fibers, flush with the fiber ends. Carefully insert the prepared plastic fiber ends into the ports (B) as far as possible without applying extra force. Slide the fiber gripper down to lock the fibers in place (C). Installing Glass Fibers QS18V..6F Follow these steps to install the glass fibers. Retaining Clip O-rings Figure 3. Installing Glass Fibers 1. Slide the supplied o-ring on the sensor end of the fibers, as shown. 2. Press the fiber ends firmly into the ports located on the front of the sensor. 3. Slide the supplied u-shaped retaining clip into the slot in the sensor’s barrel until the clip snaps into place. Specifications Supply Voltage 10 V dc to 30 V dc (10% maximum ripple) at less than 25 mA, exclusive of load Protected against reverse polarity and transient voltages Repeatability Opposed Mode: 100 microseconds DVS, DL and FF Modes: 90 microseconds All Other Modes: 150 microseconds Light Source Glass Fiber Optic, Opposed and Diffuse mode models: Infrared, 940 nm Plastic Fiber Optic, Retroreflective, Convergent models: Visible red, 660 nm Fixed-Field and DVS models: Visible red, 630 nm Output Configuration Solid-state complementary (SPDT): NPN or PNP (current sinking or sourcing), depending on model; Rating: 100 mA maximum each output at 25 °C DVS, DL and FF Modes ON-state Saturation Voltage: less than 1.5 V at 10 mA; less than 3 V at 100 mA All Other Modes: ON-state Saturation Voltage: less than 1 V at 10 mA; less than 1.5 V at 100 mA Protected against false pulse on power-up and continuous overload or short circuit of outputs Adjustments Glass Fiber Optic, Plastic Fiber Optic, Convergent, Diffuse, and Retroreflective mode models (only): Single-turn sensitivity (Gain) adjustment potentiometer Indicators 2 LED indicators on sensor top Green: Power on Amber: Light sensed Amber flashing: Marginal excess gain (1 to 1.5 times excess gain) 4 Output Response Opposed Mode: 750 microseconds ON; 375 microseconds OFF DVS, FF and DL Modes: 850 microseconds ON/OFF All Other Modes: 600 microseconds ON/OFF 100 millisecond delay on power-up; outputs do not conduct during this time www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 197052 Rev. F WORLD-BEAM® QS18 Series Sensor Certifications Construction ABS housing 3 mm mounting hardware included Connections 2 m (6.5 ft) 4-wire PVC cable; 9 m (30 ft) 4-wire PVC cable; 4-pin M8/Picostyle or M12/Euro-style QD; or 150 mm (6 in) cable with a 4-pin M8/Picostyle or M12/Euro-style QD, depending on model Environmental IEC IP67; NEMA 6 Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Operating Conditions –20 °C to +70 °C (–4 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock All models meet MIL-STD-202F, Method 201A (Vibration: 10 Hz to 60 Hz maximum, 0.06 inch (1.52 mm) double amplitude, 10G maximum acceleration) requirements. Also meets IEC 60947-5-2 (Shock: 30G 11 ms duration, half sine wave) requirements. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Note: For performance specifications of the FF50 and FF100 models built prior to date code 17090, refer to document p/n 63908. Dimensions Model Suffix E, EV, R, and FF 15.0 mm (0.59") Model Suffix DB, W Model Suffix EB, RB 31.0 mm (1.22") 17.1 mm (0.67") Yellow LED 3.0 mm (0.12") 3.0 mm (0.12") 3.0 mm (0.12") 24.1 mm (0.95") 21.1 mm (0.82") 21.1 mm (0.82") Green LED 35.0 mm (1.38") Ø3.3 mm (0.13") Max. torque 0.6 Nm (5 in-lbs) Model Suffix FP 27.5 mm (1.09") 17.1 mm (0.67") Model Suffix F Model Suffix CV15, CV45, D, DL, LV, LP 15.0 mm (0.59") 7.5 mm (0.30") 13.4 mm (0.53") Single-turn Sensitivity Adjustment 31.0 mm (1.22") † 36.9 mm (1.45") 3.0 mm (0.12") 17.1 mm (0.67") † 19.8 mm (0.78") CV Models: 33.2 mm (1.31") 5.2 mm (0.21") 7.6 mm (0.30") P/N 197052 Rev. F M18x1 Thread Max. torque 2.3 Nm (20 in-lbs) www.bannerengineering.com - Tel: + 1 888 373 6767 Slot for Fiber Clip 5 WORLD-BEAM® QS18 Series Sensor Model Suffix Q5 Model Suffix Q (e.g. QS186EQ) Model Suffix Q7 (e.g. QS186EQ5) Model Suffix Q8 (e.g. QS186EQ7) (e.g. QS186EQ8) 41.5 mm (1.63") 150 mm (6") Euro-Style QD 150 mm (6") Pico-Style QD 49 mm (1.93") Integral 4-pin Pico-Style QD M18 x 1 Jam Nut Integral 4-pin Euro-Style QD Packing list: • Sensor • M18 x 1 jam nut • M3 hardware packet • Quick Start Guide, p/n 63687 M3 hardware packet contents: • 2 - M3 x 0.5 x 20 mm stainless steel screw • 2 - M3 x 0.5 stainless steel hex nut • 2 - M3 stainless steel washer 24.2 mm (0.95") 8.0 mm (0.32") Performance Curves Opposed Mode Excess Gain Curve Beam Pattern 1000 E X C E S S G A I N Excess Gain Curve 1000 QS186E, EV and QS18...R QS186E, EV and QS18...R 750 mm 500 mm 20 in Opposed Mode 250 mm 10 in 100 30 in Opposed Mode 0 10 0 250 mm 10 in 500 mm 20 in 750 mm 30 in 0 4m 12 ft 8m 26 ft 12 m 40 ft 16 m 52 ft 20 m 66 ft DISTANCE 1 0.1 m 0.3 ft 1m 3.3 ft 10 m 33 ft E X C E S S G A I N QS186EB and QS18...RB 100 1000 1 0.01 m 0.03 ft QS18...LP 30 mm Retroreflective Mode 20 mm DISTANCE 6 0.8 in 0.4 in with BRT-84 Reflector 0 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in .75 m 2.5 ft 1.5 m 5 ft 2.25 m 7.5 ft DISTANCE 10 m 33 ft 18 in .75 m 2.5 ft 1.5 m 5 ft 2.25 m 7.5 ft 3.0 m 10 ft 3.75 m 12.5 ft DISTANCE 0.1 m 0.33 ft 1m 3.3 ft 10 m 33 ft Excess Gain Curve 1.2 in Retroreflective Mode 0 1m 3.3 ft 12 in Beam Pattern 1000 QS18...LP 0 0.1 m 0.33 ft 6 in 300 mm Retroreflective 10 mm 1 0.01 m 0.03 ft 0 150 mm 0 Beam Pattern 10 6 in DISTANCE Excess Gain Curve G A I N 12 in 150 mm 450 mm Polarized Retroreflective with BRT-84 Reflector 18 in Opposed Mode 300 mm 0 10 100 m 330 ft 100 QS186EB and QS18...RB 450 mm Opposed Mode DISTANCE E X C E S S Beam Pattern 3.0 m 10 ft 3.75 m 12.5 ft E X C E S S G A I N QS18...LV 150 mm Retroreflective Mode 100 mm QS18...LV 4 in 50 mm 100 10 2 in with BRT-84 Reflector 0 0 50 mm 2 in 100 mm 4 in 150 mm with BRT-84 Reflector 6 in 0 1 0.01 m 0.03 ft 6 in Retroreflective Mode 1.5 m 5 ft 3.0 m 10 ft 4.5 m 15 ft 6.0 m 20 ft 7.5 m 25 ft DISTANCE 0.1 m 0.33 ft 1m 3.3 ft 10 m 33 ft DISTANCE www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 197052 Rev. F WORLD-BEAM® QS18 Series Sensor Convergent (Performance is based on a 90% reflectance white test card.) Excess Gain Curve Beam Pattern 1000 E X C E S S G A I N QS18...CV15 Convergent Mode 100 .16 in 2 mm .08 in 0 0 2 mm .08 in 4 mm .16 in 6 mm 10 .24 in 0 1 1 mm 0.04 in .24 in Convergent Mode 4 mm 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 40 mm 1.6 in 50 mm 2.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in Beam Pattern 1000 QS18...CV15 6 mm Excess Gain Curve E X C E S S QS18...CV45 6 mm QS18...CV45 Convergent Mode .08 in 0 10 0 2 mm .08 in 4 mm .16 in 6 mm .24 in 0 1 1 mm 0.04 in 1000 mm 40.0 in .16 in 2 mm 100 G A I N .24 in Convergent Mode 4 mm DISTANCE 15 mm 0.6 in 30 mm 1.2 in 45 mm 1.8 in 60 mm 2.4 in 75 mm 3.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40.0 in DISTANCE Diffuse (Performance is based on a 90% reflectance white test card.) Beam Pattern 1000 E X C E S S G A I N QS18...D QS18...D 6 mm Diffuse Mode 100 .08 in 0 10 0 2 mm .08 in 4 mm .16 in 6 mm .24 in 0 1 1 mm 0.04 in 100 mm 4.0 in 200 mm 8.0 in 300 mm 12.0 in 400mm 16.0 in 100 10 500 mm 20.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in 10 mm 8 mm 6 mm 4 mm 2 mm 0 2 mm 4 mm 6 mm 8 mm 10 mm QS18 DL .16 in 2 mm Beam Pattern 1000 .24 in Diffuse Mode 4 mm Excess Gain Curve EXCESS GAIN Excess Gain Curve 0 1 1 1000 mm 40.0 in QS18 DL 10 100 200 400 600 800 DISTANCE (mm) 1000 DISTANCE (mm) DISTANCE Diffuse (Performance is based on a 90% reflectance white test card.) Excess Gain Curve Beam Pattern 1000 G A I N QS18...DB Diffuse Mode 0 0 0.4 in 20 mm 0.8 in 30 mm 1.2 in 2 mm 1 mm 0.5 mm 100 0 0.5 mm 1 mm 1.5 mm 10 2 mm 2.5 mm 0 1 1 mm 0.04 in 100 mm 4.0 in 200 mm 8.0 in 300 mm 12.0 in 400mm 16.0 in 500 mm 20.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in DISTANCE 0 50 100 150 200 250 300 Distance (mm) 1 1 mm 0.04 in 1000 mm 40.0 in QS18...DVS Diffuse Mode 1.5 mm Diffuse Mode 0.4 in 10 mm 10 QS18...DVS 0.8 in 10 mm 100 2.5 mm 1.2 in Diffuse Mode 20 mm Beam Pattern 1000 QS18...DB 30 mm EXCESS GAIN E X C E S S Excess Gain Curve 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40.0 in DISTANCE Divergent (Performance is based on a 90% reflectance white test card.) Excess Gain Curve Beam Pattern 1000 E X C E S S G A I N QS18...W 30 mm QS18...W Divergent Diffuse Mode 100 0.8 in 10 mm 0.4 in 0 10 0 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 0 1 1 mm 0.04 in 1.2 in Divergent Diffuse Mode 20 mm 20 mm 0.8 in 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40.0 in DISTANCE P/N 197052 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 7 WORLD-BEAM® QS18 Series Sensor Fixed Field Excess Gain Curve (50 mm) Excess Gain Curve (100 mm) 1000 1000 1000 QS18..FF100 QS18..FF50 100 10 1 0.1 1 10 100 10 1 1 10 100 1000 Excess Gain Curve 20 mm 1000 2.4 in 1.6 in 0.8 in PIT46U 0 0 20 mm 0.8 in 40 mm 10 1.6 in Opposed Mode Plastic Fibers 60 mm PIT46U Fiber 0 50 mm 2 in 2.4 in 100 mm 4 in 150 mm 6 in 200 mm 250 mm 8 in 10 in DISTANCE 1 1 mm .04 in 10 mm .40 in 100 mm 4.0 in E X C E S S G A I N 100 1000 mm 40 in G A I N 10 mm 10 1.2 in Diffuse Mode Plastic Fibers 0.8 in PBT66U 0.4 in 0 10 mm 0.4 in PBT46U 0.8 in 30 mm 1.2 in 0 20 mm 0.8 in PBT46U Fiber 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.8 in DISTANCE 1 mm .04 in 10 mm .4 in 100 mm 4 in 10 50 mm 2 in 25 mm 1 in IT13S IT23S 0 25 mm 1 in 50 mm 2 in 75 mm 3 in IT23S Fibers 0 100 mm 4 in 200 mm 8 in 300 mm 12 in 400 mm 500 mm 16 in 20 in DISTANCE 1m 3.3 ft Bifurcated - Glass Fiber (Performance is based on a 90% reflectance white test card.) 1000 3 in Opposed Mode 0 IT23S Fibers w/L9 lenses .1 m .33 ft Diffuse Mode Plastic Fibers QS18..FP QS18..FP 20 mm Excess Gain Curve QS18F 75 mm Opposed Mode Glass Fibers IT13S Fibers 30 mm 20 mm Beam Pattern QS18F 1 .01 m .033 ft QS18..FP QS18..FP DISTANCE Excess Gain Curve 100 Beam Pattern PBT66U Fiber 1 .1 mm .004 in Opposed - Glass Fiber (Performance is based on a 90% reflectance white test card.) 1000 1000 0 DISTANCE E X C E S S 100 Excess Gain Curve PIT66U 40 mm Opposed Mode Plastic Fibers 10 Distance (mm) 50 mm Models: At 25 mm: 8 × 5.5 mm At 50 mm: 6 × 5 mm 100 mm Models At 50 mm: 6 × 4 mm At 100 mm: 3 × 3 mm 150 mm Models At 75 mm: 5 × 3.5 mm At 150 mm: 6 × 6 mm Bifurcated - Plastic Fiber (Performance is based on a 90% reflectance white test card.) QS18..FP QS18..FP 60 mm PIT66U Fiber G A I N 1 Beam Pattern QS18..FP QS18..FP 100 0.1 Distance (mm) Opposed - Plastic Fiber 1000 QS18..FF150 10 1 0.1 Distance (mm) E X C E S S Spot Sizes 100 Excess Gain Excess Gain 100 Excess Gain Excess Gain Curve (150 mm) 10 m 33 ft E X C E S S G A I N Beam Pattern QS18F 1.9 mm 100 0.65 mm BT23S Fiber 0.025 in BT13S 0 BT23S 0.65 mm 0.025 in 1.3 mm 0.050 in 1.9 mm 0.075 in 0 BT13S Fiber 1 1 mm .04 in 0.050 in Diffuse Mode 0 10 0.075 in QS18F 1.3 mm Diffuse Mode Glass Fibers 7.5 mm 0.3 in 15 mm 0.6 in 22.5 mm 0.9 in 30 mm 1.2 in 37.5 mm 1.5 in DISTANCE 10 mm .4 in 100 mm 4 in 1000 mm 40 in DISTANCE DISTANCE Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 2 m (6.56 ft) MQDC-415 5 m (16.4 ft) MQDC-430 9 m (29.5 ft) Style Dimensions 44 Typ. 8 15 m (49.2 ft) 2 1 3 4 Straight MQDC-450 Pinout (Female) M12 x 1 ø 14.5 www.bannerengineering.com - Tel: + 1 888 373 6767 1 = Brown 2 = White 3 = Blue 4 = Black P/N 197052 Rev. F WORLD-BEAM® QS18 Series Sensor 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406RA 2 m (6.56 ft) MQDC-415RA 5 m (16.4 ft) MQDC-430RA 9 m (29.5 ft) Style Dimensions 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 15 m (49.2 ft) M12 x 1 ø 14.5 [0.57"] 4-Pin Snap-on M8/Pico-Style Cordsets—Single Ended Model Length Style Dimensions Pinout (Female) 32 Typ. PKG4-2 2.03 m (6.66 ft) Straight ø 9.0 4 3 29 Typ. PKW4Z-2 2 m (6.56 ft) 2 1 Right-Angle 1 = Brown 2 = White 3 = Blue 4 = Black 15 Typ. ø 10.9 Sensor Status Indicators S15L Series In-Line Sensor Status Indicator Model Input Type S15LGYPQ PNP LED Color Dimensions NPN Input Active = Yellow Male 57.8 [2.27] Power ON = Green S15LGYNQ Female 27.9 [1.1] 1 4 15.0 [0.59] 2 3 2 3 Wiring 1 = Brown, 10 to 30 V DC 2 = White 4 3 = Blue, dc common 4 = Black, Sensor Input 1 WORLD-BEAM QS18 Brackets SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation 12-ga. stainless steel • • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 SMB312S 30 C A • 41 B Stainless steel 2-axis, sidemount bracket 46 B C A 46 32 20 A = 4.3 × 7.5, B = diam. 3, C = 3 × 15.3 All measurements are in millimeters. P/N 197052 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 9 WORLD-BEAM® QS18 Series Sensor Retroreflective Targets Go to www.bannerengineering.com or see the Accessories section of your current Banner Engineering Corp catalog for complete information. Note: Polarized sensors require corner cube type retroreflective targets only. Plastic and Glass Fiber Optics Go to www.bannerengineering.com or see the Accessories section of your current Banner Engineering Corp catalog for a list of plastic and glass fiber optic cables. Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. FCC Part 15 and CAN ICES-3 (B)/NMB-3(B) This device complies with part 15 of the FCC Rules and CAN ICES-3 (B)/NMB-3(B). Operation is subject to the following two conditions: 1. 2. This device may not cause harmful interference, and This device must accept any interference received, including interference that may cause undesired operation. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules and CAN ICES-3 (B)/NMB-3(B). These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: • Reorient or relocate the receiving antenna. • Increase the separation between the equipment and receiver. • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. • Consult the manufacturer. © Banner Engineering Corp. All rights reserved
QS18VP6DVSQ8 价格&库存
很抱歉,暂时无法提供与“QS18VP6DVSQ8”相匹配的价格&库存,您可以联系我们找货
QS18VP6DVSQ8
  • 1+869.988021+113.05717
