Q10AN6R
Q10AN6R
    BANNER(邦纳)
    Q10 SERIES: RECEIVERRANGE: 1
Q10AN6R 数据手册
Q10 Series Sensors Datasheet Miniature Self-Contained DC Photoelectric Sensors • • • • • Self-contained dc sensors in miniature right-angle housings; only 11 mm (0.43 in) thick Epoxy-encapsulated circuitry; IP54 (NEMA5) construction; hermetically-sealed optics 1.8 m (70 in) opposed range or 0.5 m (20 in) diffuse range Diffuse models have sensitivity adjustment Choose models for light operate or dark operate; choose either NPN (sinking) or PNP (sourcing) output models WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Note: Models with a quick disconnect require a mating cordset. Table 1: Q10 Opposed Mode Emitter (E) and Receiver (R) Models Range Cable Supply Voltage Q106E 2 m (6.5 in) Q106EQ 3-Pin Pico-style 150 mm (6 in) QD Q10AN6R 2 m (6.5 in) Q10AN6RQ 3-Pin Pico-style 150 mm (6 in) QD Q10RN6R Q10RN6RQ 1.8 m (70 in) 2 m (6.5 in) 3-Pin Pico-style 150 mm (6 in) QD Q10AP6R 2 m (6.5 in) Q10AP6RQ 3-Pin Pico-style 150 mm (6 in) QD Q10RP6R 2 m (6.5 in) Q10RP6RQ 3-Pin Pico-style 150 mm (6 in) QD NPN/ PNP L.O./ D.O. - L.O. NPN 10 V dc to 30 V dc D.O. L.O. PNP D.O. Table 2: Q10 Diffuse Mode Models Range Cable Supply Voltage Q10AN6D 2 m (6.5 in) Q10AN6DQ 3-Pin Pico-style 150 mm (6 in) QD Q10RN6D 2 m (6.5 in) Q10RN6DQ 3-Pin Pico-style 150 mm (6 in) QD Q10AP6D 0.5 m (20 in) 2 m (6.5 in) Q10AP6DQ 3-Pin Pico-style 150 mm (6 in) QD Q10RP6D 2 m (6.5 in) Q10RP6DQ 3-Pin Pico-style 150 mm (6 in) QD Original Document 45725 Rev. C NPN/ PNP L.O./ D.O. L.O. NPN D.O. 10 V dc to 30 V dc L.O. PNP D.O. 23 October 2017 45725 Q10 Series Sensors Wiring Diagrams Emitters NPN Receivers 3 1 PNP Receivers 3 – 10-30V dc 4 + 1 – 10-30 V dc + 1 Key + 10-30 V dc – 3 4 Load 1 = Brown 3 = Blue 4 = Black Load Quick disconnect (QD) wiring diagrams are functionally identical. Mounting Specifications Flat Mounting Stand-Off Mounting M2.5 x 0.45 Machine Screw 25 mm (1.0 in) long Nylon Spacer M2.5 x 0.45 Machine Screw 12mm Long Split Lockwasher Hex Nut Specifications Sensing Beam Infrared, 880 nm Adjustments Diffuse models (only); single-turn, top-mounted sensitivity control for adjustment of system gain (turn clockwise to increase) Supply Voltage and Current 10 V dc to 30 V dc (10% maximum ripple) Emitter or receiver: 15 mA Diffuse models: 20 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity Output Configuration SPST solid-state dc switch Choose NPN (current sinking) or PNP (current sourcing) models Choose light operate (N.O.) or dark operate (N.C.) models Output Rating 150 mA maximum Off-state leakage current: < 10 microamps at 30 V dc On-state saturation voltage: < 0.5 V at 10 mA dc; < 1.5 V at 150 mA dc Output Protection Circuitry Protected against output short-circuit, continuous overload, and false pulse on power-up Overload trip point ≥ 220 mA, typical, at 20 °C Output Response Time Opposed mode: 8 ms On, 4 ms Off Diffuse mode: 3 ms On and Off Repeatability Opposed mode: 1.0 ms Diffuse mode: 0.75 ms 2 Indicators Opposed mode receivers and diffuse mode sensors have two LEDs: Green and Amber Green on = power to the sensor is On Green flashing = output is overloaded Amber on = light is sensed Amber flashing = marginal excess gain (1 to 1.5×) in light condition Emitters have one Green LED; Green on = power to the sensor is On Construction Housings are black ABS; Rated UL 94V0 Lenses are hermetically-sealed glass; lens covers are clear acrylic Circuitry is epoxy-encapsulated and completely sealed Stainless steel M2.5 mounting hardware is included Connections 2 m (6.5 ft) attached cable, or 3-pin pico-style quick-disconnect fitting Cables for QD models are purchased separately Environmental Rating IEC IP54 (NEMA 5) Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) www.bannerengineering.com - Tel: +1-763-544-3164 P/N 45725 Rev. C Q10 Series Sensors Dimensions Opposed Mode Models Diffuse Mode Models Cabled Models Cabled Models 11.0 mm (0.43 in) 11.0 mm (0.43 in) Yellow LED Signal Indicator (Receiver, Only) 21.6 mm (0.85 in) Green LED Power Indicator Yellow LED Signal Indicator (Receiver, Only) Gain (Sensitivity) Adjustment 35.0 mm (1.38 in) Green LED Power Indicator 15.2 mm (0.60 in) QD Models 2.8 mm (0.11 in) 2.8 mm (0.11 in) 2X Clearance for M2.5 Screw 10.0 mm (0.39 in) 18.0 mm (0.70 in) 2.8 mm (0.11 in) 20.0 mm (0.79 in) 14.5 mm (0.57 in) 2X Clearance for M2.5 Screw 2.8 mm (0.11 in) QD Models 28.9 mm (1.14 in) 20.0 mm (0.79 in) 14.5 mm (0.57 in) 42.4 mm (1.67 in) Performance Curves Opposed Mode 1000 E X C E S S G A I N Q10 Series Q10 Series 300 mm Opposed Mode 100 12 in Opposed Mode 200 mm 8 in 100 mm 4 in 0 10 1 .01 m .033 ft 0 100 mm 4 in 200 mm 8 in 300 mm 12 in 0 .1 m .33 ft 1m 3.3 ft .5 m 20 in 10 m 33 ft 1.0 m 40 in 1.5 m 60 in 2.0 m 80 in 2.5 m 100 in DISTANCE DISTANCE Effective Beam: 5 mm Diffuse Mode Performance based on a 90% reflectance white test card. 1000 E X C E S S G A I N Q10 Series Q10 Series 60 mm Diffuse mode 2.4 in Diffuse Mode 40 mm 1.6 in 20 mm 100 0.8 in 0 10 1 1 mm .04 in 0 20 mm 0.8 in 40 mm 1.6 in 60 mm 2.4 in 0 10 mm .4 in 100 mm 4 in 1000 mm 40 in 125 mm 5 in 250 mm 10 in 375 mm 15 in 500 mm 625 mm 20 in 25 in DISTANCE DISTANCE P/N 45725 Rev. C www.bannerengineering.com - Tel: +1-763-544-3164 3 Q10 Series Sensors Cordsets 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2 m (6.56 ft) PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 9 m (29.53 ft) PKG3M-10 10 m (32.81 ft) PKW3M-2 2 m (6.56 ft) PKW3M-5 5 m (16.40 ft) Style Dimensions 35 Typ. Straight ø 9.5 M8 x 1 4 1 3 28 Typ. 20 Typ. Right-Angle PKW3M-9 Pinout (Female) 9 m (29.53 ft) 1 = Brown 3 = Blue 4 = Black M8 x 1 ø 9.5 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
Q10AN6R 价格&库存
很抱歉,暂时无法提供与“Q10AN6R”相匹配的价格&库存,您可以联系我们找货
