ISD400-7212
ISD400-7212
    SICK
    DATA TRANSMIT PAIR W/ISD400-7211
ISD400-7212 数据手册
Product data sheet ISD400-7212 ISD400 OPTICAL DATA TRANSMISSION ISD400-7212 | ISD400 OPTICAL DATA TRANSMISSION A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. ISD400-7212 1065101 Data transmission requires two devices. The second device must be ordered separately. Other models and accessories Illustration may differ www.sick.com/ISD400 Detailed technical data Mechanics/electronics Supply voltage Vs DC 18 V ... 30 V Power consumption ≤ 3.6 W 1) Connection type 1 x Ethernet female connector M12, 4-pin, D-coded 1 x power supply male connector M12, 4-pin, A-coded Frequency F2 Enclosure rating IP65 Protection class III 1)  Without load with 24 V. Performance Transmission range 0.2 m ... 150 m Light source Laser, red (660 nm) Laser, infrared (785 nm) Laser class 1M (IEC 60825-1:2014, EN 60825-1:2014) Typ. light spot size (distance) 1.75 m (at 100 m) Aperture angle 1° (sender) 1.5° (receiver) Interfaces ✔ Ethernet Data transmission rate 100 Mbit/s Digital input Vs: sender deactivated Digital output Number 1 1) Type Push-pull: PNP/NPN Function Output active for LOW and HIGH level Warning messages as the laser ages, if the permissible limits of the interior device temperature are exceeded or undercut, if the optical path is interrupted, if no Ethernet cable is connected, if the receiving level is undercut, if the laser is not ready for operation, if the heating is switched on. 1) 2  HIGH: Uv – 3 V, LOW: < 2 V. INTEGRATION PRODUCTS | SICK Product data sheet | 2021-08-03 16:49:43 Subject to change without notice ISD400-7212 | ISD400 OPTICAL DATA TRANSMISSION Ambient data Electromagnetic compatibility (EMC) EN 61000-6-2 1) EN 61000-6-4 Ambient temperature, operation –20 °C ... +55 °C Ambient temperature, storage –40 °C ... +75 °C Max. rel. humidity (not condensing) 90 %, Non-condensing 1)  This is a Class A device. This device can cause radio interference in living quarters. General notes Note Setting up a data transmission path requires a pair of devices, where one device has frequency F1 (ISD400-7xx1) and the other device has frequency F2 (ISD400-7xx2). A wide variety of Ethernet protocols can be used in protocol-free transmission (e.g., PROFINET, PROFIsafe, EtherNet/IP, EtherCAT, TCP/IP, etc.). Classifications ECl@ss 5.0 19039001 ECl@ss 5.1.4 19039001 ECl@ss 6.0 19179090 ECl@ss 6.2 19179090 ECl@ss 7.0 19179090 ECl@ss 8.0 19179090 ECl@ss 8.1 19179090 ECl@ss 9.0 19179090 ECl@ss 10.0 19179090 ECl@ss 11.0 19170500 ETIM 5.0 EC000515 ETIM 6.0 EC000515 ETIM 7.0 EC000515 ETIM 8.0 EC000515 UNSPSC 16.0901 43201404 2021-08-03 16:49:43 | Product data sheet  Subject to change without notice INTEGRATION PRODUCTS | SICK 3 ISD400-7212 | ISD400 OPTICAL DATA TRANSMISSION Dimensional drawing (Dimensions in mm (inch)) 71.7 30 (2.82) (1.18) 1 123.5 (4.86) (1.57) 3 1 4 83 (3.27) 105 (4.13) M6 11 32 40 2 (0.43) 60 (2.34) (1.26) A B C D E F 5 6 116.2 (4.57) 9 Esc 7 8 Set H I J K L M N O P Q R S T 68.7 (2.70) ①  Threaded mounting hole M6 ②  Center of optical axis, sender ③  Receive indicator ④  Center of optical axis, receiver ⑤  Ethernet female connector M12, 4-pin, D-coded ⑥  Power supply male connector M12, 4-pin, A-coded ⑦  Display with pushbuttons ⑧  Optical adjustment aid ⑨  Alignment sight Connection type Ethernet connection type 3 4 2 1 Voltage supply connection type 1 4 2 3 4 INTEGRATION PRODUCTS | SICK Product data sheet | 2021-08-03 16:49:43 Subject to change without notice ISD400-7212 | ISD400 OPTICAL DATA TRANSMISSION Connection diagram Voltage supply connection diagram brn 1 wht 2 blu 3 blk 4 L+ MF2 M MF1 Ethernet connection diagram 1 Tx+ 2 Rx+ 3 Tx– 4 Rx– Adjustment possible 6 Set Esc ⑥  Liquid crystal display with function keys Recommended accessories Other models and accessories www.sick.com/ISD400 Brief description Type Part no. BEF-DME/ISD 2046052 Terminal and alignment brackets Alignment unit for DME4000/ISD400, aluminum, anodised 2021-08-03 16:49:43 | Product data sheet  Subject to change without notice INTEGRATION PRODUCTS | SICK 5 ISD400-7212 | ISD400 OPTICAL DATA TRANSMISSION A B C D E F H I J K L M N O P Q R S T Recommended services Additional services www.sick.com/ISD400 Type Part no. Extended warranty for a total of five years from delivery date 1680671 Warranty extensions • Product area: Identification solutions, machine vision, Distance sensors, Detection and ranging solutions • Range of services: The services correspond to the scope of the statutory manufacturer warranty (SICK general terms and conditions of purchase) • Duration: Five-year warranty from delivery date. 6 INTEGRATION PRODUCTS | SICK Product data sheet | 2021-08-03 16:49:43 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
ISD400-7212 价格&库存
很抱歉,暂时无法提供与“ISD400-7212”相匹配的价格&库存,您可以联系我们找货
