Q45BB6FQ5
Q45BB6FQ5
    BANNER(邦纳)
    SEN FIBER DEPEND RANGE BIPOLAR
Q45BB6FQ5 数据手册
Q45BB6 Series Sensors Datasheet 10 V dc to 30 V dc Photoelectric Sensors With Sinking and Sourcing Solid-State Outputs • • • • • • • • • • Advanced one-piece photoelectric sensors with outstanding optical performance and extremely rugged design Operate from: 10 V dc to 30 V dc Bipolar NPN (sinking)/PNP (sourcing) outputs on all models Multiple sensing modes available: opposed, diffuse, retroreflective, and convergent, plus glass and plastic fiber optic models Selectable light/dark operate Versatile plug-in modules available for output timing logic and/or signal strength display Highly visible Power, Signal (AID™ System 1), and Output indicator LEDs Choice of prewired 2 m (6.5 ft) or 9 m (30 ft) unterminated cable, plus Mini-style or Euro-style quick-disconnect fittings Versatile mounting options Designed to withstand 1200 psi washdown; exceeds its NEMA 6P and IEC IP67 rating WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models To order the 9 m (30 ft) cable models, add the suffix "W/30" to the cabled model number. Models with a quick disconnect (QD) connector require a mating cable. Opposed-Mode Emitter (E) and Receiver (R) Models Because of their extremely high excess gain, these opposed-mode sensors are an excellent option for sensing in contaminated or dirty areas, and are also the best choice for long-range sensing. OPPOSED Infrared, 880 nm Models Range Cable Q456E Emitter 2-wire 2 m (6.5 ft) cable Q45BB6R Receiver 4-wire 2 m (6.5 ft) cable Q456EQ Emitter Q45BB6RQ Receiver Q456EQ5 Emitter Q45BB6RQ5 Receiver 60 m (200 ft) 4-Pin Mini-style QD Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 4-pin Euro-style QD 1 U.S. Patent no. 4356393 Original Document 36578 Rev. E 11 November 2016 36578 Q45BB6 Series Sensors Retroreflective-Mode Models The visible red sensing beam of these sensors makes them very easy to align. Model Q45BB6LP polarizes the emitted light and filters out unwanted reflections, making sensing possible in applications otherwise considered unsuited to retroreflective sensing. Specified using the model BRT-3 3-inch reflector (go to www.bannerengineering.com additional information). P RETRO POLAR RETRO Visible red, 680 nm (non-polarized) Visible red, 680 nm (polarized) Non-Polarized Models Range Cable Q45BB6LV Q45BB6LVQ Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 4-wire 2 m (6.5 ft) cable 0.08 to 9 m (3 in to 30 ft) Q45BB6LVQ5 4-Pin Mini-style QD 4-Pin Euro-style QD Polarized Models Range Cable Q45BB6LP Q45BB6LPQ 4-wire 2 m (6.5 ft) cable 0.15 to 6 m (6 in to 20 ft) Q45BB6LPQ5 4-Pin Mini-style QD 4-Pin Euro-style QD Diffuse-Mode Models These diffuse-mode models detect objects by sensing the reflection of their own emitted light. Ideal for use when the reflectivity and profile of the object to be sensed are sufficient to return a large percentage of emitted light back to the sensor. Model Q45BB6DX is the first choice for diffuse-mode applications when there are no background objects to falsely return light. DIFFUSE Infrared, 880 nm Short Range Models Range Cable Q45BB6D Q45BB6DQ Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 4-wire 2 m (6.5 ft) cable 45 cm (18 in) Q45BB6DQ5 4-Pin Mini-style QD 4-Pin Euro-style QD Long Range Models Range Q45BB6DL Q45BB6DLQ Cable 4-wire 2 m (6.5 ft) cable 1.8 m (6 ft) Q45BB6DLQ5 4-Pin Mini-style QD 4-Pin Euro-style QD High Power Models Range Q45BB6DX Q45BB6DXQ Q45BB6DXQ5 2 Cable 4-wire 2 m (6.5 ft) cable 3 m (10 ft) 4-Pin Mini-style QD 4-Pin Euro-style QD www.bannerengineering.com - Tel: +1-763-544-3164 P/N 36578 Rev. E Q45BB6 Series Sensors Convergent-Mode Models These sensors are ideal for reflective sensing of very small parts or profiles, and can accurately sense the position of parts approaching from the side. Ignores all but highly reflective objects that are outside the sensing range. CONVERGENT Visible red, 680 nm Models Q45BB6CV Q45BB6CVQ Q45BB6CVQ5 Q45BB6CV4 Q45BB6CV4Q Q45BB6CV4Q5 Focus Cable 38 mm (1.5 in) 4-wire 2 m (6.5 ft) cable Spot Size at Focus: 1.3 mm (0.05 in) 4-Pin Mini-style QD 4-Pin Euro-style QD 100 mm (4 in) 4-wire 2 m (6.5 ft) cable Spot Size at Focus: 1.5 mm (0.06 in) 4-Pin Mini-style QD Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 10 V dc to 30 V dc Bipolar NPN/PNP 4-Pin Euro-style QD Glass Fiber Optic Models These models are an excellent choice for glass fiber optic applications where faster sensor response is not important. Their high excess gain means that opposed individual fibers can operate reliably in many very hostile environments. Also, special miniature bifurcated fiber optic assemblies with bundle sizes as small as 0.5 mm (.020 in) diameter may be used successfully for diffuse-mode sensing when using sensor model Q45BB6F(Q). For more information on compatible glass fiber optics, go to www.bannerengineering.com. Range: Range varies by sensing mode and fiber optics used. GLASS FIBER Infrared, 880 nm and Visible red, 650 nm Infrared, 880 nm Models Q45BB6F Cable Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 4-wire 2 m (6.5 ft) cable Q45BB6FQ 4-Pin Mini-style QD Q45BB6FQ5 4-Pin Euro-style QD Visible Red, 650 nm Models Q45BB6FV Cable Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 4-wire 2 m (6.5 ft) cable Q45BB6FVQ 4-Pin Mini-style QD Q45BB6FVQ5 4-Pin Euro-style QD Plastic Fiber Optic Models Lower in cost than glass fiber optics, plastic fiber optics are ideal for use in situations where environmental conditions allow (for example, low levels of acids, alkalis, and solvents). Most are easily cut to length in the field, and are available in a variety of sensing end styles. For more information on compatible plastic fiber optics, go to www.bannerengineering.com. Visible red, 660 nm Range: Range varies by sensing mode and fiber optics used. Models Q45BB6FP Cable Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP 4-wire 2 m (6.5 ft) cable Q45BB6FPQ 4-Pin Mini-style QD Q45BB6FPQ5 4-Pin Euro-style QD P/N 36578 Rev. E PLASTIC FIBER www.bannerengineering.com - Tel: +1-763-544-3164 3 Q45BB6 Series Sensors Overview Status indicator LEDs for power, signal, and output are clearly visible beneath a raised dome in the sensor’s transparent oring-sealed polycarbonate cover. Also located beneath the sensor’s o-ring-sealed cover are controls for light/dark operate selection and the sensitivity adjustment. • • The power indicator (green) lights when power is applied to the sensor. The signal indicator (red) lights when the sensor sees its modulated light source and pulses at a rate proportional to the strength of the received light signal; this is the AID™ Alignment Indicating Device2. The output indicator (amber) lights when the sensor’s output is conducting. This indicator is especially useful when a timing logic module is used and signal and output conditions are not concurrent. • 1. Sensitivity adjustment 2. LEDs • Green LED: Power on indicator • Red LED: Signal indicator • Amber LED: Output status indicator 3. Optional LED signal strength display 4. Optional timing adjustment 5. Optional timing adjustment 6. Light/dark operate switch 6 1 5 2 3 4 Wiring Diagrams Q45BB6 Sensors with Attached Cable 1 + 10-30V dc – 3 2 4 Load Q456E Emitters with Attached Cable 3 1 Load – Key: 1=Brown 2=White 3=Blue 4=Black 10-30V dc + NOTE: Wiring for quick disconnect (QD) models (model suffix Q and Q5) are functionally identical. 2 US patent no. 4356393 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 36578 Rev. E Q45BB6 Series Sensors Specifications Supply Voltage and Current 10 V dc to 30V dc (10% maximum ripple), at less than 50 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: one current sourcing (PNP) and one current sinking (NPN) open-collector transistor Output Rating 250 mA maximum each output up to 50 °C, derated to 150 mA at 70 °C (derates 5 mA/°C) Off-state leakage current less than 1 µA Output saturation voltage (both outputs) less than 1 V at 10 mA and less than 2 V at 250 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Response Time Opposed mode: 2 milliseconds ON, 1 millisecond OFF All other sensing modes: 2 milliseconds ON/OFF NOTE: 100 millisecond delay on power-up. Output is non-conducting during this time. Repeatability Opposed mode: 0.25 milliseconds All other sensing modes: 0.5 milliseconds Response time and repeatability specifications are independent of signal strength. Indicators Indicator LEDs are clearly visible beneath a raised transparent Lexan® dome on top of the sensor. Power (green) LED lights whenever 10 V dc to 30V dc power is applied, and flashes to indicate output overload or output short circuit Signal (red) AID™ System LED lights whenever the sensor sees its modulated light source, and pulses at a rate proportional to the strength of the received light signal Load (amber) LED lights whenever the output is energized Optional 7-element LED signal strength display modules Construction Molded reinforced thermoplastic polyester housing, o-ring-sealed transparent Lexan®3 cover, molded acrylic lenses, and stainless steel hardware. Designed to withstand 1200 psi washdown. The base of the cabled models has a ½-inch NPS integral internal conduit thread. Environmental Rating NEMA 6, IEC IP67 Connections PVC-jacketed 2 m (6.5 ft) or 9 m (30 ft) cables; or 4-pin Mini-style (“Q” suffix models) or 4-pin Euro-style (“Q5” suffix models) quickdisconnect (QD) fittings are available. QD cables are ordered separately. Operating Conditions Temperature: −40 °C to +70 °C (−40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Application Notes Optional output timing modules are available. See Output Timing Logic and Signal Strength Display Modules on page 9. Certifications Adjustments Beneath sensor’s transparent cover: Light/Dark Operate select switch and multi-turn Sensitivity control (allows precise sensitivity setting – turn clockwise to increase gain). Optional logic and logic/display modules have adjustable timing functions (see Output Timing Logic and Signal Strength Display Modules on page 9) Dimensions Opposed, Retro, and Diffuse Sensing Modes (Model Suffix E, R, D, DL, DX, LP, and LV) Cabled Models Mini-Style Quick-Disconnect Models Euro-Style Quick Disconnect Models 54.1 mm (2.13") 44.5 mm (1.75") Lens Centerline 50.8 mm (2.00") 69.0 mm (2.72") 6.4 mm (0.25") 87.6 mm (3.45") 4.5 mm (#10) Screw Clearance (2) 7.1 mm (0.28") 30.0 mm (1.18") Internal Thread (1/2–14NPSM) External thread (M30 x 1.5) hex nut supplied ø 6.1 (0.24") 2m (6.5') Cable External Thread M30 X 1.5 14 mm (0.6") Mini-style QD Connector 15 mm (0.6") Euro-style QD Connector 3 Lexan® is a registered trademark of General Electric Co. P/N 36578 Rev. E www.bannerengineering.com - Tel: +1-763-544-3164 5 Q45BB6 Series Sensors Convergent Sensor Models Glass Fiber Optic Models Plastic Fiber Optic Models (CV and CV4) (F and FV) (FP) 60.5 mm (2.38") 61.7 mm (2.43") 59.9 mm (2.36") Performance Curves Opposed Excess Gain Beam Pattern 1000 Effective Beam: 13 mm Q45E/R E X C E S S Opposed Mode G A I N Q45E/R 1.5 m 100 60 in Opposed Mode 1.0 m 40 in 0.5 m 20 in 0 10 0 0.5 m 20 in 1.0 m 40 in 1.5 m 1 0.1 m 0.33 ft 1.0 m 3.3 ft 10 m 33 ft 100 m 330 ft 60 in 0 12 m 40 ft 24 m 80 ft DISTANCE Excess Gain G A I N Beam Pattern Retroreflective Mode Q45LV 75 mm Retroreflective Mode With BRT-3 Reflector .10 m .33 ft 1.0 m 3.3 ft DISTANCE 10 m 33 ft 3.0 in 50 mm 2.0 in 25 mm 1.0 in 0 10 1 .01 m .033 ft Excess Gain Q45LV 100 60 m 200 ft Retroreflective Polarized 1000 1000 48 m 160 ft DISTANCE Retroreflective Non-Polarized E X C E S S 36 m 120 ft 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 0 3m 10 ft 6m 20 ft 9m 30 ft DISTANCE 12 m 40 ft 15 m 50 ft E X C E S S G A I N Beam Pattern Q45LP Retroreflective Mode 100 Q45LP 75 mm Retroreflective Mode 50 mm 25 mm 10 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 1 .01 m .033 ft .10 m .33 ft 1.0 m 3.3 ft DISTANCE 10 m 33 ft 2.0 in 1.0 in 0 With BRT-3 Reflector 3.0 in 3.0 in 0 1.5 m 5 ft 3m 10 ft 4.5 m 15 ft 6m 20 ft 7.5 m 25 ft DISTANCE Diffuse-mode performance curves are based on a 90% reflectance white test card. 6 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 36578 Rev. E Q45BB6 Series Sensors Diffuse Short Range Excess Gain Diffuse Long Range Beam Pattern Excess Gain 1000 1000 Q45D E X C E S S Diffuse Mode 15 mm 100 0.6 in Q45D 10 mm 0.4 in Diffuse Mode 5 mm G A I N 0.2 in 0 10 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 1 1.0 mm 0.04 in 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40 in 0.6 in 0 100 mm 4.0 in 200mm 8.0 in DISTANCE 300 mm 12.0 in E X C E S S G A I N Q45DL Diffuse Mode 100 Q45DL Diffuse Mode 75 mm 3.0 in 50 mm 2.0 in 25 mm 1.0 in 10 0 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 1 .01 m .033 ft 400 mm 500 mm 16.0 in 20.0 in Beam Pattern .10 m .33 ft DISTANCE 1.0 m 3.3 ft 10 m 33 ft 3.0 in 0 0.6 m 2 ft 1.2 m 4 ft DISTANCE 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE Diffuse High Power Excess Gain Beam Pattern 1000 Q45DX E X C E S S Diffuse Mode 100 G A I N Q45DX 75 mm 3.0 in Diffuse Mode 50 mm 2.0 in 25 mm 1.0 in 10 0 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 1 0.01 m 0.033 ft 0.1 m 0.33 ft 1.0 m 3.3 ft 10 m 33 ft 3.0 in 0 0.6 m 2 ft DISTANCE 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE Convergent mode performance curves are based on a 90% reflectance white test card. Convergent (CV and CVQ Models) Excess Gain Convergent (CV4 and CV4Q Models) Beam Pattern Excess Gain 1000 1000 Q45CV E X C E S S Convergent Mode 100 Q45CV 3.8 mm 0.15 in Convergent Mode 2.5 mm 0.10 in 1.2 mm G A I N 10 0.05 in 0 1 1 mm .04 in 10 mm .4 in 100 mm 4 in Beam Pattern 1000 mm 40 in 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 38 mm 1.5 in DISTANCE 75 mm 3.0 in 113 mm 4.5 in E X C E S S G A I N Q45CV4 Convergent Mode 100 0.15 in Convergent Mode 2.5 mm 0.10 in 1.2 mm 0.05 in 0 10 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 1 1 mm .04 in 150 mm 190 mm 6.0 in 7.5 in Q45CV4 3.8 mm 10 mm .4 in 100 mm 4 in 1000 mm 40 in 0.15 in 0 38 mm 1.5 in 113 mm 4.5 in 150 mm 190 mm 6.0 in 7.5 in DISTANCE DISTANCE DISTANCE 75 mm 3.0 in Glass fiber optic diffuse mode performance curves are based on a 90% reflectance white test card. Glass Fiber Optic, Infrared (Opposed Mode) Excess Gain Glass Fiber Optic, Infrared (Diffuse Mode) Beam Pattern Excess Gain 1000 E X C E S S G A I N 1000 Q45F Opposed Mode 100 Q45F 150 mm IT23S Fibers 50 mm 10 0 IT13S Fibers 0.1 m 0.33 ft 1.0 m 3.3 ft DISTANCE P/N 36578 Rev. E 10 m 33 ft 6.0 in Opposed Mode 100 mm IT23S Fibers 1 0.01 m 0.03 ft Beam Pattern 4.0 in 2.0 in 0 IT13S Fibers 50 mm 2.0 in 100 mm 4.0 in 150 mm 6.0 in 0 0.4 m 15 in 0.8 m 30 in 1.2 m 45 in DISTANCE 1.6 m 60 in 2.0 m 75 in E X C E S S G A I N Q45F Diffuse Mode 100 Q45F 3.8 mm Diffuse Mode 2.5 mm BT13S Fiber 1.3 mm BT23S Fiber BT13S Fiber 10 mm 0.4 in 100 mm 4.0 in DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 1000 mm 40 in 0 1.3 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 1 1 mm 0.04 in 0.10 in 0.05 in BT23S Fiber 0 10 0.15 in 0.15 in 0 25 mm 1 in 50 mm 2 in 75 mm 3 in 100 mm 125 mm 4 in 5 in DISTANCE 7 Q45BB6 Series Sensors Glass Fiber Optic, Visible Red (Opposed Mode) Excess Gain Glass Fiber Optic, Visible Red (Diffuse Mode) Beam Pattern Excess Gain 1000 1000 E X C E S S G A I N Beam Pattern Q45FV Opposed Mode Q45FV 30 mm 100 Opposed Mode 20 mm IT23S Fibers 10 mm 0.4 in 0 10 1 1.0 mm 0.04 in 10 mm 0.4 in 0 10 mm IT13S Fibers 100 mm 4 in 1.2 in 0.8 in IT23S Fibers 0.4 in IT13S Fibers 20 mm 0.8 in 30 mm 1.2 in 0 1000 mm 40 in 100 mm 4 in 150 mm 6 in 200 mm 8 in E X C E S S G A I N Q45FV Diffuse Mode 100 0.08 in 1.0 mm 10 0.04 in BT13S Fiber 0 BT13S Fiber 0 1.0 mm BT23S Fiber 0.04 in BT23S Fiber 2.0 mm 0.08 in 3.0 mm 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40 in 0.12 in 0 5 mm 0.2 in 10 mm 0.4 in DISTANCE DISTANCE DISTANCE 0.12 in Diffuse Mode 2.0 mm 1 1 mm 0.04 in 250 mm 300 mm 10 in 12 in Q45FV 3.0 mm 15 mm 0.6 in 20 mm 0.8 in 25 mm 1.0 in DISTANCE Plastic fiber optic Diffuse mode performance curves are based on a 90% reflectance white test card. Plastic Fiber Optic (Diffuse Mode) Plastic Fiber Optic (Opposed Mode) Excess Gain Beam Pattern Excess Gain 1000 E X C E S S 1000 Q45FP Opposed Mode 100 Q45FP 45 mm 0 PIT26U Fibers 100 mm 4.0 in 1.2 in 0.6 in 0 PIT26U Fibers 15 mm 10 mm 0.4 in PIT46U Fibers 15 mm 10 1 1 mm 0.04 in 1.8 in Opposed Mode 30 mm PIT46U Fibers G A I N Beam Pattern 0.6 in 30 mm 1.2 in 45 mm 1.8 in 1000 mm 40 in 0 DISTANCE 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 100 mm 125 mm 4.0 in 5.0 in DISTANCE E X C E S S G A I N Q45FP Diffuse Mode 100 PBT46U Fiber Q45FP 18 mm 0.75 in Diffuse Mode 12 mm 0.50 in PBT46U Fiber 6 mm 0.25 in 0 10 0 6 mm PBT26U Fiber 1 0.1 mm 0.004 in 1 mm 0.04 in 10 mm 0.4 in 100 mm 4 in 0.25 in 12 mm 0.50 in 18 mm 0.75 in 0 10 mm 0.4 in 20 mm 0.8 in DISTANCE 30 mm 1.2 in 40 mm 1.6 in 50 mm 2.0 in DISTANCE Accessories Corsets 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 Style Dimensions Pinout (Female) 9.14 m (30 ft) 3 4 Straight MQDC-450 2 1 44 Typ. M12 x 1 ø 14.5 15.2 m (50 ft) 1 = Brown 2 = White 3 = Blue 4 = Black 4-Pin Mini-Style Cordsets Model Length MBCC-406 1.83 m (6 ft) MBCC-412 3.66 m (12 ft) Style Dimensions 52 Typ. Pinout (Female) 7/8-16UN-2B Straight MBCC-430 8 ø 25.5 9.14 m (30 ft) www.bannerengineering.com - Tel: +1-763-544-3164 2 4 1 3 1 2 3 4 = = = = Brown White Blue Black P/N 36578 Rev. E Q45BB6 Series Sensors Retroreflective Targets Banner offers a wide selection of high-quality retroreflective targets. See www.bannerengineering.com for complete information. NOTE: Polarized sensors require corner cube type retroreflective targets. Non-polarized sensors may use any retroreflective target. Brackets SMB30C • 56 SMB30MM 30 mm split clamp, black A PBT bracket • • • B Mounting hole for 30 mm sensor 13 Hole center spacing: A=ø 45 Hole size: B=ø 27.2 • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor 57 70 with curved mounting slots for versatile orientation 66 Stainless steel mounting hardware included 12-ga. stainless steel bracket C 57 B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 Output Timing Logic and Signal Strength Display Modules Q45 sensors easily accept the addition of output timing logic and signal strength display functions. Display modules have a seven-element display that gives a more precise indication of excess gain than does the AID™ system LED that is standard on Q45 sensors. The modules listed below may be used with all Q45BB6 sensors. Refer to the module's datasheet for more information. Models Logic and/or Display Function 45LM58 Programmable output timing logic 45LM58D Programmable output timing logic plus signal strength display 45LMD Signal strength display only (no timing function) P/N 36578 Rev. E www.bannerengineering.com - Tel: +1-763-544-3164 9 Q45BB6 Series Sensors Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
Q45BB6FQ5 价格&库存
很抱歉,暂时无法提供与“Q45BB6FQ5”相匹配的价格&库存,您可以联系我们找货
Q45BB6FQ5
  • 1+1370.97124
库存:1
