S-8354J50MC-JZJT2U
S-8354J50MC-JZJT2U
    ABLIC(艾普凌科)
    SC74A
    IC REG BOOST 5V 300MA SOT23-5
S-8354J50MC-JZJT2U 数据手册
S-8353/8354 Series www.ablic.com STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR © ABLIC Inc., 2002-2020 Rev.3.1_00 The S-8353/8354 Series is a CMOS step-up switching regulator which mainly consists of a reference voltage source, an oscillation circuit, a power MOS FET, an error amplifier, a phase compensation circuit, a PWM control circuit (S-8353 Series) and a PWM / PFM switching control circuit (S-8354 Series). The S-8353/8354 Series can configure the step-up switching regulator with an external coil, capacitor, and diode. In addition to the above features, the small package and low current consumption make the S-8353/8354 Series ideal for portable equipment applications requiring high efficiency. The S-8353 Series realizes low ripple, high efficiency, and excellent transient characteristics due to its PWM control circuit whose duty ratio can be varied linearly from 0% to 83% (from 0% to 78% for 250 kHz models), an excellently designed error amplifier, and phase compensation circuits. The S-8354 Series features a PWM / PFM switching controller that can switch the operation to a PFM controller with a duty ratio is 15% under a light load to prevent a decline in the efficiency due to the IC operating current.  Features • Low voltage operation: Startup at 0.9 V min. (IOUT = 1 mA) guaranteed • Low current consumption : During operation 18.7 μA (3.3 V, 50 kHz, typ.) During shutdown: 0.5 μA (max.) • Duty ratio : Built-in PWM / PFM switching control circuit (S-8354 Series) 15 % to 83 % (30 kHz and 50 kHz models) 15 % to 78 % (250 kHz models) • External parts : Coil, capacitor, and diode • Output voltage : Selectable in 0.1 V steps between 1.5 V and 6.5 V (for VDD / VOUT separate types) Selectable in 0.1 V steps between 2.0 V and 6.5 V (for other than VDD / VOUT separate types) • Output voltage accuracy : ±2.4% • Oscillation frequency : 30 kHz, 50 kHz, and 250 kHz selectable • Soft start function : 6 ms (50 kHz, typ.) • Lead-free, Sn 100%, halogen-free*1 *1. Refer to “ Product Name Structure” for details.  Applications • Power supplies for portable equipment such as digital cameras, electronic notebooks, and PDAs • Power supplies for audio equipment such as portable CD / MD players • Constant voltage power supplies for cameras, VCRs, and communication devices • Power supplies for microcomputers  Packages • SOT-23-3 • SOT-23-5 • SOT-89-3 1 STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR S-8353/8354 Series Rev.3.1_00  Block Diagrams (1) A, C and H Types (Without Shutdown Function) CONT VOUT Oscillation circuit PWMcontrol circuit or PWM / PFM swiching control circuit Soft start built-in reference power supply IC internal power supply + − Phase compensation circuit VSS Figure 1 (2) A and H Types (With Shutdown Function) CONT VOUT Oscillation circuit PWMcontrol circuit or PWM / PFM swiching control circuit Soft start built-in reference power supply IC internal power supply + − Phase compensation circuit VSS ON / OFF Figure 2 (3) D and J Types (VDD / VOUT Separate Type) CONT VDD VOUT Oscillation circuit IC internal power supply + PWMcontrol circuit − or PWM / PFM swiching control circuit Soft start built-in reference power supply Phase compensation circuit Figure 3 2 VSS STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR Rev.3.1_00 S-8353/8354 Series  Product Name Structure The control system, product types, output voltage, and packages for the S-8353/8354 Series can be selected at the user’s request. Please refer to the “3. Product Name” for the definition of the product name, “4. Package” regarding the package drawings and “5. Product Name List” for the full product names. 1. Function List (1) PWM Control Products Table 1 Switching Frequency [kHz] Shutdown Function VDD / VOUT Separate Type Package S-8353AxxMC S-8353AxxMA S-8353AxxUA S-8353CxxMA S-8353CxxUA 50 50 50 30 30 Yes − − − − − − − − − SOT-23-5 SOT-23-3 SOT-89-3 SOT-23-3 SOT-89-3 S-8353DxxMC 50 − Yes SOT-23-5 S-8353HxxMC 250 Yes − SOT-23-5 S-8353HxxMA 250 − − SOT-23-3 S-8353HxxUA 250 − − SOT-89-3 S-8353JxxMC 250 − Yes SOT-23-5 Product Name Application Applications requiring shutdown function Applications not requiring shutdown function Applications not requiring shutdown function For pager For pager Applications requiring variable output voltage with an external resistor Applications requiring a shutdown function and a thin coil Applications not requiring a shutdown function and requiring a thin coil Applications not requiring a shutdown function and requiring a thin coil Applications requiring variable output voltage with an external resistor and a thin coil (2) PWM / PFM Switching Control Products Table 2 Switching Frequency [kHz] Shutdown Function VDD / VOUT Separate Type Package S-8354AxxMC S-8354AxxMA S-8354AxxUA S-8354CxxMA 50 50 50 30 Yes − − − − − − − SOT-23-5 SOT-23-3 SOT-89-3 SOT-23-3 S-8354DxxMC 50 − Yes SOT-23-5 S-8354HxxMC 250 Yes − SOT-23-5 S-8354HxxMA 250 − − SOT-23-3 S-8354HxxUA 250 − − SOT-89-3 S-8354JxxMC 250 − Yes SOT-23-5 Product Name Application Applications requiring shutdown function Applications not requiring shutdown function Applications not requiring shutdown function For pager Applications requiring variable output voltage with an external resistor Applications requiring a shutdown function and a thin coil Applications not requiring a shutdown function and requiring a thin coil Applications not requiring a shutdown function and requiring a thin coil Applications requiring variable output voltage with an external resistor and a thin coil 3 STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR S-8353/8354 Series Rev.3.1_00 2. Package and Function List by Product Type Table 3 Series Name S-8353 Series, S-8354 Series Type A (Normal product or with shutdown function) A = 50 kHz C (Normal product) C = 30 kHz D (VDD / VOUT separate type) D = 50 kHz H (Normal product or with shutdown function) H = 250 kHz J (VDD / VOUT separate type) J = 250 kHz Package Name Shutdown Function VDD / VOUT Separate Type Yes / No (Abbreviation) Yes / No MC Yes No MA / UA No MA No No MC No Yes MC Yes MA / UA No MC No No Yes 3. Product Name (1) SOT-23-3 S-835 x x xx MA - xxx xx x Environmental code U : Lead-free (Sn 100%), halogen-free G : Lead-free (for details, please contact our sales representatives) IC direction in tape specifications *1 T1 : Product of environmental code = U T2 : Product of environmental code = G Product code *2 Package code MA : SOT-23-3 Output voltage 15 to 65 (e.g. When the output voltage is 1.5 V, it is expressed as 15.) Product type A : Normal products (SOT-23-3, SOT-89-3) or With shutdown function products (SOT-23-5), C : Normal products, D : VDD / VOUT separate type, H : Normal products (SOT-23-3, SOT-89-3) or With shutdown function products (SOT-23-5), J : VDD / VOUT separate type, Control system 3 : PWM control 4 : PWM / PFM switching control *1. Refer to the tape specifications. *2. Refer to the Table 4 to Table 8 in the “5. Product Name List”. 4 fOSC = 50 kHz fOSC = 30 kHz fOSC = 50 kHz fOSC = 250 kHz fOSC = 250 kHz STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR Rev.3.1_00 S-8353/8354 Series (2) SOT-23-5, SOT-89-3 S-835 x x xx xx - xxx T2 x Environmental code U : Lead-free (Sn 100%), halogen-free G : Lead-free (for details, please contact our sales representatives) IC direction in tape specifications *1 Product code *2 Package code MC : SOT-23-5 UA : SOT-89-3 Output voltage 15 to 65 (e.g. When the output voltage is 1.5 V, it is expressed as 15.) Product type A : Normal products (SOT-23-3, SOT-89-3) or With shutdown function products (SOT-23-5), C : Normal products, D : VDD / VOUT separate type, H : Normal products (SOT-23-3, SOT-89-3) or With shutdown function products (SOT-23-5), J : VDD / VOUT separate type, fOSC = 50 kHz fOSC = 30 kHz fOSC = 50 kHz fOSC = 250 kHz fOSC = 250 kHz Control system 3 : PWM control 4 : PWM / PFM switching control *1. Refer to the tape specifications. *2. Refer to the Table 4 to Table 8 in the “5. Product Name List”. 4. Package Package Name SOT-23-3 SOT-23-5 SOT-89-3 Environmental code = G Environmental code = U Package MP003-A-P-SD MP003-C-P-SD MP005-A-P-SD UP003-A-P-SD Drawing Code Tape MP003-A-C-SD MP003-C-C-SD MP005-A-C-SD UP003-A-C-SD Reel MP003-A-R-SD MP003-Z-R-SD MP005-A-R-SD UP003-A-R-SD 5 STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR S-8353/8354 Series Rev.3.1_00 5. Product Name List (1) S-8353 Series Table 4 Output voltage 2.0 V 2.5 V 2.7 V 2.8 V 3.0 V 3.3 V 3.5 V 3.6 V 3.8 V 4.0 V 4.5 V 4.6 V 5.0 V 5.5 V S-8353AxxMC Series S-8353A20MC-IQFT2x S-8353A25MC-IQKT2x S-8353A27MC-IQMT2x S-8353A28MC-IQNT2x S-8353A30MC-IQPT2x S-8353A33MC-IQST2x S-8353A35MC-IQUT2x − S-8353A38MC-IQXT2x − S-8353A45MC-IRET2x − S-8353A50MC-IRJT2x S-8353A55MC-IROT2x S-8353AxxMA Series − − − − S-8353A30MA-IQPT S-8353A33MA-IQST − − − − − − S-8353A50MA-IRJT − S-8353AxxUA Series − − − − S-8353A30UA-IQPT2x S-8353A33UA-IQST2x − S-8353A36UA-IQVT2x S-8353A38UA-IQXT2x S-8353A40UA-IQZT2x − − S-8353A50UA-IRJT2x S-8353A55UA-IROT2x S-8353CxxMA Series − − − − S-8353C30MA-ISPT − − − − − − S-8353C46MA-ITFT − − Table 5 Output voltage 2.0 V 2.6 V 2.8 V 3.0 V 3.1 V 3.2 V 3.3 V 3.5 V 3.7 V 3.8 V 4.0 V 4.5 V 5.0 V 6.0 V 6.5 V Remark 1. 2. 3. 4. 6 S-8353CxxUA Series − − − S-8353C30UA-ISPT2x − − − − − − − − − − − S-8353DxxMC Series S-8353D20MC-IUFT2x − − S-8353D30MC-IUPT2x − − − − − − − − S-8353D50MC-IVJT2x − − S-8353HxxMC Series S-8353HxxMA Series − − − S-8353H30MA-IWPT − − S-8353H33MA-IWST − − − − − − − − S-8353H20MC-IWFT2x S-8353H26MC-IWLT2x S-8353H28MC-IWNT2x S-8353H30MC-IWPT2x S-8353H31MC-IWQT2x S-8353H32MC-IWRT2x S-8353H33MC-IWST2x S-8353H35MC-IWUT2x S-8353H37MC-IWWT2x S-8353H38MC-IWXT2x S-8353H40MC-IWZT2x S-8353H45MC-IXET2x S-8353H50MC-IXJT2x S-8353H60MC-IXTT2x S-8353H65MC-IXYT2x Please contact our sales representatives for products other than the above. x: G or U : 2G or 1U Please select products of environmental code = U for Sn 100%, halogen-free products. STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR Rev.3.1_00 S-8353/8354 Series Table 6 Output voltage 1.8 V 2.0 V 2.1 V 2.5 V 3.0 V 3.3 V 3.6 V 5.0 V S-8353HxxUA Series − − − − − S-8353H33UA-IWST2x S-8353H36UA-IWVT2x S-8353H50UA-IXJT2x S-8353JxxMC Series S-8353J18MC-IYDT2x S-8353J20MC-IYFT2x S-8353J21MC-IYGT2x S-8353J25MC-IYKT2x S-8353J30MC-IYPT2x S-8353J33MC-IYST2x − S-8353J50MC-IZJT2x (2) S-8354 Series Table 7 Output voltage 2.0 V 2.7 V 2.8 V 3.0 V 3.3 V 3.5 V 3.8 V 4.0 V 5.0 V S-8354AxxMC Series − S-8354A27MC-JQMT2x − S-8354A30MC-JQPT2x S-8354A33MC-JQST2x − S-8354A38MC-JQXT2x S-8354A40MC-JQZT2x S-8354A50MC-JRJT2x S-8354AxxMA Series S-8354AxxUA Series − S-8354A20MA-JQFT − S-8354A27MA-JQMT S-8354A28MA-JQNT S-8354A28UA-JQNT2x S-8354A30MA-JQPT S-8354A30UA-JQPT2x S-8354A33MA-JQST S-8354A33UA-JQST2x − S-8354A35UA-JQUT2x − − − S-8354A40UA-JQZT2x S-8354A50MA-JRJT S-8354A50UA-JRJT2x S-8354CxxMA Series − − − S-8354C30MA-JSPT − − − − − Table 8 Output voltage 1.5 V 2.0 V 2.5 V 2.7V 3.0 V 3.1 V 3.3 V 3.5 V 4.0 V 4.2 V 4.5 V 4.7 V 5.0 V Remark 1. 2. 3. 4. S-8354DxxMC Series − S-8354D20MC-JUFT2x − − S-8354D30MC-JUPT2x − S-8354D33MC-JUST2x − − − − − − S-8354HxxMC S-8354HxxUA S-8354JxxMC Series Series Series − − S-8354J15MC-JYAT2x − − S-8354J20MC-JYFT2x − − S-8354H25MC-JWKT2x − S-8354H27MC-JWMT2x S-8354H27UA-JWMT2x − S-8354H30MC-JWPT2x S-8354J30MC-JYPT2x − − S-8354H31MC-JWQT2x − S-8354H33MC-JWST2x S-8354J33MC-JYST2x − − S-8354H35MC-JWUT2x − − S-8354H40MC-JWZT2x − − S-8354H42MC-JXBT2x − − S-8354H45MC-JXET2x − − S-8354H47MC-JXGT2x − S-8354H50MC-JXJT2x S-8354J50MC-JZJT2x Please contact our sales representatives for products other than the above. x: G or U : 2G or 1U Please select products of environmental code = U for Sn 100%, halogen-free products. 7 STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR S-8353/8354 Series Rev.3.1_00  Pin Configurations Table 9 A, C and H Types (Without shutdown function, VDD / VOUT non-separate type) SOT-23-3 Top view 1 Pin No. 1 2 3 2 Symbol VOUT VSS CONT Description Output voltage pin and IC power supply pin GND pin External inductor connection pin 3 Figure 4 Table 10 A and H Types (With shutdown function, VDD / VOUT non-separate type) SOT-23-5 Top view 4 5 1 2 3 Figure 5 Pin No. Symbol Description Shutdown pin 1 “H”: Normal operation (Step-up operating) ON / OFF “L”: Step-up stopped (Entire circuit stopped) 2 VOUT Output voltage pin and IC power supply pin 3 NC*1 No connection 4 VSS GND pin 5 CONT External inductor connection pin *1. The NC pin indicates electrically open. Table 11 D and J Types (Without shutdown function, VDD / VOUT separate type) Pin No. Symbol Description 1 VOUT Output voltage pin 2 VDD IC power supply pin 3 NC*1 No connection 4 VSS GND pin 5 CONT External inductor connection pin *1. The NC pin indicates electrically open. SOT-89-3 Top view Table 12 A and H Types (Without shutdown function, VDD / VOUT non-separate type) Pin No. 1 2 3 1 2 Figure 6 8 3 Symbol VSS VOUT CONT Description GND pin Output voltage pin and IC power supply pin External inductor connection pin STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR Rev.3.1_00 S-8353/8354 Series  Absolute Maximum Ratings Table 13 (Ta = 25°C unless otherwise specified) Item Symbol VOUT pin voltage voltage*2 VDD pin CONT pin voltage CONT pin current VDD VCONT ICONT SOT-23-3 SOT-23-5 PD SOT-89-3 Operating ambient temperature Topr Storage temperature Tstg *1. With shutdown function *2. For VDD / VOUT separate type *3. When mounted on board [Mounted board] (1) Board size : 114.3 mm × 76.2 mm × t1.6 mm (2) Board name : JEDEC STANDARD51-7 Caution VSS − 0.3 to VSS + 12 V VSS − 0.3 to VSS + 12 VSS − 0.3 to VSS + 12 300 150 (When not mounted on board) 430*3 250 (When not mounted on board) 600*3 500 (When not mounted on board) 1000*3 −40 to + 85 −40 to + 125 V V mA mW mW mW mW mW mW °C °C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. When mounted on board (2) When not mounted on board 600 1000 Power dissipation (PD) [mW] 1200 Power dissipation (PD) [mW] (1) Unit V VOUT VON / OFF ON / OFF pin voltage*1 Power dissipation Absolute maximum rating VSS − 0.3 to VSS + 12 SOT-89-3 800 SOT-23-5 600 SOT-23-3 400 200 0 0 50 100 150 Ambient temperature (Ta) [°C] 500 SOT-89-3 400 SOT-23-5 300 SOT-23-3 200 100 0 0 50 100 150 Ambient temperature (Ta) [°C] Figure 7 Power Dissipation of Packages 9 STEP-UP, PWM CONTROL or PWM / PFM SWITCHABLE BUILT-IN TRANSISTOR SWITCHING REGULATOR S-8353/8354 Series Rev.3.1_00  Electrical Characteristics (1) 50 kHz Product (A and D Types) Table 14 Item Symbol Condition Output voltage VOUT − Input voltage Operation start voltage Oscillation start voltage VIN VST1 VST2 Operation holding voltage VHLD − IOUT = 1 mA No external parts, Voltage applied to VOUT IOUT = 1 mA, Judged by decreasing VIN voltage gradually S-835xx15 to 19 S-835xx20 to 29 S-835xx30 to 39 VOUT = VOUT(S) × 0.95 S-835xx40 to 49 S-835xx50 to 59 S-835xx60 to 65 S-835xx15 to 19 S-835xx20 to 29 S-835xx30 to 39 VOUT = VOUT(S) + 0.5 V S-835xx40 to 49 S-835xx50 to 59 S-835xx60 to 65 Current consumption 1 ISS1 Current consumption 2 ISS2 Current consumption during shutdown (With shutdown function) ISSS Switching current Switching transistor leakage current Line regulation Load regulation Output voltage temperature coefficient Oscillation frequency Maximum duty ratio PWM / PFM switching duty ratio (For S-8354 Series) VON / OFF = 0 V S-835xx15 to 19 S-835xx20 to 24 S-835xx25 to 29 S-835xx30 to 39 S-835xx40 to 49 S-835xx50 to 59 S-835xx60 to 65 − − V 2 − − − − − − − − − − − − 10.8 13.3 18.7 24.7 31.0 37.8 4.8 5.0 5.1 5.3 5.5 5.7 18.0 22.2 31.1 41.1 51.6 63.0 9.5 9.9 10.2 10.6 10.9 11.3 μA μA μA μA μA μA μA μA μA μA μA μA 1 1 1 1 1 1 1 1 1 1 1 1 − − 0.5 μA 1 80 103 125 144 176 200 215 128 165 200 231 282 320 344 − − − − − − − mA mA mA mA mA mA mA 1 1 1 1 1 1 1 VCONT = 0.4 V ISWQ VCONT = VOUT = 10 V − − 0.5 μA 1 ΔVOUT1 ΔVOUT2 ΔVOUT ΔTa • VOUT VIN = VOUT(S) × 0.4 to × 0.6 IOUT = 10 μA to VOUT(S) / 250 × 1.25 − − 30 30 60 60 mV mV 2 2 Ta = −40°C to +85°C − ±50 − ppm / °C 2 fOSC MaxDuty VOUT = VOUT(S) × 0.95 VOUT = VOUT(S) × 0.95 42.5 75 50 83 57.5 90 kHz % 1 1 PFMDuty VIN = VOUT(S) − 0.1 V, No-load 10 15 24 % 1 VSH VSL1 VSL2 0.75 − − − − − − 0.3 0.2 V V V 1 1 1 − 0.1 − 0.1 μA 1 − 0.1 − 0.1 μA 1 3.0 − 6.0 85 12.0 − ms % 2 2 ON / OFF pin input current (With shutdown function) ISH ISL VON / OFF = 0 V Soft start time Efficiency tSS EFFI 10 0.7 ISW Measured oscillation at CONT pin At VOUT≥1.5 V Judged oscillation stop at CONT pin At VOUT
S-8354J50MC-JZJT2U
物料型号:S-8353/8354系列 - 这些是CMOS升压型开关稳压器,包含内置的功率MOSFET。
器件简介: - S-8353/8354系列是主要应用于便携设备、音频设备、摄像头、VCRs、通信设备和微型计算机的电源供应的升压型开关稳压器。 - S-8353系列采用PWM控制电路,而S-8354系列则采用PWM/PFM切换控制电路。
引脚分配: - SOT-23-3封装有3个引脚,分别为VOUT(输出电压引脚和IC电源引脚)、VSS(地线)和CONT(外部电感连接引脚)。 - SOT-23-5封装有5个引脚,包括具有关闭功能的引脚ON/OFF。
参数特性: - 低电压启动:最低0.9V(IOUT = 1mA时保证启动)。 - 低电流消耗:运行时18.7μA(3.3V,50kHz,典型值);关闭时0.5μA(最大值)。 - 可调占空比:内置PWM/PFM切换控制电路(S-8354系列)15%至83%(30kHz和50kHz型号)或15%至78%(250kHz型号)。 - 输出电压:在1.5V至6.5V(VDD/VOUT分开型号)或2.0V至6.5V(其他型号)之间,以0.1V步进选择。 - 输出电压精度:±2.4%。 - 振荡频率:30kHz、50kHz和250kHz可选。
功能详解: - PWM控制产品(S-8353系列)通过改变脉冲宽度从0%至83%(对于H和J型号为78%)来控制开关频率,保持恒定,从而易于滤除开关产生的纹波电压。 - PWM/PFM切换控制产品(S-8354系列)根据负载电流自动在PWM和PFM之间切换,以降低轻载时的IC工作电流,防止效率下降。
应用信息: - 适用于便携设备(如数码相机、电子笔记本、PDAs)、音频设备(如便携式CD/MD播放器)、摄像头、VCRs、通信设备和微型计算机的电源供应。
封装信息: - 提供SOT-23-3、SOT-23-5和SOT-89-3封装。
S-8354J50MC-JZJT2U 价格&库存
很抱歉,暂时无法提供与“S-8354J50MC-JZJT2U”相匹配的价格&库存,您可以联系我们找货
