WL27-3P2430
WL27-3P2430
    SICK
    SENSOR RETROREFLECTIVE 11M PNP
WL27-3P2430 数据手册
Product data sheet WL27-3P2430 W27-3 COMPACT PHOTOELECTRIC SENSORS WL27-3P2430 | W27-3 COMPACT PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WL27-3P2430 1027769 Other models and accessories www.sick.com/W27-3 Illustration may differ Detailed technical data Features Dimensions (W x H x D) 24.6 mm x 80.6 mm x 54 mm Housing design (light emission) Rectangular Sensing range max. 0.1 m ... 15 m 1) Sensing range 0.1 m ... 11 m 1) Type of light Visible red light Light source LED 2) Light spot size (distance) Ø 220 mm (10 m) Angle of dispersion Approx. 1.5° Wave length 660 nm Adjustment None 1) 2)  Reflector PL80A.  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 1) 2) 3) 4) 5) 6) 7) 8) 2 10 V DC ... 30 V DC 1)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  Reference voltage: 50 V DC. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-04-14 18:31:38 Subject to change without notice WL27-3P2430 | W27-3 COMPACT PHOTOELECTRIC SENSORS Ripple
WL27-3P2430 价格&库存
很抱歉,暂时无法提供与“WL27-3P2430”相匹配的价格&库存,您可以联系我们找货
