WORLD-BEAM® QS30 – Universal Voltage
Quick Start Guide
Self-Contained, Photoelectric Sensors in Universal-Style Housing
For additional technical information about this product, including complete instructions, dimensions, accessories, and
specifications, see http://www.bannerengineering.com and search 119166.
WARNING: Not To Be Used for Personnel Protection
Never use this device as a sensing device for personnel protection. Doing
so could lead to serious injury or death. This device does not include the selfchecking redundant circuitry necessary to allow its use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or deenergized sensor output condition.
Models
Sensing Mode
OPPOSED
P
Model
Range
LED
Infrared, 875 nm
QS303E Emitter
60 m (200 ft)
QS30VR3R Receiver
60 m (200 ft)
8 m (26 ft)2
Visible red, 630 nm
QS30VR3LP
Effective Beam: 18 mm (0.7 in)
POLAR RETRO
FIXED-FIELD
Output
SPDT
QS30VR3FF200
200 mm (7.9 in)
QS30VR3FF400
400 mm (15.7 in)
QS30VR3FF600
600 mm (23.6 in)
Visible red, 680 nm
1 Standard 2 m (6.5 ft) cable models are listed.
For 9 m (30 ft) integral cable: add suffix "W/30” (for example, QS303E W/30).
5-pin Micro-style 152 mm (6 in) cable: add "QPMA" (for example, QS303EQPMA).
2 Range is measured using a model BRT-84 retroreflector.
Original Document
119168 Rev. C
1 February 2016
119168
Wiring Diagrams
Cabled Emitters
Other Cabled Models
Cable and QPMA hookups are functionally identical.
bn
bu
bn
24 - 250V ac (50/60 Hz)
12 - 250V dc
bu
12 - 250V dc
wh
N.C.
ye
C
bk
N.O.
Specifications
Supply Voltage
Universal Voltage: 24 V to 250 V ac (50 Hz/60 Hz) or 12 V to 250 V
dc (1.0 watt maximum)
Supply Protection Circuitry
Protected against transient voltages
Operating Conditions
Temperature: −20 °C to +70 °C (−4 °F to +158 °F)
Humidity: 90% at +50 °C maximum relative humidity (noncondensing)
Required Overcurrent Protection
Output Configuration
SPDT (Single-Pole Double-Throw) electromechanical relay output (all
models except emitters)
Output Rating
Max. Switching Power (resistive load): 150 W, 1250 VA
Max. Switching Voltage (resistive load): 250 V ac; 125 V dc
Max. Switching Current (resistive load): 5 A @ 250 V ac; 5 A @ 30
V dc derated to 200 mA @ 125 V dc
Min. Voltage and Current: 5 V dc, 10 mA
Mechanical life of relay: 50 million operations
Electrical life of relay at full resistive load: 100,000 operations
Output Response
15 milliseconds ON and OFF
NOTE: 100 millisecond delay on power-up;
output does not conduct during this time.
Cutoff Point Tolerance
Fixed-Field Only: ± 5% of nominal cutoff distance
Indicators
Two LEDs (Green and Amber) on top of sensor
Green ON: power to sensors is ON
Amber ON: light sensed
Amber flashing: excess gain marginal (1 to 1.5 times) in light
condition
WARNING: Electrical connections must be
made by qualified personnel in accordance
with local and national electrical codes and
regulations.
Overcurrent protection is required to be provided by end product
application per the supplied table.
Overcurrent protection may be provided with external fusing or via
Current Limiting, Class 2 Power Supply.
Supply wiring leads < 24 AWG shall not be spliced.
For additional product support, go to http://
www.bannerengineering.com.
Supply Wiring (AWG)
Required Overcurrent Protection (Amps)
22
3.0
24
2.0
26
1.0
28
0.8
30
0.5
Certifications
Large, oval LED indicator on sensor back (except emitters)
Amber ON: normally open output is conducting
Construction
ABS housing, rated IEC IP67, NEMA 6; acrylic lens cover
Connections
2 m (6.5 in) or 9 m (30 in) 5-wire PVC cable
2
www.bannerengineering.com - Tel: +1-763-544-3164
P/N 119168 Rev. C
Dimensions
Hardware included:
(2) M3 x 0.5 x 28 stainless steel
machine screws, nuts and washers
22.0 mm
(0.87")
54.3 mm
(2.14")
1.4 mm
(0.05")
44.0 mm
(1.73")
8.9 mm
(0.35")
M30 x 1.5 Thread
max. torque 6 Nm (53 in lbs)
with included
30 mm mounting nut
51.1 mm
(2.01")
Amber and Green LEDs
Amber LED
Output
Indicator
33.0 mm
(1.30")
5.5 mm
(0.22")
12.5 mm
(0.47")
2 x ø3.3 mm (0.13")
max. torque
0.7 Nm (6 in lbs)
16 mm
(0.63")
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp.
will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty
period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION,
ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE
OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE
LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL,
CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER
ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product
previously manufactured by Banner Engineering Corp.
很抱歉,暂时无法提供与“QS30LLPC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2630.758411+340.99638
