ML17-8-450/115/136
ML17-8-450/115/136
    PEPPERL+FUCHS(倍加福)
    DIFFUSED PHOTO SEN 10-450MM
ML17-8-450/115/136 数据手册
Diffuse mode sensor ML17-8-450/115/136 Dimensions 29.3 15 24.1 34.5 M18 x 1 10.2 ø3 13.9 Model Number ML17-8-450/115/136 Diffuse mode sensor with fixed cable Features • Compact, versatile housing • 360° high visibility LEDs • Adjustable sensing range • Front mounting with M18-threads or side mounting holes Electrical connection BN +UB WH Q2 BU 0V BK Q1 = Light on = Dark on Indicators/operating means 1 3 1 Signal display yellow 2 Operating display green 3 Sensitivity adjustment Release date: 2020-01-06 22:06 Date of issue: 2020-01-06 905783_eng.xml 2 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Diffuse mode sensor ML17-8-450/115/136 Technical data Accessories General specifications Detection range Adjustment range Reference target Light source Light type Ambient light limit 10 ... 450 mm 60 ... 450 mm standard white, 100 mm x 100 mm IRED modulated infrared light , 950 nm ≤ 10000 Lux Indicators/operating means Operation indicator Function indicator Control elements LED green LED yellow, lights up with receiver lit Sensing range adjuster Electrical specifications Operating voltage Ripple No-load supply current Time delay before availability Output Switching type Signal output Switching voltage Switching current Voltage drop Switching frequency Response time UB I0 tv Ud f OMH-ML17 Mounting bracket OMH-ML17-1 Mounting bracket Additional accessories can be found in the Internet. 10 ... 30 V DC , class 2 max. 10 % < 25 mA ≤ 200 ms light/dark on 2 push-pull (4 in 1)outputs, short-circuit protected, reverse polarity protected, overvoltage protected max. 30 V DC max. 100 mA per output ≤ 2.5 V DC 500 Hz ≤ 1 ms Conformity Product standard EN 60947-5-2 Ambient conditions Ambient temperature Storage temperature -20 ... 55 °C (-4 ... 131 °F) -20 ... 70 °C (-4 ... 158 °F) Mechanical specifications Housing width Housing height Degree of protection Connection Material Housing Optical face Mass OMH-ML17-EZ Mounting bracket 15 mm 34.5 mm IP67 2 m PVC cable ABS Acrylic approx. 40 g Approvals and certificates UL approval CCC approval cULus CCC approval / marking not required for products rated ≤36 V Curves/Diagrams ML17-8-450 Characteristic response curve Offset Y [mm] 20 15 10 905783_eng.xml 5 0 -5 -10 Date of issue: 2020-01-06 -15 -20 0 50 100 150 200 250 300 350 400 450 500 Distance X [mm] Release date: 2020-01-06 22:06 y x 2 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Diffuse mode sensor ML17-8-450/115/136 ML17-8-450 Relative received light strength Stability control 61 51 41 31 21 11 1 0 50 100 150 200 250 300 350 400 450 500 Distance X [mm] Release date: 2020-01-06 22:06 Date of issue: 2020-01-06 905783_eng.xml x Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
ML17-8-450/115/136 价格&库存
很抱歉,暂时无法提供与“ML17-8-450/115/136”相匹配的价格&库存,您可以联系我们找货
