Q60BB6AFV1000Q
Q60BB6AFV1000Q
    BANNER(邦纳)
    PHOTO SEN 200-1000MM BIPOLAR
Q60BB6AFV1000Q 数据手册
Q60AFV Series Sensors with Visible Red Emitter Datasheet Self-Contained Adjustable-Field Sensors • • • • • • • Adjustable-field background suppression sensor detects objects within a defined sensing field, while ignoring objects located beyond the sensing field cutoff Two-turn, logarithmic adjustment of sensing field cutoff point from 0.2 m to 1 m (7.9 in to 3.3 ft); allows easy setting of cutoff point at long range Rotating pointer indicates relative cutoff point setting Easy push-button or remote programming of light/dark operate and output timing; continuous status indicators verify all settings at a glance Output ON and/or OFF delays adjustable from 8 milliseconds to 16 seconds Powerful, highly collimated visible red sensing beam Tough ABS/polycarbonate blend housing is rated IP67; NEMA 6 10 V DC to 30 V DC Models (Q60BB6AFV): • Powered by 10 V DC to 30 V DC; bipolar (one NPN and one PNP) outputs • Available with integral cable or rotating Euro-style quick-disconnect fitting Universal Voltage Models (Q60VR3AFV): • 12 V DC to 250 V DC or 24 V AC to 250 V AC, 50/60 Hz • Available with integral cable or rotating 1/2 in-20UNF quick-disconnect fitting WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Models Minimum Range Cutoff Point Cable 1 Q60BB6AFV1000 5-wire 2 m (6.5 ft) Q60BB6AFV1000Q 5-pin M12 QD Q60VR3AFV1000 Q60VR3AFV1000Q1 65 mm to 130 mm (2.5 in to 5 in) depending on cutoff point setting Adjustable: 200 mm to 1000 mm (8 in 5-wire 2 m (6.5 ft) to 40 in) 4-pin 1/2 in-20UNF QD Supply Voltage Output Type 10 V DC to 30 V DC Bipolar NPN/PNP Universal Voltage 12 V DC to 250 V DC or 24 V AC to 250 V AC E/M Relay (SPDT), normally closed and normally open contacts E/M Relay (SPST), normally open contact Overview The Q60AFV sensor is a full-featured adjustable-field sensor. These adjustable-field sensors are able to detect objects of relatively low reflectivity, while ignoring other objects in the background (beyond the cutoff point). The cutoff distance is mechanically adjustable, using the 2-turn adjustment screw on the top of the sensor. A rotating pointer indicates the relative cutoff position. The indicator moves clockwise to show increasing distance. Two push buttons (ON Delay and OFF Delay) are used to set the output delay options, to toggle between light and dark operate modes and to lock out the push buttons for security purposes. These functions also may be accomplished using the remote wire (available on some models). Seven LED indicators show, during RUN mode, the sensor configuration and operating status. During Delay Configuration, 5 of the LEDs combine to form a single light bar that indicates relative ON or OFF delay time. Note: When an object approaches from the side, the most reliable sensing usually occurs when the line of approach is parallel to the sensing axis. 1 To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, Q60BB6AFV1000 W/30. Models with a quick disconnect require a mating cordset. Original Document 69622 Rev. D 18 October 2021 69622 Q60AFV Series Sensors with Visible Red Emitter Features and Indicators Note: Outputs are active during on/off timing selection mode. ON Delay Steady Green: Run mode, ON delay is active Flashing Green: ON Delay Selection mode is active OFF Delay Steady Green: Run mode, OFF delay is active Flashing Green: OFF Delay Selection mode is active ON/OFF Delay Push Buttons and Indicators Cutoff Adjustment Screw 5-Segment Light Bar 2 Indicates relative delay time during ON or OFF Delay Selection modes Output Indicator Steady Amber: Outputs are conducting Steady Green: During ON/OFF Delay Selection modes Dark Operate Indicator Steady Green: Dark Operate is selected Lockout Indicator Steady Green: Buttons are locked out Light Operate Indicator Steady Green: Light Operate is selected Signal Indicator Steady Green: Sensor is receiving signal Flashing Green: Marginal signal (1.0 to 2.25 excess gain) Light Sensed Indicator Light Operate Selected Push Button Lockout Indicator Dark Operate Selected Output Conducting (Bi-color Amber/Green) The indicators also function as a 5-segment light bar during delay selection modes Adjustable-Field Sensing—Theory of Operation The Q60AFV compares the reflections of its emitted light beam (E) from an object back to the sensor’s two differently-aimed detectors R1 and R2 (see Figure 1 on p. 2). If the near detector (R1) light signal is stronger than the far detector (R2) light signal (see object A, closer than the cutoff distance), the sensor responds to the object. If the far detector (R2) light signal is stronger than the near detector (R1) light signal (see object B, object beyond the cutoff distance), the sensor ignores the object. The cutoff distance for these sensors is adjustable. Objects lying beyond the cutoff distance are ignored, even if they are highly reflective. However, it is possible to falsely detect a background object, under certain conditions (see Background Reflectivity and Placement on p. 4). Figure 1. Adjustable field sensing concept Cutoff Distance Receiver Elements Object A Near Detector R1 Figure 2. Sensing Axis Object B or Background Lenses Receiver Elements Far Detector R2 Emitter E Sensing Range Sensing Axis In the drawings and information provided in this document, the letters E, R1, and R2 identify how the sensor’s three optical elements (Emitter “E”, Near Detector “R1”, and Far Detector “R2”) line up across the face of the sensor. The location of these elements defines the sensing axis (see Figure 2 on p. 2). The sensing axis becomes important in certain situations, such as in the Object Beyond Cutoff illustrations in Background Reflectivity and Placement on p. 4. 2 2 Output, Dark Operate, Lockout, Light Operate and Signal indicators function as 5-Segment Light Bar during ON or OFF Delay Selection modes www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69622 Rev. D Q60AFV Series Sensors with Visible Red Emitter Installation Wiring Diagrams Q60BB6xx(Q) Cabled and QD Models, 10 V DC to 30 V DC 1 4 1 + 10-30V dc – 3 2 Q60VR3xx Cabled Model, 24 V AC to 250 V AC (50/60Hz) or 12 V DC to 250 V DC 3 2 N.C. 5 Load C 4 Load 5 24 - 250V ac or 12 - 250V dc N.O. Key 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray Remote Program Q60VR3xxQ1 QD Model, 24 V AC to 250 V AC (50/60Hz) or 12 V DC to 250 V DC 1 24-250V ac or 12-250V dc* 2 3 N.O. 4 C Key 1 = Red/Black 2 = Red/White 3 = Red 4 = Green 3 A max. load *NOTE: Connection of dc power is without regard to polarity. Set the Cutoff Distance The cutoff distance for Q60AFV sensors can be adjusted between 200 mm to 1000 millimeters (8 in to 40 in). To maximize contrast, position the lightest possible background to be used, at the closest position it will come to the sensor during use. Using a small screwdriver in the adjustment screw, adjust the cutoff distance until the threshold is reached and the green Light Sensed indicator changes state. If the indicator never turns ON, the background is beyond the maximum sensing cutoff and will be ignored. Note the position of the rotating cutoff position indicator at this position. Then repeat the procedure, using the darkest target, placed in its most distant position for sensing. Adjust the cutoff so that the indicator is midway between the two positions. Figure 3. Set the cutoff distance approximately midway between the farthest target and the closest background Target Background Increas ing Dis Figure 4. Setting the cutoff distance ce tan RANGE R1 R2 ON DELAY E Farthest Target Object Set Cutoff Midway Between Closest Background DO LO SIG OFF DELAY Cutoff Distance Note: Setting the cutoff distance adjustment screw to its maximum clockwise position places the receiver lens directly in front of the receiver elements and results in the Q60 performing as a long-range diffuse sensor. P/N 69622 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 3 Q60AFV Series Sensors with Visible Red Emitter Sensing Reliability For highest sensitivity, the sensor-to-object distance should be such that the object will be sensed at or near the point of maximum excess gain. The excess gain curves show excess gain versus sensing distance for 200 mm and 1 m cutoffs. Maximum excess gain for a 200 mm cutoff occurs at a lens-to-object distance of about 150 mm, and for a 1 m cutoff, at about 400 mm. The background must be placed beyond the cutoff distance. Following these two guidelines makes it possible to detect objects of low reflectivity, even against close-in reflective backgrounds. Background Reflectivity and Placement Avoid mirror-like backgrounds that produce specular reflections. A false sensor response occurs if a background surface reflects the sensor's light more to the near detector (R1) than to the far detector (R2). The result is a false ON condition (Figure 5 on p. 4). Correct this problem by using a diffusely reflective (matte) background, or angling either the sensor or the background (in any plane) so the background does not reflect light back to the sensor (Figure 6 on p. 4). Position the background as far beyond the cutoff distance as possible. An object beyond the cutoff distance, either stationary (and when positioned as shown in Figure 7 on p. 4), or moving past the face of the sensor in a direction perpendicular to the sensing axis, may cause unwanted triggering of the sensor if more light is reflected to the near detector than to the far detector. Correct the problem by rotating the sensor 90° (Figure 8 on p. 4). The object then reflects the R1 and R2 fields equally, resulting in no false triggering. A better solution, if possible, may be to reposition the object or the sensor. Figure 5. Reflective Background - Problem Sensing Field Sensing Field Cutoff Distance Core of Emitted Beam Cutoff Distance Reflective Background Strong Direct Reflection to R1 R1 R2 E Figure 6. Reflective Background - Solution R1 R2 E Reflective Background E = Emitter R1 = Near Detector R2 = Far Detector Core of Emitted Beam E = Emitter R1 = Near Detector R2 = Far Detector Figure 7. Object Beyond Cutoff - Problem Figure 8. Object Beyond Cutoff - Solution ON RANGE E, R1, R2 DELAY DELAY OFF R1 R2 DO LO SIG Cutoff Distance Strong Direct Reflection Away From Sensor E Sensing Field Sensing Field A reflective background object in this position or moving across the sensor face in this axis and direction may cause a false sensor response. A reflective background object in this position or moving across the sensor face in this axis is ignored. Color Sensitivity The effects of object reflectivity on cutoff distance, though small, may be important for some applications. It is expected that at any given cutoff setting, the actual cutoff distance for lower reflectance targets is slightly shorter than for higher reflectance targets. This behavior is known as color sensitivity. These excess gain curves were generated using a white test card of 90% reflectance. Objects with reflectivity of less than 90% reflect less light back to the sensor, and thus require proportionately more excess gain in order to be sensed with the same reliability as more reflective objects. When sensing an object of very low reflectivity, it may be especially important to sense it at or near the distance of maximum excess gain. 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69622 Rev. D Q60AFV Series Sensors with Visible Red Emitter The percentage of deviation indicates a change in the cutoff point for either 18% gray or 6% black targets, relative to the cutoff point set for a 90% reflective white test card. For example, the cutoff point decreases 4% for a 6% reflectance black target when the cutoff point is adjusted for 1000 mm (40 in) using a 90% reflectance white test card. In other words, the cutoff point for the black target is 960 mm (38 in) for this setting. Figure 10. Q60 Minium Range Versus Cutoff Setting Minimum Range with a 6% Black Card (mm) Figure 9. Cutoff Point Deviation 0 Percent Deviation -1 -2 -3 18% Gray Card 6% Black Card -4 -5 200 300 400 500 600 700 800 900 1000 150 140 130 120 110 100 90 80 70 60 50 200 400 600 800 1000 Cutoff Distance (mm) with 90% White Card Cutoff Setting (90% White Card) Hysteresis (% of Cutoff) with 6% Black Card Figure 11. Hysteresis 2.0 1.5 1.0 0.5 0 200 400 600 800 1000 Cutoff Setting (mm) with 90% White Card Configuring a Sensor Set the Output Delay DO DO DO 16 seconds DO 72 DO 4.0 seconds DO 56 LO 1.00 second SIG 40 LO 0.250 second SIG 24 LO 0.062 second SIG 8 LO No Delay SIG 0 LED Status LO Delay Time SIG Step # LO Note: Remote wire available on models Q60BB6AFV(Q) only. Major increments, displayed by a single full-intensity LED, are shown: SIG The output of the Q60AFV sensor may be delayed between 0.008 and 16 seconds, in any of 72 increments. Delay is indicated on the 5segment light bar using single LED segments or combinations of them, in varying stages of intensity. To set a delay, single-click the appropriate button or pulse the remote wire to enable the process (as described in the following procedures). Then use the + or – button or the appropriate remote wire pulse procedure to increase or decrease the delay (single-click adjusts the delay by one step at a time, and holding the button in provides a rapid increase/decrease). Increase or Decrease the ON Delay T = 40 – 800 ms Press and Hold > 800 ms unless otherwise noted P/N 69622 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 5 Q60AFV Series Sensors with Visible Red Emitter Increase the ON Delay—4-second time-out Enter ON Delay Setup Enable Delay Increment Single-Click Push Button Press and Hold ON DELAY + T >800 ms – DELAY OFF ON DELAY + T >800 ms – DELAY OFF + ON T >800 ms Rapid Increment Single-Click N/A DELAY – OFF DELAY Remote Input Step Increment >800 ms Decrease the ON Delay—4-second time-out Enter ON Delay Setup Enable Delay Decrement Single-Click ON + DELAY T >800 ms T T T >800 ms – DELAY ON DELAY + T >800 ms – OFF DELAY + ON DELAY – OFF DELAY Remote Input Press and Hold Single-Click N/A Rapid Decrement OFF Push Button Step Decrement >800 ms Increase or Decrease the OFF Delay T = 40 – 800 ms Press and Hold > 800 ms unless otherwise noted Increase the OFF Delay—4-second time-out Enter OFF Delay Setup Enable Delay Increment Single-Click Push Button Press and Hold ON DELAY – T >800 ms + DELAY OFF ON DELAY – + DELAY OFF ON – + T >800 ms T T T >800 ms Rapid Increment Single-Click N/A DELAY DELAY OFF Remote Input Step Increment >800 ms Decrease the OFF Delay—4-second time-out Enter OFF Delay Setup Enable Delay Decrement Single-Click ON – + DELAY T >800 ms DELAY ON DELAY – T T T >800 ms + DELAY T T T >800 ms Press and Hold Single-Click OFF ON – + DELAY DELAY OFF Remote Input N/A Rapid Decrement OFF Push Button Step Decrement >800 ms Select Light Operate or Dark Operate Select Light Operate or Dark Operate mode using the two push buttons or a 4-second pulse of the remote line to toggle between the selections. LO/DO Toggle Four-Second Press and Hold ON DELAY – + 6 OFF Remote Input DELAY Push Button >4 sec. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69622 Rev. D Q60AFV Series Sensors with Visible Red Emitter Lock the Push Buttons For security, the push buttons can be locked out using either the remote line or the push buttons themselves. Push Button Lockout Toggle Concurrent Quad-Click ON DELAY – + DELAY Remote Input OFF Push Button T T T T T T T >800 ms Specifications Supply Voltage and Current Q60BB6AFV models: 10 V DC to 30 V DC (10% maximum ripple) at less than 50 mA exclusive of load Q60VR3AFV Universal models: 12 V DC to 250 V DC or 24 V AC to 250 V AC, 50/60 Hz Supply Protection Circuitry Protected against reverse polarity and transient voltages The dc wiring for model Q60VR3 is without regard to polarity Output Configuration Q60BB6AFV models: Bipolar; one NPN (current sinking) and one PNP (current sourcing) open-collector transistor Q60VR3AFV cabled model: E/M Relay (SPDT), normally closed and normally open contacts Q60VR3AFVQ1 (QD) model: E/M Relay (SPST), normally open contact Output Rating—Q60BB6AFV models 150 mA maximum each output @ 25 °C Off-state leakage current: < 5 μA @ 30 V DC Output saturation NPN: < 200 mV @ 10 mA and < 1 V @150 mA Output saturation PNP: < 1 V at 10 mA; < 1.5 V at 150 mA Output Rating—Q60VR3AFV Universal models Minimum voltage and current: 5 V DC, 10 mA Mechanical life of relay: 50,000,000 operations Electrical life of relay at full resistive load: 100,000 operations Maximum switching power (resistive load): Cabled models: 1250 VA, 150 W QD models: 750 VA, 90 W Maximum switching voltage (resistive load): Cabled models: 250 V AC, 125 V DC QD models: 250 V AC, 125 V DC Maximum switching current (resistive load): Cabled models: 5 A @ 250 V AC, 5 A @ 30 V DC derated to 200 mA @ 125 V DC QD models: 3 A @ 250 V AC, 3 A @ 30 V DC derated to 200 mA @ 125 V DC Output Protection Circuitry Q60BB6AFV models: Protected against continuous overload or short circuit of outputs All models: Protected against false pulse on power-up Adjustments Slotted, geared, 2-turn, cutoff range adjustment screw (mechanical stops on both ends of travel) 2 momentary push buttons: ON Delay (+) and OFF Delay (–); DC models also have a remote program wire ON Delay select: 8 ms to 16 seconds OFF Delay select: 8 ms to 16 seconds LO/DO select Push button lockout for security Construction Housing: ABS polycarbonate blend Lens: Acrylic Cover: Clear ABS Environmental Rating IP67; NEMA 6 Connections 2 m (6.5 ft) or 9 m (30 ft) attached cable, 5-pin M12 fitting, or 5-pin 7/8 in-16UNF 150 mm (6 in) QD, depending on model. QD cables are ordered separately Operating Conditions Temperature: –20 °C to +55 °C (–4 °F to +131°F) 90% at +50 °C maximum relative humidity (non-condensing) Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Output Response Time Q60BB6AFV models: 2 milliseconds ON and OFF Note: 150 millisecond delay on power-up; outputs do not conduct during this time. Q60VR3AFV Universal models: 15 milliseconds ON and OFF Note: 150 millisecond delay on power-up; relay is de-energized during this time. Certifications Repeatability 500 microseconds Sensing Hysteresis See Color Sensitivity on p. 4 P/N 69622 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 7 Q60AFV Series Sensors with Visible Red Emitter Dimensions 15.2 mm (0.60") 4.0 mm (0.16") 4.9 mm (0.19") – DELAY OFF LO SIG + ON DO RANGE 25.0 mm (0.98") DELAY 60.0 mm (2.36") 52.0 mm (2.05") 4.0 mm (0.16") 2x ø4.2 mm (0.17") 14.0 mm (0.55") Q60BB6AFV200 75.0 mm (2.95") 52.0 mm (2.05") bn 67.0 mm (2.64") wh bk Q60BB6AFV200Q bn + 10-30V dc – bu + 10-30V dc – bu wh Load bk Load gy gy Remote Teach Load Load Remote Teach M3 hardware is included 17.0 mm (0.67") 77.6 mm (3.06") Performance Curves Excess Gain at 200 mm Cutoff Excess Gain at 1000 mm cutoff 10000 10000 1000 1000 E X C E S S G A I N Q60AFV E X C E S S 100 G A I N 10 1 1 mm 0.04 in 10 mm 0.4 in 100 mm 4 in 1000 40 in Q60AFV 100 10 1 1 mm 0.04 in 100 mm 4 in 1000 mm 40 in DISTANCE DISTANCE 8 10 mm 0.4 in www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69622 Rev. D Q60AFV Series Sensors with Visible Red Emitter Accessories Cordsets 4-Pin 1/2-in Dual Key Cordsets—Single Ended Model Length MQAC-406 2 m (6.56 ft) MQAC-415 5 m (16.4 ft) MQAC-430 9.14 m (30 ft) Style Dimensions Pinout (Female) 42 Typ. Straight MQAC-406RA 1.83 m (6 ft) MQAC-415RA 5 m (16.4 ft) 1/2-20 UNF-2B ø 14.5 4 1 2 32 Typ 1 = Red/Black 2 = Red/White 3 = Red 4 = Green 28 Typ Right-Angle MQAC-430RA 3 9.14 m (30 ft) 1/2-20 UNF-2B ø 14.5 5-Pin Threaded M12 Cordsets—Single Ended Model Length MQDC1-501.5 Style Dimensions 0.5 m (1.5 ft) MQDC1-506 2 m (6.5 ft) MQDC1-515 5 m (16.4 ft) MQDC1-530 9 m (29.5 ft) MQDC1-506RA 2 m (6.5 ft) MQDC1-515RA 5 m (16.4 ft) 44 Typ. Straight M12 x 1 ø 14.5 30 Typ. [1.18"] 9 m (29.5 ft) 1 4 32 Typ. [1.26"] Right-Angle MQDC1-530RA Pinout (Female) 2 3 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray M12 x 1 ø 14.5 [0.57"] Brackets 60 82 SMBQ60 • • ø3.8 Right-angle bracket 14-gauge 304 stainless steel ø4.5 22 P/N 69622 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 9 Q60AFV Series Sensors with Visible Red Emitter Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
Q60BB6AFV1000Q 价格&库存
很抱歉,暂时无法提供与“Q60BB6AFV1000Q”相匹配的价格&库存,您可以联系我们找货
Q60BB6AFV1000Q
    • 1+2123.77710
    库存:1
    Q60BB6AFV1000Q
    • 1+2668.129981+345.22433
    库存:11
