SM91R
SM91R
    BANNER(邦纳)
    VALU-BEAM: RECEIVERRANGE: 60
SM91R 数据手册
VALU-BEAM® 912 Series AC- and DC-powered sensors with solid-state outputs For the latest technical information about this product, including specifications, dimensions, and wiring, see www.BannerEngineering.com Features • Choose models for 10 to 30V dc or 24 to 250V ac operation • DC models have bipolar solid-state outputs: one NPN (sinking) and one PNP (sourcing) • AC models have an SPST solid-state output rated for up to 3/4 amp with simple 2wire hookup • All models have a rear panel sensitivity adjustment and light/dark operate switch • DC models include Banner’s Alignment Indicating Device (AID™) system • Choose models with integral 2 m (6.5') cable or Mini-style QD (quick-disconnect) connector; 9 m (30') cables are also available Opposed Mode Emitter (E) and Receiver (R) Models OPPOSED Infrared, 880 nm Models Range SMA91E 2 m (6.5') SMA91EQD SM91R SM91RQD Cable* 3-pin Mini QD 60 m (200') SM2A91R 2 m (6.5') 4-pin Mini QD 2 m (6.5') SM2A91RQD 3-pin Mini QD SMA91ESR 2 m (6.5') SMA91ESRQD SM91RSR SM91RSRQD SM2A91RSR SM2A91RSRQD 3-pin Mini QD 3 m (10') 2 m (6.5') 4-pin Mini QD 2 m (6.5') 3-pin Mini QD Supply Voltage Output Type 10-250V ac/dc - 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-wire 10-250V ac/dc - 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-wire * 9 m cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., SMA91E W/30). A model with a QD connector requires a mating cable; see Quick-Disconnect Cables on page 10. WARNING: Not To Be Used for Personnel Protection Never use this product as a sensing device for personnel protection. Doing so could lead to serious injury or death. This product does NOT include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. P/N 03467_web Rev. F 4/11/2012 VALU-BEAM® 912 Series Retroreflective Mode Models P Visible Red, 650 nm Non-Polarized RETRO Range† Models POLAR RETRO Polarized Cable* Supply Voltage 2 m (6.5') 10-30V dc Output Type Non-Polarized SM912LV SM912LVQD SM2A912LV 0.15 to 9 m (6" to 30') SM2A912LVQD 4-Pin Mini QD 2 m (6.5') 24-250V ac 3-Pin Mini QD Bipolar NPN/PNP SPST SCR Solid-state 2-Wire Polarized†† SM912LVAG SM912LVAGQD SM2A912LVAG 2 m (6.5') 0.3 to 4.5 m (1' to 15') SM2A912LVAGQD 4-Pin Mini QD 2 m (6.5') 3-Pin Mini QD 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire † Retroreflective range is specified using one model BRT-3 retroreflector (3" diameter). Actual sensing range may be more or less than specified, depending upon the efficiency and reflective area of the retroreflector used. †† Use polarized models when shiny objects will be sensed. Diffuse Mode Models DIFFUSE Infrared, 880 nm Models Range† SM912D SM912DQD SM2A912D 2 m (6.5') 760 mm (30") SM2A912DQD SM2A912DSR SM2A912DSRQD 2 4-Pin Mini QD 2 m (6.5') 3-Pin Mini QD SM912DSR SM912DSRQD Cable* 2 m (6.5') 380 mm (15") 4-Pin Mini QD 2 m (6.5') 3-Pin Mini QD Supply Voltage Output Type 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire www.bannerengineering.com - tel: 763-544-3164 P/N 03467_web Rev. F VALU-BEAM® 912 Series Convergent Mode Models CONVERGENT VISIBLE RED CONVERGENT Visible Red or Infrared; see below Models Range Cable* Supply Voltage Output Type 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire Visible Red 650 nm SM912CV SM912CVQD SM2A912CV 2 m (6.5') 38 mm (1.5") Spot Size at Focus: 1.5 mm (0.06") SM2A912CVQD 4-Pin Mini QD 2 m (6.5') 3-Pin Mini QD Infrared 880 nm SM912C SM912CQD SM2A912C 2 m (6.5') 38 mm (1.5") SM2A912CQD 4-Pin Mini QD 2 m (6.5') 3-Pin Mini QD Glass Fiber Optic Individual Emitter or Receiver Models GLASS FIBER TWO SENSORS Infrared, 880 nm Use where the separation between emitting and receiving fibers is more than a few feet, or where it is inconvenient to run both fibers from a single sensor. Watertight o-ring-sealed sensor/fiber interface. Models Range SMA91EF 2 m (6.5') SMA91EFQD SM91RF SM91RFQD SM2A91RF SM2A91RFQD Cable* 3-Pin Mini QD Range varies with fiber used 2 m (6.5') 4-Pin Mini QD 2 m (6.5') 3-Pin Mini QD Supply Voltage Output Type 10-250V ac/dc – 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire * 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., SMA91EF W/30). A model with a QD connector requires a mating cable; see Quick-Disconnect Cables on page 10. P/N 03467_web Rev. F www.bannerengineering.com - tel: 763-544-3164 3 VALU-BEAM® 912 Series Glass Fiber Optic Models Infrared 880 nm Watertight o-ring-sealed sensor/fiber interface. GLASS FIBER Models Range Cable* SM912F 2 m (6.5') Range varies with sensing mode and fiber optics used SM912FQD SM2A912F 4-Pin Mini QD 2 m (6.5') SM2A912FQD 3-Pin Mini QD Supply Voltage Output Type 10-30V dc Bipolar NPN/PNP 24-250V ac SPST SCR Solid-state 2-Wire * 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., SM912F W/30). A model with a QD connector requires a mating cable; see Quick-Disconnect Cables on page 10. Dimensions Cabled Models QD Models Rear View LED Indicator 36.6 mm (1.44") Light/Dark Operate Select (L.O. = CW, D.O. = CCW) 35.6 mm (1.40") Sensitivity Control (Turn CW to Increase) Lens Centerline 50.8 mm (2.00") NOTE: Control potentiometers are behind cover screws; remove screws to access controls 17.8 mm (0.70") 39.1 mm (1.54") 4.5 mm (#10) Screw Clearance (2) 12.7 mm (0.50") M30 x 1.5 External Thread 1/2" - 14 NPSM Internal Thread Hex Nut Supplied 5.6 mm (0.22") M30 x 1.5 Thread Hex Nut Supplied 26.7 mm (1.05") 25.4 mm (1.00") Mini-style Quick-disconnect Convergent Sensing Mode (model suffix LVAG, C and CV) Glass Fiber Optic (model suffix F, EF and RF) 39.6 mm (1.56") 42.2 mm (1.66") Fiber Port Centerline 4 www.bannerengineering.com - tel: 763-544-3164 P/N 03467_web Rev. F VALU-BEAM® 912 Series Specifications - DC Models Supply Voltage and Current 10 to 30V dc at 20 mA maximum, exclusive of load; except for SMA91E, ESR and EF emitters, which operate from 10 to 250V ac or dc Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: One current sourcing (PNP) and one current sinking (NPN) open-collector transistor Output Rating 250 mA continuous, each output Off-state leakage current: less than 10 microamps Output saturation voltage: (PNP output) less than 1 volt at 10 mA and less than 2 volts at 250 mA Output saturation voltage: (NPN output) less than 200 millivolts at 10 mA and less than 1 volt at 250 mA Output Response Time Receivers only: 8 milliseconds ON and 4 milliseconds OFF, independent of signal strength. All other models: 4 milliseconds ON/OFF NOTE: millisecond delay on power-up; outputs do not conduct during this delay. Repeatability Opposed and Glass Fiber Optic Emitter-Receiver pairs: 1.0 millisecond Retro, Diffuse, Convergent and Glass Fiber Optic Models: 1.3 milliseconds Adjustments Light/Dark Operate select switch and Sensitivity control potentiometer, both located at rear of sensor Indicators Alignment Indicating Device (AID™) lights a top-mounted red LED indicator whenever the sensor sees a “light” condition; its pulse rate is proportional to the light signal strength (the stronger the signal, the faster the pulse rate). Model SMA91E and SM91ESR emitters: visible-red “tracer beam” indicates “Power ON” and enables lineof-sight alignment. Construction Reinforced thermoplastic polyester housing, totally encapsulated, molded acrylic lenses and stainless steel hardware Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 12 and 13 IEC IP66 Connections PVC-jacketed 2 m (6.5') or 9 m (30') cables or 4-pin Mini-style quick-disconnect (QD) fitting available. NOTE: Opposed-mode emitters use 3-pin Mini-style QD fitting. See Quick-Disconnect Cables on page 10. Operating Conditions Temperature: -20° to +70° C (-4° to +158° F) Maximum relative humidity: 90% at 50° C (non-condensing) Certifications DC Hookups Emitters - Cabled bn bu P/N 03467_web Rev. F Emitters - QD (3-Pin Mini-Style) bn + 10-250V ac/dc – bu 3-Pin Mini-Style Pinout (Cable Connector Shown) 1 + 10-250V ac/dc – bk www.bannerengineering.com - tel: 763-544-3164 3 2 1 = Black 2 = Brown 3 = Blue 5 VALU-BEAM® 912 Series Other DC Models - Cabled bn bk bn + 10-30V dc – bu wh Other DC Models - QD (4-Pin MiniStyle) + 10-30V dc – bu wh Load bk Load Load Load 4-Pin Mini-Style Pinout (Cable Connector Shown) 2 4 1 3 1 = Brown 2 = White 3 = Blue 4 = Black Specifications - AC Models Supply Voltage and Current 24 to 250V ac (50/60 Hz); except for SMA91E, ESR and EF emitters, which operate from 10 to 250V ac or dc Supply Protection Circuitry Protected against transient voltages Output Configuration SPST SCR solid-state relay with either normally closed or normally open contact (light/dark operate selectable); 2-wire hookup Output Rating Minimum load current 10 mA, max. steady-state load capability 750 mA to 50° C ambient (122° F), 500 mA to 70° C ambient (158° F) Inrush capability: 4 amps for 1 second (non-repetitive) Off-state leakage: current less than 1.7 mA rms On-state voltage drop: ≤ 5 volts rms at 750 mA load, ≤ 10 volts rms at 15 mA load Output Protection Circuitry Protected against false pulse on power-up Output Response Time Receivers only: 8 milliseconds ON and 4 milliseconds OFF, independent of signal strength. All other models: 4 milliseconds ON/OFF OFF time does not include load response of up to 1/2 ac cycle (8.3 milliseconds). Response time specification of the load should be considered when total response time is important. NOTE: millisecond delay on power-up; outputs do not conduct during this delay. Repeatability Opposed and Glass Fiber Optic Emitter-Receiver pairs: 1.0 millisecond Retro, Diffuse, Convergent and Glass Fiber Optic Models: 2.6 milliseconds 6 Adjustments Light/Dark Operate select switch and Sensitivity control potentiometer, both located at rear of sensor Indicators Top-mounted red LED indicator lights when output is conducting. Model SMA91E and SM91ESR emitters: visible-red “tracer beam” indicates “Power ON” and enables lineof-sight alignment. Construction Reinforced thermoplastic polyester housing, totally encapsulated, molded acrylic lenses and stainless steel hardware Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 12 and 13 IEC IP66 Connections PVC-jacketed 2 m (6.5') or 9 m (30') cables or 3-pin Mini-style (QD) fitting available. See Quick-Disconnect Cables on page 10. Operating Conditions Temperature: -20° to +70° C (-4° to +158° F) Maximum relative humidity: 90% at 50° C (non-condensing) Application Notes 1.) 912 Series ac sensors can be destroyed from overload conditions. 2.) Use on low voltage requires careful analysis of the load to determine if the leakage current or on-state voltage of the sensor will interfere with proper operation of the load. 3.) The false-pulse protection feature may cause momentary drop-out of the load when the sensor is wired in series or parallel with mechanical switch contacts. Certifications www.bannerengineering.com - tel: 763-544-3164 P/N 03467_web Rev. F VALU-BEAM® 912 Series AC Hookups Emitters - Cabled Emitters - QD (3-Pin Mini-Style) bn bn + + 10-250V ac/dc – bu 10-250V ac/dc – bu 3-Pin Mini-Style Pinout (Cable Connector Shown) bk 1 2 3 Other AC Models - Cabled Other AC Models - QD (3-Pin Mini-Style) bn bn bu bu 24-250V ac Load 1 = Black 2 = Brown 3 = Blue + 24-250V ac – bk Load Excess Gain Mode 1000 EXCESS GAIN Opposed Mode Emitter and Receiver Models EXCESS GAIN 1000 100 10 SMA91E / SM91R, SMA91E / SM2A91R Opposed Mode 100 10 SMA91ESR / SM91RSR, SMA91ESR / SM2A91RSR 1 0.1 m 0.33' 1.0 m 3.3' 10 m 33' 1 0.01 m 0.033' 100 m 330' DISTANCE Opposed Mode 0.10 m 0.33' 1000 SM912LV, SM2A912LV SM912LVAG, SM2A912LVAG Retroreflective Mode EXCESS GAIN EXCESS GAIN Retroreflective Mode 100 With BRT-3 Reflector 10 1 0.01 m 0.033' 0.10 m 0.33' 1.0 m 3.3' 10 m 33' DISTANCE P/N 03467_web Rev. F 10 m 33' DISTANCE 1000 Retroreflective Mode Models 1.0 m 3.3' www.bannerengineering.com - tel: 763-544-3164 100 With BRT-3 Reflector 10 1 0.01 m 0.033' 0.10 m 0.33' 1.0 m 3.3' 10 m 33' DISTANCE 7 VALU-BEAM® 912 Series Mode 1000 1000 SM912D, SM2A912D SM912DSR, SM2A912DSR Diffuse Mode EXCESS GAIN Diffuse Mode Models EXCESS GAIN Diffuse Mode 100 10 1 1 mm 0.04" 10 mm 0.4" 100 mm 4" 100 10 1 1 mm 0.04" 1000 mm 40" 10 mm 0.4" DISTANCE 1000 mm 40" DISTANCE Visible Red 650 nm 1000 100 mm 4" Infrared 880 nm 1000 SM912CV, SM2A912CV SM912C, SM2A912C EXCESS GAIN Convergent Mode Models EXCESS GAIN Convergent Mode Convergent Mode 100 10 1 1 mm 0.04" 10 mm 0.4" 100 mm 4" 100 10 1 1 mm 0.04" 1000 mm 40" 10 mm 0.4" DISTANCE 100 mm 4" 1000 mm 40" DISTANCE 1000 Glass Fiber Optic Individual Emitter or Receiver Models EXCESS GAIN SMA91EF & SM91RF, SMA91EF & SM2A91RF Opposed Mode 100 IT23S Fibers W/L16F Lenses 10 1 0.1 m 0.33' IT23S Fibers W/L9 Lenses 1.0 m 3.3' 10 m 33' 100 m 330' DISTANCE 1000 1000 SM912F SM2A912F SM912F SM2A912F 100 10 Diffuse Mode IT23S Fibers IT13S Fibers EXCESS GAIN Glass Fiber Optic Models EXCESS GAIN Opposed Mode 100 BT23S Fiber 10 BT13S Fiber 1 1 mm 0.04" 10 mm 0.4" 100 mm 4" 1000 mm 40" DISTANCE 8 www.bannerengineering.com - tel: 763-544-3164 1 1 mm 0.04" 10 mm 0.4" 100 mm 4" 1000 mm 40" DISTANCE P/N 03467_web Rev. F VALU-BEAM® 912 Series Beam Patterns Mode SMA91E / SM91R, SMA91E / SM2A91R 60" 300 mm 1000 mm Opposed Mode 40" 200 mm 20" 100 mm 4" 0 0 500 mm Opposed Mode Emitter and Receiver Models SMA91ESR / SM91RSR, SMA91ESR / SM2A91RSR 1500 mm 0 0 20" 100 mm 4" 1000 mm 40" 200 mm 8" 1500 mm 60" 300 mm 15 m 50' 30 m 100' 45 m 150' 60 m 200' 12" 0 75 m 250' .6 m 2' 1.2 m 4' Non-Polarized SM912LVAG, SM2A912LVAG 6.0" 75 mm 4.0" 50 mm 2.0" 50 mm 2.0" 25 mm 1.0" Retroreflective Mode 0 0 50 mm With BRT-3 Reflector 150 mm 0 2m 6.6' 4m 13' 6m 20' 8m 26' 3.0" Retroreflective Mode 0 2.0" 25 mm 4.0" 50 mm 6.0" 75 mm 10 m 33' 0 1.0" With BRT-3 Reflector 2.0" 3.0" 0 1m 3.3' DISTANCE 2m 6.6' 3m 10' 4m 13' 5m 16' DISTANCE SM912D, SM2A912D SM912DSR, SM2A912DSR 0.75" 18 mm 12 mm 0.50" 12 mm 0.50" 6 mm 0.25" 6 mm 0.25" 18 mm Diffuse Mode 0 0 0.75" Diffuse Mode 0 0 6 mm 0.25" 6 mm 0.25" 12 mm 0.50" 12 mm 0.50" 18 mm 0.75" 18 mm 0 150 mm 6" 300 mm 12" 450 mm 18" 0.75" 0 600 mm 750 mm 24" 30" 75 mm 3" Visible Red 650 nm SM912CV, SM2A912CV 2.4 mm Convergent Mode 1.6 mm 150 mm 6" 225 mm 9" 300 mm 375 mm 12" 15" DISTANCE DISTANCE 0.8 mm Infrared 880 nm 0.09" 2.4 mm 0.06" 1.6 mm 0.03" 0.8 mm 0 0 SM912C, SM2A912C 0.09" Convergent Mode 0.06" 0.03" 0 0 0.8 mm 0.03" 0.8 mm 0.03" 1.6 mm 0.06" 1.6 mm 0.06" 2.4 mm 0.09" 2.4 mm 0.09" 0 12.5 mm 0.5" 25 mm 1.0" 37.5 mm 1.5" 50 mm 2.0" 62.5 mm 2.5" SMA91EF & SM91RF, SMA91EF & SM2A91RF 300 mm 0 15 mm 0.6" 30 mm 1.2" 45 mm 1.8" 60 mm 2.4" 75 mm 3.0" DISTANCE DISTANCE 12" Opposed Mode 200 mm 8" 100 mm Glass Fiber Optic Individual Emitter or Receiver Models 3.0 m 10' 100 mm 100 mm Convergent Mode Models 2.4 m 8' Polarized SM912LV, SM2A912LV 150 mm 1.8 m 6' DISTANCE DISTANCE Diffuse Mode Models 8" 500 mm 0 Retroreflective Mode Models 12" Opposed Mode 4" IT23S Fibers With L9 lenses 0 100 mm 0 IT23S Fibers With L16F lenses 200 mm 300 mm 4" 8" 12" 0 2.4 m 8' 4.8 m 16' 7.2 m 24' 9.6 m 32' 12 m 40' DISTANCE P/N 03467_web Rev. F www.bannerengineering.com - tel: 763-544-3164 9 VALU-BEAM® 912 Series Mode SM912F/SM2A912F 3" 1.9 mm 50 mm 2" 1.3 mm 25 mm 1" 0.7 mm 0 0 25 mm 1" 0.7 mm 0.03" 50 mm 2" 1.3 mm 0.05" 75 mm 3" 1.9 mm 75 mm Opposed Mode 0 Glass Fiber Optic Models IT13S 0 IT23S 100 mm 4" 200 mm 8" 300 mm 12" 0.05" 0.03" BT13S BT23S 0 0.08" 0 400 mm 500 mm 16" 20" 0.08" SM912F/SM2A912F Diffuse Mode 7.5 mm 0.3" 15 mm 0.6" 22.5 mm 0.9" 30 mm 1.2" 37.5 mm 1.5" DISTANCE DISTANCE Accessories Quick-Disconnect Cables Model Length Style Dimensions MBCC-306 2 m (6.5') MBCC-312 4 m (12') 3-Pin Mini-style straight MBCC-330 9 m (30') MBCC-406 2 m (6.5') MBCC-412 4 m (12') MBCC-430 9 m (30') Pinout (Female View) 1 61 mm max. (2.4") 4-Pin Mini-style straight 7/8-16UN-2B 2 3 ø 28 mm max. (1.1") 2 4 1 3 1 = Black 2 = Brown 3 = Blue 1 = Brown 2 = White 3 = Blue 4 = Black Cabling Accessories Model Description AC-6 2 m (6.5') armored cable jacket I.D. 5/16"; O.D. 7/16" PVC-6 2 m (6.5') flexible PVC tubing (not for QD models) I.D. 1/4"; O.D. 3/8" RF1-2NPS Compression fitting for attaching armored cable or PVC tubing – HF1-2NPS 10 • Flexible black nylon cable protector • Includes a neoprene gland that compresses around the VALU-BEAM cable to provide an additional seal against moisture • Resistant to gasoline, alcohol, oil, grease, solvents and weak acids • Working temperature range of -30° to +100° C (-22° to +212° F) www.bannerengineering.com - tel: 763-544-3164 P/N 03467_web Rev. F VALU-BEAM® 912 Series Extension Cables (without connectors) The following cables are available for extending the length of existing sensor cable. These are 30 m (100') lengths of VALU-BEAM cable. This cable may be spliced to existing cable. Connectors, if used, must be customer-supplied. Model Type Used With: EC312-100 4-conductor SM912 Series dc sensors EC312A-100 2-conductor For all emitters and SM2A912 Series ac sensors Retroreflective Targets Banner offers a wide selection of high-quality retroreflective targets. See the Accessories section of your current Banner Photoelectric Sensors catalog for complete information. NOTE: Polarized sensors require corner cube type retroreflective targets. Non-polarized sensors may use any retroreflective target. Replacement Lens Assemblies VALU-BEAM lens assemblies are field-replaceable. In addition, some lenses may be used to convert from one sensing mode to another, or to change the sensing range of a particular sensor. The possible conversions are listed in the table below. Models Description Possible Sensing Mode or Range Changes UC-900AG Replacement lens for LVAG Change LV to LVAG UC-900C Replacement lens for C and CV Change LV to CV UC-900DSR Replacement lens for DSR, ESR, and RSR Change D or F to DSR, EF to ESR, and RF to RSR UC-900F Replacement lens for F Change D to F and DSR to F UC-900FP Replacement lens for FP – UC-900L Replacement lens for E, R, LV, and D Change LVAG to LV, CV to LV, DSR to D, and F to D UC-900J Attach to E, R, ESR, RSR, LV, and D models Flat polycarbonate dust cover P/N 03467_web Rev. F www.bannerengineering.com - tel: 763-544-3164 11 VALU-BEAM® 912 Series Mounting Brackets SMB30C SMB30SC 56 • 30 mm split clamp, black PBT bracket • Stainless steel mounting hardware included • Mounting hole for 30 mm sensor A 66 B 13 Hole center spacing: A=ø 45 Hole size: B=ø 27.2 • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼") hardware • Mounting hole for 30 mm sensor 57 70 C 57 B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp.
SM91R 价格&库存
很抱歉,暂时无法提供与“SM91R”相匹配的价格&库存,您可以联系我们找货
