RL28-8-H-700-RT/47/105
    PEPPERL+FUCHS(倍加福)
    PHOTO SEN 20-700MM BACK SUPPRESS
RL28-8-H-700-RT/47/105 数据手册
Background suppression sensor RL28-8-H-700-RT/47/105 < Ultra bright LEDs for power on and switching state < Good alignability due to red transmission LED < Not sensitive to ambient light, even with switched energy saving lamps < Waterproof, degree of protection IP67 < Protection class II Background suppression sensor Dimensions Connector view 54.3 14.8 Print Type code Connection diagram 8 25.8 16 6 ø5 88 62 26.5 Emitter 9.8 2 4 25 11 5 10 Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 419618_eng.pdf Receiver M12 x 1 Dovetail mount 10 51.8 Sensing range adjuster LED indicator: switching state LED indicator: operation Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Light/dark switch LED indicator: switching state Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Background suppression sensor RL28-8-H-700-RT/47/105 Technical Data General specifications Detection range 20 ... 700 mm Detection range min. 20 ... 200 mm Detection range max. 20 ... 700 mm Background suppression max. + 10 % of the upper limit of the detection range Light source LED Light type modulated visible red light , 660 nm Black-white difference (6 %/90 %) < 20 % Diameter of the light spot approx. 15 mm at a distance of 700 mm Angle of divergence Emitter 1.2°, Receiver 2° Ambient light limit 50000 Lux Functional safety related parameters MTTFd 720 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator LED green Function indicator 2 LEDs yellow ON: object inside the scanning range OFF: object outside the scanning range Control elements Sensing range adjuster , Light-on/dark-on changeover switch Electrical specifications Operating voltage UB Ripple No-load supply current 10 ... 30 V DC 10 % I0 ≤ 40 mA Output Switching type light/dark on switchable Signal output 2 PNP, complementary, short-circuit protected, reverse polarity protected , open collectors Switching voltage max. 30 V DC Switching current Switching frequency Response time max. 200 mA f 250 Hz 2 ms Conformity Product standard EN 60947-5-2 Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 419618_eng.pdf Approvals and certificates EAC conformity TR CU 020/2011 Protection class II, rated voltage ≤ 250 V AC with pollution degree 1-2 according to IEC 60664-1 UL approval E87056 , cULus Listed , class 2 power supply , type rating 1 Ambient conditions Ambient temperature -40 ... 60 °C (-40 ... 140 °F) Storage temperature -40 ... 75 °C (-40 ... 167 °F) Mechanical specifications Housing width 25.8 mm Housing height 88 mm Housing depth 54.3 mm Degree of protection IP67 Connection 5-pin, M12 x 1 connector Material Housing Plastic ABS Optical face plastic Connector plastic Mass 70 g Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Background suppression sensor RL28-8-H-700-RT/47/105 Connection Assignment Option: /47 1 +UB 2 Q 3 0V 4 Q 5 n.c. = Light on = Dark on Connection Assignment 1 5 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 5 BN WH BU BK GY (brown) (white) (blue) (black) (gray) Characteristic response curve RL(K)28-8-H-700-RT Offset Y [mm] 8 6 4 2 0 -2 -4 -6 -8 0 200 400 600 x y Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 419618_eng.pdf Characteristic Curve 800 Distance X [mm] white 90 % grey 18 % black 6 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Background suppression sensor RL28-8-H-700-RT/47/105 Characteristic Curve Difference in detection distance RL(K)28-8-H-700-RT Measured detection distance X [mm] 800 700 600 500 400 300 200 100 0 0 200 x 400 600 800 Adjusted detection distance X [mm] white 90 % grey 18 % black 6 % Application Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 419618_eng.pdf Accessories OMH-05 Mounting aid for round steel ø 12 mm or sheet 1.5 mm ... 3 mm OMH-21 Mounting bracket: mounting aid for sensors in the RL* series OMH-22 Mounting aid for RL* series OMH-RLK29-HW Mounting bracket for rear wall mounting OMH-RL28-C Weld slag cover model Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Background suppression sensor RL28-8-H-700-RT/47/105 Additional Information Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 419618_eng.pdf Mounting instructions: There are two bore holes for mounting the sensor with M5 bolts. The base surface must be flat to avoid distorting the housing during mounting. It is advisable to secure the bolts with spring washers so that the sensor does not become misaligned. Outdoor installation: The sensor must be protected against rain and splash-water, possibly must a cover be installed. Adjustment: Adjust the sensor on the background. After the connecting to the power supply the green LED illuminates. In case the yellow LEDs illuminate too, the detection range needs to be reduced with the detection range adjuster, until the yellow LEDs is switched off. If the object is moved into the detection range the yellow LEDs illuminates. Driving inductive loads: If the sensor are used to drive inductive loads, the following safety procedures must be carried out: For operating voltage of 10 V DC … 30 V DC: fit a protection diode, max. 200 mA Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5
RL28-8-H-700-RT/47/105 价格&库存
很抱歉,暂时无法提供与“RL28-8-H-700-RT/47/105”相匹配的价格&库存,您可以联系我们找货
