LD32CNB06NPT
LD32CNB06NPT
    CARLOGAVAZZI
    SENSOR REFLECTIVE 60M NPN NO/NC
LD32CNB06NPT 数据手册
Photoelectrics Laser, Diffuse-reflective, Background Suppression Type LD32CNB06 • • • • • • • • • • • • Product Description Miniature sensor range Range: 60 mm Sensitivity adjustment by Teach-In programming Modulated, red laser light, 650 nm (class 2) Supply voltage: 10 to 30 VDC Output: 100 mA, NPN or PNP preset Make and break switching function programmable LED for output indication, signal stability and power ON Protection: reverse polarity, short circuit and transients Cable and plug versions Compact housing Excellent EMC performance Ordering Key LD32CNB06PPM5T flexible. The small spot and background suppression makes the sensor able to detect small objects close to the background. The output type is preset (NPN or PNP), and the output switching function is programmable (NO or NC). Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Teach-In Housing WxHxD Range Sn Ordering no. NPN & PNP cable Make & break switching Ordering no. NPN & PNP plug Make & break switching 12 x 32 x 20 mm 60 mm LD 32 CNB 06 NPT LD 32 CNB 06 PPT LD 32 CNB 06 NPM5T LD 32 CNB 06 PPM5T The LD32 sensor family is available in a compact 12 x 32 x 20 mm reinforced PMMA/ABS-housing. The sensors are useful in applications where highaccuracy detection as well as small size is required. The Teach-In function for adjustment of the sensitivity makes the sensors highly Type Selection Specifications Rated operating distance (Sn) Up to 60 mm, reference target Kodak test card R 27, white, 90% reflectivity, 100 x 100 mm Blind zone ≤ 25 mm Sensitivity Adjustable by Teach-In (push button or wire) Temperature drift ≤ 1%/ºC Hysteresis (H) (differential travel) ≤ 7% (grey scale displacement 90%/18%) 10 to 30 VDC Rated operational volt. (UB ) (ripple included) Ripple (Urpp ) ≤ 10% Output current ≤ 100 mA Continuous (Ie) Short-time (I) ≤ 100 mA (max. load capacity 100 nF) ≤ 25 mA @ 24 VDC No load supply current (Io) Specifications are subject to change without notice (06.02.2006) Minimum operational current (Im) OFF-state current (Ir ) Voltage drop (Ud ) Protection Laser protection class Average power Pulse width Pulse repetition time MTBF Light source Light type Sensing angle Ambient light Light spot Operating frequency Response time OFF-ON (tON) ON-OFF (tOFF ) Power ON delay (tv) 0.5 mA ≤ 100 µA ≤ 2.4 VDC @ 100 mA Short-circuit, reverse polarity and transients Class 2 - according to EN60825-1-3/97 < 1 mW t = 3 μs f = 5 kHz > 50’000 h @ Ta = 40ºC Laser red light, 650 nm Red, modulated < 0.8º 5,000 lux < 0.5 mm 1000 Hz ≤ 0.5 ms ≤ 0.5 ms ≤ 300 ms 1 LD32CNB06 Specifications (cont.) Output function NPN and PNP NO/NC switching function External Teach (ET) Same function as button Locked (disable teach button) Operating mode Indication Output ON Power ON Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Preset Set up by button Shock 10 to 30 VDC 0 to 2.5 VDC Not connected Rated insulation voltage Housing material Body Front material Connection Cable LED, yellow LED, green II (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) Plug Weight CE-marking 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 30 g / 11 ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) 500 VAC (rms) ABS, black PMMA, red PUR, black, 2 m 4 x 0.14 mm2, Ø = 3.6 mm M8, 4-pin Cable type: 40 g Plug type: 10 g Yes -20° to +60°C (-4° to +140°F) -20° to +80°C (-4° to +176°F) Operation Diagram tv = Power ON delay Power supply Object/target present Break (NC) Output ON Make (NO) Output ON Wiring Diagrams NPN 1 BN PNP +V 1 BN + 4 BK ET 2 WH ET Teach input is active when 2 WH wire is connected to V+ (1 BN). 2 WH 4 BK 3 BU 3 BU - - V ET = External Teach Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (06.02.2006) LD32CNB06 Dimensions Plug version Cable version Accessories Delivery Contents • Photoelectric switch: LD 32 CNB 06 ... • Installation instruction • Packaging: Cardboard box Mounting bracket APD32-MB3 14 6 3.3 1.2 3.3 5 30 18.75 3.3 7.5 20 For further information refer to “Accessories” Specifications are subject to change without notice (06.02.2006) 3 LD32CNB06 Adjustment Sensitivity adjustment, with static object 1. Line up the sensor with the object. Yellow LED and green LED are ON. 2. Press the button for 3 s until both LED’s flash simultaneously (the first switching point is stored). 3. Place the object outside the detection area. 4. Press the button for 1 s. a) The green LED flashes and stays ON: the second switching point is stored, and the sensor is ready to operate. b) Both LED’s flash simultaneously: the sensor cannot detect the object, no switching points are stored. 1 2 3s 3 4 1s Programming of make and break switching function 13 s 1. Press the button for 13 s. Both LED’s flash alternately. 2. Release the button: the green LED flashes. 3. While the green LED flashes, the output is inverted each time the button is pressed. This is indicated by the yellow LED. When the button is not pressed for 10 s, the current output function is stored. The sensor is now ready for operation. Default setting 1. No object in the detection area: Press the button for 3 s, until both LED’s flash simultaneously. 3s 2. No object in the detection area: 1s Press the button for 1 s. The sensor is set to maximum sensitivity. NB! The Teach Input (2 WH) will work similarly to the push button, active High. Sensitivity adjustment, with only one object 1. Line up the sensor with the object. Yellow LED and green LED are ON. 2. Press the button for 3 s until both LED’s flash simultaneously (the first switching point is stored). 3. Leave the object in the detection area, press the button for 1 s. The green LED flashes and stays on: the second switching point is stored, and the sensor is ready to operate. Sensitivity adjustment, with a running process 1. Line up the sensor with the object. Green LED is ON. At this stage the status of the yellow LED can be ignored. 2. The running process must be the only “object” within the detection area. Press the button for 3 s until both LED’s flash simultaneously. 3s 3. Press the button for at least the duration of one process cycle. 1 cycle a) b) 4 The green LED flashes and stays ON: both switching points have been stored, and the sensor is ready to operate. Both LED’s flash simultaneously: the sensor cannot detect the object, no switching points are stored. Specifications are subject to change without notice (06.02.2006)
LD32CNB06NPT
物料型号: - 型号:LD32CNB06PPM5T
器件简介: - 该传感器系列采用紧凑的12 x 32 x 20 mm加强型PMMA/ABS外壳。 - 小光斑和背景抑制功能使其能够检测靠近背景的小物体。 - 适用于需要高精度检测和小巧尺寸的应用。
引脚分配: - NPN型:1号引脚为棕色(BN),2号引脚为白色(WH),3号引脚为蓝色(BU)。 - PNP型:1号引脚为棕色(BN),2号引脚为白色(WH),4号引脚为黑色(BK)。
参数特性: - 工作距离:最大60mm,参考目标为Kodak测试卡R 27,白色,90%反射率,100x100 mm。 - 盲区:≤25mm。 - 灵敏度:可通过Teach-In(教学输入)调整。 - 温度漂移:1%/°C。 - 滞后(H):7%(灰度位移90%/18%)。 - 额定工作电压:10至30VDC。 - 输出电流:连续100mA,短时间100mA(最大负载容量100nF)。 - 无负载供电电流:25mA@24VDC。 - 关断状态下电流:100μA。 - 电压降:2.4VDC@100mA。 - 保护:短路、反极性和瞬变保护。 - 激光保护等级:2级,根据EN60825-1-3/97。 - 平均功率:<1mW。 - 脉冲宽度:3μs。 - 脉冲重复时间:5kHz。 - MTBF(平均无故障时间):>50,000小时@40°C。 - 光源:激光红光,650 nm。 - 光类型:红色,调制。 - 感应角度:<0.8°。 - 环境光:5,000 lux。 - 光斑:<0.5mm。 - 工作频率:1000Hz。 - 响应时间:关断到导通(OFF-ON)0.5ms,导通到关断(ON-OFF)0.5ms。 - 上电延迟(t.):300ms。
功能详解: - 输出类型:NPN或PNP预设。 - 输出配置:可编程(常开或常闭)。 - Teach-In功能:用于灵敏度调整,使传感器高度灵活。
应用信息: - 适用于需要高精度检测和小巧尺寸的应用。
封装信息: - 外壳尺寸:12 x 32 x 20 mm。 - 外壳材料:PMMA/ABS。 - 连接类型:电缆和插头版本。
LD32CNB06NPT 价格&库存
很抱歉,暂时无法提供与“LD32CNB06NPT”相匹配的价格&库存,您可以联系我们找货
LD32CNB06NPT
  • 1+5503.09877
库存:4
