HIP6018BCB
HIP6018BCB
    L3HARRIS
    SOIC24
    SWITCHING CONTROLLER
HIP6018BCB 数据手册
SIGNS NEW DE R O F D NT N DE L ACEM E a t COMME P E E R R T D O E N r D rt Cente OMMEN NO R EC al Suppo il.com/tsc ic n h c e T our Sheetr www.inters contactData o TERSIL N -I 8 1-88 Advanced PWM and Dual Linear Power Control The HIP6018B provides the power control and protection for three output voltages in high-performance microprocessor and computer applications. The IC integrates a PWM controllers, a linear regulator and a linear controller as well as the monitoring and protection functions into a single package. The PWM controller regulates the microprocessor core voltage with a synchronous-rectified buck converter. The linear controller regulates power for the GTL bus and the linear regulator provides power for the clock driver circuit. The HIP6018B includes an Intel-compatible, TTL 5-input digital-to-analog converter (DAC) that adjusts the core PWM output voltage from 2.1VDC to 3.5VDC in 0.1V increments and from 1.3VDC to 2.05VDC in 0.05V steps. The precision reference and voltage-mode control provide 1% static regulation. The linear regulator uses an internal pass device to provide 2.5V 2.5%. The linear controller drives an external N-channel MOSFET to provide 1.5V 2.5%. The HIP6018B monitors all the output voltages. A single Power Good signal is issued when the core is within ±10% of the DAC setting and the other levels are above their undervoltage levels. Additional built-in over-voltage protection for the core output uses the lower MOSFET to prevent output voltages above 115% of the DAC setting. The PWM overcurrent function monitors the output current by using the voltage drop across the upper MOSFET’s rDS(ON), eliminating the need for a current sensing resistor. Pinout HIP6018B (SOIC) TOP VIEW HIP6018B April 1, 2005 FN4586.3 Features • Provides 3 Regulated Voltages - Microprocessor Core, Clock and GTL Power • Drives N-Channel MOSFETs • Operates from +3.3V, +5V and +12V Inputs • Simple Single-Loop PWM Control Design - Voltage-Mode Control • Fast Transient Response - High-Bandwidth Error Amplifier - Full 0% to 100% Duty Ratios • Excellent Output Voltage Regulation - Core PWM Output: 1% Over Temperature - Other Outputs: 2.5% Over Temperature • TTL-Compatible 5-Bit Digital-to-Analog Core Output Voltage Selection - Wide Range . . . . . . . . . . . . . . . . . . . 1.3VDC to 3.5VDC - 0.1V Steps . . . . . . . . . . . . . . . . . . . . 2.1VDC to 3.5VDC - 0.05V Steps . . . . . . . . . . . . . . . . . . 1.3VDC to 2.05VDC • Power-Good Output Voltage Monitor • Microprocessor Core Voltage Protection Against Shorted MOSFET • Over-Voltage and Over-Current Fault Monitors - Does Not Require Extra Current Sensing Element, Uses MOSFET’s rDS(ON) • Small Converter Size - Constant Frequency Operation - 200kHz Free-Running Oscillator; Programmable from 50kHz to over 1MHz • Pb-Free Available (RoHS Compliant) Applications VCC 1 24 UGATE1 • Full Motherboard Power Regulation for Computers VID4 2 23 PHASE1 • Low-Voltage Distributed Power Supplies VID3 3 22 LGATE1 VID2 4 21 PGND Ordering Information VID1 5 20 OCSET1 VID0 6 19 VSEN1 PGOOD 7 PART NUMBER TEMP. RANGE (oC) PACKAGE PKG. DWG. # 18 FB1 HIP6018BCB* 0 to 70 24 Ld SOIC M24.3 0 to 70 24 Ld SOIC (Pb-free) M24.3 17 COMP1 HIP6018BCBZ* (Note) SS 9 16 FB3 RT 10 15 DRIVE3 * Add “-T” suffix for tape and reel. NOTE: Intersil Pb-free products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. FAULT 8 14 GND FB2 11 13 VOUT2 VIN2 12 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright Intersil Americas Inc. 2003, 2005. All Rights Reserved All other trademarks mentioned are the property of their respective owners. 2 FAULT FB2 VOUT2 VIN2 DRIVE3 0.23A 3V + - + - + 0.3V - + SS 1.26V VCC INHIBIT + FB3 - FIGURE 1. 4V OV DACOUT SOFTSTART & FAULT LOGIC TTL D/A CONVERTER (DAC) OC2 LUV VID4 VID0 VID2 VID1 VID3 11A + - + - LINEAR UNDERVOLTAGE + - + - + - + - FB1 OC1 COMP1 ERROR AMP 115% 90% 110% VSEN1 PWM RT UPPER DRIVE RESET (POR) POWER-ON VCC LOWER DRIVE GATE CONTROL INHIBIT OSCILLATOR PWM COMP + - + - 200mA OCSET1 VCC VCC 3V GND PGND LGATE1 PHASE1 UGATE1 PGOOD HIP6018B Block Diagram HIP6018B Simplified Power System Diagram +5VIN Q1 +3.3VIN LINEAR REGULATOR VOUT2 PWM1 CONTROLLER VOUT1 HIP6018B Q2 LINEAR CONTROLLER Q3 VOUT3 FIGURE 2. Typical Application +12VIN +5VIN CIN VCC OCSET1 VIN2 +3.3VIN POWERGOOD PGOOD VOUT2 VOUT2 2.5V UGATE1 FB2 COUT2 Q1 PHASE1 LGATE1 Q3 DRIVE3 VOUT3 Q2 CR1 PGND HIP6018B FB3 VSEN1 1.5V FB1 COUT3 COMP1 VID0 VID1 VID2 FAULT VID3 RT VID4 SS GND FIGURE 3. 3 LOUT1 CSS COUT1 VOUT1 1.3V TO 3.5V HIP6018B Absolute Maximum Ratings Thermal Information Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .+15V PGOOD, RT, FAULT, and GATE Voltage . . . GND - 0.3V to VCC + 0.3V Input, Output or I/O Voltage . . . . . . . . . . . . . . . . . . GND -0.3V to 7V Thermal Resistance (Typical, Note 1) JA (oC/W) SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 Maximum Junction Temperature (Plastic Package) 150oC Maximum Storage Temperature Range . . . . . . . . . . -65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . .300oC (SOIC - Lead Tips Only) Operating Conditions Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . +12V 10% Ambient Temperature Range . . . . . . . . . . . . . . . . . . . . . 0oC to 70oC Junction Temperature Range. . . . . . . . . . . . . . . . . . . . 0oC to 125oC CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. JA is measured with the component mounted on a high effective thermal conductivity test board in free air. See Tech Brief TB379 for details. Electrical Specifications Recommended Operating Conditions, Unless Otherwise Noted. Refer to Figures 1, 2 and 3 PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS - 8 - mA VCC SUPPLY CURRENT Nominal Supply ICC UGATE1, DRIVE3, LGATE1, and VOUT2 Open POWER-ON RESET Rising VCC Threshold VOCSET = 4.5V 8.6 - 10.4 V Falling VCC Threshold VOCSET = 4.5V 8.2 - 10.2 V 2.45 2.55 2.65 V VIN2 Under-Voltage Hysteresis - 100 - mV Rising VOCSET1 Threshold - 1.25 - V Rising VIN2 Under-Voltage Threshold OSCILLATOR Free Running Frequency RT = OPEN 185 200 215 kHz Total Variation 6k < RT to GND < 200k -15 - +15 % - 1.9 - VP-P DAC(VID0-VID4) Input Low Voltage - - 0.8 V DAC(VID0-VID4) Input High Voltage 2.0 - - V DACOUT Voltage Accuracy -1.0 - +1.0 % 1.240 1.265 1.290 V -2.5 - 2.5 % - 75 87 % - 6 - % Over-Current Protection 180 230 - mA Over-Current Protection During Start-Up 560 700 - mA -2.5 - 2.5 % - 75 87 % - 6 - % VIN2 - VOUT3 > 1.5V 20 40 - mA VIN2 - DRIVE3 > 0.6V 20 40 - mA VOSC Ramp Amplitude RT = Open REFERENCE AND DAC Reference Voltage (Pin FB2 and FB3) LINEAR REGULATOR Regulation 10mA < IVOUT2 < 150mA Under-Voltage Level FB2UV FB2 Rising Under-Voltage Hysteresis LINEAR CONTROLLER Regulation VSEN3 = DRIVE3, 0 < IDRIVE3 < 20mA Under-Voltage Level FB3UV FB3 Rising Under-Voltage Hysteresis Output Drive Current IDRIVE3 DRIVE3 Source Current 4 HIP6018B Electrical Specifications Recommended Operating Conditions, Unless Otherwise Noted. Refer to Figures 1, 2 and 3 (Continued) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS - 88 - dB - 15 - MHz COMP = 10pF - 6 - V/s PWM CONTROLLER ERROR AMPLIFIER DC Gain Gain-Bandwidth Product GBWP Slew Rate SR PWM CONTROLLER GATE DRIVER Upper Drive Source IUGATE VCC = 12V, VUGATE1 (or VGATE2) = 6V - 1 - A Upper Drive Sink RUGATE VUGATE1-PHASE1 = 1V - 1.7 3.5  Lower Drive Source ILGATE VCC = 12V, VLGATE1 = 1V - 1 - A Lower Drive Sink RLGATE VLGATE1 = 1V - 1.4 3.0  VSEN1 Rising 112 115 118 % VFAULT = 10V 10 14 - mA VOCSET = 4.5VDC 170 200 230 A - 11 - A - - 1.0 V PROTECTION VOUT1 Over-Voltage Trip FAULT Sourcing Current IOVP OCSET1 Current Source IOCSET Soft-Start Current ISS Chip Shutdown Soft-Start Threshold POWER GOOD VOUT1 Upper Threshold VSEN1 Rising 108 - 110 % VOUT1 Under Voltage VSEN1 Rising 92 - 94 % VOUT1 Hysteresis (VSEN1 / DACOUT) Upper/Lower Threshold - 2 - % IPGOOD = -4mA - - 0.5 V PGOOD Voltage Low VPGOOD Typical Performance Curves 100 CGATE = 4800pF CUGATE1 = CLGATE1 = CGATE VVCC = 12V, VIN = 5V 80 RT PULLUP TO +12V ICC (mA) RESISTANCE (k) 1000 100 10 60 40 0 100 SWITCHING FREQUENCY (kHz) FIGURE 4. RT RESISTANCE vs FREQUENCY 5 CGATE = 1500pF 20 RT PULLDOWN TO VSS 10 CGATE = 3600pF 1000 CGATE = 660pF 100 200 300 400 500 600 700 800 900 1000 SWITCHING FREQUENCY (kHz) FIGURE 5. BIAS SUPPLY CURRENT vs FREQUENCY HIP6018B Functional Pin Description VSEN1 (Pin 19) This pin is connected to the PWM converter’s output voltage. The PGOOD and OVP comparator circuits use this signal to report output voltage status and for over voltage protection. OCSET1 (Pin 20) Connect a resistor (ROCSET) from this pin to the drain of the upper MOSFET. ROCSET, an internal 200A current source (IOCSET), and the upper MOSFET on-resistance (rDS(ON)) set the PWM converter over-current (OC) trip point according to the following equation: I OCSET  R OCSET I PEAK = ---------------------------------------------------r DS  ON  An over-current trip cycles the soft-start function. Sustaining an over-current for 2 soft-start intervals shuts down the controller. SS (Pin 9) Connect a capacitor from this pin to ground. This capacitor, along with an internal 11A (typically) current source, sets the soft-start interval of the converter. Pulling this pin low with an open drain signal will shut down the IC. VID0, VID1, VID2, VID3, VID4 (Pins 6, 5, 4, 3 and 2) VID0-4 are the input pins to the 5-bit DAC. The states of these five pins program the internal voltage reference (DACOUT). The level of DACOUT sets the core converter output voltage. It also sets the core PGOOD and OVP thresholds. COMP1 and FB1 (Pins 17 and 18) COMP1 and FB1 are the available external pins of the PWM error amplifier. The FB1 pin is the inverting input of the error amplifier. Similarly, the COMP1 pin is the error amplifier output. These pins are used to compensate the voltagecontrol feedback loop of the PWM converter. UGATE1 (Pin 24) Connect UGATE pin to the PWM converter’s upper MOSFET gate. This pin provides the gate drive for the upper MOSFET. PGND (Pin 21) This is the power ground connection. Tie the PWM converter’s lower MOSFET source to this pin. LGATE1 (Pin 22) Connect LGATE1 to the PWM converter’s lower MOSFET gate. This pin provides the gate drive for the lower MOSFET. VCC (Pin 1) Provide a 12V bias supply for the IC to this pin. This pin also provides the gate bias charge for all the MOSFETs controlled by the IC. RT (Pin 10) This pin provides oscillator switching frequency adjustment. By placing a resistor (RT) from this pin to GND, the nominal 200kHz switching frequency is increased according to the following equation: 6 5  10 Fs  200kHz + --------------------R T  k  (RT to GND) Conversely, connecting a pull-up resistor (RT) from this pin to VCC reduces the switching frequency according to the following equation: 7 4  10 Fs  200kHz – --------------------R T  k  (RT to 12V) FAULT (Pin 8) This pin is low during normal operation, but it is pulled to VCC in the event of an over-voltage or over-current condition. DRIVE3 (Pin 15) Connect this pin to the gate of an external MOSFET. This pin provides the drive for the linear controller’s pass transistor. GND (Pin 14) FB3 (Pin 16) Signal ground for the IC. All voltage levels are measured with respect to this pin. Connect this pin to a resistor divider to set the linear controller output voltage. PGOOD (Pin 7) VOUT2 (Pin 13) PGOOD is an open collector output used to indicate the status of the output voltages. This pin is pulled low when the core output is not within 10%of the DACOUT reference voltage and the other outputs are below their under-voltage thresholds. The PGOOD output is open for ‘11111’ VID code. See Table 1. Output of the linear regulator. Supplies current up to 230mA. PHASE1 (Pin 23) Connect the PHASE pin to the PWM converter’s upper MOSFET source. This pin is used to monitor the voltage drop across the upper MOSFET for over-current protection. 6 FB2 (Pin 11) Connect this pin to a resistor divider to set the linear regulator output voltage. VIN2 (Pin 12) This pin supplies power to the internal regulator. Connect this pin to a suitable 3.3V source. Additionally, this pin is used to monitor the 3.3V supply. If, following a startup cycle, the voltage drops below 2.55V (typically), the chip shuts down. A new soft-start cycle is HIP6018B initiated upon return of the 3.3V supply above the undervoltage threshold. Description Operation The HIP6018B monitors and precisely controls 4 output voltage levels (Refer to Figures 1, 2, and 3). It is designed for microprocessor computer applications with 3.3V and 5V power, and 12V bias input from an ATX power supply. The IC has one PWM controller, a linear controller, and a linear regulator. The PWM controller is designed to regulate the microprocessor core voltage (VOUT1) by driving 2 MOSFETs (Q1 and Q2) in a synchronous-rectified buck converter configuration. The core voltage is regulated to a level programmed by the 5-bit digital-to-analog converter (DAC). An integrated linear regulator supplies the 2.5V clock power (VOUT2). The linear controller drives an external MOSFET (Q3) to supply the GTL bus power (VOUT3). until each output reaches sufficient voltage to transfer control to the input reference clamp. If we consider the 2.0V output (VOUT1) in Figure 3, this time occurs at T2. During the interval between T2 and T3, the error amplifier reference ramps to the final value and the converter regulates the output to a voltage proportional to the SS pin voltage. At T3 the input clamp voltage exceeds the reference voltage and the output voltage is in regulation. PGOOD (2V/DIV) 0V SOFT-START (1V/DIV) 0V VOUT2 ( = 2.5V) Initialization The HIP6018B automatically initializes upon receipt of input power. Special sequencing of the input supplies is not necessary. The Power-On Reset (POR) function continually monitors the input supply voltages. The POR monitors the bias voltage (+12VIN) at the VCC pin, the 5V input voltage (+5VIN) on the OCSET1 pin, and the 3.3V input on the VIN2 pin. The normal level on OCSET1 is equal to +5VIN less a fixed voltage drop (see over-current protection). The POR function initiates soft-start operation after all three input supply voltages exceed their POR thresholds. VOUT1 (DAC = 2V) OUTPUT VOLTAGES (0.5V/DIV) VOUT3 ( = 1.5V) 0V T0 T1 T2 T3 T4 TIME Soft-Start The POR function initiates the soft-start sequence. Initially, the voltage on the SS pin rapidly increases to approximately 1V (this minimizes the soft-start interval). Then an internal 11A current source charges an external capacitor (CSS) on the SS pin to 4V. The PWM error amplifier reference input (+terminal) and output (COMP1 pin) is clamped to a level proportional to the SS pin voltage. As the SS pin voltage slews from 1V to 4V, the output clamp generates PHASE pulses of increasing width that charge the output capacitor(s). After this initial stage, the reference input clamp slows the output voltage rate-of-rise and provides a smooth transition to the final set voltage. Additionally both linear regulator’s reference inputs are clamped to a voltage proportional to the SS pin voltage. This method provides a rapid and controlled output voltage rise. Figure 3 shows the soft-start sequence for the typical application. At T0 the SS voltage rapidly increases to approximately 1V. At T1, the SS pin and error amplifier output voltage reach the valley of the oscillator’s triangle wave. The oscillator’s triangular waveform is compared to the clamped error amplifier output voltage. As the SS pin voltage increases, the pulse-width on the PHASE pin increases. The interval of increasing pulse-width continues 7 FIGURE 6. SOFT-START INTERVAL The remaining outputs are also programmed to follow the SS pin voltage. Each linear output (VOUT2 and VOUT3) initially follows a ramp similar to that of the PWM output. When each output reaches sufficient voltage the input reference clamp slows the rate of output voltage rise. The PGOOD signal toggles ‘high’ when all output voltage levels have exceeded their under-voltage levels. See the Soft-Start Interval section under Applications Guidelines for a procedure to determine the soft-start interval. Fault Protection All three outputs are monitored and protected against extreme overload. A sustained overload on any linear regulator output or an over-voltage on the PWM output disables all converters and drives the FAULT pin to VCC. Figure 7 shows a simplified schematic of the fault logic. An over-voltage detected on VSEN1 immediately sets the fault latch. A sequence of three over-current fault signals also sets the fault latch. A comparator indicates when CSS is fully charged (UP signal), such that an under-voltage event on either linear output (FB2 or FB3) is ignored until after the softstart interval (T4 in Figure 6). At startup, this allows VOUT2 HIP6018B INHIBIT S Q OC1 S R 0.15V SS + + 4V COUNTER - - R FAULT LATCH VCC S Q UP R POR FAULT OV FIGURE 7. FAULT LOGIC - SIMPLIFIED SCHEMATIC and VOUT3 to slew up over increased time intervals, without generating a fault. Cycling the bias input voltage (+12VIN on the VCC pin) off then on resets the counter and the fault latch. Over-Voltage Protection During operation, a short on the upper PWM MOSFET (Q1) causes VOUT1 to increase. When the output exceeds the over-voltage threshold of 115% (typical) of DACOUT, the over-voltage comparator trips to set the fault latch and turns Q2 on as required in order to regulate VOUT1 to 1.15 x DACOUT. This blows the input fuse and reduces VOUT1. The fault latch raises the FAULT pin close to VCC potential. A separate over-voltage circuit provides protection during the initial application of power. For voltages on the VCC pin below the power-on reset (and above ~4V), VOUT1 is monitored for voltages exceeding 1.26V. Should VSEN1 exceed this level, the lower MOSFET (Q2) is driven on as needed to regulate VOUT1 to 1.26V. Over-Current Protection All outputs are protected against excessive over-currents. The PWM controller uses the upper MOSFET’s onresistance, rDS(ON) to monitor the current for protection against shorted outputs. The linear regulator monitors the current of the integrated power device and signals an overcurrent condition for currents in excess of 230mA. Additionally, both the linear regulator and the linear controller monitor FB2 and FB3 for under-voltage to protect against excessive currents. Figures 8 and 9 illustrate the over-current protection with an overload on OUT1. The overload is applied at T0 and the current increases through the output inductor (LOUT1). At time T1, the OVER-CURRENT1 comparator trips when the voltage across Q1 (ID • rDS(ON)) exceeds the level programmed by ROCSET. This inhibits all outputs, discharges the soft-start capacitor (CSS) with a 11A current sink, and increments the counter.CSS recharges at T2 and initiates a soft-start cycle with the error amplifiers clamped by soft-start. With OUT1 still overloaded, the inductor current increases to trip the overcurrent comparator. Again, this inhibits all outputs, but the 8 INDUCTOR CURRENTSOFT-START OVER CURRENT LATCH FAULT/RT soft-start voltage continues increasing to 4V before discharging. The counter increments to 2. The soft-start cycle repeats at T3 and trips the over-current comparator. The SS pin voltage increases to 4V at T4 and the counter increments to 3. This sets the fault latch to disable the converter. The fault is reported on the FAULT pin. LUV FAULT REPORTED 10V 0V COUNT =1 COUNT =2 COUNT =3 4V 2V 0V OVERLOAD APPLIED 0A T0 T1 T2 T3 T4 TIME FIGURE 8. OVER-CURRENT OPERATION The linear regulator operates in the same way as PWM1 to over-current faults. Additionally, the linear regulator and linear controller monitor the feedback pins for an undervoltage. Should excessive currents cause FB2 or FB3 to fall below the linear under-voltage threshold, the LUV signal sets the over-current latch if CSS is fully charged. Blanking the LUV signal during the CSS charge interval allows the linear outputs to build above the under-voltage threshold during normal start-up. Cycling the bias input power off then on resets the counter and the fault latch. Resistor ROCSET1 programs the over-current trip level for the PWM converter. As shown in Figure 9, the internal 200A current sink develops a voltage across ROCSET (VSET) that is referenced to VIN. The DRIVE signal enables the over-current comparator (OVER-CURRENT1). When the voltage across the upper MOSFET (VDS(ON)) exceeds VSET, the over-current comparator trips to set the over-current latch. Both VSET and VDS are referenced to VIN and a small capacitor across ROCSET helps VOCSET track the variations of VIN due to MOSFET switching. The over-current function will trip at a peak inductor current (IPEAK) determined by: I OCSET xR OCSET I PEAK = ------------------------------------------------------r DS  ON  HIP6018B OVER-CURRENT TRIP: VDS > VSET TABLE 1. VOUT1 VOLTAGE PROGRAM VIN = +5V (iD • rDS(ON) > IOCSET • ROCSET) PIN NAME VID4 VID3 VID2 VID1 VID0 NOMINAL OUT1 VOLTAGE DACOUT 0 1 1 1 1 1.30 0 1 1 1 0 1.35 0 1 1 0 1 1.40 0 1 1 0 0 1.45 0 1 0 1 1 1.50 0 1 0 1 0 1.55 0 1 0 0 1 1.60 0 1 0 0 0 1.65 0 0 1 1 1 1.70 0 0 1 1 0 1.75 0 0 1 0 1 1.80 1. The maximum rDS(ON) at the highest junction temperature. 0 0 1 0 0 1.85 2. The minimum IOCSET from the specification table. 0 0 0 1 1 1.90 3. Determine IPEAK for IPEAK > IOUT(MAX) + (I)/2, where I is the output inductor ripple current. 0 0 0 1 0 1.95 0 0 0 0 1 2.00 0 0 0 0 0 2.05 1 1 1 1 1 INHIBIT OUT1 Voltage Program 1 1 1 1 0 2.1 The output voltage of the PWM converter is programmed to discrete levels between 1.3VDC and 3.5VDC . This output is designed to supply the microprocessor core voltage. The voltage identification (VID) pins program an internal voltage reference (DACOUT) through a TTL-compatible 5-bit digital-to-analog converter. The level of DACOUT also sets the PGOOD and OVP thresholds. Table 1 specifies the DACOUT voltage for the different combinations of connections on the VID pins. The VID pins can be left open for a logic 1 input, because they are internally pulled up to +5V by a 10A (typically) current source. Changing the VID inputs during operation is not recommended. The sudden change in the resulting reference voltage could toggle the PGOOD signal and exercise the over-voltage protection. 1 1 1 0 1 2.2 1 1 1 0 0 2.3 1 1 0 1 1 2.4 1 1 0 1 0 2.5 1 1 0 0 1 2.6 1 1 0 0 0 2.7 1 0 1 1 1 2.8 1 0 1 1 0 2.9 1 0 1 0 1 3.0 1 0 1 0 0 3.1 1 0 0 1 1 3.2 The ‘11111’ VID pin combination resulting in an INHIBIT disables the IC and the open-collector at the PGOOD pin. 1 0 0 1 0 3.3 1 0 0 0 1 3.4 1 0 0 0 0 3.5 OCSET IOCSET 200A VSET + VCC + VDS PHASE - OVERCURRENT1 PWM ID + UGATE DRIVE OC1 ROCSET VCC LGATE GATE CONTROL VPHASE = VIN - VDS VOCSET = VIN - VSET PGND HIP6018B FIGURE 9. OVER-CURRENT DETECTION The OC trip point varies with MOSFET’s temperature. To avoid over-current tripping in the normal operating load range, determine the ROCSET resistor from the equation above with: For an equation for the output inductor ripple current see the section under component guidelines titled ‘Output Inductor Selection’. NOTE: 0 = connected to GND or VSS, 1 = open or connected to 5V through pull-up resistors. 9 HIP6018B Initially, the soft-start function clamps the error amplifier’s output of the PWM converter. After the output voltage increases to approximately 80% of the set value, the reference input of the error amplifier is clamped to a voltage proportional to the SS pin voltage. Both linear outputs follow a similar start-up sequence. The resulting output voltage sequence is shown in Figure 6. The soft-start function controls the output voltage rate of rise to limit the current surge at start-up. The soft-start interval is programmed by the soft-start capacitor, CSS. Programming a faster soft-start interval increases the peak surge current. The peak surge current occurs during the initial output voltage rise to 80% of the set value. +5VIN +3.3VIN CIN +12V CVCC COCSET1 VCC GND VIN2 OCSET1 VOUT3 Q3 GATE3UGATE1 ROCSET1 Q1 LOUT1 PHASE1 HIP6018B VOUT2 LGATE1 Q2 VOUT1 COUT1 CR1 LOAD Soft-Start Interval The critical small signal components include the by-pass capacitor for VCC and the soft-start capacitor, CSS. Locate these components close to their connecting pins on the control IC. Minimize any leakage current paths from SS node because the internal current source is only 11A. LOAD Application Guidelines SS PGND Shutdown The VID codes resulting in an INHIBIT as shown in Table 1 also shuts down the IC. Layout Considerations MOSFETs switch very fast and efficiently. The speed with which the current transitions from one device to another causes voltage spikes across the interconnecting impedances and parasitic circuit elements. The voltage spikes can degrade efficiency, radiate noise into the circuit, and lead to device over-voltage stress. Careful component layout and printed circuit design minimizes the voltage spikes in the converter. Consider, as an example, the turn-off transition of the upper PWM MOSFET. Prior to turn-off, the upper MOSFET was carrying the full load current. During the turn-off, current stops flowing in the upper MOSFET and is picked up by the lower MOSFET (and/or parallel Schottky diode). Any inductance in the switched current path generates a large voltage spike during the switching interval. Careful component selection, tight layout of the critical components, and short, wide circuit traces minimize the magnitude of voltage spikes. Contact Intersil for evaluation board drawings of the component placement and printed circuit board. There are two sets of critical components in a DC-DC converter using a HIP6018B controller. The power components are the most critical because they switch large amounts of energy. The critical small signal components connect to sensitive nodes or supply critical by-passing current. The power components should be placed first. Locate the input capacitors close to the power switches. Minimize the length of the connections between the input capacitors and the power switches. Locate the output inductor and output capacitors between the MOSFETs and the load. Locate the PWM controller close to the MOSFETs. 10 CSS VOUT2 LOAD The PWM output does not switch until the soft-start voltage (VSS) exceeds the oscillator’s valley voltage. Additionally, the reference on each linear’s amplifier is clamped to the soft-start voltage. Holding the SS pin low with an open drain or collector signal turns off all three regulators. COUT2 KEY ISLAND ON POWER PLANE LAYER ISLAND ON CIRCUIT PLANE LAYER VIA CONNECTION TO GROUND PLANE FIGURE 10. PRINTED CIRCUIT BOARD POWER PLANES AND ISLANDS A multi-layer printed circuit board is recommended. Figure 10 shows the connections of the critical components in the converter. Note that capacitors CIN and COUT could each represent numerous physical capacitors. Dedicate one solid layer for a ground plane and make all critical component ground connections with vias to this layer. Dedicate another solid layer as a power plane and break this plane into smaller islands of common voltage levels. The power plane should support the input power and output power nodes. Use copper filled polygons on the top and bottom circuit layers for the phase nodes. Use the remaining printed circuit layers for small signal wiring. The wiring traces from the control IC to the MOSFET gate and source should be sized to carry 1A currents. The traces for OUT2 need only be sized for 0.2A. Locate COUT2 close to the HIP6018B IC. PWM Controller Feedback Compensation Both PWM controllers use voltage-mode control for output regulation. This section highlights the design consideration for a voltage-mode controller. Apply the methods and considerations to both PWM controllers. Figure 11 highlights the voltage-mode control loop for a synchronous-rectified buck converter. The output voltage is regulated to the reference voltage level. The reference voltage level is the DAC output voltage for the PWM controller. The error amplifier output (VE/A) is compared with the oscillator (OSC) triangular wave to provide a pulse-width modulated wave with an amplitude of VIN at the PHASE node. The PWM wave is smoothed by the output filter (LO and CO). HIP6018B Compensation Break Frequency Equations VIN OSC  VOSC DRIVER PWM COMP LO - DRIVER + VOUT PHASE CO ESR (PARASITIC) ZFB VE/A - ERROR AMP ZIN + REFERENCE DETAILED FEEDBACK COMPENSATION C2 C1 ZFB VOUT ZIN C3 R2 R3 R1 COMP - FB + 1 F P2 = ----------------------------------2  R 3  C3 1 F Z2 = ------------------------------------------------------2   R1 + R3   C3 Figure 12 shows an asymptotic plot of the DC-DC converter’s gain vs. frequency. The actual modulator gain has a peak due to the high Q factor of the output filter at FLC, which is not shown in Figure 12. Using the above guidelines should yield a compensation gain similar to the curve plotted. The open loop error amplifier gain bounds the compensation gain. Check the compensation gain at FP2 with the capabilities of the error amplifier. The closed loop gain is constructed on the log-log graph of Figure 12 by adding the modulator gain (in dB) to the compensation gain (in dB). This is equivalent to multiplying the modulator transfer function to the compensation transfer function and plotting the gain. 100 FZ1 FZ2 FP1 FP2 80 HIP6018B REFERENCE The modulator transfer function is the small-signal transfer function of VOUT/VE/A. This function is dominated by a DC gain and the output filter, with a double pole break frequency at FLC and a zero at FESR. The DC gain of the modulator is simply the input voltage, VIN, divided by the peak-to-peak oscillator voltage, VOSC . Modulator Break Frequency Equations 1 F ESR = ----------------------------------------2  ESR  C O The compensation network consists of the error amplifier internal to the HIP6018B and the impedance networks ZIN and ZFB. The goal of the compensation network is to provide a closed loop transfer function with an acceptable 0dB crossing frequency (f0dB) and adequate phase margin. Phase margin is the difference between the closed loop phase at f0dB and 180 degrees The equations below relate the compensation network’s poles, zeros and gain to the components (R1, R2, R3, C1, C2, and C3) in Figure 11. Use these guidelines for locating the poles and zeros of the compensation network: 1. Pick Gain (R2/R1) for desired converter bandwidth 2. Place 1ST Zero Below Filter’s Double Pole (~75% FLC) 3. Place 2ND Zero at Filter’s Double Pole 4. Place 1ST Pole at the ESR Zero 5. Place 2ND Pole at Half the Switching Frequency 6. Check Gain against Error Amplifier’s Open-Loop Gain 7. Estimate Phase Margin - Repeat if Necessary 11 OPEN LOOP ERROR AMP GAIN 60 GAIN (dB) FIGURE 11. VOLTAGE-MODE BUCK CONVERTER COMPENSATION DESIGN 1 F LC = ---------------------------------------2  L O  C O 1 F P1 = ------------------------------------------------------C1  C2 2  R 2   ----------------------  C1 + C2 1 F Z1 = ----------------------------------2  R 2  C1 40 20 20LOG (R2/R1) 0 20LOG (VIN/VOSC) MODULATOR GAIN -20 COMPENSATION GAIN -40 -60 CLOSED LOOP GAIN FLC 10 100 1K FESR 10K 100K 1M 10M FREQUENCY (Hz) FIGURE 12. ASYMPTOTIC BODE PLOT OF CONVERTER GAIN The compensation gain uses external impedance networks ZFB and ZIN to provide a stable, high bandwidth loop. A stable control loop has a 0dB gain crossing with -20dB/decade slope and a phase margin greater than 45 degrees. Include worst case component variations when determining phase margin. Component Selection Guidelines Output Capacitor Selection The output capacitors for each output have unique requirements. In general the output capacitors should be selected to meet the dynamic regulation requirements. Additionally, the PWM converters require an output capacitor to filter the current ripple. The linear regulator is internally compensated and requires an output capacitor that meets the stability requirements. The load transient for the microprocessor core requires high quality capacitors to supply the high slew rate (di/dt) current demands. HIP6018B PWM Output Capacitors Modern microprocessors produce transient load rates above 10A/ns. High frequency capacitors initially supply the transient and slow the current load rate seen by the bulk capacitors. The bulk filter capacitor values are generally determined by the ESR (effective series resistance) and ESL (effective series inductance) parameters rather than actual capacitance. High frequency decoupling capacitors should be placed as close to the power pins of the load as physically possible. Be careful not to add inductance in the circuit board wiring that could cancel the usefulness of these low inductance components. Consult with the manufacturer of the load on specific decoupling requirements. Use only specialized low-ESR capacitors intended for switching regulator applications for the bulk capacitors. The bulk capacitor’s ESR determines the output ripple voltage and the initial voltage drop after a high slew-rate transient. An aluminum electrolytic capacitor’s ESR value is related to the case size with lower ESR available in larger case sizes. However, the equivalent series inductance of these capacitors increases with case size and can reduce the usefulness of the capacitor to high slew-rate transient loading. Unfortunately, ESL is not a specified parameter. Work with your capacitor supplier and measure the capacitor’s impedance with frequency to select suitable components. In most cases, multiple electrolytic capacitors of small case size perform better than a single large case capacitor. For a given transient load magnitude, the output voltage transient response due to the output capacitor characteristics can be approximated by the following equation: dI TRAN V TRAN = ESL  --------------------- + ESR  I TRAN dt Linear Output Capacitors The output capacitors for the linear regulator and the linear controller provide dynamic load current. The linear controller uses dominant pole compensation integrated in the error amplifier and is insensitive to output capacitor selection. Capacitor, COUT3 should be selected for transient load regulation. The output capacitor for the linear regulator provides loop stability. The linear regulator (OUT2) requires an output capacitor characteristic shown in Figure 13. The upper line plots the 45 phase margin with 150mA load and the lower line is the 45 phase margin limit with a 10mA load. Select a COUT2 capacitor with characteristic between the two limits. Output Inductor Selection The PWM converter requires an output inductor. The output inductor is selected to meet the output voltage ripple requirements and sets the converter’s response time to a load transient. The inductor value determines the converter’s ripple current and the ripple voltage is a function of the ripple current. The ripple voltage and current are approximated by the following equations: 12 0.7 0.6 0.5 ESR () 0.4 LE AB TION T S A ER OP 0.3 0.2 0.1 10 100 CAPACITANCE (F) 1000 FIGURE 13. COUT2 OUTPUT CAPACITOR V IN – V OUT V OUT I = --------------------------------  ---------------FS  LO V IN V OUT = I  ESR Increasing the value of inductance reduces the ripple current and voltage. However, the large inductance values reduce the converter’s response time to a load transient. One of the parameters limiting the converter’s response to a load transient is the time required to change the inductor current. Given a sufficiently fast control loop design, the HIP6018B will provide either 0% or 100% duty cycle in response to a load transient. The response time is the time interval required to slew the inductor current from an initial current value to the post-transient current level. During this interval the difference between the inductor current and the transient current level must be supplied by the output capacitors. Minimizing the response time can minimize the output capacitance required. The response time to a transient is different for the application of load and the removal of load. The following equations give the approximate response time interval for application and removal of a transient load: L O  I TRAN t RISE = -------------------------------V IN – V OUT L O  I TRAN t FALL = ------------------------------V OUT where: ITRAN is the transient load current step, tRISE is the response time to the application of load, and tFALL is the response time to the removal of load. With a +5V input source, the worst case response time can be either at the application or removal of load, and dependent upon the output voltage setting. Be sure to check both of these equations at the minimum and maximum output levels for the worst case response time. Input Capacitor Selection The important parameters for the bulk input capacitor are the voltage rating and the RMS current rating. For reliable operation, select the bulk capacitor with voltage and current ratings above the maximum input voltage and largest RMS current required by the circuit. The capacitor voltage rating should be at least 1.25 times greater than the maximum input voltage and a voltage rating of 1.5 times is a conservative guideline. HIP6018B Use a mix of input bypass capacitors to control the voltage overshoot across the MOSFETs. Use ceramic capacitance for the high frequency decoupling and bulk capacitors to supply the RMS current. Small ceramic capacitors should be placed very close to the upper MOSFET to suppress the voltage induced in the parasitic circuit impedances. For a through hole design, several electrolytic capacitors (Panasonic HFQ series or Nichicon PL series or Sanyo MVGX or equivalent) may be needed. For surface mount designs, solid tantalum capacitors can be used, but caution must be exercised with regard to the capacitor surge current rating. These capacitors must be capable of handling the surge-current at power-up. The TPS series available from AVX, and the 593D series from Sprague are both surge current tested. MOSFET Selection/Considerations The HIP6018B requires 3 N-Channel power MOSFETs. Two MOSFETs are used in the synchronous-rectified buck topology of the PWM converter. The linear controller drives a MOSFET as a pass transistor. These should be selected based upon rDS(ON) , gate supply requirements, and thermal management requirements. PWM1 MOSFET Selection and Considerations In high-current PWM applications, the MOSFET power dissipation, package selection and heatsink are the dominant design factors. The power dissipation includes two loss components; conduction loss and switching loss. These losses are distributed between the upper and lower MOSFETs according to duty factor (see the equations below). The conduction loss is the only component of power dissipation for the lower MOSFET. Only the upper MOSFET has switching losses, since the lower device turns on into near zero voltage. The equations below assume linear voltage-current transitions and do not model power loss due to the reverse-recovery of the lower MOSFET’s body diode. The gate-charge losses are proportional to the switching frequency (FS) and are dissipated by the HIP6018B, thus not contributing to the MOSFETs’ temperature rise. However, large gate charge increases the switching interval, tSW which increases the upper MOSFET switching losses. Ensure that both MOSFETs are within their maximum junction temperature at high ambient temperature by calculating the temperature rise according to package thermal resistance specifications. A separate heatsink may be necessary depending upon MOSFET power, package type, ambient temperature and air flow. 2 I O  r DS  ON   V OUT I O  V IN  t SW  F S P UPPER = ------------------------------------------------------------ + ---------------------------------------------------V IN 2 applied to the upper MOSFET is different than the lower MOSFET. Figure 14 shows the gate drive where the upper gateto-source voltage is approximately VCC less the input supply. For +5V main power and +12VDC for the bias, the gate-to-source voltage of Q1 is 7V. The lower gate drive voltage is +12VDC. A logic-level MOSFET is a good choice for Q1 and a logic-level MOSFET can be used for Q2 if its absolute gate-to-source voltage rating exceeds the maximum voltage applied to VCC. +5V OR LESS +12V VCC HIP6018B UGATE PHASE - + LGATE The rDS(ON) is different for the two previous equations even if the type device is used for both. This is because the gate drive 13 NOTE: VGS VCC -5V Q2 CR1 PGND NOTE: VGS VCC GND FIGURE 14. OUTPUT GATE DRIVERS Rectifier CR1 is a clamp that catches the negative inductor voltage swing during the dead time between the turn off of the lower MOSFET and the turn on of the upper MOSFET. The diode must be a Schottky type to prevent the lossy parasitic MOSFET body diode from conducting. It is acceptable to omit the diode and let the body diode of the lower MOSFET clamp the negative inductor swing, but efficiency might drop one or two percent as a result. The diode's rated reverse breakdown voltage must be greater than twice the maximum input voltage. Linear Controller MOSFET Selection The main criteria for the selection of a transistor for the linear regulator is package selection for efficient removal of heat. The power dissipated in a linear regulator is: P LINEAR = I O   V IN – V OUT  Select a package and heatsink that maintains the junction temperature below the maximum rating while operating at the highest expected ambient temperature. Additionally, if selecting a bipolar NPN transistor, insure the gain (hfe) at the minimum operating temperature and given collectorto-emitter voltage is sufficiently high as to deliver the worst-case steady state current required by the GTL output, when the transistor is driven with the minimum guaranteed DRIVE3 output current. For example, operating at “T” junction temperature, 3.3V input, and 1.5V output (VCE = 1.8V) the NPN’s gain should satisfy the following equation: 2 I O  r DS  ON    V IN – V OUT  P LOWER = --------------------------------------------------------------------------------V IN Q1 I GTL  steady – state  h fe  ----------------------------------------------------------I DRIVE3  min  HIP6018B HIP6018B DC-DC Converter Application Circuit +3.3VDC, +5VDC and +12VDC. For detailed information on the circuit, including a Bill-of-Materials and circuit board description, see Application Note AN9805. Also see Intersil’s web page (http://www.intersil.com). Figure 15 shows an application circuit of a power supply for a microprocessor computer system. The power supply provides the microprocessor core voltage (VOUT1), the GTL bus voltage (VOUT3) and clock generator voltage (VOUT2) from +12VIN L1 F1 +5VIN 15A 1H C1-7 6x1000F GND + C15 1F C16 1F C18 VCC 1 VIN2 +3.3VIN + 1000pF R2 20 12 OCSET1 1.1K POWERGOOD 7 C19 1000F 24 23 PGOOD Q1 HUF76143 UGATE1 PHASE1 VOUT1 (1.3 TO 3.5V) L3 3.5H Q3 RFD3055 DRIVE3 VOUT3 (1.5V) R11 + 1.87K C43-46 4x1000F R13 (2.5V) 10K C47 270F 15 21 16 19 R12 10K HIP6018B VOUT2 VOUT2 + FB3 22 FB2 18 LGATE1 PGND R4 4.99K VSEN1 FB1 13 11 17 COMP1 R14 10K VID0 VID1 VID1 VID2 VID2 VID3 VID3 VID4 VID4 C40 2.21K 0.68F 10pF C42 8 6 R10 5 10 4 9 FAULT RT SS 3 2 14 GND FIGURE 15. APPLICATION CIRCUIT 14 R8 C41 2200pF 160K VID0 C24-36 + 7x1000F Q2 HUF76143 C48 0.039F R9 732K HIP6018B Small Outline Plastic Packages (SOIC) M24.3 (JEDEC MS-013-AD ISSUE C) N 24 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE INDEX AREA 0.25(0.010) M H B M INCHES E -B- 1 2 3 L SEATING PLANE -A- h x 45o A D -C- e A1 B C 0.10(0.004) 0.25(0.010) M C A M SYMBOL MIN MAX MIN MAX NOTES A 0.0926 0.1043 2.35 2.65 - A1 0.0040 0.0118 0.10 0.30 - B 0.013 0.020 0.33 0.51 9 C 0.0091 0.0125 0.23 0.32 - D 0.5985 0.6141 15.20 15.60 3 E 0.2914 0.2992 7.40 7.60 4 e µ B S 0.05 BSC 1.27 BSC - H 0.394 0.419 10.00 10.65 - h 0.010 0.029 0.25 0.75 5 L 0.016 0.050 0.40 1.27 6 N  NOTES: MILLIMETERS 24 0o 24 8o 0o 7 8o 1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication Number 95. Rev. 0 12/93 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. 3. Dimension “D” does not include mold flash, protrusions or gate burrs. Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006 inch) per side. 4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per side. 5. The chamfer on the body is optional. If it is not present, a visual index feature must be located within the crosshatched area. 6. “L” is the length of terminal for soldering to a substrate. 7. “N” is the number of terminal positions. 8. Terminal numbers are shown for reference only. 9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater above the seating plane, shall not exceed a maximum value of 0.61mm (0.024 inch) 10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9001 quality systems. Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com 15
HIP6018BCB 价格&库存
很抱歉,暂时无法提供与“HIP6018BCB”相匹配的价格&库存,您可以联系我们找货
