WTB26P-34161120A00
WTB26P-34161120A00
    SICK
    SENSOR PROXIMITY 1.6M NPN/PNP
WTB26P-34161120A00 数据手册
Product data sheet WTB26P-34161120A00 W26 COMPACT PHOTOELECTRIC SENSORS WTB26P-34161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTB26P-34161120A00 1218806 Other models and accessories www.sick.com/W26 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 24.6 mm x 82.5 mm x 53.3 mm Housing design (light emission) Rectangular Sensing range max. 30 mm ... 1,600 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 7 mm (700 mm) Wave length 635 nm Adjustment Teach-Turn adjustment BluePilot: For setting the sensing range IO-Link For configuring the sensor parameters and Smart Task functions Indication LED blue BluePilot: sensing range indicator LED green Operating indicator Static: power on Flashing: IO-Link mode 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-18 16:08:35 Subject to change without notice WTB26P-34161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS LED yellow Status of received light beam Static on: object present Static off: object not present Pin 2 configuration 1) 2) External Input (test), Teach-in, switching signal  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WTB26P-34161120A00
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入侧的LED引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过光电效应实现信号传输,具有隔离作用,提高电路安全性。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm。
WTB26P-34161120A00 价格&库存
很抱歉,暂时无法提供与“WTB26P-34161120A00”相匹配的价格&库存,您可以联系我们找货
WTB26P-34161120A00
  • 1+2707.940891+351.44130
  • 5+2607.637115+338.42370
