PD30CNP06NPM5RT
PD30CNP06NPM5RT
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 6M NPN
PD30CNP06NPM5RT 数据手册
Photoelectrics Retro-reflective, Polarized Type PD30CNP06....RT • Miniature sensor range • Range: 6 m, with reflector • Sensitivity adjustment by Teach-In programming • Modulated, red light 660 nm, polarized • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function programmable • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Remote teach features Product Description Ordering Key The PD30CNP06 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Remote teach The Teach-In function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is programmable (NO or NC). A remote teach feature allow the sensor to be set up from e.g. a PLC. PD30CNP06PPM5RT Type Selection Housing Range Connection WxHxD Sn Ordering no. NPN Make or break switching Ordering no. PNP Make or break switching 10 x 30 x 20 mm 6 m 10 x 30 x 20 mm 6 m PD 30 CNP 06 NPRT PD 30 CNP 06 NPM5RT PD 30 CNP 06 PPRT PD 30 CNP 06 PPM5RT Cable Plug Note: Reflectors to be ordered separately Specifications EN 60947-5-2 Rated operating distance (Sn) Up to 6 m, with reflector Ø 80 mm (ER4) 4 m on ER4060 reflector Blind zone 100 mm Sensitivity Adjustable by Teach-In Temperature drift ≤ 0.1%/ºC Hysteresis (H) (differential travel) ≤ 10% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 30 mA @ 24 VDC Minimum operational current (Im) 0.5 mA OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2.4 VDC @ 100 mA Protection Short-circuit, reverse polarity and transients Light source GaAlAs, LED, 660 nm Specifications are subject to change without notice (05.08.2016) Light type Red, modulated Sensing angle ± 2º Ambient light 10,000 lux Light spot 110 mm @ 1.5 m Operating frequency 1000 Hz Response time OFF-ON (tON) ≤ 0.5 ms ON-OFF (tOFF ) ≤ 0.5 ms Power ON delay (tv) ≤ 300 ms Output function NPN and PNP Preset NO/NC switching function Set up by button Remote teach function Teach on (push button active) 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) Tamper proof When activated more than 20 sec. the sensor goes into a Tamper proof mode. Indication Output ON LED, yellow Signal stability ON and power ON LED, green 1 PD30CNP06....RT Specifications (cont.) Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock EN 60947-5-2 III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +55°C (-13° to +131°F) -40° to +70°C (-40° to +158°F) 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage 500 VAC (rms) Housing material Body ABS Front material PMMA, red Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON, 54-series) Weight With cable: 40 g With plug:  10 g CE-marking Yes Approvals cULus (UL508) Operation Diagram tv = Power ON delay ON OFF Power supply Make Output (N.O.) Present Not Present Tv ON OFF Break Output (N.C.) ON OFF Object Tv Wiring Diagrams NPN 1 BN Remote teach PNP V 2 WH 4 BK Remote teach 3 BU 1 BN V 4 BK 2 WH 3 BU V (GND) V (GND) Remote teach input active when connected to GND Remote teach input active when connected to V+ Excess Gain Detection Diagram 300 100 200 Exess gain (mm) 100 0 10 -100 -200 -300 1 0 2 4 6 (m) 2 8 10 0.1 1 10 Distance (m) Specifications are subject to change without notice (05.08.2016) PD30CNP06....RT Accessories Signal Stability Indication 21.2 14 9° 32.4 1.2 25.4 Excess Gain 9° 26,3 29.3 39 3.2 Operation level x 1.25 Operation level Operation level x 0.75 1.2 10 1.25 1.0 0.75 25.4 3.2 13.5 16.2 6.0 5.2 3 Yellow LED ON 4.4 14 4.4 6.0 16 10 7.3 Green LED ON 8.2 5.7 Time 4.4 Mounting bracket: APD30-1 Mounting bracket: APD30-2 Dimensions Plug version Cable version 10.6 PD30CNP 06NPM5T 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 10.8 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET xxxxxxS Incorrect Correct Emitter Two M3 Two, 9.5 dia. Lenses 15 30 15 22 Receiver Optical axis 5.5 5.5 Two, 9.5 dia. Lenses 10.8 17 22 Receiver Optical axis R 25.4 17 R Power / Stability LED Green 10.6 1.1 PD30CNP 06NPM5T 25.4 30 Output LED Yellow Power / Stability LED Green 5.5 5.5 1.1 Output LED Yellow xxxxxxS 6 20 10.6 6 Teach Button 20 10.6 Teach Button Two M3 > 100 mm Emitter 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PD 30 CNP 06 ... • Installation instruction • Mountingbracket APD30-MB1 • Packaging: Cardboard box • Reflector is to be purchased separately • Mounting bracket APD30-MB2 to be purchased separately Specifications are subject to change without notice (05.08.2016) 3 PD30CNP06....RT Teach functions Normal operation, optimized switching point 1. Line up the sensor with the reflector. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object between the sensor and reflector in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 4 3 sec. 1 1 Push once For maximum sensing distance (default setting) 1. Line up the sensor with the reflector, place the object between the sensor and reflector in the detection zone. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) For dynamic setup (running process) 1. Line up the sensor with the reflector. Green LED is ON, status on the yellow LED is not important. 2. Press the button for 3 second until both LEDs flashes simultaneously. 3. Press the button a second time for at least one second, both LED’s flashes fast simultaneously and keep the button pressed for at least one process cycle, release the button and the sensor is ready to operate (The second switch point is stored) 2 3 sec. 3 One cycle For make or break setup (N.O. or N.C.) 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 3 10 sec. 3 sec. 2 Push once Push once For minimum sensing distance 1. Line up the sensor with the reflector. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 sec. 4 3 Push once Specifications are subject to change without notice (05.08.2016)
PD30CNP06NPM5RT 价格&库存
很抱歉,暂时无法提供与“PD30CNP06NPM5RT”相匹配的价格&库存,您可以联系我们找货
