PD180CBT30MU
PD180CBT30MU
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 30M SPST
PD180CBT30MU 数据手册
Photoelectrics Through-beam, Relay Output, Battery Powered Type PD180CBT30Q/MU • Designed for industrial doors and gates • ESPE type 2, Performance level C • Range 15 m or 30 m • Modulated, infrared light • Supply voltage: 12 to 24 VAC/DC (receiver) • Supply voltage: 2 x ER14505 3.6 VDC size AA Lithium batteries (emitter) • SPST relay output • SPST relay low battery • LED for output indication • Connection, terminal block • Emitter test input • CE (EN 12453, EN 12978) and UL325 approved Product Description The PD180CBT30Q/MU sensor is developed specifically for the domestic and industrial door market. The sensor meets the regulations for industrial doors in Europe and North America. The robust polycarbonate housing allows flexible installation as the lenses are adjustable both in horizontal and vertical direction. The sensor is easy to use and no sensitivity adjustments are necessary. The aspherical lens design is superior to previous design of sensors with built-in parabolic reflectors that had corrosion and dust Ordering Key problems. Increased safety by build-in: - Sensor test function; the emitter has a built-in test input designed to mute the emitter and thus evaluate the sensor function. Test function is to be activated by the door controller or the door function can be activated by a limit switch, magnet sensor or a safety edge profile. The receiver works with a power-supply from 12 to 24 VAC/DC and the emitter is designed to use 2 x ER14505 3.6 VDC size AA Lithium batteries. PD180CBT30Q/MU Type Housing style Housing size Housing material Battery operated Detection principle Sensing distance Output type Output configuration Mute function Type Selection Housing Range Ordering no. size Sn Emitter 180 x 51 x 49 mm 30 m PD180CBT30MU Ordering no. Receiver PD180CBT30Q Specifications Emitter Rated operating dist (Sn) 15 m with jumper not activated 30 m with jumper activated Rated operational volt. (Ue) 2 x ER14505 3.6 VDC size AA ≥2700 mAh Lithium batteries Battery lifetime Jumper not active 15m => 2.5 years Jumper active 30m => 1.5 years Supply current With Mute active (Io) Typ. 29 µA Protection Reverse polarity, transients Specifications are subject to change without notice (25.05.2018) Mute input Normal operation > 6 KΩ Mute < 4 KΩ Light source LED, 850 nm Light spot size @ 15 m setting 1.2 m @ 7.5 m @ 30 m setting 2.4 m @ 15 m Light type Infrared, modulated Optical angle ± 4.1° 1 PD180 Specifications Receiver Rated operating dist. (Sn) Blind zone Temperature drift Hysteresis (H) Rated operational volt. (Ue) AC: 45 Hz - 65 Hz Ripple (Urrp) Output Contact ratings Resistive loads AC 1 DC 1 Mechanical life (typical) Lifetime contacts (typical) AC 1 DC 1 Minimum load power No load supply current (Io) + Battery low alarm 15 or 30 m dependent on emitter settings None ≤ 0.4%/°C 3 - 20% Supply class 2 12 to 24 VDC, -15% +10% 12 to 24 VAC, -15% +10% ≤ 10% AgPd-Au 0.5 A/30 VAC 1 A/30 VDC ≥ 10 000 000 cycles 0.5 A/30 VAC 100 000 1 A/30 VDC 100 000 1 mW ≤ 36 mA DC (relay ON) ≤ 55 mA DC (both relays ON) Ambient light Incandescent light @ 3000 … 3200 °K Incandescent light 3200 °K Fluorescent light Stroboscopic light Flashing beacon light Optical angle Protection Operating frequency (f) Response time OFF-ON (tON) ON-OFF (tOFF) Power ON delay (tv ) Indication function Power ON Output ON ≥ 100 000 lux (EN 60947-5-2) ≥ 10 000 lux* (EN 61496-2) ≥ 3 000 lux* (EN 61496-2) 0.05 J @ 200 Hz to 0.5 J @ 5 Hz* (EN 61496-2) 3 to 5 J @ 0.5 to 2 Hz* (EN 61496-2) ± 4.7° Reverse polarity, transients 25 Hz ≤ 20 ms ≤ 20 ms ≤ 300 ms LED, green LED, yellow * Failure to danger (worst case alignment) General Specifications Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Vibration Drop test Lens adjustment Adjustable optics Rated insulation voltage Housing material Front Backpart Connection Emitter 2 III (IEC 60664/EN 60947-1) 3 (IEC 60664/EN 60947-1) IP 55 (IEC 60529; 60947-1) -25° to +55°C (-13° to +131°F) -25° to +80°C (-13° to +176°F) 10 to 150 Hz, 0.5 mm/7.5 g (EN 60068-2-6) 2 x 1 m & 100 x 0.5 m (IEC 60068-2-31) Horisontal 200° Vertical ±30° 50 VDC PC black PC black Weight Emitter 270 g Receiver 230 g UL-Approval cURus UL325, CSA-C22.2 No.247 CE-marking Yes EN 12453, EN 12978, EN 61496-1, Type 2 ESPE General reference Sensor designed according to EN 60947-5-2 MTTFd related to combined product life time (Rx+Tx) 110 years @ 40°C (+104°F) (EN ISO 13849-1 (Parts count method, annex D.1), SN 29500) ESPE architecture (Cat.) 2 (EN ISO 13849-1) Performance level (PL.) C (EN ISO 13849-1) PFHd 1.04 x 10-6 Errors per hour (EN ISO 13849-1) Mission Time 20 years (EN ISO 13849-1) 2 pole terminal block Receiver 6 pole terminal bock Specifications are subject to change without notice (25.05.2018) PD180 Operation Description • The sensor shall be mounted with the draining hole facing down. • The cable must be mounted pointing downwards to avoid water entering the sensor (See Dimensions). • This product can only be used to detect direct interruption between Tx and Rx; it must not be reflected • The sensors must be mounted on a hard vibration-free surface • In order to obtain an “ESPE type 2” safety device, the sensors must be connected to a control system fittet with “Photo test” or similar sensor verification function. Operation Diagram tv = Power ON delay Emitter supply low battery Power supply (receiver) Target emitter present Object present Mute active < 4 kΩ Make (NO) Output ON Output Battery Dimensions Detection Diagram Sensing range [feet] 50.86 0,0 16,4 32,8 49,2 65,6 82,0 98,4 114,8 6,6 1,500 4,9 1,000 3,3 0,500 1,6 0,000 0,0 -0,500 -1,6 -1,000 -3,3 -1,500 -4,9 38.4 -2,000 0,00 5,00 10,00 15,00 20,00 25,00 30,00 Detection width [feet] 49.3 Detection width [m] 2,000 -6,6 35,00 Sensing range [m] PD180 30m PD180 15m 181 Excess Gain 1000 Excess Gain 100 15 m 30 m 10 1 1 10 100 Distance (m) Specifications are subject to change without notice (25.05.2018) 3 Wiring Diagram Delivery Contents Receiver Emitter 1 2 2 1 12 to 24 VAC/DC 3 Mute input 4 Output 5 6 1A 30 VDC 0.5A 30 VAC • PD180 emitter or receiver (separate box) • Installation instruction in emitter box • Packaging: Cardboard box • 2 x 3 screws for raw plugs ø2.9 x 25 DIN 7981C • 2 x 3 raw plugs for 8 mm hole • 2 x 1 Strain releif • 2 x 2 Screws for strain releif M3 x 12 mm • 2 x 1 Cable gland Battery Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 4 Specifications are subject to change without notice (25.05.2018)
PD180CBT30MU 价格&库存
很抱歉,暂时无法提供与“PD180CBT30MU”相匹配的价格&库存,您可以联系我们找货
PD180CBT30MU
  • 1+587.037261+73.45000
  • 5+547.841245+68.54580
  • 10+514.9671510+64.43260
PD180CBT30MU
  • 1+990.167811+123.88963
  • 5+940.664315+117.69576
  • 10+910.9578710+113.97889
  • 25+881.2566325+110.26268
