PD30CNR06PPDU
PD30CNR06PPDU
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 6M PNP
PD30CNR06PPDU 数据手册
Photoelectrics Retro-reflective Type PD30CNR06....DU • • • • • • • • • • • • Product Description The PD30CNR06 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where highaccuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Miniature sensor range Range: 6 m, with reflector Sensitivity adjustment by Teach-In programming Modulated, infrared light 880 nm Supply voltage: 10 to 30 VDC Output: 100 mA, NPN or PNP preset Make and break switching function programmable LED indication for output, stability and power ON Protection: reverse polarity, short circuit and transients Cable and plug versions Excellent EMC performance Dust alarm output Ordering Key The Teach-In function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is one programmable (NO or NC) and one dust output NO or NC. PD30CNR06PPM5DU Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Dust output Type Selection Housing WxHxD Range Sn Connection Ordering no. NPN Make or break switching Ordering no. PNP Make or break switching 10 x 30 x 20 mm 10 x 30 x 20 mm 6m 6m Cable Plug PD 30 CNR 06 NPDU PD 30 CNR 06 NPM5DU PD 30 CNR 06 PPDU PD 30 CNR 06 PPM5DU Note: Reflectors to be ordered seperately Specifications Rated operating distance (Sn) Up to 6 m, with reflector Ø 80 mm (ER4) 4 m on ER4060 reflector Blind zone 100 mm Sensitivity Adjustable by Teach-In Temperature drift ≤ 0.1%/ºC Hysteresis (H) (differential travel) ≤ 10% 10 to 30 VDC Rated operational volt. (UB ) (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) Dust output current ≤ 20 mA Continuous (Ie) Short-time (I) ≤ 20 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 30 mA @ 24 VDC Minimum operational current (Im) 0.5 mA OFF-state current (Ir ) ≤ 100 µA ≤ 2.4 VDC @ 100 mA Voltage drop (Ud ) Specifications are subject to change without notice (09.12.2008) Protection Light source Light type Sensing angle Ambient light Light spot Operating frequency Response time OFF-ON (tON) ON-OFF (tOFF ) Power ON delay (tv) Output function NPN and PNP NO/NC switching function Output configuration Programming options Output pin 4 black Output Dust alarm output Delay on operate Indication Output ON Signal stability ON and power ON Short-circuit, reverse polarity and transients GaAlAs, LED, 880 nm Infrared, modulated ± 2º 10,000 lux 110 mm @ 1.5 m 1000 Hz ≤ 0.5 ms ≤ 0.5 ms ≤ 300 ms Preset Set up by button NO or NC NO or NC (dust) 20 ms LED, yellow LED, green 1 PD30CNR06....DU Specifications (cont.) Environment Installation category III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) Pollution degree Degree of protection Ambient temperature Operating Storage Vibration -25° to +55°C (-13° to +131°F) -40° to +70°C (-40° to +158°F) 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Shock Rated insulation voltage Housing material Body Front material Connection Cable 500 VAC (rms) ABS PMMA, red PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm M8, 4-pin (CON, 54-series) With cable: 40 g With plug: 10 g Yes cULus (UL508) Plug Weight CE-marking Approvals Operation Diagram tv = Power ON delay ON OFF Power supply Make Output (N.O.) Present Not Present Tv ON OFF Break Output (N.C.) ON OFF Object Tv Wiring Diagrams NPN 1 BN PNP V 1 BN V 4 BK 2 WH* 2 WH* 4 BK 3 BU 3 BU GND *Dust Output *Dust Output GND Excess Gain Detection Diagram 300 100 200 Exess gain (mm) 100 0 10 -100 -200 -300 1 0 2 4 6 (m) 2 8 10 0.1 1 10 Distance (m) Specifications are subject to change without notice (09.12.2008) PD30CNR06....DU Accessories Signal Stability Indication 21.2 14 9° 32.4 1.2 25.4 Excess Gain 9° 26,3 29.3 39 Operation level Operation level x 0.75 3.2 Operation level x 1.25 1.0 0.75 1.2 10 1.25 25.4 3.2 13.5 16.2 6.0 5.7 6.0 5.2 3 Yellow LED ON 4.4 Dust ON 14 4.4 16 10 7.3 Green LED ON 8.2 Time 4.4 Mounting bracket: APD30-MB1 Mounting bracket: APD30-MB2 Dimensions Plug version Cable version 6 20 10.6 6 Teach Button 20 10.6 Teach Button Output LED Yellow Output LED Yellow Power / Stability LED Green 10.6 10.8 1.1 17 Receiver 15 Emitter Two M3 Two, 9.5 dia. Lenses 5.5 5.5 15 22 25.4 Optical axis 5.5 5.5 22 25.4 Two, 9.5 dia. Lenses 30 1.1 Receiver Optical axis 30 10.6 10.8 17 Power / Stability LED Green Emitter Two M3 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • • • • • Reflector is to be purchased seperately • Mounting bracket APD30-MB2 to be purchased seperately Photoelectric switch: PD 30 CNR 06 ... Installation instruction Mountingbracket APD30-MB1 Packaging: Cardboard box Specifications are subject to change without notice (09.12.2008) 3 PD30CNR06....DU Teach functions Normal operation, optimized switching point. Line up the sensor with the reflector. Yellow LED and 1. Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object between the sensor and reflector in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 1 4 3 sec. 2 2 1 2 Push once 4 Push once For dust output (N.O. or N.C.) 1. Press the button for 15 seconds, until the yellow LEDs flashes. 2. While the yellow LED flashes, the dust output is inverted each time the button is pressed. Green LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 3 15 sec. 3 sec. One cycle 3 For minimum detection overhead. 1. Line up the sensor with the reflector. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 3 For make or break set-up (N.O. or N.C.) 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 10 sec. 3 sec. 2 3 sec. Push once For maximum sensing distance (default setting) 1. Line up the sensor with the reflector, place the object between the sensor and reflector in the detection zone. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 For dynamic set-up (running process) Line up the sensor with the reflector. Green LED is ON, 1. status on the yellow LED is not important. 2. Press the button for 3 second until both LEDs flashes simultaneously. Press the button a second time for at least one 3. second, both LED’s flashes fast siultainiously and keep the button pressed for at least one process cycle, release the button and the sensor is ready to operate (The second switch point is stored) Push once Push once Specifications are subject to change without notice (09.12.2008)
PD30CNR06PPDU 价格&库存
很抱歉,暂时无法提供与“PD30CNR06PPDU”相匹配的价格&库存,您可以联系我们找货
PD30CNR06PPDU
  • 2+568.47057
  • 4+557.99976
  • 5+526.38179
库存:10
