WTS16P-2416112BA00
WTS16P-2416112BA00
    SICK
    SENSOR PROXIMITY 750MM NPN/PNP
WTS16P-2416112BA00 数据手册
Online data sheet WTS16P-2416112BA00 W16 SMALL PHOTOELECTRIC SENSORS WTS16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTS16P-2416112BA00 1220299 Other models and accessories www.sick.com/W16 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric proximity sensor, TwinEye technology, Background suppression Dimensions (W x H x D) 20 mm x 55.7 mm x 42 mm Housing design (light emission) Rectangular Sensing range max. 10 mm ... 750 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 8 mm (300 mm) Wave length 635 nm Adjustment BluePilot: Teach-Turn adjustment with sensing range indicator, IO-Link, Bluetooth Pin 2 configuration External input, Teach-in, switching signal Special applications Detecting uneven, shiny objects 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WTS16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ≤ 5 Vpp Power consumption 30 mA, 50 mA 2) 3) Switching output PUSH/PULL, PNP, NPN Output: QL1 / C Switching output or IO-Link mode Output function Factory setting: Pin 2 / white (MF): NPN normally open (light switching), PNP normally closed (dark switching), Pin 4 / black (QL1 / C): NPN normally closed (dark switching), PNP normally open (light switching), IO-Link Switching mode Light/dark switching Signal voltage PNP HIGH/LOW Approx. VS – 2.5 V / 0 V Signal voltage NPN HIGH/LOW Approx. VS / < 2.5 V Output current Imax. ≤ 100 mA Response time ≤ 1.4 ms 4) Switching frequency 350 Hz 5) Connection type Male connector M12, 4-pin Circuit protection A, B, C, D 6) 7) 8) 9) Protection class III Weight 50 g IO-Link ✔ Housing material Plastic, VISTAL® Optics material Plastic, PMMA Enclosure rating IP66 (According to EN 60529) IP67 (According to EN 60529) IP69 (According to EN 60529) 10) Ambient operating temperature –40 °C ... +60 °C Ambient storage temperature –40 °C ... +75 °C UL File No. NRKH.E181493 & NRKH7.E181493 1) 2) 3) 4) 5) 6) 7) 8) 9)  Limit values.  16 V DC ... 30 V DC, without load.  10 V DC ... 16 V DC, without load.  Signal transit time with resistive load in switching mode. Different values possible in COM2 mode.  With light/dark ratio 1:1 in switching mode. Different values possible in IO-Link mode.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected. 10)  Replaces IP69K with ISO 20653: 2013-03. Safety-related parameters MTTFD 378 years DCavg 0% Classifications ECl@ss 5.0 27270904 ECl@ss 5.1.4 27270904 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 WTS16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 6.0 27270904 ECl@ss 6.2 27270904 ECl@ss 7.0 27270904 ECl@ss 8.0 27270904 ECl@ss 8.1 27270904 ECl@ss 9.0 27270904 ETIM 5.0 EC002719 ETIM 6.0 EC002719 UNSPSC 16.0901 39121528 Smart Task Smart Task name Base logics Logic function Direct AND OR Window Hysteresis Timer function Deactivated On delay Off delay ON and OFF delay Impulse (one shot) Inverter Yes Switching frequency SIO Direct: 350 HzSIO Logic: 300 HzIOL: 280 Hz 1) 2) 3) Response time SIO Direct: 1.4 msSIO Logic: 1.65 msIOL: 1.75 ms 1) 2) 3) Repeatability SIO Direct: 750 µsSIO Logic: 800 µsIOL: 900 µs 1) 2) 3) Switching signal QL1 Switching output Switching signal QL2 Switching output 1)  SIO Direct: sensor operation in standard I/O mode without IO-Link communication and without using internal sensor logic or time parameters (set to "direct"/"deactivated"). 2) 3)  SIO Logic: Sensor operation in standard I/O mode without IO-Link communication. Sensor-internal logic or timing parameters plus Automation Functions used.  IOL: Sensor operation with full IO-Link communication and usage of logic, timing and Automation Function parameters. Communication interface Communication interface IO-Link V1.1 Bluetooth Communication Interface detail COM2 (38,4 kBaud) Cycle time 2.3 ms Process data length 16 Bit Process data structure Bit 0 = switching signal QL1 Bit 1 = switching signal QL2 Bit 2 ... 15 = empty VendorID 26 DeviceID HEX 0x8001B5 DeviceID DEZ 8389045 4 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WTS16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS Connection diagram Cd-390 1 BN WH 2 BU 3 BK 4 + (L+) MF – (M) QL1/C Characteristic curve WTS16P-xxxxx1xx Minimum distance in mm (y) between the set sensing range and background (white, 90%) y 90 WTS16P-xxxxx1xx 18%/90% 80 1 white background (90%) 2 6%/90% 70 3 90%/90% x 60 y Example: Sensing range on black, 6%, x = 300 mm, y = 20 mm 50 40 30 20 10 x 0 0 200 400 600 800 1,000 (7.87) (15.75) (23.62) (31.5) (39.37) Distance in mm (inch) ①  Sensing range on black, 6% remission ②  Sensing range on gray, 18 % remission ③  Sensing range on white, 90% remission Light spot size WTS16P-xxxxx1xx mm (inch) 12 (0.47) 8 (0.31) 4 (0.16) 0 –4 (–0.16) –8 (–0.31) –12 (–0.47) 0 200 400 600 800 (7.87) (15.75) (23.62) (31.5) Distance in mm (inch) 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 WTS16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F Sensing range diagram WTS16P-xxxxx1xx 1 2 3 15 100 10 100 400 500 10 100 0 100 200 750 400 (3.94)(7.87) (15.75) 800 1,000 1,500 (31.5) (39.37) (59.06) Distance in mm (inch) A Adjustment range BluePilot: Sensing range indicator (blue LED) Teach-Turn adjustment A = Detection distance (depending on object remission) ①  Sensing range on black, 6% remission ②  Sensing range on gray, 18 % remission ③  Sensing range on white, 90% remission Dimensional drawing (Dimensions in mm (inch)) 18 2 17.5 29.9 (0.18) 52.9 (2.08) 6 (0.24) 3 7 (0.28) 1 55.7 (2.19) 45.5 (1.79) 5 (0.2) 12.2 (0.48) 24.2 (0.95) 12.2 (0.48) 2 M12 (0.24) 6.5 (0.26) 3 (0.12) 15 (0.59) 4 7.5 (0.3) Ø 4.1 (0.16) 39.9 (1.57) 55.4 (2.18) 42 (1.65) 4.1 (0.16) 20 (0.79) (0.71) H I J K L M N O P Q R S T WTS16, connector 28 (1.1) 35.5 (1.4) 5 16 (0.63) 678 ①  Center of optical axis, sender ②  Center of optical axis, receiver ③  Mounting hole, Ø 4.1 mm ④  Connection ⑤  LED indicator green: power ⑥  LED indicator yellow: Status of received light beam ⑦  Teach-Turn adjustment of sensing range ⑧  BluePilot blue: sensing range indicator 6 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WTS16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS Recommended accessories Other models and accessories www.sick.com/W16 Brief description Type Part no. BEF-KHS-N02 2051608 YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Universal bar clamp systems Plate N02 for universal clamp bracket, Zinc plated steel (sheet), Zinc die cast (clamping bracket), Universal clamp (5322626), mounting hardware Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
WTS16P-2416112BA00 价格&库存
很抱歉,暂时无法提供与“WTS16P-2416112BA00”相匹配的价格&库存,您可以联系我们找货
