MP2S11HD
MP2S11HD
    PEPPERL+FUCHS(倍加福)
    PHOTO SEN MP SERIES BASE UNIT
MP2S11HD 数据手册
Photoelectric Sensors • Harsh Duty • Modular design - Exchangeable rotatable heads - Limit switch and mini style plug-in bases - Screw terminal, preleaded, and connector version receptacles • Withstands 1200 psi washdown, IP69K MP Series modular sensors enable users to customize a sensing solution for almost any application. For this reason, the components of this series are sold separately. Refer to pages 594-595 for instruction on how to assemble an MP Series sensor. • 6 A SPDT and 5 A DPDT relay models • Multifunction timer/logic cards available • DC, AC, AC/DC models Diffuse Mode Photoelectric MP Series Modular Modular Photoelectric Sensors MP Series Retro-Reflective Mode Sensing Ranges: 3  00 mm, 450 mm, 760 mm, 900 mm, 1.3 m, 1.8 m, 3 m Features: • Polarization filter to detect shiny objects Outputs: Dependent on base selected Sensing Ranges: 4.5 m, 6 m, 9 m Outputs: Dependent on base selected Thru-Beam Mode Fiber Optic Mode Sensing Ranges: 36 m, 60 m Sensing Ranges: Dependent on fibers selected Outputs: Dependent on base selected Outputs: Dependent on base selected See page 610-620 for MP Series sensing charateristics, wiring, dimensions and accessories. Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 593 1. BUILD AN MP SENSOR Photoelectric MP Series Modular 1 SELECT A HEAD 2 Head 3 Plug-in/DPDT Relay Base SPDT Relay Base Mini Style Base STANDARD HEADS (pages 596-597) Receptacle Models Diffuse: 450 mm range, 1 ms response, plastic lens, infrared Diffuse: 3 m range, 10 ms response, glass lens, infrared Diffuse: 3 m range, 10 ms response, plastic lens, infrared Diffuse: 900 mm range, 10 ms response, plastic lens, infrared Diffuse: 1.3 m range, 10 ms response, plastic lens, infrared MPD6HD MPD1HD MPD2HD MPD4HD MPD8HD Polarized Retro-Reflective: 4.5 m range, 1 ms response, glass lens, visible red Polarized Retro-Reflective: 6 m range, 10 ms response, glass lens, visible red Retro-Reflective: 9 m range, 1 ms response, glass lens, infrared Retro-Reflective: 9 m range, 1 ms response, plastic lens, infrared Retro-Reflective: 9 m range, 10 ms response, glass lens, infrared Retro-Reflective: 9 m range, 10 ms response, plastic lens, infrared MPP6HD MPP1HD MPL16HD MPL6HD MPL1HD MPL2HD Thru-Beam: 60 m range, transmitter, glass lens, infrared Thru-Beam: 60 m range, transmitter, plastic lens, infrared Thru-Beam: 60 m range, receiver, 1 ms response, glass lens, infrared Thru-Beam: 60 m range, receiver, 1 ms response, plastic lens, infrared Thru-Beam: 60 m range, receiver, 10 ms response, glass lens, infrared MPE1HD MPE2HD MPR16HD MPR6HD MPR1HD MPF Fiber Optic: 1 ms response, infrared MPF Fiber Optic: 5 ms response, visible red MPG Fiber Optic: 1 ms response, infrared MPF6HD MPF2HD MPG6HD ANALOG HEADS (page 598) Models MPF5HD MPF Fiber Optic: infrared 2-WIRE AC HEADS (pages 598-600) 594 Models Diffuse: 300 mm range, plastic lens, infrared Diffuse: 760 mm range, plastic lens, infrared Diffuse: 1.8 m range, glass lens, infrared Diffuse: 1.8 m range, plastic lens, infrared MP2D7HD MP2D4HD MP2D1HD MP2D2HD Polarized Retroreflective: 4.5 m range, glass lens, visible red Retroreflective: 9 m range, glass lens, infrared Retroreflective: 9 m range, plastic lens, infrared MP2P1HD MP2L1HD MP2L2HD Thru-Beam: 36 m range, transmitter, glass lens, infrared Thru-Beam: 36 m range, transmitter, plastic lens, infrared Thru-Beam: 36 m range, receiver, plastic lens, infrared MPE3HD MPE4HD MP2R2HD MPF Fiber Optic: infrared MP2F1HD MPF Fiber Optic: visible red MP2F2HD Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2. 3. SELECT A BASE SELECT A RECEPTACLE DC AC DPDT RELAY BASE (page 603) RELAY Model MPSD11HD DPDT, 92-132 VAC, 5 A, output indicator SPDT RELAY BASES (page 604) DC SPDT RELAY AC MINI STYLE BASES (pages 605-607) MINI RELAY AC 10-30 VDC, 2 m preleaded cable, emitter base only 10-30 VDC, NPN N.O., 2 m preleaded cable 10-30 VDC, PNP N.O., 2 m preleaded cable 10-30 VDC, NPN and PNP, N.O., 2 m preleaded cable 92-132VAC, 2m preleaded cable, emitter base only 92-132 VAC, 4-wire bilateral FET (AC/DC), 100 mA max., 2 m preleaded cable 92-132 VAC, 4-wire solid state AC relay, 0.5 A max., 2 m preleaded cable 22-26 VAC/VDC, 4-wire bilateral FET, 100 mA max., 2 m preleaded cable 10-30 VDC, NPN N.O., 4-pin micro connector 10-30 VDC, PNP N.O., 4-pin micro connector 10-30 VDC, NPN and PNP, N.O., 4-pin micro connector 10-30 VDC, 4-pin micro connector, emitter base only 10-30 VDC, NPN and PNP, 4-pin mini connector 10-30 VDC, NPN N.O., 4-pin mini connector 10-30 VDC, PNP N.O., 4-pin mini connector 92-132 VAC, 3-pin mini connector, emitter base only 92-132 VAC, 4-wire solid state AC relay, 0.5 A max., 5-pin mini connector 92-132 VAC, 4-wire bilateral FET (AC/DC), 100 mA max., 5-pin mini connector 10.8-140 VDC/18-140 VAC, 4-wire FET w/output ind., 5-pin mini connector 92-132 VAC, 6 A, SPDT relay, 2 m preleaded cable 92-132 VAC, 6 A, SPDT relay, 5-pin mini connector ANALOG 12-24 VDC analog output (0-5 VDC or 4-20 mA) 3-WIRE DC 4-WIRE AC AC/DC MICRO CONNECT. DC MINI CONNECT. DC MINI CONNECT. AC MINI AC/DC s s s s s s s s m m m m l l l l l l l s l MPB20 l m MPB22 MPB27 DPDT RECEPTACLE Models MPB23 MPB24 NO RECEPTACLE NEEDED ELECTRICAL CONNECTION KEY MPT30HD MPT31HD MPT32HD MPT33HD MPT10HD MPT17HD MPT11HD MPT16HD MPT41HD-CM MPT42HD-CM MPT43HD-CM MPT40HD-CM MPT43HD MPT41HD MPT42HD MPT20HD MPT21HD MPT27HD MPT28HD MPW11HD MPW21HD ■ l m s Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Terminal connectors Mini connectors Micro connectors Preleaded cable NO RECEPTACLE NEEDED Model Models RECEPTACLE Standard 4-terminal, 1/2” NPT conduit thread 5-pin mini connector MPS30HD MPS10HD MPS13HD MPS14HD MP2S11HD 10-30 VDC emitter base only 92-132 VAC emitter base only 198-264 VAC emitter base only 22-26 VAC/VDC emitter base only 22-260 VAC plug-in base Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com MPV31HD MPV11HD MPV12HD MPV14HD MPV13HD MPS35HD 2-WIRE PLUG-IN BASES (page 609) 2-WIRE AC ■ 8-terminal, 1/2” NPT conduit hole ■ 8-terminal, 3/4” NPT conduit hole ■ Models ANALOG PLUG-IN BASE (page 608) DC Models Models ■ ■ ■ ■ ■ SPDT, 10-30 VDC, 6 A SPDT, 103-132 VAC, 6 A SPDT, 192-264 VAC, 6 A SPDT, 20-260 VAC/VDC, 6 A SPDT, 22-26 VAC, 6 A RECEPTACLE Standard 4-terminal, 1/2” NPT conduit thread 5-pin mini connector 4-pin micro connector Photoelectric MP Series Modular AC Models MPS18HD MPS30HD MPS33HD MPS31HD MPS32HD MPS12HD MPS13HD MPS17HD MPS11HD MPS10HD 10.8-140 VDC/18-140 VAC 4-wire FET w/output indicator 10-30 VDC emitter base only 10-30 VDC NPN and PNP, 4-wire DC 10-30 VDC NPN N.O./N.C., 4-wire DC 10-30 VDC PNP, 3-wire DC 198-264 VAC 4-wire solid state AC relay 1 A max. 198-264 VAC emitter base only 92-132 VAC 4-wire bilateral FET (AC/DC) 100 mA max. 92-132 VAC 4-wire solid state AC relay 1 A max. 92-132 VAC emitter base only PLUG-IN BASES (pages 602-603) AC/DC Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Models ■ MPB20 l MPB22 Stocked item Typical delivery 4 weeks or less Consult factory for all other models 595 Photoelectric Sensors STANDARD HEADS Photoelectric MP Series Modular Diffuse Mode Specifications Infrared 450 mm SENSING RANGE SENSITIVITY ADJUSTMENT MODEL NUMBER(S) RESPONSE TIME* HOUSING MATERIAL LENS 900 mm Yes Yes Yes Yes MPD4HD MPD8HD MPD1HD — — — MPD2HD ≤ 1 ms ≤ 10 ms ≤ 10 ms ≤ 10 ms Polycarbonate Polycarbonate Polycarbonate Polycarbonate Plastic Plastic Plastic Glass (1HD)/plastic (2HD) See page 601 *NOTE: Total response time is the sum of the sensor head and base response times. Retro-Reflective Mode Specifications Visible Red Infrared 4.5 m 6m 9m 9m SENSITIVITY ADJUSTMENT Yes Yes Yes Yes POLARIZED FILTER Yes Yes No No MODEL NUMBER(S) MPP6HD MPP1HD MPL1HD MPL16HD — — MPL2HD MPL6HD RESPONSE TIME* HOUSING MATERIAL LENS ≤ 1 ms ≤ 10 ms ≤ 10 ms ≤ 1 ms Polycarbonate Polycarbonate Polycarbonate Polycarbonate Glass Glass Glass (1HD)/plastic (2HD) Glass (16HD)/plastic (6HD) See page 601 ADDITIONAL DATA 3m MPD6HD ADDITIONAL DATA SENSING RANGE 596 1.3 m *NOTE: Total response time is the sum of the sensor head and base response times. Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors STANDARD HEADS Thru-Beam Mode Infrared 60 m SENSING RANGE SENSITIVITY ADJUSTMENT MODEL NUMBER(S) 60 m 60 m Yes Yes Yes Transmitter MPE1HD MPE1HD MPE2HD Receiver MPR1HD MPR16HD MPR6HD ≤ 10 ms ≤ 1 ms ≤ 1 ms Polycarbonate Polycarbonate Polycarbonate Glass Glass Plastic RESPONSE TIME* HOUSING MATERIAL LENS See page 601 ADDITIONAL DATA *NOTE: Total response time is the sum of the sensor head and base response times. Fiber Optic Mode Specifications SENSING RANGE Visible Red Infrared Determined by cable † SENSITIVITY ADJUSTMENT MODEL NUMBER(S) RESPONSE TIME* HOUSING MATERIAL Determined by cable† Yes Yes MPF2HD MPF6HD — MPG6HD ≤ 5 ms ≤ 1 ms Polycarbonate Photoelectric MP Series Modular Specifications Polycarbonate See page 601 ADDITIONAL DATA *NOTE: Total response time is the sum of the sensor head and base response times.  ee pages 761-796 for S fiber optic lengths and specifications. † Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 597 Photoelectric Sensors ANALOG HEADS Photoelectric MP Series Modular Fiber Optic Mode Specifications Infrared Determined by cable† SENSING RANGE SENSITIVITY ADJUSTMENT Yes MODEL NUMBER(S) MPF5HD RESPONSE TIME ≤ 10 ms HOUSING MATERIAL Polycarbonate See page 601 ADDITIONAL DATA 2-WIRE AC HEADS Diffuse Mode Specifications Infrared 300 mm SENSING RANGE SENSITIVITY ADJUSTMENT MODEL NUMBER(S) RESPONSE TIME*  ee pages 761-796 for S fiber optic lengths and specifications. † HOUSING MATERIAL LENS 760 mm 1.8 m Yes Yes Yes MP2D7HD MP2D4HD MP2D1HD — — MP2D2HD ≤ 10 ms ≤ 15 ms ≤ 15 ms Polycarbonate Polycarbonate Polycarbonate Plastic Plastic Glass (1HD)/plastic (2HD) ADDITIONAL DATA See page 601 *NOTE: Total response time is the sum of the sensor head and base response times. 598 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors 2-WIRE AC HEADS Retro-Reflective Mode Visible Red Infrared 4.5 m 9m SENSITIVITY ADJUSTMENT Yes Yes POLARIZED FILTER Yes No MODEL NUMBER(S) MP2P1HD MP2L1HD — MP2L2HD SENSING RANGE RESPONSE TIME* HOUSING MATERIAL LENS ≤ 10 ms ≤ 10 ms Polycarbonate Polycarbonate Glass Glass (1HD)/plastic (2HD) See page 601 ADDITIONAL DATA *NOTE: Total response time is the sum of the sensor head and base response times. Thru-Beam Mode Specifications SENSING RANGE Infrared 36 m SENSITIVITY ADJUSTMENT MODEL NUMBER(S) Transmitter Receiver Yes MPE3HD MPE4HD MP2R2HD ≤ 10 ms RESPONSE TIME* HOUSING MATERIAL Polycarbonate LENS ADDITIONAL DATA Photoelectric MP Series Modular Specifications Glass (3HD) Plastic (4HD/2HD) See page 601 *NOTE: Total response time is the sum of the sensor head and base response times. Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 599 Photoelectric Sensors 2-WIRE AC HEADS Specifications SENSING RANGE Visible Red Determined by cable Determined by cable† Yes Yes MP2F2HD MP2F1HD ≤1 ms ≤1 ms Polycarbonate Polycarbonate SENSITIVITY ADJUSTMENT MODEL NUMBER(S) RESPONSE TIME* HOUSING MATERIAL Infrared † ADDITIONAL DATA See page 601 *NOTE: Total response time is the sum of the sensor head and base response times.  ee pages 761-796 for S fiber optic lengths and specifications. † Photoelectric MP Series Modular Fiber Optic Mode 600 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors MP Series Head Specifications MP Series Head Specifications Yes (2) SENSING CHARACTERISTICS Pages 610-612 WIRING DIAGRAMS Pages 613-614 OPERATING MODE Light on/dark on DIMENSIONS Page 615 PROTECTION (IEC) IP69K when all components are properly assembled ACCESSORIES Pages 616-619 TEMPERATURE RANGE WORKING -22 ºF to +158 ºF STORAGE -67 ºF to +185 ºF HUMIDITY RANGE 95% RH (non-condensing) VIBRATION 10 G,10-500 Hz SHOCK 50 G HEAD HOUSING Glass-filled polycarbonate ACCESS COVER Glass-filled acetal, Type 20 SEALS Santoprene STANDARDS EN 60947-5-2 APPROVALS Operating/Adjustment Of All Heads Sensitivity Adjustment Photoelectric MP Series Modular LED(s) Reference Guide Sensitivity Adjustment Alignment Indicators Use a small blade screwdriver to open the cover on top of the sensor head. This exposes the sensitivity adjustment screw, labeled “S”. The 15-turn sensitivity potentiometer will normally click at both extremes of the sensitivity range. - Turn the screw clockwise to increase the sensitivity. - Turn the screw counterclockwise to decrease sensitivity. - Snap the cover closed and fasten with a screw. Light On/Dark On Mode Selector Switch Fiber Optic Head Options Every MP Series photoelectric sensor head has a light on/dark on selector switch located on the PC board inside the sensor head. The operating mode should be set prior to assembling the head to its respective base. Fiber optic heads are furnished in two cable connection styles, MPF and MPG, as designated by the first three letters in their catalog listings. Dark On - The output (load) is energized when the light is blocked (retro and thru scan), or object absent (diffuse scan); the photosensor is dark. Light On - The output (load) is energized when the light is not blocked (retro and thru scan), or object is present (diffuse scan); the photosensor is illuminated. Alignment Indicators Two LED indicators are located on top of the sensor head. Sufficient light level turns the green light ON. When the light level decreases to 150% of the minimum operating level, the red light turns ON. Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com MPF fiber optic sensor heads use dual slot glass cables and are part of the original MP product line. The sensor head has a dual slot end tip bezel connection on the sensor head which maintains compatibility with FE-MLS8C-FO sensors. With the MPZFOADPT adapter, the MPF heads can accept plastic cables too. MPG fiber optic sensor heads use universal style glass cables. MPG heads accept the same universal style cables used with our MHP miniature high performance sensors and furnished by many manufacturers of photoelectric products. They cannot be used with plastic cables. Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 601 Photoelectric Sensors Photoelectric MP Series Modular PLUG-IN BASE Specifications DC MODEL NUMBER(S) AC AC/DC † MPS30HD MPS10HD MPS18HD MPS31HD MPS11HD — † MPS32HD MPS12HD — MPS33HD MPS13HD† — — MPS17HD — OUTPUT 1 NPN (31HD) 1 PNP (32HD) 1 NPN and 1 PNP (33HD) Solid state relay (11HD/12HD) Thyristor (17HD) Thyristor LOAD CURRENT 250 mA max. (31HD/32D) 100 mA max. (33HD) 5 mA-1 A (11HD/12HD) 100 mA max. (17HD) 100 mA max. ≤ 10 µA ≤ 200 µA (11HD) ≤ 240 µA (12HD) ≤ 10 µA (17HD) ≤ 10 µA — 30 A for 8 ms (11HD/12HD) 250 mA for 8 ms (17HD) 250 mA for 8 ms, (non-repetitive) ≤ 1.0 VDC (31HD/32HD) ≤ 0.8 VDC (33HD) ≤ 1.4 VAC at rated load (11HD/12HD) ≤ 3 V at 60 mA (17HD) ≤ 5 VDC (DC operation) ≤ 10 µs ≤ 10 ms (11HD/12HD) ≤ 2 ms (17HD) ≤ 2 ms No (30HD/31HD/32HD) Yes (33HD) No No LEAKAGE CURRENT INRUSH CURRENT VOLTAGE DROP RESPONSE TIME* SHORT CIRCUIT AND OVERLOAD PROTECTION REVERSE POLARITY PROTECTION SUPPLY VOLTAGE Yes No No 10-30 VDC 92-132 VAC, 50/60 Hz (10HD/11H/17HD) 198-264 VAC, 50/60 Hz (12HD/13HD) 10.8-140 VDC 18-140 VAC, 50/60 Hz CURRENT CONSUMPTION ≤ 25 mA ≤ 70 mA ≤ 50 mA ELECTRICAL CONNECTION Dependent on receptacle selection Dependent on receptacle selection Dependent on receptacle selection See page 603 ADDITIONAL DATA *NOTE: Total response time is the sum of the sensor head and base response times. NOTE: Emitter base only. † 602 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors DPDT RELAY BASE Plug-in Base Specifications Specifications AC TEMPERATURE RANGE WORKING -22 ºF to +158 ºF MODEL NUMBER MPSD11HD STORAGE -67 ºF to +185 ºF SUPPLY VOLTAGE 92-132 VAC, 50/60 Hz SHOCK 50 G VIBRATION 10 G,10-500 Hz HUMIDITY RANGE 95% RH (non-condensing) HEAD/BASE SEAL Santoprene RECEPTACLE/BASE SEAL PROTECTION (IEC) HOUSING MATERIAL OUTPUT DPDT relay ELECTRICAL CONTACT RATING 250 VAC/5 A ≤ 6.6 VA POWER CONSUMPTION MECHANICAL LIFE OF RELAY 5 x 107 operations Buna-N RESPONSE TIME* ≤ 10 ms IP69K when all components are properly assembled PROTECTION (IEC) IP69K when all components are properly assembled Glass-filled Polysulfone STANDARDS EN 60947-5-2 APPROVALS TEMPERATURE RANGE WORKING -22 ºF to 158 ºF STORAGE -67 ºF to 185 ºF SHOCK 10G VIBRATION 6 G, 10-55 Hz @ double amplitude of 1 mm HUMIDITY 95% RH (non-condensing) HOUSING MATERIAL Glass-filled Polysulfone STANDARDS EN 60947-5-2 APPROVALS ELECTRICAL CONNECTION MPB20 Standard 4-terminal, 1/2” NPT conduit thread MPB22 5-pin mini connector MPB27 4-pin micro connector Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com dependent on receptacle selection *NOTE: Total response time is the sum of the sensor head and base response times. RECEPTACLE MODELS See pages 803-854 for cordsets Photoelectric MP Series Modular PLUG-IN BASE DPDT RECEPTACLE MODELS MPB23 8-terminal, 1/2” NPT conduit thread MPB24 8-terminal, PG 13.5 conduit thread Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 603 Photoelectric MP Series Modular Photoelectric Sensors SPDT RELAY BASE Specifications MODEL NUMBER(S) OUTPUT DC AC MPV31HD MPV11HD — MPV12HD — MPV13HD — MPV14HD SPDT relay SPDT relay 10-30 VDC 103-132 VAC, 50/60 Hz (11HD) 192-264 VAC, 50/60 Hz (12HD) 22-26 VAC, 50/60 Hz (13HD) 20-260 VAC/DC (14HD) ≤ 10 VA ≤ 10 VA (11HD) ≤ 18.5 VA (12HD) ≤ 2 VA (13HD) ≤ 4 VA (14HD) DC 28 V/6 A 24 V/6 A AC 300 V/6 A 300 V/ 6A 5-terminal 1/2” conduit hole 5-terminal 1/2” conduit hole SUPPLY VOLTAGE POWER CONSUMPTION ELECTRICAL CONTACT RATING ELECTRICAL CONNECTION SPDT Relay Base Specifications MECHANICAL LIFE OF RELAY 20 x 106 operations ≤ 10 ms RESPONSE TIME* TEMPERATURE RANGE WORKING -22 ºF to +158 ºF STORAGE PROTECTION (IEC) -67 ºF to +185 ºF IP69K when all components are properly assembled SHOCK 10 G VIBRATION 10 G,10-100 Hz HUMIDITY RANGE 95% RH (non-condensing) BASE Glass-filled polycarbonate COVER/BASE SEAL Buna-N HEAD/BASE SEAL Santoprene COVER Die cast zinc STANDARDS EN 60947-5-2 APPROVALS *NOTE: Total response time is the sum of the sensor head and base response times. 604 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Specifications DC MODEL NUMBER(S) AC MPT30HD AC/DC † MPT10HD MPT16HD MPT31HD MPT11HD — MPT32HD — — MPT33HD MPT17HD — OUTPUT 1 NPN (31HD) 1 PNP (32HD) 1 NPN and 1 PNP (33HD) Solid state relay (11HD) Thyristor (17HD) Thyristor LOAD CURRENT 250 mA max. (31HD/32D) 100 mA max. (33HD) 5 mA-500 mA (11HD) 100 mA max. (17HD) 100 mA max. ≤ 10 µA ≤ 400 µA (11HD) ≤ 10 µA (17HD) ≤ 10 µA — 12 A for 16 ms (11HD) 250 mA for 8 ms (17HD) 250 mA for 8 ms, (non-repetitive) ≤ 1 VDC (32HD/31HD) ≤ 0.6 VDC (33HD) ≤ 1.2 VAC at rated (11HD) ≤ 3 V (17HD) ≤ 3 V (DC operation) ≤ 10 µs ≤ 10 ms (11HD) ≤ 2 ms (17HD) ≤ 2 ms No (30HD/31HD/32HD) Yes (33HD) No No No No No 10-30 VDC 92-132 VAC, 50/60 Hz (10HD/11H/17HD) 198-264 VAC, 50/60 Hz (12HD/13HD) 24 VAC, 50/60 Hz (14HD) 24 VAC/VDC ≤ 25 mA ≤ 70 mA ≤ 70 mA LEAKAGE CURRENT INRUSH CURRENT VOLTAGE DROP RESPONSE TIME* SHORT CIRCUIT AND OVERLOAD PROTECTION REVERSE POLARITY PROTECTION SUPPLY VOLTAGE CURRENT CONSUMPTION ELECTRICAL CONNECTION † 2-meter cable, PVC covered, 4-conductor, #18 AWG 2-meter cable, PVC covered, 4-conductor, #18 AWG Photoelectric MP Series Modular MINI STYLE BASE 2-meter cable, PVC covered, 4-conductor, #18 AWG See page 607 ADDITIONAL DATA *NOTE: Total response time is the sum of the sensor head and base response times. NOTE: Emitter base only. † Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 605 Photoelectric Sensors Photoelectric MP Series Modular MINI STYLE BASE Specifications MODEL NUMBER(S) DC DC AC AC/DC — † MPT40HD-CM MPT20HD MPT28HD MPT41HD MPT41HD-CM MPT21HD — MPT42HD MPT42HD-CM MPT27HD — MPT43HD MPT43HD-CM — — OUTPUT 1 NPN (41HD) 1 PNP (42HD) 1 NPN and 1 PNP (43HD) 1 NPN (41HD) 1 PNP (42HD) 1 NPN and 1 PNP (43HD) Solid state relay (21HD) Thyristor (27HD) Thyristor LOAD CURRENT 250 mA max. (41HD/42D) 100 mA max. (43HD) 250 mA max. (41HD/42D) 100 mA max. (43HD) 500 mA max. (21HD) 100 mA max. (27HD) 100 mA max. ≤ 10 µA ≤ 10 µA ≤ 400 µA (21HD) ≤ 10 µA (27HD) ≤ 10 µA — — 12 A for 16 ms (21HD/22HD) 250 mA for 8 ms (27HD) 250 mA for 8 ms (non-repetitive) ≤ 1 VDC (42HD/41HD) ≤ 0.6 VDC (43HD) ≤ 1 VDC (42HD/41HD) ≤ 0.6 VDC (43HD) ≤ 1.2 VAC (21HD) ≤ 3 V (27HD) ≤ 5 V (DC operation) ≤ 10 µs ≤ 10 µs ≤ 10 ms (21HD) ≤ 2 ms (27HD) ≤ 2 ms No (40HD/41HD/42HD) Yes (43HD) No (40HD/41HD/42HD) Yes (43HD) No No Yes Yes No No 10-30 VDC 10-30 VDC 92-132 VAC, 50/60 Hz 10.8-140 VDC 18-140 VAC, 50/60 Hz ≤ 25 mA ≤ 25 mA ≤ 70 mA ≤ 70 mA LEAKAGE CURRENT INRUSH CURRENT VOLTAGE DROP RESPONSE TIME* SHORT CIRCUIT AND OVERLOAD PROTECTION REVERSE POLARITY PROTECTION SUPPLY VOLTAGE CURRENT CONSUMPTION ELECTRICAL CONNECTION Quick disconnect type V94 † Quick disconnect type V93 (20HD) type V95 (21HD/27HD) Quick disconnect type V1 See page 607 ADDITIONAL DATA *NOTE: Total response time is the sum of the sensor head and base response times. NOTE: Emitter base only. † 606 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Quick disconnect type V95 Photoelectric Sensors MINI RELAY BASE Mini Style Base Specifications Specifications AC TEMPERATURE RANGE WORKING -22 ºF to +158 ºF STORAGE -67 ºF to +185 ºF SHOCK VIBRATION MODEL NUMBER(S) MPW11HD MPW21HD 50 G 10 G,10-500 Hz SUPPLY VOLTAGE 92-132 VAC, 50/60 Hz HUMIDITY RANGE 95% RH (non-condensing) POWER CONSUMPTION BASE Glass-filled polycarbonate OUTPUT BASE SEAL PROTECTION (IEC) STANDARDS HOUSING MATERIAL Santoprene IP69K when all components are properly assembled EN 60947-5-2 Glass-filled Polysulfone APPROVALS ≤ 10 VA (including load) SPDT relay ELECTRICAL CONTACT RATING DC 30 V/6 A AC 125 V/6 A MECHANICAL LIFE OF RELAY 50 x 106 operations RESPONSE TIME* 10 ms PROTECTION (IEC) IP69K when all components are properly assembled TEMPERATURE RANGE WORKING STORAGE SHOCK -22 ºF to 158º F -67 ºF to 185 ºF 20 G (no contact transfer) 100 G (no damage) VIBRATION 10 G, 10-500 Hz HUMIDITY 95% RH (non-condensing) HOUSING MATERIAL Photoelectric MP Series Modular MINI STYLE BASE Glass-filled Polysulfone STANDARDS EN 60947-5-2 APPROVALS ELECTRICAL CONNECTION MPW11HD MPW21HD 2-meter cable, PVC covered, 4-conductor, #18 AWG Quick disconnect type V95 *NOTE: Total response time is the sum of the sensor head and base response times. Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 607 Photoelectric MP Series Modular Photoelectric Sensors ANALOG PLUG-IN BASE Specifications APPLICATION CONSIDERATION DC Determined by cable† SENSING RANGE MODEL NUMBER(S) MPS35HD OUTPUT Voltage 0-5 VDC Current 4-20 mA LOAD CURRENT 5 mA max. DRIFT (68ºF to 140ºF) 3% typical (0 to 68ºF) 6% typical SHORT CIRCUIT AND OVERLOAD PROTECTION No REVERSE POLARITY PROTECTION Yes SUPPLY VOLTAGE 12-24 VDC ≤ 40 mA POWER CONSUMPTION REPEATABILITY ± 1% typical PROTECTION (IEC) TEMPERATURE RANGE IP69K when all components are properly assembled WORKING +32 ºF to 140 ºF STORAGE HOUSING MATERIAL -67 ºF to 185 ºF Glass-filled Polysulfone SHOCK 50 G VIBRATION 10 G, 10-500 Hz HUMIDITY 95% RH (non-condensing) STANDARDS EN 60947-5-2 APPROVALS ELECTRICAL CONNECTION Dependent on receptacle selected  ee pages 761-796 for S fiber optic lengths and specifications. † The MPF5HD head emits an IR beam, which is bounced off the detected object and returned. Depending on the distance to the object and its reflectivity, the head produces a signal with a magnitude proportional to the sensed distance between the object and the head. The MPS35 uses this signal to produce a voltage output and a current output. The MPS35HD base provides a voltage output from 0-5VDC. The voltage output sources voltage to the user’s load, which is then connected to the MPS35HD’s negative supply terminal or ground. Current flows from the voltage output to ground. The voltage output can only supply up to 5mA of current and therefore, the load impedance must be 1000 ohms or more. Lower impedances will produce false output voltage readings. The MPS35HD base also provides a current output from 4-20mA. The user’s load is connected from the MPS35HD’s positive supply terminal and to the analog current “output” terminal. The “output” pin sinks current (current flows into it). Output current is monitored through an internal resistor in the current amplifier. As the target is moved toward the sense head, increased current is sent to the load and to the sense resistor. Without limitations, this current would produce voltages across these two resistances that would exceed the MPS35HD’s supply voltage. Under these conditions, the output current will reach some value and just stay there. Therefore, to ensure proper operation of the MPF5HD/ MPS35HD sensor, the current output load resistance cannot exceed 250 ohms. The current output can only operate with loads of 0-250 ohms. The MPF5HD head produces only one output signal from which the MPS35HD produces its voltage output. The voltage output is then used to run the current amplifier via an internal connection. There is only one set of range and offset adjustments provided. These adjust both the voltage and current outputs. Due to differences in the two amplifiers, only one output can be set accurately. Therefore only one output should be used with the other left unconnected. Should it be necessary to use both outputs, the voltage output must see a minimum load resistance of 5000 ohms. This is necessary to prevent overloading of the sensor, which could produce incorrect output voltage and current values. RECEPTACLE MODELS MPB20 Standard 4-terminal, 1/2” NPT conduit thread MPB22 5-pin mini connector See pages 803-854 for cordsets 608 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Specifications MODEL NUMBER(S) SUPPLY VOLTAGE POWER CONSUMPTION AC/DC AC MPS14HD† MP2S11HD 22-26 VAC/DC 22-260 VAC 70 mA — OUTPUT — Solid state AC relay LOAD CURRENT — 500 mA max. LEAKAGE CURRENT — ≤ 1.9 mA INRUSH CURRENT — 5 A/8 ms VOLTAGE DROP — ≤ 10 V RESPONSE TIME* — ≤ 2 ms SHORT CIRCUIT AND OVERLOAD PROTECTION No No REVERSE POLARITY PROTECTION ELECTRICAL CONNECTION No Yes Dependent on receptacle selected Dependent on receptacle selected *NOTE: Total response time is the sum of the sensor head and base response times. NOTE: Emitter base only. † NOTE: For specifications on Models: MPS10HD, MPS13HD and MPS30HD emitter bases, see pages 602-603 2-Wire AC Base Specifications PROTECTION (IEC) TEMPERATURE RANGE IP69K when all components are properly assembled WORKING -22 ºF to +158 ºF STORAGE -67 ºF to +185 ºF HOUSING MATERIAL VIBRATION HUMIDITY RANGE RECEPTACLE MODELS MPB20 Standard 4-terminal, 1/2” NPT conduit thread MPB22 5-pin mini connector See pages 803-854 for cordsets Glass-filled Polysulfone SHOCK Photoelectric MP Series Modular 2-WIRE AC BASE 50 G 10 G,10-500 Hz 95% RH (non-condensing) PLUG-IN RECEPTACLE Die-cast zinc STANDARDS EN 60947-5-2 APPROVALS Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 609 Photoelectric Sensors Standard Head Sensing Characteristics Diffuse Scan Sensing Characteristics Excess Gain vs. Sensing Range Excess Gain vs. Sensing Range MPD2HD 150 20 Excess Gain Excess Gain MPD4HD 200 10 5 100 50 2 1 0.3 .03 x 0 0 3 500 1000 1270 Distance X [mm] Distance X [m] x Diffuse Scan Sensing Characteristics Excess Gain vs. Sensing Range Movement Characteristics MPD6HD 100 Movement Characteristics MPD1/D2 3 2 MPD1 20 10 0 Max. Recommended Range (clean air) MPD2 -10 -20 20 200 500 800 -40 Distance X [mm] x 20 10 0 -10 -20 MPD6 -40 -30 1 10 MPD4 40 Offset Y [mm] Offset Y [mm] 10 MPD4HD/6HD 60 40 30 Excess Gain 0 0.5 1.5 1 2 2.5 -60 3 0.5 0 x Distance X [m] 1 Distance X [m] y x y Photoelectric MP Series Modular 100 Polarized Scan Sensing Characteristics Excess Gain vs. Sensing Range Excess Gain vs. Sensing Range MPP1HD 10 100 H32 RR1 Offset Y [mm] Excess Gain 3 10 MPP6 30 MPP1 0 -30 Max. Recommended Range (clean air) -60 H32 -100 1 0.3 3 0.6 x MPP1HD/P6HD 60 RR1 Excess Gain Movement Characteristics MPP6HD 100 1 9 0.1 0.2 x 1 6 3 3 4 6 7 Distance X [m] x Distance X [m] y Distance X [m] 0.5 Retro-Reflective Scan Sensing Characteristics Excess Gain vs. Sensing Range Movement Characteristics MPL2HD/6HD 100 70 Movement Characteristics MPL1/MPL2 MPL2 3 2 20 0 Max. Recommended Range (clean air) -20 -40 -130 -70 0.1 0.2 6 Distance X [m] 0 0.5 1 2 3 x 5 6 7 8 9 Distance X [m] 610 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 1 4 x y x 3 100 70 50 30 0 -30 -50 -70 -100 y 1 MPL1 Offset Y [mm] Offset Y [mm] Excess Gain 40 10 MPL6HD 130 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 7 Distance X [m] 10 Photoelectric Sensors Standard Head Sensing Characteristics 100 Excess Gain vs. Sensing Range with Glass Cable Thru-Beam Scan Sensing Characteristics Movement Characteristics MPEHD/MPRHD MPE6HD/MPR6HD 1750 750 Offset Y [mm] Excess Gain 10 3 2 200 0 -200 Max. Recommended Range (clean air) -750 -1250 1 4 30 x 70 60 -1750 Distance X [m] 0 3 10 20 30 x 40 50 60 y Distance X [m] Fiber Optic Sensing Characteristics Movement Characteristics MPF6HD/MPG6HD Offset Y [mm] Offset Y [mm] 5 Max. Recommended Range (clean air) 0 -5 -10 0 5 40 20 60 80 10.16 8.13 6.10 4.06 2.03 0 -2.03 -4.06 -6.10 -8.13 -10.16 100 MPF6HD 1000 600 B2B-3 PAD6-M 100 50 DIFFUSE 10 5 1 0 25.4 12.7 x Distance X [mm] 38.1 50.8 65.5 0 .003 0.2 .025 x 0.8 2 Distance X [m] Distance X [mm] y y x Excess Gain vs. Sensing Range MPF2HD/MPG2HD Excess Gain Movement Characteristics 10 2-Wire AC Head Sensing Characteristics Photoelectric MP Series Modular 1250 Diffuse Scan Sensing Characteristics Excess Gain vs. Sensing Range Movement Characteristics MP2D1HD/D2HD/D4HD Movement Characteristics MP2D4HD 38 100 1 0 0.48 0.76 x 1.0 12 0 -12 1.4 1.5 1.7 2.0 2.3 MP2D1 12 0 -12 -38 -38 -50 0 Distance X [m] 25 -25 -25 MP2D2 0.24 Offset Y [mm] Offset Y [mm] MP2D4 .01 0.3 0.4 0.6 0.7 0.9 0 0.3 0.6 x Distance X [m] 0.9 1.2 Distance X [m] 1.5 1.8 y y x Polarized Scan Sensing Characteristics Excess Gain vs. Sensing Range Movement Characteristics MP2P1HD MP2P1HD 152 100 Offset Y [mm] 101 Excess Gain 10 50 0 -50 -101 -152 1 0 1.5 3.5 x 4.6 6.1 7.6 9.1 0 1.5 x Distance X [m] 3.5 4.6 6.1 7.6 9.1 Distance X [m] y Excess Gain MP2D1 MP2D2 38 25 10 MP2D1HD/MP2D2HD 50 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 611 Photoelectric Sensors 2-Wire AC Head Sensing Characteristics Retro-Reflective Scan Sensing Characteristics Excess Gain vs. Sensing Range Movement Characteristics MP2L1HD/L2HD MP2L1 152 Offset Y [mm] Excess Gain MP2L2 10 MP2L1 101 MP2L2 50 0 -50 -101 -152 1 -203 0 1.5 3.5 4.6 6.1 x 7.6 9.1 10.7 0 12.2 1.5 3.5 4.6 x 6.1 7.6 9.1 10.7 12.2 Distance X [m] y Distance X [m] Thru-Beam Scan Sensing Characteristics Excess Gain vs. Sensing Range Movement Characteristics MP2R2HD 10,000 1000 100 Offset Y [m] Excess Gain 10 1 0.3 30 3 x 300 Distance X [m] 1.5 1.2 0.9 0.6 0.3 0 -0.3 -0.6 -0.9 -1.2 -1.5 0 6 12 x 18 MP2R2HD/MPE4HD 24 30 36 Distance X [m] y Photoelectric MP Series Modular MP2L1HD/MP2L2HD 203 100 Fiber Optic Diffuse Scan Sensing Characteristics Excess Gain vs. Sensing Range with Glass Cable (FE-B2B-3) Excess Gain vs. Sensing Range with Plastic Cable (FEF-PAD6-M) MP2F1HD/F2HD MP2F1HD/F2HD 102 100 10 Excess Gain Excess Gain 1000 MP2F1 101 MP2F1 MP2F2 MP2F2 1 0 13 25 38 51 64 76 Distance X [mm] 88 100 100 0 5 x 15 612 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 20 Distance X [mm] x 10 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 25 37 Photoelectric Sensors Wiring Diagrams DC Terminal Connection AC AC Terminal Connection Model: MPS30HD 2 N DC 2 4 4 1 3 1 3 L1 Green (Metal Base Only) N 4 Relay Output 3 DC 2 4 Load L1 3 2 L2 DC White Relay Output 3 Model: MPT17HD Black AC (+) Red Orange Load Load 3 L1 N NOTE: Relay also requires AC power 4 1 Relay Output Orange (-) 2 L1 Red Model: MPS32HD Model: MPS12HD 1 (+) Green (Metal Base Only) NOTE: Pins 3 and 4 must be jumpered (jumper wire not included) 4 N Model: MPT11HD Black AC 1 Load Green (Metal Base Only) AC L1 White (-) Model: MPS31HD 2 1 Model: MPT10HD Black AC (+) Green (Metal Base Only) Model: MPS11HD AC Cable Connection White (-) L1 115 VAC L1 (+/-)115-300V AC/DC L2 (-/+) N Green (Metal Base Only) Green (Metal Base Only) NOTE: Pins 3 and 4 must be jumpered (jumper wire not included) DC Model: MPS13HD AC 2 3 2 4 Load 3 1 NC 2 1 L1 N.O. COM. N.C. L2 NO C NC 2 1 L1 24 VAC N.O. COM. N.C. N NO C NC 2 L1 N.O. 1 COM.1 N.C.1 N.O.2 COM.2 N.C.2 N 3 2 4 7 6 8 5 Green (Metal Base Only) Model: MP2S11HD Load L2 2 4 I Load N DC (+) 1 V Load 3 Cable Connection (-) Green (Metal Base Only) Model: MPT30HD DC Terminal Connection AC/DC 2 4 1 Load 3 AC/DC 2 4 1 N(-/+) L1(+/-) 24-300V AC/DC L2(-/+) L1(+/-) 24V AC/DC Load 3 N(-/+) L1(+/-) 12-140V AC/DC N(-/+) L1(+/-) 12-140V AC/DC Red (+) Black (-) Model: MPT31HD Red DC (+) White Black Load Model: MPT32HD Red DC White (-) (+) Load Black (-) Green (Metal Base Only) Model: MPV14HD 1 NO C NC 2 L1 20-260 VAC L1 Load Model: MPS35HD AC/DC 4 1 White Model: MPS18HD Model: MPSD11HD 1 Model: MP2T11HD AC Black Model: MPS16HD Model: MPV13HD 2 White AC/DC Model: MPV12HD AC Blue (+) N.O. COM. N.C. (-) NO 2 L1 N.O. COM. N.C. N NO 1 NC DC Analog C AC L1 N.O. COM. N.C. N Orange (-) C N L1(+/-) 115-300V AC/DC L2(-/+) L1 115V AC Model: MPV11HD AC Black Red Model: MPV31HD DC Green (Metal Base Only) AC AC (+) L1 Model: MPS17HD AC 4 Load Green (Metal Base Only) 1 3 Green (Metal Base Only) 1 2 1 Load L2 4 AC Model: MPW11HD Model: MPS33HD Photoelectric MP Series Modular Model: MPS10HD AC L1(+/-) 20-260 VAC/DC N.O. COM. N.C. L2(-/+) Model: MPT33HD Red DC Load White (+) Orange Load Black (-) 3 Green (Metal Base Only) Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 613 Photoelectric Sensors Wiring Diagrams AC/DC DC Photoelectric MP Series Modular Cable Connection Mini Quick Disconnect Note: Wiring diagrams show quick disconnect pin numbers. Model: MPT16HD AC/DC V94 Type Black Red Orange Load White L1 (+/-)24V AC/DC L1 (+/-)24-300V AC/DC L2 (-/+) N (-/+) Model: MPT41HD DC Red 3 Red (+) 2 White 1 Black AC Mini Quick Disconnect Note: Wiring diagrams show quick disconnect pin numbers. Load (-) DC 2 4 1 3 2 4 1 3 2 4 1 Load Black (-) Red 3 Red V93 Type 1 Black (+) Load (-) (+) White Load Black (-) Model: MPT20HD White AC 2 Black L1 3 2 N Black 1 3 White Model: MPT43HD L1 DC N 3 Red 2 White Load 4 Green Load 1 Black Red (+) (+) White (-) Load Black (-) Green Load V95 Type Model: MPT21HD AC Black Orange 5 Black 2 Red L1 4 Orange 4 Micro Quick Disconnect Red 2 5 N DC L1 Relay Output 3 Relay Output 1 White 1 White Note: Wiring diagrams show quick disconnect pin numbers. N Model: MPT27HD AC Black Orange 5 Black 4 Orange Load 1 White L1 115 VAC L1 (+/-)115-300V AC/DC L2 (-/+) N Load 3 4 5 2 V1 Type Model: MPT40HD-CM Output Red DC 1 White AC 5 Black 2 Red 4 Orange 3 Green 1 White 1 Brown (+) N (–) L1 N.O. COM. N.C. N 3 2 4 1 5 N.C. Orange COM. Red N.O. 3 1 2 Blue (–) Brown (+) Blue (–) Model: MPT41HD-CM Black 1 Brown DC N L1 White 4 Black AC/DC Load (+) 4 3 1 2 (–) Black Load Brown (+) Model: MPT42HD-CM Black Mini Quick Disconnect Note: Wiring diagrams show quick disconnect pin numbers. 1 Brown DC 3 Blue 2 Red 4 Orange Load 1 White Load 4 3 1 2 (–) Load Brown (–) (+) Model: MPT43HD-CM Model: MPT28HD 5 Black Blue (+) 4 Black V95 Type Black Orange L1 (+/-)12-140V AC/DC L1 (+/-)12-140V AC/DC N (-/+) N (-/+) Load 3 4 Model: MPB22 Mini 4 Green 3 Blue AC/DC L1 3 Blue Model: MPW21HD (+) White 3 Model: MPT42HD 2 White 2 Red 5 2 Black L1 1 Brown 2 White Load 4 Black Load 3 Blue DC Output Red 1 White N Blue (+) 4 3 1 2 (–) 3 Black Green (Metal Base Only) Micro Green Red 5 1 3 4 2 1 Black White Blue 3 1 2 3 Blue Black Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Black 4 Green (Metal Base Only) Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com (–) Load Brown 2 Brown 4 White Load White Model: MPB27 Orange 2 White 4 Red 1 Orange 614 White Brown (+) Photoelectric Sensors Dimensions (mm) SENSOR HEAD, BASE AND RECEPTACLE DIMENSIONS 39.6 55.2 47.2 52.3 7.6 43.2 43.2 50.2 40.6 39.2 137.2 REF 10—32 UNF—2B Tapped from rear 12.7/.500 min depth (2) 85.9 59.4 10.2 29.5 52.3 5.1 DIA (2) Mounting Holes 52.3 1/2—14 NPT Photoelectric MP Series Modular FIBER OPTIC SENSOR HEAD DIMENSIONS 16.5 20.6 SENSOR HEAD WITH MINI RELAY BASE DIMENSIONS QUICK DISCONNECT MINI BASE DIMENSIONS 4.4 Ø Mounting Hole 39.6 52.3 19.8 39.6 SQ 25.4 4.6 7 5.1 25.4 40.6 43.2 90.3 Front Mount 43.7 6.4 Mounting Hole 7/8—16 UN—2A 3.8 6.1 4.44 25.4 15.2 54.4 15.2 M30 x 1.5 19 Ø 25.4 Ø 5.1 4.44 DIA Mounting Hole 6.4 QUICK DISCONNECT MICRO BASE DIMENSIONS 4.4 Ø Mounting Hole 25.4 M30 X 1.5 39.6 SQ 25.4 4.6 5.1 25.4 40.6 55 15.2 5.4 1/2—1/4 NPSM M30 x 1.5 8 6.4 Mounting Hole M12x1 25.4 Ø Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 615 Photoelectric Sensors MULTIFUNCTION TIMER/LOGIC CARD Photoelectric MP Series Modular FOR A COMPLETE CONTROL • Multifuction Time/logic Card • Photoelectric Sensor Head • Reflector (Retro and Polar Scans) CHOICE OF: • Plug-in base • Plug-in Receptacle • Mini Base • Relay Base Multifunction Logic Cards Model No. Description MPA1HD 0.15 to 15 sec. time adjustment MPA155HD 1 to 30 sec. adjustment MPA188HD 0.01 to 1 sec. adjustment Plug-in timer/logic cards easily convert any ON/OFF MP Series photoelectric into a multifunction control. Seven DIP switches located on the timer card provide the user with a choice of seven delay functions including dual delay and motion detection. In addition, light operated or dark operated sensing can be selected by a switch located on the photoelectric sensor head. TIME DELAY OPTIONS The timer/logic cards can be set up to modify the sensor’s head output signal. For instance, in thru-scan or reflective scan (L.O. mode), if the logic card is set for OFF delay the sensor does not immediately turn off its output circuit after the beam goes dark or is blocked. Instead it waits until the beam has been dark for a preset time. If set for ON delay, the sensor waits for a preset to time to recognize that the beam is complete. Each timer/logic card has seven DIP switches to select ON delay, OFF delay, or both. The delays range as shown in the Specifications and Order Guide. The cards also offer totally independent range selection and adjustment for ON and OFF delays. ONE SHOT OPTIONS In addition, the timer/logic card offers four modes of operation: 1-shot, a delayed 1-shot, 1-shot drop, and a delayed 1-shot drop. The cards can be adjusted for both the width of the 1-shot pulse and the length of delay before the 1-shot is fired. TIMING OPTION SETTINGS Prior to inserting a multifunction timer card into the photoelectric sensor head, you must properly set DIP switches located on the card. You must also set the L.O./D.O. switch located in the photoelectric sensor head. TIMING ADJUSTMENTS On the top of the MP Series photoelectric sensor head is an access cover. When opened with a small blade screwdriver, the multi-turn timer adjustment screws, labeled “1” and “2,” are exposed. Clockwise rotation increases the time range(s). If a single delay option is selected, the other timer adjustment is automatically set to zero. When the sensor head has been set to the desired timing range(s), snap the access cover shut to provide proper head sealing. - + 1 616 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 S Photoelectric Sensors MULTIFUNCTION TIMER/LOGIC CARD Timing Options Settings Timing/Adjustment T1 denotes screw adjustment 1 T2 denotes screw adjustment 2 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com DIP SWITCHES 1-7 Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric MP Series Modular DIP switches on the card are labeled 1-7, with OFF position toward the labels. Refer to the timing chart below for DIP switch settings and their results for a retro-reflective or thru-beam setup. 617 Photoelectric Sensors TARGET Photoelectric MP Series Modular TARGET Reflector Reflector NO TARGET Leading Edge TARGET GONE TRAILING EDGE Output is OFF Output doesn’t turn on until the time delay period has expired. Output is OFF Light On Output is ON Output is OFF Output doesn’t turn back on until the delay period has expired. Dark On Output is OFF Output is ON Output remains on for the amount of time set for the off delay. The output turns off when the delay period has expired. Light On Output is ON Output will not turn off until the time delay has expired. Output turns back on. Output is OFF Output doesn’t turn on until the time delay period has expired. Output doesn’t turn back off until the time delay period has expired Output turns on after the time delay period has expired. Output turns off after the time delay period has expired. Output turns back on after the delay period has expired. Dark On ON/OFF Delay Light On Dark On Output is OFF Dark On Output is ON Light On Output is ON Dark On Output is OFF Light On The output turns on as soon as the target is present. The output will remain on only for the amount of time set. Output turns off only for the amount of time set. When that time expires, the output will turn back on. If the time set for the output to turn on has not run out, the output will remain on. If the time set for the output to remain on expired while the target was still in front of the sensor and the output turned back off, the output will remain off. If the time set for the output to turn off has not expired, the output will remain off. If the time set for the output to remain off expired while the target was still in front of the sensor and the output turned back on, the output will remain on. Output remains ON Output turns off only for the amount of time set. When that time expires, the output will turn back on. Output is OFF Output turns on after the time delay period has expired. Output remains on only for the time period set, when that time expires the output will turn back off. Output turns on after the time delay period expires. Output turns on only for the time period set. When that time expires, the output will turn back off. Output remains off if the one shot time period has expired. If the one shot period hasn’t expired, the output will remain on. Output is OFF Delayed 1-shot Dark On Output is ON Output is ON Output turns off after the time delay period has expired. Output turns off only for the time period set, when that time expires, the output will turn back on. Light On Output is ON Output turns off after the time delay period expires. Output turns on only for the time period set. When that time expires, the output will turn back on. Output remains off if the one shot time period had expired. If the one shot period hasn’t expired, the output will remain on. Delayed 1-shot Drop TARGET MOVING CONDITIONS TARGET NOT MOVING CONDITIONS 618 Reflector TARGET PRESENT LEADING EDGE OFF Delay 1-shot Drop TARGET Dark On ON Delay 1-shot Trailing Edge Motion Detector OFF with no Motion Light or Dark On Output is ON Output is OFF Motion Detector ON with no Motion Light or Dark On Output is OFF Output is ON Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Accessories (Dimensions in mm) Swivel Mounting Brackets Optional mounting brackets (MPZB01 or MPZB02) can be provided that fit around the threaded portion of the mini base. The brackets allow the base to rotate 360º. A 30 mm mounting nut and lockwasher is included for securing the mini base to the bracket. The basic ball and swivel mounting bracket (360º swivel 10º tilt) consists of two plastic brackets and the spherical plastic swivel nut. The swivel nut has M30 threading for direct installation of the MPT (mini MP base), including the quick disconnect versions. The bracket (MPZB06) can be directly mounted to a surface, or the MPZB07 mounting plate may be used. The MPZB08 adapter allows you to connect the ball and swivel bracket to the MP relay (MPV) and MP plug-in bases (MPS). MPZB01 54.6 31.8 19.1 (2) 31.8 29.2 30.5 16 7.1 Ø (2) 63.6 44.5 Screw (2) 10-32 UNF on 2.0 (50.8) center Modular Photoelectric Control 31.8 Washer (2) 22.9 R 25.4 3 MAX R (2) MPZB02 54.6 31.8 19.1 (2) 31.8 29.2 30.5 7.1 Ø 63.6 16 22.9 R Nut—Special 54.6 R (12) MPZB07 Bracket (2) 31.8 Nut (2) 44.5 Ø 3 MAX R (2) Exploded View of MPZB06 45 deg. TYP Mounting Brackets MPZB11 FE-MB8 Model No. Description MPZB01 Mini MP mounting bracket, vertical slots MPZB02 Mini MP mounting bracket, circular slots MPZB06 Ball and swivel mounting bracket (fits 30mm mini MP) MPZB07 Ball and swivel vertical mounting plate MPZB08 Adapter (use with MPZB06 to fit 1/2” conduit hole) MPZB12 Photoswitch 4000 (MLS8C) to limit switch style (combination of the MPZB11 and FE-MB8) MPZB14 Combination of the MPZB06 and MPZB07 bracket Photoelectric MP Series Modular Mounting Brackets Other Accessories MPZB12 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Model No. Description MPZFOADPT Pair of fiber cable adapters allows use of cutable 1000 micron plastic cable MPZN01 Mini base steel mounting nut and lockwasher MPZN02 Mini base plastic mounting nut and lockwasher MPGKITC Pair of cable end tips and accessories for universal cables MPZR01 Replacement relay for MPV series—6A SPDT MPZR02 Replacement relay for MPSD series—5A DPDT Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 619 Photoelectric Sensors Photoelectric MP Series Modular Notes 620 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com
MP2S11HD 价格&库存
很抱歉,暂时无法提供与“MP2S11HD”相匹配的价格&库存,您可以联系我们找货
