PD30CNB15NPRT
PD30CNB15NPRT
    CARLOGAVAZZI
    SENSOR REFLECTIVE 150MM NPN
PD30CNB15NPRT 数据手册
Photoelectrics Diffuse-reflective, Background Suppression Type PD30CNB15....RT • Miniature sensor range • Range: 150 mm • Sensitivity adjustment by Teach-In programming • Modulated, red light 660 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make or break switching function programmable • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Remote teach features Product Description Ordering Key The PD30CNB15 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Remote teach The Teach-In function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is NO or NC output. A remote teach feature allow the sensor to be set up from e.g. a PLC. PD30CNB15PPM5RT Type Selection Housing Range Connection WxHxD Sn Ordering no. Ordering no. NPN PNP Make or break switching Make or break switching 10 x 30 x 20 mm 10 x 30 x 20 mm PD 30 CNB 15 NPRT PD 30 CNB 15 NPM5RT Specifications 150 m m 150 m m Cable Plug PD 30 CNB 15 PPRT PD 30 CNB 15 PPM5RT EN 60947-5-2 Rated operating distance (Sn) Up to 150 mm, referece target Kodak test card R27, white, 90% reflective, 200 x 200 mm Blind zone 30 mm Sensitivity Adjustable by Teach-In Temperature drift ≤ 0.2%/ºC Hysteresis (H) 90% White < 10% 18% Grey < 15% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 32 mA @ 24 VDC Minimum operational current (Im) 0.5 mA OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2.4 VDC @ 100 mA Protection Short-circuit, reverse polarity and transients Specifications are subject to change without notice (14.06.2016) Light source Light type Sensing angle Ambient light Light spot Operating frequency Response time OFF-ON (tON) ON-OFF (tOFF ) Power ON delay (tv) Output function NPN and PNP NO/NC switching function Remote teach function Teach on Tamper proof Indication Output ON Signal stability ON and power ON GaAlAs, LED, 660 nm Red, modulated ± 2º 10,000 lux 110 mm @ 1.5 m 1000 Hz ≤ 0.5 ms ≤ 0.5 ms ≤ 400 ms Preset Set up by button 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) When activated more than 20 sec. the sensor goes into a Tamper proof mode. LED, yellow LED, green 1 PD30CNB15....RT Specifications (cont.) Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +55°C (-13° to +131°F) -40° to +70°C (-40° to +158°F) 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage 500 VAC (rms) Housing material Body ABS Front material PMMA, red Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON. 54-series) Weight With cable: 40 g With plug:  10 g CE-marking Yes Approvals cULus (UL508) Operation Diagram Operation Diagram tv = Power ON delay ON OFF Power supply Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Object Tv Wiring Diagrams NPN 1 BN Remote teach PNP V 2 WH 4 BK 1 BN V 4 BK 2 WH Remote teach 3 BU 3 BU V (GND) V (GND) Remote teach input active when connected to GND Remote teach input active when connected to V+ Sensing Conditions Detection Diagram 30 5 % of sensing distance 3 2 (mm) 5% / 90% 25 4 1 0 -1 -2 20 18% / 90% 15 10 90% / 90% 5 -3 0 -4 -5 0 0 50 100 Sensing range (mm) 2 150 20 40 60 80 100 120 140 160 Distance (mm) 200 5% / 90% Black on White 18% / 90% Grey on White 90% / 90% White on White Specifications are subject to change without notice (14.06.2016) PD30CNB15....RT Dimensions Plug version Cable version 10.6 20 10.6 20 10.6 Two, 9.5 dia. Lenses Receiver Optical axis Receiver Optical axis Correct xxxxxxS > 100 mm Emitter Two M3 Two, 9.5 dia. Lenses 15 22 15 30 5.5 5.5 22 25.4 10.8 17 R Incorrect xxxxxxS 30 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 25.4 1.1 17 Power / Stability LED Green 10.6 PD30CNP 06NPM5T 10.8 1.1 PD30CNP 06NPM5T R Output LED Yellow Power / Stability LED Green 5.5 5.5 Output LED Yellow 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 6 Teach Button 6 Teach Button Two M3 Emitter 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Accessories Delivery Contents 21.2 14 9° 32.4 1.2 25.4 3.2 1.2 • Photoelectric switch: PD 30 CNB 15 ... • Installation instruction • Mountingbracket APD30-MB1 • Packaging: Cardboard box 29.3 10 26,3 3.2 39 9° 25.4 Any repetitive flexing of the cable should be avoided 13.5 16.2 6.0 5.2 4.4 Mounting bracket: APD30-MB1 3 14 4.4 8.2 6.0 16 10 7.3 5.7 4.4 Mounting bracket: APD30-MB2 • Mounting bracket APD30-MB2 to be purchased seperately • Connector type CONG 5A../CON. 54NF.. series. Specifications are subject to change without notice (14.06.2016) 3 PD30CNB15....RT Teach functions Normal operation, optimized switching point. 1. Line up the sensor at the background. Yellow LED is not important and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) a) if the object is to close to the background the sensor will teach both background and object as object. 1 2 3 For dynamic set-up (running process) 1. Line up the sensor at the object. Green LED is ON, status on the yellow LED is not important. 2. Press the button for 3 second until both LEDs flashes simultaneously. 3. Press the button a second time for at least one second, both LED’s flashes fast siultainiously and keep the button pressed for at least one process cycle, release the button and the sensor is ready to operate (The second switch point is stored) 1 2 3 4 3 sec. 3 sec. Push once For maximum sensing distance (default setting) 1. Line up the sensor without a background. Yellow LED is not important and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 One cycle For make or break set-up (N.O. or N.C.) 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indi- cates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 3 10 sec. 3 sec. Push once Push once For minimum sensing distance 1. Line up the sensor at the object. Yellow LED is not important and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate(Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 sec. 4 3 Push once Specifications are subject to change without notice (14.06.2016)
PD30CNB15NPRT 价格&库存
很抱歉,暂时无法提供与“PD30CNB15NPRT”相匹配的价格&库存,您可以联系我们找货
