GRTE18S-P234Z
GRTE18S-P234Z
    SICK
    SENSOR 400MM PNP LO M12 MTL FLSH
GRTE18S-P234Z 数据手册
Product data sheet GRTE18S-P234Z GR18S CYLINDRICAL PHOTOELECTRIC SENSORS GRTE18S-P234Z | GR18S CYLINDRICAL PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. GRTE18S-P234Z 1059487 Other models and accessories www.sick.com/GR18S Illustration may differ Detailed technical data Features H I J K L M N O P Q R S T Sensor/ detection principle Photoelectric proximity sensor, Energetic Dimensions (W x H x D) 18 mm x 18 mm x 38.1 mm Housing design (light emission) Cylindrical Thread diameter (housing) M18 x 1 Optical axis Axial, fully flush Sensing range max. 5 mm ... 550 mm 1) Sensing range 10 mm ... 400 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 9 mm (400 mm) Wave length 650 nm Adjustment Potentiometer, 270° Indication LED indicator green Operating indicator Static: power on LED indicator yellow Status of received light beam Static on: object present Static off: object not present 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-01 16:33:33 Subject to change without notice GRTE18S-P234Z | GR18S CYLINDRICAL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple 49 °C, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected.  At Uv
GRTE18S-P234Z 价格&库存
很抱歉,暂时无法提供与“GRTE18S-P234Z”相匹配的价格&库存,您可以联系我们找货
