PD70CNT12PO
PD70CNT12PO
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 12M PNP
PD70CNT12PO 数据手册
Photoelectrics Through-beam, Transistor Output Type PD70CNT12.. • • • • • • • • • • • Product Description The PD70 sensor family of Photoelectric sensors is specially designed for Doors and Entrance control to meet the requirements in the door market. The slim housing design fits inside the alu- Doors and Entrance control Range 12 m Modulated, infrared light Supply voltage: 10 to 30 VDC Output: 100 mA, NPN or PNP type Make or break switching LED for output indication or power supply Protection: reverse polarity, short circuit, transients Cable versions or M8 connector Emitter mute CE and UL325 approved Ordering Key minium frame of e.g. sliding doors. The emitter has a test input to turn it off for evaluation of the sensor function. Available in 10-30 VDC version. PD70CNT12NOM5MH Type Housing style Housing size Housing material Sensor code Detection principle Sensing distance Output type Output configuration Connection type Mute input Type Selection Test Range Sn Connector Ordering no. Receiver NPN, NO Ordering no. Receiver NPN, NC Ordering no. Receiver PNP, NO Mute Low Mute Low Mute High Mute High 12 m 12 m 12 m 12 m NO YES NO YES PD70CNT12NO PD70CNT12NOM5 PD70CNT12NC PD70CNT12PO PD70CNT12NCM5 PD70CNT12POM5 Ordering no. Receiver PNP, NC Ordering no. Emitter PD70CNT12PC PD70CNT12PCM5 PD70CNT12ML PD70CNT12M5ML PD70CNT12MH PD70CNT12M5MH Note: Please order emitter and receiver separately Specifications Emitter Rated operational volt. (UB) Ripple (Urrp) Supply current Protection Test input Test High Emitter off Emitter on Test Low Emitter off Emitter on 10 to 30 VDC ≤ 10% ≤ 20 mA Reverse polarity, transients Light source Light type Optical angle Indication function Power supply ON LED, 850 nm Infrared, modulated < ± 5° LED, green 5 to 30 VDC < 2.5 VDC or not connected < 2.5 VDC 5 to 30 VDC or not connected Specifications are subject to change without notice (07.06.2010) 1 PD70 Specifications Receiver Rated operating dist. (Sn) Blind zone Temperature drift Hysteresis (H) Rated operational volt. (UB) Ripple (Urrp) Output current Continuous (Ie) Short-time (I) 12 m None ≤ 0.2%/°C 10 - 15% 10 to 30 VDC (ripple included) ≤ 10% ≤ 100 mA ≤ 100 mA, (max. load capacity 100 nF) No load supply current (Io) ≤ 16 mA Minimum operational current (Im) 0.5 mA Ambient light 100.000 LUX Optical angle OFF-state current (Ir ) Voltage drop (Ud ) Protection ± 5° ≤100 µA ≤ 1.8 VDC @ 100 mA Short-circuit, reverse polarity, transients Operating frequency (f) 100 Hz Response time OFF-ON (tON) < 5 ms ON-OFF (tOFF) < 5 ms Power ON delay (tv ) ≤ 200 ms Output function NPN or PNP Make or break (NO or NC) Indication function Output ON LED, yellow General Specifications Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Vibration Shock Rated insulation voltage Housing material Housing Backpart receiver Backpart emitter Connection Cable II (IEC 60664/60664A, 60947-1) 3 (IEC 60664/60664A, 60947-1) IP 67 (IEC 60529, 60947-1) -25° to +55°C (-13° to +131°F) -40° to +70°C (-40° to +158°F) 10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 2 x 1 m & 100 x 0.5 m (IEC 60068-2-32) 50 VDC Plug Weight (each sensor) With cable With plug CE-marking UL-Approval PC black PC Green PC Red PVC, TX: grey / RX: black, 5 m, 3 x 0.14 mm2, Ø 2.9 mm M8 - 3 pole 90 g 20 g EN12445, EN12453, EN12978 cus UL325, CSA-C22.2 No.247 Operation Diagram tv = Power ON delay Power supply Target emitter present Object present Break (NC) Output ON Make (NO) Output ON Test active High (MH) Test active Low (ML) Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (07.06.2010) PD70 Dimensions Detection Diagram Cable version 0,8 Plug version 11,6 Displacement (m) 0,6 11,6 11,53 11,53 10 0,4 0,2 0 -0,2 -0,4 10 -0,6 6,9 Ø4 3,3 -0,8 1 0 Ø2,5 2 3 4 5 6 7 Diastance (m) 8 9 10 11 12 70 Excess Gain 200 Excess Gain 100 10 1 1 10 20 Distance (m) Wiring Diagram Emitter, mute, Low 1BN 4BK 3BU PD 70 CNT 12 ML Delivery Contents • PD70 • Packaging: plastic bag Receiver 1BN 1BN 4BK 4BK 3BU PD 70 CNT 12 NO 3BU PD 70 CNT 12 NC Emitter, mute, High 1BN 4BK 3BU PD 70 CNT 12 MH 1BN 1BN 4BK 4BK 3BU PD 70 CNT 12 PO 3BU PD 70 CNT 12 PC Specifications are subject to change without notice (07.06.2010) 3
PD70CNT12PO 价格&库存
很抱歉,暂时无法提供与“PD70CNT12PO”相匹配的价格&库存,您可以联系我们找货
PD70CNT12PO
  • 1+332.202871+41.61790
  • 5+310.013925+38.83810
  • 10+295.0408810+36.96230
库存:5
PD70CNT12PO
  • 1+474.020151+59.38457
  • 5+450.316505+56.41501
  • 10+436.0998110+54.63396
  • 25+421.8797425+52.85249
库存:7
PD70CNT12PO
    • 3+313.67688
    库存:4
