KT5W-2P1116
KT5W-2P1116
    SICK
    SEN CONTRAST PNP 10MM M12-5
KT5W-2P1116 数据手册
Product data sheet KT5W-2P1116 KT5 CONTRAST SENSORS KT5W-2P1116 | KT5 CONTRAST SENSORS A B C D E F Ordering information Type Part no. KT5W-2P1116 1018044 Other models and accessories www.sick.com/KT5 Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Dimensions (W x H x D) 30.4 mm x 53 mm x 80 mm Sensing distance 10 mm 1) Housing design (light emission) Rectangular Light source LED, RGB 2) Wave length 470 nm, 525 nm, 640 nm Light emission Long and short side of housing, exchangeable Light spot size 1.2 mm x 4.2 mm Light spot direction Vertical 3) Adjustment Teach-in button Teach-in mode Static 2-point teach-in 1) 2) 3)  From front edge of lens.  Average service life: 100,000 h at TU = +25 °C.  In relation to long side of housing. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ≤ 5 Vpp 2) Current consumption 1 s. Red emitted light and yellow LED flash. Example T E A C H Press and hold teach-in button > 1 s. Yellow LED goes out. Dark switching Light switching Internal signal received Switching threshold Switching threshold Internal signal received Output Q Output Q Switching characteristics The optimum emitted light is selected automatically. Light/dark setting is defined using teach-in sequence. The switching threshold is set in the center between the background and the mark. Teach-in can also be performed using an external control signal. 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 5 KT5W-2P1116 | KT5 CONTRAST SENSORS Sensing distance Sensing distance 100 90 1 80 70 60 50 Relative sensitivity in % A B C D E F 2 40 30 20 3 10 0 H I J K L M N O P Q R S T 10 20 30 40 50 (0.39) (0.79) (1.18) (1.57) (1.97) Sensing distance in mm (inch) ①  Sensing distance 10 mm ②  Sensing distance 20 mm ③  Sensing distance 40 mm Recommended accessories Other models and accessories www.sick.com/KT5 Brief description Type Part no. Lens, 40 mm sensing distance, M20 x 0.75 OBJ-210 2010945 Lens, 10 mm sensing distance, M20 x 0.75 OBJ-211 1004936 Lens, 20 mm sensing distance, M20 x 0.75 OBJ-212 1011506 BEF-KHS-G01 2022464 BEF-KHS-K01 2022718 BEF-KHS-KH1 2022726 BEF-MS12G-A 4056054 BEF-MS12G-B 4056055 Lenses and accessories Universal bar clamp systems 6 REGISTRATION SENSORS | SICK Product data sheet | 2021-09-24 16:53:32 Subject to change without notice KT5W-2P1116 | KT5 CONTRAST SENSORS Brief description Type Part no. BEF-MS12L-A 4056052 BEF-MS12L-B 4056053 YF2A15020VB5XLEAX 2096239 YF2A15050VB5XLEAX 2096240 YF2A15100VB5XLEAX 2096241 YG2A15020VB5XLEAX 2096215 YG2A15050VB5XLEAX 2096216 YG2A15100VB5XLEAX 2096217 DOS-1205-G 6009719 DOS-1205-W 6009720 Plug connectors and cables 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
KT5W-2P1116 价格&库存
很抱歉,暂时无法提供与“KT5W-2P1116”相匹配的价格&库存,您可以联系我们找货
