DS18VP6LPQ
DS18VP6LPQ
    BANNER(邦纳)
    DS18VP6LPQ 4 PIN PICO QP POL RET
DS18VP6LPQ 数据手册
DS18 Series Sensors Datasheet Miniature self-contained photoelectric sensors in a universal housing • • • • • • • • Multiple mounting options accommodate almost any mounting requirements Exceptional optical performance, comparable to larger “MINI-style” or barrel sensors Patented wide-beam retroreflective models for enhanced ease of alignment 10 to 30V dc operation, with solid-state complementary NPN or PNP outputs, light operate or dark operate, depending on model Bright output LED indicates object is within the sensor’s field of view Rugged sealed housing with protected circuitry, rated IP67/NEMA 6 All models feature 18 mm threaded barrel and base for easy, versatile mounting Choose 2 m (6.5 ft) or 9 m (30 ft) cable, or 4-pin Euro-style or Pico-style integral QD fitting or 150 mm (6 in) QD Patent(s) issued or pending WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Model1 Sensing Mode Sensing Beam Range DS186E Output N/A DS18VN6R Opposed Infrared, 940 nm Effective Beam: 13 mm (0.5 in) 20 m (65.6 ft) NPN DS18VP6R PNP DS18VN6LP NPN Polarized Retroreflective DS18VP6LP DS18VN6LPW 3.5 m (11.4 ft) Wide-Angle Polarized Retroreflective DS18VP6LPW Visible red, 660 nm DS18VN6FF50 DS18VP6FF50 DS18VN6FF100 3.0 m (9.8 ft) 50 mm (2 in) Fixed-Field 100 mm (4 in) DS18VP6FF100 1 • • • • • PNP NPN PNP NPN PNP NPN PNP Only standard 2 m (6.5 ft) cable models are listed. For 9 m (30 ft) cable, add suffix “W/30” to the model number (for example, DS186E W/30) For 4-pin integral Euro-style QD, add suffix “Q8” (for example, DS186EQ8) For 4-pin integral Pico-style QD, add suffix “Q7” (for example, DS186EQ7) For 4-pin Euro-style 150 mm (6 in) pigtail QD, add suffix “Q5” (for example, DS186EQ5) For 4-pin Pico-style 150 mm (6 in) pigtail QD, add suffix “Q” (for example, DS186EQ) Original Document 128911 Rev. H 17 October 2016 128911 DS18 Series Sensors Wiring Diagrams NPN (Sinking) Outputs 3 – 10–30 V dc + 1 4 2 PNP (Sourcing) Outputs 1 + 10-30V dc – 3 Load 4 Load 2 Emitters 3 Load Key 1 2 3 4 – = = = = Brown White Blue Black 10-30V dc 1 + Load Specifications Supply Voltage 10 to 30 V dc (10% maximum ripple) at less than 20 mA, exclusive of load Protected against reverse polarity and transient voltages Output Response Time Opposed Mode: 800 microseconds ON; 400 microseconds OFF All others: 2 milliseconds ON/OFF NOTE: 100 millisecond delay on power-up; outputs do not conduct during this time Output Configuration Solid-state complementary; NPN or PNP (current sinking or sourcing), depending on model Rating: 100 mA combined load from −20 °C to +60 °C (−4 °F to +140 °F) Linearly derate combined load from 100 to 50 mA at temperatures from +60 °C to 70 °C (140 °F to 158 °F ) Off-state leakage current: NPN: less than 200 μA @ 30 V dc (See the Application Note) PNP: less than 10 μA @ 30 V dc Repeatability Opposed Mode: 100 microseconds All others: 350 microseconds ON-state saturation voltage: Indicators 2 LED indicators Green solid: Power ON Yellow (back cover) ON: Black wire (pin 4) is conducting; an object is within sensor’s field of view Protected against false pulse on power-up and continuous overload or short circuit of outputs Connections 2 m (6.5 ft) 4-wire PVC cable, 9 m (30 ft) 4-wire PVC cable, 4-pin Picostyle integral QD, 4-pin Euro-style integral QD, 4-pin Pico-style Pigtail QD, or 4-pin Euro-style Pigtail QD, depending on model Application Notes NPN off-state leakage current is < 200 μA for load resistances > 3 kΩ or optically isolated loads. For load current of 100 mA, leakage is < 1% of load current. Operating Conditions Temperature: −20 °C to +70 °C (−4 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Environmental Rating IEC IP67; NEMA 6; UL Type 1 Certifications Industrial Control Equipment NPN: < 1.6 V @ 100 mA PNP: < 3 V @ 100 mA Construction ABS housing, 3 mm mounting hardware included Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 3TJJ 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 128911 Rev. H DS18 Series Sensors Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. M18 x 1 Jam Nut 24.2 mm (0.95") Cabled/Pigtail Models 8.0 mm (0.32") 31.1 mm (1.23") 20.9 mm (0.82") 15.0 mm (0.59") Power ON LED (Green) Output LED (Yellow) Euro-Style Integral QD Models 17.1 mm (0.67") 5.2 mm (0.20") 24.1 mm (0.95") 34.5 mm (1.36") 47.9 mm (1.89") Pico-Style Integral QD Models 55.4 mm (2.18") 59.9 mm (2.36") 2X 3.2 mm (Ø 0.13") 2X M18 X1-6g 11.3 mm (0.44") M8 X1-6g M12 X1-6g Ø24.0 mm (0.95") Performance Curves Performance based on a 90% reflectance white test card 1000 E X C E S S G A I N 1000 DS186E and DS18...R Opposed Mode DS186E and DS18...R 750 mm 100 30" Opposed Mode 500 mm 20" 250 mm 10" 0 10 0 250 mm 10" 500 mm 20" 750 mm 1 0.1 m 0.3' 1m 3.3' 10 m 33' 30" 100 m 330' 0 DISTANCE 4m 12' 8m 26' 12 m 40' 16 m 52' E X C E S S G A I N DS18...FF50 Fixed-Field 100 10 1 0.1 mm 0.004" 20 m 66' Figure 2. Opposed Mode—Beam Pattern 10.0 mm 0.4" 100 mm 4.0" DISTANCE DISTANCE Figure 1. Opposed Mode—Excess Gain 1.0 mm 0.04" Figure 3. Fixed-Field 50 mm—Excess Gain Performance based on a 90% reflectance white test card 1000 E X C E S S G A I N 1000 DS18...LP DS18...LPW 60 mm Retroreflective Mode with BRT-84 Reflector 100 DS18...LP DS18...LPW 2.4" 40 mm 1.6" 20 mm 1 0.01 m 0.03' 0.1 m 0.33' 1m 3.3' 10 m 33' DISTANCE Figure 4. Polarized Retroreflective—Excess Gain P/N 128911 Rev. H 0.8" Retroreflective Mode with BRT-84 Reflector 0 10 0 20 mm 0.8" 40 mm 1.6" 60 mm 2.4" 0 0.75 m 2.5' 1.5 m 5' 2.25 m 7.5' 3.0 m 10' 3.75 m 12.5' DISTANCE Figure 5. Polarized Retroreflective—Beam Pattern www.bannerengineering.com - Tel: +1-763-544-3164 E X C E S S G A I N DS18...FF100 Fixed-Field 100 10 1 0.1 mm 0.004" 1.0 mm 0.04" 10.0 mm 0.4" 100 mm 4.0" DISTANCE Figure 6. Fixed-Field 100 mm——Excess Gain 3 DS18 Series Sensors Accessories 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 3 4 1 2 3 4 30 Typ. [1.18"] 15.2 m (50 ft) 2 1 32 Typ. [1.26"] Right-Angle MQDC-450RA Pinout (Female) = = = = Brown White Blue Black M12 x 1 ø 14.5 [0.57"] 4-Pin Snap-on M8/Pico-Style Cordsets Model Length Style Dimensions Pinout (Female) 32 Typ. PKG4-2 2 m (6.56 ft) Straight ø 9.0 4 2 1 3 29 Typ. PKW4Z-2 2 m (6.56 ft) Right-Angle 15 Typ. 1 = Brown 2 = White 3 = Blue 4 = Black ø 10.9 Mounting Brackets Retroreflectors SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware See http://www.bannerengineering.com for complete information on retroreflectors. 30 C A 41 B NOTE: Polarized sensors require corner cube-type retroreflectors. 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 See http://www.bannerengineering.com for additional 18 mm barrel mounting bracket options. 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 128911 Rev. H DS18 Series Sensors Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
DS18VP6LPQ 价格&库存
很抱歉,暂时无法提供与“DS18VP6LPQ”相匹配的价格&库存,您可以联系我们找货
DS18VP6LPQ
  • 1+1064.716931+138.18083
