S126EQDP
S126EQDP
    BANNER(邦纳)
    PHOTO SEN EMITTER 15M
S126EQDP 数据手册
EZ-BEAM S12 Series Opposed-Mode Sensor Pairs Datasheet • • • • • • Economical opposed-mode (beam-break) sensor pairs in 12-millimeter diameter barrel-style housings Sensing range of 15 meters (50 feet) Totally self-contained; 10 to 30 V dc operation Complementary outputs: one normally open, one normally closed; choice of NPN (sinking) or PNP (sourcing) configuration, 100 mA max. (continuous) One output may be used as a marginal signal alarm LED status indicators for Power On, Output Overload, Object Sensed, and Low Gain conditions Visible Red, 680 nm Models Cable S126E Emitter S126EQP Emitter 2 m (6.5 ft) 4-Pin Pico QD Output Type - Beam Pattern (Effective beam: 8.1 mm) Excess Gain 1000 S12 Series S12 Series S12SN6RQP Receiver 2 m (6.5 ft) 4-Pin Pico QD S12SP6R Receiver S12SP6RQP Receiver NPN 2 m (6.5 ft) 4-Pin Pico QD EXCESS GAIN 1500 mm S12SN6R Receiver Opposed Mode 100 60 in Opposed Mode 1000 mm 40 in 500 mm 20 in 0 10 0 500 mm 20 in 1000 mm 40 in 1500 mm PNP 60 in 0 1 .1 m .33 ft 1m 3.3 ft 10 m 33 ft 100 m 330 ft 5m 16 ft 10 m 32 ft 15 m 49 ft 20 m 66 ft 25 m 82 ft DISTANCE DISTANCE To order 9 m (30 ft) cable models, add the suffix “W/30” to the model number of any cabled sensor (e.g. - S12SN6R W/ 30). Models with a QD connector requires an accessory mating cable. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Original Document 34501 Rev. B 27 March 2014 34501 EZ-BEAM S12 Series Opposed-Mode Sensor Pairs Specifications Supply Voltage and Current 10 to 30 V dc (10% maximum ripple) Supply current (exclusive of load current): Opposed Mode Emitters: 25 mA; Opposed Mode Receivers: 20 mA Supply Protection Circuitry Protected against reverse polarity and transient voltages Repeatability 375 microseconds; repeatability and response are independent of signal strength Indicators Receivers have two LEDs: green and amber Green solid: power to sensor is “on” Green flashing: output is overloaded (dc models only) Amber solid: normally open output is conducting Amber flashing: excess gain marginal (1–1.5x) in light condition Output Configuration SPDT (complementary) solid-state dc switch; choose NPN (current sinking) or PNP (current sourcing) models. Light operate: N.O. output conducts when the sensor sees the emitter’s Construction modulated light reinforced thermoplastic polyester housings; polycarbonate lenses; Dark operate: N.C. output conducts when the sensor sees dark; The polyurethane end cap N.C. (normally closed) output may be wired as a normally open Environmental Rating marginal signal alarm output, depending upon hookup to the power Leakproof design rated NEMA 6P (IEC IP67) supply (U.S. patent 5087838) Connections Output Rating 2 m (6.5 ft) or 9 m (30 ft) attached PVC-covered 4-wire cable, or a 4100 mA maximum (each) in standard hookup; when wired for alarm pin Pico-style QD output, the total load may not exceed 100 mA Off-state leakage current < 1 microamp at 30 V dc On-state saturation voltage < 1 V at 10 mA dc and < 1.5 V at 150 mA dc Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Response Time 3 milliseconds ON, 1.5 milliseconds OFF 100 millisecond delay on power-up; outputs are non-conducting during this time Operating Conditions Temperature: –40 °C to 70 °C (–40 °F to 158 °F) Maximum relative humidity: 90% at 50 °C (non-condensing) Vibration and Mechanical Shock Meets Mil. Std. 202F requirements. Method 201A (Vibration: frequency 10 to 60 Hz, max., double amplitude 0.06-inch acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for non-operation). Certifications Dimensions Green LED Power Indicator Amber LED Output Indicator 2m 12 x 1 mm Thread (6.5') Cable Jam Nuts (Provided) 4.1 mm 150 mm (6") Pigtail (0.16") 38 mm 59.9 mm (1.5") (2.36") Figure 1. Cabled Models 2 www.bannerengineering.com - tel: 763-544-3164 Figure 2. Pigtail Quick Disconnect Models P/N 34501 Rev. B EZ-BEAM S12 Series Opposed-Mode Sensor Pairs Wiring Diagrams Receivers with NPN Outputs (Standard) 3 2 1 − 10–30 V dc + 1 4 4 Load Load 1 2 Load Receivers with PNP Outputs (Alarm) 3 − 10–30 V dc + 3 4 Alarm Emitters with Quick Disconnect 1 1 3 1 2 3 4 Load 2 Alarm 3 + 10–30 V dc 4 − 2 - Brown White Blue Black - Brown White Blue Black - Brown White Blue Black Key + 10–30 V dc − 1 Load Emitters with Attached Cable 1 2 3 4 Load 2 Load Load Key + 10–30 V dc − 3 Receivers with NPN Outputs (Alarm) 4 Receivers with PNP Outputs (Standard) Key + 10–30 V dc − 1 2 3 4 not used not used Accessories Brackets SMB12MM • 12-gauge, stainless steel, right-angle mounting bracket for barrel-style sensors with 12 mm threads • Curved mounting slot allows the bracket ±10° of lateral movement • Mounting holes accommodate #8 hardware 12.3 mm (0.49") ø 12.3 mm (0.49") 25.4 mm (1.00") 38.1 mm (1.50") 12.7 mm (0.50") R 3.1 mm (0.12") 10 Slot 4.6 mm (0.18") R 24.1 mm (0.95") 42.9 mm (1.69") 20 R 5.1 mm (0.20") ø 4.6 mm (0.18") Hole center spacing: A to B = 26.0 Hole size: A = ø 4.6, B = 12.8 x 4.6, C= ø 12.3 Aperture Kits. SP12 sensors may be fitted with apertures that narrow or shape the effective beam of the sensor and protect the sensor’s lens. These apertures are rectangular or circular thread-on water-tight parts. Use of apertures with SP12 high-gain sensors makes it possible to create very narrow, concentrated sensing beams for precision sensing applications. P/N 34501 Rev. B www.bannerengineering.com - tel: 763-544-3164 3 EZ-BEAM S12 Series Opposed-Mode Sensor Pairs Model Description Dimensions AP12SC Includes lens, o-ring, thread-on housing, and 3 circular apertures with openings of: • 0.5 mm (0.02 inch) diameter • 1.0 mm (0.04 inch) diameter • 2.5 mm (0.10 inch) diameter AP12SR Includes lens, o-ring, thread-on housing, and 3 rectangular apertures with openings of: • 0.5 mm (0.02 inch) wide • 1.0 mm (0.04 inch) wide • 2.5 mm (0.10 inch) wide 4-Pin Snap-on M8/Pico-Style Cordsets Model Length Style PKG4-2 2.00 m (6.56 ft) Straight Dimensions Pinout 32 Typ. 4 3 ø 9.0 PKW4Z-2 2.00 m (6.56 ft) Right-Angle 1 2 3 4 29 Typ. 2 1 = = = = Brown White Blue Black 15 Typ. ø 10.9 Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. www.bannerengineering.com - tel: 763-544-3164
S126EQDP 价格&库存
很抱歉,暂时无法提供与“S126EQDP”相匹配的价格&库存,您可以联系我们找货
