S18-2VNLP-2M
S18-2VNLP-2M
    BANNER(邦纳)
    PHOTO SEN REFLECT 6M NPN
S18-2VNLP-2M 数据手册
S18-2 Plastic 18 mm Barrel Sensors Datasheet Next Generation Self-contained DC-operated Sensors • • • • • • Economical photoelectric sensors for cost sensitive and high volume installations Powerful and bright visible red emitter beam for easy alignment and set-up Highly visible output and dual-function power and stability indicators Wide operating temperature range: –40 °C to +70 °C (–40 °F to +158 °F) Robust 250° adjustment potentiometer on select models Stable detection in the presence of fluorescent lights for non through-beam applications WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Emitter/Receiver Models 1 Model Range S18-2NAEL-2M S18-2NAEJ-2M Emitter S18-2NAES-2M 25 m (82 ft) with beam inhibit S18-2VNRS-2M S18-2VPRS-2M None 25 m (82 ft) with adjustment S18-2VNRL-2M S18-2VPRL-2M Output 25 m (82 ft) 25 m (82 ft) Receiver 25 m (82 ft) with adjustment Complementary NPN Complementary PNP Complementary NPN Complementary PNP Polarized Retroreflective Models 1 Model S18-2VNLP-2M S18-2VPLP-2M S18-2VNLPC-2M S18-2VPLPC-2M Range 6 m (19.7 ft) with BRT-84 reflector 6 m (19.7 ft) with BRT-84 reflector, with adjustment Output Complementary NPN Complementary PNP Complementary NPN Complementary PNP Retroreflective Models 1 Model S18-2VNLV-2M S18-2VPLV-2M Range 7.5 m (24.6 ft) with BRT-84 reflector, with adjustment Output Complementary NPN Complementary PNP 1 Integral 2 m (6.5 ft) unterminated cable models are listed. • To order the 9 m (30 ft) PVC cable model, add the suffix "9M" to the model number. For example, S18-2VNDL-9M. • To order the 4-pin M12/Euro-style integral quick disconnect model, add the suffix "Q8" to the model number. For example, S18-2VNDL-Q8. • To order the 150 mm (6 in) PVC cable model with a 4-pin M12/Euro-style quick disconnect, add the suffix "Q5" to the model number. For example, S18-2VNDL0Q5. • To order the 150 mm (6 in) PVC cable model with a 4-pin M8/Pico-style quick disconnect, add the suffix "Q3" to the model number. For example, S18-VNDL-Q3. Original Document 170670 Rev. J 1 October 2018 170670 S18-2 Plastic 18 mm Barrel Sensors Diffuse Models 1 Model Range S18-2VNDL-2M Output Complementary NPN 750 mm (29.5 in) with adjustment S18-2VPDL-2M S18-2VNDS-2M Complementary PNP Complementary NPN 300 mm (11.8 in) with adjustment S18-2VPDS-2M Complementary PNP Fixed Field Models Model Range S18-2VNFF30-2M Output Complementary NPN 30 mm S18-2VPFF30-2M S18-2VNFF50-2M Complementary PNP Complementary NPN 50 mm S18-2VPFF50-2M S18-2VNFF75-2M Complementary PNP Complementary NPN 75 mm S18-2VPFF75-2M S18-2VNFF100-2M Complementary PNP Complementary NPN 100 mm S18-2VPFF100-2M S18-2VNFF150-2M Complementary PNP Complementary NPN 150 mm S18-2VPFF150-2M S18-2VNFF200-2M Complementary PNP Complementary NPN 200 mm S18-2VPFF200-2M Complementary PNP Installing the S18-2 Sensor To install the S18-2 Sensor: 1. Amber LED Gain adjustment 2. 3. 4. Align the sensor as required for the application. For the most sensitive object detection, align the sensor so that the objects move across the sensor's axis. Secure the sensor to a bracket. Wire sensor as shown in the wiring diagrams. Adjust the gain adjuster (sensitivity pot) if necessary. Green LED Amber LED Figure 1. S18-2 Features and Installation Wiring Diagrams Emitter Emitter with Active High Beam Inhibit Complementary NPN 3 3 1 – 10-30V dc + 3 1 4 − 10-30V dc + 1 10-30V dc 2 4 – 10-30V dc + Load Load Complementary PNP 1 + 10-30V dc – 3 4 2 Load Load Note: Open lead wires must be connected to a terminal block. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 170670 Rev. J S18-2 Plastic 18 mm Barrel Sensors Specifications Supply Voltage 10 V dc to 30 V dc for ambient temperature ≤ 55 °C 10 V dc to 24 V dc for ambient temperature > 55 °C Supply Current (Exclusive of Load Current) Diffuse: 16 mA Opposed Mode Emitters: 17 mA Opposed Mode Receivers: 8 mA Retroreflective and Polarized Retroreflective: 16 mA Fixed Field: 22 mA Output Protection Circuitry Protected against false pulse on power-up and continuous short circuit of outputs. Short circuit protection at elevated temperature may require a power cycle to reset. Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Rating ≤ 50 mA total current for ambient temperatures > 55 °C ≤ 100 mA total current through both outputs ≤ 55 °C OFF-State Leakage Current: < 50 µA at 30 V dc ON-State Saturation Voltage: < 1.5 V at 10 mA; < 3.0 V at 100 mA Output Configuration Complementary PNP or NPN by model number Emitter LED Visible Red Indicators Three LEDs (1 green, 2 amber) Green solid: indicates power applied and sensor ready Green flashing: indicates marginal sensing signal Amber solid: indicates Pin 4 (black wire) output conducting Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration; frequency 10 to 60 Hz, max., double amplitude 0.06 in acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for non-operation) Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) Environmental Rating IEC IP67 Certifications Class 2 power ; UL Environmental Rating: Type 1 P/N 170670 Rev. J Output Response Time Response is independent of signal strength Opposed models: 1.5 milliseconds ON, 1 millisecond OFF Retro, Polarized Retro, and Diffuse models: 1.5 milliseconds ON, 0.75 milliseconds OFF Fixed Field models: 2 milliseconds ON, 2 milliseconds OFF Delay on Power-up: 100 milliseconds; outputs do not conduct during this time Repeatability Repeatability is independent of signal strength Opposed models: 170 microseconds Retro, Polarized Retro, and Diffuse models: 100 microseconds Fixed Field models: 200 microseconds Adjustments Diffuse (DL, DS), Emitter (ES), Receiver (RS), Polarized Retroreflective (LPC), Retroreflective (LV) models: Single turn sensitivity (gain) adjustment potentiometer Emitter Beam Inhibit (EJ) models: Tie black wire to 10 to 30 V dc for beam inhibit Construction Housing, connector, gain pot driver: ABS Front window: PMMA Indicator windows: Clear ABS Mounting nuts: 30% glass filled PBT Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 www.bannerengineering.com - Tel: +1-763-544-3164 3 S18-2 Plastic 18 mm Barrel Sensors Performance Curves Diffuse Models (300 mm Range) Beam Pattern Excess Gain 20 15 5 0 EXCESS GAIN BEAM PATTERN (mm) 1000 10 −5 −10 100 10 −15 −20 0 50 10 0 15 0 20 0 25 0 30 0 35 0 1 40 0 DISTANCE (mm) 10 1 100 DISTANCE (mm) 1000 Diffuse Models (750 mm Range) Beam Pattern Excess Gain 100 10 EXCESS GAIN BEAM PATTERN (mm) 15 5 0 -5 10 - 10 - 15 0 100 200 300 400 500 600 700 800 1 DISTANCE (mm) 1 10 100 1000 DISTANCE (mm) Emitter/Receiver Models (Effective Beam Size: 15.2 mm) Beam Pattern Excess Gain EXCESS GAIN BEAM PATTERN (mm) 1000 1000 800 600 400 200 0 - 200 - 400 - 600 - 800 - 1000 0 5 10 15 DISTANCE (m) 20 25 100 10 1 0.1 1 10 100 DISTANCE (m) 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 170670 Rev. J S18-2 Plastic 18 mm Barrel Sensors Polarized Retroreflective Models Beam Pattern Excess Gain 100 BRT-92x92C BRT-84 BRT-60x40C BRT-40x19A BRT-60x40IP BRT-THG-2-100 40 EXCESS GAIN BEAM PATTERN (mm) 60 20 0 - 20 10 - 40 - 60 0 1 2 3 4 5 6 DISTANCE (m) 1 0.01 0.1 1 10 DISTANCE (m) Retroreflective Models Beam Pattern Excess Gain 100 BRT-92x92C BRT-84 BRT-60x40C BRT-40x19A BRT-60x40IP BRT-THG-2-100 80 40 EXCESS GAIN BEAM PATTERN (mm) 60 20 0 -20 10 -40 -60 -80 0 1 2 3 4 5 DISTANCE (m) 6 7 8 1 0.01 0.1 1 10 DISTANCE (m) P/N 170670 Rev. J www.bannerengineering.com - Tel: +1-763-544-3164 5 S18-2 Plastic 18 mm Barrel Sensors Fixed Field Models - Excess Gain Target for Excess Gain Curves use a 90% Reflective White Card 1000 100 EXCESS GAIN EXCESS GAIN 1000 10 100 10 1 1 10 100 1000 1 DISTANCE (mm) 1 10 100 1000 DISTANCE (mm) S18-2FF30 S18-2FF50 Emitter Image Size: 4.0 mm square at 15 mm and 3.5 mm square at 30 mm Emitter Image Size: 4 mm square at 25 mm and 3 mm square at 50 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 18% Gray Test Card: Cutoff distance will be 98% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 100 100 EXCESS GAIN 1000 EXCESS GAIN 1000 10 1 1 10 100 10 1 1000 1 DISTANCE (mm) 10 100 1000 DISTANCE (mm) S18-2FF75 S18-2FF100 Emitter Image Size: 4.5 mm square at 37 mm and 4.0 mm square at 75 Emitter Image Size: 4.5 mm square at 50 mm and 4.5 mm square at mm 100 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 18% Gray Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 90% of value shown 6 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 170670 Rev. J S18-2 Plastic 18 mm Barrel Sensors Fixed Field Models - Excess Gain Target for Excess Gain Curves use a 90% Reflective White Card 1000 EXCESS GAIN EXCESS GAIN 1000 100 10 100 10 1 1 1 10 100 1 1000 10 100 1000 DISTANCE (mm) DISTANCE (mm) S18-2FF150 S18-2FF200 Emitter Image Size: 5 mm square at 75 mm and 8 mm square at 150 mm Emitter Image Size: 5 mm square at 100 mm and 8 mm square at 200 mm 18% Gray Test Card: Cutoff distance will be 90% of value shown 18% Gray Test Card: Cutoff distance will be 85% of value shown 6% Black Test Card: Cutoff distance will be 70% of value shown 6% Black Test Card: Cutoff distance will be 60% of value shown Dimensions Cable Models 13.1 mm [0.51”] QD Models 73 mm [2.87”] 64 mm [2.52”] 63.5 mm [2.50”] M12 x 1 45.3 mm [1.78”] M18 x 1 16.7 mm [0.66”] 16.3 mm dia [0.64”] M18 x 1 - 6g Knurled Nut (2) Maximum Torque: 2.3 N∙m (20 in-lbs) All measurements are listed in millimeters [inches], unless noted otherwise. Accessories Cordsets All measurements are listed in millimeters, unless noted otherwise. P/N 170670 Rev. J www.bannerengineering.com - Tel: +1-763-544-3164 7 S18-2 Plastic 18 mm Barrel Sensors 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 15.2 m (50 ft) 2 1 3 4 32 Typ. [1.26"] 1 = Brown 2 = White 3 = Blue 4 = Black 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) M12 x 1 ø 14.5 [0.57"] 4-Pin Threaded M8/Pico-Style Cordsets Model Length PKG4M-2 2 m (6.56 ft) PKG4M-5 5 m (16.4 ft) PKG4M-9 9 m (29.5 ft) Style Dimensions Pinout (Female) 35 Typ. Straight ø 9.5 M8 x 1 PKW4M-2 2 m (6.56 ft) PKW4M-5 5 m (16.4 ft) PKW4M-9 2 1 3 28 Typ. 20 Typ. Right Angle 4 9 m (29.5 ft) 1 = Brown 2 = White 3 = Blue 4 = Black M8 x 1 ø 9.5 Apertures 8 Model Units Aperture Description AP18SCN 3 Kit includes round apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) diameter. AP18SRN 3 Kit includes rectangular apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) wide. Each kit also includes a thread-on housing, Teflon® FEP® lens, and o-ring. APG18S 1 Kit with glass lens to protect plastic sensor lens from chemical environments and weld splatter damage. Product www.bannerengineering.com - Tel: +1-763-544-3164 P/N 170670 Rev. J S18-2 Plastic 18 mm Barrel Sensors Brackets SMB18SF • 18 mm swivel bracket with M18 × 1 internal thread • Black thermoplastic polyester • Stainless steel swivel locking hardware included 51 B SMBS18-2-1 • 30% glass-filled PBT M18 - 1 x 6G 42 4.5 ø28 25 A Hole center spacing: A = 36.0 Hole size: A = ø 5.3, B = ø 18.0 SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 30 C A 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 B 41 SMB18FA.. • Swivel bracket with tilt and pan movement for precision adjustment • Easy sensor mounting to extruded rail T-slots • Metric and inch size bolts available • 18 mm sensor mounting hole 66 B 69 A Hole size: B=ø 18.1 Model Bolt Thread (A) SMB18FA 3/8 - 16 × 2 in SMB18FAM10 M10 - 1.5 × 50 SMB18FAM12 n/a; no bolt included. Mounts directly to 12 mm (½ in) rods For additional brackets, check the current Banner catalog or visit www.bannerengineering.com. All measurements are listed in millimeters, unless noted otherwise. Reflectors BRT-2X2 • • • • • Square, acrylic target Reflectivity factor: 1.0 Max. temperature: +50 °C (+122 ºF) Optional brackets are available Approximate size: 51 mm × 51 mm BRT-40X19A • Rectangular, acrylic target • Reflectivity Factor: 1.3 • Temperature: –20 °C to +60 °C (– 4 °F to +140 °F) • Approximate size: 19 mm × 60 mm overall; 19 mm × 40 mm reflector P/N 170670 Rev. J BRT-84X84A • • • • Square, acrylic target Reflectivity Factor: 2.0 Temperature: –20 °C to +60 °C (– 4 °F to +140 °F) Approximate size: 84 mm × 84 mm BRT-60X40C • Rectangular, acrylic target • Reflectivity Factor: 1.4 • Temperature: –20 °C to +60 °C (– 4 °F to +140 °F) • Optional brackets are available • Approximate size: 40 mm × 60 mm www.bannerengineering.com - Tel: +1-763-544-3164 9 S18-2 Plastic 18 mm Barrel Sensors BRT-84 • Round, acrylic target • Reflectivity Factor: 1.4 • Temperature: –20 °C to +60 °C (– 4 °F to +140 °F) • Optional brackets are available • Size: 84 mm diameter • Mounting Hole: 4.5 mm diameter Retroreflective Tape Model Reflectivit y Factor Maximum Temperature Size BRTTHG-2-100 0.7 +60 °C (+140 °F) 50 mm (2 in) wide, 2.5 m (100 in) long Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
S18-2VNLP-2M 价格&库存
很抱歉,暂时无法提供与“S18-2VNLP-2M”相匹配的价格&库存,您可以联系我们找货
S18-2VNLP-2M
  • 1+769.469021+99.44010
库存:10
