WSE26P-24162100A00
WSE26P-24162100A00
    SICK
    SENSOR THRU-BEAM 60M NPN/PNP
WSE26P-24162100A00 数据手册
Product data sheet WSE26P-24162100A00 W26 COMPACT PHOTOELECTRIC SENSORS WSE26P-24162100A00 | W26 COMPACT PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WSE26P-24162100A00 1088335 Other models and accessories www.sick.com/W26 Illustration may differ Detailed technical data Features Sensor/ detection principle Through-beam photoelectric sensor Dimensions (W x H x D) 24.6 mm x 82.5 mm x 53.3 mm Housing design (light emission) Rectangular Sensing range max. 0 m ... 60 m Type of light Visible red light Light source PinPoint LED 1) Light spot size (distance) Ø 115 mm (15 m) Wave length 635 nm Adjustment IO-Link For configuring the sensor parameters and Smart Task functions Wire/pin For activating the test input Indication LED blue BluePilot: Alignment aid LED green Operating indicator Static: power on Flashing: IO-Link mode LED yellow Status of received light beam Static: object not present Static off: object present Flashing: Below the 1.5 function reserve 1) 2  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-18 16:08:35 Subject to change without notice WSE26P-24162100A00 | W26 COMPACT PHOTOELECTRIC SENSORS Pin 2 configuration 1) External Input (test), Teach-in, switching signal  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WSE26P-24162100A00 价格&库存
很抱歉,暂时无法提供与“WSE26P-24162100A00”相匹配的价格&库存,您可以联系我们找货
