VSM-2M5APD10-Q7
VSM-2M5APD10-Q7
    BANNER(邦纳)
    VSM-2 SERIES: 5 MM THREADED BARR
VSM-2M5APD10-Q7 数据手册
VSM-2 Series Micro Sensor Datasheet Miniature self-contained sensor in a stainless steel housing • • • • • • Available with 4 mm diameter smooth barrel or 5 mm threaded barrel for mounting in the smallest spaces Diffuse and opposed mode sensing options to meet a wide variety of application requirements IO-Link communication for remote configuration and monitoring, simple device replacement, and advanced diagnostics Visible red beam for easy alignment Dual color LED indicator for clear visualization of sensor status Focused beam allows for reliable presence detection even when the sensor is fully embedded within the machine WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or de-energized (off) output condition. Models with a 4 mm Smooth Barrel Opposed Mode Models must be purchased in pairs: one emitter and one receiver NPN Models PNP Models with IO-Link Emitter Models Range VSM-2S4RNR500-2M VSM-2S4RPR500-2M VSM-2S4NAEL-2M VSM-2S4RNR500-Q3 VSM-2S4RPR500-Q3 VSM-2S4NAEL-Q3 VSM-2S4RNR500-Q7 VSM-2S4RPR500-Q7 VSM-2S4NAEL-Q7 Output Type Connection 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 500 mm (0 to 19.7 in) DO 150 mm (6 in) PUR cable with a 3-pin M8/Picostyle quick disconnect Integral 3-pin M8/Pico-style quick disconnect Diffuse Mode Models NPN Models PNP Models with IO-Link VSM-2S4AND10-2M VSM-2S4APD10-2M VSM-2S4AND10-Q3 VSM-2S4APD10-Q3 VSM-2S4AND10-Q7 VSM-2S4APD10-Q7 VSM-2S4AND20-2M VSM-2S4APD20-2M VSM-2S4AND20-Q3 VSM-2S4APD20-Q3 VSM-2S4AND20-Q7 VSM-2S4APD20-Q7 VSM-2S4AND50-2M VSM-2S4APD50-2M VSM-2S4AND50-Q3 VSM-2S4APD50-Q3 VSM-2S4AND50-Q7 VSM-2S4APD50-Q7 VSM-2S4AND100-2M VSM-2S4APD100-2M VSM-2S4AND100-Q3 VSM-2S4APD100-Q3 Range Output Type Connection 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 10 mm (0 to 0.39 in) 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect Integral 3-pin M8/Pico-style quick disconnect 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 20 mm (0 to 0.79 in) 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect LO Integral 3-pin M8/Pico-style quick disconnect 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 50 mm (0 to 2 in) 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect Integral 3-pin M8/Pico-style quick disconnect 2 m (6.5 ft) unterminated 4-wire PUR-jacketed cable 0 to 100 mm (0 to 4 in) 150 mm (6 in) PUR cable with a 4-pin M8/Pico-style quick disconnect Models with a 5 mm Threaded Barrel Opposed Mode Models must be purchased in pairs: one emitter and one receiver NPN Models PNP Models with IO-Link Emitter Models Range VSM-2M5RNR500-2M VSM-2M5RPR500-2M VSM-2M5NAEL-2M VSM-2M5RNR500-Q3 VSM-2M5RPR500-Q3 VSM-2M5NAEL-Q3 VSM-2M5RNR500-Q7 VSM-2M5RPR500-Q7 VSM-2M5NAEL-Q7 Original Document 211301 Rev. B Output Type Connection 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 500 mm (0 to 19.7 in) DO 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect Integral 3-pin M8/Pico-style quick disconnect 7 February 2020 211301 VSM-2 Series Micro Sensor Diffuse Mode Models NPN Models PNP Models with IO-Link VSM-2M5AND10-2M VSM-2M5APD10-2M VSM-2M5AND10-Q3 VSM-2M5APD10-Q3 VSM-2M5AND10-Q7 VSM-2M5APD10-Q7 VSM-2M5AND20-2M VSM-2M5APD20-2M VSM-2M5AND20-Q3 VSM-2M5APD20-Q3 VSM-2M5AND20-Q7 VSM-2M5APD20-Q7 VSM-2M5AND50-2M VSM-2M5APD50-2M Range Output Type Connection 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect 0 to 10 mm (0 to 0.39 in) Integral 3-pin M8/Pico-style quick disconnect 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 20 mm (0 to 0.79 in) 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect LO Integral 3-pin M8/Pico-style quick disconnect 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable 0 to 50 mm (0 to 2 in) VSM-2M5AND50-Q3 VSM-2M5APD50-Q3 VSM-2M5AND50-Q7 VSM-2M5APD50-Q7 VSM-2M5AND100-2M VSM-2M5APD100-2M VSM-2M5AND100-Q3 VSM-2M5APD100-Q3 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect Integral 3-pin M8/Pico-style quick disconnect 2 m (6.5 ft) unterminated 4-wire PUR-jacketed cable 0 to 100 mm (0 to 4 in) 150 mm (6 in) PUR cable with a 4-pin M8/Pico-style quick disconnect Wiring Emitters PNP/IO-Link Models bn bn (1) + bk bu (3) + 10–30 V dc – bu 10–30 V dc bu (3) Load – 10–30 V dc + bn (1) bk (4) PNP/IO-Link Load – Integral 3-pin M8/Pico-style quick disconnect (male) Models 4 1 NPN Models 3 Key 1 - Brown 2 - White 3 - Blue 4 - Black Integral 4-pin M8/Pico-style male quick disconnect Models PNP/IO-Link Models PUSH-PULL + CH1 10–30 V dc Load 3 2 4 1 3 NPN Models 1 4 2 – CH2 Remote Input 1 3 4 + 10-30V dc – Load 2 Remote Input Remote Configuration Instructions—100 mm Diffuse Mode Models Only One-Point TEACH A one-point TEACH sets the threshold for ON/OFF using a single target. A target that returns the same or more light to the sensor turns the output ON. A target that returns less light than the configured target turns the output OFF. 1. Position the target. 2. Hold the remote input wire (white) high for 1 to 3 seconds. 3. Release the remote input wire before 3 seconds. The amber LED is on for 3 seconds, indicating a valid configuration. After the configuration, the green/output LED is on. When presenting a darker target than the one that was configured, the amber LED turns on as the threshold is approached. With a darker target, the green/output LED is off. Two-Point TEACH A two-point TEACH sets the threshold between two different targets. A target that returns the same or more light to the sensor turns the output ON. A target that returns less light than the configured target turns the output OFF. 1. Position the target at the desired ON condition. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 211301 Rev. B VSM-2 Series Micro Sensor 2. Hold the remote input wire (white) high for 6 to 15 seconds to teach the ON condition. The amber LED flashes for 3 seconds while the remote input wire is held high, turns off for 3 seconds, and then begins flashing again at 6 seconds. 3. Release remote input wire before 15 seconds. 4. Position the target at the desired OFF condition. 5. Hold the remote input wire high for 1 second. The amber LED is on for 3 seconds, indicating a valid configuration. The green/output LED and the sensor output are OFF. A moving target causes the amber LED to turn on as the target reaches the threshold. After the target is at or above the threshold, the green/output LED and the sensor output are ON. Specifications Supply Voltage and Current 10 to 30 V dc (10% maximum ripple) Less than 12 mA consumption without load Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Single-output: 1 NPN or 1 PNP/IO-Link; light operate (LO) or dark operate (DO), depending on model Response Time Normal Mode: Less than 500 µs (default) Fine Mode: Less than 1 ms (selectable via IO-Link) Fast Mode: Less than 200 µs (selectable via IO-Link) Switching Frequency Normal Mode: Less than 1 kHz (default) Fine Mode: Less than 500 Hz (selectable via IO-Link) Fast Mode: Less than 2.5 kHz (selectable via IO-Link) Output Rating Current: Less than 100 mA PNP On Voltage: Supply voltage – 2 V PNP Off Voltage: Approximately 0 V NPN On Voltage: Supply voltage NPN Off Voltage: < 2.0 V Output Protection Circuitry Protected against false power-up and continuous overload or short circuit of outputs Overload trip point ≥ 100 mA Light Source Opposed, Diffuse: 630 nm red LED Delay at Power-Up 20 milliseconds Repeatability 1 millisecond Indicators Green/output LED: Output is conducting Amber LED: Marginal signal or near threshold of the sensor (ON to OFF or OFF to ON) Light Spot Size Diffuse: 5 mm dia (at 10 mm), 8 mm (at 20 mm), and 20 mm (at 50 mm) Opposed: 50 mm dia (at 200 mm) Required Overcurrent Protection Construction V2A stainless steel with PUR cable; PBT/PMMA optics Environmental Rating IEC IP67 Connection 2 m (6.5 ft) unterminated 3-wire PUR-jacketed cable; 150 mm (6 in) PUR cable with a 3-pin M8/Pico-style quick disconnect; Integral 3-pin M8/Pico-style quick disconnect; 2 m (6.5 ft) unterminated 4-wire PUR-jacketed cable; or 150 mm (6 in) PUR cable with a 4-pin M8/Pico-style quick disconnect, depending on the model Operating Conditions –25 °C to +65 °C (–13 °F to +149 °F) Vibration and Mechanical Shock IEC 60947-5-2 Certifications WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Dimensions All measurements are listed in millimeters, unless noted otherwise. Connector Models Cable Models Pigtail Models (threaded) (threaded) (threaded) (non-threaded) (non-threaded) (non-threaded) P/N 211301 Rev. B www.bannerengineering.com - Tel: + 1 888 373 6767 3 VSM-2 Series Micro Sensor Performance Curves Opposed Models Diffuse, 10 mm Range Models 10000 100 Excess Gain Excess Gain 1000 100 10 0 0 100 200 300 400 500 10 0 600 0 2 4 Distance (mm) Diffuse, 20 mm Range Models 10 12 40 50 60 100 Excess Gain Excess Gain 8 Diffuse, 50 mm Range Models 100 10 0 6 Distance (mm) 0 5 10 15 20 25 30 10 0 0 10 Distance (mm) 20 30 Distance (mm) Diffuse, 100 mm Range Models Excess Gain 100 10 0 0 20 40 60 80 100 120 Distance (mm) Accessories Brackets All measurements are listed in millimeters, unless noted otherwise. SMBVSM4 • Mounting clamp for 4 mm barrel-style sensors • Black impact-resistant plastic Hole center spacing: A = 8.0 Hole size: A = ø 3.3 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 211301 Rev. B VSM-2 Series Micro Sensor Cordsets All measurements are listed in millimeters, unless noted otherwise. 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2 m (6.56 ft) PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 9 m (29.53 ft) PKG3M-10 10 m (32.81 ft) PKW3M-2 2 m (6.56 ft) PKW3M-5 5 m (16.40 ft) Style Dimensions 35 Typ. Straight ø 9.5 M8 x 1 4 1 3 28 Typ. 1 = Brown 3 = Blue 4 = Black 20 Typ. Right-Angle PKW3M-9 Pinout (Female) 9 m (29.53 ft) M8 x 1 ø 9.5 4-Pin Threaded M8/Pico-Style Cordsets—Single Ended Model Length PKG4M-2 2 m (6.56 ft) PKG4M-5 5 m (16.4 ft) PKG4M-9 9 m (29.5 ft) Style Dimensions Pinout (Female) 35 Typ. Straight ø 9.5 M8 x 1 PKW4M-2 2 m (6.56 ft) PKW4M-5 5 m (16.4 ft) PKW4M-9 20 Typ. 9 m (29.5 ft) 2 1 3 28 Typ. Right Angle 4 1 = Brown 2 = White 3 = Blue 4 = Black M8 x 1 ø 9.5 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
VSM-2M5APD10-Q7 价格&库存
很抱歉,暂时无法提供与“VSM-2M5APD10-Q7”相匹配的价格&库存,您可以联系我们找货
VSM-2M5APD10-Q7
  • 1+2424.393801+315.09810
库存:2
