D10AFPQ5
D10AFPQ5
    BANNER(邦纳)
    D10AFPQ5 QD 4 PIN EURO RED
D10AFPQ5 数据手册
D10—Discrete Output Datasheet Low-cost, 10 to 30 V dc Sensor for use with Plastic Fiber Optics • Models available with visible red (660 nm) or visible green (525 nm) LED light source Sleek, ultra-slim 10 mm housing, mounts to standard 35 mm DIN rail Solid-state, bipolar discrete outputs: one current sourcing (PNP) and one current sinking (NPN) High-speed models: 200-microsecond output response Standard models: 500-microsecond output response plus crosstalk-avoidance circuitry (for applications with multiple sensors) Selectable Light/Dark Operate and 40 millisecond pulse stretcher (OFF-delay), via two easy-to-operate slide switches 12-turn Sensitivity adjustment with relative position indicator LED status indicators for Power ON and Light Sensed (AID™) indication Models available with integral cable or Pico-style quick-disconnect • • • • • • • • WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Red Beam (660 nm) Green Beam (525 nm) Response Time Cable1 Output Type D10AFP D10AFPG 500 microseconds 4-conductor 2 m (6.5 ft) Cable Bipolar NPN/PNP Solid-state D10AFPQ D10AFPGQ D10AFPY D10AFPGY D10AFPYQ D10AFPGYQ 4-pin Pico-style QD 200 microseconds 4-conductor 2 m (6.5 ft) Cable 4-pin Pico-style QD Features 12-Turn Sensitivity (Gain) Control and Indicator Green Power ON LED Turn Sensitivity control clockwise to increase Gain LO DO DELAY 0 ms 40 ms + Delay Selector Switch LO/DO Select Switch Yellow Signal Strength LED LED flashes to indicate received signal strength 1 To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, D10AFP W/30. Models with a quick disconnect require a mating cordset. Original Document 118431 Rev. B 14 November 2016 118431 D10—Discrete Output Installation Installing Fibers and Housing Installing Fibers Mounting the D10 on a DIN Rail or the Mounting Bracket Slides up to release fibers Plastic fiber emitter port Plastic fiber receiver port DIN Rail (or included mounting bracket) Wiring Diagram Key 1 + 10-30V dc – 3 2 4 2 Load 1 2 3 4 = = = = Brown White Blue Black NOTE: Quick disconnect (QD) wiring diagrams are functionally identical. Load 100 mA maximum load www.bannerengineering.com - Tel: +1-763-544-3164 P/N 118431 Rev. B D10—Discrete Output Specifications Sensing Beam Visible red, 660 nm or Visible green, 525 nm , depending on model Supply Voltage 10 to 30 V dc (10% max. ripple) at less than 25 mA, exclusive of load Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: 1 current sourcing (PNP) and 1 current sinking (NPN) Output Rating 100 mA per output with short circuit protection OFF-state leakage current: < 10 μA sourcing; 200 μA sinking ON-state saturation voltage: NPN: 1.6 V at 100 mA PNP: 2.0 V at 100 mA Construction Black ABS/polycarbonate alloy (UL94 V-0 rated) housing, clear polycarbonate cover Environmental Rating IEC IP50, NEMA 1 Connections 2 m or 9 m (6.5 ft or 30 ft) attached cable, or 4-pin Pico-style quickdisconnect fitting; cables for QD models are purchased separately Operating Conditions Operating Temperature: −10 °C to +55 °C (+14 °F to +131 °F) Storage Temperature: −20 °C to +85 °C (−4 °F to +185 °F) 90% at +55 °C maximum relative humidity (non-condensing) Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Output Protection Protected against output short-circuit and false pulse on power up NOTE: Maximum 100 ms delay on power up; outputs do not conduct during this time Output Response Time Standard models (with crosstalk avoidance circuitry): 500 microseconds High-speed models: 200 microseconds Repeatability Standard models: 95 microseconds High-speed models: 50 microseconds Adjustments 12-turn Sensitivity potentiometer with relative position indicator; LO/DO Selection switch; 0 or 40 ms off delay switch NOTE: Use proper ESD techniques while making adjustments under cover. Indicators Two LEDs: Green and Amber Green ON steady: Power ON Amber flashing: Light Sensed Signal strength indicator (Banner’s AID™ Alignment Indicating Device—the faster the flash, the more light is received) P/N 118431 Rev. B Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications www.bannerengineering.com - Tel: +1-763-544-3164 3 D10—Discrete Output Dimensions 10.5 ± 0.2 mm (typ.) (0.41") 35.9 mm (1.41") 7.6 mm 0.30" 9.8 mm (0.39") Mounting Bracket (included) 61.3 mm (2.42") 68.1 mm (2.68") All measurements are listed in millimeters [inches], unless noted otherwise. Included Bracket Dimensions 8.6 mm (0.34") 10.0 mm (0.39") 5.0 mm (0.20") 35.1 mm (1.38") 15.2 mm (0.60") 5.0 mm (0.20") 2x 3.5 mm (0.14") M3 Hardware included: Lock Washer (2) Flat Washer (2) Screws (2) Hex Nuts (2) 2.5 mm (0.10") 25.4 mm (1.00") 16.0 mm (0.63") 2 x ø3.3 mm (0.13") 10.0 mm (0.39") 4 2x ø3.2 mm (0.13") 2x C'sink ø8.0 mm (0.31") 3.2 mm (0.13") deep ø4.4 mm (0.18") thru www.bannerengineering.com - Tel: +1-763-544-3164 P/N 118431 Rev. B D10—Discrete Output Performance Curves Opposed Mode Red Beam Models High-Speed Red Beam Models 1000 1000 D10AFP Opposed Mode Red with PIT..U Fiber 100 G A I N E X C E S S 10 G A I N PIT46U PIT16U 1 1 mm (.04") PIT66U PIT26U 10 mm (0.4") 100 mm (4.0") PIT16U PIT26U 10 mm (0.4") (0.6") 15 mm (0.4") 10 mm (0.2") PIT16U 0 D10AFG.. 35 mm (1.4") 45 mm (1.8") 60 mm (0.4") 40 mm (0.2") 0 Opposed Mode Green with PIT..U Fiber PIT66U 20 mm (2.4") (1.6") (0.8") 0 0 PIT26U PIT46U -20 mm (0.8") -10 mm (0.4") -40 mm (1.6") (0.6") -60 mm (2.4") 0 60 mm (2.4") 10 mm (0.4") 20 mm (0.8") 30 mm (1.2") 40 mm (1.6") 0 50 mm (1.9") 30 mm (1.2") 60 mm (2.4") 90 mm (3.5") 120 mm 150 mm (4.7") (5.9") DISTANCE DISTANCE D10AFPY D10AFP Opposed Mode Red with PIT..U Fiber (5.9") (3.9") PIT66U 50 mm (1.9") PIT46U 0 0 -50 mm (1.9") -100 mm (3.9") -150 mm (5.9") 100 mm (3.9") 200 mm (7.9") 300 mm (11.8") Opposed Mode Red with PIT..U Fiber 90 mm (3.5") 60 mm Beam Width Beam Width (0.6") -15 mm DISTANCE 0 PIT26U PIT16U 0 1000 mm (40.0") DISTANCE Opposed Mode Red with PIT..U Fiber 5 mm 100 mm (4.0") (0.6") -15 mm 25 mm (0.98") 10 mm (0.4") (0.4") -10 mm 100 mm 1000 mm (40.0") PIT66U PIT26U 1 1 mm (.04") (0.2") (0.2") 150 mm PIT46U 10 -5 mm -5 mm 15 mm (0.6") Beam Width Beam Width PIT26U 5 mm 0 100 mm (4.0") 100 D10AFPY D10AFP 0 PIT66U PIT46U D10AFPG D10AFPGY Opposed Mode Green with PIT..U Fiber DISTANCE Opposed Mode Red with PIT..U Fiber 10 mm G A I N 10 DISTANCE 15 mm E X C E S S 100 1 1 mm (.04") 1000 mm (40.0") 1000 D10AFPY Opposed Mode Red with PIT..U Fiber Beam Width E X C E S S Green Beam Models (2.4") 30 mm (1.2") PIT66U PIT46U 0 0 -30 mm (1.2") -60 mm (2.4") -90 mm 400 mm 500 mm (15.7") (19.8") (3.5") 0 DISTANCE 100 mm (3.9") 200 mm (7.9") 300 mm (11.8") 400 mm 500 mm (15.7") (19.8") DISTANCE Diffuse Mode Red Beam Models High-Speed Red Beam Models 1000 E X C E S S G A I N D10AFP Diffuse Mode Red with PBT..U fibers 100 10 PBT46U PBT26U 1 1 mm (.04") 10 mm (0.4") 100 mm (4.0") DISTANCE P/N 118431 Rev. B 1000 mm (40.0") 1000 1000 E X C E S S G A I N PBT66U Green Beam Models D10AFPY Diffuse Mode Red with PBT..U fibers 100 G A I N 10 PBT66U PBT26U 1 1 mm (.04") PBT46U 10 mm (0.4") 100 mm (4.0") E X C E S S 1000 mm (40.0") DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 D10AFPG.. Diffuse Mode Green with PBT..U fibers 100 10 PBT46U PBT46U 1 1 mm (.04") 10 mm (0.4") 100 mm (4.0") 1000 mm (40.0") DISTANCE 5 D10—Discrete Output PBT66U Beam Width 60 mm 30 mm PBT46U PBT26U (2.4") 80 mm (1.2") 0 0 120 mm (4.7") (3.1") 25 mm (1.6") PBT26U 0 0 -80 mm (3.5") -120 mm -90 mm 90 mm (3.5") 35 mm (2.4") -60 mm 60 mm (2.4") PBT46U 40 mm 0 150 mm (5.9") 25 mm (0.98") 50 mm (1.9") 75 mm (2.9") 100 mm (3.9") Green Beam Models (4.7") (1.6") (1.2") 30 mm (1.2") PBT66U -40 mm -30 mm 0 D10AFPY Diffuse Mode Red with PBT..U Fiber 120 mm (3.5") Beam Width D10AFP Diffuse Mode Red with PBT..U Fiber 90 mm High-Speed Red Beam Models Beam Width Red Beam Models 15 mm (1.4") PBT46U (0.9") (0.6") PBT46U 0 0 -15 mm (0.6") (3.1") -25 mm (0.9") (4.7") -35 mm (1.4") 125 mm (4.9") 0 DISTANCE DISTANCE D10AFPG.. Diffuse Mode Green with PBT..U Fiber 10 mm (0.4") 20 mm (0.8") 30 mm (1.2") 40 mm (1.6") 50 mm (1.9") DISTANCE Accessories 4-Pin Snap-on M8/Pico-Style Cordsets Model Length Style Dimensions Pinout (Female) 32 Typ. PKG4-2 2 m (6.56 ft) Straight ø 9.0 4 2 1 3 29 Typ. PKW4Z-2 2 m (6.56 ft) Right-Angle 15 Typ. 1 = Brown 2 = White 3 = Blue 4 = Black ø 10.9 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
D10AFPQ5
物料型号:D10AFP, D10AFPG, D10AFPQ, D10AFPGQ, D10AFPY, D10AFPGY
器件简介: - 低成本,适用于塑料光纤的10至30伏直流传感器。 - 有可见红光(660纳米)或可见绿光(525纳米)的LED光源型号。 - 时尚超薄10毫米外壳,可安装在标准的35毫米DIN导轨上。
引脚分配:4针Pico式快速断开或4芯2米(6.5英尺)电缆。
参数特性: - 固态双极性离散输出:一个电流源(PNP)和一个电流汇(NPN)。 - 高速型号:200微秒输出响应。 - 标准型号:500微秒输出响应及串扰避免电路(适用于多传感器应用)。 - 可选择的亮/暗操作和40毫秒脉冲拉伸器(关闭延迟),通过两个易于操作的滑动开关。 - 12转灵敏度调整和相对位置指示器。 - 电源和光感LED状态指示器。
功能详解: - 通过两个滑动开关选择亮/暗操作模式和延迟时间。 - 通过顺时针旋转灵敏度控制来增加增益。 - 绿色LED指示电源开启,琥珀色LED闪烁表示接收到的信号强度。
应用信息: - 警告:不要将此设备用作人员保护的感应设备,可能会导致严重的伤害或死亡。
封装信息: - ABS/聚碳酸酯合金(UL94 V-0级)外壳,透明聚碳酸酯盖。 - 环境等级:IEC IP50,NEMA 1。 - 连接:2米或9米(6.5英尺或30英尺)的附加电缆,或4针Pico式快速断开配件。
D10AFPQ5 价格&库存
很抱歉,暂时无法提供与“D10AFPQ5”相匹配的价格&库存,您可以联系我们找货
D10AFPQ5
  • 1+1636.073251+211.43318
库存:5
