S18SP6LP W/30
S18SP6LP W/30
    BANNER(邦纳)
    RANGE: 2 M; INPUT: 10-30 V DC
S18SP6LP W/30 数据手册
Compact Sensors PHOTOELECTRICS Compact Sensors WORLD-BEAM® QS18 ............................... page 66 • Universal photoelectric family offers 18 mm threaded lens or side mounts. • One sensor family replaces hundreds of other sensor styles. • One housing design fulfills all mounting requirements. • All sensing modes are available including laser, fiber optic and ultrasonic. • Ranges are up to 30 m. ng Comoin! So • A wide variety of connecting options are available. • QS18 Expert™ visible red diffuse and plastic fiber optic models will be available soon—contact factory or visit www.bannerengineering.com for more information. MINI-BEAM®. . . . . page 75 M18 . . . . . . . . . . page 92 • Extensive family in all sensing modes and ranges to 30 m • Expert™ push-button teachable models • Models for special needs—clear plastic detection, NAMUR outputs • World’s most popular photoelectric • Rugged 18 mm stainless steel threaded barrels • Opposed, polarized, non-polarized retroreflective, diffuse and fixed-field modes • Dual LED indicators • Specially designed EZ-BEAM ® style optics and electronics for reliable sensing without adjustments T18. . . . . . . . . . . page 98 QH23/Q23 . . . . . . page 88 • Right-angle, T-shaped package • Specialized fixed-field and polarized retroreflective models • Specially designed EZ-BEAM® style optics and electronics for reliable sensing without adjustments • Models for ac or dc power • Choice of vertical or horizontal housing • High power in a small package • Ranges to 8 m • Five sensing modes including polarized retroreflective S18 . . . . . . . . . . . page 92 Q25 . . . . . . . . . page 103 • 18 mm threaded plastic barrels • Specialized laser diode emitter models • Specially designed EZ-BEAM ® style optics and electronics for reliable sensing without adjustments • Models for ac or dc power • Compact rectangular 25 mm right angle housing with 18 mm threaded mounting base • Completely epoxy encapsulated • Specially designed EZ-BEAM ® style optics and electronics for reliable sensing without adjustments • Models for ac or dc power More information online at bannerengineering.com 65 WORLD-BEAM® QS18 Series PHOTOELECTRICS Compact Sensors WORLD-BEAM® QS18 Series Universal Sensors LASER EMITTER • Features a universal housing with an 18 mm threaded lens or side mounts OPPOSED • Replaces hundreds of other sensors • Meets IP67 and NEMA 6 standards for harsh environments RETRO P LASER POLAR RETRO P POLAR RETRO • Available in opposed, polarized and non-polarized retroreflective, convergent, regular and wideangle diffuse, laser, ultrasonic, plastic or glass fiber optic, fixed-field and adjustable-field sensing modes • Offers easy push-button TEACH-mode setup in Expert™ QS18E and ultrasonic models DIFFUSE • Ranges up to 20 m LASER DIFFUSE CONVERGENT ADJUSTABLE-FIELD Bright LED operating status indicators visible from 360° Optional 18 mm threaded lens mount on some models Side mount standard on all models LASER ADJUSTABLE-FIELD FIXED-FIELD Rugged sealed housing, protected circuitry Variety of cable and connector options QS18 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Page 67 QS18 Laser Emitter . . . . . . . . . . . . . . . . . . . . . . . . . . 68 QS18 Laser models . . . . . . . . . . . . . . . . . . . . . . . . . . 68 QS18 Background Suppression . . . . . . . . . . . . . . . . . 69 QS18 Expert™ . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 72 QS18 Ultrasonic . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73 GLASS FIBER PLASTIC FIBER ULTRASONIC BRACKETS PAGE 350 QD CABLES 4-Pin Euro & 4-Pin Pico PAGE 378, 379 & 380 REFLECTORS PAGE 391 APERTURES QS18 QS18 Expert ™ QS18 Laser • Eight sensing modes for solving most applications: opposed, retroreflective, convergent, diffuse, plastic and glass fiber optic, and adjustable field and fixed field • High power, visible red and infrared sensing beam • Highly visible diagnostics • Advanced teachable microprocessor • Single push-button programming • Instant learning of difficult sensing condition • Reliable detection of transparent and reflective objects • Opposed, diffuse, retroreflective and adjustablefield models • High-performance sensing with visible Class 1 lasers • Long sensing ranges • Ideal for confined areas • Emitter models available with five beam shapes PAGE 406 66 More information online at bannerengineering.com QS18 Background Suppression • Adjustable-field models with cutoff point from 20 to 100 mm or 30 to 150 mm • Fixed-field models sensing range of 50 or 100 mm • Visible red LED or laser sensing beam • Accurate and reliable even with low-reflectivity targets • Ideal for small, difficult-toaccess areas WORLD-BEAM® QS18 Series Compact Sensors Optional 18 mm threaded lens mount on some models 15.0 mm 15.0 mm 21.0 mm Detailed Dimensions 35.0 mm 31.0 mm A variety of cable and connector options 15.0 mm Opposed and Diffuse Models Suffix EB, RB, DB and W Rugged sealed housing, protected circuitry 21.0 mm 35.0 mm 35.0 mm E• YL PIGTAIL • P -S QPMA A BL E EURO Adjustable-field Models Suffix AF100 and LAF UR •C T Bright LED operating status indicators visible from 360° 15.0 mm 15.0 mm CA LL FACTORY 36.9 mm 27.5 mm Opposed, Retroreflective, Laser Retroreflective, Convergent, Diffuse, Laser Diffuse and Fixed-field Models Suffix E, R, LV, LP, LLP, CV15, CV45, D, LD, LE and FF 35.0 mm 35.0 mm Plastic Fiber Models Suffix FP Glass Fiber Models Suffix F WORLD-BEAM® QS18, 10-30V dc Models Sensing Mode/LED* Range Download PDF Cable** Output Type 2m 4-pin Euro QD — 2m 4-pin Euro QD NPN QS18VP6R QS18VP6RQ8 2m 4-pin Euro QD PNP QS186EB Emitter QS186EBQ8 Emitter 2m 4-pin Euro QD — 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP QS186E Emitter QS186EQ8 Emitter QS18VN6R QS18VN6RQ8 20 m Excess Gain Beam Pattern EGCO-8 (p. 428) BPO-8 (p. 450) Data Sheet 63908 QS18VN6RB QS18VN6RBQ8 QS18VP6RB QS18VP6RBQ8 OPPOSED 3m EGCO-9 (p. 428) BPO-9 (p. 450) * Infrared LED ** For 9 m cable, add suffix W/30 to the 2 m model number (example, QS186E W/30). A model with a QD requires a mating cable (see pages 378 and 380). QD models: • For 4-pin integral Euro-style QD, add suffix Q8 (example, QS186EQ8). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS186EQ5). • For 4-pin integral Pico-style QD, add suffix Q7 (example, QS186EQ7). • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS186EQ). More information online at bannerengineering.com 67 PHOTOELECTRICS WORLD-BEAM® QS18 Sensors WORLD-BEAM® QS18 Series Compact Sensors PHOTOELECTRICS WORLD-BEAM® QS18, 10-30V dc (cont’d) Models Sensing Mode/LED* QS186LE*** Range Output Type Excess Gain Beam Pattern Data Sheet 2m 15 m (4500 X excess gain) QS186LEQ8*** Cable** Download PDF 4-pin Euro QD LASER EMITTER QS186LE10 QS186LE10Q8 LASER SPOT 2m 4-pin Euro QD QS186LE11 QS186LE11Q8 LASER SPOT 2m 4-pin Euro QD QS186LE12 See Data sheet for more information. LASER SPOT QS186LE12Q8 QS186LE14 QS186LE14Q8 See Data sheet for more information. 109415 2m 4-pin Euro QD 2m 4-pin Euro QD LASER SPOT QS18VN6LV QS18VN6LVQ8 6.5 m QS18VP6LV QS18VP6LVQ8 — 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP EGCR-7 (p. 431) † RETRO BPR-7 (p. 453) 63908 QS18VN6LP QS18VN6LPQ8 QS18VP6LP QS18VP6LPQ8 P 3.5 m QS18VN6LLP QS18VN6LLPQ8 QS18VP6LLP QS18VP6LLPQ8 10 m NPN 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN † POLAR RETRO P 2m 4-pin Euro QD †† LASER POLAR RETRO QS18VN6CV15 QS18VN6CV15Q8 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP 16 mm QS18VP6CV15 QS18VP6CV15Q8 EGCR-8 (p. 431) BPR-8 (p. 453 ) EGCR-9 (p. 431) — EGCC-9 (p. 437) BPC-9 (p. 459) 118900 63908 QS18VN6CV45 QS18VN6CV45Q8 CONVERGENT 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP EGCC-10 (p. 437) 43 mm QS18VP6CV45 QS18VP6CV45Q8 BPC-10 (p. 459) * Visible Red LED Visible Red Laser ** For 9 m cable, add suffix W/30 to the 2 m model number (example, QS18VN6LV W/30). A model with a QD requires a mating cable (see pages 378 and 380). QD models (except Laser Emitters): • For 4-pin integral Euro-style QD, add suffix Q8 (example, QS18VN6LVQ8). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS18VN6LVQ5). • For 4-pin integral Pico-style QD, add suffix Q7 (example, QS18VN6LVQ7). • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS18VN6LVQ). *** Specified with QS18 threaded lens receiver. Not recommended for dusty or dirty environments; the scattered light would greatly reduce excess gain. † Retroreflective range is specified using one model BRT-84 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. †† Retroreflective range is specified using one model BRT-51X51BM or BXT-TVHG-2X2 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. 68 More information online at bannerengineering.com WORLD-BEAM® QS18 Series Compact Sensors Models Sensing Mode/LED* Range Cable** Download PDF Output Type QS18VN6D QS18VN6DQ8 2m 4-pin Euro QD NPN QS18VP6D QS18VP6DQ8 2m 4-pin Euro QD PNP Excess Gain Beam Pattern EGCD-6 (p. 434) BPD-6 (p. 456) 450 mm QS18VN6DB QS18VN6DBQ8 DIFFUSE QS18VP6DB QS18VP6DBQ8 QS18VN6W QS18VN6WQ8 DIVERGENT DIFFUSE QS18VN6LD QS18VN6LDQ8 NPN 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN 300 mm QS18VP6LD QS18VP6LDQ8 QS18VN6AF100 QS18VN6AF100Q5 QS18VP6AF100 2m 4-pin Euro QD LASER DIFFUSE ADJUSTABLE-FIELD QS18VP6AF100Q5 Data Sheet 63908 2m 4-pin Euro QD 100 mm QS18VP6W QS18VP6WQ8 PHOTOELECTRICS WORLD-BEAM® QS18, 10-30V dc (cont’d) 2m 1 mm to 4-pin Euro Pigtail QD cutoff point 2m (adj. between 20-100 mm) 4-pin Euro Pigtail QD EGCD-7 (p. 434) BPD-7 (p. 456) EGCD-8 (p. 434) BPD-8 (p. 456) 63908 EGCD-9 (p. 434) BPD-42 (p. 458) 118899 PNP NPN EGCA-1 (p. 440) Cutoff Point Deviation Curve PNP — CPDC-1 (p. 474) 66981 QS18VN6LAF 2m QS18VN6LAFQ5 QS18VP6LAF LASER ADJUSTABLE-FIELD QS18VP6LAFQ5 QS18VN6FF50 QS18VN6FF50Q8 1 mm 4-pin Euro Pigtail QD to cutoff point (adj. between 2m 30-150 mm) 4-pin Euro Pigtail QD 0-50 mm Cutoff QS18VP6FF50 QS18VP6FF50Q8 2m 4-pin Euro QD 2m 4-pin Euro QD NPN EGCA-2 (p. 440) Cutoff Point Deviation Curve PNP — CPDC-2 (p. 474) NPN EGCF-4 (p. 441) — PNP 63908 QS18VN6FF100 QS18VN6FF100Q8 QS18VP6FF100 QS18VP6FF100Q8 FIXED-FIELD 0-100 mm Cutoff 2m 4-pin Euro QD 2m 4-pin Euro QD NPN EGCF-5 (p. 441) — PNP * Infrared LED Visible Red LED Visible Red Laser ** For 9 m cable, add suffix W/30 to the 2 m model number (example, QS18VN6W W/30). A model with a QD requires a mating cable (see pages 378 and 380). QD models (except Adjustable-Field): • For 4-pin integral Euro-style QD, add suffix Q8 (example, QS18VN6WQ8). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS18VN6WQ5). • For 4-pin integral Pico-style QD, add suffix Q7 (example, QS18VN6WQ7). • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS18VN6WQ). QD models (Adjustable-Field only): • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS18VP6AF100Q). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS18VP6AF100Q5). More information online at bannerengineering.com 69 WORLD-BEAM® QS18 Series Compact Sensors PHOTOELECTRICS WORLD-BEAM® QS18, 10-30V dc (cont’d) Sensing Mode/LED* Models QS18VN6F QS18VN6FQ8 QS18VP6F QS18VP6FQ8 GLASS FIBER QS18VN6FP QS18VN6FPQ8 QS18VP6FP QS18VP6FPQ8 PLASTIC FIBER Download PDF Output Type Range Cable** Range varies by sensing mode and fiber optics used 2m 4-pin Euro QD 2m 4-pin Euro QD PNP Range varies by sensing mode and fiber optics used 2m 4-pin Euro QD NPN 2m 4-pin Euro QD NPN PNP Excess Gain Beam Pattern Data Sheet EGCG-1 & EGCG-2 (p. 444) BPG-1 & BPG-2 (p. 462) 63908 EGCP-1 & EGCP-2 (p. 447) BPP-1 & BPP-2 (p. 465) 63908 * Infrared LED Visible Red LED ** For 9 m cable, add suffix W/30 to the 2 m model number (example, QS18VN6F W/30). A model with a QD requires a mating cable (see pages 378 and 380). QD models: • For 4-pin integral Euro-style QD, add suffix Q8 (example, QS18VN6FQ8). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS18VN6FQ5). • For 4-pin integral Pico-style QD, add suffix Q7 (example, QS18VN6FQ7). • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS18VN6FQ). WORLD-BEAM® QS18 Specifications Supply Voltage Retroreflective, Diffuse and Adjustable-field Laser models: 10 to 30V dc (10% max. ripple) at less than 15 mA, exclusive of load Laser Emitter models: 10 to 30V dc (10% max. ripple) at less than 35 mA, exclusive of load All other models: 10 to 30V dc (10% max. ripple) at less than 25 mA, exclusive of load Laser Characteristics (Lasers only) Wavelength: 650 nm visible red Class 1 laser Pulse width: 7 microseconds (Laser Emitter models: 5 microseconds) Rep rate: 130 microseconds (Laser Emitter models: 27 microseconds) Pulse output power: 0.065 mW (Laser Emitter models: less than 1.9 mW) Supply Protection Circuitry Protected against reverse polarity and transient voltages Laser Control Enable beam by applying 0V dc to white wire; apply +10 to 30V dc to white wire to inhibit (extinguish) beam Output Configuration* Solid-state complementary (SPDT); NPN (current sinking) or PNP (current sourcing), depending on model; Rating: 100 mA max. each output at 25° C OFF-state leakage current: Retroreflective, Diffuse and Adjustable-field Laser models: NPN: less than 200 µA @ 30V dc PNP: less than 10 µA @ 30V dc Fixed-field models: less than 200 µA @ 30V dc All others: less than 50 µA @ 30V dc ON-state saturation voltage: Retroreflective, Diffuse and Adjustable-field Laser models: NPN: less than 1.6V @ 100 mA PNP: less than 2.0V @ 100 mA All other models: less than 1V @ 10 mA; less than 1.5V @ 100 mA Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Response Time* Opposed models: 750 microseconds ON; 375 microseconds OFF Retroreflective Laser, Diffuse Laser and Adjustable-field models: 700 microseconds ON/OFF Fixed-field models: 850 microseconds ON/OFF All others models: 600 microseconds ON/OFF Delay at Power-up Laser Emitters: 1.5 seconds Retroreflective, Diffuse and Adjustable-field Laser models: 200 milliseconds; outputs do not conduct during this time. All others: 100 milliseconds; outputs do not conduct during this time. Repeatability* Opposed models: 100 microseconds Retroreflective and Diffuse Laser models: 130 microseconds Adjustable-field models: 175 microseconds Fixed-field models: 160 microseconds All other models: 150 microseconds * Does not apply to laser emitter models. 70 More information online at bannerengineering.com WORLD-BEAM® QS18 Series Compact Sensors Sensing Hysteresis* Retroreflective Laser models: 12% of range typical Diffuse Laser models: 15% of range typical Adjustable-field models: 0.5% of range typical at 20 mm cutoff 1% of range typical at 50 mm cutoff 3% of range typical at 100 mm cutoff Adjustable-field Laser models: 1% range typical at 30 mm cutoff 2% range typical at 75 mm cutoff 5% range typical at 150 mm cutoff Adjustments* Retroreflective, Retroreflective Laser, Convergent, Diffuse, Diffuse Laser and Glass Fiber Optic, Plastic Fiber Optic models: Single-turn sensitivity (Gain) adjustment potentiometer Adjustable-field models: five-turn adjustment screw sets cutoff distance between 20 and 100 mm (adjustable-field) or 30 and 150 mm (laser adjustable-field), clutched at both ends of travel Indicators Laser Emitter models: Green LED: Power applied PHOTOELECTRICS ® ® WORLD-BEAM QS18 Specifications (cont’d) WORLD-BEAM QS18 Specifications All other models, 2 LED indicators: Green ON steady: Power ON Green flashing: Output overloaded Yellow † ON steady: Light sensed Yellow † flashing: Marginal excess gain (1.0 to 1.5x excess gain) in the light condition † NOTE: Prior to date code 0223, the output indicator was red instead of yellow. Construction ABS housing, rated IEC IP67; NEMA 6; acrylic lens cover (Laser Emitter models have PMMA window) 2.5 mm (adjustable-field only) and 3 mm mounting hardware included Connections 2 m or 9 m 4-wire PVC cable, or 4-pin 150 mm pigtail Pico-style QD (Q), or 4-pin 150 mm pigtail Euro-style QD (Q5), or 4-pin Integral Pico-style QD (Q7), or 4-pin Integral Euro-style QD (Q8), depending on model. See pages 378 and 380. Operating Conditions Laser models Adjustable-field Temperature: -10° to +50° C 0° to +55° C Relative humidity: 90% @ 50° C (non-condensing) Laser Classification (Laser models only) Class 1 laser product; complies with EN60825-1: 2001 and 21 CFR 1040.10, except deviations persuant to Laser Notice 50, dated 7-26-01. Certifications Laser models: All others -20° to +70° C All other models: Hookup Diagrams Emitters: DC03 (p. 476) NPN Models: DC04 (p.476) Laser Emitter Models: SP01 (p. 489) PNP Models: DC05 (p. 477) * Does not apply to laser emitter models. Class 1 Laser Sensors Lasers that are safe under reasonably foreseeable conditions of operation, including the use of optical instruments for intrabeam viewing. Reference 60825-1 Amend. 2 © IEC:2001(E), section 8.2. For safe laser use: • Do not permit a person to stare at the laser from within the beam. • Do not point the laser at a person’s eye at close range. • Locate open laser beam paths either above or below eye level, where practical. More information online at bannerengineering.com 71 WORLD-BEAM® QS18 Series Compact Sensors PHOTOELECTRICS WORLD-BEAM® QS18 Expert and Ultrasonic Sensors Bright LED status indicators visible from 360° Simple push-button programming 31.0 mm 35.0 mm 15.0 mm E YL • PIGTAIL • P 35.0 mm Retroreflective, Convergent and Diffuse Models Suffix LP, CV15, CV45 and D UR -S QPMA 15.0 mm A BL E EURO 31.0 mm •C T Optional 18 mm threaded lens mount on some models Detailed Dimensions 15.0 mm 15.0 mm CA LL FACTORY Programming Button 35.0 mm 33.5 mm 21.0 mm 35.0 mm Ultrasonic Models Suffix NA and PA Diffuse Models Suffix DB and W WORLD-BEAM® QS18 Expert™ , 10-30V dc Models QS18EN6LP QS18EN6LPQ8 QS18EP6LP QS18EP6LPQ8 Sensing Mode/LED* P Range 3.5 m Cable** Download PDF Output Type 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN † POLAR RETRO QS18EN6CV15 QS18EN6CV15Q8 16 mm QS18EP6CV15 QS18EP6CV15Q8 QS18EN6CV45 QS18EN6CV45Q8 CONVERGENT 43 mm QS18EP6CV45 QS18EP6CV45Q8 2m 4-pin Euro QD PNP QS18EN6D QS18EN6DQ8 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP 2m 4-pin Euro QD NPN 2m 4-pin Euro QD PNP 800 mm QS18EP6D QS18EP6DQ8 QS18EN6DB QS18EN6DBQ8 DIFFUSE 500 mm QS18EP6DB QS18EP6DBQ8 Excess Gain Beam Pattern EGCR-10 (p. 431) BPR-9 (p. 453) EGCC-11 (p. 437) BPC-11 (p. 459) EGCC-12 (p. 437) BPC-12 (p. 459) EGCD-10 (p. 434) BPD-9 (p. 456) EGCD-11 (p. 434) BPD-10 (p. 456 ) Data Sheet 69948 * Infrared LED Visible Red LED ** For 9 m cable, add suffix W/30 to the 2 m model number (example, QS18EN6LP W/30). A model with a QD requires a mating cable (see pages 378 and 380). QD models: • For 4-pin integral Euro-style QD, add suffix Q8 (example, QS18EN6LPQ8). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS18EN6LPQ5). • For 4-pin integral Pico-style QD, add suffix Q7 (example, QS18EN6LPQ7). • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS18EN6LPQ). † Retroreflective range is specified using one model BRT-84 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. 72 More information online at bannerengineering.com WORLD-BEAM® QS18 Expert™ Series Compact Sensors Models QS18EN6W QS18EN6WQ8 Sensing Mode/LED* Range Cable** 2m 4-pin Euro QD DIVERGENT Output Type 2m 4-pin Euro QD DIFFUSE Download PDF Excess Gain Beam Pattern Data Sheet EGCD-12 (p. 434) BPD-11 (p. 456) 69948 NPN 300 mm QS18EP6W QS18EP6WQ8 PNP WORLD-BEAM® QS18 Ultrasonic, 12-30V dc Models† Sensing Mode/LED* Range Cable** QS18UNA QS18UNAQ8 2m 4-pin Euro QD QS18UNAE†† QS18UNAEQ8†† 2m 4-pin Euro QD Download PDF Output Type Excess Gain Beam Pattern NPN — — 50 - 500 mm QS18UPA QS18UPAQ8 QS18UPAE†† QS18UPAEQ8†† ULTRASONIC PHOTOELECTRICS WORLD-BEAM® QS18 Expert™ , 10-30V dc (cont’d) Data Sheet 119287 2m 4-pin Euro QD PNP — — 2m 4-pin Euro QD * Infrared LED Ultrasonic ** For 9 m cable, add suffix W/30 to the 2 m model number (example, QS18EN6W W/30). A model with a QD requires a mating cable (see pages 378, 379 and 380). QD models: • For 4-pin integral Euro-style QD, add suffix Q8 (example, QS18EN6WQ8). • For 4-pin 150 mm Euro-style pigtail, add suffix Q5 (example, QS18EN6WQ5). • For 4-pin integral Pico-style QD, add suffix Q7 (example, QS18EN6WDQ7). • For 4-pin 150 mm Pico-style pigtail, add suffix Q (example, QS18EN6WQ). † For complete information see QS18U Ultrasonic Sensors on page 293. †† Models are epoxy-encapsulated, DIN 40050, IP69K with remote Teach programming. More information online at bannerengineering.com 73 WORLD-BEAM® QS18 Expert™ Series Compact Sensors PHOTOELECTRICS WORLD-BEAM® QS18 Expert™ Specifications Supply Voltage 10 to 30V dc (10% max. ripple) at less than 35 mA, exclusive of load; 10 to 24V dc @ greater than 55° C Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPST solid-state NPN (current sinking) or PNP (current sourcing), depending on model. Configuration in TEACH sequence for light operate (LO) or dark operate (DO). Rating: 100 mA max. OFF-state leakage current: less than 50 µA @ 30V dc ON-state saturation voltage: less than 1.5V (2 m cable); 1.7V (9 m cable) Protected against false pulse on power-up and continuous overload or short circuit of output Output Response Time 600 microseconds ON/OFF Delay at Power-up Less than 1 second; outputs do not conduct during this time Repeatability 75 microseconds Adjustments Push button and remote wire • Thresholds: Push-button/remote-wire teachable • Light/dark operate: Selectable by programming order (load output follows the first taught target condition) • Push-button lockout (remote wire only) Indicators 2 LED indicators: Green: RUN mode, output short-circuit Red: Output ON/marginal, TEACH mode Construction Polycarbonate/ABS housing and TPE push button, rated IEC IP67; NEMA 6 3 mm mounting hardware included Connections 2 m or 9 m 4-wire PVC cable, or 4-pin 150 mm pigtail Pico-style QD (Q), or 4-pin 150 mm pigtail Euro-style QD (Q5), or 4-pin Integral Pico-style QD (Q7), or 4-pin Integral Euro-style QD (Q8). QD cables are ordered separately. See pages 378 and 380. Operating Conditions Temperature: -20° to +70° C Application Note The first condition presented during TEACH mode becomes the OUTPUT ON condition. Relative humidity: 90% @ 50° C (non-condensing) Certifications Hookup Diagrams NPN Models: DC09 (p. 478) PNP Models: DC10 (p. 478) WORLD-BEAM® QS18 Ultrasonic Specifications See page 295. 74 More information online at bannerengineering.com MINI-BEAM® Series Compact Sensors PHOTOELECTRICS MINI-BEAM® Broad Family of Compact Sensors • Models are available for ac, dc, or ac/dc universal voltage operation. • Available models include opposed, opposed clear plastic detection, diffuse and divergent diffuse, polarized and nonpolarized retroreflective, convergent, glass and plastic fiber optic. • Convergent and fiber optic models offer infrared or visible red, blue, white, or green LED light source; select a color based on the application. • SME312 Expert™ models offer easy, push-button TEACHmode setup. • MIAD9 series NAMUR models are for hazardous environments with approved switching amplifiers having intrinsically safe input circuits. • MINI-BEAM models detect clear plastic; MINI-BEAM Expert models detect clear objects. OPPOSED CLEAR PLASTIC OPPOSED RETRO P DC Models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 76 AC Models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .78 Expert Models. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .81 Universal Voltage Models . . . . . . . . . . . . . . . . . . . . . . . . . .84 NAMUR Models . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .86 POLAR RETRO CLEAR PLASTIC P POLAR RETRO DIFFUSE ® MINI-BEAM DC Sensors Opposed, Retroreflective, Diffuse and Convergent Models Suffix E, R, EPD, RPD, D, LV, LP, C, C2, CV, CV2, CVB, CV2B, CVG and CV2G Signal strength output indicator 10 to 30V dc with bipolar NPN/PNP outputs DIVERGENT DIFFUSE 12.2 mm 30.7 mm CONVERGENT 2 m or 9 m integral cable, or Euro-style quickdisconnect fitting 30.7 mm GLASS FIBER Optional 18 mm threaded lens mount on some models PLASTIC FIBER 12.2 mm 12.2 mm 53.3 mm Diffuse Models Suffix DBZ and W 30.7 mm Detailed Dimensions 39.1 mm BRACKETS PAGE 350 QD CABLES 4 or 5-Pin Euro + 3-Pin Micro 12.2 mm PAGE 380, 382 & 386 REFLECTORS 30.7 mm PAGE 391 APERTURES 57.5 mm PAGE 406 Plastic Fiber Models Suffix FP, FPG and FPB 42.1 mm Glass Fiber Models Suffix F, FV, FVG and FVB More information online at bannerengineering.com 75 MINI-BEAM® Series Compact Sensors PHOTOELECTRICS MINI-BEAM®, 10-30V dc Models Sensing Mode/LED* SM31E Emitter SM31EQD Emitter OPPOSED 30 m SM31RL SM31RLQD SM31EPD Emitter SM31RPD Emitter Range 3m SM31R SM31RQD SM31EL Emitter SM31ELQD Emitter Download PDF CLEAR PLASTIC Cable** Output Type 2m 4-Pin Euro QD 2m 4-Pin Euro QD SM312LP SM312LPQD EGCO-11 (p. 428) 2m 4-Pin Euro QD BPO-11 (p. 450) 2m See Note Below*** 5 m† 2m 4-Pin Euro QD EGCR-11 (p. 431) BPR-10 (p. 453) 50 mm - 2 m† 2m 4-Pin Euro QD EGCR-12 (p. 431) BPR-11 (p. 453) 10 mm - 3 m† 2m 4-Pin Euro QD EGCR-13 (p. 431) BPR-12 (p. 453) 380 mm 2m 4-Pin Euro QD EGCD-13 (p. 434) BPD-12 (p. 456) 300 mm 2m 4-Pin Euro QD EGCD-14 (p. 434) BPD-13 (p. 456) 4-Pin Euro QD EGCD-15 (p. 434) BPD-14 (p. 456) RETRO P POLAR RETRO EXTENDED RANGE P POLAR RETRO DIFFUSE DIVERGENT SM312W SM312WQD BPO-10 (p. 450) 130 mm DIFFUSE 2m Bipolar NPN/PNP SM312C SM312CQD 16 mm 2m 4-Pin Euro QD EGCC-13 (p. 437) BPC-13 (p. 459) SM312C2 SM312C2QD 43 mm 2m 4-Pin Euro QD EGCC-14 (p. 437) BPC-14 (p. 459) 16 mm 2m 4-Pin Euro QD EGCC-15 (p. 437) BPC-15 (p. 459) 43 mm 2m 4-Pin Euro QD EGCC-16 (p. 437) BPC-16 (p. 459) SM312CVG SM312CVGQD 16 mm 2m 4-Pin Euro QD EGCC-17 (p. 438) BPC-17 (p. 460) SM312CV2G SM312CV2GQD 49 mm 2m 4-Pin Euro QD EGCC-18 (p. 438) BPC-18 (p. 460) 16 mm 2m 4-Pin Euro QD EGCC-19 (p. 438) BPC-19 (p. 460) 49 mm 2m 4-Pin Euro QD EGCC-20 (p. 438) BPC-20 (p. 460) CONVERGENT SM312CV SM312CVQD SM312CV2 SM312CV2QD CONVERGENT CONVERGENT SM312CVB SM312CVBQD SM312CV2B SM312CV2BQD 03458 OPPOSED SM312D SM312DQD SM312DBZ SM312DBZQD EGCO-10 (p. 428) Data Sheet 4-Pin Euro QD SM312LV SM312LVQD SM312LVAG SM312LVAGQD Beam Pattern 03560 2m 4-Pin Euro QD 0.3 m SM31EPDQD SM31RPDQD Excess Gain CONVERGENT 03562 03366 03564 69943 03365 50975 49290 Infrared LED Visible Red LED Visible Green LED Visible Blue LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SM312D W/30). A model with a QD requires a mating cable (see page 380). *** Actual range depends on light transmission through the plastic being sensed. Some clear plastic materials may not be detected. When in doubt, ask your Banner representative to evaluate material samples. † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. 76 More information online at bannerengineering.com MINI-BEAM® Series Compact Sensors Models Sensing Mode/LED* Range SM312F SM312FQD Output Type Excess Gain Beam Pattern Data Sheet EGCG-3 & EGCG-4 (p. 444) BPG-3 & BPG-4 (p. 462) 03368 4-Pin Euro QD EGCG-5 & EGCG-6 (p. 444) BPG-5 & BPG-6 (p. 462) 03510 2m 4-Pin Euro QD EGCG-7 (p. 444) BPG-7 (p. 462) 50975 EGCG-8 (p. 444) BPG-8 (p. 462) 49290 BPP-3 & BPP-4 (p. 465) 03370 Cable** 4-Pin Euro QD SM312FV 2m SM312FVQD GLASS FIBER SM312FVG SM312FVGQD GLASS FIBER SM312FVB SM312FVBQD Download PDF 2m GLASS FIBER Range varies by sensing mode and fiber optics used GLASS FIBER 2m 4-Pin Euro QD Bipolar NPN/PNP SM312FPQD PLASTIC FIBER 4-Pin Euro QD EGCP-3 & EGCP-4 (p. 447) SM312FPG SM312FPGQD 2m 4-Pin Euro QD EGCP-5 (p. 447) BPP-5 (p. 465) 50975 PLASTIC FIBER 2m 4-Pin Euro QD EGCP-6 (p. 447) BPP-6 (p. 465) 49290 SM312FP SM312FPB SM312FPBQD PLASTIC FIBER PHOTOELECTRICS MINI-BEAM®, 10-30V dc (cont’d) 2m Infrared LED Visible Red LED Visible Green LED Visible Blue LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SM312F W/30). A model with a QD requires a mating cable (see page 380). MINI-BEAM® DC Specifications Supply Voltage and Current 10 to 30V dc (10% max. ripple) at less than 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: One current sourcing (PNP) and one current sinking (NPN) open-collector transistor; light operate (LO) or dark operate (DO) selectable. Output Rating 150 mA max. each output at 25° C, derated to 100 mA at 70° C (derate ≈ 1 mA per ° C) Off-state leakage current: less than 1 µA Output saturation voltage (PNP output): less than 1 volt at 10 mA and less than 2 volts at 150 mA Output saturation voltage (NPN output): less than 200 millivolts at 10 mA and less than 1 volt at 150 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short-circuit of outputs Output Response Time Sensors will respond to either a “light” or a “dark” signal of 1 millisecond or longer duration, 500 Hz max. 0.3 millisecond response modification is available. See note below†. NOTE: 100 millisecond delay on power-up: outputs do not conduct during this time. Repeatability Opposed: 0.14 milliseconds; Non-Polarized and Polarized Retroreflective, Diffuse, Convergent, Glass and Plastic Fiber Optic: 0.3 milliseconds. Response time and repeatability specifications are independent of signal strength. Adjustments LIGHT/DARK OPERATE select switch, and 15-turn slotted brass screw GAIN (sensitivity) adjustment potentiometer (clutched at both ends of travel). Both controls are located on rear panel of sensor and protected by a gasketed, clear acrylic cover. Indicators Alignment Indicating Device system (AID) lights a rear-panel mounted red LED indicator whenever the sensor sees a “light” condition, with a superimposed pulse rate proportional to the light signal strength (the stronger the signal, the faster the pulse rate). Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring sealing, acrylic lenses, and stainless steel screws. Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67 Connections PVC-jacketed 4-conductor 2 m or 9 m cables, or 4-pin Euro-style quick-disconnect (QD) fitting are available. QD cables are ordered separately. See page 380. Operating Conditions Temperature: -20° to +70° C Relative humidity: 90% at 50° C (non-condensing) Certifications Hookup Diagrams † Emitters: DC03 (p. 476) Other Models: DC06 (p. 477) NOTE: DC MINI-BEAMs may be ordered with 0.3 millisecond on/off response by adding suffix MHS to the model number (example, SM312LVMHS). This modification reduces sensing range (and excess gain). More information online at bannerengineering.com 77 MINI-BEAM® Series PHOTOELECTRICS Compact Sensors MINI-BEAM® AC Sensors Opposed, Retroreflective, Diffuse and Convergent Models Suffix E, R, EPD, RPD, D, LV, LP, C and CV Signal strength or output indicator 24 to 240V ac with solid-state outputs 30.7 mm 12.2 mm 2 m or 9 m integral cable, quickdisconnect fitting or Micro-style QD 30.7 mm Optional 18 mm threaded lens mount on some models 12.2 mm 66.0 mm 51.8 mm 12.2 mm 12.2 mm Diffuse Models Suffix DBZ and W 30.7 mm Detailed Dimensions 30.7 mm 69.9 mm Plastic Fiber Models Suffix FP 54.8 mm Glass Fiber Models Suffix F and FV MINI-BEAM®, 24-240V ac Models Sensing Mode/LED* Range Download PDF Cable** Output Type 2m 3-Pin Micro QD SMA31E Emitter SMA31EQD Emitter 3m SM2A31R SM2A31RQD 2m 3-Pin Micro QD SMA31EL Emitter SMA31ELQD Emitter 2m 3-Pin Micro QD Excess Gain Beam Pattern EGCO-10 (p. 428) BPO-10 (p. 450) Data Sheet 03561 OPPOSED EGCO-11 (p. 428) 30 m 2m 3-Pin Micro QD SM2A31RL SM2A31RLQD SMA31EPD Emitter SM2A31RPD CLEAR PLASTIC 2m 0.3 m SMA31EPDQD Emitter SM2A31RPDQD See Note Below*** 03458 3-Pin Micro QD OPPOSED SM2A312D SM2A312DQD SM2A312DBZ SM2A312DBZQD SPST Solid-State 2-Wire BPO-11 (p. 450) DIFFUSE 380 mm 2m 3-Pin Micro QD EGCD-13 (p. 434) BPD-12 (p. 456) 03376 300 mm 2m 3-Pin Micro QD EGCD-14 (p. 434) BPD-13 (p. 456) 03565 2m EGCD-15 (p. 434) BPD-14 (p. 456) 03565 DIVERGENT SM2A312W SM2A312WQD * ** *** 78 130 mm DIFFUSE 3-Pin Micro QD Infrared LED Visible Red LED For 9 m cable, add suffix W/30 to the 2 m model number (example, SM2A312D W/30). A model with a QD requires a mating cable (see page 386). Actual range depends on light transmission through the plastic being sensed. Some clear plastic materials may not be detected. When in doubt, ask your Banner representative to evaluate material samples. More information online at bannerengineering.com MINI-BEAM® Series Compact Sensors Models Sensing Mode/LED* SM2A312LV SM2A312LVQD Download PDF Excess Gain Beam Pattern EGCR-11 (p. 431) BPR-10 (p. 453) EGCR-12 (p. 431) BPR-11 (p. 453) 3-Pin Micro QD EGCR-13 (p. 431) BPR-12 (p. 453) 16 mm 2m 3-Pin Micro QD EGCC-13 (p. 437) BPC-13 (p. 459) 43 mm 2m 3-Pin Micro QD EGCC-14 (p. 437) BPC-14 (p. 459) 16 mm 2m 3-Pin Micro QD EGCC-15 (p. 437) BPC-15 (p. 459) EGCC-16 (p. 437) BPC-16 (p. 459) EGCC-17 (p. 438) BPC-17 (p. 460) 69942 EGCG-3 & EGCG-4 (p. 444) BPG-3 & BPG-4 (p. 462) 03375 EGCG-5 & EGCG-6 (p. 444) BPG-5 & BPG-6 (p. 462) 69942 EGCP-3 & EGCP-4 (p. 447) BPP-3 & BPP-4 (p. 465) 03404 Range 5 m† PHOTOELECTRICS MINI-BEAM®, 24-240V ac (cont’d) Cable** Output Type 2m 3-Pin Micro QD Data Sheet RETRO SM2A312LVAG SM2A312LVAGQD P 50 mm - 2 m† 2m 3-Pin Micro QD 03563 POLAR RETRO EXTENDED RANGE SM2A312LP SM2A312LPQD P 2m 10 mm - 3 m† POLAR RETRO SM2A312C SM2A312CQD 69942 SM2A312C2 SM2A312C2QD CONVERGENT SM2A312CV SM2A312CVQD SM2A312CV2 SM2A312CV2QD CONVERGENT 43 mm 2m 3-Pin Micro QD SPST Solid-state 2-Wire 2m SM2A312CVG SM2A312CVGQD 16 mm 3-Pin Micro QD 03402 CONVERGENT 2m SM2A312F SM2A312FQD GLASS FIBER SM2A312FV SM2A312FVQD Range varies by sensing mode and fiber optics used SM2A312FPQD PLASTIC FIBER 2m 3-Pin Micro QD GLASS FIBER SM2A312FP 3-Pin Micro QD Range varies by sensing mode and fiber optics used 2m 3-Pin Micro QD Infrared LED Visible Red LED Visible Green LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SM2A312LP W/30). A model with a QD requires a mating cable (see page 386). † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. More information online at bannerengineering.com 79 MINI-BEAM® Series Compact Sensors PHOTOELECTRICS MINI-BEAM® AC Specifications Supply Voltage and Current 24 to 240V ac (50/60 Hz), 250V ac max Supply Protection Circuitry Protected against transient voltages Output Configuration SPST SCR solid-state relay (light/dark operate selectable); 2-wire hookup Output Rating Min. load current 5 mA; max. steady-state load capability 300 mA to 50° C ambient 100 mA to 70° C ambient Inrush capability: 3 amps for 1 second (non repetitive); 10 amps for 1 cycle (non repetitive) Off-state leakage current: less than 1.7 mA rms On-state voltage drop: ≤ 5 volts at 300 mA load, ≤ 10 volts at 15 mA load Output Protection Circuitry Protected against false pulse on power-up Output Response Time Opposed Mode: 2 milliseconds on and 1 millisecond off; Non-Polarized and Polarized Retroreflective, Convergent, Plastic Fiber Optic: 4 milliseconds on and off; Diffuse and Glass Fiber Optic: 8 milliseconds on and off “OFF” response time specification does not include load response of up to ½ ac cycle (8.3 milliseconds). Response time specification of load should be considered when important. NOTE: 300 millisecond delay on power-up. Repeatability Opposed: 0.3 milliseconds Non-Polarized and Polarized Retroreflective, and Convergent and Plastic Fiber Optic: 1.3 milliseconds Diffuse and Glass Fiber Optics: 2.6 milliseconds Response time and repeatability specifications are independent of signal strength. Adjustments LIGHT/DARK OPERATE select switch, and 15-turn slotted brass screw GAIN (sensitivity) adjustment potentiometer (clutched at both ends of travel). Both controls are located on rear panel of sensor and protected by a gasketed, clear acrylic cover. Indicators Red indicator LED on rear of sensor is “ON” when the load is energized Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring sealing, acrylic lenses, and stainless steel screws Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67 Connections PVC-jacketed 2-conductor 2 m or 9 m cables, or 3-pin micro-style quick-disconnect (QD) fitting are available. QD cables are ordered separately. See page 386. Operating Conditions Temperature: -20° to +70° C Application Notes i) Relative humidity: 90% at 50° C (non-condensing) Overload conditions can destroy ac MINI-BEAM sensors. Directly wiring sensor without load series across hot and neutral will damage sensor (except emitter models). ii) Low voltage use requires careful analysis of the load to determine if the leakage current or on-state voltage of the sensor will interfere with proper operation of the load. iii) The false-pulse protection feature may cause momentary drop-out of the load when the sensor is wired in series or parallel with mechanical switch contacts. Certifications Hookup Diagrams 80 Cabled Emitters: AC03 (p. 484) QD Emitters: AC04 (p. 484) More information online at bannerengineering.com All Other QD Models: AC02 (p. 484) All Other Cabled Models: AC01 (p. 484) MINI-BEAM® Expert™ Series Compact Sensors PHOTOELECTRICS MINI-BEAM® Expert™ Sensors Retroreflective, Diffuse and Convergent Models Suffix LV, LP, D, DV, CV, CV2, CVG, CVB and CVW Simple push-button programming or remote TEACH via wire 30.7 mm Dual-LED multi-function indicators 12.2 mm 2 m or 9 m integral cable, or Euro-style quick disconnect fitting 30.7 mm Popular 18 mm threaded lens mount 66.0 mm 12.2 mm 12.2 mm 51.8 mm Detailed Dimensions 12.2 mm 30.7 mm Diffuse Models Suffix W 30.7 mm 69.9 mm Plastic Fiber Models Suffix FP, FPG, FPB and FPW Glass Fiber Models Suffix F, FV, FVG, FVB and FVW 54.8 mm MINI-BEAM® Expert™ , 10-30V dc Models SME312LP SME312LPQD Sensing Mode/LED* P Range 10 mm - 3 m† POLAR RETRO Download PDF Cable** Output Type 2m 5-Pin Euro QD Excess Gain Beam Pattern EGCR-14 (p. 431) BPR-13 (p. 453) EGCR-15 (p. 431) BPR-14 (p. 453) EGCD-16 (p. 434) BPD-15 (p. 456) EGCD-18 (p. 435) BPD-17 (p. 457) EGCD-17 (p. 435) BPD-16 (p. 456) Data Sheet 55214 SME312LPC*** SME312LPCQD*** CLEAR OBJECT 1m P 2m 5-Pin Euro QD POLAR RETRO SME312D SME312DQD 380 mm DIFFUSE SME312DV SME312DVQD SME312W 1100 mm DIFFUSE DIVERGENT 130 mm SME312WQD 2m 5-Pin Euro QD Bipolar NPN/PNP 2m 5-Pin Euro QD 2m 5-Pin Euro QD 55214 DIFFUSE Infrared LED Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SME312D W/30). A model with a QD requires a mating cable (see page 382). *** NOTE: For clear object detection, sensing range varies, according to the efficiency and reflective area of the retroreflector(s) used. For these low-contrast applications, the model BRT-2X2 reflector is recommended and is included with each SME312LPC(QD) sensor. • For applications with high vibration, the model BRT-51x51BM, with its micro-prism geometry, is recommended. • For long-range applications, the BRT-77X77C reflector provides a range up to 2 m. • SME312LPC(QD) are for use with corner cube type reflectors only; reflective tape is not recommended. See page 391 for more information. † NOTE: Retroreflective range is specified using one model BRT-3 retroreflector, unless otherwise noted. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories section for more information. More information online at bannerengineering.com 81 MINI-BEAM® Expert™ Series Compact Sensors PHOTOELECTRICS MINI-BEAM® Expert™ , 10-30V dc (cont’d) Models Sensing Mode/LED* SME312CV 16 mm SME312CVQD SME312CV2 CONVERGENT 43 mm SME312CV2QD SME312CVG SME312CVGQD 16 mm CONVERGENT SME312CVB SME312CVBQD 16 mm CONVERGENT SME312CVW SME312CVWQD Range 16 mm CONVERGENT SME312F SME312FQD GLASS FIBER Range varies by sensing mode and fiber optics used 2m 5-Pin Euro QD 2m 5-Pin Euro QD 2m 5-Pin Euro QD 5-Pin Euro QD GLASS FIBER 2m 5-Pin Euro QD PLASTIC FIBER PLASTIC FIBER PLASTIC FIBER Range varies by sensing mode and fiber optics used 2m 5-Pin Euro QD PLASTIC FIBER Bipolar NPN/PNP Excess Gain Beam Pattern EGCC-21 (p. 438) BPC-21 (p. 460) EGCC-22 (p. 438) BPC-22 (p. 460) EGCC-23 (p. 438) BPC-23 (p. 460) EGCC-24 (p. 438) BPC-24 (p. 460) EGCC-25 (p. 438) BPC-25 (p. 460) EGCG-9 & EGCG-10 (p. 444) BPG-9 & BPG-10 (p. 462) EGCG-11 & EGCG-12 (p. 444) BPG-11 & BPG-12 (p. 462) EGCG-13 (p. 444) BPG-13 (p. 462) EGCG-14 (p. 444) BPG-14 (p. 462) EGCG-15 (p. 444) BPG-15 (p. 462) EGCP-7 & EGCP-8 (p. 447) BPP-7 & BPP-8 (p. 465) EGCP-9 (p. 447) BPP-9 (p. 465) 2m 5-Pin Euro QD 5-Pin Euro QD EGCP-10 (p. 447) BPP-10 (p. 465) EGCP-11 (p. 447) BPP-11 (p. 465) Infrared LED Visible Red LED Visible Green LED Visible Blue LED Visible White LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SME312CV W/30). A model with a QD requires a mating cable (see page 382). 82 More information online at Data Sheet 55214 55214 55214 2m SME312FPW SME312FPWQD 5-Pin Euro QD 2m SME312FPB SME312FPBQD 2m 5-Pin Euro QD GLASS FIBER SME312FPG SME312FPGQD 5-Pin Euro QD 2m SME312FP SME312FPQD 2m 5-Pin Euro QD GLASS FIBER SME312FVW SME312FVWQD 5-Pin Euro QD 2m SME312FVB SME312FVBQD 2m 5-Pin Euro QD GLASS FIBER SME312FVG SME312FVGQD Output Type 2m SME312FV SME312FVQD Cable** Download PDF bannerengineering.com MINI-BEAM® Expert™ Series Compact Sensors Supply Voltage and Current 10 to 30V dc (10% max. ripple) at less than 45 mA, exclusive of load Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: One current sourcing (PNP) and one current sinking (NPN) open-collector transistor. Configuration in TEACH sequence for Light Operate (LO) or Dark Operate (DO). Output Rating 150 mA max. each output at 25° C, derated to 100 mA at 70° C (derate ≈ 1 mA per ° C) Off-state leakage current: less than 5 µA @ 30V dc Output saturation voltage (PNP output): less than 1 volt at 10 mA and less than 2 volts at 150 mA Output saturation voltage (NPN output): less than 200 millivolts at 10 mA and less than 1 volt at 150 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short-circuit of outputs Output Response Time Sensors will respond to either a “light” or a “dark” signal of 500 microseconds or longer duration, 1 kHz max. NOTE: 1 second delay on power-up; outputs do not conduct during this time. Repeatability 100 microseconds (all models) Adjustments Push-button TEACH mode sensitivity setting; remote TEACH mode input is provided (gray wire) Indicators Two LEDs: Yellow and Bicolor Green/Red PHOTOELECTRICS MINI-BEAM® Expert™ Specifications Green (RUN Mode): ON when power is applied Flashes when received light level approaches the switching threshold Red (TEACH Mode): OFF when no signal is received. Pulses to indicate signal strength (received light level). Rate is proportional to signal strength (the stronger the signal, the faster the pulse rate). This is a function of Banner’s Alignment Indicating Device (AID). Yellow (TEACH Mode): ON to indicate sensor is ready to learn output ON condition OFF to indicate sensor is ready to learn output OFF condition Yellow (RUN Mode): ON when outputs are conducting Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring seal, acrylic lenses, and stainless steel screws. Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67 Connections PVC-jacketed 5-conductor 2 m or 9 m unterminated cable, or 5-pin Euro-style quick-disconnect (QD) fitting are available. QD cables are ordered separately. See page 382. Operating Conditions Temperature: -20° to +70° C Application Notes The first condition presented during TEACH mode becomes the output ON condition. Relative humidity: 90% at 50° C (non-condensing) Certifications Hookup Diagrams DC11 (p. 478) More information online at bannerengineering.com 83 MINI-BEAM® Universal Voltage Series Compact Sensors PHOTOELECTRICS MINI-BEAM® Universal Voltage Sensors Opposed, Retroreflective, Diffuse and Convergent Models Suffix E, EL, R, RL, LV, LP, D, CV and CV2 Popular, compact MINI-BEAM package with a SPDT electromechanical (E/M) relay 30.7 mm 12.2 mm Universal supply voltage: 24 to 240V ac, 50/60 Hz; 24 to 240V dc 30.7 mm Easy-tooperate sensors with few required adjustments 12.2 mm 81.0 mm 12.2 mm 66.8 mm 12.2 mm 30.7 mm Diffuse Models Suffix W 30.7 mm Detailed Dimensions 85.3 mm 69.8 mm Plastic Fiber Models Suffix FP Glass Fiber Models Suffix F and FV MINI-BEAM® Universal Voltage, 24-240V ac or dc Models Sensing Mode/LED* SMU31E Emitter SMU31R SMU31EL Emitter SMU31RL OPPOSED SMU315LV Excess Gain Beam Pattern 2m EGCO-12 (p. 428) BPO-12 (p. 450) 30 m 2m EGCO-13 (p. 428) BPO-13 (p. 450) 5 m† 2m EGCR-16 (p. 431) BPR-15 (p. 453) 10 mm - 3 m† 2m EGCR-17 (p. 432) BPR-16 (p. 453) Range Cable** 3m Output Type Download PDF Data Sheet RETRO SMU315LP P POLAR RETRO SMU315D SPDT E/M Relay 380 mm 2m EGCD-19 (p. 435) BPD-18 (p. 457) 130 mm 2m EGCD-20 (p. 435) BPD-19 (p. 457) 16 mm 2m EGCC-26 (p. 438) BPC-26 (p. 460) 43 mm 2m EGCC-27 (p. 438) BPC-27 (p. 460) 55230 DIFFUSE DIVERGENT SMU315W DIFFUSE SMU315CV SMU315CV2 CONVERGENT Infrared LED Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SMU315D W/30). † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. 84 More information online at bannerengineering.com MINI-BEAM® Universal Voltage Series Compact Sensors Models Sensing Mode/LED* SMU315F GLASS FIBER SMU315FV Range Cable** 2m Range varies by sensing mode and fiber optics used 2m GLASS FIBER SMU315FP PLASTIC FIBER Output Type Range varies by sensing mode and fiber optics used SPDT E/M Relay 2m PHOTOELECTRICS MINI-BEAM® Universal Voltage, 24-240V ac or dc (cont’d) Download PDF Excess Gain Beam Pattern EGCG-16 (p. 444) & EGCG-17 (p. 445) BPG-16 (p. 462) & BPG-17 (p. 463) EGCG-18 & EGCG-19 (p. 445) BPG-18 & BPG-19 (p. 463) EGCP-12 & EGCP-13 (p. 447) BPP-12 & BPP-13 (p. 465) Data Sheet 55230 Infrared LED Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, SMU315F W/30). MINI-BEAM® Universal Voltage Specifications Supply Voltage Universal voltage: 24 to 240V ac, 50/60Hz or 24 to 240V dc (1.5 watts or 2.5 VA max.) Supply Protection Circuitry Protected against transient voltages. DC hookup is without regard to polarity. Output Configuration SPDT (Single-Pole, Double Throw) (form C) electromechanical relay, ON/OFF output. Output Rating Max. switching power (resistive load): 90W, 250VA Max. switching voltage (resistive load): 250V ac or 30V dc Max. switching current (resistive load): 3A Min. voltage and current: 5V dc, 10 mA Mechanical life: 20,000,000 operations Electrical life at full resistive load: 100,000 operations Output Protection Circuitry Protected against false pulse on power-up. Output Response Time Closure time: 20 milliseconds max. Release time: 20 milliseconds max. Max. switching speed: 25 operations per second Repeatability All sensing modes: 1 millisecond Adjustments Light/Dark Operate select switch, and 15-turn slotted brass screw Gain (sensitivity) adjustment potentiometer (clutched at both ends of travel). Both controls are located on rear panel of sensor and are protected by a gasketed, clear acrylic cover. Indicators Alignment Indicator Device system (AID) lights a rear-panel-mounted LED indicator whenever the sensor sees a “light” condition, with a superimposed pulse rate proportional to the light signal strength (the stronger the signal, the faster the pulse rate). Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring seal, acrylic lenses, and stainless steel screws. Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67. Connections PVC-jacketed 5-conductor 2 m or 9 m unterminated cable. Opposed mode emitter cables are 2-conductor. Operating Conditions Temperature: -20° to +55° C Application Notes Install transient suppressor (MOV) across contacts switching inductive loads. Relative humidity: 90% at 50° C (non-condensing) Certifications Hookup Diagrams Emitters: UN02 (p. 487) Other AC/DC Models: UN01 (p. 487) More information online at bannerengineering.com 85 MINI-BEAM® NAMUR Series Compact Sensors 12.2 mm PHOTOELECTRICS MINI-BEAM® NAMUR Sensors 30.7 mm Intrinsically safe sensors with MINI-BEAM performance and small size 30.7 mm For use with approved switching amplifiers with intrinsically safe input circuits 51.8 mm Diffuse Models Suffix W Output 1 mA or less in the dark and 2 mA or more in the light 12.2 mm Models with integral cable or quick-disconnect 66.0 mm 12.2 mm 30.7 mm Opposed, Retroreflective, Diffuse and Convergent Models Suffix E, R, LV, D, and CV 69.9 mm Detailed Dimensions Glass Fiber Models Suffix F MINI-BEAM® NAMUR, 5-15V dc Models Sensing Mode/LED* Range Download PDF Cable** 2m 4-Pin Euro QD MI9E Emitter MI9EQ Emitter Output Type MIAD9LV MIAD9LVQ MIAD9LVAG MIAD9LVAGQ MIAD9D MIAD9DQ 2m 4-Pin Euro QD OPPOSED EGCR-18 (p. 432) BPR-17 (p. 454) 50 mm - 2 m 2m 4-Pin Euro QD EGCR-19 (p. 432) BPR-18 (p. 454) 380 mm 2m 4-Pin Euro QD EGCD-21 (p. 435) BPD-20 (p. 457) EGCD-22 (p. 435) BPD-21 (p. 457) DIFFUSE DIVERGENT 75 mm MIAD9WQ 2m 4-Pin Euro QD DIFFUSE Constant Current ≤1.2 mA dark ≥2.1 mA light 16 mm 2m 4-Pin Euro QD EGCC-28 (p. 438) BPC-28 (p. 460) CONVERGENT 43 mm 2m 4-Pin Euro QD EGCC-29 (p. 438) BPC-29 (p. 460) 2m 4-Pin Euro QD EGCG-20 & EGCG-21 (p. 445) BPG-20 & BPG-21 (p. 463) GLASS FIBER Range varies by sensing mode and fiber optics used MIAD9CV MIAD9CVQ MIAD9CV2 MIAD9CV2Q BPO-14 (p. 450) 2m 4-Pin Euro QD POLAR RETRO MIAD9W EGCO-14 (p. 428) 5m RETRO P Beam Pattern MIAD9F MIAD9FQ Data Sheet — 6m MIAD9R MIAD9RQ Excess Gain 39616 Infrared LED Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, MIAD9LV W/30). A model with a QD requires a special 4-pin Euro QD mating cable (see page 381). † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. 86 More information online at bannerengineering.com MINI-BEAM® NAMUR Series Compact Sensors Supply Voltage 5 to 15V dc (provided by the amplifier to which the sensor is connected) Output Constant current output: ≤ 1.2 mA in the “dark” condition and ≤ 2.1 mA in the “light” condition Output Response Time Opposed mode receiver: 2 milliseconds on/400 microseconds off All other models: 5 milliseconds on/off (does not include amplifier response) Adjustments 15-turn slotted brass screw GAIN (sensitivity) adjustment potentiometer (clutched at both ends of travel); located on rear panel and protected by a clear gasketed acrylic cover Indicators Red LED Alignment Indicator Device (AID) located on rear panel lights when the sensor sees a “light” condition; pulse rate is proportional to signal strength (the stronger the signal, the faster the pulse rate). Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring sealing, acrylic lenses, and stainless steel screws Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12 and 13; IEC IP67 Connections PVC-jacketed 2-conductor 2 m or 9 m cables, or special 4-pin Euro-style quick-disconnect (QD) fitting are available; QD cables are ordered separately. See page 381. Operating Conditions Temperature: -40° to +70° C Design Standards MIAD9 Series sensors comply with the following standards: DIN 19 234, EN 50 014 Part 1. 1977, EN50 020 Part 7. 1977, Factory Mutual #3610 and 3611, CSA 22.2 #157-92 and 22.2 #213-M1987 PHOTOELECTRICS MINI-BEAM® NAMUR Specifications Relative humidity: 90% at 50° C (non-condensing) Certifications LISTE D Hookup Diagrams SP02 (p. 489) APPROVALS CSA: #LR 41887 Instrinsically Safe, with Entity for Class I, Groups A-D Class I, Div. 2, Groups A-D FM: #J.I. 5Y3A4.AX Intrinsically Safe, with Entity for Class I, II, III, Div. 1, Groups A-G Class I, II, III, Div. 2, Groups A-D and G KEMA: #03ATEX1441X II IG EEx ia IIC T6 ETL: #553868 More information online at bannerengineering.com 87 Q23 Series Compact Sensors PHOTOELECTRICS Q23 and QH23 Vertical and Horizontal Rectangular Sensors • Available with vertical and horizontal housings • Delivers high power in a small package • Features ranges up to 8 m • Uses a powerful visible red sensing beam for easy setup and alignment • Offered in opposed, polarized retroreflective, convergent, diffuse and plastic fiber optic modes • Features marginal gain indicator with alarm output OPPOSED P POLAR RETRO DIFFUSE CONVERGENT 23.0 mm Q23 and QH23 Sensors PLASTIC FIBER BRACKETS PAGE 350 QD CABLES 4-Pin Pico Dual-LED multi-function indicators Detailed Dimensions 34.0 mm Two housing styles 34.0 mm 2 m or 9 m integral cable, or 150 mm Pico-style quickdisconnect pigtail 23.0 mm PAGE 378 REFLECTORS 12.0 mm PAGE 391 PAGE 406 12.0 mm 12.0 mm APERTURES Opposed, Retroreflective and Diffuse Models Suffix E, R, LP and D 34.0 mm 12.0 mm 23.0 mm 25.5 mm 12.0 mm 12.0 mm Q23 Convergent Models Suffix CV 36.5 mm 34.0 mm 23.0 mm 27.1 mm Q23 Plastic Fiber Optic Models Suffix FP and FPY 88 More information online at bannerengineering.com 38.1 mm QH23 Plastic Fiber Optic Models Suffix FP and FPY QH23 Convergent Models Suffix CV Q23 Series Compact Sensors Models Sensing Mode/LED* Range Q236E Emitter QH236E Emitter PHOTOELECTRICS Q23 and QH23, 10-30V dc Download PDF Cable** Output Type Excess Gain Beam Pattern Data Sheet 2m – Q236EQ Emitter QH236EQ Emitter 4-pin Pico Pigtail QD Q23SN6R QH23SN6R 2m NPN 8m Q23SN6RQ QH23SN6RQ EGCO-15 (p. 428) BPO-15 (p. 450) 46637 EGCR-20 (p. 432) BPR-19 (p. 454) 46637 EGCD-23 (p. 435) BPD-22 (p. 457) 4-pin Pico Pigtail QD OPPOSED Q23SP6R QH23SP6R 2m PNP Q23SP6RQ QH23SP6RQ 4-pin Pico Pigtail QD Q23SN6LP QH23SN6LP 2m NPN Q23SN6LPQ QH23SN6LPQ Q23SP6LP QH23SP6LP 4-pin Pico Pigtail QD P 100 mm - 2 m† 2m POLAR RETRO PNP Q23SP6LPQ QH23SP6LPQ 4-pin Pico Pigtail QD Q23SN6D QH23SN6D Q23SN6DQ QH23SN6DQ 2m NPN SHORT-RANGE 4-pin Pico Pigtail QD 200 mm Q23SP6D QH23SP6D 2m DIFFUSE PNP Q23SP6DQ QH23SP6DQ 4-pin Pico Pigtail QD 46637 Q23SN6DL QH23SN6DL Q23SN6DLQ QH23SN6DLQ 2m NPN LONG-RANGE 4-pin Pico Pigtail QD EGCD-24 (p. 435) 800 mm Q23SP6DL QH23SP6DL DIFFUSE BPD-23 (p. 457) 2m PNP Q23SP6DLQ QH23SP6DLQ 4-pin Pico Pigtail QD Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, Q23SN6D W/30). A model with a pigtail QD requires a mating cable (see page 378). † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. More information online at bannerengineering.com 89 Q23 Series Compact Sensors PHOTOELECTRICS Q23 and QH23, 10-30V dc (cont’d) Models Sensing Mode/LED* Range Q23SN6CV50 QH23SN6CV50 Cable** Download PDF Output Type Excess Gain Beam Pattern Data Sheet 2m NPN Q23SN6CV50Q QH23SN6CV50Q 4-pin Pico Pigtail QD 50 mm Q23SP6CV50 QH23SP6CV50 EGCC-30 (p. 438) BPC-30 (p. 460) EGCP-14 & EGCP-15 (p. 447) BPP-14 & BP-15 (p. 465) 46637 2m CONVERGENT PNP Q23SP6CV50Q QH23SP6CV50Q 4-pin Pico Pigtail QD Q23SN6FP QH23SN6FP Q23SN6FPQ QH23SN6FPQ Q23SP6FP QH23SP6FP 2m NPN Standard Speed: 1 ms 4-pin Pico Pigtail QD 2m PLASTIC FIBER PNP Q23SP6FPQ QH23SP6FPQ Range varies by sensing mode and fiber optics used Q23SN6FPY QH23SN6FPY Q23SN6FPYQ QH23SN6FPYQ Q23SP6FPY QH23SP6FPY 46637 2m NPN High Speed: 100 µs 4-pin Pico Pigtail QD PLASTIC FIBER EGCP-16 (p. 447) & EGCP-17 (p. 448) 2m BPP-16 (p. 465) & BPP-17 (p. 466) PNP Q23SP6FPYQ QH23SP6FPYQ * ** 4-pin Pico Pigtail QD 4-pin Pico Pigtail QD Visible Red LED For 9 m cable, add suffix W/30 to the 2 m model number (example, Q23SN6CV50 W/30). A model with a pigtail QD requires a mating cable (see page 378). Q23 and QH23 Specifications 90 Supply Voltage and Current 10 to 30V dc (10% max. ripple) at less than 25 mA for diffuse, Retroreflective, and fiber optic models (exclusive of load) Opposed emitters and receivers draw 20 mA each Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Solid-state complementary (SPDT) dc switch; NPN (current sinking) or PNP (current sourcing), depending on model. The Dark Operate (DO) output may be wired as a normally open marginal signal alarm output, depending upon hookup to the power supply. Output Rating 150 mA max. each in standard hookup; when wired for alarm output, the total load may not exceed 150 mA Off-state leakage current: less than 1 mA at 30V dc Output saturation voltage: less than 1 volt at 10 mA dc; less than 1.5V at 150 mA dc Output Protection Circuitry Protected against false pulse on power-up, transient voltages, and continuous overload or short-circuit of outputs Output Response Time All other models: 1 millisecond ON/OFF Q23FPQ high-speed models: 100 microsecond ON/OFF; protected against false pulse on power-up NOTE: 100 millisecond delay on power-up: outputs do not conduct during this time. More information online at bannerengineering.com Q23 Series Compact Sensors Repeatability Opposed: 0.13 milliseconds; Retroreflective and Diffuse: 0.25 milliseconds FPY High-Speed Plastic Fiber Optic: 25 microseconds Response time and repeatability specifications are independent of signal strength. Adjustments SENSITIVITY control (single-turn, o-ring sealed potentiometer) Indicators Sensors except opposed mode emitters have two LEDs: Green ON steady: dc power ON Green flashing: output overload Yellow ON steady: Light Operate (LO), output is energized Yellow flashing: marginal excess gain (1 - 1.5x), LO output is energized Emitters have green power “ON” indicator Construction Yellow and black ABS housing, with acrylic lenses, completely sealed. Stainless steel mounting bracket and M3 mounting hardware are supplied Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67. Housing materials rated UL 94 V-0 Connections PVC-jacketed 4-conductor 2 m or 9 m cables, or 4-pin Pico-style 50 mm threaded quick-disconnect (QD) fitting are available. Mating QD cables are ordered separately. See page 378. Operating Conditions Temperature: -20° to +55° C Application Notes To avoid damage to the sensor caused by static discharge (ESD), use the plastic screwdriver supplied with each sensor (included in the hardware packet) to adjust the SENSITIVITY control. Otherwise, use a screwdriver with an insulated handle. PHOTOELECTRICS (cont’d) Q23 Q23 and and QH23 Specifications (cont’d) QH23 Specifications Relative humidity: 90% at 50° C (non-condensing) Certifications Hookup Diagrams Emitters: DC03 (p. 476) NPN Models: DC07 (p. 477) More information online at PNP Models: DC08 (p. 477) bannerengineering.com 91 S18/M18 Series Compact Sensors PHOTOELECTRICS S18 and M18 18 mm ThreadedBarrel Sensors • Features EZ-BEAM® technology, with specially designed optics and electronics for reliable sensing without adjustments • Available in plastic threaded barrel sensor (S18) and stainless steel threaded barrel sensor (M18) • Completely epoxy-encapsulated to provide superior durability, even in harsh sensing environments (S18) • Uses innovative dual-indicator system to take the guesswork out of monitoring sensor performance • Available in models for ac or dc power • Includes advanced diagnostics to warn of marginal sensing conditions or output overload (dc models) • Meets rigorous IP69K standards for use in 1200 psi washdowns (S18) OPPOSED RETRO S18 DC Models. . . . . . . . . . . . . . . . . . . . . . . .Page 93 M18 DC Models . . . . . . . . . . . . . . . . . . . . . . . . . . . 94 S18 AC Models . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96 P POLAR RETRO S18 and M18 DC Sensors DIFFUSE FIXED-FIELD BRACKETS PAGE 350 QD CABLES Advanced self-diagnostics with separate alarm output; dual-LED multi-function indicators S18 Opposed, Non-polarized Retroreflective and Diffuse Models Suffix E, R, L and D 59.2 mm Popular 18 mm threaded barrel 65.0 mm ø 18.0 mm 10 to 30V dc with NPN or PNP outputs S18 Polarized Retroreflective and Fixed-field Models Suffix LP and FF 4-Pin Euro + 4-Pin Micro PAGE 380 & 386 REFLECTORS 2 m or 9 m integral cable, or Euro-style quick-disconnect fitting PAGE 391 ø 18.0 mm APERTURES PAGE 406 Detailed Dimensions 65.0 mm 59.2 mm M18 Opposed, Non-polarized Retroreflective and Diffuse Models Suffix E, R, L, D and DL 92 More information online at bannerengineering.com M18 Polarized Retroreflective and Fixed-field Models Suffix LP and FF S18/M18 Series Compact Sensors Models Sensing Mode/LED* Download PDF Range S186E Emitter S186EQ Emitter Cable** Output Type 2m 4-Pin Euro QD — 2m 4-Pin Euro QD NPN S18SP6R S18SP6RQ 2m 4-Pin Euro QD PNP S18SN6L S18SN6LQ 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN S18SN6R S18SN6RQ PHOTOELECTRICS S18, 10-30V dc 20 m Excess Gain Beam Pattern EGCO-16 (p. 428) BPO-16 (p. 450) EGCR-21 (p. 432) BPR-20 (p. 454) EGCR-22 (p. 432) BPR-21 (p. 454) EGCF-6 (p. 441) — Data Sheet OPPOSED 2m S18SP6L S18SP6LQ S18SN6LP S18SN6LPQ S18SP6LP S18SP6LPQ RETRO P 2m † POLAR RETRO S18SN6FF25 S18SN6FF25Q 0 - 25 mm Cutoff S18SP6FF25 S18SP6FF25Q S18SN6FF50 S18SN6FF50Q S18SP6FF50 S18SP6FF50Q † 0 - 50 mm Cutoff FIXED-FIELD S18SN6FF100 S18SN6FF100Q 0 - 100 mm Cutoff S18SP6FF100 S18SP6FF100Q S18SN6D S18SN6DQ 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 100 mm S18SP6D S18SP6DQ S18SN6DL S18SN6DLQ DIFFUSE 300 mm S18SP6DL S18SP6DLQ 116159 EGCF-7 (p. 441) — EGCF-8 (p. 441) — EGCD-25 (p. 435) BPD-24 (p. 457) EGCD-26 (p. 435) BPD-25 (p. 457) Infrared LED Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, S18SP6D W/30). A model with a QD requires a mating cable (see page 380). † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. More information online at bannerengineering.com 93 S18/M18 Series Compact Sensors PHOTOELECTRICS M18, 10-30V dc Models Download PDF Sensing Mode/LED* Range Cable** Output Type 2m 4-Pin Euro QD – 2m 4-Pin Euro QD NPN M18SP6R M18SP6RQ 2m 4-Pin Euro QD PNP M18SN6L M18SN6LQ 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN M186E Emitter M186EQ Emitter M18SN6R M18SN6RQ 20 m Excess Gain Beam Pattern EGCO-17 (p. 429) BPO-17 (p.451) EGCR-23 (p. 432) BPR-22 (p. 454) EGCR-24 (p. 432) BPR-23 (p. 454) EGCF-9 (p. 441) — Data Sheet OPPOSED 2m M18SP6L M18SP6LQ M18SN6LP M18SN6LPQ M18SP6LP M18SP6LPQ RETRO P 2m † POLAR RETRO M18SN6FF25 M18SN6FF25Q 0 - 25 mm Cutoff M18SP6FF25 M18SP6FF25Q M18SN6FF50 M18SN6FF50Q M18SP6FF50 M18SP6FF50Q † 0 - 50 mm Cutoff FIXED-FIELD M18SN6FF100 M18SN6FF100Q 0 - 100 mm Cutoff M18SP6FF100 M18SP6FF100Q M18SN6D M18SN6DQ 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 2m 4-Pin Euro QD NPN 2m 4-Pin Euro QD PNP 100 mm M18SP6D M18SP6DQ M18SN6DL M18SN6DLQ DIFFUSE 300 mm M18SP6DL M18SP6DLQ 49201 EGCF-10 (p. 441) — EGCF-11 (p. 441) — EGCD-27 (p. 435) BPD-26 (p. 457) EGCD-28 (p. 435) BPD-27 (p. 457) Infrared LED Visible Red LED * ** For 9 m cable, add suffix W/30 to the 2 m model number (example, M18SN6D W/30). A model with a QD requires a mating cable (see page 380). † Retroreflective range is specified using one model BRT-3 retroreflector. Actual sensing range may differ, depending on the efficiency and reflective area of the retroreflector used. See Accessories for more information. 94 More information online at bannerengineering.com S18/M18 Series Compact Sensors Supply Voltage and Current 10 to 30V dc (10% max. ripple); Supply current (exclusive of load current): Opposed Mode Emitters: 25 mA Opposed Mode Receivers: 20 mA Polarized Retroreflective: 30 mA Non-polarized Retroreflective: 25 mA Fixed-field: 35 mA Diffuse: 25 mA Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Solid-state complementary (SPDT) dc switch; NPN (current sinking) or PNP (current sourcing), depending on model. The Dark Operate (DO) output may be wired as a normally open marginal signal alarm output, depending upon hookup to the power supply. Output Rating 150 mA max. (each) in standard hookup. When wired for alarm output, the total load may not exceed 150 mA Off-state leakage current: less than 1 mA at 30V dc; On-state saturation voltage: less than 1V at 10 mA dc;
S18SP6LP W/30 价格&库存
很抱歉,暂时无法提供与“S18SP6LP W/30”相匹配的价格&库存,您可以联系我们找货
S18SP6LP W/30
  • 1+1560.324221+201.42479
