KT5W-2P1123
KT5W-2P1123
    SICK
    SEN CONTRAST PNP 10MM M12-5
KT5W-2P1123 数据手册
Product data sheet KT5W-2P1123 KT5 CONTRAST SENSORS KT5W-2P1123 | KT5 CONTRAST SENSORS A B C D E F Ordering information Type Part no. KT5W-2P1123 1017810 Other models and accessories www.sick.com/KT5 Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Dimensions (W x H x D) 30.4 mm x 53 mm x 80 mm Sensing distance 10 mm 1) Housing design (light emission) Rectangular Light source LED, RGB 2) Wave length 470 nm, 525 nm, 640 nm Light emission Long and short side of housing, exchangeable Light spot size 1.2 mm x 4.2 mm Light spot direction Vertical 3) Adjustment Teach-in button Teach-in mode Teach-in dynamic 1) 2) 3)  From front edge of lens.  Average service life: 100,000 h at TU = +25 °C.  In relation to long side of housing. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ≤ 5 Vpp 2) Current consumption 10 V ... < UV Retention time (ET) 25 ms, non-volatile memory Time delay 20 ms Connection type Male connector M12, 5-pin Protection class II 7) Circuit protection UV connections, reverse polarity protected Output Q short-circuit protected Interference pulse suppression Enclosure rating IP67 Weight 400 g Housing material Metal, zinc diecast 1) 2) 3) 4) 5) 6) 7)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Without load.  With light/dark ratio 1:1.  Signal transit time with resistive load.  Short-circuit-proof.  Reference voltage DC 50 V. Ambient data Ambient operating temperature –10 °C ... +55 °C Ambient temperature, storage –25 °C ... +75 °C Shock load According to IEC 60068 Classifications ECl@ss 5.0 27270906 ECl@ss 5.1.4 27270906 ECl@ss 6.0 27270906 ECl@ss 6.2 27270906 ECl@ss 7.0 27270906 ECl@ss 8.0 27270906 ECl@ss 8.1 27270906 ECl@ss 9.0 27270906 ECl@ss 10.0 27270906 ECl@ss 11.0 27270906 ETIM 5.0 EC001820 ETIM 6.0 EC001820 ETIM 7.0 EC001820 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 3 KT5W-2P1123 | KT5 CONTRAST SENSORS ETIM 8.0 EC001820 UNSPSC 16.0901 39121528 Dimensional drawing (Dimensions in mm (inch)) KT5-2 Teach-in, KT5-2 Display Ø 26 3.5 4.5 17.4 (0.14) (0.18) (0.69) (1.02) Sensing distance 40 mm (1.57 inch) (1.00) (1.00) 30.4 Sensing distance 20 mm (0.79 inch) 5 17 4 3 5 28 (1.10) 52 (2.05) 80 (3.15) 13 (0.51) (0.12) 25 (0.98) 40 (1.57) 53 (2.09) 2 M H I J K L M N O P Q R S T (1.20) 21 (0.83) 1 2 Ø 25.5 Sensing distance 10 mm (0.39 inch) (1.10) Ø 25.6 56 (2.20) 28 9 (0.35) M5 A B C D E F 3 (0.67) ①  Lens (light transmission), can be exchanged for pos. 4 ②  M5 threaded mounting hole, 5.5 mm deep ③  See dimensional drawings of lenses ④  Blind screw can be replaced by pos. 1 ⑤  Connector M12 (rotatable up to 90°) Adjustments KT5-2 Teach-in, KT5W-xxx3 RUN 1 L T E A C H Q RUN 2 D 3 TEACH ①  Function signal indicator (yellow) ②  Pre-selection switch ③  Teach-in button 4 REGISTRATION SENSORS | SICK Product data sheet | 2021-09-24 16:53:32 Subject to change without notice KT5W-2P1123 | KT5 CONTRAST SENSORS Connection diagram Cd-324 BN 1 BK 4 BU 3 WH 2 GY 5 +(L+) Q -(M) L/D Teach Concept of operation KT5-2 Teach-in, teach-in dynamic 1. Select switching function (light/dark) 2. Position mark or background L RUN L L RUN T E A C H RUN 3. Move at least one repeat length using the light spot RUN D RUN T E A C H RUN D Turn rotary switch to desired teach position: D = dark switching L = light switching Press the teach-in button and keep it pressed. Example L RUN T E A C H RUN D Keep the teach-in button pressed. T E A C H D Release the teach-in button. Yellow LED will illuminate, when emitted light is on the mark. Print image in detection track Light switching Dark switching Internal signal received Switching threshold Output Q Switching threshold Internal signal received Output Q Switching characteristics The optimum emitted light is selected automatically. The switching threshold is set in the center between the lowest and the second-lowest reflectivity. Teach-in can also be performed using an external control signal. Light/dark setting can also be configured using an external control signal. Observe the minimum speed (25 mm/s ... 300 mm/s). 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 5 KT5W-2P1123 | KT5 CONTRAST SENSORS Sensing distance Sensing distance 100 90 1 80 70 60 50 Relative sensitivity in % A B C D E F 2 40 30 20 3 10 0 H I J K L M N O P Q R S T 10 20 30 40 50 (0.39) (0.79) (1.18) (1.57) (1.97) Sensing distance in mm (inch) ①  Sensing distance 10 mm ②  Sensing distance 20 mm ③  Sensing distance 40 mm Recommended accessories Other models and accessories www.sick.com/KT5 Brief description Type Part no. Lens, 40 mm sensing distance, M20 x 0.75 OBJ-210 2010945 Lens, 10 mm sensing distance, M20 x 0.75 OBJ-211 1004936 Lens, 20 mm sensing distance, M20 x 0.75 OBJ-212 1011506 BEF-KHS-G01 2022464 BEF-KHS-K01 2022718 BEF-KHS-KH1 2022726 BEF-MS12G-A 4056054 BEF-MS12G-B 4056055 Lenses and accessories Universal bar clamp systems 6 REGISTRATION SENSORS | SICK Product data sheet | 2021-09-24 16:53:32 Subject to change without notice KT5W-2P1123 | KT5 CONTRAST SENSORS Brief description Type Part no. BEF-MS12L-A 4056052 BEF-MS12L-B 4056053 YF2A15020VB5XLEAX 2096239 YF2A15050VB5XLEAX 2096240 YF2A15100VB5XLEAX 2096241 YG2A15020VB5XLEAX 2096215 YG2A15050VB5XLEAX 2096216 YG2A15100VB5XLEAX 2096217 DOS-1205-G 6009719 DOS-1205-W 6009720 Plug connectors and cables 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
KT5W-2P1123 价格&库存
很抱歉,暂时无法提供与“KT5W-2P1123”相匹配的价格&库存,您可以联系我们找货
