MLV12-8-H-250-RT/47/65B/124
    PEPPERL+FUCHS(倍加福)
    PHOTO SEN 20-250MM BACK SUPPRESS
MLV12-8-H-250-RT/47/65B/124 数据手册
Background suppression sensor MLV12-8-H-250-RT/47/65b/124 < Reliable detection of all surfaces, independent of color and structure < Minimal black-white difference < Ultra bright LEDs for power on and switching state < Flashing power on LED in case of short-circuit < Not sensitive to ambient light, even with switched energy saving lamps < Multiple device installation possible, no mutual interference (no cross-talk) < Protection class II Triangulation sensor with background suppression in a widely used standard housing, red light, 250 mm detection range, electrically adjustable, light/dark on, two PNP outputs, M12 plug Dimensions Unit Connector M12 10 M4 / 4 deep Unit Connector M8 1 5 4 3 15 2 4 3 2 1 7.5 2 6 41.5 5 1 Operating display green 2 Switch state yellow 31.8 21.3 2 5.3 ø4.5 6 Optical axis emitter 5.5 7 Connection options: 19.5 Connector 90° adjustable position M12x1 24 11.5 2 12 Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 115789_eng.pdf 65 49 3 Bright/dark switch 4 Adjuster of detection range 5 Optical axis receiver 4 1 M8x1 M12x1 M8x1 3 Fixed cable Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Background suppression sensor MLV12-8-H-250-RT/47/65b/124 Technical Data General specifications Detection range 20 ... 250 mm , adjustable Detection range min. 20 ... 50 mm Detection range max. 20 ... 250 mm Adjustment range 50 ... 250 mm Light source LED Light type modulated visible red light , 660 nm Black-white difference (6 %/90 %) 10 % at 250 mm Diameter of the light spot 8 mm at Tw 250 mm Angle of divergence 1.5 ° Ambient light limit Continuous light 30000 Lux Modulated light 5000 Lux Functional safety related parameters MTTFd 650 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator LED green, flashes in case of short-circuit Function indicator 2 LEDs yellow ON: object inside the scanning range OFF: object outside the scanning range Control elements potentiometer for light/dark, detection range adjustment Electrical specifications Operating voltage UB Ripple No-load supply current 10 ... 30 V DC max. 10 % I0 ≤ 55 mA Output Switching type light/dark on switchable Signal output 2 PNP outputs, complementary, short-circuit protected, reverse polarity protected, open collector Switching voltage max. 30 V DC Switching current max. 0.2 A Voltage drop Ud ≤ 2.5 V DC Switching frequency f 1000 Hz Response time 0.5 ms Conformity Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 115789_eng.pdf Product standard EN 60947-5-2 Compliance with standards and directives Standard conformity Shock and impact resistance IEC / EN 60068. half-sine, 40 g in each X, Y and Z directions Vibration resistance IEC / EN 60068-2-6. Sinus. 10 -150 Hz, 5 g in each X, Y and Z directions Approvals and certificates Protection class II, rated voltage ≤ 300 V AC with pollution degree 1-2 according to IEC 60664-1 UL approval cULus CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -40 ... 60 °C (-40 ... 140 °F) Storage temperature -40 ... 75 °C (-40 ... 167 °F) Mechanical specifications Housing width 41.5 mm Housing height 49 mm Housing depth 15 mm Degree of protection IP67 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Background suppression sensor MLV12-8-H-250-RT/47/65b/124 Technical Data Connection Metal connector, M12, 5-pin, 90° rotatable Material Housing Frame: nickel plated, die cast zinc, Laterals: glass-fiber reinforced plastic PC Optical face Plastic pane Mass 60 g Connection Assignment Option: /47 1 +UB 2 Q 3 0V 4 Q 5 n.c. = Light on = Dark on Connection Assignment 1 5 4 2 3 Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 115789_eng.pdf Wire colors in accordance with EN 60947-5-2 1 2 3 4 5 BN WH BU BK GY (brown) (white) (blue) (black) (gray) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Background suppression sensor Characteristic response curve MLV12-8-H-250-RT/47/65b/124 MLV12-8-H-250-RT Offset Y [mm] 4 3 2 1 0 -1 -2 -3 -4 0 50 100 150 200 250 Distance X [mm] x y white 90 % grey 18 % black 6 % Characteristic Curve Difference in detection distance MLV12-8-H-250-RT Measured detection distance X [mm] 300 250 200 150 100 50 0 0 50 100 x 300 250 150 200 Adjusted detection distance (white) X [mm] white 90 % grey 18 % black 6 % Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 115789_eng.pdf Accessories OMH-MLV12-HWG Mounting bracket for series MLV12 sensors OMH-MLV12-HWK Mounting bracket for series MLV12 sensors OMH-K01 dove tail mounting clamp OMH-K02 dove tail mounting clamp OMH-K03 dove tail mounting clamp OMH-06 Mounting aid for round steel ø 12 mm or sheet 1.5 mm ... 3 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4
MLV12-8-H-250-RT/47/65B/124 价格&库存
很抱歉,暂时无法提供与“MLV12-8-H-250-RT/47/65B/124”相匹配的价格&库存,您可以联系我们找货
