MC68HC908QY2MDW
MC68HC908QY2MDW
    ROCHESTER(罗切斯特)
    SOIC16
    IC MCU 8BIT 1.5KB FLASH 16SOIC
MC68HC908QY2MDW 数据手册
MC68HC908QY4 MC68HC908QT4 MC68HC908QY2 MC68HC908QT2 MC68HC908QY1 MC68HC908QT1 Data Sheet M68HC08 Microcontrollers MC68HC908QY4/D Rev 3.0 1/2004 MOTOROLA.COM/SEMICONDUCTORS MC68HC908QY4 MC68HC908QT4 MC68HC908QY2 MC68HC908QT2 MC68HC908QY1 MC68HC908QT1 Data Sheet To provide the most up-to-date information, the revision of our documents on the World Wide Web will be the most current. Your printed copy may be an earlier revision. To verify you have the latest information available, refer to: http://motorola.com/semiconductors/ The following revision history table summarizes changes contained in this document. For your convenience, the page number designators have been linked to the appropriate location. Motorola and the Stylized M Logo are registered trademarks of Motorola, Inc. DigitalDNA is a trademark of Motorola, Inc. This product incorporates SuperFlash® technology licensed from SST. MC68HC908QY/QT Family — Rev. 3 MOTOROLA © Motorola, Inc., 2004 Data Sheet 3 Revision History Revision History Date Revision Level September, 2002 N/A December, 2002 January, 2003 0.1 0.2 Initial release N/A 1.2 Features — Added 8-pin dual flat no lead (DFN) packages to features list. 19 Figure 1-2. MCU Pin Assignments — Figure updated to include DFN packages. 21 Figure 2-1. Memory Map — Clarified illegal address and unimplemented memory. 28 Figure 2-2. Control, Status, and Data Registers — Corrected bit definitions for Port A Data Register (PTA) and Data Direction Register A (DDRA). 28 Table 13-3. Interrupt Sources — Corrected vector addresses for keyboard interrupt and ADC conversion complete interrupt. 124 Section 13. System Integration Module (SIM) — Removed reference to break status register as it is duplicated in break module. 113 11.3.1 Internal Oscillator and 11.3.1.1 Internal Oscillator Trimming — Clarified oscillator trim option ordering information and what to expect with untrimmed device. 97 Figure 11-5. Oscillator Trim Register (OSCTRIM) — Bit 1 designation corrected. 104 Figure 15-13. Monitor Mode Circuit (Internal Clock, No High Voltage) — Diagram updated for clarity. 160 Figure 12-1. I/O Port Register Summary — Corrected bit definitions for PTA7, DDRA7, and DDRA6. 105 Figure 12-2. Port A Data Register (PTA) — Corrected bit definition for PTA7. 106 Figure 12-3. Data Direction Register A (DDRA) — Corrected bit definitions for DDRA7 and DDRA6. 107 Figure 12-6. Port B Data Register (PTB) — Corrected bit definition for PTB1 109 Section 9. Keyboard Interrupt Module (KBI) — Section reworked after deletion of auto wakeup for clarity. 83 Section 4. Auto Wakeup Module (AWU) — New section added for clarity. 49 Figure 10-1. LVI Module Block Diagram — Corrected LVI stop representation. 91 Section 16. Electrical Specifications — Extensive changes made to electrical specifications. 169 17.5 8-Pin Dual Flat No Lead (DFN) Package (Case #1452) — Added case outline drawing for DFN package. 187 Section 17. Ordering Information and Mechanical Specifications — Added ordering information for DFN package. 185 4.2 Features — Corrected third bulleted item. 49 Data Sheet 4 Page Number(s) Description MC68HC908QY/QT Family — Rev. 3 Revision History MOTOROLA Revision History Revision History (Continued) Date August, 2003 Revision Level 1.0 Description Reformatted to meet latest M68HC08 documentation standards N/A Figure 1-1. Block Diagram — Diagram redrawn to include keyboard interrupt module and TCLK pin designator. 20 Figure 1-2. MCU Pin Assignments — Added TCLK pin designator. 21 Table 1-2. Pin Functions — Added TCLK pin description. 22 Table 1-3. Function Priority in Shared Pins — Revised table for clarity and to add TCLK. 23 Figure 2-1. Memory Map — Corrected names for the IRQ status and control register (INTSCR) bits 3–0. 26 3.7.3 ADC Input Clock Register — Clarified bit description for the ADC clock prescaler bits. 48 4.3 Functional Description — Updated periodic wakeup request values. 51 Figure 6-1. COP Block Diagram — Reworked for clarity 59 Section 8. External Interrupt (IRQ) — Corrected bit names for MODE, IRQF, ACK, and IMASK Section 14. Timer Interface Module (TIM) — Added TCLK function. 15.3 Monitor Module (MON) — Updated with additional data. Section 16. Electrical Specifications — Updated with additional data. October, 2003 January, 2004 2.0 3.0 77–81 131–147 156 169–183 Figure 2-2. Control, Status, and Data Registers — Deleted unimplemented areas from $FFB0–$FFBD and $FFC2–$FFCF as they are actually available. Also corrected $FFBF designation from unimplemented to reserved. 28 Figure 6-1. COP Block Diagram — Reworked for clarity 59 6.3.2 STOP Instruction — Added subsection 60 13.4.2 Active Resets from Internal Sources — Reworked notes for clarity. 117 Table 13-2. Reset Recovery Timing — Replaced previous table with new information. 118 Section 14. Timer Interface Module (TIM) — Updated with additional data. 131 Figure 15-3. Break I/O Register Summary — Corrected bit designators for the BRKAR register 151 15.3 Monitor Module (MON) — Clarified seventh bullet. 156 Table 17-1. MC Order Numbers — Corrected temperature and package designators. 185 Figure 2-2. Control, Status, and Data Registers — Corrected reset state for the FLASH Block Protect Register at address location $FFBE and the Internal Oscillator Trim Value at $FFC0. 32 Figure 2-5. FLASH Block Protect Register (FLBPR) — Restated reset state for clarity. 39 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Page Number(s) Data Sheet Revision History 5 Revision History Data Sheet 6 MC68HC908QY/QT Family — Rev. 3 Revision History MOTOROLA Data Sheet — MC68HC908QY/QT Family List of Sections Section 1. General Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .17 Section 2. Memory . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Section 3. Analog-to-Digital Converter (ADC) . . . . . . . . . . . . . . . . . . . 41 Section 4. Auto Wakeup Module (AWU) . . . . . . . . . . . . . . . . . . . . . . . . 49 Section 5. Configuration Register (CONFIG) . . . . . . . . . . . . . . . . . . . . 55 Section 6. Computer Operating Properly (COP) . . . . . . . . . . . . . . . . . 59 Section 7. Central Processor Unit (CPU) . . . . . . . . . . . . . . . . . . . . . . . 63 Section 8. External Interrupt (IRQ) . . . . . . . . . . . . . . . . . . . . . . . . . . . . 77 Section 9. Keyboard Interrupt Module (KBI) . . . . . . . . . . . . . . . . . . . . 83 Section 10. Low-Voltage Inhibit (LVI) . . . . . . . . . . . . . . . . . . . . . . . . . . 91 Section 11. Oscillator Module (OSC). . . . . . . . . . . . . . . . . . . . . . . . . . . 95 Section 12. Input/Output Ports (PORTS) . . . . . . . . . . . . . . . . . . . . . . 105 Section 13. System Integration Module (SIM) . . . . . . . . . . . . . . . . . . 113 Section 14. Timer Interface Module (TIM) . . . . . . . . . . . . . . . . . . . . . . 131 Section 15. Development Support. . . . . . . . . . . . . . . . . . . . . . . . . . . . 149 Section 16. Electrical Specifications. . . . . . . . . . . . . . . . . . . . . . . . . . 169 Section 17. Ordering Information and Mechanical Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 185 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet List of Sections 7 List of Sections Data Sheet 8 MC68HC908QY/QT Family — Rev. 3 List of Sections MOTOROLA Data Sheet — MC68HC908QY/QT Family Table of Contents Section 1. General Description 1.1 1.2 1.3 1.4 1.5 1.6 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Pin Function Priority . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 17 19 19 22 23 Section 2. Memory 2.1 2.2 2.3 2.4 2.5 2.6 2.6.1 2.6.2 2.6.3 2.6.4 2.6.5 2.6.6 2.6.7 2.6.8 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Unimplemented Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . . . Reserved Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Input/Output (I/O) Section. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Random-Access Memory (RAM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Memory (FLASH) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Page Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Mass Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Program Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FLASH Block Protect Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 25 25 27 33 34 34 35 36 36 37 39 40 40 Section 3. Analog-to-Digital Converter (ADC) 3.1 3.2 3.3 3.3.1 3.3.2 3.3.3 3.3.4 3.3.5 3.4 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ADC Port I/O Pins. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Voltage Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Conversion Time. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Continuous Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Accuracy and Precision . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . MC68HC908QY/QT Family — Rev. 3 MOTOROLA 41 41 43 44 44 44 44 44 45 Data Sheet Table of Contents 9 Table of Contents 3.5 3.5.1 3.5.2 3.6 3.7 3.7.1 3.7.2 3.7.3 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Input/Output Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Input/Output Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ADC Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . ADC Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ADC Input Clock Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 45 45 45 45 46 47 48 Section 4. Auto Wakeup Module (AWU) 4.1 4.2 4.3 4.4 4.5 4.6 4.6.1 4.6.2 4.6.3 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Input/Output Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Port A I/O Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Keyboard Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . Keyboard Interrupt Enable Register . . . . . . . . . . . . . . . . . . . . . . . . . 49 49 50 51 51 51 52 52 53 Section 5. Configuration Register (CONFIG) 5.1 5.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 55 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 55 Section 6. Computer Operating Properly (COP) 6.1 6.2 6.3 6.3.1 6.3.2 6.3.3 6.3.4 6.3.5 6.3.6 6.3.7 6.4 6.5 6.6 6.7 6.7.1 6.7.2 6.8 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . BUSCLKX4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . STOP Instruction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . COPCTL Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Power-On Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Internal Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . COPD (COP Disable) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . COPRS (COP Rate Select) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . COP Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . COP Module During Break Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Data Sheet 10 59 59 60 60 60 60 60 60 61 61 61 61 61 61 61 62 62 MC68HC908QY/QT Family — Rev. 3 Table of Contents MOTOROLA Table of Contents Section 7. Central Processor Unit (CPU) 7.1 7.2 7.3 7.3.1 7.3.2 7.3.3 7.3.4 7.3.5 7.4 7.5 7.5.1 7.5.2 7.6 7.7 7.8 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . CPU Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Accumulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Index Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stack Pointer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Program Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Condition Code Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Arithmetic/Logic Unit (ALU) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . CPU During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Instruction Set Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63 63 64 64 65 65 66 66 68 68 68 68 68 69 75 Section 8. External Interrupt (IRQ) 8.1 8.2 8.3 8.4 8.5 8.6 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IRQ Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IRQ Module During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . IRQ Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 77 77 77 80 81 81 Section 9. Keyboard Interrupt Module (KBI) 9.1 9.2 9.3 9.3.1 9.3.2 9.4 9.5 9.6 9.7 9.7.1 9.7.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Keyboard Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Keyboard Initialization. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Keyboard Module During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . Input/Output Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Keyboard Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . Keyboard Interrupt Enable Register . . . . . . . . . . . . . . . . . . . . . . . . . MC68HC908QY/QT Family — Rev. 3 MOTOROLA 83 83 85 85 87 87 87 87 88 88 89 Data Sheet Table of Contents 11 Table of Contents Section 10. Low-Voltage Inhibit (LVI) 10.1 10.2 10.3 10.3.1 10.3.2 10.3.3 10.3.4 10.4 10.5 10.6 10.6.1 10.6.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Polled LVI Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Forced Reset Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Voltage Hysteresis Protection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . LVI Trip Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . LVI Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . LVI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 91 91 92 92 92 93 93 93 94 94 94 Section 11. Oscillator Module (OSC) 11.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 11.2 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 11.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 11.3.1 Internal Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 11.3.1.1 Internal Oscillator Trimming . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 11.3.1.2 Internal to External Clock Switching . . . . . . . . . . . . . . . . . . . . . . . 97 11.3.2 External Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 98 11.3.3 XTAL Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 98 11.3.4 RC Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99 11.4 Oscillator Module Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 11.4.1 Crystal Amplifier Input Pin (OSC1) . . . . . . . . . . . . . . . . . . . . . . . . . 100 11.4.2 Crystal Amplifier Output Pin (OSC2/PTA4/BUSCLKX4). . . . . . . . . 100 11.4.3 Oscillator Enable Signal (SIMOSCEN) . . . . . . . . . . . . . . . . . . . . . . 101 11.4.4 XTAL Oscillator Clock (XTALCLK) . . . . . . . . . . . . . . . . . . . . . . . . . 101 11.4.5 RC Oscillator Clock (RCCLK) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101 11.4.6 Internal Oscillator Clock (INTCLK) . . . . . . . . . . . . . . . . . . . . . . . . . 101 11.4.7 Oscillator Out 2 (BUSCLKX4). . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101 11.4.8 Oscillator Out (BUSCLKX2) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101 11.5 Low Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102 11.5.1 Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102 11.5.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102 11.6 Oscillator During Break Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102 11.7 CONFIG2 Options . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102 11.8 Input/Output (I/O) Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 103 11.8.1 Oscillator Status Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 103 11.8.2 Oscillator Trim Register (OSCTRIM) . . . . . . . . . . . . . . . . . . . . . . . 104 Data Sheet 12 MC68HC908QY/QT Family — Rev. 3 Table of Contents MOTOROLA Table of Contents Section 12. Input/Output Ports (PORTS) 12.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.2 Port A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.2.1 Port A Data Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.2.2 Data Direction Register A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.2.3 Port A Input Pullup Enable Register . . . . . . . . . . . . . . . . . . . . . . . . 12.3 Port B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.3.1 Port B Data Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.3.2 Data Direction Register B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12.3.3 Port B Input Pullup Enable Register . . . . . . . . . . . . . . . . . . . . . . . . 105 106 106 107 108 109 109 109 111 Section 13. System Integration Module (SIM) 13.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.2 RST and IRQ Pins Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.3 SIM Bus Clock Control and Generation . . . . . . . . . . . . . . . . . . . . . . . . 13.3.1 Bus Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.3.2 Clock Start-Up from POR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.3.3 Clocks in Stop Mode and Wait Mode . . . . . . . . . . . . . . . . . . . . . . . 13.4 Reset and System Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.4.1 External Pin Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.4.2 Active Resets from Internal Sources . . . . . . . . . . . . . . . . . . . . . . . 13.4.2.1 Power-On Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.4.2.2 Computer Operating Properly (COP) Reset . . . . . . . . . . . . . . . . 13.4.2.3 Illegal Opcode Reset. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.4.2.4 Illegal Address Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.4.2.5 Low-Voltage Inhibit (LVI) Reset . . . . . . . . . . . . . . . . . . . . . . . . . 13.5 SIM Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.5.1 SIM Counter During Power-On Reset . . . . . . . . . . . . . . . . . . . . . . 13.5.2 SIM Counter During Stop Mode Recovery . . . . . . . . . . . . . . . . . . . 13.5.3 SIM Counter and Reset States . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6 Exception Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.1 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.1.1 Hardware Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.1.2 SWI Instruction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.2 Interrupt Status Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.2.1 Interrupt Status Register 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.2.2 Interrupt Status Register 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.2.3 Interrupt Status Register 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.3 Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.4 Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.6.5 Status Flag Protection in Break Mode . . . . . . . . . . . . . . . . . . . . . . 13.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.7.1 Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . MC68HC908QY/QT Family — Rev. 3 MOTOROLA 113 116 116 116 116 116 117 117 117 118 119 120 120 120 120 120 121 121 121 121 123 124 124 125 125 126 126 126 126 127 127 128 Data Sheet Table of Contents 13 Table of Contents 13.8 SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 13.8.1 SIM Reset Status Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 13.8.2 Break Flag Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 Section 14. Timer Interface Module (TIM) 14.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.2 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.3 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.1 TIM Counter Prescaler . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.2 Input Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.3 Output Compare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.3.1 Unbuffered Output Compare. . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.3.2 Buffered Output Compare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.4 Pulse Width Modulation (PWM) . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.4.4.1 Unbuffered PWM Signal Generation. . . . . . . . . . . . . . . . . . . . . . 14.4.4.2 Buffered PWM Signal Generation . . . . . . . . . . . . . . . . . . . . . . . . 14.4.4.3 PWM Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.5 Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.6 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.7 TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.8 Input/Output Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.8.1 TIM Clock Pin (PTA2/TCLK). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.8.2 TIM Channel I/O Pins (PTA0/TCH0 and PTA1/TCH1) . . . . . . . . . . 14.9 Input/Output Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.9.1 TIM Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . 14.9.2 TIM Counter Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.9.3 TIM Counter Modulo Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.9.4 TIM Channel Status and Control Registers . . . . . . . . . . . . . . . . . . 14.9.5 TIM Channel Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 131 131 131 133 135 135 135 135 136 136 137 138 138 139 139 140 140 140 140 141 141 143 143 144 147 Section 15. Development Support 15.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2 Break Module (BRK). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.1 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.1.1 Flag Protection During Break Interrupts . . . . . . . . . . . . . . . . . . . 15.2.1.2 TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.1.3 COP During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.2 Break Module Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.2.1 Break Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . 15.2.2.2 Break Address Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.2.3 Break Auxiliary Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.2.4 Break Status Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.2.5 Break Flag Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.2.3 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Data Sheet 14 149 149 149 152 152 152 153 153 154 154 155 155 156 MC68HC908QY/QT Family — Rev. 3 Table of Contents MOTOROLA Table of Contents 15.3 Monitor Module (MON) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.1 Normal Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.2 Forced Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.3 Monitor Vectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.4 Data Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.5 Break Signal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.6 Baud Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.1.7 Commands . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.3.2 Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 156 156 160 162 162 163 163 163 164 167 Section 16. Electrical Specifications 16.1 16.2 16.3 16.4 16.5 16.6 16.7 16.8 16.9 16.10 16.11 16.12 16.13 16.14 16.15 16.16 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Functional Operating Range. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Typical 5-V Output Drive Characteristics . . . . . . . . . . . . . . . . . . . . . . . 5-V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-V Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Typical 3.0-V Output Drive Characteristics. . . . . . . . . . . . . . . . . . . . . . 3-V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-V Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Supply Current Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Analog-to-Digital Converter Characteristics . . . . . . . . . . . . . . . . . . . . . Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . . . . . . . . Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 169 169 170 170 171 172 173 174 175 176 177 178 179 181 182 183 Section 17. Ordering Information and Mechanical Specifications 17.1 17.2 17.3 17.4 17.5 17.6 17.7 17.8 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . MC Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-Pin Plastic Dual In-Line Package (Case #626) . . . . . . . . . . . . . . . . . 8-Pin Small Outline Integrated Circuit Package (Case #968). . . . . . . . 8-Pin Dual Flat No Lead (DFN) Package (Case #1452). . . . . . . . . . . . 16-Pin Plastic Dual In-Line Package (Case #648D) . . . . . . . . . . . . . . . 16-Pin Small Outline Integrated Circuit Package (Case #751G) . . . . . 16-Pin Thin Shrink Small Outline Package (Case #948F) . . . . . . . . . . MC68HC908QY/QT Family — Rev. 3 MOTOROLA 185 185 186 186 187 188 188 189 Data Sheet Table of Contents 15 Table of Contents Data Sheet 16 MC68HC908QY/QT Family — Rev. 3 Table of Contents MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 1. General Description 1.1 Introduction The MC68HC908QY4 is a member of the low-cost, high-performance M68HC08 Family of 8-bit microcontroller units (MCUs). The M68HC08 Family is a Complex Instruction Set Computer (CISC) with a Von Neumann architecture. All MCUs in the family use the enhanced M68HC08 central processor unit (CPU08) and are available with a variety of modules, memory sizes and types, and package types. 0.4 Table 1-1. Summary of Device Variations Device FLASH Memory Size Analog-to-Digital Converter Pin Count MC68HC908QT1 1536 bytes — 8 pins MC68HC908QT2 1536 bytes 4 ch, 8 bit 8 pins MC68HC908QT4 4096 bytes 4 ch, 8 bit 8 pins MC68HC908QY1 1536 bytes — 16 pins MC68HC908QY2 1536 bytes 4 ch, 8 bit 16 pins MC68HC908QY4 4096 bytes 4 ch, 8 bit 16 pins 1.2 Features Features include: • High-performance M68HC08 CPU core • Fully upward-compatible object code with M68HC05 Family • 5-V and 3-V operating voltages (VDD) • 8-MHz internal bus operation at 5 V, 4-MHz at 3 V • Trimmable internal oscillator – 3.2 MHz internal bus operation – 8-bit trim capability allows 0.4% accuracy(1) – ± 25% untrimmed • Auto wakeup from STOP capability • Configuration (CONFIG) register for MCU configuration options, including: – Low-voltage inhibit (LVI) trip point 1. The oscillator frequency is guaranteed to ±5% over temperature and voltage range after trimming. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet General Description 17 General Description • In-system FLASH programming • FLASH security(1) • On-chip in-application programmable FLASH memory (with internal program/erase voltage generation) – MC68HC908QY4 and MC68HC908QT4 — 4096 bytes – MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, and MC68HC908QT1 — 1536 bytes • 128 bytes of on-chip random-access memory (RAM) • 2-channel, 16-bit timer interface module (TIM) • 4-channel, 8-bit analog-to-digital converter (ADC) on MC68HC908QY2, MC68HC908QY4, MC68HC908QT2, and MC68HC908QT4 • 5 or 13 bidirectional input/output (I/O) lines and one input only: – Six shared with keyboard interrupt function and ADC – Two shared with timer channels – One shared with external interrupt (IRQ) – Eight extra I/O lines on 16-pin package only – High current sink/source capability on all port pins – Selectable pullups on all ports, selectable on an individual bit basis – Three-state ability on all port pins • 6-bit keyboard interrupt with wakeup feature (KBI) • Low-voltage inhibit (LVI) module features: – Software selectable trip point in CONFIG register • System protection features: – Computer operating properly (COP) watchdog – Low-voltage detection with reset – Illegal opcode detection with reset – Illegal address detection with reset • External asynchronous interrupt pin with internal pullup (IRQ) shared with general-purpose input pin • Master asynchronous reset pin (RST) shared with general-purpose input/output (I/O) pin • Power-on reset • Internal pullups on IRQ and RST to reduce external components • Memory mapped I/O registers • Power saving stop and wait modes 1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users. Data Sheet 18 MC68HC908QY/QT Family — Rev. 3 General Description MOTOROLA General Description MCU Block Diagram • MC68HC908QY4, MC68HC908QY2, and MC68HC908QY1 are available in these packages: – 16-pin plastic dual in-line package (PDIP) – 16-pin small outline integrated circuit (SOIC) package – 16-pin thin shrink small outline package (TSSOP) • MC68HC908QT4, MC68HC908QT2, and MC68HC908QT1 are available in these packages: – 8-pin PDIP – 8-pin SOIC – 8-pin dual flat no lead (DFN) package Features of the CPU08 include the following: • Enhanced HC05 programming model • Extensive loop control functions • 16 addressing modes (eight more than the HC05) • 16-bit index register and stack pointer • Memory-to-memory data transfers • Fast 8 × 8 multiply instruction • Fast 16/8 divide instruction • Binary-coded decimal (BCD) instructions • Optimization for controller applications • Efficient C language support 1.3 MCU Block Diagram Figure 1-1 shows the structure of the MC68HC908QY4. 1.4 Pin Assignments The MC68HC908QT4, MC68HC908QT2, and MC68HC908QT1 are available in 8-pin packages and the MC68HC908QY4, MC68HC908QY2, and MC68HC908QY1 in 16-pin packages. Figure 1-2 shows the pin assignment for these packages. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet General Description 19 General Description PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 1-1. Block Diagram Data Sheet 20 MC68HC908QY/QT Family — Rev. 3 General Description MOTOROLA General Description Pin Assignments VDD 1 8 VSS PTA0/TCH0/KBI0 PTA5/OSC1/AD3/KBI5 2 7 PTA0/AD0/TCH0/KBI0 6 PTA1/TCH1/KBI1 PTA4/OSC2/AD2/KBI4 3 6 PTA1/AD1/TCH1/KBI1 5 PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 4 5 PTA2/IRQ/KBI2/TCLK VDD 1 8 VSS PTA5/OSC1/KBI5 2 7 PTA4/OSC2/KBI4 3 PTA3/RST/KBI3 4 8-PIN ASSIGNMENT MC68HC908QT1 PDIP/SOIC 8-PIN ASSIGNMENT MC68HC908QT2 AND MC68HC908QT4 PDIP/SOIC VDD 1 16 VSS PTB0 PTB7 2 15 PTB0 14 PTB1 PTB6 3 14 PTB1 4 13 PTA0/TCH0/KBI0 PTA5/OSC1/AD3/KBI5 4 13 PTA0/AD0/TCH0/KBI0 PTA4/OSC2/KBI4 5 12 PTA1/TCH1/KBI1 PTA4/OSC2/AD2/KBI4 5 12 PTA1/AD1/TCH1/KBI1 PTB5 6 11 PTB2 PTB5 6 11 PTB2 PTB4 7 10 PTB3 PTB4 7 10 PTB3 PTA3/RST/KBI3 8 9 PTA3/RST/KBI3 8 9 VDD 1 16 VSS PTB7 2 15 PTB6 3 PTA5/OSC1/KBI5 PTA2/IRQ/KBI2/TCLK 16-PIN ASSIGNMENT MC68HC908QY2 AND MC68HC908QY4 PDIP/SOIC 16-PIN ASSIGNMENT MC68HC908QY1 PDIP/SOIC PTA0/TCH0/KBI0 PTB1 PTB0 VSS VDD PTB7 PTB6 PTA5/OSC1/KBI5 1 2 3 4 5 6 7 8 16 15 14 13 12 11 10 9 PTA1/TCH1/KBI1 PTB2 PTB3 PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 PTB4 PTB5 PTA4/OSC2/KBI4 PTA0/AD0/TCH0/KBI0 PTB1 PTB0 VSS VDD PTB7 PTB6 PTA5/OSC1/AD3/KBI5 16-PIN ASSIGNMENT MC68HC908QY1 TSSOP PTA0/TCH0/KBI0 1 PTA2/IRQ/KBI2/TCLK 1 2 3 4 5 6 7 8 16 15 14 13 12 11 10 9 PTA1/AD1/TCH1/KBI1 PTB2 PTB3 PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 PTB4 PTB5 PTA4/OSC2/AD2/KBI4 16-PIN ASSIGNMENT MC68HC908QY2 AND MC68HC908QY4 TSSOP 8 PTA1/TCH1/KBI1 PTA0/AD0/TCH0/KBI0 1 8 PTA1/AD1/TCH1/KBI1 VSS 2 7 PTA2/IRQ/KBI2/TCLK VSS 2 7 PTA2/IRQ/KBI2/TCLK VDD 3 6 PTA3/RST/KBI3 VDD 3 6 PTA3/RST/KBI3 PTA5/OSC1/KB15 4 5 PTA4/OSC2/KBI4 PTA5//OSC1/AD3/KB15 4 8-PIN ASSIGNMENT MC68HC908QT1 DFN 5 PTA4/OSC2/AD2/KBI4 8-PIN ASSIGNMENT MC68HC908QT2 AND MC68HC908QT4 DFN Figure 1-2. MCU Pin Assignments MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet General Description 21 General Description 1.5 Pin Functions Table 1-2 provides a description of the pin functions. Table 1-2. Pin Functions Pin Name Description Input/Output VDD Power supply Power VSS Power supply ground Power PTA0 — General purpose I/O port Input/Output AD0 — A/D channel 0 input Input PTA0 TCH0 — Timer Channel 0 I/O Input/Output KBI0 — Keyboard interrupt input 0 Input PTA1 — General purpose I/O port Input/Output AD1 — A/D channel 1 input Input PTA1 TCH1 — Timer Channel 1 I/O Input/Output KBI1 — Keyboard interrupt input 1 Input PTA2 — General purpose input-only port Input IRQ — External interrupt with programmable pullup and Schmitt trigger input Input KBI2 — Keyboard interrupt input 2 Input TCLK — Timer clock input Input PTA2 PTA3 — General purpose I/O port PTA3 PTA4 Input/Output RST — Reset input, active low with internal pullup and Schmitt trigger Input KBI3 — Keyboard interrupt input 3 Input PTA4 — General purpose I/O port Input/Output OSC2 — XTAL oscillator output (XTAL option only) RC or internal oscillator output (OSC2EN = 1 in PTAPUE register) Output Output AD2 — A/D channel 2 input Input KBI4 — Keyboard interrupt input 4 Input PTA5 — General purpose I/O port Input/Output OSC1 — XTAL, RC, or external oscillator input Input AD3 — A/D channel 3 input Input KBI5 — Keyboard interrupt input 5 Input PTA5 PTB[0:7](1) 8 general-purpose I/O ports Input/Output 1. The PTB pins are not available on the 8-pin packages. Data Sheet 22 MC68HC908QY/QT Family — Rev. 3 General Description MOTOROLA General Description Pin Function Priority 1.6 Pin Function Priority Table 1-3 is meant to resolve the priority if multiple functions are enabled on a single pin. NOTE: Upon reset all pins come up as input ports regardless of the priority table. Table 1-3. Function Priority in Shared Pins Pin Name Highest-to-Lowest Priority Sequence PTA0 AD0 → TCH0 → KBI0 → PTA0 PTA1 AD1 →TCH1 → KBI1 → PTA1 PTA2 IRQ → KBI2 → TCLK → PTA2 PTA3 RST → KBI3 → PTA3 PTA4 OSC2 → AD2 → KBI4 → PTA4 PTA5 OSC1 → AD3 → KBI5 → PTA5 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet General Description 23 General Description Data Sheet 24 MC68HC908QY/QT Family — Rev. 3 General Description MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 2. Memory 2.1 Introduction The central processor unit (CPU08) can address 64 Kbytes of memory space. The memory map, shown in Figure 2-1, includes: • 4096 bytes of user FLASH for MC68HC908QT4 and MC68HC908QY4 • 1536 bytes of user FLASH for MC68HC908QT2, MC68HC908QT1, MC68HC908QY2, and MC68HC908QY1 • 128 bytes of random access memory (RAM) • 48 bytes of user-defined vectors, located in FLASH • 416 bytes of monitor read-only memory (ROM) • 1536 bytes of FLASH program and erase routines, located in ROM 2.2 Unimplemented Memory Locations Accessing an unimplemented location can have unpredictable effects on MCU operation. In Figure 2-1 and in register figures in this document, unimplemented locations are shaded. 2.3 Reserved Memory Locations Accessing a reserved location can have unpredictable effects on MCU operation. In Figure 2-1 and in register figures in this document, reserved locations are marked with the word Reserved or with the letter R. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 25 Memory $0000 ↓ $003F I/O REGISTERS 64 BYTES $0040 ↓ $007F RESERVED(1) 64 BYTES $0080 ↓ $00FF RAM 128 BYTES $0100 ↓ $27FF UNIMPLEMENTED(1) 9984 BYTES $2800 ↓ $2DFF AUXILIARY ROM 1536 BYTES $2E00 ↓ $EDFF UNIMPLEMENTED(1) 49152 BYTES $EE00 ↓ $FDFF FLASH MEMORY MC68HC908QT4 AND MC68HC908QY4 4096 BYTES Note 1. Attempts to execute code from addresses in this range will generate an illegal address reset. $2E00 UNIMPLEMENTED 51712 BYTES ↓ $F7FF $FE00 BREAK STATUS REGISTER (BSR) $FE01 RESET STATUS REGISTER (SRSR) $FE02 BREAK AUXILIARY REGISTER (BRKAR) $FE03 BREAK FLAG CONTROL REGISTER (BFCR) $FE04 INTERRUPT STATUS REGISTER 1 (INT1) $FE05 INTERRUPT STATUS REGISTER 2 (INT2) MC68HC908QT1, MC68HC908QT2, MC68HC908QY1, and MC68HC908QY2 Memory Map $FE06 INTERRUPT STATUS REGISTER 3 (INT3) $FE07 RESERVED FOR FLASH TEST CONTROL REGISTER (FLTCR) $FE08 FLASH CONTROL REGISTER (FLCR) $FE09 BREAK ADDRESS HIGH REGISTER (BRKH) $FE0A BREAK ADDRESS LOW REGISTER (BRKL) $FE0B BREAK STATUS AND CONTROL REGISTER (BRKSCR) $FE0C LVISR $FE0D ↓ $FE0F RESERVED FOR FLASH TEST 3 BYTES $FE10 ↓ $FFAF MONITOR ROM 416 BYTES $FFB0 ↓ $FFBD FLASH 14 BYTES $FFBE FLASH BLOCK PROTECT REGISTER (FLBPR) $FFBF RESERVED FLASH $FFC0 INTERNAL OSCILLATOR TRIM VALUE $FFC1 RESERVED FLASH $FFC2 ↓ $FFCF FLASH 14 BYTES $FFD0 ↓ $FFFF USER VECTORS 48 BYTES $F800 ↓ $FDFF FLASH MEMORY 1536 BYTES Figure 2-1. Memory Map Data Sheet 26 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory Input/Output (I/O) Section 2.4 Input/Output (I/O) Section Addresses $0000–$003F, shown in Figure 2-2, contain most of the control, status, and data registers. Additional I/O registers have these addresses: • $FE00 — Break status register, BSR • $FE01 — Reset status register, SRSR • $FE02 — Break auxiliary register, BRKAR • $FE03 — Break flag control register, BFCR • $FE04 — Interrupt status register 1, INT1 • $FE05 — Interrupt status register 2, INT2 • $FE06 — Interrupt status register 3, INT3 • $FE07 — Reserved • $FE08 — FLASH control register, FLCR • $FE09 — Break address register high, BRKH • $FE0A — Break address register low, BRKL • $FE0B — Break status and control register, BRKSCR • $FE0C — LVI status register, LVISR • $FE0D — Reserved • $FFBE — FLASH block protect register, FLBPR • $FFC0 — Internal OSC trim value — Optional • $FFFF — COP control register, COPCTL MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 27 Memory Addr. Register Name Bit 7 $0000 Port A Data Register Read: (PTA) Write: See page 106. Reset: Port B Data Register Read: (PTB) Write: See page 109. Reset: $0001 $0002 Unimplemented $0003 Unimplemented $0004 Data Direction Register A Read: (DDRA) Write: See page 107. Reset: Read: $0005 Data Direction Register B (DDRB) Write: See page 109. Reset: $000C 4 3 2 PTA5 PTA4 PTA3 PTA2 1 Bit 0 PTA1 PTA0 PTB1 PTB0 DDRA1 DDRA0 Unaffected by reset PTB7 PTB6 PTB5 PTB4 PTB3 PTB2 Unaffected by reset 0 R R DDRA5 DDRA4 DDRA3 0 0 0 0 0 0 0 0 DDRB7 DDRB6 DDRB5 DDRB4 DDRB3 DDRB2 DDRB1 DDRB0 0 0 0 0 0 0 0 0 PTAPUE5 PTAPUE4 PTAPUE3 PTAPUE2 PTAPUE1 PTAPUE0 0 0 0 0 0 0 0 PTBPUE6 PTBPUE5 PTBPUE4 PTBPUE3 PTBPUE2 PTBPUE1 PTBPUE0 0 0 0 0 0 0 0 0 0 0 KEYF 0 IMASKK MODEK Unimplemented Port A Input Pullup Enable Read: Register (PTAPUE) Write: See page 108. Reset: OSC2EN 0 Port B Input Pullup Enable Read: PTBPUE7 Register (PTBPUE) Write: See page 111. Reset: 0 $000D ↓ $0019 Unimplemented $001A Keyboard Status and Read: Control Register (KBSCR) Write: See page 88. Reset: $001B AWUL 5 Unimplemented $0006 ↓ $000A $000B R 6 Keyboard Interrupt Read: Enable Register (KBIER) Write: See page 89. Reset: 0 0 ACKK 0 0 0 0 0 0 0 0 0 0 AWUIE KBIE5 KBIE4 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 0 0 0 R = Reserved = Unimplemented U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 1 of 5) Data Sheet 28 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory Input/Output (I/O) Section Addr. Register Name $001C $001D $001E Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 IRQF 0 IMASK MODE 0 0 0 R R RSTEN 0 0 0 0(2) Unimplemented IRQ Status and Control Read: Register (INTSCR) Write: See page 81. Reset: Configuration Register 2 Read: (CONFIG2)(1) Write: See page 56. Reset: ACK 0 0 0 IRQPUD IRQEN R 0 0 0 0 0 OSCOPT1 OSCOPT0 0 1. One-time writable register after each reset. 2. RSTEN reset to 0 by a power-on reset (POR) only. $001F Configuration Register 1 Read: (CONFIG1)(1) Write: See page 56. Reset: COPRS LVISTOP LVIRSTD LVIPWRD LVI5OR3 SSREC STOP COPD 0 0 0 0 0(2) 0 0 0 PS2 PS1 PS0 1. One-time writable register after each reset. 2. LVI5OR3 reset to 0 by a power-on reset (POR) only. $0020 $0021 $0022 $0023 $0024 $0025 TIM Status and Control Read: Register (TSC) Write: See page 141. Reset: TOF 0 0 1 0 0 0 0 0 Read: TIM Counter Register High (TCNTH) Write: See page 143. Reset: Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 0 0 0 0 0 0 0 0 Read: Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 1 1 1 1 1 1 1 1 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 1 1 1 1 1 1 1 1 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 TIM Counter Register Low (TCNTL) Write: See page 143. Reset: TIM Counter Modulo Read: Register High (TMODH) Write: See page 143. Reset: TIM Counter Modulo Read: Register Low (TMODL) Write: See page 143. Reset: TIM Channel 0 Status and Read: Control Register (TSC0) Write: See page 144. Reset: Read: $0026 TIM Channel 0 Register High (TCH0H) Write: See page 147. Reset: 0 CH0F 0 TOIE TSTOP 0 0 TRST Indeterminate after reset = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 2 of 5) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 29 Memory Addr. Register Name TIM Channel 0 Read: Register Low (TCH0L) Write: See page 147. Reset: $0027 $0028 TIM Channel 1 Status and Read: Control Register (TSC1) Write: See page 144. Reset: TIM Channel 1 Read: Register High (TCH1H) Write: See page 147. Reset: $0029 TIM Channel 1 Read: Register Low (TCH1L) Write: See page 147. Reset: $002A $002B ↓ $0035 Unimplemented $0036 Oscillator Status Register Read: (OSCSTAT) Write: See page 103. Reset: $0037 Unimplemented Read: Oscillator Trim Register (OSCTRIM) See page 104. Read: $0038 Write: Reset: $0039 ↓ $003B Unimplemented $003C ADC Status and Control Read: Register (ADSCR) Write: See page 46. Reset: $003D Unimplemented $003E ADC Data Register Read: (ADR) Write: See page 47. Reset: Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Indeterminate after reset CH1F 0 CH1IE 0 MS1A ELS1B ELS1A TOV1 CH1MAX 0 0 0 0 0 0 0 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 2 Bit 1 Bit 0 Indeterminate after reset Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Indeterminate after reset ECGST R R R R R R ECGON 0 0 0 0 0 0 0 0 TRIM7 TRIM6 TRIM5 TRIM4 TRIM3 TRIM2 TRIM1 TRIM0 1 0 0 0 0 0 0 0 AIEN ADCO CH4 CH3 CH2 CH1 CH0 0 0 0 1 1 1 1 1 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 COCO Indeterminate after reset = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 3 of 5) Data Sheet 30 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory Input/Output (I/O) Section Addr. $003F Register Name ADC Input Clock Register Read: (ADICLK) Write: See page 48. Reset: Break Status Register Read: (BSR) Write: See page 155. Reset: $FE00 Bit 7 6 5 4 3 2 1 Bit 0 ADIV2 ADIV1 ADIV0 0 0 0 0 0 0 0 0 0 0 0 0 0 R R R R R R SBSW See note 1 R 0 1. Writing a 0 clears SBSW. $FE01 SIM Reset Status Register (SRSR) See page 129. PIN COP ILOP ILAD MODRST LVI 0 POR: 1 0 0 0 0 0 0 0 Read: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 BCFE R R R R R R R 0 IF5 IF4 IF3 0 IF1 0 0 R R R R R R R R 0 0 0 0 0 0 0 0 IF14 0 0 0 0 0 0 0 R R R R R R R R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IF15 R R R R R R R R 0 0 0 0 0 0 0 0 R R R R R R R R 0 0 0 0 HVEN MASS ERASE PGM 0 0 0 0 0 0 0 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 0 0 0 0 0 0 0 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 R = Reserved Write: Break Flag Control Read: Register (BFCR) Write: See page 155. Reset: $FE03 $FE05 POR Break Auxiliary Register (BRKAR) Write: See page 154. Reset: $FE02 $FE04 Read: Interrupt Status Register 1 Read: (INT1) Write: See page 81. Reset: Interrupt Status Register 2 Read: (INT2) Write: See page 81. Reset: Read: $FE06 Interrupt Status Register 3 (INT3) Write: See page 81. Reset: $FE07 $FE08 Reserved FLASH Control Register Read: (FLCR) Write: See page 34. Reset: Read: $FE09 $FE0A Break Address High Register (BRKH) Write: See page 154. Reset: Break Address low Read: Register (BRKL) Write: See page 154. Reset: BDCOP 0 = Unimplemented U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 4 of 5) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 31 Memory Addr. $FE0B Register Name Break Status and Control Read: Register (BRKSCR) Write: See page 153. Reset: LVI Status Register Read: (LVISR) Write: See page 93. Reset: $FE0C $FE0D ↓ $FE0F Reserved for FLASH Test $FFBE FLASH Block Protect Read: Register (FLBPR) Write: See page 39. Reset: $FFBF Reserved $FFC0 Internal Oscillator Trim Value (Optional) $FFC1 Reserved Read: Write: Bit 7 6 5 4 3 2 1 Bit 0 BRKE BRKA 0 0 0 0 0 0 0 0 0 0 0 0 0 0 LVIOUT 0 0 0 0 0 0 R 0 0 0 0 0 0 0 0 R R R R R R R R BPR7 BPR6 BPR5 BPR4 BPR3 BPR2 BPR1 BPR0 Unaffected by reset R R R R R R R R TRIM7 TRIM6 TRIM5 TRIM4 TRIM3 TRIM2 TRIM1 TRIM0 R R R R R R Reset: $FFFF COP Control Register Read: (COPCTL) Write: See page 61. Reset: Unaffected by reset R R LOW BYTE OF RESET VECTOR WRITING CLEARS COP COUNTER (ANY VALUE) Unaffected by reset = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 5 of 5) Data Sheet 32 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory Random-Access Memory (RAM) . Table 2-1. Vector Addresses Vector Priority Lowest Vector Address Vector $FFDE ADC conversion complete vector (high) $FFDF ADC conversion complete vector (low) $FFE0 Keyboard vector (high) $FFE1 Keyboard vector (low) IF15 IF14 IF13 ↓ IF6 — Not used $FFF2 TIM overflow vector (high) $FFF3 TIM overflow vector (low) $FFF4 TIM Channel 1 vector (high) $FFF5 TIM Channel 1 vector (low) $FFF6 TIM Channel 0 vector (high) $FFF7 TIM Channel 0 vector (low) IF5 IF4 IF3 IF2 — Not used $FFFA IRQ vector (high) $FFFB IRQ vector (low) $FFFC SWI vector (high) $FFFD SWI vector (low) $FFFE Reset vector (high) $FFFF Reset vector (low) IF1 — Highest — 2.5 Random-Access Memory (RAM) Addresses $0080–$00FF are RAM locations. The location of the stack RAM is programmable. The 16-bit stack pointer allows the stack to be anywhere in the 64-Kbyte memory space. NOTE: For correct operation, the stack pointer must point only to RAM locations. Before processing an interrupt, the central processor unit (CPU) uses five bytes of the stack to save the contents of the CPU registers. NOTE: For M6805, M146805, and M68HC05 compatibility, the H register is not stacked. During a subroutine call, the CPU uses two bytes of the stack to store the return address. The stack pointer decrements during pushes and increments during pulls. NOTE: Be careful when using nested subroutines. The CPU may overwrite data in the RAM during a subroutine or during the interrupt stacking operation. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 33 Memory 2.6 FLASH Memory (FLASH) This subsection describes the operation of the embedded FLASH memory. The FLASH memory can be read, programmed, and erased from a single external supply. The program and erase operations are enabled through the use of an internal charge pump. The FLASH memory consists of an array of 4096 or 1536 bytes with an additional 48 bytes for user vectors. The minimum size of FLASH memory that can be erased is 64 bytes; and the maximum size of FLASH memory that can be programmed in a program cycle is 32 bytes (a row). Program and erase operations are facilitated through control bits in the FLASH control register (FLCR). Details for these operations appear later in this section. The address ranges for the user memory and vectors are: NOTE: • $EE00 – $FDFF; user memory, 4096 bytes: MC68HC908QY4 and MC68HC908QT4 • $F800 – $FDFF; user memory, 1536 bytes: MC68HC908QY2, MC68HC908QT2, MC68HC908QY1 and MC68HC908QT1 • $FFD0 – $FFFF; user interrupt vectors, 48 bytes. An erased bit reads as a 1 and a programmed bit reads as a 0. A security feature prevents viewing of the FLASH contents.(1) 2.6.1 FLASH Control Register The FLASH control register (FLCR) controls FLASH program and erase operations. Address: Read: $FE08 Bit 7 6 5 4 0 0 0 0 0 0 0 0 Write: Reset: 3 2 1 Bit 0 HVEN MASS ERASE PGM 0 0 0 0 Figure 2-3. FLASH Control Register (FLCR) HVEN — High Voltage Enable Bit This read/write bit enables high voltage from the charge pump to the memory for either program or erase operation. It can only be set if either PGM =1 or ERASE =1 and the proper sequence for program or erase is followed. 1 = High voltage enabled to array and charge pump on 0 = High voltage disabled to array and charge pump off 1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users. Data Sheet 34 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory FLASH Memory (FLASH) MASS — Mass Erase Control Bit This read/write bit configures the memory for mass erase operation. 1 = Mass erase operation selected 0 = Mass erase operation unselected ERASE — Erase Control Bit This read/write bit configures the memory for erase operation. ERASE is interlocked with the PGM bit such that both bits cannot be equal to 1 or set to 1 at the same time. 1 = Erase operation selected 0 = Erase operation unselected PGM — Program Control Bit This read/write bit configures the memory for program operation. PGM is interlocked with the ERASE bit such that both bits cannot be equal to 1 or set to 1 at the same time. 1 = Program operation selected 0 = Program operation unselected 2.6.2 FLASH Page Erase Operation Use the following procedure to erase a page of FLASH memory. A page consists of 64 consecutive bytes starting from addresses $XX00, $XX40, $XX80, or $XXC0. The 48-byte user interrupt vectors area also forms a page. Any FLASH memory page can be erased alone. 1. Set the ERASE bit and clear the MASS bit in the FLASH control register. 2. Read the FLASH block protect register. 3. Write any data to any FLASH location within the address range of the block to be erased. 4. Wait for a time, tNVS (minimum 10 µs). 5. Set the HVEN bit. 6. Wait for a time, tErase (minimum 1 ms or 4 ms). 7. Clear the ERASE bit. 8. Wait for a time, tNVH (minimum 5 µs). 9. Clear the HVEN bit. 10. After time, tRCV (typical 1 µs), the memory can be accessed in read mode again. NOTE: CAUTION: Programming and erasing of FLASH locations cannot be performed by code being executed from the FLASH memory. While these operations must be performed in the order as shown, but other unrelated operations may occur between the steps. A page erase of the vector page will erase the internal oscillator trim value at $FFC0. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 35 Memory In applications that require more than 1000 program/erase cycles, use the 4 ms page erase specification to get improved long-term reliability. Any application can use this 4 ms page erase specification. However, in applications where a FLASH location will be erased and reprogrammed less than 1000 times, and speed is important, use the 1 ms page erase specification to get a shorter cycle time. 2.6.3 FLASH Mass Erase Operation Use the following procedure to erase the entire FLASH memory to read as a 1: 1. Set both the ERASE bit and the MASS bit in the FLASH control register. 2. Read the FLASH block protect register. 3. Write any data to any FLASH address(1) within the FLASH memory address range. 4. Wait for a time, tNVS (minimum 10 µs). 5. Set the HVEN bit. 6. Wait for a time, tMErase (minimum 4 ms). 7. Clear the ERASE and MASS bits. NOTE: Mass erase is disabled whenever any block is protected (FLBPR does not equal $FF). 8. Wait for a time, tNVHL (minimum 100 µs). 9. Clear the HVEN bit. 10. After time, tRCV (typical 1 µs), the memory can be accessed in read mode again. NOTE: CAUTION: Programming and erasing of FLASH locations cannot be performed by code being executed from the FLASH memory. While these operations must be performed in the order as shown, but other unrelated operations may occur between the steps. A mass erase will erase the internal oscillator trim value at $FFC0. 2.6.4 FLASH Program Operation Programming of the FLASH memory is done on a row basis. A row consists of 32 consecutive bytes starting from addresses $XX00, $XX20, $XX40, $XX60, $XX80, $XXA0, $XXC0, or $XXE0. Use the following step-by-step procedure to program a row of FLASH memory Figure 2-4 shows a flowchart of the programming algorithm. NOTE: Only bytes which are currently $FF may be programmed. 1. When in monitor mode, with security sequence failed (see 15.3.2 Security), write to the FLASH block protect register instead of any FLASH address. Data Sheet 36 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory FLASH Memory (FLASH) 1. Set the PGM bit. This configures the memory for program operation and enables the latching of address and data for programming. 2. Read the FLASH block protect register. 3. Write any data to any FLASH location within the address range desired. 4. Wait for a time, tNVS (minimum 10 µs). 5. Set the HVEN bit. 6. Wait for a time, tPGS (minimum 5 µs). 7. Write data to the FLASH address being programmed(1). 8. Wait for time, tPROG (minimum 30 µs). 9. Repeat step 7 and 8 until all desired bytes within the row are programmed. 10. Clear the PGM bit(1). 11. Wait for time, tNVH (minimum 5 µs). 12. Clear the HVEN bit. 13. After time, tRCV (typical 1 µs), the memory can be accessed in read mode again. NOTE: The COP register at location $FFFF should not be written between steps 5–12, when the HVEN bit is set. Since this register is located at a valid FLASH address, unpredictable behavior may occur if this location is written while HVEN is set. This program sequence is repeated throughout the memory until all data is programmed. NOTE: Programming and erasing of FLASH locations cannot be performed by code being executed from the FLASH memory. While these operations must be performed in the order shown, other unrelated operations may occur between the steps. Do not exceed tPROG maximum, see 16.16 Memory Characteristics. 2.6.5 FLASH Protection Due to the ability of the on-board charge pump to erase and program the FLASH memory in the target application, provision is made to protect blocks of memory from unintentional erase or program operations due to system malfunction. This protection is done by use of a FLASH block protect register (FLBPR). The FLBPR determines the range of the FLASH memory which is to be protected. The range of the protected area starts from a location defined by FLBPR and ends to the bottom of the FLASH memory ($FFFF). When the memory is protected, the HVEN bit cannot be set in either ERASE or PROGRAM operations. NOTE: In performing a program or erase operation, the FLASH block protect register must be read after setting the PGM or ERASE bit and before asserting the HVEN bit. 1. The time between each FLASH address change, or the time between the last FLASH address programmed to clearing PGM bit, must not exceed the maximum programming time, tPROG maximum. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 37 Memory Algorithm for Programming a Row (32 Bytes) of FLASH Memory 1 SET PGM BIT 2 READ THE FLASH BLOCK PROTECT REGISTER 3 WRITE ANY DATA TO ANY FLASH ADDRESS WITHIN THE ROW ADDRESS RANGE DESIRED 4 WAIT FOR A TIME, tNVS 5 SET HVEN BIT 6 WAIT FOR A TIME, tPGS 7 WRITE DATA TO THE FLASH ADDRESS TO BE PROGRAMMED 8 WAIT FOR A TIME, tPROG 9 COMPLETED PROGRAMMING THIS ROW? Y N 10 CLEAR PGM BIT 11 WAIT FOR A TIME, tNVH 12 NOTES: The time between each FLASH address change (step 7 to step 7), or the time between the last FLASH address programmed to clearing PGM bit (step 7 to step 10) must not exceed the maximum programming time, tPROG max. CLEAR HVEN BIT 13 WAIT FOR A TIME, tRCV END OF PROGRAMMING This row program algorithm assumes the row/s to be programmed are initially erased. Figure 2-4. FLASH Programming Flowchart Data Sheet 38 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Memory FLASH Memory (FLASH) When the FLBPR is programmed with all 0 s, the entire memory is protected from being programmed and erased. When all the bits are erased (all 1’s), the entire memory is accessible for program and erase. When bits within the FLBPR are programmed, they lock a block of memory. The address ranges are shown in 2.6.6 FLASH Block Protect Register. Once the FLBPR is programmed with a value other than $FF, any erase or program of the FLBPR or the protected block of FLASH memory is prohibited. Mass erase is disabled whenever any block is protected (FLBPR does not equal $FF). The FLBPR itself can be erased or programmed only with an external voltage, VTST, present on the IRQ pin. This voltage also allows entry from reset into the monitor mode. 2.6.6 FLASH Block Protect Register The FLASH block protect register is implemented as a byte within the FLASH memory, and therefore can only be written during a programming sequence of the FLASH memory. The value in this register determines the starting address of the protected range within the FLASH memory. Address: Read: Write: $FFBE Bit 7 6 5 4 3 2 1 Bit 0 BPR7 BPR6 BPR5 BPR4 BPR3 BPR2 BPR1 BPR0 Reset: Unaffected by reset. Initial value from factory is 1. Write to this register is by a programming sequence to the FLASH memory. Figure 2-5. FLASH Block Protect Register (FLBPR) BPR[7:0] — FLASH Protection Register Bits [7:0] These eight bits in FLBPR represent bits [13:6] of a 16-bit memory address. Bits [15:14] are 1s and bits [5:0] are 0s. The resultant 16-bit address is used for specifying the start address of the FLASH memory for block protection. The FLASH is protected from this start address to the end of FLASH memory, at $FFFF. With this mechanism, the protect start address can be XX00, XX40, XX80, or XXC0 within the FLASH memory. See Figure 2-6 and Table 2-2. 16-BIT MEMORY ADDRESS START ADDRESS OF FLASH BLOCK PROTECT 1 1 FLBPR VALUE 0 0 0 0 0 0 Figure 2-6. FLASH Block Protect Start Address MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Memory 39 Memory Table 2-2. Examples of Protect Start Address BPR[7:0] Start of Address of Protect Range $00–$B8 The entire FLASH memory is protected. $B9 (1011 1001) $EE40 (1110 1110 0100 0000) $BA (1011 1010) $EE80 (1110 1110 1000 0000) $BB (1011 1011) $EEC0 (1110 1110 1100 0000) $BC (1011 1100) $EF00 (1110 1111 0000 0000) and so on... $DE (1101 1110) $F780 (1111 0111 1000 0000) $DF (1101 1111) $F7C0 (1111 0111 1100 0000) $FE (1111 1110) $FF80 (1111 1111 1000 0000) FLBPR, OSCTRIM, and vectors are protected $FF The entire FLASH memory is not protected. 2.6.7 Wait Mode Putting the MCU into wait mode while the FLASH is in read mode does not affect the operation of the FLASH memory directly, but there will not be any memory activity since the CPU is inactive. The WAIT instruction should not be executed while performing a program or erase operation on the FLASH, or the operation will discontinue and the FLASH will be on standby mode. 2.6.8 Stop Mode Putting the MCU into stop mode while the FLASH is in read mode does not affect the operation of the FLASH memory directly, but there will not be any memory activity since the CPU is inactive. The STOP instruction should not be executed while performing a program or erase operation on the FLASH, or the operation will discontinue and the FLASH will be on standby mode NOTE: Standby mode is the power-saving mode of the FLASH module in which all internal control signals to the FLASH are inactive and the current consumption of the FLASH is at a minimum. Data Sheet 40 MC68HC908QY/QT Family — Rev. 3 Memory MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 3. Analog-to-Digital Converter (ADC) 3.1 Introduction This section describes the analog-to-digital converter (ADC). The ADC is an 8-bit, 4-channel analog-to-digital converter. The ADC module is only available on the MC68HC908QY2, MC68HC908QT2, MC68HC908QY4, and MC68HC908QT4. 3.2 Features Features of the ADC module include: • 4 channels with multiplexed input • Linear successive approximation with monotonicity • 8-bit resolution • Single or continuous conversion • Conversion complete flag or conversion complete interrupt • Selectable ADC clock frequency Figure 3-1 provides a summary of the input/output (I/O) registers. Addr. Register Name ADC Status and Control Register (ADSCR) See page 46. $003C $003D Unimplemented $003E ADC Data Register (ADR) See page 47. $003F ADC Input Clock Register (ADICLK) See page 48. Bit 7 Read: COCO Write: 6 5 4 3 2 1 Bit 0 AIEN ADCO CH4 CH3 CH2 CH1 CH0 Reset: 0 0 0 1 1 1 1 1 Read: AD7 AD6 AD5 AD4 AD3 AD2 AD1 AD0 Write: Reset: Read: Write: Reset: Indeterminate after reset ADIV2 ADIV1 ADIV0 0 0 0 0 0 0 0 0 0 0 0 0 0 = Unimplemented Figure 3-1. ADC I/O Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Analog-to-Digital Converter (ADC) 41 Analog-to-Digital Converter (ADC) PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 3-2. Block Diagram Highlighting ADC Block and Pins Data Sheet 42 MC68HC908QY/QT Family — Rev. 3 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) Functional Description 3.3 Functional Description Four ADC channels are available for sampling external sources at pins PTA0, PTA1, PTA4, and PTA5. An analog multiplexer allows the single ADC converter to select one of the four ADC channels as an ADC voltage input (ADCVIN). ADCVIN is converted by the successive approximation register-based counters. The ADC resolution is eight bits. When the conversion is completed, ADC puts the result in the ADC data register and sets a flag or generates an interrupt. Figure 3-3 shows a block diagram of the ADC. INTERNAL DATA BUS READ DDRA DISABLE WRITE DDRA DDRAx RESET WRITE PTA ADCx PTAx READ PTA DISABLE ADC CHANNEL x ADC DATA REGISTER INTERRUPT LOGIC AIEN CONVERSION COMPLETE COCO BUS CLOCK ADC VOLTAGE IN ADCVIN ADC CHANNEL SELECT (1 OF 4 CHANNELS) CH[4:0] ADC CLOCK CLOCK GENERATOR ADIV[2:0] Figure 3-3. ADC Block Diagram MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Analog-to-Digital Converter (ADC) 43 Analog-to-Digital Converter (ADC) 3.3.1 ADC Port I/O Pins PTA0, PTA1, PTA4, and PTA5 are general-purpose I/O pins that are shared with the ADC channels. The channel select bits (ADC status and control register (ADSCR), $003C), define which ADC channel/port pin will be used as the input signal. The ADC overrides the port I/O logic by forcing that pin as input to the ADC. The remaining ADC channels/port pins are controlled by the port I/O logic and can be used as general-purpose I/O. Writes to the port register or data direction register (DDR) will not have any affect on the port pin that is selected by the ADC. Read of a port pin which is in use by the ADC will return a 0 if the corresponding DDR bit is at 0. If the DDR bit is at 1, the value in the port data latch is read. 3.3.2 Voltage Conversion When the input voltage to the ADC equals VDD, the ADC converts the signal to $FF (full scale). If the input voltage equals VSS, the ADC converts it to $00. Input voltages between VDD and VSS are a straight-line linear conversion. All other input voltages will result in $FF if greater than VDD and $00 if less than VSS. NOTE: Input voltage should not exceed the analog supply voltages. 3.3.3 Conversion Time Sixteen ADC internal clocks are required to perform one conversion. The ADC starts a conversion on the first rising edge of the ADC internal clock immediately following a write to the ADSCR. If the ADC internal clock is selected to run at 1 MHz, then one conversion will take 16 µs to complete. With a 1-MHz ADC internal clock the maximum sample rate is 62.5 kHz. Conversion Time = 16 ADC Clock Cycles ADC Clock Frequency Number of Bus Cycles = Conversion Time × Bus Frequency 3.3.4 Continuous Conversion In the continuous conversion mode (ADCO = 1), the ADC continuously converts the selected channel filling the ADC data register (ADR) with new data after each conversion. Data from the previous conversion will be overwritten whether that data has been read or not. Conversions will continue until the ADCO bit is cleared. The COCO bit (ADSCR, $003C) is set after each conversion and will stay set until the next read of the ADC data register. When a conversion is in process and the ADSCR is written, the current conversion data should be discarded to prevent an incorrect reading. 3.3.5 Accuracy and Precision The conversion process is monotonic and has no missing codes. Data Sheet 44 MC68HC908QY/QT Family — Rev. 3 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) Interrupts 3.4 Interrupts When the AIEN bit is set, the ADC module is capable of generating a central processor unit (CPU) interrupt after each ADC conversion. A CPU interrupt is generated if the COCO bit is at 0. The COCO bit is not used as a conversion complete flag when interrupts are enabled. 3.5 Low-Power Modes The following subsections describe the ADC in low-power modes. 3.5.1 Wait Mode The ADC continues normal operation during wait mode. Any enabled CPU interrupt request from the ADC can bring the microcontroller unit (MCU) out of wait mode. If the ADC is not required to bring the MCU out of wait mode, power down the ADC by setting the CH[4:0] bits in ADSCR to 1s before executing the WAIT instruction. 3.5.2 Stop Mode The ADC module is inactive after the execution of a STOP instruction. Any pending conversion is aborted. ADC conversions resume when the MCU exits stop mode. Allow one conversion cycle to stabilize the analog circuitry before using ADC data after exiting stop mode. 3.6 Input/Output Signals The ADC module has four channels that are shared with I/O port A. ADC voltage in (ADCVIN) is the input voltage signal from one of the four ADC channels to the ADC module. 3.7 Input/Output Registers These I/O registers control and monitor ADC operation: • ADC status and control register (ADSCR) • ADC data register (ADR) • ADC clock register (ADICLK) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Analog-to-Digital Converter (ADC) 45 Analog-to-Digital Converter (ADC) 3.7.1 ADC Status and Control Register The following paragraphs describe the function of the ADC status and control register (ADSCR). When a conversion is in process and the ADSCR is written, the current conversion data should be discarded to prevent an incorrect reading. Address: $003C Bit 7 Read: COCO Write: Reset: 0 6 5 4 3 2 1 Bit 0 AIEN ADCO CH4 CH3 CH2 CH1 CH0 0 0 1 1 1 1 1 = Unimplemented Figure 3-4. ADC Status and Control Register (ADSCR) COCO — Conversions Complete Bit In non-interrupt mode (AIEN = 0), COCO is a read-only bit that is set at the end of each conversion. COCO will stay set until cleared by a read of the ADC data register. Reset clears this bit. In interrupt mode (AIEN = 1), COCO is a read-only bit that is not set at the end of a conversion. It always reads as a 0. 1 = Conversion completed (AIEN = 0) 0 = Conversion not completed (AIEN = 0) or CPU interrupt enabled (AIEN = 1) NOTE: The write function of the COCO bit is reserved. When writing to the ADSCR register, always have a 0 in the COCO bit position. AIEN — ADC Interrupt Enable Bit When this bit is set, an interrupt is generated at the end of an ADC conversion. The interrupt signal is cleared when ADR is read or ADSCR is written. Reset clears the AIEN bit. 1 = ADC interrupt enabled 0 = ADC interrupt disabled ADCO — ADC Continuous Conversion Bit When set, the ADC will convert samples continuously and update ADR at the end of each conversion. Only one conversion is allowed when this bit is cleared. Reset clears the ADCO bit. 1 = Continuous ADC conversion 0 = One ADC conversion CH[4:0] — ADC Channel Select Bits CH4, CH3, CH2, CH1, and CH0 form a 5-bit field which is used to select one of the four ADC channels. The five select bits are detailed in Table 3-1. Care should be taken when using a port pin as both an analog and a digital input simultaneously to prevent switching noise from corrupting the analog signal. Data Sheet 46 MC68HC908QY/QT Family — Rev. 3 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) Input/Output Registers The ADC subsystem is turned off when the channel select bits are all set to 1. This feature allows for reduced power consumption for the MCU when the ADC is not used. Reset sets all of these bits to 1. NOTE: Recovery from the disabled state requires one conversion cycle to stabilize. Table 3-1. MUX Channel Select CH4 CH3 CH2 CH1 CH0 ADC Channel Input Select 0 0 0 0 0 ADC0 PTA0 0 0 0 0 1 ADC1 PTA1 0 0 0 1 0 ADC2 PTA4 0 0 0 1 1 ADC3 PTA5 0 0 1 0 0 — ↓ ↓ ↓ ↓ ↓ — 1 1 0 1 0 — 1 1 0 1 1 — Reserved 1 1 1 0 0 — Unused 1 1 1 0 1 — VDDA(2) 1 1 1 1 0 — VSSA(2) 1 1 1 1 1 — ADC power off Unused(1) 1. If any unused channels are selected, the resulting ADC conversion will be unknown. 2. The voltage levels supplied from internal reference nodes, as specified in the table, are used to verify the operation of the ADC converter both in production test and for user applications. 3.7.2 ADC Data Register One 8-bit result register is provided. This register is updated each time an ADC conversion completes. Address: $003E Read: Bit 7 6 5 4 3 2 1 Bit 0 AD7 AD6 AD5 AD4 AD3 AD2 AD1 AD0 Write: Reset: Indeterminate after reset = Unimplemented Figure 3-5. ADC Data Register (ADR) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Analog-to-Digital Converter (ADC) 47 Analog-to-Digital Converter (ADC) 3.7.3 ADC Input Clock Register This register selects the clock frequency for the ADC. Address: $003F Bit 7 Read: Write: Reset: 6 5 ADIV2 ADIV1 ADIV0 0 0 0 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 = Unimplemented Figure 3-6. ADC Input Clock Register (ADICLK) ADIV2–ADIV0 — ADC Clock Prescaler Bits ADIV2, ADIV1, and ADIV0 form a 3-bit field which selects the divide ratio used by the ADC to generate the internal ADC clock. Table 3-2 shows the available clock configurations. The ADC clock frequency should be set between fADIC(MIN) and fADIC(MAX). The analog input level should remain stable for the entire conversion time (maximum = 17 ADC clock cycles). Table 3-2. ADC Clock Divide Ratio ADIV2 ADIV1 ADIV0 ADC Clock Rate 0 0 0 Bus clock ÷ 1 0 0 1 Bus clock ÷ 2 0 1 0 Bus clock ÷ 4 0 1 1 Bus clock ÷ 8 1 X X Bus clock ÷ 16 X = don’t care Data Sheet 48 MC68HC908QY/QT Family — Rev. 3 Analog-to-Digital Converter (ADC) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 4. Auto Wakeup Module (AWU) 4.1 Introduction This section describes the auto wakeup module (AWU). The AWU generates a periodic interrupt during stop mode to wake the part up without requiring an external signal. Figure 4-2 is a block diagram of the AWU. 4.2 Features Features of the auto wakeup module include: • One internal interrupt with separate interrupt enable bit, sharing the same keyboard interrupt vector and keyboard interrupt mask bit • Exit from low-power stop mode without external signals • Selectable timeout periods • Dedicated low-power internal oscillator separate from the main system clock sources Figure 4-1 provides a summary of the input/output (I/O) registers used in conjuction with the AWU. Addr. Register Name $0000 $001A $001B Bit 7 6 Port A Data Register Read: (PTA) Write: See page 52. Reset: 0 AWUL Keyboard Status Read: and Control Register Write: (KBSCR) See page 52. Reset: 0 Keyboard Interrupt Enable Read: Register (KBIER) Write: See page 53. Reset: 5 4 3 PTA5 PTA4 PTA3 2 PTA2 1 Bit 0 PTA1 PTA0 IMASKK MODEK Unaffected by reset 0 0 0 KEYF 0 ACKK 0 0 0 0 0 0 0 0 0 0 AWUIE KBIE5 KBIE4 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 0 0 0 = Unimplemented Figure 4-1. AWU Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Auto Wakeup Module (AWU) 49 Auto Wakeup Module (AWU) 4.3 Functional Description The function of the auto wakeup logic is to generate periodic wakeup requests to bring the microcontroller unit (MCU) out of stop mode. The wakeup requests are treated as regular keyboard interrupt requests, with the difference that instead of a pin, the interrupt signal is generated by an internal logic. Writing the AWUIE bit in the keyboard interrupt enable register enables or disables the auto wakeup interrupt input (see Figure 4-2). A logic 1 applied to the AWUIREQ input with auto wakeup interrupt request enabled, latches an auto wakeup interrupt request. Auto wakeup latch, AWUL, can be read directly from the bit 6 position of port A data register (PTA). This is a read-only bit which is occupying an empty bit position on PTA. No PTA associated registers, such as PTA6 data direction or PTA6 pullup exist for this bit. Entering stop mode will enable the auto wakeup generation logic. An internal RC oscillator (exclusive for the auto wakeup feature) drives the wakeup request generator. Once the overflow count is reached in the generator counter, a wakeup request, AWUIREQ, is latched and sent to the KBI logic. See Figure 4-1. Wakeup interrupt requests will only be serviced if the associated interrupt enable bit, AWUIE, in KBIER is set. The AWU shares the keyboard interrupt vector. COPRS (FROM CONFIG1) VDD AUTOWUGEN TO PTA READ, BIT 6 1 = DIV 29 SHORT 0 = DIV 214 OVERFLOW INT RC OSC EN D 32 kHz CLK E RST AWUL Q AWUIREQ R TO KBI INTERRUPT LOGIC (SEE Figure 9-3. Keyboard Interrupt Block Diagram) CLRLOGIC RESET CLEAR ACKK (CGMXCLK) BUSCLKX4 CLK RST RESET ISTOP RESET AWUIE Figure 4-2. Auto Wakeup Interrupt Request Generation Logic Data Sheet 50 MC68HC908QY/QT Family — Rev. 3 Auto Wakeup Module (AWU) MOTOROLA Auto Wakeup Module (AWU) Wait Mode The overflow count can be selected from two options defined by the COPRS bit in CONFIG1. This bit was “borrowed” from the computer operating properly (COP) using the fact that the COP feature is idle (no MCU clock available) in stop mode. The typical values of the periodic wakeup request are (at room temperature): • COPRS = 0: 650 ms @ 5 V, 875 ms @ 3 V • COPRS = 1: 16 ms @ 5 V, 22 ms @ 3 V The auto wakeup RC oscillator is highly dependent on operating voltage and temperature. This feature is not recommended for use as a time-keeping function. The wakeup request is latched to allow the interrupt source identification. The latched value, AWUL, can be read directly from the bit 6 position of PTA data register. This is a read-only bit which is occupying an empty bit position on PTA. No PTA associated registers, such as PTA6 data, PTA6 direction, and PTA6 pullup exist for this bit. The latch can be cleared by writing to the ACKK bit in the KBSCR register. Reset also clears the latch. AWUIE bit in KBI interrupt enable register (see Figure 4-2) has no effect on AWUL reading. The AWU oscillator and counters are inactive in normal operating mode and become active only upon entering stop mode. 4.4 Wait Mode The AWU module remains inactive in wait mode. 4.5 Stop Mode When the AWU module is enabled (AWUIE = 1 in the keyboard interrupt enable register) it is activated automatically upon entering stop mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of stop mode. The AWU counters start from ‘0’ each time stop mode is entered. 4.6 Input/Output Registers The AWU shares registers with the keyboard interrupt (KBI) module and the port A I/O module. The following I/O registers control and monitor operation of the AWU: • Port A data register (PTA) • Keyboard interrupt status and control register (KBSCR) • Keyboard interrupt enable register (KBIER) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Auto Wakeup Module (AWU) 51 Auto Wakeup Module (AWU) 4.6.1 Port A I/O Register The port A data register (PTA) contains a data latch for the state of the AWU interrupt request, in addition to the data latches for port A. Address: $0000 Read: Bit 7 6 0 AWUL 0 0 Write: Reset: 5 4 3 2 PTA5 PTA4 PTA3 PTA2 1 Bit 0 PTA1 PTA0 Unaffected by reset = Unimplemented Figure 4-3. Port A Data Register (PTA) AWUL — Auto Wakeup Latch This is a read-only bit which has the value of the auto wakeup interrupt request latch. The wakeup request signal is generated internally. There is no PTA6 port or any of the associated bits such as PTA6 data direction or pullup bits. 1 = Auto wakeup interrupt request is pending 0 = Auto wakeup interrupt request is not pending NOTE: PTA5–PTA0 bits are not used in conjuction with the auto wakeup feature. To see a description of these bits, see 12.2.1 Port A Data Register. 4.6.2 Keyboard Status and Control Register The keyboard status and control register (KBSCR): • Flags keyboard/auto wakeup interrupt requests • Acknowledges keyboard/auto wakeup interrupt requests • Masks keyboard/auto wakeup interrupt requests Address: $001A Read: Bit 7 6 5 4 3 2 0 0 0 0 KEYF 0 Write: Reset: ACKK 0 0 0 0 0 0 1 Bit 0 IMASKK MODEK 0 0 = Unimplemented Figure 4-4. Keyboard Status and Control Register (KBSCR) Bits 7–4 — Not used These read-only bits always read as 0s. KEYF — Keyboard Flag Bit This read-only bit is set when a keyboard interrupt is pending on port A or auto wakeup. Reset clears the KEYF bit. 1 = Keyboard/auto wakeup interrupt pending 0 = No keyboard/auto wakeup interrupt pending Data Sheet 52 MC68HC908QY/QT Family — Rev. 3 Auto Wakeup Module (AWU) MOTOROLA Auto Wakeup Module (AWU) Input/Output Registers ACKK — Keyboard Acknowledge Bit Writing a 1 to this write-only bit clears the keyboard/auto wakeup interrupt request on port A and auto wakeup logic. ACKK always reads as 0.Reset clears ACKK. IMASKK— Keyboard Interrupt Mask Bit Writing a 1 to this read/write bit prevents the output of the keyboard interrupt mask from generating interrupt requests on port A or auto wakeup. Reset clears the IMASKK bit. 1 = Keyboard/auto wakeup interrupt requests masked 0 = Keyboard/auto wakeup interrupt requests not masked NOTE: MODEK is not used in conjuction with the auto wakeup feature. To see a description of this bit, see 9.7.1 Keyboard Status and Control Register. 4.6.3 Keyboard Interrupt Enable Register The keyboard interrupt enable register (KBIER) enables or disables the auto wakeup to operate as a keyboard/auto wakeup interrupt input. Address: $001B Bit 7 Read: 0 Write: Reset: 0 6 5 4 3 2 1 Bit 0 AWUIE KBIE5 KBIE4 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 0 0 0 = Unimplemented Figure 4-5. Keyboard Interrupt Enable Register (KBIER) AWUIE — Auto Wakeup Interrupt Enable Bit This read/write bit enables the auto wakeup interrupt input to latch interrupt requests. Reset clears AWUIE. 1 = Auto wakeup enabled as interrupt input 0 = Auto wakeup not enabled as interrupt input NOTE: KBIE5–KBIE0 bits are not used in conjuction with the auto wakeup feature. To see a description of these bits, see 9.7.2 Keyboard Interrupt Enable Register. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Auto Wakeup Module (AWU) 53 Auto Wakeup Module (AWU) Data Sheet 54 MC68HC908QY/QT Family — Rev. 3 Auto Wakeup Module (AWU) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 5. Configuration Register (CONFIG) 5.1 Introduction This section describes the configuration registers (CONFIG1 and CONFIG2). The configuration registers enable or disable the following options: • Stop mode recovery time (32 × BUSCLKX4 cycles or 4096 × BUSCLKX4 cycles) • STOP instruction • Computer operating properly module (COP) • COP reset period (COPRS): (213 –24) × BUSCLKX4 or (218 –24) × BUSCLKX4 • Low-voltage inhibit (LVI) enable and trip voltage selection • OSC option selection • IRQ pin • RST pin • Auto wakeup timeout period 5.2 Functional Description The configuration registers are used in the initialization of various options. The configuration registers can be written once after each reset. Most of the configuration register bits are cleared during reset. Since the various options affect the operation of the microcontroller unit (MCU) it is recommended that this register be written immediately after reset. The configuration registers are located at $001E and $001F, and may be read at anytime. NOTE: The CONFIG registers are one-time writable by the user after each reset. Upon a reset, the CONFIG registers default to predetermined settings as shown in Figure 5-1 and Figure 5-2. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Configuration Register (CONFIG) 55 Configuration Register (CONFIG) Address: $001E Bit 7 6 5 4 3 2 1 Bit 0 IRQPUD IRQEN R OSCOPT1 OSCOPT0 R R RSTEN Reset: 0 0 0 0 0 0 0 U POR: 0 0 0 0 0 0 0 0 R = Reserved Read: Write: U = Unaffected Figure 5-1. Configuration Register 2 (CONFIG2) IRQPUD — IRQ Pin Pullup Control Bit 1 = Internal pullup is disconnected 0 = Internal pullup is connected between IRQ pin and VDD IRQEN — IRQ Pin Function Selection Bit 1 = Interrupt request function active in pin 0 = Interrupt request function inactive in pin OSCOPT1 and OSCOPT0 — Selection Bits for Oscillator Option (0, 0) Internal oscillator (0, 1) External oscillator (1, 0) External RC oscillator (1, 1) External XTAL oscillator RSTEN — RST Pin Function Selection 1 = Reset function active in pin 0 = Reset function inactive in pin NOTE: The RSTEN bit is cleared by a power-on reset (POR) only. Other resets will leave this bit unaffected. Address: $001F Bit 7 6 5 4 3 2 1 Bit 0 COPRS LVISTOP LVIRSTD LVIPWRD LVI5OR3 SSREC STOP COPD Reset: 0 0 0 0 U 0 0 0 POR: 0 0 0 0 0 0 0 0 Read: Write: U = Unaffected Figure 5-2. Configuration Register 1 (CONFIG1) COPRS (Out of STOP Mode) — COP Reset Period Selection Bit 1 = COP reset short cycle = (213 – 24) × BUSCLKX4 0 = COP reset long cycle = (218 – 24) × BUSCLKX4 COPRS (In STOP Mode) — Auto Wakeup Period Selection Bit 1 = Auto wakeup short cycle = (29) × INTRCOSC 0 = Auto wakeup long cycle = (214) × INTRCOSC Data Sheet 56 MC68HC908QY/QT Family — Rev. 3 Configuration Register (CONFIG) MOTOROLA Configuration Register (CONFIG) Functional Description LVISTOP — LVI Enable in Stop Mode Bit When the LVIPWRD bit is clear, setting the LVISTOP bit enables the LVI to operate during stop mode. Reset clears LVISTOP. 1 = LVI enabled during stop mode 0 = LVI disabled during stop mode LVIRSTD — LVI Reset Disable Bit LVIRSTD disables the reset signal from the LVI module. 1 = LVI module resets disabled 0 = LVI module resets enabled LVIPWRD — LVI Power Disable Bit LVIPWRD disables the LVI module. 1 = LVI module power disabled 0 = LVI module power enabled LVI5OR3 — LVI 5-V or 3-V Operating Mode Bit LVI5OR3 selects the voltage operating mode of the LVI module. The voltage mode selected for the LVI should match the operating VDD for the LVI’s voltage trip points for each of the modes. 1 = LVI operates in 5-V mode 0 = LVI operates in 3-V mode NOTE: The LVI5OR3 bit is cleared by a power-on reset (POR) only. Other resets will leave this bit unaffected. SSREC — Short Stop Recovery Bit SSREC enables the CPU to exit stop mode with a delay of 32 BUSCLKX4 cycles instead of a 4096 BUSCLKX4 cycle delay. 1 = Stop mode recovery after 32 BUSCLKX4 cycles 0 = Stop mode recovery after 4096 BUSCLKX4 cycles NOTE: Exiting stop mode by an LVI reset will result in the long stop recovery. When using the LVI during normal operation but disabling during stop mode, the LVI will have an enable time of tEN. The system stabilization time for power-on reset and long stop recovery (both 4096 BUSCLKX4 cycles) gives a delay longer than the LVI enable time for these startup scenarios. There is no period where the MCU is not protected from a low-power condition. However, when using the short stop recovery configuration option, the 32 BUSCLKX4 delay must be greater than the LVI’s turn on time to avoid a period in startup where the LVI is not protecting the MCU. STOP — STOP Instruction Enable Bit STOP enables the STOP instruction. 1 = STOP instruction enabled 0 = STOP instruction treated as illegal opcode COPD — COP Disable Bit COPD disables the COP module. 1 = COP module disabled 0 = COP module enabled MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Configuration Register (CONFIG) 57 Configuration Register (CONFIG) Data Sheet 58 MC68HC908QY/QT Family — Rev. 3 Configuration Register (CONFIG) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 6. Computer Operating Properly (COP) 6.1 Introduction The computer operating properly (COP) module contains a free-running counter that generates a reset if allowed to overflow. The COP module helps software recover from runaway code. Prevent a COP reset by clearing the COP counter periodically. The COP module can be disabled through the COPD bit in the configuration 1 (CONFIG1) register. 6.2 Functional Description INTERNAL RESET SOURCES RESET STATUS REGISTER COP TIMEOUT CLEAR STAGES 5–12 STOP INSTRUCTION RESET CIRCUIT 12-BIT SIM COUNTER CLEAR ALL STAGES BUSCLKX4 COPCTL WRITE COP CLOCK COPEN (FROM SIM) COP DISABLE (COPD FROM CONFIG1) RESET COPCTL WRITE 6-BIT COP COUNTER CLEAR COP COUNTER COP RATE SELECT (COPRS FROM CONFIG1) Figure 6-1. COP Block Diagram MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Computer Operating Properly (COP) 59 Computer Operating Properly (COP) The COP counter is a free-running 6-bit counter preceded by the 12-bit system integration module (SIM) counter. If not cleared by software, the COP counter overflows and generates an asynchronous reset after 218 – 24 or 213 – 24 BUSCLKX4 cycles; depending on the state of the COP rate select bit, COPRS, in configuration register 1. With a 218 – 24 BUSCLKX4 cycle overflow option, the internal 12.8-MHz oscillator gives a COP timeout period of 20.48 ms. Writing any value to location $FFFF before an overflow occurs prevents a COP reset by clearing the COP counter and stages 12–5 of the SIM counter. NOTE: Service the COP immediately after reset and before entering or after exiting stop mode to guarantee the maximum time before the first COP counter overflow. A COP reset pulls the RST pin low (if the RSTEN bit is set in the CONFIG1 register) for 32 × BUSCLKX4 cycles and sets the COP bit in the reset status register (RSR). See 13.8.1 SIM Reset Status Register. NOTE: Place COP clearing instructions in the main program and not in an interrupt subroutine. Such an interrupt subroutine could keep the COP from generating a reset even while the main program is not working properly. 6.3 I/O Signals The following paragraphs describe the signals shown in Figure 6-1. 6.3.1 BUSCLKX4 BUSCLKX4 is the oscillator output signal. BUSCLKX4 frequency is equal to the crystal frequency or the RC-oscillator frequency. 6.3.2 STOP Instruction The STOP instruction clears the SIM counter. 6.3.3 COPCTL Write Writing any value to the COP control register (COPCTL) (see 6.4 COP Control Register) clears the COP counter and clears stages 12–5 of the SIM counter. Reading the COP control register returns the low byte of the reset vector. 6.3.4 Power-On Reset The power-on reset (POR) circuit in the SIM clears the SIM counter 4096 × BUSCLKX4 cycles after power up. 6.3.5 Internal Reset An internal reset clears the SIM counter and the COP counter. Data Sheet 60 MC68HC908QY/QT Family — Rev. 3 Computer Operating Properly (COP) MOTOROLA Computer Operating Properly (COP) COP Control Register 6.3.6 COPD (COP Disable) The COPD signal reflects the state of the COP disable bit (COPD) in the configuration register 1 (CONFIG1). See Section 5. Configuration Register (CONFIG). 6.3.7 COPRS (COP Rate Select) The COPRS signal reflects the state of the COP rate select bit (COPRS) in the configuration register 1 (CONFIG1). See Section 5. Configuration Register (CONFIG). 6.4 COP Control Register The COP control register (COPCTL) is located at address $FFFF and overlaps the reset vector. Writing any value to $FFFF clears the COP counter and starts a new timeout period. Reading location $FFFF returns the low byte of the reset vector. Address: $FFFF Bit 7 6 5 4 3 Read: LOW BYTE OF RESET VECTOR Write: CLEAR COP COUNTER Reset: Unaffected by reset 2 1 Bit 0 Figure 6-2. COP Control Register (COPCTL) 6.5 Interrupts The COP does not generate CPU interrupt requests. 6.6 Monitor Mode The COP is disabled in monitor mode when VTST is present on the IRQ pin. 6.7 Low-Power Modes The WAIT and STOP instructions put the MCU in low power-consumption standby modes. 6.7.1 Wait Mode The COP continues to operate during wait mode. To prevent a COP reset during wait mode, periodically clear the COP counter. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Computer Operating Properly (COP) 61 Computer Operating Properly (COP) 6.7.2 Stop Mode Stop mode turns off the BUSCLKX4 input to the COP and clears the SIM counter. Service the COP immediately before entering or after exiting stop mode to ensure a full COP timeout period after entering or exiting stop mode. 6.8 COP Module During Break Mode The COP is disabled during a break interrupt with monitor mode when BDCOP bit is set in break auxiliary register (BRKAR). Data Sheet 62 MC68HC908QY/QT Family — Rev. 3 Computer Operating Properly (COP) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 7. Central Processor Unit (CPU) 7.1 Introduction The M68HC08 CPU (central processor unit) is an enhanced and fully object-code-compatible version of the M68HC05 CPU. The CPU08 Reference Manual (Motorola document order number CPU08RM/AD) contains a description of the CPU instruction set, addressing modes, and architecture. 7.2 Features Features of the CPU include: • Object code fully upward-compatible with M68HC05 Family • 16-bit stack pointer with stack manipulation instructions • 16-bit index register with x-register manipulation instructions • 8-MHz CPU internal bus frequency • 64-Kbyte program/data memory space • 16 addressing modes • Memory-to-memory data moves without using accumulator • Fast 8-bit by 8-bit multiply and 16-bit by 8-bit divide instructions • Enhanced binary-coded decimal (BCD) data handling • Modular architecture with expandable internal bus definition for extension of addressing range beyond 64 Kbytes • Low-power stop and wait modes MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Central Processor Unit (CPU) 63 Central Processor Unit (CPU) 7.3 CPU Registers Figure 7-1 shows the five CPU registers. CPU registers are not part of the memory map. 0 7 ACCUMULATOR (A) 0 15 H X INDEX REGISTER (H:X) 15 0 STACK POINTER (SP) 15 0 PROGRAM COUNTER (PC) 7 0 V 1 1 H I N Z C CONDITION CODE REGISTER (CCR) CARRY/BORROW FLAG ZERO FLAG NEGATIVE FLAG INTERRUPT MASK HALF-CARRY FLAG TWO’S COMPLEMENT OVERFLOW FLAG Figure 7-1. CPU Registers 7.3.1 Accumulator The accumulator is a general-purpose 8-bit register. The CPU uses the accumulator to hold operands and the results of arithmetic/logic operations. Bit 7 6 5 4 3 2 1 Bit 0 Read: Write: Reset: Unaffected by reset Figure 7-2. Accumulator (A) Data Sheet 64 MC68HC908QY/QT Family — Rev. 3 Central Processor Unit (CPU) MOTOROLA Central Processor Unit (CPU) CPU Registers 7.3.2 Index Register The 16-bit index register allows indexed addressing of a 64-Kbyte memory space. H is the upper byte of the index register, and X is the lower byte. H:X is the concatenated 16-bit index register. In the indexed addressing modes, the CPU uses the contents of the index register to determine the conditional address of the operand. The index register can serve also as a temporary data storage location. Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 X X X X X X X X Read: Write: Reset: X = Indeterminate Figure 7-3. Index Register (H:X) 7.3.3 Stack Pointer The stack pointer is a 16-bit register that contains the address of the next location on the stack. During a reset, the stack pointer is preset to $00FF. The reset stack pointer (RSP) instruction sets the least significant byte to $FF and does not affect the most significant byte. The stack pointer decrements as data is pushed onto the stack and increments as data is pulled from the stack. In the stack pointer 8-bit offset and 16-bit offset addressing modes, the stack pointer can function as an index register to access data on the stack. The CPU uses the contents of the stack pointer to determine the conditional address of the operand. Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 Read: Write: Reset: Figure 7-4. Stack Pointer (SP) NOTE: The location of the stack is arbitrary and may be relocated anywhere in random-access memory (RAM). Moving the SP out of page 0 ($0000 to $00FF) frees direct address (page 0) space. For correct operation, the stack pointer must point only to RAM locations. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Central Processor Unit (CPU) 65 Central Processor Unit (CPU) 7.3.4 Program Counter The program counter is a 16-bit register that contains the address of the next instruction or operand to be fetched. Normally, the program counter automatically increments to the next sequential memory location every time an instruction or operand is fetched. Jump, branch, and interrupt operations load the program counter with an address other than that of the next sequential location. During reset, the program counter is loaded with the reset vector address located at $FFFE and $FFFF. The vector address is the address of the first instruction to be executed after exiting the reset state. Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 Bit 0 1 Read: Write: Reset: Loaded with vector from $FFFE and $FFFF Figure 7-5. Program Counter (PC) 7.3.5 Condition Code Register The 8-bit condition code register contains the interrupt mask and five flags that indicate the results of the instruction just executed. Bits 6 and 5 are set permanently to 1. The following paragraphs describe the functions of the condition code register. Bit 7 6 5 4 3 2 1 Bit 0 V 1 1 H I N Z C X 1 1 X 1 X X X Read: Write: Reset: X = Indeterminate Figure 7-6. Condition Code Register (CCR) V — Overflow Flag The CPU sets the overflow flag when a two's complement overflow occurs. The signed branch instructions BGT, BGE, BLE, and BLT use the overflow flag. 1 = Overflow 0 = No overflow Data Sheet 66 MC68HC908QY/QT Family — Rev. 3 Central Processor Unit (CPU) MOTOROLA Central Processor Unit (CPU) CPU Registers H — Half-Carry Flag The CPU sets the half-carry flag when a carry occurs between accumulator bits 3 and 4 during an add-without-carry (ADD) or add-with-carry (ADC) operation. The half-carry flag is required for binary-coded decimal (BCD) arithmetic operations. The DAA instruction uses the states of the H and C flags to determine the appropriate correction factor. 1 = Carry between bits 3 and 4 0 = No carry between bits 3 and 4 I — Interrupt Mask When the interrupt mask is set, all maskable CPU interrupts are disabled. CPU interrupts are enabled when the interrupt mask is cleared. When a CPU interrupt occurs, the interrupt mask is set automatically after the CPU registers are saved on the stack, but before the interrupt vector is fetched. 1 = Interrupts disabled 0 = Interrupts enabled NOTE: To maintain M6805 Family compatibility, the upper byte of the index register (H) is not stacked automatically. If the interrupt service routine modifies H, then the user must stack and unstack H using the PSHH and PULH instructions. After the I bit is cleared, the highest-priority interrupt request is serviced first. A return-from-interrupt (RTI) instruction pulls the CPU registers from the stack and restores the interrupt mask from the stack. After any reset, the interrupt mask is set and can be cleared only by the clear interrupt mask software instruction (CLI). N — Negative flag The CPU sets the negative flag when an arithmetic operation, logic operation, or data manipulation produces a negative result, setting bit 7 of the result. 1 = Negative result 0 = Non-negative result Z — Zero flag The CPU sets the zero flag when an arithmetic operation, logic operation, or data manipulation produces a result of $00. 1 = Zero result 0 = Non-zero result C — Carry/Borrow Flag The CPU sets the carry/borrow flag when an addition operation produces a carry out of bit 7 of the accumulator or when a subtraction operation requires a borrow. Some instructions — such as bit test and branch, shift, and rotate — also clear or set the carry/borrow flag. 1 = Carry out of bit 7 0 = No carry out of bit 7 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Central Processor Unit (CPU) 67 Central Processor Unit (CPU) 7.4 Arithmetic/Logic Unit (ALU) The ALU performs the arithmetic and logic operations defined by the instruction set. Refer to the CPU08 Reference Manual (Motorola document order number CPU08RM/AD) for a description of the instructions and addressing modes and more detail about the architecture of the CPU. 7.5 Low-Power Modes The WAIT and STOP instructions put the MCU in low power-consumption standby modes. 7.5.1 Wait Mode The WAIT instruction: • Clears the interrupt mask (I bit) in the condition code register, enabling interrupts. After exit from wait mode by interrupt, the I bit remains clear. After exit by reset, the I bit is set. • Disables the CPU clock 7.5.2 Stop Mode The STOP instruction: • Clears the interrupt mask (I bit) in the condition code register, enabling external interrupts. After exit from stop mode by external interrupt, the I bit remains clear. After exit by reset, the I bit is set. • Disables the CPU clock After exiting stop mode, the CPU clock begins running after the oscillator stabilization delay. 7.6 CPU During Break Interrupts If a break module is present on the MCU, the CPU starts a break interrupt by: • Loading the instruction register with the SWI instruction • Loading the program counter with $FFFC:$FFFD or with $FEFC:$FEFD in monitor mode The break interrupt begins after completion of the CPU instruction in progress. If the break address register match occurs on the last cycle of a CPU instruction, the break interrupt begins immediately. A return-from-interrupt instruction (RTI) in the break routine ends the break interrupt and returns the MCU to normal operation if the break interrupt has been deasserted. Data Sheet 68 MC68HC908QY/QT Family — Rev. 3 Central Processor Unit (CPU) MOTOROLA Central Processor Unit (CPU) Instruction Set Summary 7.7 Instruction Set Summary Table 7-1 provides a summary of the M68HC08 instruction set. ADC #opr ADC opr ADC opr ADC opr,X ADC opr,X ADC ,X ADC opr,SP ADC opr,SP V H I N Z C A ← (A) + (M) + (C) Add with Carry IMM DIR EXT IX2   –    IX1 IX SP1 SP2 A9 B9 C9 D9 E9 F9 9EE9 9ED9 ii dd hh ll ee ff ff IMM DIR EXT IX2   –    IX1 IX SP1 SP2 AB BB CB DB EB FB 9EEB 9EDB ii dd hh ll ee ff ff ff ee ff A7 ii 2 – – – – – – IMM AF ii 2 IMM DIR EXT IX2 0 – –   – IX1 IX SP1 SP2 A4 B4 C4 D4 E4 F4 9EE4 9ED4 ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 0 DIR INH INH  – –    IX1 IX SP1 38 dd 48 58 68 ff 78 9E68 ff 4 1 1 4 3 5 C DIR INH INH  – –    IX1 IX SP1 37 dd 47 57 67 ff 77 9E67 ff 4 1 1 4 3 5 Add without Carry AIS #opr Add Immediate Value (Signed) to SP SP ← (SP) + (16 « M) – – – – – – IMM AIX #opr Add Immediate Value (Signed) to H:X H:X ← (H:X) + (16 « M) A ← (A) & (M) ASL opr ASLA ASLX ASL opr,X ASL ,X ASL opr,SP A ← (A) + (M) Logical AND Arithmetic Shift Left (Same as LSL) C b7 ASR opr ASRA ASRX ASR opr,X ASR opr,X ASR opr,SP Arithmetic Shift Right BCC rel Branch if Carry Bit Clear b0 b7 2 3 4 4 3 2 4 5 2 3 4 4 3 2 4 5 ADD #opr ADD opr ADD opr ADD opr,X ADD opr,X ADD ,X ADD opr,SP ADD opr,SP AND #opr AND opr AND opr AND opr,X AND opr,X AND ,X AND opr,SP AND opr,SP ff ee ff Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 7-1. Instruction Set Summary (Sheet 1 of 7) b0 PC ← (PC) + 2 + rel ? (C) = 0 Mn ← 0 ff ee ff – – – – – – REL 24 rr 3 DIR (b0) DIR (b1) DIR (b2) – – – – – – DIR (b3) DIR (b4) DIR (b5) DIR (b6) DIR (b7) 11 13 15 17 19 1B 1D 1F dd dd dd dd dd dd dd dd 4 4 4 4 4 4 4 4 BCLR n, opr Clear Bit n in M BCS rel Branch if Carry Bit Set (Same as BLO) PC ← (PC) + 2 + rel ? (C) = 1 – – – – – – REL 25 rr 3 BEQ rel Branch if Equal PC ← (PC) + 2 + rel ? (Z) = 1 – – – – – – REL 27 rr 3 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Central Processor Unit (CPU) 69 Central Processor Unit (CPU) V H I N Z C BGE opr Branch if Greater Than or Equal To (Signed Operands) BGT opr Branch if Greater Than (Signed Operands) BHCC rel Branch if Half Carry Bit Clear PC ← (PC) + 2 + rel ? (H) = 0 BHCS rel Branch if Half Carry Bit Set BHI rel Branch if Higher BHS rel PC ← (PC) + 2 + rel ? (N ⊕ V) = 0 Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 7-1. Instruction Set Summary (Sheet 2 of 7) – – – – – – REL 90 rr 3 PC ← (PC) + 2 + rel ? (Z) | (N ⊕ V) = 0 – – – – – – REL 92 rr 3 – – – – – – REL 28 rr 3 PC ← (PC) + 2 + rel ? (H) = 1 – – – – – – REL 29 rr PC ← (PC) + 2 + rel ? (C) | (Z) = 0 – – – – – – REL 22 rr 3 Branch if Higher or Same (Same as BCC) PC ← (PC) + 2 + rel ? (C) = 0 – – – – – – REL 24 rr 3 BIH rel Branch if IRQ Pin High PC ← (PC) + 2 + rel ? IRQ = 1 – – – – – – REL 2F rr 3 BIL rel Branch if IRQ Pin Low PC ← (PC) + 2 + rel ? IRQ = 0 – – – – – – REL 2E rr 3 (A) & (M) IMM DIR EXT 0 – –   – IX2 IX1 IX SP1 SP2 A5 B5 C5 D5 E5 F5 9EE5 9ED5 ii dd hh ll ee ff ff ff ee ff 2 3 4 4 3 2 4 5 93 rr 3 BIT #opr BIT opr BIT opr BIT opr,X BIT opr,X BIT ,X BIT opr,SP BIT opr,SP Bit Test BLE opr Branch if Less Than or Equal To (Signed Operands) BLO rel Branch if Lower (Same as BCS) BLS rel PC ← (PC) + 2 + rel ? (Z) | (N ⊕ V) = 1 – – – – – – REL 3 PC ← (PC) + 2 + rel ? (C) = 1 – – – – – – REL 25 rr 3 Branch if Lower or Same PC ← (PC) + 2 + rel ? (C) | (Z) = 1 – – – – – – REL 23 rr 3 BLT opr Branch if Less Than (Signed Operands) PC ← (PC) + 2 + rel ? (N ⊕ V) =1 – – – – – – REL 91 rr 3 BMC rel Branch if Interrupt Mask Clear PC ← (PC) + 2 + rel ? (I) = 0 – – – – – – REL 2C rr 3 BMI rel Branch if Minus PC ← (PC) + 2 + rel ? (N) = 1 – – – – – – REL 2B rr 3 BMS rel Branch if Interrupt Mask Set PC ← (PC) + 2 + rel ? (I) = 1 – – – – – – REL 2D rr 3 BNE rel Branch if Not Equal PC ← (PC) + 2 + rel ? (Z) = 0 – – – – – – REL 26 rr 3 BPL rel Branch if Plus PC ← (PC) + 2 + rel ? (N) = 0 – – – – – – REL 2A rr 3 BRA rel Branch Always PC ← (PC) + 2 + rel – – – – – – REL 20 rr 3 DIR (b0) DIR (b1) DIR (b2) DIR (b3) – – – – –  DIR (b4) DIR (b5) DIR (b6) DIR (b7) 01 03 05 07 09 0B 0D 0F dd rr dd rr dd rr dd rr dd rr dd rr dd rr dd rr 5 5 5 5 5 5 5 5 – – – – – – REL 21 rr 3 BRCLR n,opr,rel Branch if Bit n in M Clear BRN rel Branch Never PC ← (PC) + 3 + rel ? (Mn) = 0 PC ← (PC) + 2 Data Sheet 70 MC68HC908QY/QT Family — Rev. 3 Central Processor Unit (CPU) MOTOROLA Central Processor Unit (CPU) Instruction Set Summary PC ← (PC) + 3 + rel ? (Mn) = 1 DIR (b0) DIR (b1) DIR (b2) DIR (b3) – – – – –  DIR (b4) DIR (b5) DIR (b6) DIR (b7) 00 02 04 06 08 0A 0C 0E dd rr dd rr dd rr dd rr dd rr dd rr dd rr dd rr 5 5 5 5 5 5 5 5 Mn ← 1 DIR (b0) DIR (b1) DIR (b2) DIR (b3) – – – – – – DIR (b4) DIR (b5) DIR (b6) DIR (b7) 10 12 14 16 18 1A 1C 1E dd dd dd dd dd dd dd dd 4 4 4 4 4 4 4 4 PC ← (PC) + 2; push (PCL) SP ← (SP) – 1; push (PCH) SP ← (SP) – 1 PC ← (PC) + rel – – – – – – REL AD rr 4 PC ← (PC) + 3 + rel ? (A) – (M) = $00 PC ← (PC) + 3 + rel ? (A) – (M) = $00 PC ← (PC) + 3 + rel ? (X) – (M) = $00 PC ← (PC) + 3 + rel ? (A) – (M) = $00 PC ← (PC) + 2 + rel ? (A) – (M) = $00 PC ← (PC) + 4 + rel ? (A) – (M) = $00 DIR IMM – – – – – – IMM IX1+ IX+ SP1 31 41 51 61 71 9E61 dd rr ii rr ii rr ff rr rr ff rr 5 4 4 5 4 6 Description V H I N Z C BRSET n,opr,rel Branch if Bit n in M Set BSET n,opr Set Bit n in M BSR rel Branch to Subroutine CBEQ opr,rel CBEQA #opr,rel CBEQX #opr,rel Compare and Branch if Equal CBEQ opr,X+,rel CBEQ X+,rel CBEQ opr,SP,rel Cycles Operand Operation Effect on CCR Address Mode Source Form Opcode Table 7-1. Instruction Set Summary (Sheet 3 of 7) CLC Clear Carry Bit C←0 – – – – – 0 INH 98 1 CLI Clear Interrupt Mask I←0 – – 0 – – – INH 9A 2 M ← $00 A ← $00 X ← $00 H ← $00 M ← $00 M ← $00 M ← $00 DIR INH INH 0 – – 0 1 – INH IX1 IX SP1 3F dd 4F 5F 8C 6F ff 7F 9E6F ff (A) – (M) IMM DIR EXT IX2  – –    IX1 IX SP1 SP2 A1 B1 C1 D1 E1 F1 9EE1 9ED1 M ← (M) = $FF – (M) A ← (A) = $FF – (M) X ← (X) = $FF – (M) M ← (M) = $FF – (M) M ← (M) = $FF – (M) M ← (M) = $FF – (M) DIR INH INH 0 – –   1 IX1 IX SP1 33 dd 43 53 63 ff 73 9E63 ff (H:X) – (M:M + 1)  – –    IMM DIR CLR opr CLRA CLRX CLRH CLR opr,X CLR ,X CLR opr,SP CMP #opr CMP opr CMP opr CMP opr,X CMP opr,X CMP ,X CMP opr,SP CMP opr,SP Clear Compare A with M COM opr COMA COMX COM opr,X COM ,X COM opr,SP Complement (One’s Complement) CPHX #opr CPHX opr Compare H:X with M MC68HC908QY/QT Family — Rev. 3 MOTOROLA 65 75 ii dd hh ll ee ff ff ff ee ff ii ii+1 dd 3 1 1 1 3 2 4 2 3 4 4 3 2 4 5 4 1 1 4 3 5 3 4 Data Sheet Central Processor Unit (CPU) 71 Central Processor Unit (CPU) Compare X with M DAA Decimal Adjust A DBNZ opr,rel DBNZA rel DBNZX rel Decrement and Branch if Not Zero DBNZ opr,X,rel DBNZ X,rel DBNZ opr,SP,rel DEC opr DECA DECX DEC opr,X DEC ,X DEC opr,SP Decrement DIV Divide INC opr INCA INCX INC opr,X INC ,X INC opr,SP JMP opr JMP opr JMP opr,X JMP opr,X JMP ,X JSR opr JSR opr JSR opr,X JSR opr,X JSR ,X LDA #opr LDA opr LDA opr LDA opr,X LDA opr,X LDA ,X LDA opr,SP LDA opr,SP Exclusive OR M with A Increment Jump Jump to Subroutine Load A from M (X) – (M) (A)10 A3 B3 C3 D3 E3 F3 9EE3 9ED3 U – –    INH 72 A ← (A) – 1 or M ← (M) – 1 or X ← (X) – 1 PC ← (PC) + 3 + rel ? (result) ≠ 0 DIR PC ← (PC) + 2 + rel ? (result) ≠ 0 INH PC ← (PC) + 2 + rel ? (result) ≠ 0 – – – – – – INH PC ← (PC) + 3 + rel ? (result) ≠ 0 IX1 PC ← (PC) + 2 + rel ? (result) ≠ 0 IX PC ← (PC) + 4 + rel ? (result) ≠ 0 SP1 3B 4B 5B 6B 7B 9E6B ii dd hh ll ee ff ff ff ee ff 2 3 4 4 3 2 4 5 2 dd rr rr rr ff rr rr ff rr 5 3 3 5 4 6 M ← (M) – 1 A ← (A) – 1 X ← (X) – 1 M ← (M) – 1 M ← (M) – 1 M ← (M) – 1 DIR INH  – –   – INH IX1 IX SP1 A ← (H:A)/(X) H ← Remainder – – – –   INH 52 A ← (A ⊕ M) IMM DIR EXT IX2 0 – –   – IX1 IX SP1 SP2 A8 B8 C8 D8 E8 F8 9EE8 9ED8 M ← (M) + 1 A ← (A) + 1 X ← (X) + 1 M ← (M) + 1 M ← (M) + 1 M ← (M) + 1 DIR INH INH  – –   – IX1 IX SP1 3C dd 4C 5C 6C ff 7C 9E6C ff PC ← Jump Address DIR EXT – – – – – – IX2 IX1 IX BC CC DC EC FC dd hh ll ee ff ff 2 3 4 3 2 PC ← (PC) + n (n = 1, 2, or 3) Push (PCL); SP ← (SP) – 1 Push (PCH); SP ← (SP) – 1 PC ← Unconditional Address DIR EXT – – – – – – IX2 IX1 IX BD CD DD ED FD dd hh ll ee ff ff 4 5 6 5 4 A ← (M) IMM DIR EXT 0 – –   – IX2 IX1 IX SP1 SP2 A6 B6 C6 D6 E6 F6 9EE6 9ED6 ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 Data Sheet 72 IMM DIR EXT IX2  – –    IX1 IX SP1 SP2 Cycles V H I N Z C CPX #opr CPX opr CPX opr CPX ,X CPX opr,X CPX opr,X CPX opr,SP CPX opr,SP EOR #opr EOR opr EOR opr EOR opr,X EOR opr,X EOR ,X EOR opr,SP EOR opr,SP Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 7-1. Instruction Set Summary (Sheet 4 of 7) 3A dd 4A 5A 6A ff 7A 9E6A ff 4 1 1 4 3 5 7 ii dd hh ll ee ff ff ff ee ff ff ee ff 2 3 4 4 3 2 4 5 4 1 1 4 3 5 MC68HC908QY/QT Family — Rev. 3 Central Processor Unit (CPU) MOTOROLA Central Processor Unit (CPU) Instruction Set Summary LDHX #opr LDHX opr LDX #opr LDX opr LDX opr LDX opr,X LDX opr,X LDX ,X LDX opr,SP LDX opr,SP LSL opr LSLA LSLX LSL opr,X LSL ,X LSL opr,SP V H I N Z C Load H:X from M H:X ← (M:M + 1) IMM 0 – –   – DIR 45 55 X ← (M) IMM DIR EXT IX2 0 – –   – IX1 IX SP1 SP2 AE BE CE DE EE FE 9EEE 9EDE 0 DIR INH  – –    INH IX1 IX SP1 38 dd 48 58 68 ff 78 9E68 ff 4 1 1 4 3 5 C DIR INH INH  – – 0   IX1 IX SP1 34 dd 44 54 64 ff 74 9E64 ff 4 1 1 4 3 5 Load X from M Logical Shift Left (Same as ASL) LSR opr LSRA LSRX LSR opr,X LSR ,X LSR opr,SP Logical Shift Right MOV opr,opr MOV opr,X+ MOV #opr,opr MOV X+,opr Move MUL Unsigned multiply Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 7-1. Instruction Set Summary (Sheet 5 of 7) C b7 b0 0 b7 b0 (M)Destination ← (M)Source H:X ← (H:X) + 1 (IX+D, DIX+) 0 – –   – DD DIX+ IMD IX+D X:A ← (X) × (A) – 0 – – – 0 INH M ← –(M) = $00 – (M) A ← –(A) = $00 – (A) X ← –(X) = $00 – (X) M ← –(M) = $00 – (M) M ← –(M) = $00 – (M) DIR INH INH  – –    IX1 IX SP1 4E 5E 6E 7E ii jj dd 3 4 ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 ff ee ff dd dd dd ii dd dd 42 5 4 4 4 5 30 dd 40 50 60 ff 70 9E60 ff 4 1 1 4 3 5 NEG opr NEGA NEGX NEG opr,X NEG ,X NEG opr,SP Negate (Two’s Complement) NOP No Operation None – – – – – – INH 9D 1 NSA Nibble Swap A A ← (A[3:0]:A[7:4]) – – – – – – INH 62 3 A ← (A) | (M) IMM DIR EXT IX2 0 – –   – IX1 IX SP1 SP2 AA BA CA DA EA FA 9EEA 9EDA ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 ORA #opr ORA opr ORA opr ORA opr,X ORA opr,X ORA ,X ORA opr,SP ORA opr,SP Inclusive OR A and M PSHA Push A onto Stack Push (A); SP ← (SP) – 1 – – – – – – INH 87 2 PSHH Push H onto Stack Push (H); SP ← (SP) – 1 – – – – – – INH 8B 2 PSHX Push X onto Stack Push (X); SP ← (SP) – 1 – – – – – – INH 89 2 PULA Pull A from Stack SP ← (SP + 1); Pull (A) – – – – – – INH 86 2 PULH Pull H from Stack SP ← (SP + 1); Pull (H) – – – – – – INH 8A 2 PULX Pull X from Stack SP ← (SP + 1); Pull (X) – – – – – – INH 88 2 MC68HC908QY/QT Family — Rev. 3 MOTOROLA ff ee ff Data Sheet Central Processor Unit (CPU) 73 Central Processor Unit (CPU) ROL opr ROLA ROLX ROL opr,X ROL ,X ROL opr,SP V H I N Z C Rotate Left through Carry C b7 b0 Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 7-1. Instruction Set Summary (Sheet 6 of 7) DIR INH  – –    INH IX1 IX SP1 39 dd 49 59 69 ff 79 9E69 ff 4 1 1 4 3 5 DIR INH INH  – –    IX1 IX SP1 36 dd 46 56 66 ff 76 9E66 ff 4 1 1 4 3 5 ROR opr RORA RORX ROR opr,X ROR ,X ROR opr,SP Rotate Right through Carry RSP Reset Stack Pointer SP ← $FF – – – – – – INH 9C 1 RTI Return from Interrupt SP ← (SP) + 1; Pull (CCR) SP ← (SP) + 1; Pull (A) SP ← (SP) + 1; Pull (X) SP ← (SP) + 1; Pull (PCH) SP ← (SP) + 1; Pull (PCL)       INH 80 7 RTS Return from Subroutine SP ← SP + 1; Pull (PCH) SP ← SP + 1; Pull (PCL) – – – – – – INH 81 4 A ← (A) – (M) – (C) IMM DIR EXT  – –    IX2 IX1 IX SP1 SP2 A2 B2 C2 D2 E2 F2 9EE2 9ED2 C b7 b0 ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 SBC #opr SBC opr SBC opr SBC opr,X SBC opr,X SBC ,X SBC opr,SP SBC opr,SP Subtract with Carry SEC Set Carry Bit C←1 – – – – – 1 INH 99 1 SEI Set Interrupt Mask I←1 – – 1 – – – INH 9B 2 M ← (A) DIR EXT IX2 0 – –   – IX1 IX SP1 SP2 B7 C7 D7 E7 F7 9EE7 9ED7 (M:M + 1) ← (H:X) 0 – –   – DIR 35 I ← 0; Stop Oscillator – – 0 – – – INH 8E M ← (X) DIR EXT IX2 0 – –   – IX1 IX SP1 SP2 BF CF DF EF FF 9EEF 9EDF dd hh ll ee ff ff IMM DIR EXT  – –    IX2 IX1 IX SP1 SP2 A0 B0 C0 D0 E0 F0 9EE0 9ED0 ii dd hh ll ee ff ff STA opr STA opr STA opr,X STA opr,X STA ,X STA opr,SP STA opr,SP Store A in M STHX opr Store H:X in M STOP Enable IRQ Pin; Stop Oscillator STX opr STX opr STX opr,X STX opr,X STX ,X STX opr,SP STX opr,SP SUB #opr SUB opr SUB opr SUB opr,X SUB opr,X SUB ,X SUB opr,SP SUB opr,SP Store X in M Subtract A ← (A) – (M) Data Sheet 74 ff ee ff dd hh ll ee ff ff ff ee ff 3 4 4 3 2 4 5 dd 4 1 ff ee ff ff ee ff 3 4 4 3 2 4 5 2 3 4 4 3 2 4 5 MC68HC908QY/QT Family — Rev. 3 Central Processor Unit (CPU) MOTOROLA Central Processor Unit (CPU) Opcode Map V H I N Z C Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 7-1. Instruction Set Summary (Sheet 7 of 7) SWI Software Interrupt PC ← (PC) + 1; Push (PCL) SP ← (SP) – 1; Push (PCH) SP ← (SP) – 1; Push (X) SP ← (SP) – 1; Push (A) SP ← (SP) – 1; Push (CCR) SP ← (SP) – 1; I ← 1 PCH ← Interrupt Vector High Byte PCL ← Interrupt Vector Low Byte TAP Transfer A to CCR CCR ← (A)       INH 84 2 TAX Transfer A to X X ← (A) – – – – – – INH 97 1 TPA Transfer CCR to A A ← (CCR) – – – – – – INH 85 1 (A) – $00 or (X) – $00 or (M) – $00 DIR INH 0 – –   – INH IX1 IX SP1 H:X ← (SP) + 1 – – – – – – INH 95 2 A ← (X) – – – – – – INH 9F 1 (SP) ← (H:X) – 1 – – – – – – INH 94 2 TST opr TSTA TSTX TST opr,X TST ,X TST opr,SP Test for Negative or Zero TSX Transfer SP to H:X TXA Transfer X to A TXS Transfer H:X to SP A C CCR dd dd rr DD DIR DIX+ ee ff EXT ff H H hh ll I ii IMD IMM INH IX IX+ IX+D IX1 IX1+ IX2 M N Accumulator Carry/borrow bit Condition code register Direct address of operand Direct address of operand and relative offset of branch instruction Direct to direct addressing mode Direct addressing mode Direct to indexed with post increment addressing mode High and low bytes of offset in indexed, 16-bit offset addressing Extended addressing mode Offset byte in indexed, 8-bit offset addressing Half-carry bit Index register high byte High and low bytes of operand address in extended addressing Interrupt mask Immediate operand byte Immediate source to direct destination addressing mode Immediate addressing mode Inherent addressing mode Indexed, no offset addressing mode Indexed, no offset, post increment addressing mode Indexed with post increment to direct addressing mode Indexed, 8-bit offset addressing mode Indexed, 8-bit offset, post increment addressing mode Indexed, 16-bit offset addressing mode Memory location Negative bit n opr PC PCH PCL REL rel rr SP1 SP2 SP U V X Z & | ⊕ () –( ) # « ← ? :  — – – 1 – – – INH 83 9 3D dd 4D 5D 6D ff 7D 9E6D ff 3 1 1 3 2 4 Any bit Operand (one or two bytes) Program counter Program counter high byte Program counter low byte Relative addressing mode Relative program counter offset byte Relative program counter offset byte Stack pointer, 8-bit offset addressing mode Stack pointer 16-bit offset addressing mode Stack pointer Undefined Overflow bit Index register low byte Zero bit Logical AND Logical OR Logical EXCLUSIVE OR Contents of Negation (two’s complement) Immediate value Sign extend Loaded with If Concatenated with Set or cleared Not affected 7.8 Opcode Map See Table 7-2. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Central Processor Unit (CPU) 75 MSB Branch REL DIR INH 3 4 0 1 2 5 BRSET0 3 DIR 5 BRCLR0 3 DIR 5 BRSET1 3 DIR 5 BRCLR1 3 DIR 5 BRSET2 3 DIR 5 BRCLR2 3 DIR 5 BRSET3 3 DIR 5 BRCLR3 3 DIR 5 BRSET4 3 DIR 5 BRCLR4 3 DIR 5 BRSET5 3 DIR 5 BRCLR5 3 DIR 5 BRSET6 3 DIR 5 BRCLR6 3 DIR 5 BRSET7 3 DIR 5 BRCLR7 3 DIR 4 BSET0 2 DIR 4 BCLR0 2 DIR 4 BSET1 2 DIR 4 BCLR1 2 DIR 4 BSET2 2 DIR 4 BCLR2 2 DIR 4 BSET3 2 DIR 4 BCLR3 2 DIR 4 BSET4 2 DIR 4 BCLR4 2 DIR 4 BSET5 2 DIR 4 BCLR5 2 DIR 4 BSET6 2 DIR 4 BCLR6 2 DIR 4 BSET7 2 DIR 4 BCLR7 2 DIR 3 BRA 2 REL 3 BRN 2 REL 3 BHI 2 REL 3 BLS 2 REL 3 BCC 2 REL 3 BCS 2 REL 3 BNE 2 REL 3 BEQ 2 REL 3 BHCC 2 REL 3 BHCS 2 REL 3 BPL 2 REL 3 BMI 2 REL 3 BMC 2 REL 3 BMS 2 REL 3 BIL 2 REL 3 BIH 2 REL Read-Modify-Write INH IX1 5 6 1 NEGX 1 INH 4 CBEQX 3 IMM 7 DIV 1 INH 1 COMX 1 INH 1 LSRX 1 INH 4 LDHX 2 DIR 1 RORX 1 INH 1 ASRX 1 INH 1 LSLX 1 INH 1 ROLX 1 INH 1 DECX 1 INH 3 DBNZX 2 INH 1 INCX 1 INH 1 TSTX 1 INH 4 MOV 2 DIX+ 1 CLRX 1 INH 4 NEG 2 IX1 5 CBEQ 3 IX1+ 3 NSA 1 INH 4 COM 2 IX1 4 LSR 2 IX1 3 CPHX 3 IMM 4 ROR 2 IX1 4 ASR 2 IX1 4 LSL 2 IX1 4 ROL 2 IX1 4 DEC 2 IX1 5 DBNZ 3 IX1 4 INC 2 IX1 3 TST 2 IX1 4 MOV 3 IMD 3 CLR 2 IX1 SP1 IX 9E6 7 Control INH INH 8 9 Register/Memory IX2 SP2 IMM DIR EXT A B C D 9ED 4 SUB 3 EXT 4 CMP 3 EXT 4 SBC 3 EXT 4 CPX 3 EXT 4 AND 3 EXT 4 BIT 3 EXT 4 LDA 3 EXT 4 STA 3 EXT 4 EOR 3 EXT 4 ADC 3 EXT 4 ORA 3 EXT 4 ADD 3 EXT 3 JMP 3 EXT 5 JSR 3 EXT 4 LDX 3 EXT 4 STX 3 EXT 4 SUB 3 IX2 4 CMP 3 IX2 4 SBC 3 IX2 4 CPX 3 IX2 4 AND 3 IX2 4 BIT 3 IX2 4 LDA 3 IX2 4 STA 3 IX2 4 EOR 3 IX2 4 ADC 3 IX2 4 ORA 3 IX2 4 ADD 3 IX2 4 JMP 3 IX2 6 JSR 3 IX2 4 LDX 3 IX2 4 STX 3 IX2 5 SUB 4 SP2 5 CMP 4 SP2 5 SBC 4 SP2 5 CPX 4 SP2 5 AND 4 SP2 5 BIT 4 SP2 5 LDA 4 SP2 5 STA 4 SP2 5 EOR 4 SP2 5 ADC 4 SP2 5 ORA 4 SP2 5 ADD 4 SP2 IX1 SP1 IX E 9EE F LSB 0 1 2 3 4 5 Central Processor Unit (CPU) 6 7 8 9 A B C MOTOROLA MC68HC908QY/QT Family — Rev. 3 D E F 4 1 NEG NEGA 2 DIR 1 INH 5 4 CBEQ CBEQA 3 DIR 3 IMM 5 MUL 1 INH 4 1 COM COMA 2 DIR 1 INH 4 1 LSR LSRA 2 DIR 1 INH 4 3 STHX LDHX 2 DIR 3 IMM 4 1 ROR RORA 2 DIR 1 INH 4 1 ASR ASRA 2 DIR 1 INH 4 1 LSL LSLA 2 DIR 1 INH 4 1 ROL ROLA 2 DIR 1 INH 4 1 DEC DECA 2 DIR 1 INH 5 3 DBNZ DBNZA 3 DIR 2 INH 4 1 INC INCA 2 DIR 1 INH 3 1 TST TSTA 2 DIR 1 INH 5 MOV 3 DD 3 1 CLR CLRA 2 DIR 1 INH INH Inherent REL Relative IMM Immediate IX Indexed, No Offset DIR Direct IX1 Indexed, 8-Bit Offset EXT Extended IX2 Indexed, 16-Bit Offset DD Direct-Direct IMD Immediate-Direct IX+D Indexed-Direct DIX+ Direct-Indexed *Pre-byte for stack pointer indexed instructions 5 3 NEG NEG 3 SP1 1 IX 6 4 CBEQ CBEQ 4 SP1 2 IX+ 2 DAA 1 INH 5 3 COM COM 3 SP1 1 IX 5 3 LSR LSR 3 SP1 1 IX 4 CPHX 2 DIR 5 3 ROR ROR 3 SP1 1 IX 5 3 ASR ASR 3 SP1 1 IX 5 3 LSL LSL 3 SP1 1 IX 5 3 ROL ROL 3 SP1 1 IX 5 3 DEC DEC 3 SP1 1 IX 6 4 DBNZ DBNZ 4 SP1 2 IX 5 3 INC INC 3 SP1 1 IX 4 2 TST TST 3 SP1 1 IX 4 MOV 2 IX+D 4 2 CLR CLR 3 SP1 1 IX SP1 Stack Pointer, 8-Bit Offset SP2 Stack Pointer, 16-Bit Offset IX+ Indexed, No Offset with Post Increment IX1+ Indexed, 1-Byte Offset with Post Increment 7 3 RTI BGE 1 INH 2 REL 4 3 RTS BLT 1 INH 2 REL 3 BGT 2 REL 9 3 SWI BLE 1 INH 2 REL 2 2 TAP TXS 1 INH 1 INH 1 2 TPA TSX 1 INH 1 INH 2 PULA 1 INH 2 1 PSHA TAX 1 INH 1 INH 2 1 PULX CLC 1 INH 1 INH 2 1 PSHX SEC 1 INH 1 INH 2 2 PULH CLI 1 INH 1 INH 2 2 PSHH SEI 1 INH 1 INH 1 1 CLRH RSP 1 INH 1 INH 1 NOP 1 INH 1 STOP * 1 INH 1 1 WAIT TXA 1 INH 1 INH 2 SUB 2 IMM 2 CMP 2 IMM 2 SBC 2 IMM 2 CPX 2 IMM 2 AND 2 IMM 2 BIT 2 IMM 2 LDA 2 IMM 2 AIS 2 IMM 2 EOR 2 IMM 2 ADC 2 IMM 2 ORA 2 IMM 2 ADD 2 IMM 3 SUB 2 DIR 3 CMP 2 DIR 3 SBC 2 DIR 3 CPX 2 DIR 3 AND 2 DIR 3 BIT 2 DIR 3 LDA 2 DIR 3 STA 2 DIR 3 EOR 2 DIR 3 ADC 2 DIR 3 ORA 2 DIR 3 ADD 2 DIR 2 JMP 2 DIR 4 4 BSR JSR 2 REL 2 DIR 2 3 LDX LDX 2 IMM 2 DIR 2 3 AIX STX 2 IMM 2 DIR MSB 0 3 SUB 2 IX1 3 CMP 2 IX1 3 SBC 2 IX1 3 CPX 2 IX1 3 AND 2 IX1 3 BIT 2 IX1 3 LDA 2 IX1 3 STA 2 IX1 3 EOR 2 IX1 3 ADC 2 IX1 3 ORA 2 IX1 3 ADD 2 IX1 3 JMP 2 IX1 5 JSR 2 IX1 5 3 LDX LDX 4 SP2 2 IX1 5 3 STX STX 4 SP2 2 IX1 4 SUB 3 SP1 4 CMP 3 SP1 4 SBC 3 SP1 4 CPX 3 SP1 4 AND 3 SP1 4 BIT 3 SP1 4 LDA 3 SP1 4 STA 3 SP1 4 EOR 3 SP1 4 ADC 3 SP1 4 ORA 3 SP1 4 ADD 3 SP1 2 SUB 1 IX 2 CMP 1 IX 2 SBC 1 IX 2 CPX 1 IX 2 AND 1 IX 2 BIT 1 IX 2 LDA 1 IX 2 STA 1 IX 2 EOR 1 IX 2 ADC 1 IX 2 ORA 1 IX 2 ADD 1 IX 2 JMP 1 IX 4 JSR 1 IX 4 2 LDX LDX 3 SP1 1 IX 4 2 STX STX 3 SP1 1 IX High Byte of Opcode in Hexadecimal LSB Low Byte of Opcode in Hexadecimal 0 5 Cycles BRSET0 Opcode Mnemonic 3 DIR Number of Bytes / Addressing Mode Central Processor Unit (CPU) Data Sheet 76 Table 7-2. Opcode Map Bit Manipulation DIR DIR Data Sheet — MC68HC908QY/QT Family Section 8. External Interrupt (IRQ) 8.1 Introduction The IRQ pin (external interrupt), shared with PTA2 (general purpose input) and keyboard interrupt (KBI), provides a maskable interrupt input 8.2 Features Features of the IRQ module include the following: • External interrupt pin, IRQ • IRQ interrupt control bits • Hysteresis buffer • Programmable edge-only or edge and level interrupt sensitivity • Automatic interrupt acknowledge • Selectable internal pullup resistor 8.3 Functional Description IRQ pin functionality is enabled by setting configuration register 2 (CONFIG2) IRQEN bit accordingly. A zero disables the IRQ function and IRQ will assume the other shared functionalities. A one enables the IRQ function. A falling edge on the external interrupt pin can latch a central processor unit (CPU) interrupt request. Figure 8-2 shows the structure of the IRQ module. Interrupt signals on the IRQ pin are latched into the IRQ latch. An interrupt latch remains set until one of the following actions occurs: • Vector fetch — A vector fetch automatically generates an interrupt acknowledge signal that clears the IRQ latch. • Software clear — Software can clear the interrupt latch by writing to the acknowledge bit in the interrupt status and control register (INTSCR). Writing a 1 to the ACK bit clears the IRQ latch. • Reset — A reset automatically clears the interrupt latch. The external interrupt pin is falling-edge-triggered out of reset and is softwareconfigurable to be either falling-edge or falling-edge and low-level triggered. The MODE bit in the INTSCR controls the triggering sensitivity of the IRQ pin. When the interrupt pin is edge-triggered only (MODE = 0), the CPU interrupt request remains set until a vector fetch, software clear, or reset occurs. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet External Interrupt (IRQ) 77 External Interrupt (IRQ) PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 8-1. Block Diagram Highlighting IRQ Block and Pins Data Sheet 78 MC68HC908QY/QT Family — Rev. 3 External Interrupt (IRQ) MOTOROLA External Interrupt (IRQ) Functional Description ACK INTERNAL ADDRESS BUS RESET TO CPU FOR BIL/BIH INSTRUCTIONS VECTOR FETCH DECODER VDD IRQPUD INTERNAL PULLUP DEVICE VDD IRQF D CLR Q CK IRQ SYNCHRONIZER IRQ INTERRUPT REQUEST HIGH VOLTAGE DETECT TO MODE SELECT LOGIC IRQ FF IMASK MODE Figure 8-2. IRQ Module Block Diagram When the interrupt pin is both falling-edge and low-level triggered (MODE = 1), the CPU interrupt request remains set until both of the following occur: • Vector fetch or software clear • Return of the interrupt pin to logic 1 The vector fetch or software clear may occur before or after the interrupt pin returns to logic 1. As long as the pin is low, the interrupt request remains pending. A reset will clear the latch and the MODE control bit, thereby clearing the interrupt even if the pin stays low. When set, the IMASK bit in the INTSCR mask all external interrupt requests. A latched interrupt request is not presented to the interrupt priority logic unless the IMASK bit is clear. NOTE: The interrupt mask (I) in the condition code register (CCR) masks all interrupt requests, including external interrupt requests. See 13.6 Exception Control. Figure 8-3 provides a summary of the IRQ I/O register. Addr. Register Name $001D IRQ Status and Control Read: Register (INTSCR) Write: See page 81. Reset: Bit 7 6 5 4 3 2 0 0 0 0 IRQF 0 ACK 0 0 0 0 0 0 1 Bit 0 IMASK MODE 0 0 = Unimplemented Figure 8-3. IRQ I/O Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet External Interrupt (IRQ) 79 External Interrupt (IRQ) 8.4 IRQ Pin A falling edge on the IRQ pin can latch an interrupt request into the IRQ latch. A vector fetch, software clear, or reset clears the IRQ latch. If the MODE bit is set, the IRQ pin is both falling-edge sensitive and low-level sensitive. With MODE set, both of the following actions must occur to clear IRQ: • Vector fetch or software clear — A vector fetch generates an interrupt acknowledge signal to clear the latch. Software may generate the interrupt acknowledge signal by writing a 1 to the ACK bit in the interrupt status and control register (INTSCR). The ACK bit is useful in applications that poll the IRQ pin and require software to clear the IRQ latch. Writing to the ACK bit prior to leaving an interrupt service routine can also prevent spurious interrupts due to noise. Setting ACK does not affect subsequent transitions on the IRQ pin. A falling edge that occurs after writing to the ACK bit latches another interrupt request. If the IRQ mask bit, IMASK, is clear, the CPU loads the program counter with the vector address at locations $FFFA and $FFFB. • Return of the IRQ pin to logic 1 — As long as the IRQ pin is at logic 0, IRQ remains active. The vector fetch or software clear and the return of the IRQ pin to logic 1 may occur in any order. The interrupt request remains pending as long as the IRQ pin is at logic 0. A reset will clear the latch and the MODE control bit, thereby clearing the interrupt even if the pin stays low. If the MODE bit is clear, the IRQ pin is falling-edge sensitive only. With MODE clear, a vector fetch or software clear immediately clears the IRQ latch. The IRQF bit in the INTSCR register can be used to check for pending interrupts. The IRQF bit is not affected by the IMASK bit, which makes it useful in applications where polling is preferred. NOTE: When the IRQ function is enabled in the CONFIG2 register, the BIH and BIL instructions can be used to read the logic level on the IRQ pin. If the IRQ function is disabled, these instructions will behave as if the IRQ pin is a logic 1, regardless of the actual level on the pin. Conversely, when the IRQ function is enabled, bit 2 of the port A data register will always read a 0. NOTE: When using the level-sensitive interrupt trigger, avoid false interrupts by masking interrupt requests in the interrupt routine. An internal pullup resistor to VDD is connected to the IRQ pin; this can be disabled by setting the IRQPUD bit in the CONFIG2 register ($001E). Data Sheet 80 MC68HC908QY/QT Family — Rev. 3 External Interrupt (IRQ) MOTOROLA External Interrupt (IRQ) IRQ Module During Break Interrupts 8.5 IRQ Module During Break Interrupts The system integration module (SIM) controls whether the IRQ latch can be cleared during the break state. The BCFE bit in the break flag control register (BFCR) enables software to clear the latches during the break state. See Section 13. System Integration Module (SIM). To allow software to clear the IRQ latch during a break interrupt, write a 1 to the BCFE bit. If a latch is cleared during the break state, it remains cleared when the MCU exits the break state. To protect the latches during the break state, write a 0 to the BCFE bit. With BCFE at 0 (its default state), writing to the ACK bit in the IRQ status and control register during the break state has no effect on the IRQ latch. 8.6 IRQ Status and Control Register The IRQ status and control register (ISCR) controls and monitors operation of the IRQ module, see Section 5. Configuration Register (CONFIG). The ISCR has the following functions: • Shows the state of the IRQ flag • Clears the IRQ latch • Masks IRQ and interrupt request • Controls triggering sensitivity of the IRQ interrupt pin Address: $001D Read: Bit 7 6 5 4 3 0 0 0 0 IRQF Write: Reset: 2 0 ACK 0 0 0 0 0 0 1 Bit 0 IMASK MODE 0 0 = Unimplemented Figure 8-4. IRQ Status and Control Register (INTSCR) IRQF — IRQ Flag This read-only status bit is high when the IRQ interrupt is pending. 1 = IRQ interrupt pending 0 = IRQ interrupt not pending ACK — IRQ Interrupt Request Acknowledge Bit Writing a 1 to this write-only bit clears the IRQ latch. ACK always reads as 0. Reset clears ACK. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet External Interrupt (IRQ) 81 External Interrupt (IRQ) IMASK — IRQ Interrupt Mask Bit Writing a 1 to this read/write bit disables IRQ interrupt requests. Reset clears IMASK. 1 = IRQ interrupt requests disabled 0 = IRQ interrupt requests enabled MODE — IRQ Edge/Level Select Bit This read/write bit controls the triggering sensitivity of the IRQ pin. Reset clears MODE. 1 = IRQ interrupt requests on falling edges and low levels 0 = IRQ interrupt requests on falling edges only Data Sheet 82 MC68HC908QY/QT Family — Rev. 3 External Interrupt (IRQ) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 9. Keyboard Interrupt Module (KBI) 9.1 Introduction The keyboard interrupt module (KBI) provides six independently maskable external interrupts, which are accessible via the PTA0–PTA5 pins. 9.2 Features Features of the keyboard interrupt module include: • Six keyboard interrupt pins with separate keyboard interrupt enable bits and one keyboard interrupt mask • Software configurable pullup device if input pin is configured as input port bit • Programmable edge-only or edge and level interrupt sensitivity • Exit from low-power modes Figure 9-1 provides a summary of the input/output (I/O) registers Addr. Register Name Bit 7 6 5 4 3 2 Read: Keyboard Status and Control $001A Register (KBSCR) Write: See page 88. Reset: 0 0 0 0 KEYF 0 $001B Read: Keyboard Interrupt Enable Register (KBIER) Write: See page 89. Reset: 1 Bit 0 IMASKK MODEK ACKK 0 0 0 0 0 0 0 0 AWUIE KBIE5 KBIE4 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 0 0 0 0 0 = Unimplemented Figure 9-1. KBI I/O Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Keyboard Interrupt Module (KBI) 83 Keyboard Interrupt Module (KBI) PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HLC908QT1, MC68HLC908QT2, and MC68HLC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 9-2. Block Diagram Highlighting KBI Block and Pins Data Sheet 84 MC68HC908QY/QT Family — Rev. 3 Keyboard Interrupt Module (KBI) MOTOROLA Keyboard Interrupt Module (KBI) Functional Description 9.3 Functional Description The keyboard interrupt module controls the enabling/disabling of interrupt functions on the six port A pins. These six pins can be enabled/disabled independently of each other. INTERNAL BUS VECTOR FETCH DECODER ACKK KBI0 VDD KBIE0 TO PULLUP ENABLE . . . RESET D CLR KEYF Q SYNCHRONIZER CK KBI5 KEYBOARD INTERRUPT FF IMASKK KEYBOARD INTERRUPT REQUEST MODEK KBIE5 TO PULLUP ENABLE AWUIREQ(1) 1. For AWUGEN logic refer to Figure 4-2. Auto Wakeup Interrupt Request Generation Logic. Figure 9-3. Keyboard Interrupt Block Diagram 9.3.1 Keyboard Operation Writing to the KBIE0–KBIE5 bits in the keyboard interrupt enable register (KBIER) independently enables or disables each port A pin as a keyboard interrupt pin. Enabling a keyboard interrupt pin in port A also enables its internal pullup device irrespective of PTAPUEx bits in the port A input pullup enable register (see 12.2.3 Port A Input Pullup Enable Register). A logic 0 applied to an enabled keyboard interrupt pin latches a keyboard interrupt request. A keyboard interrupt is latched when one or more keyboard interrupt inputs goes low after all were high. The MODEK bit in the keyboard status and control register controls the triggering mode of the keyboard interrupt. • If the keyboard interrupt is edge-sensitive only, a falling edge on a keyboard interrupt input does not latch an interrupt request if another keyboard pin is already low. To prevent losing an interrupt request on one input because another input is still low, software can disable the latter input while it is low. • If the keyboard interrupt is falling edge and low-level sensitive, an interrupt request is present as long as any keyboard interrupt input is low. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Keyboard Interrupt Module (KBI) 85 Keyboard Interrupt Module (KBI) If the MODEK bit is set, the keyboard interrupt inputs are both falling edge and low-level sensitive, and both of the following actions must occur to clear a keyboard interrupt request: • Vector fetch or software clear — A vector fetch generates an interrupt acknowledge signal to clear the interrupt request. Software may generate the interrupt acknowledge signal by writing a 1 to the ACKK bit in the keyboard status and control register (KBSCR). The ACKK bit is useful in applications that poll the keyboard interrupt inputs and require software to clear the keyboard interrupt request. Writing to the ACKK bit prior to leaving an interrupt service routine can also prevent spurious interrupts due to noise. Setting ACKK does not affect subsequent transitions on the keyboard interrupt inputs. A falling edge that occurs after writing to the ACKK bit latches another interrupt request. If the keyboard interrupt mask bit, IMASKK, is clear, the central processor unit (CPU) loads the program counter with the vector address at locations $FFE0 and $FFE1. • Return of all enabled keyboard interrupt inputs to logic 1 — As long as any enabled keyboard interrupt pin is at logic 0, the keyboard interrupt remains set. The auto wakeup interrupt input, AWUIREQ, will be cleared only by writing to ACKK bit in KBSCR or reset. The vector fetch or software clear and the return of all enabled keyboard interrupt pins to logic 1 may occur in any order. If the MODEK bit is clear, the keyboard interrupt pin is falling-edge sensitive only. With MODEK clear, a vector fetch or software clear immediately clears the keyboard interrupt request. Reset clears the keyboard interrupt request and the MODEK bit, clearing the interrupt request even if a keyboard interrupt input stays at logic 0. The keyboard flag bit (KEYF) in the keyboard status and control register can be used to see if a pending interrupt exists. The KEYF bit is not affected by the keyboard interrupt mask bit (IMASKK) which makes it useful in applications where polling is preferred. To determine the logic level on a keyboard interrupt pin, use the data direction register to configure the pin as an input and then read the data register. NOTE: Setting a keyboard interrupt enable bit (KBIEx) forces the corresponding keyboard interrupt pin to be an input, overriding the data direction register. However, the data direction register bit must be a 0 for software to read the pin. Data Sheet 86 MC68HC908QY/QT Family — Rev. 3 Keyboard Interrupt Module (KBI) MOTOROLA Keyboard Interrupt Module (KBI) Wait Mode 9.3.2 Keyboard Initialization When a keyboard interrupt pin is enabled, it takes time for the internal pullup to reach a logic 1. Therefore a false interrupt can occur as soon as the pin is enabled. To prevent a false interrupt on keyboard initialization: 1. Mask keyboard interrupts by setting the IMASKK bit in the keyboard status and control register. 2. Enable the KBI pins by setting the appropriate KBIEx bits in the keyboard interrupt enable register. 3. Write to the ACKK bit in the keyboard status and control register to clear any false interrupts. 4. Clear the IMASKK bit. An interrupt signal on an edge-triggered pin can be acknowledged immediately after enabling the pin. An interrupt signal on an edge- and level-triggered interrupt pin must be acknowledged after a delay that depends on the external load. Another way to avoid a false interrupt: 1. Configure the keyboard pins as outputs by setting the appropriate DDRA bits in the data direction register A. 2. Write 1s to the appropriate port A data register bits. 3. Enable the KBI pins by setting the appropriate KBIEx bits in the keyboard interrupt enable register. 9.4 Wait Mode The keyboard module remains active in wait mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of wait mode. 9.5 Stop Mode The keyboard module remains active in stop mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of stop mode. 9.6 Keyboard Module During Break Interrupts The system integration module (SIM) controls whether the keyboard interrupt latch can be cleared during the break state. The BCFE bit in the break flag control register (BFCR) enables software to clear status bits during the break state. To allow software to clear the keyboard interrupt latch during a break interrupt, write a 1 to the BCFE bit. If a latch is cleared during the break state, it remains cleared when the MCU exits the break state. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Keyboard Interrupt Module (KBI) 87 Keyboard Interrupt Module (KBI) To protect the latch during the break state, write a 0 to the BCFE bit. With BCFE at 0 (its default state), writing to the keyboard acknowledge bit (ACKK) in the keyboard status and control register during the break state has no effect. 9.7 Input/Output Registers The following I/O registers control and monitor operation of the keyboard interrupt module: • Keyboard interrupt status and control register (KBSCR) • Keyboard interrupt enable register (KBIER) 9.7.1 Keyboard Status and Control Register The keyboard status and control register (KBSCR): • Flags keyboard interrupt requests • Acknowledges keyboard interrupt requests • Masks keyboard interrupt requests • Controls keyboard interrupt triggering sensitivity Address: $001A Read: Bit 7 6 5 4 3 2 0 0 0 0 KEYF 0 Write: Reset: ACKK 0 0 0 0 0 0 1 Bit 0 IMASKK MODEK 0 0 = Unimplemented Figure 9-4. Keyboard Status and Control Register (KBSCR) Bits 7–4 — Not used These read-only bits always read as 0s. KEYF — Keyboard Flag Bit This read-only bit is set when a keyboard interrupt is pending on port A or auto wakeup. Reset clears the KEYF bit. 1 = Keyboard interrupt pending 0 = No keyboard interrupt pending ACKK — Keyboard Acknowledge Bit Writing a 1 to this write-only bit clears the keyboard interrupt request on port A and auto wakeup logic. ACKK always reads as 0. Reset clears ACKK. IMASKK— Keyboard Interrupt Mask Bit Writing a 1 to this read/write bit prevents the output of the keyboard interrupt mask from generating interrupt requests on port A or auto wakeup. Reset clears the IMASKK bit. 1 = Keyboard interrupt requests masked 0 = Keyboard interrupt requests not masked Data Sheet 88 MC68HC908QY/QT Family — Rev. 3 Keyboard Interrupt Module (KBI) MOTOROLA Keyboard Interrupt Module (KBI) Input/Output Registers MODEK — Keyboard Triggering Sensitivity Bit This read/write bit controls the triggering sensitivity of the keyboard interrupt pins on port A and auto wakeup. Reset clears MODEK. 1 = Keyboard interrupt requests on falling edges and low levels 0 = Keyboard interrupt requests on falling edges only 9.7.2 Keyboard Interrupt Enable Register The port A keyboard interrupt enable register (KBIER) enables or disables each port A pin or auto wakeup to operate as a keyboard interrupt input. Address: $001B Bit 7 Read: 0 Write: Reset: 0 6 5 4 3 2 1 Bit 0 AWUIE KBIE5 KBIE4 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 0 0 0 = Unimplemented Figure 9-5. Keyboard Interrupt Enable Register (KBIER) KBIE5–KBIE0 — Port A Keyboard Interrupt Enable Bits Each of these read/write bits enables the corresponding keyboard interrupt pin on port A to latch interrupt requests. Reset clears the keyboard interrupt enable register. 1 = KBIx pin enabled as keyboard interrupt pin 0 = KBIx pin not enabled as keyboard interrupt pin NOTE: AWUIE bit is not used in conjunction with the keyboard interrupt feature. To see a description of this bit, see Section 4. Auto Wakeup Module (AWU). MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Keyboard Interrupt Module (KBI) 89 Keyboard Interrupt Module (KBI) Data Sheet 90 MC68HC908QY/QT Family — Rev. 3 Keyboard Interrupt Module (KBI) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 10. Low-Voltage Inhibit (LVI) 10.1 Introduction This section describes the low-voltage inhibit (LVI) module, which monitors the voltage on the VDD pin and can force a reset when the VDD voltage falls below the LVI trip falling voltage, VTRIPF. 10.2 Features Features of the LVI module include: • Programmable LVI reset • Programmable power consumption • Selectable LVI trip voltage • Programmable stop mode operation 10.3 Functional Description Figure 10-1 shows the structure of the LVI module. LVISTOP, LVIPWRD, LVI5OR3, and LVIRSTD are user selectable options found in the configuration register (CONFIG1). See Section 5. Configuration Register (CONFIG). VDD STOP INSTRUCTION LVISTOP FROM CONFIG FROM CONFIG LVIRSTD LVIPWRD FROM CONFIG LOW VDD DETECTOR VDD > LVITRIP = 0 LVI RESET VDD ≤ LVITRIP = 1 LVIOUT LVI5OR3 FROM CONFIG Figure 10-1. LVI Module Block Diagram MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Low-Voltage Inhibit (LVI) 91 Low-Voltage Inhibit (LVI) The LVI is enabled out of reset. The LVI module contains a bandgap reference circuit and comparator. Clearing the LVI power disable bit, LVIPWRD, enables the LVI to monitor VDD voltage. Clearing the LVI reset disable bit, LVIRSTD, enables the LVI module to generate a reset when VDD falls below a voltage, VTRIPF. Setting the LVI enable in stop mode bit, LVISTOP, enables the LVI to operate in stop mode. Setting the LVI 5-V or 3-V trip point bit, LVI5OR3, enables the trip point voltage, VTRIPF, to be configured for 5-V operation. Clearing the LVI5OR3 bit enables the trip point voltage, VTRIPF, to be configured for 3-V operation. The actual trip thresholds are specified in 16.5 5-V DC Electrical Characteristics and 16.9 3-V DC Electrical Characteristics. NOTE: After a power-on reset, the LVI’s default mode of operation is 3 volts. If a 5-V system is used, the user must set the LVI5OR3 bit to raise the trip point to 5-V operation. If the user requires 5-V mode and sets the LVI5OR3 bit after power-on reset while the VDD supply is not above the VTRIPR for 5-V mode, the microcontroller unit (MCU) will immediately go into reset. The next time the LVI releases the reset, the supply will be above the VTRIPR for 5-V mode. Once an LVI reset occurs, the MCU remains in reset until VDD rises above a voltage, VTRIPR, which causes the MCU to exit reset. See Section 13. System Integration Module (SIM) for the reset recovery sequence. The output of the comparator controls the state of the LVIOUT flag in the LVI status register (LVISR) and can be used for polling LVI operation when the LVI reset is disabled. 10.3.1 Polled LVI Operation In applications that can operate at VDD levels below the VTRIPF level, software can monitor VDD by polling the LVIOUT bit. In the configuration register, the LVIPWRD bit must be cleared to enable the LVI module, and the LVIRSTD bit must be at set to disable LVI resets. 10.3.2 Forced Reset Operation In applications that require VDD to remain above the VTRIPF level, enabling LVI resets allows the LVI module to reset the MCU when VDD falls below the VTRIPF level. In the configuration register, the LVIPWRD and LVIRSTD bits must be cleared to enable the LVI module and to enable LVI resets. 10.3.3 Voltage Hysteresis Protection Once the LVI has triggered (by having VDD fall below VTRIPF), the LVI will maintain a reset condition until VDD rises above the rising trip point voltage, VTRIPR. This prevents a condition in which the MCU is continually entering and exiting reset if VDD is approximately equal to VTRIPF. VTRIPR is greater than VTRIPF by the hysteresis voltage, VHYS. Data Sheet 92 MC68HC908QY/QT Family — Rev. 3 Low-Voltage Inhibit (LVI) MOTOROLA Low-Voltage Inhibit (LVI) LVI Status Register 10.3.4 LVI Trip Selection The LVI5OR3 bit in the configuration register selects whether the LVI is configured for 5-V or 3-V protection. NOTE: The microcontroller is guaranteed to operate at a minimum supply voltage. The trip point (VTRIPF [5 V] or VTRIPF [3 V]) may be lower than this. See 16.5 5-V DC Electrical Characteristics and 16.9 3-V DC Electrical Characteristics for the actual trip point voltages. 10.4 LVI Status Register The LVI status register (LVISR) indicates if the VDD voltage was detected below the VTRIPF level while LVI resets have been disabled. Address: $FE0C Read: Bit 7 6 5 4 3 2 1 Bit 0 LVIOUT 0 0 0 0 0 0 R 0 0 0 0 0 0 0 0 R = Reserved Write: Reset: = Unimplemented Figure 10-2. LVI Status Register (LVISR) LVIOUT — LVI Output Bit This read-only flag becomes set when the VDD voltage falls below the VTRIPF trip voltage and is cleared when VDD voltage rises above VTRIPR. The difference in these threshold levels results in a hysteresis that prevents oscillation into and out of reset (see Table 10-1). Reset clears the LVIOUT bit. Table 10-1. LVIOUT Bit Indication VDD LVIOUT VDD > VTRIPR 0 VDD < VTRIPF 1 VTRIPF < VDD < VTRIPR Previous value 10.5 LVI Interrupts The LVI module does not generate interrupt requests. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Low-Voltage Inhibit (LVI) 93 Low-Voltage Inhibit (LVI) 10.6 Low-Power Modes The STOP and WAIT instructions put the MCU in low power-consumption standby modes. 10.6.1 Wait Mode If enabled, the LVI module remains active in wait mode. If enabled to generate resets, the LVI module can generate a reset and bring the MCU out of wait mode. 10.6.2 Stop Mode When the LVIPWRD bit in the configuration register is cleared and the LVISTOP bit in the configuration register is set, the LVI module remains active in stop mode. If enabled to generate resets, the LVI module can generate a reset and bring the MCU out of stop mode. Data Sheet 94 MC68HC908QY/QT Family — Rev. 3 Low-Voltage Inhibit (LVI) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 11. Oscillator Module (OSC) 11.1 Introduction The oscillator module is used to provide a stable clock source for the microcontroller system and bus. The oscillator module generates two output clocks, BUSCLKX2 and BUSCLKX4. The BUSCLKX4 clock is used by the system integration module (SIM) and the computer operating properly module (COP). The BUSCLKX2 clock is divided by two in the SIM to be used as the bus clock for the microcontroller. Therefore the bus frequency will be one fourth of the BUSCLKX4 frequency. 11.2 Features The oscillator has these four clock source options available: 1. Internal oscillator: An internally generated, fixed frequency clock, trimmable to ±5%.This is the default option out of reset. 2. External oscillator: An external clock that can be driven directly into OSC1. 3. External RC: A built-in oscillator module (RC oscillator) that requires an external R connection only. The capacitor is internal to the chip. 4. External crystal: A built-in oscillator module (XTAL oscillator) that requires an external crystal or ceramic-resonator. 11.3 Functional Description The oscillator contains these major subsystems: • Internal oscillator circuit • Internal or external clock switch control • External clock circuit • External crystal circuit • External RC clock circuit MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Oscillator Module (OSC) 95 Oscillator Module (OSC) PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 11-1. Block Diagram Highlighting OSC Block and Pins Data Sheet 96 MC68HC908QY/QT Family — Rev. 3 Oscillator Module (OSC) MOTOROLA Oscillator Module (OSC) Functional Description 11.3.1 Internal Oscillator The internal oscillator circuit is designed for use with no external components to provide a clock source with tolerance less than ±25% untrimmed.An 8-bit trimming register allows adjustment to a tolerance of less than ±5%. The internal oscillator will generate a clock of 12.8 MHz typical (INTCLK) resulting in a bus speed (internal clock ÷ 4) of 3.2 MHz. 3.2 MHz came from the maximum bus speed guaranteed at 3 V which is 4 MHz.Since the internal oscillator will have a ±25% tolerance (pre-trim), then the +25% case should not allow a frequency higher than 4 MHz: 3.2 MHz + 25% = 4 MHz Figure 11-3 shows how BUSCLKX4 is derived from INTCLK and, like the RC oscillator, OSC2 can output BUSCLKX4 by setting OSC2EN in PTAPUE register.See Section 12. Input/Output Ports (PORTS) 11.3.1.1 Internal Oscillator Trimming The 8-bit trimming register, OSCTRIM, allows a clock period adjust of +127 and –128 steps. Increasing OSCTRIM value increases the clock period. Trimming allows the internal clock frequency to be set to 12.8 MHz ± 5%. All devices are programmed with a trim value in a reserved FLASH location, $FFC0. This value can be copied from the FLASH to the OSCTRIM register ($0038) during reset initialization. Reset loads OSCTRIM with a default value of $80. WARNING: Bulk FLASH erasure will set location $FFC0 to $FF and the factory programmed value will be lost. 11.3.1.2 Internal to External Clock Switching When external clock source (external OSC, RC, or XTAL) is desired, the user must perform the following steps: 1. For external crystal circuits only, OSCOPT[1:0] = 1:1: To help precharge an external crystal oscillator, set PTA4 (OSC2) as an output and drive high for several cycles. This may help the crystal circuit start more robustly. 2. Set CONFIG2 bits OSCOPT[1:0] according to Table 11-2. The oscillator module control logic will then set OSC1 as an external clock input and, if the external crystal option is selected, OSC2 will also be set as the clock output. 3. Create a software delay to wait the stabilization time needed for the selected clock source (crystal, resonator, RC) as recommended by the component manufacturer. A good rule of thumb for crystal oscillators is to wait 4096 cycles of the crystal frequency, i.e., for a 4-MHz crystal, wait approximately 1 msec. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Oscillator Module (OSC) 97 Oscillator Module (OSC) 4. After the manufacturer’s recommended delay has elapsed, the ECGON bit in the OSC status register (OSCSTAT) needs to be set by the user software. 5. After ECGON set is detected, the OSC module checks for oscillator activity by waiting two external clock rising edges. 6. The OSC module then switches to the external clock. Logic provides a glitch free transition. 7. The OSC module first sets the ECGST bit in the OSCSTAT register and then stops the internal oscillator. NOTE: Once transition to the external clock is done, the internal oscillator will only be reactivated with reset. No post-switch clock monitor feature is implemented (clock does not switch back to internal if external clock dies). 11.3.2 External Oscillator The external clock option is designed for use when a clock signal is available in the application to provide a clock source to the microcontroller. The OSC1 pin is enabled as an input by the oscillator module. The clock signal is used directly to create BUSCLKX4 and also divided by two to create BUSCLKX2. In this configuration, the OSC2 pin cannot output BUSCLKX4.So the OSC2EN bit in the port A pullup enable register will be clear to enable PTA4 I/O functions on the pin 11.3.3 XTAL Oscillator The XTAL oscillator circuit is designed for use with an external crystal or ceramic resonator to provide an accurate clock source. In this configuration, the OSC2 pin is dedicated to the external crystal circuit. The OSC2EN bit in the port A pullup enable register has no effect when this clock mode is selected. In its typical configuration, the XTAL oscillator is connected in a Pierce oscillator configuration, as shown in Figure 11-2. This figure shows only the logical representation of the internal components and may not represent actual circuitry. The oscillator configuration uses five components: NOTE: • Crystal, X1 • Fixed capacitor, C1 • Tuning capacitor, C2 (can also be a fixed capacitor) • Feedback resistor, RB • Series resistor, RS (optional) The series resistor (RS) is included in the diagram to follow strict Pierce oscillator guidelines and may not be required for all ranges of operation, especially with high frequency crystals. Refer to the crystal manufacturer’s data for more information. Data Sheet 98 MC68HC908QY/QT Family — Rev. 3 Oscillator Module (OSC) MOTOROLA Oscillator Module (OSC) Functional Description FROM SIM TO SIM BUSCLKX4 XTALCLK TO SIM BUSCLKX2 ÷2 SIMOSCEN MCU OSC1 OSC2 RS(1) RB X1 C1 C2 Note 1. RS can be zero (shorted) when used with higher-frequency crystals. Refer to manufacturer’s data. See Section 16. Electrical Specifications for component value recommendations. Figure 11-2. XTAL Oscillator External Connections 11.3.4 RC Oscillator The RC oscillator circuit is designed for use with external R to provide a clock source with tolerance less than 25%. In its typical configuration, the RC oscillator requires two external components, one R and one C. In the MC68HC908QY4, the capacitor is internal to the chip. The R value should have a tolerance of 1% or less, to obtain a clock source with less than 25% tolerance. The oscillator configuration uses one component, REXT. In this configuration, the OSC2 pin can be left in the reset state as PTA4. Or, the OSC2EN bit in the port A pullup enable register can be set to enable the OSC2 output function on the pin. Enabling the OSC2 output slightly increases the external RC oscillator frequency, fRCCLK. See Figure 11-3 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Oscillator Module (OSC) 99 Oscillator Module (OSC) OSCRCOPT TO SIM FROM SIM INTCLK TO SIM 0 BUSCLKX4 BUSCLKX2 1 SIMOSCEN EXTERNAL RC EN OSCILLATOR RCCLK ÷2 1 PTA4 I/O 0 PTA4 OSC2EN MCU OSC1 PTA4/BUSCLKX4 (OSC2) VDD REXT See Section 16. Electrical Specifications for component value requirements. Figure 11-3. RC Oscillator External Connections 11.4 Oscillator Module Signals The following paragraphs describe the signals that are inputs to and outputs from the oscillator module. 11.4.1 Crystal Amplifier Input Pin (OSC1) The OSC1 pin is either an input to the crystal oscillator amplifier, an input to the RC oscillator circuit, or an external clock source. For the internal oscillator configuration, the OSC1 pin can assume other functions according to Table 1-3. Function Priority in Shared Pins. 11.4.2 Crystal Amplifier Output Pin (OSC2/PTA4/BUSCLKX4) For the XTAL oscillator device, the OSC2 pin is the crystal oscillator inverting amplifier output. For the external clock option, the OSC2 pin is dedicated to the PTA4 I/O function. The OSC2EN bit has no effect. For the internal oscillator or RC oscillator options, the OSC2 pin can assume other functions according to Table 1-3. Function Priority in Shared Pins, or the output of the oscillator clock (BUSCLKX4). Data Sheet 100 MC68HC908QY/QT Family — Rev. 3 Oscillator Module (OSC) MOTOROLA Oscillator Module (OSC) Oscillator Module Signals Table 11-1. OSC2 Pin Function Option OSC2 Pin Function XTAL oscillator Inverting OSC1 External clock PTA4 I/O Internal oscillator or RC oscillator Controlled by OSC2EN bit in PTAPUE register OSC2EN = 0: PTA4 I/O OSC2EN = 1: BUSCLKX4 output 11.4.3 Oscillator Enable Signal (SIMOSCEN) The SIMOSCEN signal comes from the system integration module (SIM) and enables/disables either the XTAL oscillator circuit, the RC oscillator, or the internal oscillator. 11.4.4 XTAL Oscillator Clock (XTALCLK) XTALCLK is the XTAL oscillator output signal. It runs at the full speed of the crystal (fXCLK) and comes directly from the crystal oscillator circuit. Figure 11-2 shows only the logical relation of XTALCLK to OSC1 and OSC2 and may not represent the actual circuitry. The duty cycle of XTALCLK is unknown and may depend on the crystal and other external factors. Also, the frequency and amplitude of XTALCLK can be unstable at start up. 11.4.5 RC Oscillator Clock (RCCLK) RCCLK is the RC oscillator output signal. Its frequency is directly proportional to the time constant of external R and internal C. Figure 11-3 shows only the logical relation of RCCLK to OSC1 and may not represent the actual circuitry. 11.4.6 Internal Oscillator Clock (INTCLK) INTCLK is the internal oscillator output signal. Its nominal frequency is fixed to 12.8 MHz, but it can be also trimmed using the oscillator trimming feature of the OSCTRIM register (see 11.3.1.1 Internal Oscillator Trimming). 11.4.7 Oscillator Out 2 (BUSCLKX4) BUSCLKX4 is the same as the input clock (XTALCLK, RCCLK, or INTCLK). This signal is driven to the SIM module and is used to determine the COP cycles. 11.4.8 Oscillator Out (BUSCLKX2) The frequency of this signal is equal to half of the BUSCLKX4, this signal is driven to the SIM for generation of the bus clocks used by the CPU and other modules on the MCU. BUSCLKX2 will be divided again in the SIM and results in the internal MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Oscillator Module (OSC) 101 Oscillator Module (OSC) bus frequency being one fourth of either the XTALCLK, RCCLK, or INTCLK frequency. 11.5 Low Power Modes The WAIT and STOP instructions put the MCU in low-power consumption standby modes. 11.5.1 Wait Mode The WAIT instruction has no effect on the oscillator logic. BUSCLKX2 and BUSCLKX4 continue to drive to the SIM module. 11.5.2 Stop Mode The STOP instruction disables either the XTALCLK, the RCCLK, or INTCLK output, hence BUSCLKX2 and BUSCLKX4. 11.6 Oscillator During Break Mode The oscillator continues to drive BUSCLKX2 and BUSCLKX4 when the device enters the break state. 11.7 CONFIG2 Options Two CONFIG2 register options affect the operation of the oscillator module: OSCOPT1 and OSCOPT0. All CONFIG2 register bits will have a default configuration. Refer to Section 5. Configuration Register (CONFIG) for more information on how the CONFIG2 register is used. Table 11-2 shows how the OSCOPT bits are used to select the oscillator clock source. Table 11-2. Oscillator Modes OSCOPT1 OSCOPT0 Oscillator Modes 0 0 Internal oscillator 0 1 External oscillator 1 0 External RC 1 1 External crystal Data Sheet 102 MC68HC908QY/QT Family — Rev. 3 Oscillator Module (OSC) MOTOROLA Oscillator Module (OSC) Input/Output (I/O) Registers 11.8 Input/Output (I/O) Registers The oscillator module contains these two registers: 1. Oscillator status register (OSCSTAT) 2. Oscillator trim register (OSCTRIM) 11.8.1 Oscillator Status Register The oscillator status register (OSCSTAT) contains the bits for switching from internal to external clock sources. Address: $0036 Read: Write: Reset: Bit 7 6 5 4 3 2 1 R R R R R R ECGON 0 0 0 0 0 0 0 R = Reserved Bit 0 ECGST 0 = Unimplemented Figure 11-4. Oscillator Status Register (OSCSTAT) ECGON — External Clock Generator On Bit This read/write bit enables external clock generator, so that the switching process can be initiated. This bit is forced low during reset. This bit is ignored in monitor mode with the internal oscillator bypassed, PTM or CTM mode. 1 = External clock generator enabled 0 = External clock generator disabled ECGST — External Clock Status Bit This read-only bit indicates whether or not an external clock source is engaged to drive the system clock. 1 = An external clock source engaged 0 = An external clock source disengaged MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Oscillator Module (OSC) 103 Oscillator Module (OSC) 11.8.2 Oscillator Trim Register (OSCTRIM) Address: $0038 Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 TRIM7 TRIM6 TRIM5 TRIM4 TRIM3 TRIM2 TRIM1 TRIM0 1 0 0 0 0 0 0 0 Figure 11-5. Oscillator Trim Register (OSCTRIM) TRIM7–TRIM0 — Internal Oscillator Trim Factor Bits These read/write bits change the size of the internal capacitor used by the internal oscillator. By measuring the period of the internal clock and adjusting this factor accordingly, the frequency of the internal clock can be fine tuned. Increasing (decreasing) this factor by one increases (decreases) the period by approximately 0.2% of the untrimmed period (the period for TRIM = $80). The trimmed frequency is guaranteed not to vary by more than ±5% over the full specified range of temperature and voltage. The reset value is $80, which sets the frequency to 12.8 MHz (3.2 MHz bus speed) ±25%. Data Sheet 104 MC68HC908QY/QT Family — Rev. 3 Oscillator Module (OSC) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 12. Input/Output Ports (PORTS) 12.1 Introduction The MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 have five bidirectional input-output (I/O) pins and one input only pin. The MC68HC908QY1, MC68HC908QY2, and MC68HC908QY4 have thirteen bidirectional pins and one input only pin. All I/O pins are programmable as inputs or outputs. NOTE: Connect any unused I/O pins to an appropriate logic level, either VDD or VSS. Although the I/O ports do not require termination for proper operation, termination reduces excess current consumption and the possibility of electrostatic damage. Figure 12-1 provides a summary of the I/O registers. Addr. Register Name Port A Data Register (PTA) See page 106. $0000 Port B Data Register (PTB) See page 109. $0001 $0004 $0005 $000B $000C Data Direction Register A (DDRA) See page 107. Data Direction Register B (DDRB) See page 109. Port A Input Pullup Enable Register (PTAPUE) See page 108. Port B Input Pullup Enable Register (PTBPUE) See page 111. Bit 7 Read: Write: 6 AWUL R 5 4 3 PTA5 PTA4 PTA3 Reset: Read: Write: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: PTA2 1 Bit 0 PTA1 PTA0 PTB1 PTB0 DDRA1 DDRA0 Unaffected by reset PTB7 PTB6 PTB5 Reset: Read: 2 PTB4 PTB3 PTB2 Unaffected by reset 0 R R DDRA5 DDRA4 DDRA3 0 0 0 0 0 0 0 0 DDRB7 DDRB6 DDRB5 DDRB4 DDRB3 DDRB2 DDRB1 DDRB0 0 0 0 0 0 0 0 0 PTAPUE5 PTAPUE4 PTAPUE3 PTAPUE2 PTAPUE1 PTAPUE0 OSC2EN 0 0 0 0 0 0 0 0 PTBPUE7 PTBPUE6 PTBPUE5 PTBPUE4 PTBPUE3 PTBPUE2 PTBPUE1 PTBPUE0 0 0 0 0 0 0 0 0 R = Reserved = Unimplemented Figure 12-1. I/O Port Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Input/Output Ports (PORTS) 105 Input/Output Ports (PORTS) 12.2 Port A Port A is a 6-bit special function port that shares all six of its pins with the keyboard interrupt (KBI) module (see Section 9. Keyboard Interrupt Module (KBI)). Each port A pin also has a software configurable pullup device if the corresponding port pin is configured as an input port. NOTE: PTA2 is input only. When the IRQ function is enabled in the configuration register 2 (CONFIG2), bit 2 of the port A data register (PTA) will always read a 0. In this case, the BIH and BIL instructions can be used to read the logic level on the PTA2 pin. When the IRQ function is disabled, these instructions will behave as if the PTA2 pin is a logic 1. However, reading bit 2 of PTA will read the actual logic level on the pin. 12.2.1 Port A Data Register The port A data register (PTA) contains a data latch for each of the six port A pins. Address: $0000 Bit 7 Read: Write: R 6 AWUL 5 4 3 PTA5 PTA4 PTA3 Reset: 2 PTA2 1 Bit 0 PTA1 PTA0 KBI1 KBI0 Unaffected by reset KBI5 Additional Functions: R KBI4 = Reserved KBI3 KBI2 = Unimplemented Figure 12-2. Port A Data Register (PTA) PTA[5:0] — Port A Data Bits These read/write bits are software programmable. Data direction of each port A pin is under the control of the corresponding bit in data direction register A. Reset has no effect on port A data. AWUL — Auto Wakeup Latch Data Bit This is a read-only bit which has the value of the auto wakeup interrupt request latch. The wakeup request signal is generated internally (see Section 4. Auto Wakeup Module (AWU)). There is no PTA6 port nor any of the associated bits such as PTA6 data register, pullup enable or direction. KBI[5:0] — Port A Keyboard Interrupts The keyboard interrupt enable bits, KBIE5–KBIE0, in the keyboard interrupt control enable register (KBIER) enable the port A pins as external interrupt pins (see Section 9. Keyboard Interrupt Module (KBI)). Data Sheet 106 MC68HC908QY/QT Family — Rev. 3 Input/Output Ports (PORTS) MOTOROLA Input/Output Ports (PORTS) Port A 12.2.2 Data Direction Register A Data direction register A (DDRA) determines whether each port A pin is an input or an output. Writing a 1 to a DDRA bit enables the output buffer for the corresponding port A pin; a 0 disables the output buffer. Address: $0004 Read: Write: Reset: Bit 7 6 5 4 3 R R DDRA5 DDRA4 DDRA3 0 0 0 0 R = Reserved 2 0 0 1 Bit 0 DDRA1 DDRA0 0 0 0 = Unimplemented Figure 12-3. Data Direction Register A (DDRA) DDRA[5:0] — Data Direction Register A Bits These read/write bits control port A data direction. Reset clears DDRA[5:0], configuring all port A pins as inputs. 1 = Corresponding port A pin configured as output 0 = Corresponding port A pin configured as input NOTE: Avoid glitches on port A pins by writing to the port A data register before changing data direction register A bits from 0 to 1. Figure 12-4 shows the port A I/O logic. READ DDRA ($0004) PTAPUEx INTERNAL DATA BUS WRITE DDRA ($0004) RESET DDRAx 30 k WRITE PTA ($0000) PTAx PTAx READ PTA ($0000) TO KEYBOARD INTERRUPT CIRCUIT Figure 12-4. Port A I/O Circuit NOTE: Figure 12-4 does not apply to PTA2 When DDRAx is a 1, reading address $0000 reads the PTAx data latch. When DDRAx is a 0, reading address $0000 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Input/Output Ports (PORTS) 107 Input/Output Ports (PORTS) 12.2.3 Port A Input Pullup Enable Register The port A input pullup enable register (PTAPUE) contains a software configurable pullup device for each if the six port A pins. Each bit is individually configurable and requires the corresponding data direction register, DDRAx, to be configured as input. Each pullup device is automatically and dynamically disabled when its corresponding DDRAx bit is configured as output. Address: $000B Bit 7 Read: Write: Reset: 6 OSC2EN 0 0 5 4 3 2 1 Bit 0 PTAPUE5 PTAPUE4 PTAPUE3 PTAPUE2 PTAPUE1 PTAPUE0 0 0 0 0 0 0 = Unimplemented Figure 12-5. Port A Input Pullup Enable Register (PTAPUE) OSC2EN — Enable PTA4 on OSC2 Pin This read/write bit configures the OSC2 pin function when internal oscillator or RC oscillator option is selected. This bit has no effect for the XTAL or external oscillator options. 1 = OSC2 pin outputs the internal or RC oscillator clock (BUSCLKX4) 0 = OSC2 pin configured for PTA4 I/O, having all the interrupt and pullup functions PTAPUE[5:0] — Port A Input Pullup Enable Bits These read/write bits are software programmable to enable pullup devices on port A pins. 1 = Corresponding port A pin configured to have internal pull if its DDRA bit is set to 0 0 = Pullup device is disconnected on the corresponding port A pin regardless of the state of its DDRA bit Table 12-1 summarizes the operation of the port A pins. Table 12-1. Port A Pin Functions PTAPUE Bit DDRA Bit PTA Bit I/O Pin Mode Accesses to DDRA Accesses to PTA Read/Write Read Write 1 0 X(1) Input, VDD(2) DDRA5–DDRA0 Pin PTA5–PTA0(3) 0 0 X Input, Hi-Z(4) DDRA5–DDRA0 Pin PTA5–PTA0(3) X 1 X Output DDRA5–DDRA0 PTA5–PTA0 PTA5–PTA0(5) 1. X = don’t care 2. I/O pin pulled to VDD by internal pullup. 3. Writing affects data register, but does not affect input. 4. Hi-Z = high impedance 5. Output does not apply to PTA2 Data Sheet 108 MC68HC908QY/QT Family — Rev. 3 Input/Output Ports (PORTS) MOTOROLA Input/Output Ports (PORTS) Port B 12.3 Port B Port B is an 8-bit general purpose I/O port. Port B is only available on the MC68HC908QY1, MC68HC908QY2, and MC68HC908QY4. 12.3.1 Port B Data Register The port B data register (PTB) contains a data latch for each of the eight port B pins. Address: $0001 Read: Write: Bit 7 6 5 4 3 2 1 Bit 0 PTB7 PTB6 PTB5 PTB4 PTB3 PTB2 PTB1 PTB0 Reset: Unaffected by reset Figure 12-6. Port B Data Register (PTB) PTB[7:0] — Port B Data Bits These read/write bits are software programmable. Data direction of each port B pin is under the control of the corresponding bit in data direction register B. Reset has no effect on port B data. 12.3.2 Data Direction Register B Data direction register B (DDRB) determines whether each port B pin is an input or an output. Writing a 1 to a DDRB bit enables the output buffer for the corresponding port B pin; a 0 disables the output buffer. Address: $0005 Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 DDRB7 DDRB6 DDRB5 DDRB4 DDRB3 DDRB2 DDRB1 DDRB0 0 0 0 0 0 0 0 0 Figure 12-7. Data Direction Register B (DDRB) DDRB[7:0] — Data Direction Register B Bits These read/write bits control port B data direction. Reset clears DDRB[7:0], configuring all port B pins as inputs. 1 = Corresponding port B pin configured as output 0 = Corresponding port B pin configured as input NOTE: Avoid glitches on port B pins by writing to the port B data register before changing data direction register B bits from 0 to 1. Figure 12-8 shows the port B I/O logic. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Input/Output Ports (PORTS) 109 Input/Output Ports (PORTS) READ DDRB ($0005) PTBPUEx INTERNAL DATA BUS WRITE DDRB ($0005) RESET DDRBx 30 k WRITE PTB ($0001) PTBx PTBx READ PTB ($0001) Figure 12-8. Port B I/O Circuit When DDRBx is a 1, reading address $0001 reads the PTBx data latch. When DDRBx is a 0, reading address $0001 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. Table 12-2 summarizes the operation of the port B pins. Table 12-2. Port B Pin Functions DDRB Bit PTB Bit I/O Pin Mode Accesses to DDRB Accesses to PTB Read/Write Read Write 0 X(1) Input, Hi-Z(2) DDRB7–DDRB0 Pin PTB7–PTB0(3) 1 X Output DDRB7–DDRB0 Pin PTB7–PTB0 1. X = don’t care 2. Hi-Z = high impedance 3. Writing affects data register, but does not affect the input. Data Sheet 110 MC68HC908QY/QT Family — Rev. 3 Input/Output Ports (PORTS) MOTOROLA Input/Output Ports (PORTS) Port B 12.3.3 Port B Input Pullup Enable Register The port B input pullup enable register (PTBPUE) contains a software configurable pullup device for each of the eight port B pins. Each bit is individually configurable and requires the corresponding data direction register, DDRBx, be configured as input. Each pullup device is automatically and dynamically disabled when its corresponding DDRBx bit is configured as output. Address: $000C Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 PTBPUE7 PTBPUE6 PTBPUE5 PTBPUE4 PTBPUE3 PTBPUE2 PTBPUE2 PTBPUE0 0 0 0 0 0 0 0 0 Figure 12-9. Port B Input Pullup Enable Register (PTBPUE) PTBPUE[7:0] — Port B Input Pullup Enable Bits These read/write bits are software programmable to enable pullup devices on port B pins 1 = Corresponding port B pin configured to have internal pull if its DDRB bit is set to 0 0 = Pullup device is disconnected on the corresponding port B pin regardless of the state of its DDRB bit. Table 12-3 summarizes the operation of the port B pins. Table 12-3. Port B Pin Functions PTBPUE Bit DDRB Bit PTB Bit I/O Pin Mode Accesses to DDRB Read/Write Read Write 1 0 X(1) Input, VDD(2) DDRB7–DDRB0 Pin PTB7–PTB0(3) 0 0 X Input, Hi-Z(4) DDRB7–DDRB0 Pin PTB7–PTB0(3) X 1 X Output DDRB7–DDRB0 PTB7–PTB0 PTB7–PTB0 1. 2. 3. 4. Accesses to PTB X = don’t care I/O pin pulled to VDD by internal pullup. Writing affects data register, but does not affect input. Hi-Z = high impedance MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Input/Output Ports (PORTS) 111 Input/Output Ports (PORTS) Data Sheet 112 MC68HC908QY/QT Family — Rev. 3 Input/Output Ports (PORTS) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 13. System Integration Module (SIM) 13.1 Introduction This section describes the system integration module (SIM), which supports up to 24 external and/or internal interrupts. Together with the central processor unit (CPU), the SIM controls all microcontroller unit (MCU) activities. A block diagram of the SIM is shown in Figure 13-1. Figure 13-2 is a summary of the SIM I/O registers. The SIM is a system state controller that coordinates CPU and exception timing. The SIM is responsible for: • Bus clock generation and control for CPU and peripherals – Stop/wait/reset/break entry and recovery – Internal clock control • Master reset control, including power-on reset (POR) and computer operating properly (COP) timeout • Interrupt control: – Acknowledge timing – Arbitration control timing – Vector address generation • CPU enable/disable timing Table 13-1. Signal Name Conventions Signal Name Description BUSCLKX4 Buffered clock from the internal, RC or XTAL oscillator circuit. BUSCLKX2 The BUSCLKX4 frequency divided by two. This signal is again divided by two in the SIM to generate the internal bus clocks (bus clock = BUSCLKX4 ÷ 4). Address bus Internal address bus Data bus Internal data bus PORRST Signal from the power-on reset module to the SIM IRST Internal reset signal R/W Read/write signal MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 113 System Integration Module (SIM) MODULE STOP MODULE WAIT CPU STOP (FROM CPU) CPU WAIT (FROM CPU) STOP/WAIT CONTROL SIMOSCEN (TO OSCILLATOR) SIM COUNTER COP CLOCK BUSCLKX4 (FROM OSCILLATOR) BUSCLKX2 (FROM OSCILLATOR) ÷2 VDD INTERNAL PULL-UP RESET PIN LOGIC CLOCK CONTROL CLOCK GENERATORS POR CONTROL MASTER RESET CONTROL RESET PIN CONTROL SIM RESET STATUS REGISTER INTERNAL CLOCKS ILLEGAL OPCODE (FROM CPU) ILLEGAL ADDRESS (FROM ADDRESS MAP DECODERS) COP TIMEOUT (FROM COP MODULE) LVI RESET (FROM LVI MODULE) FORCED MON MODE ENTRY (FROM MENRST MODULE) RESET INTERRUPT CONTROL AND PRIORITY DECODE INTERRUPT SOURCES CPU INTERFACE Figure 13-1. SIM Block Diagram Data Sheet 114 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Introduction Addr. Register Name $FE00 Break Status Register (BSR) See page 155. Bit 7 6 5 4 3 2 R R R R R R Read: Bit 0 SBSW Write: Reset: 1 R Note 1 0 0 0 0 0 0 0 0 1. Writing a 0 clears SBSW. $FE01 SIM Reset Status Register (SRSR) See page 129. $FE02 Reserved $FE03 Break Flag Control Register (BFCR) See page 130. $FE04 $FE05 $FE06 Interrupt Status Register 1 (INT1) See page 125. Interrupt Status Register 2 (INT2) See page 125. Interrupt Status Register 3 (INT3) See page 126. Read: POR PIN COP ILOP ILAD MODRST LVI 0 1 0 0 0 0 0 0 0 R R R R R R R R BCFE R R R R R R R Write: POR: Read: Write: Reset: 0 Read: 0 IF5 IF4 IF3 0 IF1 0 0 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 Read: IF14 0 0 0 0 0 0 0 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 Read: 0 0 0 0 0 0 0 IF15 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved = Unimplemented Figure 13-2. SIM I/O Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 115 System Integration Module (SIM) 13.2 RST and IRQ Pins Initialization RST and IRQ pins come out of reset as PTA3 and PTA2 respectively. RST and IRQ functions can be activated by programing CONFIG2 accordingly. Refer to Section 5. Configuration Register (CONFIG). 13.3 SIM Bus Clock Control and Generation The bus clock generator provides system clock signals for the CPU and peripherals on the MCU. The system clocks are generated from an incoming clock, BUSCLKX2, as shown in Figure 13-3. FROM OSCILLATOR BUSCLKX4 FROM OSCILLATOR BUSCLKX2 SIM COUNTER ÷2 BUS CLOCK GENERATORS SIM Figure 13-3. SIM Clock Signals 13.3.1 Bus Timing In user mode, the internal bus frequency is the oscillator frequency (BUSCLKX4) divided by four. 13.3.2 Clock Start-Up from POR When the power-on reset module generates a reset, the clocks to the CPU and peripherals are inactive and held in an inactive phase until after the 4096 BUSCLKX4 cycle POR time out has completed. The IBUS clocks start upon completion of the time out. 13.3.3 Clocks in Stop Mode and Wait Mode Upon exit from stop mode by an interrupt or reset, the SIM allows BUSCLKX4 to clock the SIM counter. The CPU and peripheral clocks do not become active until after the stop delay time out. This time out is selectable as 4096 or 32 BUSCLKX4 cycles. See 13.7.2 Stop Mode. In wait mode, the CPU clocks are inactive. The SIM also produces two sets of clocks for other modules. Refer to the wait mode subsection of each module to see if the module is active or inactive in wait mode. Some modules can be programmed to be active in wait mode. Data Sheet 116 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Reset and System Initialization 13.4 Reset and System Initialization The MCU has these reset sources: • Power-on reset module (POR) • External reset pin (RST) • Computer operating properly module (COP) • Low-voltage inhibit module (LVI) • Illegal opcode • Illegal address All of these resets produce the vector $FFFE–FFFF ($FEFE–FEFF in monitor mode) and assert the internal reset signal (IRST). IRST causes all registers to be returned to their default values and all modules to be returned to their reset states. An internal reset clears the SIM counter (see 13.5 SIM Counter), but an external reset does not. Each of the resets sets a corresponding bit in the SIM reset status register (SRSR). See 13.8 SIM Registers. 13.4.1 External Pin Reset The RST pin circuits include an internal pullup device. Pulling the asynchronous RST pin low halts all processing. The PIN bit of the SIM reset status register (SRSR) is set as long as RST is held low for at least the minimum tRL time. Figure 13-4 shows the relative timing. The RST pin function is only available if the RSTEN bit is set in the CONFIG1 register. BUSCLKX2 RST ADDRESS BUS VECT H PC VECT L Figure 13-4. External Reset Timing 13.4.2 Active Resets from Internal Sources The RST pin is initially setup as a general-purpose input after a POR. Setting the RSTEN bit in the CONFIG1 register enables the pin for the reset function. This section assumes the RSTEN bit is set when describing activity on the RST pin. NOTE: For POR and LVI resets, the SIM cycles through 4096 BUSCLKX4 cycles during which the SIM forces the RST pin low. The internal reset signal then follows the sequence from the falling edge of RST shown in Figure 13-5. The COP reset is asynchronous to the bus clock. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 117 System Integration Module (SIM) The active reset feature allows the part to issue a reset to peripherals and other chips within a system built around the MCU. All internal reset sources actively pull the RST pin low for 32 BUSCLKX4 cycles to allow resetting of external peripherals. The internal reset signal IRST continues to be asserted for an additional 32 cycles (see Figure 13-5). An internal reset can be caused by an illegal address, illegal opcode, COP time out, LVI, or POR (see Figure 13-6). IRST RST RST PULLED LOW BY MCU 32 CYCLES 32 CYCLES BUSCLKX4 ADDRESS BUS VECTOR HIGH Figure 13-5. Internal Reset Timing ILLEGAL ADDRESS RST ILLEGAL OPCODE RST COPRST POR LVI INTERNAL RESET Figure 13-6. Sources of Internal Reset Table 13-2. Reset Recovery Timing Reset Recovery Type Actual Number of Cycles POR/LVI 4163 (4096 + 64 + 3) All others 67 (64 + 3) 13.4.2.1 Power-On Reset When power is first applied to the MCU, the power-on reset module (POR) generates a pulse to indicate that power on has occurred. The SIM counter counts out 4096 BUSCLKX4 cycles. Sixty-four BUSCLKX4 cycles later, the CPU and memories are released from reset to allow the reset vector sequence to occur. Data Sheet 118 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Reset and System Initialization At power on, the following events occur: • A POR pulse is generated. • The internal reset signal is asserted. • The SIM enables the oscillator to drive BUSCLKX4. • Internal clocks to the CPU and modules are held inactive for 4096 BUSCLKX4 cycles to allow stabilization of the oscillator. • The POR bit of the SIM reset status register (SRSR) is set See Figure 13-7. OSC1 PORRST 4096 CYCLES 32 CYCLES 32 CYCLES BUSCLKX4 BUSCLKX2 RST ADDRESS BUS $FFFE $FFFF Figure 13-7. POR Recovery 13.4.2.2 Computer Operating Properly (COP) Reset An input to the SIM is reserved for the COP reset signal. The overflow of the COP counter causes an internal reset and sets the COP bit in the SIM reset status register (SRSR). The SIM actively pulls down the RST pin for all internal reset sources. To prevent a COP module time out, write any value to location $FFFF. Writing to location $FFFF clears the COP counter and stages 12–5 of the SIM counter. The SIM counter output, which occurs at least every (212 – 24) BUSCLKX4 cycles, drives the COP counter. The COP should be serviced as soon as possible out of reset to guarantee the maximum amount of time before the first time out. The COP module is disabled during a break interrupt with monitor mode when BDCOP bit is set in break auxiliary register (BRKAR). MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 119 System Integration Module (SIM) 13.4.2.3 Illegal Opcode Reset The SIM decodes signals from the CPU to detect illegal instructions. An illegal instruction sets the ILOP bit in the SIM reset status register (SRSR) and causes a reset. If the stop enable bit, STOP, in the mask option register is 0, the SIM treats the STOP instruction as an illegal opcode and causes an illegal opcode reset. The SIM actively pulls down the RST pin for all internal reset sources. 13.4.2.4 Illegal Address Reset An opcode fetch from an unmapped address generates an illegal address reset. The SIM verifies that the CPU is fetching an opcode prior to asserting the ILAD bit in the SIM reset status register (SRSR) and resetting the MCU. A data fetch from an unmapped address does not generate a reset. The SIM actively pulls down the RST pin for all internal reset sources. See Figure 2-1. Memory Map for memory ranges. 13.4.2.5 Low-Voltage Inhibit (LVI) Reset The LVI asserts its output to the SIM when the VDD voltage falls to the LVI trip voltage VTRIPF. The LVI bit in the SIM reset status register (SRSR) is set, and the external reset pin (RST) is held low while the SIM counter counts out 4096 BUSCLKX4 cycles after VDD rises above VTRIPR. Sixty-four BUSCLKX4 cycles later, the CPU and memories are released from reset to allow the reset vector sequence to occur. The SIM actively pulls down the (RST) pin for all internal reset sources. 13.5 SIM Counter The SIM counter is used by the power-on reset module (POR) and in stop mode recovery to allow the oscillator time to stabilize before enabling the internal bus (IBUS) clocks. The SIM counter also serves as a prescaler for the computer operating properly module (COP). The SIM counter uses 12 stages for counting, followed by a 13th stage that triggers a reset of SIM counters and supplies the clock for the COP module. The SIM counter is clocked by the falling edge of BUSCLKX4. 13.5.1 SIM Counter During Power-On Reset The power-on reset module (POR) detects power applied to the MCU. At power-on, the POR circuit asserts the signal PORRST. Once the SIM is initialized, it enables the oscillator to drive the bus clock state machine. Data Sheet 120 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control 13.5.2 SIM Counter During Stop Mode Recovery The SIM counter also is used for stop mode recovery. The STOP instruction clears the SIM counter. After an interrupt, break, or reset, the SIM senses the state of the short stop recovery bit, SSREC, in the configuration register 1 (CONFIG1). If the SSREC bit is a 1, then the stop recovery is reduced from the normal delay of 4096 BUSCLKX4 cycles down to 32 BUSCLKX4 cycles. This is ideal for applications using canned oscillators that do not require long start-up times from stop mode. External crystal applications should use the full stop recovery time, that is, with SSREC cleared in the configuration register 1 (CONFIG1). 13.5.3 SIM Counter and Reset States External reset has no effect on the SIM counter (see 13.7.2 Stop Mode for details.) The SIM counter is free-running after all reset states. See 13.4.2 Active Resets from Internal Sources for counter control and internal reset recovery sequences. 13.6 Exception Control Normal sequential program execution can be changed in three different ways: 1. Interrupts a. Maskable hardware CPU interrupts b. Non-maskable software interrupt instruction (SWI) 2. Reset 3. Break interrupts 13.6.1 Interrupts An interrupt temporarily changes the sequence of program execution to respond to a particular event. Figure 13-8 flow charts the handling of system interrupts. Interrupts are latched, and arbitration is performed in the SIM at the start of interrupt processing. The arbitration result is a constant that the CPU uses to determine which vector to fetch. Once an interrupt is latched by the SIM, no other interrupt can take precedence, regardless of priority, until the latched interrupt is serviced (or the I bit is cleared). At the beginning of an interrupt, the CPU saves the CPU register contents on the stack and sets the interrupt mask (I bit) to prevent additional interrupts. At the end of an interrupt, the RTI instruction recovers the CPU register contents from the stack so that normal processing can resume. Figure 13-9 shows interrupt entry timing. Figure 13-10 shows interrupt recovery timing. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 121 System Integration Module (SIM) FROM RESET BREAK INTERRUPT? I BIT SET? YES NO YES I BIT SET? NO IRQ INTERRUPT? YES NO TIMER INTERRUPT? YES NO STACK CPU REGISTERS SET I BIT LOAD PC WITH INTERRUPT VECTOR (AS MANY INTERRUPTS AS EXIST ON CHIP) FETCH NEXT INSTRUCTION SWI INSTRUCTION? YES NO RTI INSTRUCTION? YES UNSTACK CPU REGISTERS NO EXECUTE INSTRUCTION Figure 13-8. Interrupt Processing Data Sheet 122 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control MODULE INTERRUPT I BIT DUMMY ADDRESS BUS DATA BUS SP DUMMY SP – 1 SP – 2 PC – 1[7:0] PC – 1[15:8] SP – 3 X SP – 4 A VECT H CCR VECT L V DATA H START ADDR V DATA L OPCODE R/W Figure 13-9. Interrupt Entry MODULE INTERRUPT I BIT ADDRESS BUS SP – 4 DATA BUS SP – 3 CCR SP – 2 A SP – 1 X SP PC PC + 1 PC – 1[7:0] PC – 1[15:8] OPCODE OPERAND R/W Figure 13-10. Interrupt Recovery 13.6.1.1 Hardware Interrupts A hardware interrupt does not stop the current instruction. Processing of a hardware interrupt begins after completion of the current instruction. When the current instruction is complete, the SIM checks all pending hardware interrupts. If interrupts are not masked (I bit clear in the condition code register), and if the corresponding interrupt enable bit is set, the SIM proceeds with interrupt processing; otherwise, the next instruction is fetched and executed. If more than one interrupt is pending at the end of an instruction execution, the highest priority interrupt is serviced first. Figure 13-11 demonstrates what happens when two interrupts are pending. If an interrupt is pending upon exit from the original interrupt service routine, the pending interrupt is serviced before the LDA instruction is executed. The LDA opcode is prefetched by both the INT1 and INT2 return-from-interrupt (RTI) instructions. However, in the case of the INT1 RTI prefetch, this is a redundant operation. NOTE: To maintain compatibility with the M6805 Family, the H register is not pushed on the stack during interrupt entry. If the interrupt service routine modifies the H register or uses the indexed addressing mode, software should save the H register and then restore it prior to exiting the routine. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 123 System Integration Module (SIM) CLI LDA #$FF INT1 BACKGROUND ROUTINE PSHH INT1 INTERRUPT SERVICE ROUTINE PULH RTI INT2 PSHH INT2 INTERRUPT SERVICE ROUTINE PULH RTI Figure 13-11. Interrupt Recognition Example 13.6.1.2 SWI Instruction The SWI instruction is a non-maskable instruction that causes an interrupt regardless of the state of the interrupt mask (I bit) in the condition code register. NOTE: A software interrupt pushes PC onto the stack. A software interrupt does not push PC – 1, as a hardware interrupt does. 13.6.2 Interrupt Status Registers The flags in the interrupt status registers identify maskable interrupt sources. Table 13-3 summarizes the interrupt sources and the interrupt status register flags that they set. The interrupt status registers can be useful for debugging. Table 13-3. Interrupt Sources Priority Highest Source Flag Mask(1) INT Register Flag Vector Address — — — $FFFE–$FFFF Reset SWI instruction — — — $FFFC–$FFFD IRQ pin IRQF IMASK IF1 $FFFA–$FFFB Timer channel 0 interrupt CH0F CH0IE IF3 $FFF6–$FFF7 Timer channel 1 interrupt CH1F CH1IE IF4 $FFF4–$FFF5 Timer overflow interrupt Lowest TOF TOIE IF5 $FFF2–$FFF3 Keyboard interrupt KEYF IMASKK IF14 $FFE0–$FFE1 ADC conversion complete interrupt COCO AIEN IF15 $FFDE–$FFDF 1. The I bit in the condition code register is a global mask for all interrupt sources except the SWI instruction. Data Sheet 124 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control 13.6.2.1 Interrupt Status Register 1 Address: $FE04 Bit 7 6 5 4 3 2 1 Bit 0 Read: 0 IF5 IF4 IF3 0 IF1 0 0 Write: R R R R R R R R 0 0 0 0 0 0 0 0 R = Reserved Reset: Figure 13-12. Interrupt Status Register 1 (INT1) IF1 and IF3–IF5 — Interrupt Flags These flags indicate the presence of interrupt requests from the sources shown in Table 13-3. 1 = Interrupt request present 0 = No interrupt request present Bit 0, 1, 3, and 7 — Always read 0 13.6.2.2 Interrupt Status Register 2 Address: $FE05 Bit 7 6 5 4 3 2 1 Bit 0 Read: IF14 0 0 0 0 0 0 0 Write: R R R R R R R R 0 0 0 0 0 0 0 0 R = Reserved Reset: Figure 13-13. Interrupt Status Register 2 (INT2) IF14 — Interrupt Flags This flag indicates the presence of interrupt requests from the sources shown in Table 13-3. 1 = Interrupt request present 0 = No interrupt request present Bit 0–6 — Always read 0 MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 125 System Integration Module (SIM) 13.6.2.3 Interrupt Status Register 3 Address: $FE06 Bit 7 6 5 4 3 2 1 Bit 0 Read: 0 0 0 0 0 0 0 IF15 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 13-14. Interrupt Status Register 3 (INT3) IF15 — Interrupt Flags These flags indicate the presence of interrupt requests from the sources shown in Table 13-3. 1 = Interrupt request present 0 = No interrupt request present Bit 1–7 — Always read 0 13.6.3 Reset All reset sources always have equal and highest priority and cannot be arbitrated. 13.6.4 Break Interrupts The break module can stop normal program flow at a software programmable break point by asserting its break interrupt output. (See Section 15. Development Support.) The SIM puts the CPU into the break state by forcing it to the SWI vector location. Refer to the break interrupt subsection of each module to see how each module is affected by the break state. 13.6.5 Status Flag Protection in Break Mode The SIM controls whether status flags contained in other modules can be cleared during break mode. The user can select whether flags are protected from being cleared by properly initializing the break clear flag enable bit (BCFE) in the break flag control register (BFCR). Protecting flags in break mode ensures that set flags will not be cleared while in break mode. This protection allows registers to be freely read and written during break mode without losing status flag information. Setting the BCFE bit enables the clearing mechanisms. Once cleared in break mode, a flag remains cleared even when break mode is exited. Status flags with a two-step clearing mechanism — for example, a read of one register followed by the read or write of another — are protected, even when the first step is accomplished prior to entering break mode. Upon leaving break mode, execution of the second step will clear the flag as normal. Data Sheet 126 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Low-Power Modes 13.7 Low-Power Modes Executing the WAIT or STOP instruction puts the MCU in a low powerconsumption mode for standby situations. The SIM holds the CPU in a non-clocked state. The operation of each of these modes is described below. Both STOP and WAIT clear the interrupt mask (I) in the condition code register, allowing interrupts to occur. 13.7.1 Wait Mode In wait mode, the CPU clocks are inactive while the peripheral clocks continue to run. Figure 13-15 shows the timing for wait mode entry. ADDRESS BUS WAIT ADDR DATA BUS WAIT ADDR + 1 PREVIOUS DATA SAME SAME NEXT OPCODE SAME SAME R/W NOTE: Previous data can be operand data or the WAIT opcode, depending on the last instruction. Figure 13-15. Wait Mode Entry Timing A module that is active during wait mode can wake up the CPU with an interrupt if the interrupt is enabled. Stacking for the interrupt begins one cycle after the WAIT instruction during which the interrupt occurred. In wait mode, the CPU clocks are inactive. Refer to the wait mode subsection of each module to see if the module is active or inactive in wait mode. Some modules can be programmed to be active in wait mode. Wait mode can also be exited by a reset (or break in emulation mode). A break interrupt during wait mode sets the SIM break stop/wait bit, SBSW, in the break status register (BSR). If the COP disable bit, COPD, in the configuration register is 0, then the computer operating properly module (COP) is enabled and remains active in wait mode. Figure 13-16 and Figure 13-17 show the timing for wait recovery. ADDRESS BUS DATA BUS $6E0B $A6 $A6 $6E0C $A6 $01 $00FF $0B $00FE $00FD $00FC $6E EXITSTOPWAIT NOTE: EXITSTOPWAIT = RST pin OR CPU interrupt OR break interrupt Figure 13-16. Wait Recovery from Interrupt MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 127 System Integration Module (SIM) 32 CYCLES ADDRESS BUS DATA BUS 32 CYCLES $6E0B $A6 $A6 RSTVCT H RSTVCT L $A6 RST BUSCLKX4 Figure 13-17. Wait Recovery from Internal Reset 13.7.2 Stop Mode In stop mode, the SIM counter is reset and the system clocks are disabled. An interrupt request from a module can cause an exit from stop mode. Stacking for interrupts begins after the selected stop recovery time has elapsed. Reset or break also causes an exit from stop mode. The SIM disables the oscillator signals (BUSCLKX2 and BUSCLKX4) in stop mode, stopping the CPU and peripherals. Stop recovery time is selectable using the SSREC bit in the configuration register 1 (CONFIG1). If SSREC is set, stop recovery is reduced from the normal delay of 4096 BUSCLKX4 cycles down to 32. This is ideal for the internal oscillator, RC oscillator, and external oscillator options which do not require long start-up times from stop mode. NOTE: External crystal applications should use the full stop recovery time by clearing the SSREC bit. The SIM counter is held in reset from the execution of the STOP instruction until the beginning of stop recovery. It is then used to time the recovery period. Figure 13-18 shows stop mode entry timing and Figure 13-19 shows the stop mode recovery time from interrupt or break. NOTE: To minimize stop current, all pins configured as inputs should be driven to a logic 1 or logic 0. CPUSTOP ADDRESS BUS DATA BUS STOP ADDR STOP ADDR + 1 PREVIOUS DATA SAME NEXT OPCODE SAME SAME SAME R/W NOTE: Previous data can be operand data or the STOP opcode, depending on the last instruction. Figure 13-18. Stop Mode Entry Timing Data Sheet 128 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) SIM Registers STOP RECOVERY PERIOD BUSCLKX4 INTERRUPT ADDRESS BUS STOP + 2 STOP +1 STOP + 2 SP SP – 1 SP – 2 SP – 3 Figure 13-19. Stop Mode Recovery from Interrupt 13.8 SIM Registers The SIM has three memory mapped registers. Table 13-4 shows the mapping of these registers. Table 13-4. SIM Registers Address Register Access Mode $FE00 BSR User $FE01 SRSR User $FE03 BFCR User 13.8.1 SIM Reset Status Register This register contains seven flags that show the source of the last reset. Clear the SIM reset status register by reading it. A power-on reset sets the POR bit. Address: $FE01 Read: Bit 7 6 5 4 3 2 1 Bit 0 POR PIN COP ILOP ILAD MODRST LVI 0 1 0 0 0 0 0 0 0 Write: POR: = Unimplemented Figure 13-20. SIM Reset Status Register (SRSR) POR — Power-On Reset Bit 1 = Last reset caused by POR circuit 0 = Read of SRSR PIN — External Reset Bit 1 = Last reset caused by external reset pin (RST) 0 = POR or read of SRSR MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet System Integration Module (SIM) 129 System Integration Module (SIM) COP — Computer Operating Properly Reset Bit 1 = Last reset caused by COP counter 0 = POR or read of SRSR ILOP — Illegal Opcode Reset Bit 1 = Last reset caused by an illegal opcode 0 = POR or read of SRSR ILAD — Illegal Address Reset Bit (illegal attempt to fetch an opcode from an unimplemented address) 1 = Last reset caused by an opcode fetch from an illegal address 0 = POR or read of SRSR MODRST — Monitor Mode Entry Module Reset bit 1 = Last reset caused by monitor mode entry when vector locations $FFFE and $FFFF are $FF after POR while IRQ = VDD 0 = POR or read of SRSR LVI — Low Voltage Inhibit Reset bit 1 = Last reset caused by LVI circuit 0 = POR or read of SRSR 13.8.2 Break Flag Control Register The break control register (BFCR) contains a bit that enables software to clear status bits while the MCU is in a break state. Address: $FE03 Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 BCFE R R R R R R R 0 R = Reserved Figure 13-21. Break Flag Control Register (BFCR) BCFE — Break Clear Flag Enable Bit This read/write bit enables software to clear status bits by accessing status registers while the MCU is in a break state. To clear status bits during the break state, the BCFE bit must be set. 1 = Status bits clearable during break 0 = Status bits not clearable during break Data Sheet 130 MC68HC908QY/QT Family — Rev. 3 System Integration Module (SIM) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 14. Timer Interface Module (TIM) 14.1 Introduction This section describes the timer interface module (TIM). The TIM is a two-channel timer that provides a timing reference with input capture, output compare, and pulse-width-modulation functions. Figure 14-2 is a block diagram of the TIM. 14.2 Features Features of the TIM include the following: • Two input capture/output compare channels – Rising-edge, falling-edge, or any-edge input capture trigger – Set, clear, or toggle output compare action • Buffered and unbuffered pulse width modulation (PWM) signal generation • Programmable TIM clock input – 7-frequency internal bus clock prescaler selection – External TIM clock input • Free-running or modulo up-count operation • Toggle any channel pin on overflow • TIM counter stop and reset bits 14.3 Pin Name Conventions The TIM shares two input/output (I/O) pins with two port A I/O pins. The full names of the TIM I/O pins are listed in Table 14-1. The generic pin name appear in the text that follows. Table 14-1. Pin Name Conventions TIM Generic Pin Names: Full TIM Pin Names: TCH0 TCH1 TCLK PTA0/TCH0 PTA1/TCH1 PTA2/TCLK MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 131 Timer Interface Module (TIM) PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU PTB SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 14-1. Block Diagram Highlighting TIM Block and Pins Data Sheet 132 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description 14.4 Functional Description Figure 14-2 shows the structure of the TIM. The central component of the TIM is the 16-bit TIM counter that can operate as a free-running counter or a modulo up-counter. The TIM counter provides the timing reference for the input capture and output compare functions. The TIM counter modulo registers, TMODH:TMODL, control the modulo value of the TIM counter. Software can read the TIM counter value at any time without affecting the counting sequence. The two TIM channels are programmable independently as input capture or output compare channels. PTA2/IRQ/KBI2/TCLK PRESCALER SELECT INTERNAL BUS CLOCK PRESCALER TSTOP PS2 TRST PS1 PS0 16-BIT COUNTER TOF TOIE INTERRUPT LOGIC 16-BIT COMPARATOR TMODH:TMODL TOV0 CHANNEL 0 ELS0B ELS0A CH0MAX 16-BIT COMPARATOR TCH0H:TCH0L PORT LOGIC TCH0 CH0F 16-BIT LATCH CH0IE MS0A INTERRUPT LOGIC MS0B INTERNAL BUS TOV1 CHANNEL 1 ELS1B ELS1A CH1MAX PORT LOGIC TCH1 16-BIT COMPARATOR TCH1H:TCH1L CH1F 16-BIT LATCH MS1A CH1IE INTERRUPT LOGIC Figure 14-2. TIM Block Diagram MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 133 Timer Interface Module (TIM) Addr. Register Name $0020 TIM Status and Control Register (TSC) See page 141. $0021 $0022 $0023 $0024 $0025 $0026 $0027 $0028 $0029 $002A TIM Counter Register High (TCNTH) See page 143. TIM Counter Register Low (TCNTL) See page 143. TIM Counter Modulo Register High (TMODH) See page 143. TIM Counter Modulo Register Low (TMODL) See page 143. TIM Channel 0 Status and Control Register (TSC0) See page 144. TIM Channel 0 Register High (TCH0H) See page 147. TIM Channel 0 Register Low (TCH0L) See page 147. TIM Channel 1 Status and Control Register (TSC1) See page 144. TIM Channel 1 Register High (TCH1H) See page 147. TIM Channel 1 Register Low (TCH1L) See page 147. Bit 7 6 5 TOIE TSTOP 4 3 0 0 2 1 Bit 0 PS2 PS1 PS0 Read: TOF Write: 0 Reset: 0 0 1 0 0 0 0 0 Read: Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Reset: 0 0 0 0 0 0 0 0 Read: Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 1 1 1 1 1 1 1 1 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Reset: 1 1 1 1 1 1 1 1 Read: CH0F Write: 0 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX Reset: 0 0 0 0 0 0 0 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 2 Bit 1 Bit 0 TRST Write: Write: Reset: Read: Write: Reset: Read: Write: Read: Write: Reset: Read: Write: Indeterminate after reset Bit 7 Bit 6 Bit 5 Reset: CH1F Write: 0 Reset: 0 0 Bit 15 Bit 14 Write: CH1IE 0 MS1A ELS1B ELS1A TOV1 CH1MAX 0 0 0 0 0 0 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 2 Bit 1 Bit 0 Reset: Read: Write: Bit 3 Indeterminate after reset Read: Read: Bit 4 Indeterminate after reset Bit 7 Bit 6 Bit 5 Reset: Bit 4 Bit 3 Indeterminate after reset = Unimplemented Figure 14-3. TIM I/O Register Summary Data Sheet 134 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description 14.4.1 TIM Counter Prescaler The TIM clock source is one of the seven prescaler outputs or the TIM clock pin, TCLK. The prescaler generates seven clock rates from the internal bus clock. The prescaler select bits, PS[2:0], in the TIM status and control register (TSC) select the TIM clock source. 14.4.2 Input Capture With the input capture function, the TIM can capture the time at which an external event occurs. When an active edge occurs on the pin of an input capture channel, the TIM latches the contents of the TIM counter into the TIM channel registers, TCHxH:TCHxL. The polarity of the active edge is programmable. Input captures can generate TIM central processor unit (CPU) interrupt requests. 14.4.3 Output Compare With the output compare function, the TIM can generate a periodic pulse with a programmable polarity, duration, and frequency. When the counter reaches the value in the registers of an output compare channel, the TIM can set, clear, or toggle the channel pin. Output compares can generate TIM CPU interrupt requests. 14.4.3.1 Unbuffered Output Compare Any output compare channel can generate unbuffered output compare pulses as described in 14.4.3 Output Compare. The pulses are unbuffered because changing the output compare value requires writing the new value over the old value currently in the TIM channel registers. An unsynchronized write to the TIM channel registers to change an output compare value could cause incorrect operation for up to two counter overflow periods. For example, writing a new value before the counter reaches the old value but after the counter reaches the new value prevents any compare during that counter overflow period. Also, using a TIM overflow interrupt routine to write a new, smaller output compare value may cause the compare to be missed. The TIM may pass the new value before it is written. Use the following methods to synchronize unbuffered changes in the output compare value on channel x: • When changing to a smaller value, enable channel x output compare interrupts and write the new value in the output compare interrupt routine. The output compare interrupt occurs at the end of the current output compare pulse. The interrupt routine has until the end of the counter overflow period to write the new value. • When changing to a larger output compare value, enable TIM overflow interrupts and write the new value in the TIM overflow interrupt routine. The TIM overflow interrupt occurs at the end of the current counter overflow MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 135 Timer Interface Module (TIM) period. Writing a larger value in an output compare interrupt routine (at the end of the current pulse) could cause two output compares to occur in the same counter overflow period. 14.4.3.2 Buffered Output Compare Channels 0 and 1 can be linked to form a buffered output compare channel whose output appears on the TCH0 pin. The TIM channel registers of the linked pair alternately control the output. Setting the MS0B bit in TIM channel 0 status and control register (TSC0) links channel 0 and channel 1. The output compare value in the TIM channel 0 registers initially controls the output on the TCH0 pin. Writing to the TIM channel 1 registers enables the TIM channel 1 registers to synchronously control the output after the TIM overflows. At each subsequent overflow, the TIM channel registers (0 or 1) that control the output are the ones written to last. TSC0 controls and monitors the buffered output compare function, and TIM channel 1 status and control register (TSC1) is unused. While the MS0B bit is set, the channel 1 pin, TCH1, is available as a general-purpose I/O pin. NOTE: In buffered output compare operation, do not write new output compare values to the currently active channel registers. User software should track the currently active channel to prevent writing a new value to the active channel. Writing to the active channel registers is the same as generating unbuffered output compares. 14.4.4 Pulse Width Modulation (PWM) By using the toggle-on-overflow feature with an output compare channel, the TIM can generate a PWM signal. The value in the TIM counter modulo registers determines the period of the PWM signal. The channel pin toggles when the counter reaches the value in the TIM counter modulo registers. The time between overflows is the period of the PWM signal As Figure 14-4 shows, the output compare value in the TIM channel registers determines the pulse width of the PWM signal. The time between overflow and output compare is the pulse width. Program the TIM to clear the channel pin on output compare if the state of the PWM pulse is logic 1 (ELSxA = 0). Program the TIM to set the pin if the state of the PWM pulse is logic 0 (ELSxA = 1). The value in the TIM counter modulo registers and the selected prescaler output determines the frequency of the PWM output The frequency of an 8-bit PWM signal is variable in 256 increments. Writing $00FF (255) to the TIM counter modulo registers produces a PWM period of 256 times the internal bus clock period if the prescaler select value is 000. See 14.9.1 TIM Status and Control Register. The value in the TIM channel registers determines the pulse width of the PWM output. The pulse width of an 8-bit PWM signal is variable in 256 increments. Writing $0080 (128) to the TIM channel registers produces a duty cycle of 128/256 or 50%. Data Sheet 136 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description OVERFLOW OVERFLOW OVERFLOW PERIOD POLARITY = 1 (ELSxA = 0) TCHx PULSE WIDTH POLARITY = 0 (ELSxA = 1) TCHx OUTPUT COMPARE OUTPUT COMPARE OUTPUT COMPARE Figure 14-4. PWM Period and Pulse Width 14.4.4.1 Unbuffered PWM Signal Generation Any output compare channel can generate unbuffered PWM pulses as described in 14.4.4 Pulse Width Modulation (PWM). The pulses are unbuffered because changing the pulse width requires writing the new pulse width value over the old value currently in the TIM channel registers. An unsynchronized write to the TIM channel registers to change a pulse width value could cause incorrect operation for up to two PWM periods. For example, writing a new value before the counter reaches the old value but after the counter reaches the new value prevents any compare during that PWM period. Also, using a TIM overflow interrupt routine to write a new, smaller pulse width value may cause the compare to be missed. The TIM may pass the new value before it is written. Use the following methods to synchronize unbuffered changes in the PWM pulse width on channel x: NOTE: • When changing to a shorter pulse width, enable channel x output compare interrupts and write the new value in the output compare interrupt routine. The output compare interrupt occurs at the end of the current pulse. The interrupt routine has until the end of the PWM period to write the new value. • When changing to a longer pulse width, enable TIM overflow interrupts and write the new value in the TIM overflow interrupt routine. The TIM overflow interrupt occurs at the end of the current PWM period. Writing a larger value in an output compare interrupt routine (at the end of the current pulse) could cause two output compares to occur in the same PWM period. In PWM signal generation, do not program the PWM channel to toggle on output compare. Toggling on output compare prevents reliable 0% duty cycle generation and removes the ability of the channel to self-correct in the event of software error or noise. Toggling on output compare also can cause incorrect PWM signal generation when changing the PWM pulse width to a new, much larger value. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 137 Timer Interface Module (TIM) 14.4.4.2 Buffered PWM Signal Generation Channels 0 and 1 can be linked to form a buffered PWM channel whose output appears on the TCH0 pin. The TIM channel registers of the linked pair alternately control the pulse width of the output. Setting the MS0B bit in TIM channel 0 status and control register (TSC0) links channel 0 and channel 1. The TIM channel 0 registers initially control the pulse width on the TCH0 pin. Writing to the TIM channel 1 registers enables the TIM channel 1 registers to synchronously control the pulse width at the beginning of the next PWM period. At each subsequent overflow, the TIM channel registers (0 or 1) that control the pulse width are the ones written to last. TSC0 controls and monitors the buffered PWM function, and TIM channel 1 status and control register (TSC1) is unused. While the MS0B bit is set, the channel 1 pin, TCH1, is available as a general-purpose I/O pin. NOTE: In buffered PWM signal generation, do not write new pulse width values to the currently active channel registers. User software should track the currently active channel to prevent writing a new value to the active channel. Writing to the active channel registers is the same as generating unbuffered PWM signals. 14.4.4.3 PWM Initialization To ensure correct operation when generating unbuffered or buffered PWM signals, use the following initialization procedure: 1. In the TIM status and control register (TSC): a. Stop the TIM counter by setting the TIM stop bit, TSTOP. b. Reset the TIM counter and prescaler by setting the TIM reset bit, TRST. 2. In the TIM counter modulo registers (TMODH:TMODL), write the value for the required PWM period. 3. In the TIM channel x registers (TCHxH:TCHxL), write the value for the required pulse width. 4. In TIM channel x status and control register (TSCx): a. Write 0:1 (for unbuffered output compare or PWM signals) or 1:0 (for buffered output compare or PWM signals) to the mode select bits, MSxB:MSxA. See Table 14-3. b. Write 1 to the toggle-on-overflow bit, TOVx. c. Write 1:0 (polarity 1 — to clear output on compare) or 1:1 (polarity 0 — to set output on compare) to the edge/level select bits, ELSxB:ELSxA. The output action on compare must force the output to the complement of the pulse width level. See Table 14-3. NOTE: In PWM signal generation, do not program the PWM channel to toggle on output compare. Toggling on output compare prevents reliable 0% duty cycle generation and removes the ability of the channel to self-correct in the event of software error Data Sheet 138 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Interrupts or noise. Toggling on output compare can also cause incorrect PWM signal generation when changing the PWM pulse width to a new, much larger value. 5. In the TIM status control register (TSC), clear the TIM stop bit, TSTOP. Setting MS0B links channels 0 and 1 and configures them for buffered PWM operation. The TIM channel 0 registers (TCH0H:TCH0L) initially control the buffered PWM output. TIM status control register 0 (TSCR0) controls and monitors the PWM signal from the linked channels. MS0B takes priority over MS0A. Clearing the toggle-on-overflow bit, TOVx, inhibits output toggles on TIM overflows. Subsequent output compares try to force the output to a state it is already in and have no effect. The result is a 0% duty cycle output. Setting the channel x maximum duty cycle bit (CHxMAX) and setting the TOVx bit generates a 100% duty cycle output. See 14.9.4 TIM Channel Status and Control Registers. 14.5 Interrupts The following TIM sources can generate interrupt requests: • TIM overflow flag (TOF) — The TOF bit is set when the TIM counter reaches the modulo value programmed in the TIM counter modulo registers. The TIM overflow interrupt enable bit, TOIE, enables TIM overflow CPU interrupt requests. TOF and TOIE are in the TIM status and control register. • TIM channel flags (CH1F:CH0F) — The CHxF bit is set when an input capture or output compare occurs on channel x. Channel x TIM CPU interrupt requests are controlled by the channel x interrupt enable bit, CHxIE. Channel x TIM CPU interrupt requests are enabled when CHxIE =1. CHxF and CHxIE are in the TIM channel x status and control register. 14.6 Wait Mode The WAIT instruction puts the MCU in low power-consumption standby mode. The TIM remains active after the execution of a WAIT instruction. In wait mode the TIM registers are not accessible by the CPU. Any enabled CPU interrupt request from the TIM can bring the MCU out of wait mode. If TIM functions are not required during wait mode, reduce power consumption by stopping the TIM before executing the WAIT instruction. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 139 Timer Interface Module (TIM) 14.7 TIM During Break Interrupts A break interrupt stops the TIM counter. The system integration module (SIM) controls whether status bits in other modules can be cleared during the break state. The BCFE bit in the break flag control register (BFCR) enables software to clear status bits during the break state. See 13.8.2 Break Flag Control Register. To allow software to clear status bits during a break interrupt, write a 1 to the BCFE bit. If a status bit is cleared during the break state, it remains cleared when the MCU exits the break state. To protect status bits during the break state, write a 0 to the BCFE bit. With BCFE at 0 (its default state), software can read and write I/O registers during the break state without affecting status bits. Some status bits have a two-step read/write clearing procedure. If software does the first step on such a bit before the break, the bit cannot change during the break state as long as BCFE is at 0. After the break, doing the second step clears the status bit. 14.8 Input/Output Signals Port A shares three of its pins with the TIM. Two TIM channel I/O pins are PTA0/TCH0 and PTA1/TCH1 and an alternate clock source is PTA2/TCLK. 14.8.1 TIM Clock Pin (PTA2/TCLK) PTA2/TCLK is an external clock input that can be the clock source for the TIM counter instead of the prescaled internal bus clock. Select the PTA2/TCLK input by writing 1s to the three prescaler select bits, PS[2–0]. (See 14.9.1 TIM Status and Control Register.) When the PTA2/TCLK pin is the TIM clock input, it is an input regardless of port pin initialization. 14.8.2 TIM Channel I/O Pins (PTA0/TCH0 and PTA1/TCH1) Each channel I/O pin is programmable independently as an input capture pin or an output compare pin. PTA0/TCH0 can be configured as a buffered output compare or buffered PWM pin. Data Sheet 140 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Input/Output Registers 14.9 Input/Output Registers The following I/O registers control and monitor operation of the TIM: • TIM status and control register (TSC) • TIM counter registers (TCNTH:TCNTL) • TIM counter modulo registers (TMODH:TMODL) • TIM channel status and control registers (TSC0 and TSC1) • TIM channel registers (TCH0H:TCH0L and TCH1H:TCH1L) 14.9.1 TIM Status and Control Register The TIM status and control register (TSC) does the following: • Enables TIM overflow interrupts • Flags TIM overflows • Stops the TIM counter • Resets the TIM counter • Prescales the TIM counter clock Address: $0020 Bit 7 Read: TOF Write: 0 Reset: 0 6 5 TOIE TSTOP 0 1 4 3 0 0 TRST 0 0 2 1 Bit 0 PS2 PS1 PS0 0 0 0 = Unimplemented Figure 14-5. TIM Status and Control Register (TSC) TOF — TIM Overflow Flag Bit This read/write flag is set when the TIM counter reaches the modulo value programmed in the TIM counter modulo registers. Clear TOF by reading the TIM status and control register when TOF is set and then writing a 0 to TOF. If another TIM overflow occurs before the clearing sequence is complete, then writing 0 to TOF has no effect. Therefore, a TOF interrupt request cannot be lost due to inadvertent clearing of TOF. Reset clears the TOF bit. Writing a 1 to TOF has no effect. 1 = TIM counter has reached modulo value 0 = TIM counter has not reached modulo value TOIE — TIM Overflow Interrupt Enable Bit This read/write bit enables TIM overflow interrupts when the TOF bit becomes set. Reset clears the TOIE bit. 1 = TIM overflow interrupts enabled 0 = TIM overflow interrupts disabled MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 141 Timer Interface Module (TIM) TSTOP — TIM Stop Bit This read/write bit stops the TIM counter. Counting resumes when TSTOP is cleared. Reset sets the TSTOP bit, stopping the TIM counter until software clears the TSTOP bit. 1 = TIM counter stopped 0 = TIM counter active NOTE: Do not set the TSTOP bit before entering wait mode if the TIM is required to exit wait mode. TRST — TIM Reset Bit Setting this write-only bit resets the TIM counter and the TIM prescaler. Setting TRST has no effect on any other registers. Counting resumes from $0000. TRST is cleared automatically after the TIM counter is reset and always reads as a 0. Reset clears the TRST bit. 1 = Prescaler and TIM counter cleared 0 = No effect NOTE: Setting the TSTOP and TRST bits simultaneously stops the TIM counter at a value of $0000. PS[2:0] — Prescaler Select Bits These read/write bits select either the PTA2/TCLK pin or one of the seven prescaler outputs as the input to the TIM counter as Table 14-2 shows. Reset clears the PS[2:0] bits. Table 14-2. Prescaler Selection PS2 PS1 PS0 TIM Clock Source 0 0 0 Internal bus clock ÷ 1 0 0 1 Internal bus clock ÷ 2 0 1 0 Internal bus clock ÷ 4 0 1 1 Internal bus clock ÷ 8 1 0 0 Internal bus clock ÷ 16 1 0 1 Internal bus clock ÷ 32 1 1 0 Internal bus clock ÷ 64 1 1 1 PTA2/TCLK Data Sheet 142 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Input/Output Registers 14.9.2 TIM Counter Registers The two read-only TIM counter registers contain the high and low bytes of the value in the TIM counter. Reading the high byte (TCNTH) latches the contents of the low byte (TCNTL) into a buffer. Subsequent reads of TCNTH do not affect the latched TCNTL value until TCNTL is read. Reset clears the TIM counter registers. Setting the TIM reset bit (TRST) also clears the TIM counter registers. NOTE: If you read TCNTH during a break interrupt, be sure to unlatch TCNTL by reading TCNTL before exiting the break interrupt. Otherwise, TCNTL retains the value latched during the break. Address: $0021 Read: TCNTH Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 0 0 0 0 0 0 0 0 Write: Reset: Address: $0022 Read: TCNTL Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 Write: Reset: 0 = Unimplemented Figure 14-6. TIM Counter Registers (TCNTH:TCNTL) 14.9.3 TIM Counter Modulo Registers The read/write TIM modulo registers contain the modulo value for the TIM counter. When the TIM counter reaches the modulo value, the overflow flag (TOF) becomes set, and the TIM counter resumes counting from $0000 at the next timer clock. Writing to the high byte (TMODH) inhibits the TOF bit and overflow interrupts until the low byte (TMODL) is written. Reset sets the TIM counter modulo registers. Address: $0023 Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 1 1 1 1 1 1 1 1 Address: $0024 Read: Write: Reset: TMODH TMODL Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 1 1 1 1 1 1 1 1 Figure 14-7. TIM Counter Modulo Registers (TMODH:TMODL) NOTE: Reset the TIM counter before writing to the TIM counter modulo registers. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 143 Timer Interface Module (TIM) 14.9.4 TIM Channel Status and Control Registers Each of the TIM channel status and control registers does the following: • Flags input captures and output compares • Enables input capture and output compare interrupts • Selects input capture, output compare, or PWM operation • Selects high, low, or toggling output on output compare • Selects rising edge, falling edge, or any edge as the active input capture trigger • Selects output toggling on TIM overflow • Selects 0% and 100% PWM duty cycle • Selects buffered or unbuffered output compare/PWM operation Address: $0025 Bit 7 TSC0 6 5 4 3 2 1 Bit 0 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 0 Address: $0028 TSC1 5 4 3 2 1 Bit 0 MS1A ELS1B ELS1A TOV1 CH1MAX 0 0 0 0 0 Read: CH0F Write: 0 Reset: Bit 7 Read: CH1F Write: 0 Reset: 0 6 CH1IE 0 0 0 = Unimplemented Figure 14-8. TIM Channel Status and Control Registers (TSC0:TSC1) CHxF — Channel x Flag Bit When channel x is an input capture channel, this read/write bit is set when an active edge occurs on the channel x pin. When channel x is an output compare channel, CHxF is set when the value in the TIM counter registers matches the value in the TIM channel x registers. Clear CHxF by reading the TIM channel x status and control register with CHxF set and then writing a 0 to CHxF. If another interrupt request occurs before the clearing sequence is complete, then writing a 0 to CHxF has no effect. Therefore, an interrupt request cannot be lost due to inadvertent clearing of CHxF. Reset clears the CHxF bit. Writing a 1 to CHxF has no effect. 1 = Input capture or output compare on channel x 0 = No input capture or output compare on channel x Data Sheet 144 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Input/Output Registers CHxIE — Channel x Interrupt Enable Bit This read/write bit enables TIM CPU interrupt service requests on channel x. Reset clears the CHxIE bit. 1 = Channel x CPU interrupt requests enabled 0 = Channel x CPU interrupt requests disabled MSxB — Mode Select Bit B This read/write bit selects buffered output compare/PWM operation. MSxB exists only in the TIM channel 0 status and control register. Setting MS0B disables the channel 1 status and control register and reverts TCH1 to general-purpose I/O. Reset clears the MSxB bit. 1 = Buffered output compare/PWM operation enabled 0 = Buffered output compare/PWM operation disabled MSxA — Mode Select Bit A When ELSxB:A ≠ 00, this read/write bit selects either input capture operation or unbuffered output compare/PWM operation. See Table 14-3. 1 = Unbuffered output compare/PWM operation 0 = Input capture operation When ELSxB:A = 00, this read/write bit selects the initial output level of the TCHx pin (see Table 14-3). Reset clears the MSxA bit. 1 = Initial output level low 0 = Initial output level high NOTE: Before changing a channel function by writing to the MSxB or MSxA bit, set the TSTOP and TRST bits in the TIM status and control register (TSC). Table 14-3. Mode, Edge, and Level Selection MSxB MSxA ELSxB ELSxA X 0 0 0 Mode Output preset Pin under port control; initial output level high X 1 0 0 Pin under port control; initial output level low 0 0 0 1 Capture on rising edge only 0 0 1 0 0 0 1 1 0 1 0 0 Software compare only 0 1 0 1 Toggle output on compare 0 1 1 0 0 1 1 1 1 X 0 1 1 X 1 0 1 X 1 1 Input capture Capture on falling edge only Capture on rising or falling edge Output compare or PWM Clear output on compare Set output on compare Buffered output compare or buffered PWM MC68HC908QY/QT Family — Rev. 3 MOTOROLA Configuration Toggle output on compare Clear output on compare Set output on compare Data Sheet Timer Interface Module (TIM) 145 Timer Interface Module (TIM) ELSxB and ELSxA — Edge/Level Select Bits When channel x is an input capture channel, these read/write bits control the active edge-sensing logic on channel x. When channel x is an output compare channel, ELSxB and ELSxA control the channel x output behavior when an output compare occurs. When ELSxB and ELSxA are both clear, channel x is not connected to an I/O port, and pin TCHx is available as a general-purpose I/O pin. Table 14-3 shows how ELSxB and ELSxA work. Reset clears the ELSxB and ELSxA bits. NOTE: After initially enabling a TIM channel register for input capture operation and selecting the edge sensitivity, clear CHxF to ignore any erroneous edge detection flags. TOVx — Toggle-On-Overflow Bit When channel x is an output compare channel, this read/write bit controls the behavior of the channel x output when the TIM counter overflows. When channel x is an input capture channel, TOVx has no effect Reset clears the TOVx bit. 1 = Channel x pin toggles on TIM counter overflow. 0 = Channel x pin does not toggle on TIM counter overflow. NOTE: When TOVx is set, a TIM counter overflow takes precedence over a channel x output compare if both occur at the same time. CHxMAX — Channel x Maximum Duty Cycle Bit When the TOVx bit is at a 1, setting the CHxMAX bit forces the duty cycle of buffered and unbuffered PWM signals to 100%. As Figure 14-9 shows, the CHxMAX bit takes effect in the cycle after it is set or cleared. The output stays at the 100% duty cycle level until the cycle after CHxMAX is cleared. OVERFLOW OVERFLOW OVERFLOW OVERFLOW OVERFLOW PERIOD TCHx OUTPUT COMPARE OUTPUT COMPARE OUTPUT COMPARE OUTPUT COMPARE CHxMAX Figure 14-9. CHxMAX Latency Data Sheet 146 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Input/Output Registers 14.9.5 TIM Channel Registers These read/write registers contain the captured TIM counter value of the input capture function or the output compare value of the output compare function. The state of the TIM channel registers after reset is unknown. In input capture mode (MSxB:MSxA = 0:0), reading the high byte of the TIM channel x registers (TCHxH) inhibits input captures until the low byte (TCHxL) is read. In output compare mode (MSxB:MSxA ≠ 0:0), writing to the high byte of the TIM channel x registers (TCHxH) inhibits output compares until the low byte (TCHxL) is written. Address: $0026 Read: Write: TCH0H Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Reset: Indeterminate after reset Address: $0027 Read: Write: TCH0L Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Reset: Indeterminate after reset Address: $0029 Read: Write: TCH1H Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Reset: Indeterminate after reset Address: $02A Read: Write: Reset: TCH1L Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Indeterminate after reset Figure 14-10. TIM Channel Registers (TCH0H/L:TCH1H/L) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Timer Interface Module (TIM) 147 Timer Interface Module (TIM) Data Sheet 148 MC68HC908QY/QT Family — Rev. 3 Timer Interface Module (TIM) MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 15. Development Support 15.1 Introduction This section describes the break module, the monitor read-only memory (MON), and the monitor mode entry methods. 15.2 Break Module (BRK) The break module can generate a break interrupt that stops normal program flow at a defined address to enter a background program. Features include: • Accessible input/output (I/O) registers during the break Interrupt • Central processor unit (CPU) generated break interrupts • Software-generated break interrupts • Computer operating properly (COP) disabling during break interrupts 15.2.1 Functional Description When the internal address bus matches the value written in the break address registers, the break module issues a breakpoint signal (BKPT) to the system integration module (SIM). The SIM then causes the CPU to load the instruction register with a software interrupt instruction (SWI). The program counter vectors to $FFFC and $FFFD ($FEFC and $FEFD in monitor mode). The following events can cause a break interrupt to occur: • A CPU generated address (the address in the program counter) matches the contents of the break address registers. • Software writes a 1 to the BRKA bit in the break status and control register. When a CPU generated address matches the contents of the break address registers, the break interrupt is generated. A return-from-interrupt instruction (RTI) in the break routine ends the break interrupt and returns the microcontroller unit (MCU) to normal operation. Figure 15-2 shows the structure of the break module. Figure 15-3 provides a summary of the I/O registers. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 149 Development Support PTA0/AD0/TCH0/KBI0 CLOCK GENERATOR (OSCILLATOR) PTA PTA2/IRQ/KBI2/TCLK PTA3/RST/KBI3 DDRA PTA1/AD1/TCH1/KBI1 SYSTEM INTEGRATION MODULE PTA4/OSC2/AD2/KBI4 PTA5/OSC1/AD3/KBI5 M68HC08 CPU SINGLE INTERRUPT MODULE BREAK MODULE DDRB PTB PTB0 PTB1 PTB2 PTB3 PTB4 PTB5 PTB6 PTB7 POWER-ON RESET MODULE 8-BIT ADC 128 BYTES RAM MC68HC908QY4 AND MC68HC908QT4 4096 BYTES MC68HC908QY2, MC68HC908QY1, MC68HC908QT2, AND MC68HC908QT1: 1536 BYTES USER FLASH KEYBOARD INTERRUPT MODULE 16-BIT TIMER MODULE COP MODULE VDD POWER SUPPLY MONITOR ROM VSS RST, IRQ: Pins have internal (about 30K Ohms) pull up PTA[0:5]: High current sink and source capability PTA[0:5]: Pins have programmable keyboard interrupt and pull up PTB[0:7]: Not available on 8-pin devices – MC68HC908QT1, MC68HC908QT2, and MC68HC908QT4 ADC: Not available on the MC68HC908QY1 and MC68HC908QT1 Figure 15-1. Block Diagram Highlighting BRK and MON Blocks Data Sheet 150 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Break Module (BRK) ADDRESS BUS[15:8] BREAK ADDRESS REGISTER HIGH 8-BIT COMPARATOR ADDRESS BUS[15:0] BKPT (TO SIM) CONTROL 8-BIT COMPARATOR BREAK ADDRESS REGISTER LOW ADDRESS BUS[7:0] Figure 15-2. Break Module Block Diagram Addr. Register Name $FE00 Read: Break Status Register (BSR) Write: See page 155. Reset: $FE02 Read: Break Auxiliary Register (BRKAR) Write: See page 154. Reset: Read: Break Flag Control Register (BFCR) Write: See page 155. Reset: $FE03 Read: Break Address High Register (BRKH) Write: See page 154. Reset: $FE09 Read: Break Address Low Register (BRKL) Write: See page 154. Reset: $FE0A $FE0B Read: Break Status and Control Register (BRKSCR) Write: See page 153. Reset: Bit 7 6 5 4 3 2 R R R R R R Bit 0 SBSW Note(1) R 0 0 0 0 0 0 0 0 BDCOP 0 0 0 0 0 0 0 0 BCFE R R R R R R R Bit15 Bit14 Bit13 Bit12 Bit11 Bit10 Bit9 Bit8 0 0 0 0 0 0 0 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 BRKE BRKA 0 0 0 0 0 0 0 0 R = Reserved 0 = Unimplemented 1. Writing a 0 clears SBSW. 1 Figure 15-3. Break I/O Register Summary MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 151 Development Support When the internal address bus matches the value written in the break address registers or when software writes a 1 to the BRKA bit in the break status and control register, the CPU starts a break interrupt by: • Loading the instruction register with the SWI instruction • Loading the program counter with $FFFC and $FFFD ($FEFC and $FEFD in monitor mode) The break interrupt timing is: • When a break address is placed at the address of the instruction opcode, the instruction is not executed until after completion of the break interrupt routine. • When a break address is placed at an address of an instruction operand, the instruction is executed before the break interrupt. • When software writes a 1 to the BRKA bit, the break interrupt occurs just before the next instruction is executed. By updating a break address and clearing the BRKA bit in a break interrupt routine, a break interrupt can be generated continuously. CAUTION: A break address should be placed at the address of the instruction opcode. When software does not change the break address and clears the BRKA bit in the first break interrupt routine, the next break interrupt will not be generated after exiting the interrupt routine even when the internal address bus matches the value written in the break address registers. 15.2.1.1 Flag Protection During Break Interrupts The system integration module (SIM) controls whether or not module status bits can be cleared during the break state. The BCFE bit in the break flag control register (BFCR) enables software to clear status bits during the break state. See 13.8.2 Break Flag Control Register and the Break Interrupts subsection for each module. 15.2.1.2 TIM During Break Interrupts A break interrupt stops the timer counter. 15.2.1.3 COP During Break Interrupts The COP is disabled during a break interrupt with monitor mode when BDCOP bit is set in break auxiliary register (BRKAR). Data Sheet 152 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Break Module (BRK) 15.2.2 Break Module Registers These registers control and monitor operation of the break module: • Break status and control register (BRKSCR) • Break address register high (BRKH) • Break address register low (BRKL) • Break status register (BSR) • Break flag control register (BFCR) 15.2.2.1 Break Status and Control Register The break status and control register (BRKSCR) contains break module enable and status bits. Address: $FE0B Read: Write: Reset: Bit 7 6 BRKE BRKA 0 0 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 = Unimplemented Figure 15-4. Break Status and Control Register (BRKSCR) BRKE — Break Enable Bit This read/write bit enables breaks on break address register matches. Clear BRKE by writing a 0 to bit 7. Reset clears the BRKE bit. 1 = Breaks enabled on 16-bit address match 0 = Breaks disabled BRKA — Break Active Bit This read/write status and control bit is set when a break address match occurs. Writing a 1 to BRKA generates a break interrupt. Clear BRKA by writing a 0 to it before exiting the break routine. Reset clears the BRKA bit. 1 = Break address match 0 = No break address match MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 153 Development Support 15.2.2.2 Break Address Registers The break address registers (BRKH and BRKL) contain the high and low bytes of the desired breakpoint address. Reset clears the break address registers. Address: $FE09 Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 Bit 14 Bit 13 Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 0 0 0 0 0 0 0 0 Figure 15-5. Break Address Register High (BRKH) Address: $FE0A Read: Write: Reset: Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 0 0 0 0 0 0 0 Figure 15-6. Break Address Register Low (BRKL) 15.2.2.3 Break Auxiliary Register The break auxiliary register (BRKAR) contains a bit that enables software to disable the COP while the MCU is in a state of break interrupt with monitor mode. Address: $FE02 Read: Bit 7 6 5 4 3 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Write: Reset: Bit 0 BDCOP 0 = Unimplemented Figure 15-7. Break Auxiliary Register (BRKAR) BDCOP — Break Disable COP Bit This read/write bit disables the COP during a break interrupt. Reset clears the BDCOP bit. 1 = COP disabled during break interrupt 0 = COP enabled during break interrupt Data Sheet 154 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Break Module (BRK) 15.2.2.4 Break Status Register The break status register (BSR) contains a flag to indicate that a break caused an exit from wait mode. This register is only used in emulation mode. Address: $FE00 Read: Write: Bit 7 6 5 4 3 2 R R R R R R Reset: 1 SBSW Note(1) Bit 0 R 0 R = Reserved 1. Writing a 0 clears SBSW. Figure 15-8. Break Status Register (BSR) SBSW — SIM Break Stop/Wait SBSW can be read within the break state SWI routine. The user can modify the return address on the stack by subtracting one from it. 1 = Wait mode was exited by break interrupt 0 = Wait mode was not exited by break interrupt 15.2.2.5 Break Flag Control Register The break control register (BFCR) contains a bit that enables software to clear status bits while the MCU is in a break state. Address: $FE03 Bit 7 6 5 4 3 2 1 Bit 0 BCFE R R R R R R R Read: Write: Reset: 0 R = Reserved Figure 15-9. Break Flag Control Register (BFCR) BCFE — Break Clear Flag Enable Bit This read/write bit enables software to clear status bits by accessing status registers while the MCU is in a break state. To clear status bits during the break state, the BCFE bit must be set. 1 = Status bits clearable during break 0 = Status bits not clearable during break MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 155 Development Support 15.2.3 Low-Power Modes The WAIT and STOP instructions put the MCU in low power- consumption standby modes. If enabled, the break module will remain enabled in wait and stop modes. However, since the internal address bus does not increment in these modes, a break interrupt will never be triggered. 15.3 Monitor Module (MON) This subsection describes the monitor module (MON) and the monitor mode entry methods. The monitor allows debugging and programming of the microcontroller unit (MCU) through a single-wire interface with a host computer. Monitor mode entry can be achieved without use of the higher test voltage, VTST, as long as vector addresses $FFFE and $FFFF are blank, thus reducing the hardware requirements for in-circuit programming. Features include: • Normal user-mode pin functionality on most pins • One pin dedicated to serial communication between MCU and host computer • Standard non-return-to-zero (NRZ) communication with host computer • Execution of code in random-access memory (RAM) or FLASH • FLASH memory security feature(1) • FLASH memory programming interface • Use of external 9.8304 MHz oscillator to generate internal frequency of 2.4576 MHz • Simple internal oscillator mode of operation (no external clock or high voltage) • Monitor mode entry without high voltage, VTST, if reset vector is blank ($FFFE and $FFFF contain $FF) • Standard monitor mode entry if high voltage is applied to IRQ 15.3.1 Functional Description Figure 15-10 shows a simplified diagram of monitor mode entry. The monitor module receives and executes commands from a host computer. Figure 15-11, Figure 15-12, and Figure 15-13 show example circuits used to enter monitor mode and communicate with a host computer via a standard RS-232 interface. 1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users. Data Sheet 156 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Monitor Module (MON) POR RESET NO CONDITIONS FROM Table 15-1 PTA0 = 1, RESET VECTOR BLANK? IRQ = VTST? YES PTA0 = 1, PTA1 = 1, AND PTA4 = 0? NO NO YES YES FORCED MONITOR MODE NORMAL USER MODE NORMAL MONITOR MODE INVALID USER MODE HOST SENDS 8 SECURITY BYTES IS RESET POR? YES NO YES ARE ALL SECURITY BYTES CORRECT? ENABLE FLASH NO DISABLE FLASH MONITOR MODE ENTRY DEBUGGING AND FLASH PROGRAMMING (IF FLASH IS ENABLED) EXECUTE MONITOR CODE YES DOES RESET OCCUR? NO Figure 15-10. Simplified Monitor Mode Entry Flowchart MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 157 Development Support Simple monitor commands can access any memory address. In monitor mode, the MCU can execute code downloaded into RAM by a host computer while most MCU pins retain normal operating mode functions. All communication between the host computer and the MCU is through the PTA0 pin. A level-shifting and multiplexing interface is required between PTA0 and the host computer. PTA0 is used in a wired-OR configuration and requires a pullup resistor. The monitor code has been updated from previous versions of the monitor code to allow enabling the internal oscillator to generate the internal clock. This addition, which is enabled when IRQ is held low out of reset, is intended to support serial communication/programming at 9600 baud in monitor mode by using the internal oscillator, and the internal oscillator user trim value OSCTRIM (FLASH location $FFC0, if programmed) to generate the desired internal frequency (3.2 MHz). Since this feature is enabled only when IRQ is held low out of reset, it cannot be used when the reset vector is programmed (i.e., the value is not $FFFF) because entry into monitor mode in this case requires VTST on IRQ. The IRQ pin must remain low during this monitor session in order to maintain communication. Table 15-1 shows the pin conditions for entering monitor mode. As specified in the table, monitor mode may be entered after a power-on reset (POR) and will allow communication at 9600 baud provided one of the following sets of conditions is met: • If $FFFE and $FFFF do not contain $FF (programmed state): – The external clock is 9.8304 MHz – IRQ = VTST • If $FFFE and $FFFF contain $FF (erased state): – The external clock is 9.8304 MHz – IRQ = VDD (this can be implemented through the internal IRQ pullup) • If $FFFE and $FFFF contain $FF (erased state): – IRQ = VSS (internal oscillator is selected, no external clock required) The rising edge of the internal RST signal latches the monitor mode. Once monitor mode is latched, the values on PTA1 and PTA4 pins can be changed. Once out of reset, the MCU waits for the host to send eight security bytes (see 15.3.2 Security). After the security bytes, the MCU sends a break signal (10 consecutive logic 0s) to the host, indicating that it is ready to receive a command. Data Sheet 158 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Monitor Module (MON) VDD VDD 10 kΩ* VDD 0.1 µF RST (PTA3) MAX232 1 1 µF + VDD C1+ VTST 15 C1– 1 µF 1 kΩ 1 µF 1 µF 9.1 V 3 7 10 8 9 10 kΩ* 10 kΩ + PTA4 74HC125 5 6 DB9 2 IRQ (PTA2) VDD V– 6 5 C2– 10 kΩ* PTA1 V+ 2 C2+ + VDD 1 µF + 4 OSC1 (PTA5) 16 + 3 9.8304 MHz CLOCK 74HC125 3 2 PTA0 4 VSS 1 5 * Value not critical Figure 15-11. Monitor Mode Circuit (External Clock, with High Voltage) VDD N.C. RST (PTA3) VDD 0.1 µF MAX232 1 1 µF + 16 9.8304 MHz CLOCK + 3 4 1 µF C1+ VDD C1– C2+ + 5 C2– 1 µF 15 OSC1 (PTA5) 1 µF + 10 kΩ* V+ 2 VDD 10 kΩ 74HC125 5 6 + DB9 2 7 10 3 8 9 2 74HC125 3 N.C. PTA4 N.C. IRQ (PTA2) V– 6 1 µF PTA1 PTA0 4 VSS 1 5 * Value not critical Figure 15-12. Monitor Mode Circuit (External Clock, No High Voltage) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 159 Development Support VDD N.C. RST (PTA3) VDD 0.1 µF MAX232 1 1 µF + 4 C1– C2+ + 5 C2– N.C. 1 µF 15 3 IRQ (PTA2) 1 µF + PTA1 N.C. PTA4 N.C. 10 kΩ* V+ 2 VDD V– 6 1 µF 10 kΩ 74HC125 5 6 + DB9 2 OSC1 (PTA5) 16 + 3 1 µF C1+ VDD 7 10 8 9 74HC125 3 2 PTA0 VSS 4 1 5 * Value not critical Figure 15-13. Monitor Mode Circuit (Internal Clock, No High Voltage) 15.3.1.1 Normal Monitor Mode RST and OSC1 functions will be active on the PTA3 and PTA5 pins respectively as long as VTST is applied to the IRQ pin. If the IRQ pin is lowered (no longer VTST) then the chip will still be operating in monitor mode, but the pin functions will be determined by the settings in the configuration registers (see Section 5. Configuration Register (CONFIG)) when VTST was lowered. With VTST lowered, the BIH and BIL instructions will read the IRQ pin state only if IRQEN is set in the CONFIG2 register. If monitor mode was entered with VTST on IRQ, then the COP is disabled as long as VTST is applied to IRQ. Data Sheet 160 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Monitor Module (MON) Table 15-1. Monitor Mode Signal Requirements and Options Mode Serial CommuniRST Reset IRQ cation (PTA2) (PTA3) Vector PTA0 Mode Selection Communication Speed COP Comments External Bus Clock Frequency PTA1 PTA4 Baud Rate VTST VDD X 1 1 0 Disabled 9.8304 MHz 2.4576 MHz 9600 Provide external clock at OSC1. VDD X $FFFF (blank) 1 X X Disabled 9.8304 MHz 2.4576 MHz 9600 Provide external clock at OSC1. VSS X $FFFF (blank) 1 X X Disabled X 3.2 MHz (Trimmed) 9600 Internal clock is active. User X X Not $FFFF X X X Enabled X X X MON08 Function [Pin No.] VTST [6] RST [4] — COM [8] — OSC1 [13] — — Normal Monitor Forced Monitor MOD0 MOD1 [12] [10] 1. PTA0 must have a pullup resistor to VDD in monitor mode. 2. Communication speed in the table is an example to obtain a baud rate of 9600. Baud rate using external oscillator is bus frequency / 256 and baud rate using internal oscillator is bus frequency / 335. 3. External clock is a 9.8304 MHz oscillator on OSC1. 4. X = don’t care 5. MON08 pin refers to P&E Microcomputer Systems’ MON08-Cyclone 2 by 8-pin connector. NC 1 2 GND NC 3 4 RST NC 5 6 IRQ NC 7 8 PTA0 NC 9 10 PTA4 NC 11 12 PTA1 OSC1 13 14 NC VDD 15 16 NC MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 161 Development Support 15.3.1.2 Forced Monitor Mode If entering monitor mode without high voltage on IRQ, then startup port pin requirements and conditions, (PTA1/PTA4) are not in effect. This is to reduce circuit requirements when performing in-circuit programming. NOTE: If the reset vector is blank and monitor mode is entered, the chip will see an additional reset cycle after the initial power-on reset (POR). Once the reset vector has been programmed, the traditional method of applying a voltage, VTST, to IRQ must be used to enter monitor mode. If monitor mode was entered as a result of the reset vector being blank, the COP is always disabled regardless of the state of IRQ. If the voltage applied to the IRQ is less than VTST, the MCU will come out of reset in user mode. Internal circuitry monitors the reset vector fetches and will assert an internal reset if it detects that the reset vectors are erased ($FF). When the MCU comes out of reset, it is forced into monitor mode without requiring high voltage on the IRQ pin. Once out of reset, the monitor code is initially executing with the internal clock at its default frequency. If IRQ is held high, all pins will default to regular input port functions except for PTA0 and PTA5 which will operate as a serial communication port and OSC1 input respectively (refer to Figure 15-11). That will allow the clock to be driven from an external source through OSC1 pin. If IRQ is held low, all pins will default to regular input port function except for PTA0 which will operate as serial communication port. Refer to Figure 15-12. Regardless of the state of the IRQ pin, it will not function as a port input pin in monitor mode. Bit 2 of the Port A data register will always read 0. The BIH and BIL instructions will behave as if the IRQ pin is enabled, regardless of the settings in the configuration register. See Section 5. Configuration Register (CONFIG). The COP module is disabled in forced monitor mode. Any reset other than a power-on reset (POR) will automatically force the MCU to come back to the forced monitor mode. 15.3.1.3 Monitor Vectors In monitor mode, the MCU uses different vectors for reset, SWI (software interrupt), and break interrupt than those for user mode. The alternate vectors are in the $FE page instead of the $FF page and allow code execution from the internal monitor firmware instead of user code. NOTE: Exiting monitor mode after it has been initiated by having a blank reset vector requires a power-on reset (POR). Pulling RST (when RST pin available) low will not exit monitor mode in this situation. Data Sheet 162 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Monitor Module (MON) Table 15-2 summarizes the differences between user mode and monitor mode regarding vectors. Table 15-2. Mode Difference Functions Modes Reset Vector High Reset Vector Low Break Vector High Break Vector Low SWI Vector High SWI Vector Low User $FFFE $FFFF $FFFC $FFFD $FFFC $FFFD Monitor $FEFE $FEFF $FEFC $FEFD $FEFC $FEFD 15.3.1.4 Data Format Communication with the monitor ROM is in standard non-return-to-zero (NRZ) mark/space data format. Transmit and receive baud rates must be identical. START BIT BIT 0 BIT 1 BIT 2 BIT 3 BIT 4 BIT 5 BIT 6 BIT 7 STOP BIT NEXT START BIT Figure 15-14. Monitor Data Format 15.3.1.5 Break Signal A start bit (logic 0) followed by nine logic 0 bits is a break signal. When the monitor receives a break signal, it drives the PTA0 pin high for the duration of two bits and then echoes back the break signal. MISSING STOP BIT 2-STOP BIT DELAY BEFORE ZERO ECHO 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 Figure 15-15. Break Transaction 15.3.1.6 Baud Rate The monitor communication baud rate is controlled by the frequency of the external or internal oscillator and the state of the appropriate pins as shown in Table 15-1. Table 15-1 also lists the bus frequencies to achieve standard baud rates. The effective baud rate is the bus frequency divided by 256 when using an external oscillator. When using the internal oscillator in forced monitor mode, the effective baud rate is the bus frequency divided by 335. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 163 Development Support 15.3.1.7 Commands The monitor ROM firmware uses these commands: • READ (read memory) • WRITE (write memory) • IREAD (indexed read) • IWRITE (indexed write) • READSP (read stack pointer) • RUN (run user program) The monitor ROM firmware echoes each received byte back to the PTA0 pin for error checking. An 11-bit delay at the end of each command allows the host to send a break character to cancel the command. A delay of two bit times occurs before each echo and before READ, IREAD, or READSP data is returned. The data returned by a read command appears after the echo of the last byte of the command. NOTE: Wait one bit time after each echo before sending the next byte. FROM HOST 4 ADDRESS HIGH READ READ 4 1 ADDRESS HIGH 1 ECHO Notes: 1 = Echo delay, 2 bit times 2 = Data return delay, 2 bit times ADDRESS LOW 4 ADDRESS LOW DATA 1 3, 2 4 RETURN 3 = Cancel command delay, 11 bit times 4 = Wait 1 bit time before sending next byte. Figure 15-16. Read Transaction FROM HOST 3 ADDRESS HIGH WRITE WRITE 1 3 ADDRESS HIGH 1 ADDRESS LOW 3 ADDRESS LOW 1 DATA 3 DATA 1 2, 3 ECHO Notes: 1 = Echo delay, 2 bit times 2 = Cancel command delay, 11 bit times 3 = Wait 1 bit time before sending next byte. Figure 15-17. Write Transaction A brief description of each monitor mode command is given in Table 15-3 through Table 15-8. Data Sheet 164 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Monitor Module (MON) Table 15-3. READ (Read Memory) Command Description Read byte from memory Operand 2-byte address in high-byte:low-byte order Data Returned Returns contents of specified address Opcode $4A Command Sequence SENT TO MONITOR ADDRESS ADDRESS ADDRESS HIGH HIGH LOW READ READ ADDRESS LOW DATA ECHO RETURN Table 15-4. WRITE (Write Memory) Command Description Operand Data Returned Opcode Write byte to memory 2-byte address in high-byte:low-byte order; low byte followed by data byte None $49 Command Sequence FROM HOST WRITE WRITE ADDRESS HIGH ADDRESS HIGH ADDRESS LOW ADDRESS LOW DATA DATA ECHO Table 15-5. IREAD (Indexed Read) Command Description Operand Data Returned Opcode Read next 2 bytes in memory from last address accessed 2-byte address in high byte:low byte order Returns contents of next two addresses $1A Command Sequence FROM HOST IREAD IREAD ECHO MC68HC908QY/QT Family — Rev. 3 MOTOROLA DATA DATA RETURN Data Sheet Development Support 165 Development Support Table 15-6. IWRITE (Indexed Write) Command Description Operand Data Returned Opcode Write to last address accessed + 1 Single data byte None $19 Command Sequence FROM HOST IWRITE IWRITE DATA DATA ECHO A sequence of IREAD or IWRITE commands can access a block of memory sequentially over the full 64-Kbyte memory map. Table 15-7. READSP (Read Stack Pointer) Command Description Operand Data Returned Opcode Reads stack pointer None Returns incremented stack pointer value (SP + 1) in high-byte:low-byte order $0C Command Sequence FROM HOST READSP SP HIGH READSP SP LOW ECHO RETURN Table 15-8. RUN (Run User Program) Command Description Executes PULH and RTI instructions Operand None Data Returned None Opcode $28 Command Sequence FROM HOST RUN RUN ECHO Data Sheet 166 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Development Support Monitor Module (MON) The MCU executes the SWI and PSHH instructions when it enters monitor mode. The RUN command tells the MCU to execute the PULH and RTI instructions. Before sending the RUN command, the host can modify the stacked CPU registers to prepare to run the host program. The READSP command returns the incremented stack pointer value, SP + 1. The high and low bytes of the program counter are at addresses SP + 5 and SP + 6. SP HIGH BYTE OF INDEX REGISTER SP + 1 CONDITION CODE REGISTER SP + 2 ACCUMULATOR SP + 3 LOW BYTE OF INDEX REGISTER SP + 4 HIGH BYTE OF PROGRAM COUNTER SP + 5 LOW BYTE OF PROGRAM COUNTER SP + 6 SP + 7 Figure 15-18. Stack Pointer at Monitor Mode Entry 15.3.2 Security A security feature discourages unauthorized reading of FLASH locations while in monitor mode. The host can bypass the security feature at monitor mode entry by sending eight security bytes that match the bytes at locations $FFF6–$FFFD. Locations $FFF6–$FFFD contain user-defined data. NOTE: Do not leave locations $FFF6–$FFFD blank. For security reasons, program locations $FFF6–$FFFD even if they are not used for vectors. During monitor mode entry, the MCU waits after the power-on reset for the host to send the eight security bytes on pin PTA0. If the received bytes match those at locations $FFF6–$FFFD, the host bypasses the security feature and can read all FLASH locations and execute code from FLASH. Security remains bypassed until a power-on reset occurs. If the reset was not a power-on reset, security remains bypassed and security code entry is not required. See Figure 15-19. Upon power-on reset, if the received bytes of the security code do not match the data at locations $FFF6–$FFFD, the host fails to bypass the security feature. The MCU remains in monitor mode, but reading a FLASH location returns an invalid value and trying to execute code from FLASH causes an illegal address reset. After receiving the eight security bytes from the host, the MCU transmits a break character, signifying that it is ready to receive a command. NOTE: The MCU does not transmit a break character until after the host sends the eight security bytes. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Development Support 167 Development Support VDD 4096 + 32 CGMXCLK CYCLES COMMAND BYTE 8 BYTE 2 BYTE 1 RST FROM HOST PA0 4 BREAK 2 1 COMMAND ECHO 1 BYTE 8 ECHO Notes: 1 = Echo delay, 2 bit times 2 = Data return delay, 2 bit times 4 = Wait 1 bit time before sending next byte. 1 BYTE 2 ECHO FROM MCU 4 1 BYTE 1 ECHO 256 BUS CYCLES (MINIMUM) Figure 15-19. Monitor Mode Entry Timing To determine whether the security code entered is correct, check to see if bit 6 of RAM address $80 is set. If it is, then the correct security code has been entered and FLASH can be accessed. If the security sequence fails, the device should be reset by a power-on reset and brought up in monitor mode to attempt another entry. After failing the security sequence, the FLASH module can also be mass erased by executing an erase routine that was downloaded into internal RAM. The mass erase operation clears the security code locations so that all eight security bytes become $FF (blank). Data Sheet 168 MC68HC908QY/QT Family — Rev. 3 Development Support MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 16. Electrical Specifications 16.1 Introduction This section contains electrical and timing specifications. 16.2 Absolute Maximum Ratings Maximum ratings are the extreme limits to which the microcontroller unit (MCU) can be exposed without permanently damaging it. NOTE: This device is not guaranteed to operate properly at the maximum ratings. Refer to 16.5 5-V DC Electrical Characteristics and 16.9 3-V DC Electrical Characteristics for guaranteed operating conditions. Characteristic(1) Symbol Value Unit Supply voltage VDD – 0.3 to + 6.0 V Input voltage VIN VSS – 0.3 to VDD + 0.3 V VTST VSS – 0.3 to + 9.1 V I ±15 mA IPTA0—IPTA5 ±25 mA Storage temperature TSTG – 55 to + 150 °C Maximum current out of VSS IMVSS 100 mA Maximum current into VDD IMVDD 100 mA Mode entry voltage, IRQ pin Maximum current per pin excluding PTA0–PTA5, VDD, and VSS Maximum current for pins PTA0–PTA5 1. Voltages references to VSS. NOTE: This device contains circuitry to protect the inputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage higher than maximum-rated voltages to this high-impedance circuit. For proper operation, it is recommended that VIN and VOUT be constrained to the range VSS ≤ (VIN or VOUT) ≤ VDD. Reliability of operation is enhanced if unused inputs are connected to an appropriate logic voltage level (for example, either VSS or VDD.) MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 169 Electrical Specifications 16.3 Functional Operating Range Characteristic Operating temperature range Operating voltage range Symbol Value Unit Temp. Code TA – 40 to +125 – 40 to +105 – 40 to + 85 °C M V C VDD 2.7 to 5.5 V — 16.4 Thermal Characteristics Characteristic Symbol Value Unit Thermal resistance 8-pin PDIP 8-pin SOIC 8-pin DFN 16-pin PDIP 16-pin SOIC 16-pin TSSOP θJA I/O pin power dissipation PI/O User determined W Power dissipation(1) PD PD = (IDD x VDD) + PI/O = K/(TJ + 273°C) W Constant(2) K Average junction temperature Maximum junction temperature 105 142 173 76 90 133 PD x (TA + 273°C) °C/W + PD2 x θJA W/°C TJ TA + (PD x θJA) °C TJM 150 °C 1. Power dissipation is a function of temperature. 2. K constant unique to the device. K can be determined for a known TA and measured PD. With this value of K, PD and TJ can be determined for any value of TA. Data Sheet 170 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications 5-V DC Electrical Characteristics 16.5 5-V DC Electrical Characteristics Characteristic(1) Symbol Min Typ(2) Max VDD – 0.4 VDD – 1.5 VDD – 0.8 — — — — — — — — 50 — — — — — — 0.4 1.5 0.8 Unit Output high voltage ILoad = –2.0 mA, all I/O pins ILoad = –10.0 mA, all I/O pins ILoad = –15.0 mA, PTA0, PTA1, PTA3–PTA5 only VOH Maximum combined IOH (all I/O pins) IOHT Output low voltage ILoad = 1.6 mA, all I/O pins ILoad = 10.0 mA, all I/O pins ILoad = 15.0 mA, PTA0, PTA1, PTA3–PTA5 only VOL Maximum combined IOL (all I/O pins) IOLT — — 50 mA Input high voltage PTA0–PTA5, PTB0–PTB7 VIH 0.7 x VDD — VDD V Input low voltage PTA0–PTA5, PTB0–PTB7 VIL VSS — 0.3 x VDD V VHYS 0.06 x VDD — — V IINJ –2 — +2 mA IINJTOT –25 — +25 mA IIL –1 ±0.1 +1 µA Capacitance Ports (as input) Ports (as input) CIN COUT — — — — 12 8 pF POR rearm voltage(3) VPOR 0 — 100 mV POR rise time ramp rate(4) RPOR 0.035 — — V/ms Monitor mode entry voltage VTST VDD + 2.5 — 9.1 V Pullup resistors(5) PTA0–PTA5, PTB0–PTB7 RPU 16 26 36 kΩ Low-voltage inhibit reset, trip falling voltage VTRIPF 3.90 4.20 4.50 V Low-voltage inhibit reset, trip rising voltage VTRIPR 4.00 4.30 4.60 V Low-voltage inhibit reset/recover hysteresis VHYS — 100 — mV Input hysteresis DC injection current, all ports Total dc current injection (sum of all I/O) Ports Hi-Z leakage current V mA V 1. VDD = 4.5 to 5.5 Vdc, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted. 2. Typical values reflect average measurements at midpoint of voltage range, 25°C only. 3. Maximum is highest voltage that POR is guaranteed. 4. If minimum VDD is not reached before the internal POR reset is released, the LVI will hold the part in reset until minimum VDD is reached. 5. RPU is measured at VDD = 5.0 V. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 171 Electrical Specifications 16.6 Typical 5-V Output Drive Characteristics 2.0 VDD-VOH (V) 1.5 5V PTA 1.0 5V PTB 0.5 0.0 0 -5 -10 -15 -20 -25 -30 -35 IOH (mA) Figure 16-1. Typical 5-Volt Output High Voltage versus Output High Current (25°C) 2.0 VOL (V) 1.5 5V PTA 5V PTB 1.0 0.5 0.0 0 5 10 15 20 25 30 35 IOL (mA) Figure 16-2. Typical 5-Volt Output Low Voltage versus Output Low Current (25°C) Data Sheet 172 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications 5-V Control Timing 16.7 5-V Control Timing Characteristic(1) Symbol Min Max Unit Internal operating frequency fOP (fBus) — 8 MHz Internal clock period (1/fOP) tcyc 125 — ns RST input pulse width low tRL 100 — ns IRQ interrupt pulse width low (edge-triggered) tILIH 100 — ns — tcyc tILIL IRQ interrupt pulse period (2) Note 1. VDD = 4.5 to 5.5 Vdc, VSS = 0 Vdc, TA = TL to TH; timing shown with respect to 20% VDD and 70% VSS, unless otherwise noted. 2. The minimum period is the number of cycles it takes to execute the interrupt service routine plus 1 tcyc. tRL RST tILIL tILIH IRQ Figure 16-3. RST and IRQ Timing MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 173 Electrical Specifications 16.8 5-V Oscillator Characteristics Characteristic Symbol Min Typ Max Unit fINTCLK — 12.8 — MHz fOSCXCLK 1 — 24 MHz fRCCLK 2 — 12 MHz fOSCXCLK dc — 32 MHz Crystal load capacitance(3) CL — 20 — pF Crystal fixed capacitance(3) C1 — 2 x CL — — C2 — 2 x CL — — RB 1 10 — MΩ Internal oscillator frequency (1) Crystal frequency, XTALCLK(1) External RC oscillator frequency, RCCLK(1) External clock reference frequency Crystal tuning (1) (2) capacitance(3) Feedback bias resistor REXT RC oscillator external resistor Crystal series damping resistor fOSCXCLK = 1 MHz fOSCXCLK = 4 MHz fOSCXCLK = > 8 MHz See Figure 16-4 — — — RS 20 10 0 — — — — kΩ 1. Bus frequency, fOP, is oscillator frequency divided by 4. 2. No more than 10% duty cycle deviation from 50%. 3. Consult crystal vendor data sheet. 14 5 V 25°C RC FREQUENCY, f RCCLK (MHz) 12 10 8 6 4 2 0 0 10 20 30 40 50 60 R EXT (k Ω) Figure 16-4. RC versus Frequency (5 Volts @ 25°C) Data Sheet 174 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications 3-V DC Electrical Characteristics 16.9 3-V DC Electrical Characteristics Characteristic(1) Symbol Min Typ(2) Max VDD – 0.3 VDD – 1.0 VDD – 0.8 — — — — — — — — 50 — — — — — — 0.3 1.0 0.8 Unit Output high voltage ILoad = –0.6 mA, all I/O pins ILoad = –4.0 mA, all I/O pins ILoad = –10.0 mA, PTA0, PTA1, PTA3–PTA5 only VOH Maximum combined IOH (all I/O pins) IOHT Output low voltage ILoad = 0.5 mA, all I/O pins ILoad = 6.0 mA, all I/O pins ILoad = 10.0 mA, PTA0, PTA1, PTA3–PTA5 only VOL Maximum combined IOL (all I/O pins) IOLT — — 50 mA Input high voltage PTA0–PTA5, PTB0–PTB7 VIH 0.7 x VDD — VDD V Input low voltage PTA0–PTA5, PTB0–PTB7 VIL VSS — 0.3 x VDD V VHYS 0.06 x VDD — — V IINJ –2 — +2 mA IINJTOT –25 — +25 mA IIL –1 ±0.1 +1 µA Capacitance Ports (as input) Ports (as input) CIN COUT — — — — 12 8 pF POR rearm voltage(3) VPOR 0 — 100 mV POR rise time ramp rate(4) RPOR 0.035 — — V/ms Monitor mode entry voltage VTST VDD + 2.5 — VDD + 4.0 V Pullup resistors(5) PTA0–PTA5, PTB0–PTB7 RPU 16 26 36 kΩ Low-voltage inhibit reset, trip falling voltage VTRIPF 2.40 2.55 2.70 V Low-voltage inhibit reset, trip rising voltage VTRIPR 2.50 2.65 2.80 V Low-voltage inhibit reset/recover hysteresis VHYS — 60 — mV Input hysteresis DC injection current, all ports Total dc current injection (sum of all I/O) Ports Hi-Z leakage current V mA V 1. VDD = 2.7 to 3.3 Vdc, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted. 2. Typical values reflect average measurements at midpoint of voltage range, 25°C only. 3. Maximum is highest voltage that POR is guaranteed. 4. If minimum VDD is not reached before the internal POR reset is released, the LVI will hold the part in reset until minimum VDD is reached. 5. RPU are measured at VDD = 3.0 V MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 175 Electrical Specifications 16.10 Typical 3.0-V Output Drive Characteristics 1.5 VDD-VOH (V) 1.0 3V PTA 3V PTB 0.5 0.0 0 -5 -10 -15 -20 IOH (mA) Figure 16-5. Typical 3-Volt Output High Voltage versus Output High Current (25°C) 1.5 VOL (V) 1.0 3V PTA 3V PTB 0.5 0.0 0 5 10 15 20 IOL (mA) Figure 16-6. Typical 3-Volt Output Low Voltage versus Output Low Current (25°C) Data Sheet 176 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications 3-V Control Timing 16.11 3-V Control Timing Characteristic(1) Symbol Min Max Unit Internal operating frequency fOP (fBus) — 4 MHz Internal clock period (1/fOP) tcyc 250 — ns RST input pulse width low tRL 200 — ns IRQ interrupt pulse width low (edge-triggered) tILIH 200 — ns — tcyc tILIL IRQ interrupt pulse period (2) Note 1. VDD = 2.7 to 3.3 Vdc, VSS = 0 Vdc, TA = TL to TH; timing shown with respect to 20% VDD and 70% VDD, unless otherwise noted. 2. The minimum period is the number of cycles it takes to execute the interrupt service routine plus 1 tcyc. tRL RST tILIL tILIH IRQ Figure 16-7. RST and IRQ Timing MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 177 Electrical Specifications 16.12 3-V Oscillator Characteristics Characteristic Symbol Min Typ Max Unit fINTCLK — 12.8 — MHz fOSCXCLK 1 — 16 MHz fRCCLK 2 — 12 MHz fOSCXCLK dc — 16 MHz Crystal load capacitance(3) CL — 20 — pF Crystal fixed capacitance(3) C1 — 2 x CL — — C2 — 2 x CL — — RB 1 10 — MΩ Internal oscillator frequency (1) Crystal frequency, XTALCLK(1) External RC oscillator frequency, RCCLK (1) External clock reference frequency Crystal tuning (1) (2) capacitance(3) Feedback bias resistor REXT RC oscillator external resistor Crystal series damping resistor fOSCXCLK = 1 MHz fOSCXCLK = 4 MHz fOSCXCLK = > 8 MHz See Figure 16-8 — — — RS 10 5 0 — — — — kΩ 1. Bus frequency, fOP, is oscillator frequency divided by 4. 2. No more than 10% duty cycle deviation from 50% 3. Consult crystal vendor data sheet 12 3 V 25°C RC FREQUENCY, f RCCLK (MHz) 10 8 6 4 2 0 0 10 20 30 40 50 60 R EXT (k Ω) Figure 16-8. RC versus Frequency (3 Volts @ 25°C) Data Sheet 178 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications Supply Current Characteristics 16.13 Supply Current Characteristics Voltage Bus Frequency (MHz) Symbol Typ(2) Max Unit Run Mode VDD supply current(3) 5.0 3.0 3.2 3.2 RIDD 6.0 2.5 7.0 3.2 mA Wait Mode VDD supply current(4) 5.0 3.0 3.2 3.2 WIDD 1.0 0.67 1.5 1.0 mA mA 0.04 — — 7 125 1.0 2.0 5.0 — — 0.02 — — 5 100 0.5 1.0 4.0 — — Characteristic(1) Stop Mode VDD supply current(5) –40 to 85°C –40 to 105°C –40 to 125°C 25°C with auto wakeup enabled Incremental current with LVI enabled at 25°C Stop Mode VDD supply current(5) –40 to 85°C –40 to 105°C –40 to 125°C 25°C with auto wakeup enabled Incremental current with LVI enabled at 25°C 5.0 3.0 SIDD SIDD µA µA 1. VSS = 0 Vdc, TA = TL to TH, unless otherwise noted. 2. Typical values reflect average measurements at 25°C only. 3. Run (operating) IDD measured using trimmed internal oscillator, ADC off, all other modules enabled. All pins configured as inputs and tied to 0.2 V from rail. 4. Wait IDD measured using trimmed internal oscillator, ADC off, all other modules enabled. All pins configured as inputs and tied to 0.2 V from rail. 5. Stop IDD measured with all pins tied to 0.2 V or less from rail. No dc loads. On the 8-pin versions, port B is configured as inputs with pullups enabled. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 179 Electrical Specifications 14 12 IDD (mA) 10 Crystal w/o ADC 8 Crystal w/ ADC 6 4 Internal Osc w/o ADC 2 Internal Osc w/ ADC 0 0 1 2 3 4 5 6 7 Bus Frequency (MHz) Figure 16-9. Typical 5-Volt Run Current versus Bus Frequency (25°C) 4 3 IDD (mA) Crystal w/o ADC 2 Crystal w/ ADC Internal Osc w/o ADC 1 Internal Osc w/ ADC 0 0 1 2 3 4 5 Bus Frequency (MHz) Figure 16-10. Typical 3-Volt Run Current versus Bus Frequency (25°C) Data Sheet 180 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications Analog-to-Digital Converter Characteristics 16.14 Analog-to-Digital Converter Characteristics Characteristic Symbol Min Max Unit Comments Supply voltage VDDAD 2.7 (VDD min) 5.5 (VDD max) V — Input voltages VADIN VSS VDD V — Resolution (1 LSB) RES 10.5 21.5 mV — Absolute accuracy (Total unadjusted error) ETUE — ± 1.5 LSB Includes quantization ADC internal clock fADIC 0.5 1.048 MHz tADIC = 1/fADIC, tested only at 1 MHz Conversion range VAIN VSS VDD V — Power-up time tADPU 16 — tADIC cycles tADIC = 1/fADIC Conversion time tADC 16 17 tADIC cycles tADIC = 1/fADIC Sample time(1) tADS 5 — tADIC cycles tADIC = 1/fADIC Zero input reading(2) ZADI 00 01 Hex VIN = VSS Full-scale reading(3) FADI FE FF Hex VIN = VDD Input capacitance CADI — 8 pF Not tested IIL — ±1 µA — mA mA Enabled Enabled Input leakage(3) ADC supply current VDD = 3 V VDD = 5 V IADAD Typical = 0.45 Typical = 0.65 1. Source impedances greater than 10 kΩ adversely affect internal RC charging time during input sampling. 2. Zero-input/full-scale reading requires sufficient decoupling measures for accurate conversions. 3. The external system error caused by input leakage current is approximately equal to the product of R source and input current. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 181 Electrical Specifications 16.15 Timer Interface Module Characteristics Characteristic Symbol Min Max Unit tTH, tTL 2 — tcyc tTLTL Note(1) — tcyc tTCL, tTCH tcyc + 5 — ns Timer input capture pulse width Timer input capture period Timer input clock pulse width 1. The minimum period is the number of cycles it takes to execute the interrupt service routine plus 1 tcyc. tTLTL tTH INPUT CAPTURE RISING EDGE tTLTL tTL INPUT CAPTURE FALLING EDGE tTLTL tTH tTL INPUT CAPTURE BOTH EDGES tTCH TCLK tTCL Figure 16-11. Timer Input Timing Data Sheet 182 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Electrical Specifications Memory Characteristics 16.16 Memory Characteristics Characteristic Symbol Min Typ Max Unit VRDR 1.3 — — V — 1 — — MHz fRead(1) 0 — 8M Hz FLASH page erase time 1 k cycles tErase 0.9 3.6 1 4 1.1 5.5 ms FLASH mass erase time tMErase 4 — — ms FLASH PGM/ERASE to HVEN setup time tNVS 10 — — µs FLASH high-voltage hold time tNVH 5 — — µs FLASH high-voltage hold time (mass erase) tNVHL 100 — — µs FLASH program hold time tPGS 5 — — µs FLASH program time tPROG 30 — 40 µs FLASH return to read time tRCV(2) 1 — — µs FLASH cumulative program hv period tHV(3) — — 4 ms FLASH endurance(4) — 10 k 100 k — Cycles FLASH data retention time(5) — 15 100 — Years RAM data retention voltage FLASH program bus clock frequency FLASH read bus clock frequency 1. fRead is defined as the frequency range for which the FLASH memory can be read. 2. tRCV is defined as the time it needs before the FLASH can be read after turning off the high voltage charge pump, by clearing HVEN to 0. 3. tHV is defined as the cumulative high voltage programming time to the same row before next erase. tHV must satisfy this condition: tNVS + tNVH + tPGS + (tPROG x 32) ≤ tHV maximum. 4. Typical endurance was evaluated for this product family. For additional information on how Motorola defines Typical Endurance, please refer to Engineering Bulletin EB619. 5. Typical data retention values are based on intrinsic capability of the technology measured at high temperature and de-rated to 25°C using the Arrhenius equation. For additional information on how Motorola defines Typical Data Retention, please refer to Engineering Bulletin EB618. MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Electrical Specifications 183 Electrical Specifications Data Sheet 184 MC68HC908QY/QT Family — Rev. 3 Electrical Specifications MOTOROLA Data Sheet — MC68HC908QY/QT Family Section 17. Ordering Information and Mechanical Specifications 17.1 Introduction This section contains order numbers for the MC68HC908QY1, MC68HC908QY2, MC68HC908QY4, MC68HC908QT1, MC68HC908QT2, and MC69HC908QT4. Dimensions are given for: • 8-pin plastic dual in-line package (PDIP) • 8-pin small outline integrated circuit (SOIC) package • 8-pin dual flat no lead (DFN) package • 16-pin PDIP • 16-pin SOIC • 16-pin thin shrink small outline package (TSSOP) 17.2 MC Order Numbers Table 17-1. MC Order Numbers MC Order Number ADC FLASH Memory Package MC68HC908QY1 — 1536 bytes MC68HC908QY2 Yes 1536 bytes MC68HC908QY4 Yes 4096 bytes 16-pins PDIP, SOIC, and TSSOP MC68HC908QT1 — 1536 bytes MC68HC908QT2 Yes 1536 bytes MC68HC908QT4 Yes 4096 bytes 8-pins PDIP, SOIC, and DFN Temperature and package designators: C = –40°C to +85°C V = –40°C to +105°C M = –40°C to +125°C P = Plastic dual in-line package (PDIP) DW = Small outline integrated circuit package (SOIC) DT = Thin shrink small outline package (TSSOP) FQ = Dual flat no lead (DFN) MC68HC908QY1XXX FAMILY PACKAGE DESIGNATOR TEMPERATURE RANGE Figure 17-1. Device Numbering System MC68HC908QY/QT Family — Rev. 3 MOTOROLA Data Sheet Ordering Information and Mechanical Specifications 185 Ordering Information and Mechanical Specifications 17.3 8-Pin Plastic Dual In-Line Package (Case #626) 8 NOTES: 1. DIMENSION L TO CENTER OF LEAD WHEN FORMED PARALLEL. 2. PACKAGE CONTOUR OPTIONAL (ROUND OR SQUARE CORNERS). 3. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 5 -B1 4 DIM A B C D F G H J K L M N F -A- NOTE 2 L C J -TN SEATING PLANE D G H 0.13 (0.005) M T A M B INCHES MIN MAX 0.370 0.400 0.240 0.260 0.155 0.175 0.015 0.020 0.040 0.070 0.100 BSC 0.030 0.050 0.008 0.012 0.115 0.135 0.300 BSC --10 ° 0.030 0.040 STYLE 1: 1. AC IN 2. DC + IN 3. DC - IN 4. AC IN 5. GROUND 6. OUTPUT 7. AUXILIARY 8. VCC M K MILLIMETERS MIN MAX 9.40 10.16 6.10 6.60 3.94 4.45 0.38 0.51 1.02 1.78 2.54 BSC 0.76 1.27 0.20 0.30 2.92 3.43 7.62 BSC --10 ° 0.76 1.01 M 17.4 8-Pin Small Outline Integrated Circuit Package (Case #968) 8 LE 5 Q1 E HE M× 1 4 L Z DETAIL P D e NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER 3. DIMENSION D AND E DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS AND ARE MEASURED AT THE PARTING LINE. MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.15 (0.006) PER SIDE. 4. TERMINAL NUMBERS ARE SHOWN FOR REFERENCE ONLY. 5. THE LEAD WIDTH DIMENSION (b) DOES NOT INCLUDE DAMBAR PROTUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.08 (0.003) TOTAL IN EXCESS OF THE LEAD WIDTH DIMENSION AT MAXIMUM MATERIAL CONDITION. DAMBAR CANNOT BE LOCATED ON THE LOWER RADIUS OR THE FOOT MINIMUM SPACE BETWEEN PROTRUSIONS AND ADJACENT LEAD TO BE 0.46 (0.018). A1 A P b 0.13 (0.005) c M 0.10 (0.004) DIM A A1 b c D E e HE L LE M Q1 Z Data Sheet 186 MILLIMETERS MIN MAX --2.05 0.05 0.20 0.35 0.50 0.18 0.27 5.10 5.50 5.10 5.45 1.27 BSC 7.40 8.20 0.50 0.85 1.10 1.50 0° 10° 0.70 0.90 --0.94 INCHES MIN MAX --- 0.081 0.002 0.008 0.014 0.020 0.007 0.011 0.201 0.217 0.201 0.215 0.050 BSC 0.291 0.323 0.020 0.033 0.043 0.059 0° 10° 0.028 0.035 --- 0.037 MC68HC908QY/QT Family — Rev. 3 Ordering Information and Mechanical Specifications MOTOROLA Ordering Information and Mechanical Specifications 8-Pin Dual Flat No Lead (DFN) Package (Case #1452) 17.5 8-Pin Dual Flat No Lead (DFN) Package (Case #1452) 0.1 C 4 A 0.1 C 2X 8 0.1 C 5 1.0 1.00 0.8 0.75 2X 0.05 C 4 (0.35) 0.05 0.00 4 (0.8) C SEATING PLANE DETAIL G VIEW ROTATED 90 o CLOCKWISE 1 4 0.3 0.2 PIN 1 INDEX AREA B G M 0.3 0.2 M DETAIL M BACKSIDE PIN 1 INDEX 0.1 C A B DETAIL M PIN 1 INDEX 1 3.5 3.4 EXPOSED DIE ATTACH PAD 4 3.05 2.95 0.1 C A B 2.55 2.45 0.1 C A B 0.4 6X DETAIL N N 8X 0.5 0.4 8 5 8X VIEW M-M 0.35 0.25 0.1 0.05 M C A B M C 8X 0.065 0.015 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M, 1994. 3. THE COMPLETE JEDEC DESIGNATOR FOR THIS PACKAGE IS: HP-VFDFP-N. 4. COPLANARITY APPLIES TO LEADS AND DIE ATTACH PAD. MC68HC908QY/QT Family — Rev. 3 MOTOROLA 0.8 Data Sheet Ordering Information and Mechanical Specifications 187 Ordering Information and Mechanical Specifications 17.6 16-Pin Plastic Dual In-Line Package (Case #648D) NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. DIMENSION L TO CENTER OF LEADS WHEN FORMED PARALLEL. 4. DIMENSIONS A AND B DO NOT INCLUDE MOLD PROTRUSION. 5. MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.25 (0.010). 6. ROUNDED CORNERS OPTIONAL. -A16 9 -B1 8 F L C S -T- SEATING PLANE K H G M J D 16 PL 0.25 (0.010) M T B S A S DIM A B C D F G H J K L M S INCHES MILLIMETERS MIN MAX MIN MAX 0.740 0.760 18.80 19.30 0.245 0.260 6.23 6.60 0.145 0.175 3.69 4.44 0.015 0.021 0.39 0.53 0.050 0.070 1.27 1.77 0.100 BSC 2.54 BSC 0.050 BSC 1.27 BSC 0.008 0.015 0.21 0.38 0.120 0.140 3.05 3.55 0.295 0.305 7.50 7.74 0° 10° 0° 10° 0.015 0.035 0.39 0.88 17.7 16-Pin Small Outline Integrated Circuit Package (Case #751G) A D q 9 1 8 h X 45 ° H E 0.25 8X M B M 16 16X M 14X e B B T A S B S A1 L A 0.25 NOTES: 1. DIMENSIONS ARE IN MILLIMETERS. 2. INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M, 1994. 3. DIMENSIONS D AND E DO NOT INLCUDE MOLD PROTRUSION. 4. MAXIMUM MOLD PROTRUSION 0.15 PER SIDE. 5. DIMENSION B DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.13 TOTAL IN EXCESS OF THE B DIMENSION AT MAXIMUM MATERIAL CONDITION. SEATING PLANE T C Data Sheet 188 MILLIMETERS DIM MIN MAX A 2.35 2.65 A1 0.10 0.25 B 0.35 0.49 C 0.23 0.32 D 10.15 10.45 E 7.40 7.60 e 1.27 BSC H 10.05 10.55 h 0.25 0.75 L 0.40 1.00 q 0° 7° MC68HC908QY/QT Family — Rev. 3 Ordering Information and Mechanical Specifications MOTOROLA Ordering Information and Mechanical Specifications 16-Pin Thin Shrink Small Outline Package (Case #948F) 17.8 16-Pin Thin Shrink Small Outline Package (Case #948F) 16X K REF 0.10 (0.004) M T U 0.15 (0.006) T U V S S S K K1 2X L/2 16 9 J1 B -U- L SECTION N-N J PIN 1 IDENT. 8 1 N 0.15 (0.006) T U S 0.25 (0.010) A -V- M NOTES: 4. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 5. CONTROLLING DIMENSION: MILLIMETER. 6. DIMENSION A DOES NOT INCLUDE MOLD FLASH. PROTRUSIONS OR GATE BURRS. MOLD FLASH OR GATE BURRS SHALL NOT EXCEED 0.15 (0.006) PER SIDE. 7. DIMENSION B DOES NOT INCLUDE INTERLEAD FLASH OR PROTRUSION. INTERLEAD FLASH OR PROTRUSION SHALL NOT EXCEED 0.25 (0.010) PER SIDE. 8. DIMENSION K DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.08 (0.003) TOTAL IN EXCESS OF THE K DIMENSION AT MAXIMUM MATERIAL CONDITION. 9. TERMINAL NUMBERS ARE SHOWN FOR REFERENCE ONLY. 10. DIMENSION A AND B ARE TO BE DETERMINED AT DATUM PLANE -W-. N F DETAIL E -W- C 0.10 (0.004) -T- SEATING PLANE H D DETAIL E G MC68HC908QY/QT Family — Rev. 3 MOTOROLA DIM A B C D F G H J J1 K K1 L M MILLIMETERS MIN MAX 4.90 5.10 4.30 4.50 --1.20 0.05 0.15 0.50 0.75 0.65 BSC 0.18 0.28 0.09 0.20 0.09 0.16 0.19 0.30 0.19 0.25 6.40 BSC 0° 8° INCHES MIN MAX 0.193 0.200 0.169 0.177 --- 0.047 0.002 0.006 0.020 0.030 0.026 BSC 0.007 0.011 0.004 0.008 0.004 0.006 0.007 0.012 0.007 0.010 0.252 BSC 0° 8° Data Sheet Ordering Information and Mechanical Specifications 189 Ordering Information and Mechanical Specifications Data Sheet 190 MC68HC908QY/QT Family — Rev. 3 Ordering Information and Mechanical Specifications MOTOROLA HOW TO REACH US: USA/EUROPE/LOCATIONS NOT LISTED: Motorola Literature Distribution P.O. Box 5405 Denver, Colorado 80217 1-800-521-6274 or 480-768-2130 JAPAN: Motorola Japan Ltd. SPS, Technical Information Center 3-20-1, Minami-Azabu, Minato-ku Tokyo 106-8573, Japan 81-3-3440-3569 ASIA/PACIFIC: Motorola Semiconductors H.K. Ltd. Silicon Harbour Centre 2 Dai King Street Tai Po Industrial Estate Tai Po, N.T., Hong Kong 852-26668334 HOME PAGE: http://motorola.com/semiconductors Information in this document is provided solely to enable system and software implementers to use Motorola products. There are no express or implied copyright licenses granted hereunder to design or fabricate any integrated circuits or integrated circuits based on the information in this document. Motorola reserves the right to make changes without further notice to any products herein. Motorola makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Motorola assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters that may be provided in Motorola data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals”, must be validated for each customer application by customer’s technical experts. Motorola does not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part. MOTOROLA and the Stylized M Logo are registered in the US Patent and Trademark Office. All other product or service names are the property of their respective owners. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer. © Motorola Inc. 2004 MC68HC908QY4/D Rev. 3.0 1/2004
MC68HC908QY2MDW 价格&库存
很抱歉,暂时无法提供与“MC68HC908QY2MDW”相匹配的价格&库存,您可以联系我们找货
