OBT500-18GM60-E5-V1
OBT500-18GM60-E5-V1
    PEPPERL+FUCHS(倍加福)
    DIFFUSED PHOTO SEN 0-500MM PNP
OBT500-18GM60-E5-V1 数据手册
Diffuse mode sensor OBT500-18GM60-E5-V1 Dimensions 7 LED 70 51 60 38 Sensitivity adjuster 44 4 24 M18x1 M12 x 1 Model Number OBT500-18GM60-E5-V1 Diffuse mode sensor Electrical connection Option: with 4-pin, M12 connector 2 IN 1 +UB • Degree of protection IP67 4 Q • Strong metallic housing in cylindrical shape M18 x 1 3 0V Features E5 E5 • Dual color indication LED • High switching frequency • Light/dark ON, programmable = Light on = Dark on Pinout Wire colors in accordance with EN 60947-5-2 1 4 2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Release date: 2019-11-25 10:15 Date of issue: 2019-11-25 087797_eng.xml 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Diffuse mode sensor OBT500-18GM60-E5-V1 Technical data General specifications Detection range Reference target Light source Light type Diameter of the light spot Ambient light limit 0 ... 500 mm standard white 200 mm x 200 mm IRED , 880 nm infrared approx. 80 mm at 500 mm 10000 Lux Indicators/operating means Operation indicator Function indicator LED green Dual color-LED, yellow/green yellow: switching state green: power on flashing: stability control Sensing range adjuster Control elements Electrical specifications Operating voltage Ripple No-load supply current Time delay before availability Output Switching type Signal output Switching voltage Switching current Voltage drop Switching frequency Response time UB I0 tv Ud f 10 ... 30 V DC , class 2 10 % ≤ 25 mA ≤ 25 ms light/dark on electrically switchable 1 PNP output, short-circuit protected, reverse polarity protected, open collector max. 30 V DC max. 100 mA ≤ 2.5 V 500 Hz 1 ms Conformity Product standard EN 60947-5-2 Standard conformity Standards 2 UL 508 Ambient conditions Ambient temperature Storage temperature -25 ... 55 °C (-13 ... 131 °F) -40 ... 70 °C (-40 ... 158 °F) Mechanical specifications Degree of protection Connection Material Housing Optical face Mass IP67 4-pin, M12 x 1 connector brass, nickel-plated PC 45 g Approvals and certificates EAC conformity UL approval CCC approval Approvals TR CU 020/2011 cULus Listed, Type 1 enclosure CCC approval / marking not required for products rated ≤36 V CE, cULus Listed 57M3 (Only in association with UL Class 2 power supply; Type 1 enclosure) Curves/Diagrams Characteristic response curve 087797_eng.xml OBT500-18GM60 Offset Y [mm] 50 40 Date of issue: 2019-11-25 30 20 10 0 -10 -20 100 200 300 400 500 600 700 800 Distance X [mm] Release date: 2019-11-25 10:15 0 y x 2 white 90 % grey 18 % black 6 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Diffuse mode sensor OBT500-18GM60-E5-V1 OBT500-18GM60 Relative received light strength Stability control 25 20 15 10 5 0 0 200 400 600 800 Distance X [mm] white 90 % grey 18 % black 6 % x OBT500-18GM60 Detection ranges Object colour black grey white 0 100 200 300 400 500 600 700 800 Distance X [mm] Release date: 2019-11-25 10:15 Date of issue: 2019-11-25 087797_eng.xml x Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
OBT500-18GM60-E5-V1 价格&库存
很抱歉,暂时无法提供与“OBT500-18GM60-E5-V1”相匹配的价格&库存,您可以联系我们找货
