S-19243xxxA Series
www.ablic.com
AUTOMOTIVE, 125°C OPERATION,
10 V INPUT, 500 mA VOLTAGE REGULATOR
WITH SOFT-START FUNCTION
Rev.3.3_00
© ABLIC Inc., 2016-2020
The S-19243xxxA Series developed by using high-withstand voltage CMOS process technology, is a positive voltage
regulator with high-accuracy output voltage and high output current.
A built-in overcurrent protection circuit to limit overcurrent of the output transistor and a built-in thermal shutdown circuit to
limit heat are included. In addition to the type in which output voltage is set inside the IC, the type for which output voltage
can be set via an external resistor is added to a lineup. Also, the S-19243xxxA Series includes the soft-start function to
adjust the output voltage rising time at power-on or at the time when the ON / OFF pin is set to ON.
ABLIC Inc. offers a "thermal simulation service" which supports the thermal design in conditions when our power
management ICs are in use by customers. Our thermal simulation service will contribute to reducing the risk in the thermal
design at customers' development stage.
ABLIC Inc. also offers FIT rate calculated based on actual customer usage conditions in order to support customer
functional safety design.
Contact our sales representatives for details.
Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for
these purposes, it is imperative to contact our sales representatives.
Features
• Output voltage (internally set):
• Output voltage (externally set):
• Input voltage:
• Output voltage accuracy:
• Dropout voltage:
• Current consumption:
• Output current:
• Ripple rejection:
• Built-in overcurrent protection circuit:
• Built-in thermal shutdown circuit:
• Built-in soft-start circuit:
• Built-in ON / OFF circuit:
• Operation temperature range:
• Lead-free (Sn 100%), halogen-free
• AEC-Q100 qualified*2
1.0 V to 6.0 V, selectable in 0.05 V step
1.0 V to 9.0 V, settable via external resistor
(HSOP-8A, HSOP-6 and HSNT-8(2030) only)
2.5 V to 10.0 V
±2.3% (Tj = −40°C to +125°C)
0.09 V typ. (2.6 V output product, at IOUT = 200 mA)
During operation: 120 μA typ., 150 μA max. (Tj = −40°C to +150°C)
During power-off: 0.1 μA typ., 10.5 μA max. (Tj = −40°C to +125°C)
Possible to output 500 mA (at VIN ≥ VOUT(S) + 1.0 V)*1
60 dB typ. (at f = 1.0 kHz)
Limits overcurrent of output transistor.
Detection temperature 170°C typ.
Adjusts output voltage rising time at power-on or at the time when
Adjustable type: E / F / G / H type, tSS = 6.0 ms typ. (CSS = 10 nF)
Soft-start time can be changed by the capacitor (CSS).
Fixed type: A / B / C / D type: Fixed to tSS = 1.0 ms typ.
Ensures long battery life
Discharge shunt function "available" / "unavailable" is selectable.
Pull-down function "available" / "unavailable" is selectable.
Ta = −40°C to +125°C
*1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large.
*2. Contact our sales representatives for details.
Applications
• Constant-voltage power supply for electrical application for vehicle interior
• Constant-voltage power supply for home electric appliance
• For automotive use (engine, transmission, suspension, ABS, related-devices for EV / HEV / PHEV, etc.)
Packages
• TO-252-5S(A)
• HSOP-8A
• HSOP-6
• SOT-89-5
• HSNT-8(2030)
1
AUTOMOTIVE, 125°C OPERATION, 10 V INPUT, 500 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION
S-19243xxxA Series
Rev.3.3_00
Block Diagrams
1.
Types in which output voltage is internally set
1. 1
S-19243xxxA Series A / B / C / D type (HSOP-8A, HSOP-6, SOT-89-5, HSNT-8(2030))
*1
VIN
VOUT
Overcurrent protection circuit
Thermal shutdown circuit
ON / OFF
circuit
ON / OFF
*2
*3
Reference
voltage circuit
Soft-start
circuit
*1
VSS
Product
Type
A
B
C
D
ON / OFF Logic
Active "H"
Active "H"
Active "H"
Active "H"
Soft-start Time
Discharge Shunt
Function*2
Available
Available
Unavailable
Unavailable
Pull-down Resistor*3
Available
Unavailable
Available
Unavailable
*1. Parasitic diode
*2. A / B type (With discharge shunt function): ON, C / D type (Without discharge shunt function): OFF
*3. A / C type (With pull-down resistor): ON, B / D type (Without pull-down resistor): OFF
Figure 1
2
Rev.3.3_00
S-19243xxxA Series
1. 2
S-19243xxxA Series E / F / G / H type (TO-252-5S(A), HSOP-8A, HSOP-6, SOT-89-5, HSNT-8(2030))
*1
VOUT
VIN
ON / OFF
circuit
ON / OFF
*2
*3
Reference
voltage circuit
Soft-start
circuit
*1
SSC
*1
VSS
Product
Type
E
F
G
H
ON / OFF Logic
Active "H"
Active "H"
Active "H"
Active "H"
Soft-start Time
Changeable by capacitor (CSS)
Discharge Shunt
Function*2
Available
Available
Unavailable
Unavailable
Available
Unavailable
Available
Unavailable
*1. Parasitic diode
*2. E / F type (With discharge shunt function): ON, G / H type (Without discharge shunt function): OFF
*3. E / G type (With pull-down resistor): ON, F / H type (Without pull-down resistor): OFF
Figure 2
3
S-19243xxxA Series
Rev.3.3_00
2.
Types in which output voltage is externally set
2. 1
S-19243xxxA Series A / B / C / D type (HSOP-6)
*1
VIN
VOUT
VADJ
ON / OFF
circuit
ON / OFF
*2
*3
Reference
voltage circuit
Soft-start
circuit
*1
VSS
Product
Type
A
B
C
D
ON / OFF Logic
Active "H"
Active "H"
Active "H"
Active "H"
Soft-start Time
Discharge Shunt
Function*2
Available
Available
Unavailable
Unavailable
Available
Unavailable
Available
Unavailable
*1. Parasitic diode
Figure 3
4
Rev.3.3_00
S-19243xxxA Series
2. 2
S-19243xxxA Series E / F / G / H type (HSOP-8A, HSNT-8(2030))
*1
VIN
VOUT
VADJ
ON / OFF
circuit
ON / OFF
*2
*3
Reference
voltage circuit
Soft-start
circuit
*1
SSC
*1
VSS
Product
Type
E
F
G
H
ON / OFF Logic
Active "H"
Active "H"
Active "H"
Active "H"
Soft-start Time
Discharge Shunt
Function*2
Available
Available
Unavailable
Unavailable
Available
Unavailable
Available
Unavailable
*1. Parasitic diode
Figure 4
5
S-19243xxxA Series
Rev.3.3_00
AEC-Q100 Qualified
This IC supports AEC-Q100 for operation temperature grade 1.
Contact our sales representatives for details of AEC-Q100 reliability specification.
Product Name Structure
Users can select the product type, output voltage and package type for the S-19243xxxA Series. Refer to "1. Product
name" regarding the contents of product name, "2. Function list of product type" regarding the product type,
"3. Packages" regarding the package drawings and "4. Product name list" for details of product names.
1.
Product name
S-19243
x
xx
A -
xxxx
U
Environmental code
U:
Package abbreviation and IC packing specifications*1
V5T2:
TO-252-5S(A), Tape
E8T1:
HSOP-8A, Tape
E6T1:
HSOP-6, Tape
U5T1:
SOT-89-5, Tape
A8T1:
HSNT-8(2030), Tape
A:
Output voltage*2
00:
Externally set*3
10 to 60: Internally set
(e.g., when the output voltage is 1.0 V, it is expressed as 10.)
*3
Product type
A to H
*1.
*2.
*3.
6
Refer to the tape drawing.
If you request the product which has 0.05 V step, contact our sales representatives.
Refer to "2. Function list of product type".
Rev.3.3_00
S-19243xxxA Series
2.
Table 1
Discharge
Pull-down
Shunt Function
Resistor
Product
Type
ON / OFF
Logic
Soft-start Time
A
Active "H"
Fixed to
tSS = 1.0 ms typ.*1
Available
Fixed to
tSS = 1.0 ms typ.*1
Available
Fixed to
tSS = 1.0 ms typ.*1
Unavailable
Fixed to
tSS = 1.0 ms typ.*1
Unavailable
B
Active "H"
C
Active "H"
D
Active "H"
E
Active "H"
Available
Output Voltage
Internally set
Externally set
Unavailable
Internally set
Externally set
Available
Internally set
Externally set
Unavailable
Internally set
Externally set
Changeable by
Available
the capacitor (CSS)
Available
Internally set
Externally set
F
Active "H"
Changeable by
Available
the capacitor (CSS)
Unavailable
Internally set
Externally set
G
Active "H"
Changeable by
Unavailable
the capacitor (CSS)
Available
Internally set
Externally set
H
Active "H"
Changeable by
Unavailable
the capacitor (CSS)
Unavailable
Internally set
Externally set
*1.
Package
HSOP-8A, HSOP-6,
HSOP-6
HSOP-8A, HSOP-6,
HSOP-6
HSOP-8A, HSOP-6,
HSOP-6
HSOP-8A, HSOP-6,
HSOP-6
HSOP-6, SOT-89-5,
HSNT-8(2030)
HSOP-6, SOT-89-5,
HSNT-8(2030)
HSOP-6, SOT-89-5,
HSNT-8(2030)
HSOP-6, SOT-89-5,
HSNT-8(2030)
The soft-start time (tSS) is fixed to 1.0 ms typ. that cannot be changed.
3.
Packages
Table 2
Package Name
TO-252-5S(A)
HSOP-8A
HSOP-6
SOT-89-5
HSNT-8(2030)
Dimension
VA005-A-P-SD
FH008-A-P-SD
FH006-A-P-SD
UP005-A-P-SD
PP008-A-P-SD
Package Drawing Codes
Tape
VA005-A-C-SD
FH008-A-C-SD
FH006-A-C-SD
UP005-A-C-SD
PP008-A-C-SD
Reel
VA005-A-R-SD
FH008-A-R-SD
FH006-A-R-S1
UP005-A-R-SD
PP008-A-R-SD
Land
VA005-A-L-SD
FH008-A-L-SD
FH006-A-L-SD
PP008-A-L-SD
7
S-19243xxxA Series
Rev.3.3_00
4.
Product name list
4. 1
S-19243xxxA Series A type
ON / OFF logic
Pull-down resistor
Output Voltage
Externally set
: Active "H"
: Available
HSOP-8A
Discharge shunt function : Available
Soft-start time
Table 3
HSOP-6
SOT-89-5
S-19243A00A-E6T1U
S-19243A12A-E8T1U
S-19243A12A-E6T1U
S-19243A12A-U5T1U
S-19243A18A-E8T1U
S-19243A18A-E6T1U
S-19243A18A-U5T1U
S-19243A33A-E8T1U
S-19243A33A-E6T1U
S-19243A33A-U5T1U
S-19243A50A-E8T1U
S-19243A50A-E6T1U
S-19243A50A-U5T1U
Please contact our sales representatives for products other than the above.
1.2 V ± 2.3%
1.8 V ± 2.3%
3.3 V ± 2.3%
5.0 V ± 2.3%
Remark
4. 2
Output Voltage
Externally set
: Active "H"
: Unavailable
HSOP-8A
Soft-start time
Table 4
HSOP-6
SOT-89-5
S-19243B00A-E6T1U
S-19243B12A-E8T1U
S-19243B12A-E6T1U
S-19243B12A-U5T1U
S-19243B18A-E8T1U
S-19243B18A-E6T1U
S-19243B18A-U5T1U
S-19243B33A-E8T1U
S-19243B33A-E6T1U
S-19243B33A-U5T1U
S-19243B50A-E8T1U
S-19243B50A-E6T1U
S-19243B50A-U5T1U
1.2 V ± 2.3%
1.8 V ± 2.3%
3.3 V ± 2.3%
5.0 V ± 2.3%
4. 3
Output Voltage
Externally set
: Active "H"
: Available
HSOP-8A
Table 5
HSOP-6
HSNT-8(2030)
S-19243C12A-A8T1U
S-19243C18A-A8T1U
S-19243C33A-A8T1U
S-19243C50A-A8T1U
S-19243xxxA Series D type
ON / OFF logic
Pull-down resistor
Output Voltage
Externally set
: Active "H"
: Unavailable
HSOP-8A
Discharge shunt function : Unavailable
Soft-start time
Table 6
HSOP-6
SOT-89-5
S-19243D00A-E6T1U
S-19243D12A-E8T1U
S-19243D12A-E6T1U
S-19243D12A-U5T1U
S-19243D18A-E8T1U
S-19243D18A-E6T1U
S-19243D18A-U5T1U
S-19243D33A-E8T1U
S-19243D33A-E6T1U
S-19243D33A-U5T1U
S-19243D50A-E8T1U
S-19243D50A-E6T1U
S-19243D50A-U5T1U
1.2 V ± 2.3%
1.8 V ± 2.3%
3.3 V ± 2.3%
5.0 V ± 2.3%
8
S-19243B12A-A8T1U
S-19243B18A-A8T1U
S-19243B33A-A8T1U
S-19243B50A-A8T1U
Soft-start time
SOT-89-5
S-19243C00A-E6T1U
1.2 V ± 2.3%
S-19243C12A-E8T1U
S-19243C12A-E6T1U
S-19243C12A-U5T1U
1.8 V ± 2.3%
S-19243C18A-E8T1U
S-19243C18A-E6T1U
S-19243C18A-U5T1U
3.3 V ± 2.3%
S-19243C33A-E8T1U
S-19243C33A-E6T1U
S-19243C33A-U5T1U
5.0 V ± 2.3%
S-19243C50A-E8T1U
S-19243C50A-E6T1U
S-19243C50A-U5T1U
Remark Please contact our sales representatives for products other than the above.
Remark
HSNT-8(2030)
S-19243xxxA Series C type
ON / OFF logic
Pull-down resistor
4. 4
S-19243A12A-A8T1U
S-19243A18A-A8T1U
S-19243A33A-A8T1U
S-19243A50A-A8T1U
S-19243xxxA Series B type
ON / OFF logic
Pull-down resistor
Remark
HSNT-8(2030)
HSNT-8(2030)
S-19243D12A-A8T1U
S-19243D18A-A8T1U
S-19243D33A-A8T1U
S-19243D50A-A8T1U
Rev.3.3_00
S-19243xxxA Series
4. 5
S-19243xxxA Series E type
ON / OFF logic
Pull-down resistor
: Active "H"
: Available
Soft-start time
: Changeable by CSS
Table 7
HSOP-8A
HSOP-6
SOT-89-5
S-19243E00A-E8T1U
1.2 V ± 2.3%
S-19243E12A-V5T2U S-19243E12A-E8T1U
S-19243E12A-E6T1U S-19243E12A-U5T1U
1.8 V ± 2.3%
S-19243E18A-V5T2U S-19243E18A-E8T1U
S-19243E18A-E6T1U S-19243E18A-U5T1U
3.3 V ± 2.3%
S-19243E33A-V5T2U S-19243E33A-E8T1U
S-19243E33A-E6T1U S-19243E33A-U5T1U
5.0 V ± 2.3%
S-19243E50A-V5T2U S-19243E50A-E8T1U
S-19243E50A-E6T1U S-19243E50A-U5T1U
Output Voltage
Externally set
4. 6
TO-252-5S(A)
HSNT-8(2030)
S-19243E00A-A8T1U
S-19243E12A-A8T1U
S-19243E18A-A8T1U
S-19243E33A-A8T1U
S-19243E50A-A8T1U
S-19243xxxA Series F type
ON / OFF logic
Pull-down resistor
: Active "H"
: Unavailable
Soft-start time
: Changeable by CSS
Table 8
Output Voltage
Externally set
HSOP-8A
HSOP-6
SOT-89-5
S-19243F00A-E8T1U
1.2 V ± 2.3%
S-19243F12A-V5T2U
S-19243F12A-E8T1U
S-19243F12A-E6T1U S-19243F12A-U5T1U
1.8 V ± 2.3%
S-19243F18A-V5T2U
S-19243F18A-E8T1U
S-19243F18A-E6T1U S-19243F18A-U5T1U
3.3 V ± 2.3%
S-19243F33A-V5T2U
S-19243F33A-E8T1U
S-19243F33A-E6T1U S-19243F33A-U5T1U
5.0 V ± 2.3%
S-19243F50A-V5T2U
S-19243F50A-E8T1U
S-19243F50A-E6T1U S-19243F50A-U5T1U
4. 7
TO-252-5S(A)
S-19243xxxA Series G type
ON / OFF logic
Pull-down resistor
: Active "H"
: Available
Soft-start time
: Changeable by CSS
Table 9
HSOP-8A
HSOP-6
SOT-89-5
S-19243G00A-E8T1U
1.2 V ± 2.3%
S-19243G12A-V5T2U S-19243G12A-E8T1U S-19243G12A-E6T1U S-19243G12A-U5T1U
1.8 V ± 2.3%
S-19243G18A-V5T2U S-19243G18A-E8T1U S-19243G18A-E6T1U S-19243G18A-U5T1U
3.3 V ± 2.3%
S-19243G33A-V5T2U S-19243G33A-E8T1U S-19243G33A-E6T1U S-19243G33A-U5T1U
5.0 V ± 2.3%
S-19243G50A-V5T2U S-19243G50A-E8T1U S-19243G50A-E6T1U S-19243G50A-U5T1U
Output Voltage
Externally set
4. 8
TO-252-5S(A)
HSNT-8(2030)
S-19243G00A-A8T1U
S-19243G12A-A8T1U
S-19243G18A-A8T1U
S-19243G33A-A8T1U
S-19243G50A-A8T1U
S-19243xxxA Series H type
ON / OFF logic
Pull-down resistor
: Active "H"
: Unavailable
Soft-start time
: Changeable by CSS
Table 10
HSOP-8A
HSOP-6
SOT-89-5
S-19243H00A-E8T1U
1.2 V ± 2.3%
S-19243H12A-V5T2U S-19243H12A-E8T1U
S-19243H12A-E6T1U S-19243H12A-U5T1U
1.8 V ± 2.3%
S-19243H18A-V5T2U S-19243H18A-E8T1U
S-19243H18A-E6T1U S-19243H18A-U5T1U
3.3 V ± 2.3%
S-19243H33A-V5T2U S-19243H33A-E8T1U
S-19243H33A-E6T1U S-19243H33A-U5T1U
5.0 V ± 2.3%
S-19243H50A-V5T2U S-19243H50A-E8T1U
S-19243H50A-E6T1U S-19243H50A-U5T1U
Output Voltage
Externally set
HSNT-8(2030)
S-19243F00A-A8T1U
S-19243F12A-A8T1U
S-19243F18A-A8T1U
S-19243F33A-A8T1U
S-19243F50A-A8T1U
TO-252-5S(A)
HSNT-8(2030)
S-19243H00A-A8T1U
S-19243H12A-A8T1U
S-19243H18A-A8T1U
S-19243H33A-A8T1U
S-19243H50A-A8T1U
9
S-19243xxxA Series
Rev.3.3_00
Pin Configurations
1.
TO-252-5S(A)
Table 11 S-19243xxxA Series E / F / G / H Type,
Types in Which Output Voltage is Internally Set*1
Top view
Pin No.
3
1
2
4
Symbol
Description
1
VOUT
Output voltage pin
2
ON / OFF
ON / OFF pin
3
VSS
GND pin
4
SSC*2
Soft-start pin
5
VIN
Input voltage pin
5
Figure 5
*1. Types in which output voltage is externally set are unavailable.
*2. Connect a capacitor between the SSC pin and the VSS pin.
The soft-start time at power-on and at the time when the ON / OFF pin is set to ON can be adjusted according to
the capacitance.
10
Rev.3.3_00
S-19243xxxA Series
2.
HSOP-8A
Top view
1
8
2
7
3
6
4
5
Bottom view
8
1
7
2
6
3
5
4
*1
Figure 6
Table 12 S-19243xxxA Series A / B / C / D Type,
Pin No.
Symbol
Description
VOUT*2
VOUT*2
VSS
NC*3
ON / OFF
NC*3
NC*3
VIN
1
2
3
4
5
6
7
8
Output voltage pin
Output voltage pin
GND pin
No connection
ON / OFF pin
No connection
No connection
Input voltage pin
Table 13 S-19243xxxA Series E / F / G / H Type,
Pin No.
1
2
3
4
5
6
7
8
Symbol
VOUT
NC*3
VSS
ON / OFF
SSC*4
NC*3
NC*3
VIN
Description
Output voltage pin
No connection
GND pin
ON / OFF pin
Soft-start pin
No connection
No connection
Input voltage pin
Table 14 S-19243xxxA Series E / F / G / H Type,
Types in Which Output Voltage is Externally Set
Pin No.
1
2
3
4
5
6
7
8
Symbol
VOUT
VADJ
VSS
ON / OFF
SSC*4
NC*3
NC*3
VIN
Description
Output voltage pin
Output voltage adjustment pin
GND pin
ON / OFF pin
Soft-start pin
No connection
No connection
Input voltage pin
*1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND.
However, do not use it as the function of electrode.
*2. Although pins of number 1 and 2 are connected internally, be sure to short-circuit them nearest in use.
*3. The NC pin is electrically open.
The NC pin can be connected to the VIN pin or the VSS pin.
*4. Connect a capacitor between the SSC pin and the VSS pin.
the capacitance.
11
S-19243xxxA Series
Rev.3.3_00
3.
HSOP-6
Top view
6
5
4
1
2
3
Figure 7
Table 15 S-19243xxxA Series A / B / C / D Type,
Pin No.
Symbol
Description
1
2
3
4
5
6
VOUT
VSS
ON / OFF
NC*1
VSS
VIN
Output voltage pin
GND pin
ON / OFF pin
No connection
GND pin
Input voltage pin
Table 16 S-19243xxxA Series E / F / G / H Type,
Pin No.
1
2
3
4
5
6
Symbol
VOUT
VSS
ON / OFF
SSC*2
VSS
VIN
Description
Output voltage pin
GND pin
ON / OFF pin
Soft-start pin
GND pin
Input voltage pin
Table 17 S-19243xxxA Series A / B / C / D Type,
Pin No.
1
2
3
4
5
6
Symbol
VOUT
VSS
VADJ
ON / OFF
VSS
VIN
Description
Output voltage pin
GND pin
ON / OFF pin
GND pin
Input voltage pin
*1. The NC pin is electrically open.
the capacitance.
12
Rev.3.3_00
S-19243xxxA Series
4.
SOT-89-5
Table 18 S-19243xxxA Series A / B / C / D Type,
Top view
5
1
4
2
Figure 8
Pin No.
1
2
3
4
5
Symbol
ON / OFF
VSS
NC*2
VIN
VOUT
Description
ON / OFF pin
GND pin
No connection
Input voltage pin
Output voltage pin
3
Table 19 S-19243xxxA Series E / F / G / H Type,
Pin No.
1
2
3
4
5
Symbol
ON / OFF
VSS
SSC*3
VIN
VOUT
Description
ON / OFF pin
GND pin
Soft-start pin
Input voltage pin
Output voltage pin
*2. The NC pin is electrically open.
*3. Connect a capacitor between the SSC pin and the VSS pin.
the capacitance.
13
S-19243xxxA Series
Rev.3.3_00
4.
HSNT-8(2030)
Top view
1
8
4
5
Bottom view
8
1
5
4
Table 20 S-19243xxxA Series A / B / C / D Type,
Pin No.
Symbol
Description
VOUT*2
VOUT*2
VSS
NC*3
ON / OFF
NC*3
NC*3
VIN
1
2
3
4
5
6
7
8
Output voltage pin
Output voltage pin
GND pin
No connection
ON / OFF pin
No connection
No connection
Input voltage pin
*1
Figure 9
Table 21 S-19243xxxA Series E / F / G / H Type,
Pin No.
1
2
3
4
5
6
7
8
Symbol
VOUT*2
VOUT*2
VSS
ON / OFF
SSC*4
NC*3
NC*3
VIN
Description
Output voltage pin
Output voltage pin
GND pin
ON / OFF pin
Soft-start pin
No connection
No connection
Input voltage pin
Table 22 S-19243xxxA Series E / F / G / H Type,
Pin No.
1
2
3
4
5
6
7
8
Symbol
VOUT
VADJ
VSS
ON / OFF
SSC*4
NC*3
NC*3
VIN
Description
Output voltage pin
GND pin
ON / OFF pin
Soft-start pin
No connection
No connection
Input voltage pin
*1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not
the capacitance.
14
Rev.3.3_00
S-19243xxxA Series
Absolute Maximum Ratings
Table 23
(Ta = +25°C unless otherwise specified)
Item
Symbol
VSS − 0.3 to VSS + 12
Unit
VON / OFF
VSS − 0.3 to VIN + 0.3 ≤ VSS + 12
V
VSSC
V
VVADJ
V
550
mA
−40 to +150
°C
VIN
Input voltage
Output voltage
VOUT
Output current
IOUT
Junction temperature
Tj
V
V
Operation ambient temperature
Topr
−40 to +125
°C
Storage temperature
Tstg
−40 to +150
°C
Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
Thermal Resistance Value
Table 24
Item
Junction-to-ambient thermal resistance*1
Symbol
θJA
Condition
Min.
Typ.
Board B
Board C
Board D
84
Board E
Board A
Board B
HSNT-8(2030) Board C
Board D
Board E
Board A
Board B
TO-252-5S(A) Board C
Board D
Board E
Board A
Board B
HSOP-8A
Board C
Board D
Board E
Board A
Board B
HSOP-6
Board C
Board D
Board E
Board A
SOT-89-5
*1.
Max.
Unit
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
46
°C/W
°C/W
°C/W
35
181
135
40
42
32
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
86
60
38
31
28
104
74
39
37
31
96
74
44
41
119
Test environment: compliance with JEDEC STANDARD JESD51-2A
Remark
Refer to " Power Dissipation" and "Test Board" for details.
15
S-19243xxxA Series
Rev.3.3_00
Electrical Characteristics
1.
Types in which output voltage is internally set (S-19243x10 to S-19243x60)
Table 25 (1 / 2)
Item
Output voltage*1
Symbol
VOUT(E)
Output current*2
IOUT
Dropout voltage*3
Vdrop
Line regulation
ΔVOUT1
ΔVIN • VOUT
Load regulation
Current
consumption
during operation
ΔVOUT2
ISS1
Current
consumption
during power-off
ISS2
Input voltage
VIN
16
Condition
(Tj = −40°C to +150°C unless otherwise specified)
Test
Min.
Typ.
Max. Unit
Circuit
VOUT(S)
VOUT(S)
VOUT(S) < 1.5 V
VOUT(S)
V
1
× 0.977
× 1.023
VIN = 2.5 V, IOUT = 100 mA,
VIN = VOUT(S) + 1.0 V,
VOUT(S)
VOUT(S)
1.5 V ≤ VOUT(S)
IOUT = 100 mA,
VOUT(S)
V
× 0.977
× 1.023
mA
VIN = 2.5 V
VOUT(S) < 1.5 V 500*5
mA
1.5 V ≤ VOUT(S) 500*5
*4
V
1.0 V ≤ VOUT(S) < 2.0 V
IOUT = 200 mA,
2.0 V ≤ VOUT(S) < 2.6 V
0.52
V
Ta = +25°C
2.6 V ≤ VOUT(S) ≤ 6.0 V
0.09
V
2.5 V ≤ VIN ≤ 10 V,
VOUT(S) < 2.0 V
0.05
0.2
%/V
IOUT = 100 mA, Ta = +25°C
VOUT(S) + 0.5 V ≤ VIN ≤ 10 V,
0.05
0.2
%/V
2.0 V ≤ VOUT(S)
VIN = 2.5 V,
VOUT(S) < 1.5 V
15
30
mV
1 mA ≤ IOUT ≤ 200 mA,
Ta = +25°C
1.5 V ≤ VOUT(S)
15
30
mV
Ta = +25°C
VIN = 2.5 V,
120
150
μA
VOUT(S) < 1.5 V
ON / OFF pin = ON, no load
120
150
μA
1.5 V ≤ VOUT(S)
VIN = 2.5 V,
ON / OFF pin = OFF, no load, VOUT(S) < 1.5 V
0.1
10.5
μA
0.1
10.5
μA
ON / OFF pin = OFF, no load, 1.5 V ≤ VOUT(S)
2.5
10
V
1
3
3
1
1
1
1
1
1
1
2
2
2
2
Rev.3.3_00
S-19243xxxA Series
Table 25 (2 / 2)
Item
ON / OFF pin
input voltage "H"
ON / OFF pin
input voltage "L"
ON / OFF pin
input current "H"
ON / OFF pin
input current "L"
Ripple rejection
Short-circuit current
Symbol
VSH
VSL
Soft-start time*6
VIN = 2.5 V, RL = 1 kΩ,
determined by VOUT output
level
RL = 1 kΩ, determined by
VOUT output level
level
VOUT output level
VOUT(S) < 1.5 V
2.1
V
4
1.5 V ≤ VOUT(S)
2.1
V
4
VOUT(S) < 1.5 V
0.6
V
4
1.5 V ≤ VOUT(S)
0.6
V
4
−0.1
0.8
2.5
0.1
7.8
μA
μA
4
4
−0.1
0.1
μA
4
60
dB
5
55
dB
5
55
dB
5
50
dB
5
240
mA
3
240
mA
3
170
°C
135
°C
A / B / E / F type
100
Ω
6
A / C / E / G type
1.3
4.0
12
MΩ
4
1.0
ms
7
1.0
ms
7
ISH
VIN = 10 V, VON / OFF = 10 V
ISL
VIN = 10 V, VON / OFF = 0 V
|RR|
Ishort
Thermal shutdown
TSD
detection temperature
Thermal shutdown
TSR
release temperature
Discharge shunt
RLOW
resistance during
power-off
ON / OFF pin
pull-down resistance
Condition
RPD
tSS
Test
Min.
Typ.
Max. Unit
Circuit
B / D / F / H type
A / C / E / G type
VIN = 3.0 V, f = 1 kHz, 1.0 V ≤ VOUT(S) < 1.5 V
ΔVrip = 0.5 Vrms,
1.5 V ≤ VOUT(S) < 2.0 V
IOUT = 100 mA
f = 1 kHz,
ΔVrip = 0.5 Vrms,
IOUT = 100 mA
VIN = 2.5 V,
VOUT(S) < 1.5 V
ON / OFF pin = ON,
VOUT = 0 V, Ta = +25°C
1.5 V ≤ VOUT(S)
ON / OFF pin = ON,
VIN = 10 V, VOUT = 0.1 V
VIN = 2.5 V,
ON / OFF pin = ON
ON / OFF pin = ON
VOUT(S) < 1.5 V,
A / B / C / D type
1.5 V ≤ VOUT(S),
A / B / C / D type
*1. VOUT(S): Set output voltage
VOUT(E): Actual output voltage
Output voltage when fixing IOUT (= 100 mA) and inputting 2.5 V or VOUT(S) + 1.0 V.
*2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current.
*3. Vdrop = VIN1 − (VOUT3 × 0.98)
VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage.
VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 200 mA.
*4. The dropout voltage is limited by the difference between the input voltage (min. value) and the set output voltage.
In case of 1.0 V ≤ VOUT(S) < 1.5 V: 2.5 V − VOUT(S) = Vdrop
In case of 1.5 V ≤ VOUT(S) < 2.0 V: (VOUT(S) + 1.0 V) − VOUT(S) = 1.0 V
*5. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power
This specification is guaranteed by design.
*6. Soft-start time shows the time period from immediately after power-on or when the ON / OFF pin is set to ON until the
output voltage rises to 99%. Refer to "8. Soft-start function" in " Operation" for details.
17
S-19243xxxA Series
Rev.3.3_00
2.
Types in which output voltage is externally set (S-19243x00, HSOP-8A, HSOP-6, HSNT-8(2030))
Table 26
Item
Adjustment pin output
voltage *1
Output voltage range
Adjustment pin
internal resistance
Output current*2
Dropout voltage*3
Line regulation
Symbol
VVADJ
VROUT
IOUT
Vdrop
ΔVOUT1
ΔVIN • VOUT
ΔVOUT2
Current consumption
during operation
ISS1
Current consumption
during power-off
ISS2
VIN
VSH
VSL
ISH
ISL
Ripple rejection
|RR|
Ishort
Thermal shutdown
Thermal shutdown
release temperature
Discharge shunt
resistance during
power-off
ON / OFF pin
Soft-start time*6
600
kΩ
VOUT = VVADJ, VIN = 2.5 V
VOUT = VVADJ, IOUT = 200 mA, Ta = +25°C
VOUT = VVADJ, 2.5 V ≤ VIN ≤ 10 V,
VOUT = VVADJ, VIN = 2.5 V,
1 mA ≤ IOUT ≤ 200 mA, Ta = +25°C
VOUT = VVADJ, VIN = 2.5 V, RL = 1 kΩ,
determined by VOUT output level
B / D / F / H type
VIN = 10 V,
ON / OFF = 10 V
A / C / E / G type
500*5
*4
mA
V
10
8
0.05
0.2
%/V
8
15
30
mV
8
120
150
μA
9
0.1
10.5
μA
9
2.5
10
V
2.1
V
11
0.6
V
11
−0.1
0.8
2.5
0.1
7.8
μA
μA
11
11
VIN = 10 V, ON / OFF = 0 V
−0.1
0.1
μA
11
60
dB
12
240
mA
10
RVADJ
Load regulation
Input voltage
ON / OFF pin
input voltage "H"
ON / OFF pin
input voltage "L"
ON / OFF pin
input current "H"
ON / OFF pin
input current "L"
Test
Condition
Min.
Typ.
Max. Unit
Circuit
VOUT = VVADJ, VIN = 2.5 V, IOUT = 100 mA,
0.977
1.0
1.023
V
8
1.0
9.0
V
15
VOUT = VVADJ, VIN = 3.0 V, f = 1 kHz,
ΔVrip = 0.5 Vrms, IOUT = 100 mA
VOUT = VVADJ, VIN = 2.5 V, ON / OFF pin = ON,
TSD
170
°C
TSR
135
°C
RLOW
A / B / E / F type
100
Ω
13
A / C / E / G type
1.3
4.0
12
MΩ
11
A / B / C / D type
1.0
ms
14
RPD
tSS
ON / OFF pin = ON
*1. Output voltage when fixing IOUT (= 100 mA) and inputting 2.5 V.
In case of set output voltage (VOUT(S)) = 1.0 V: 2.5 V − VOUT(S) = Vdrop
18
Rev.3.3_00
S-19243xxxA Series
Test Circuits
1.
SSC
VOUT
VIN
*1
V
ON / OFF
A
VSS
Set to ON
Figure 10
VOUT
VIN
SSC
Test Circuit 1
*1
ON / OFF
VSS
Set to VIN or + A
GND
Figure 11
VOUT
VIN
SSC
Test Circuit 2
A
*1
V
ON / OFF
VSS
Set to ON
Figure 12
VOUT
VIN
*1.
SSC
A
Test Circuit 3
*1
V
ON / OFF
VSS
Figure 13
Test Circuit 4
RL
S-19243xxxA Series E / F / G / H type only.
19
S-19243xxxA Series
Rev.3.3_00
VOUT
VIN
SSC
*1
V
ON / OFF
RL
VSS
Set to ON
Figure 14
VOUT
VIN
SSC
Test Circuit 5
A
*1
ON / OFF
V
VSS
Set to GND
Figure 15
VIN
Test Circuit 6
VOUT
V
ON / OFF
VSS
Set to ON
Figure 16
*1.
Test Circuit 7
Oscilloscope
A
Rev.3.3_00
S-19243xxxA Series
2.
SSC
VOUT
VIN
*1
ON / OFF
VADJ
V
A
VSS
Set to ON
Figure 17
VOUT
VIN
SSC
Test Circuit 8
*1
ON / OFF
VADJ
VSS
Set to VIN or + A
GND
Figure 18
VOUT
VIN
SSC
Test Circuit 9
*1
ON / OFF
VADJ
A
V
VSS
Set to ON
Figure 19
Test Circuit 10
VIN
VOUT
SSC
A
*1
ON / OFF
Figure 20
*1.
VADJ
VSS
V
RL
Test Circuit 11
21
S-19243xxxA Series
Rev.3.3_00
VOUT
VIN
SSC
*1
ON / OFF
VADJ
V
RL
VSS
Set to ON
Figure 21
Test Circuit 12
VIN
VOUT
SSC
*1
ON / OFF
VADJ
A
V
VSS
Set to GND
Figure 22
Test Circuit 13
VIN
VOUT
VADJ
ON / OFF
V
Oscilloscope
A
VSS
Set to ON
Figure 23
Test Circuit 14
VIN
VOUT
SSC
*1
ON / OFF
VADJ
VSS
Set to ON
Figure 24
*1.
22
Test Circuit 15
V
A
Rev.3.3_00
S-19243xxxA Series
Standard Circuits
1.
1. 1
Input
VIN
CIN*1
Output
VOUT
CL
ON / OFF
*2
VSS
GND
Single GND
*1.
*2.
CIN is a capacitor for stabilizing the input.
CL is a capacitor for stabilizing the output.
Figure 25
1. 2
Input
VIN
CIN*1
Output
VOUT
ON / OFF
CL
SSC
CSS
*2
*3
VSS
Single GND
*1.
*2.
*3.
GND
CSS is a capacitor for soft-start.
Figure 26
Caution The above connection diagram and constants will not guarantee successful operation. Perform
thorough evaluation including the temperature characteristics with an actual application to set the
constants.
23
S-19243xxxA Series
Rev.3.3_00
2.
2. 1
Input
VIN
CIN
*1
Output
VOUT
Ra
*3
Rb
*3
CL
VADJ
ON / OFF
*2
VSS
GND
Single GND
*1.
*2.
*3.
Ra and Rb are resistors for output voltage external setting.
Figure 27
2. 1
Input
VIN
CIN
*1
ON / OFF
VSS
Ra
*4
Rb
*4
CL
VADJ
*2
SSC
Single GND
*1.
*2.
*3.
*4.
Output
VOUT
CSS
*3
GND
CSS is a capacitor for soft-start.。
Figure 28
constants.
24
Rev.3.3_00
S-19243xxxA Series
Condition of Application
Input capacitor (CIN):
Output capacitor (CL):
A ceramic capacitor with capacitance of 2.2 μF or more is recommended.
Caution Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external
parts. Perform thorough evaluation including the temperature characteristics with an actual
application using the above capacitors to confirm no oscillation occurs.
Selection of Input Capacitor (CIN) and Output Capacitor (CL)
The S-19243xxxA Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation
is stabilized by a ceramic capacitor with capacitance of 2.2 μF or more. When using an OS capacitor, a tantalum
capacitor or an aluminum electrolytic capacitor, the capacitance also must be 2.2 μF or more. However, an oscillation
may occur depending on the equivalent series resistance (ESR).
Moreover, the S-19243xxxA Series requires CIN between the VIN pin and the VSS pin for a stable operation.
Generally, an oscillaiton may occur when a voltage regulator is used under the conditon that the impedance of the
power supply is high.
Note that the output voltage transient characteristics varies depending on the capacitance of CIN and CL and the value
of ESR.
Caution Perform thorough evaluation including the temperature characteristics with an actual application to
select CIN and CL.
Selection of Capacitor for Soft-start (CSS)
The S-19243xxxA Series E / F / G / H type requires the capacitor for soft-start (CSS) between the SSC pin and the
VSS pin. Over the entire temperature range, the S-19243xxxA Series operates stably with a ceramic capacitor of 0.68
nF or more. According to CSS capacitance, the rising speed of the output voltage is adjustable. The time that the
output voltage rises to 99% is 6.0 ms typ. at CSS = 10 nF. The recommended value for applications is 0.68 nF ≤ CSS ≤
168 nF, however; define the values by sufficient evaluation including the temperature characteristics under the usage
condition.
Selection of Resistor for Output Voltage External Setting (Ra, Rb)
The S-19243xxxA Series provides the types in which output voltage can be set via the external resistor. The output
voltage can be set by connecting a resistor (Ra) between the VOUT pin and the VADJ pin, and a resistor (Rb) between
the VADJ pin and the VSS pin.
Depending on the intended output voltage, select Ra and Rb from the range shown in Table 27.
Caution Since the VADJ pin impedance is comparatively high and is easily affected by noise, pay adequate
attention to the wiring pattern.
Table 27
VOUT
1.0 V
1.05 V to 9.0 V
Ra
Connect to VOUT pin
0.1 kΩ to 1.2 MΩ
Rb
Unnecessary
2 kΩ to 200 kΩ
25
S-19243xxxA Series
Rev.3.3_00
Explanation of Terms
1.
Low dropout voltage regulator
This is a voltage regulator which made dropout voltage small by its built-in low on-resistance output transistor.
2.
Output voltage (VOUT)
This voltage is output at an accuracy of ±2.3% when the input voltage, the output current and the temperature are
in a certain condition*1.
*1. Differs depending on the product.
Caution
3.
If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±2.3%.
Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details.
ΔVOUT1
ΔVIN • VOUT
Line regulation
Indicates the dependency of the output voltage against the input voltage. That is, the value shows how much the
output voltage changes due to a change in the input voltage after fixing output current constant.
4.
Load regulation (ΔVOUT2)
Indicates the dependency of the output voltage against the output current. That is, the value shows how much the
output voltage changes due to a change in the output current after fixing input voltage constant.
5.
Dropout voltage (Vdrop)
Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98%
of the output voltage value (VOUT3) at VIN = VOUT(S) + 1.0 V after the input voltage (VIN) is decreased gradually.
26
Rev.3.3_00
S-19243xxxA Series
Operation
1.
Basic operation
Figure 29 shows the block diagram of the S-19243xxxA Series to describe the basic operation.
The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback
resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently,
the regulator starts the operation that keeps VOUT constant without the influence of the input voltage (VIN).
VIN
*1
Current
supply
VOUT
Error amplifier
Vref
Rf
Vfb
Reference voltage
circuit
Rs
VSS
*1.
Parasitic diode
Figure 29
2.
Output transistor
In the S-19243xxxA Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT
pin as the output transistor. In order to keep VOUT constant, the on-resistance of the output transistor varies
appropriately according to the output current (IOUT).
Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the
transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN.
Therefore, be sure that VOUT does not exceed VIN + 0.3 V.
27
S-19243xxxA Series
Rev.3.3_00
3.
ON / OFF pin
The ON / OFF pin controls the internal circuit and the output transistor in order to start and stop the regulator. When
the ON / OFF pin is set to OFF, the internal circuit stops operating and the output transistor between the VIN pin
and the VOUT pin is turned off, reducing current consumption significantly.
Note that the current consumption increases when a voltage of 0.6 V to VIN − 0.3 V is applied to the ON / OFF pin.
The ON / OFF pin is configured as shown in Figure 30 and Figure 31.
3. 1
S-19243xxxA Series A / C / E / G type
Since the ON / OFF pin is internally pulled down to the VSS pin in the floating status, the VOUT pin is set to the
VSS level.
Refer to " Electrical Characteristics" for the ON / OFF pin current.
3. 2
S-19243xxxA Series B / D / F / H type
Since the ON / OFF pin is neither pulled down nor pulled up, do not use these types in the floating status. When
not using the ON / OFF pin, connect it to the VIN pin.
Table 28
Product Type
A/B/C/D
E/F/G/H
A/B/C/D
E/F/G/H
ON / OFF Pin
Internal Circuit
VOUT Pin Voltage
*1
"H" : ON
Operate
Constant value
"L" : OFF
Stop
Pulled down to VSS*3
Current Consumption
ISS1*2
ISS2
*1. The constant value is output due to the regulating based on the set output voltage value.
*2. Note that the IC's current consumption increases as much as current flows into the pull-down resistor when
the ON / OFF pin is connected to the VIN pin and the S-19243xxxA Series A / C / E / G type is operating (refer
to Figure 30).
*3. The VOUT pin voltage of the S-19243xxxA Series A / B / E / F type is pulled down to VSS due to combined
resistance (RLOW = 100 Ω typ.) of the discharge shunt circuit and the feedback resistors, and a load.
VIN
ON / OFF
ON / OFF
VSS
Figure 30 S-19243xxxA Series
A / C / E / G type
28
VIN
VSS
Figure 31 S-19243xxxA Series
B / D / F / H type
Rev.3.3_00
S-19243xxxA Series
4.
Discharge shunt function (S-19243xxxA Series A / B / E / F type)
The S-19243xxxA Series A / B / E / F type has a built-in discharge shunt circuit to discharge the output capacitance.
The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level.
(1) The ON / OFF pin is set to OFF level.
(2) The output transistor is turned off.
(3) The discharge shunt circuit is turned on.
(4) The output capacitor discharges.
Since the S-19243xxxA Series C / D / G / H type does not have a discharge shunt circuit, the VOUT pin is set to the
VSS level through several hundred kΩ internal divided resistors between the VOUT pin and the VSS pin. The
S-19243xxxA Series A / B / E / F type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt
circuit.
S-19243xxxA Series
Output transistor: OFF
*1
VOUT
VIN
Discharge shunt circuit
: ON
*1
ON / OFF
ON / OFF circuit
Output
capacitor
(CL)
ON / OFF pin: OFF
Current flow
GND
VSS
*1. Parasitic diode
Figure 32
5.
Pull-down resistor (S-19243xxxA Series A / C / E / G type)
The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS
level.
Note that the IC's current consumption increases as much as current flows into the pull-down resistor of
4.0 MΩ typ. when the ON / OFF pin is connected to the VIN pin.
29
S-19243xxxA Series
Rev.3.3_00
6.
The S-19243xxxA Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor.
When the VOUT pin is shorted to the VSS pin, that is, at the time of the output short-circuit, the output current is
limited to 240 mA typ. due to the overcurrent protection circuit operation. The S-19243xxxA Series restarts
regulating when the output transistor is released from the overcurrent status.
Caution
7.
This overcurrent protection circuit does not work as for thermal protection. For example, when
the output transistor keeps the overcurrent status long at the time of output short-circuit or
due to other reasons, pay attention to the conditions of the input voltage and the load current
so as not to exceed the power dissipation.
The S-19243xxxA Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature
increases to 170°C typ., the thermal shutdown circuit becomes the detection status, and the regulating is stopped.
When the junction temperature decreases to 135°C typ., the thermal shutdown circuit becomes the release status,
and the regulator is restarted.
If the thermal shutdown circuit becomes the detection status due to self-heating, the regulating is stopped and VOUT
decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal
shutdown circuit becomes release status when the temperature of the IC decreases, and the regulating is restarted
after the soft-start operation is finished, thus the self-heating is generated again. Repeating this procedure makes
the waveform of VOUT into a pulse-like form. This phenomenon continues unless decreasing either or both of the
input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient
temperature. Note that the product may suffer physical damage such as deterioration if the above phenomenon
occurs continuously.
Caution
When the heat radiation of the application is not in a good condition, the self-heating cannot be
limited immediately, and the IC may suffer physical damage. Perform thorough evaluation with
an actual application to confirm no problems happen.
Table 29
Thermal Shutdown Circuit
Release: 135°C typ.*1
Detection: 170°C typ.*1
*1.
*2.
*3.
30
VOUT Pin Voltage
Constant value*2
The VOUT pin voltage is pulled down to VSS due to the feedback resistors (Rs and Rf) and a load.
Rev.3.3_00
S-19243xxxA Series
8.
Soft-start function
The S-19243xxxA Series has the built-in soft-start circuit to suppress the inrush current and overshoot of the output
voltage generated at power-on or at the time when the ON / OFF pin is set to ON. The soft-start time (tSS) is the
time period from when the output voltage rises slowly immediately after power-on or when the ON / OFF pin is set
to ON until when the output voltage rises to 99%.
Input voltage
(VIN, VON / OFF)
VIN
SSC pin voltage*1
(VSSC)
VOUT(E) × 0.99
Output voltage
(VOUT(E))
Soft-start time (tSS)
t [ms]
*1.
Figure 33
31
S-19243xxxA Series
Rev.3.3_00
8. 1
By charging the built-in capacitor via the built-in constant current source, tSS = 1.0 ms typ. is generated.
8. 2
tSS can be adjusted by the external capacitor (CSS) connected between the SSC pin and the VSS pin, and is
calculated by using the following calculation.
tSS [ms] = Soft-start coefficient*1 [ms / nF] × CSS [nF] + tD0*2 [ms]
*1. It is determined by charging the built-in constant current (approx. 2.1 μA) to CSS.
*2. The delay time of internal capacitance.
When the CSS value is sufficiently large, the tD0 value can be disregarded. When the ON / OFF pin is set to OFF,
the electrical charge charged in CSS is discharged by the transistor of the discharge shunt circuit.
Table 30
Operation Temperature
Min.
Typ.
Max.
Tj = +150°C
0.391
0.528
0.691
Tj = +125°C
0.393
0.534
0.690
Tj = +25°C
0.436
0.574
0.704
Tj = −40°C
0.467
0.604
0.717
Table 31
Delay Time of Internal Capacitnace (tD0)
Caution
32
Soft-start Coefficient [ms / nF]
Min.
Typ.
Max.
0.032 ms
0.047 ms
0.108 ms
The above calculation will not guarantee successful operation. Perform thorough evaluation using
the actual application including the temperature characteristics under the actual usage conditions
to determine CSS capacitance. Refer to " Condition of Application" and " Characteristics (Typical
Data)" for details.
Rev.3.3_00
S-19243xxxA Series
9.
between the VADJ pin and the VSS pin.
The output voltage is determined by the following formulas.
VOUT = 1.0 + Ra × la ···················· (1)
By substituting Ia = IVADJ + 1.0 / Rb to above formula (1),
VOUT = 1.0 + Ra × (IVADJ + 1.0 / Rb) = 1.0 × (1.0 + Ra / Rb) + Ra × IVADJ ······· (2)
In above formula (2), Ra × IVADJ is a factor for the output voltage error.
Whether the output voltage error is minute is judged depending on the following (3) formula.
By substituting IVADJ = 1.0 / RVADJ to Ra × IVADJ
VOUT = 1.0 × (1.0 + Ra / Rb) + 1.0 × Ra / RVADJ ················ (3)
If RVADJ is sufficiently larger than Ra, the error is judged as minute.
VOUT
Ia
VIN
IVADJ
VADJ
RVADJ
Ra
VOUT
1.0 V
Ib
Rb
VSS
Figure 34
The following expression is in order to determine VOUT = 6.0 V.
If Rb = 2 kΩ, substitute RVADJ = 600 kΩ typ. into (3),
Ra = (6.0 / 1.0 − 1) × ((2 k × 600 k) / (2 k + 600 k)) ≅ 9.97 kΩ
Caution The above connection diagrams and constants will not guarantee successful operation. Perform
thorough evaluation using the actual application to set the constants.
33
S-19243xxxA Series
Rev.3.3_00
Precautions
• Generally, when a voltage regulator is used under the condition that the load current value is small (1 mA or less),
the output voltage may increase due to the leakage current of an output transistor.
• Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may
• Generally, when the ON / OFF pin is used under the condition of OFF, the output voltage may increase due to the
• Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an
oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual
application to select CIN.
• Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The
following use conditions are recommended in the S-19243xxxA Series; however, perform thorough evaluation
including the temperature characteristics with an actual application to select CIN and CL.
Input capacitor (CIN): A ceramic capacitor with capacitance of 2.2 μF or more is recommended.
Output capacitor (CL): A ceramic capacitor with capacitance of 2.2 μF or more is recommended.
• Generally, in a voltage regulator, the values of an overshoot and an undershoot
depending on the variation factors of input voltage start-up, input voltage fluctuation,
capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which
stable operation. Perform thorough evaluation including the temperature characteristics
select CIN and CL.
in the output voltage vary
load fluctuation etc., or the
may cause a problem to the
• Generally, in a voltage regulator, an overshoot may occur in the output voltage momentarily if the input voltage
steeply changes when the input voltage is started up, the soft-start operation is performed, the input voltage
fluctuates, etc. Perform thorough evaluation including the temperature characteristics with an actual application to
• Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the
absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the
capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a
series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection
diode between the VOUT pin and the VSS pin.
• If the input voltage is started up steeply under the condition that the capacitance of CL is large, the thermal
shutdown circuit may be in the detection status by self-heating due to the charge current to CL.
• Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does
not exceed the power dissipation.
• Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic
protection circuit.
• When considering the output current value that the IC is able to output, make sure of the output current value
specified in Table 25 and Table 26 in " Electrical Characteristics" and footnote *5 of the table.
• Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that
the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and
the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC.
• When setting the output voltage by using an external resistor, connect a resistor (Ra) between the VOUT pin and the
VADJ pin and a resistor (Rb) between the VADJ pin and the VSS pin close to the respective pins.
• In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs
according to the condition of the application, perform thorough evaluation with an actual application to confirm no
problems happen.
• ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products
including this IC of patents owned by a third party.
34
Rev.3.3_00
S-19243xxxA Series
Output voltage vs. Output current (When load current increases) (Ta = +25°C)
VOUT = 1.0 V
VOUT [V]
1. 1
1. 2
VOUT = 3.0 V
1.2
3.6
1.0
3.0
0.8
VIN = 2.5 V
0.6
VIN = 3.0 V
VOUT [V]
1.
0.4
0.2
VIN = 3.5 V
VIN = 4.0 V
VIN = 5.0 V
2.4
1.8
1.2
0.6
0.0
0.0
400
600
IOUT [mA]
800
200
400
600
IOUT [mA]
800
1000
VOUT = 6.0 V
1. 3
7.2
VOUT [V]
6.0
VIN = 6.5 V
VIN = 7.0 V
VIN = 8.0 V
4.8
3.6
2.4
1.2
0.0
Remark
200
400
600
800
1000
IOUT [mA]
In determining the output current, attention should be paid to the following.
1. The minimum output current value and footnote *5 of Table 25 and Table 26 in " Electrical Characteristics"
2. Power dissipation
Output voltage vs. Input voltage (Ta = +25°C)
VOUT [V]
2. 1
VOUT = 1.0 V
2. 2
3.1
1.0
3.0
0.9
2.9
0.8
IOUT = 1 mA
IOUT = 50 mA
IOUT = 100 mA
0.7
0.6
IOUT = 1 mA
IOUT = 50 mA
IOUT = 100 mA
2.8
2.7
2.6
0.5
2.5
VOUT = 3.0 V
1.1
VOUT [V]
2.
1
2
3
4
5 6
VIN [V]
7
8
9 10
2
3
4
5
6
7
VIN [V]
8
9
10
VOUT = 6.0 V
6.1
VOUT [V]
6.0
5.9
5.8
5.7
IOUT = 1 mA
IOUT = 50 mA
IOUT = 100 mA
5.6
5.5
5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0
VIN [V]
35
S-19243xxxA Series
Rev.3.3_00
3.
Dropout voltage vs. Output current
3. 1
VOUT = 3.0 V
3. 2
0.40
0.40
Tj = +150°C
Tj = +125°C
Tj = +25°C
Tj = −40°C
0.20
0.10
200
300 400
IOUT [mA]
500
Vdrop [V]
VOUT = 3.0 V
4. 2
200
300 400
IOUT [mA]
500
600
0.30
0.25
0.25
0.20
IOUT = 300 mA
0.15
0.10
IOUT = 30 mA
0.00
−40 −25
50 75 100 125 150
Tj [°C]
0.40
0.30
0.20
IOUT = 500 mA
IOUT = 300 mA
IOUT = 10 mA
0.10
0.00
2.5
3.0
3.5
4.0 4.5
VOUT [V]
5.0
5.5
0.20
IOUT = 300 mA
0.15
0.10
IOUT = 30 mA
0.05
Dropout voltage vs. Set output voltage (Ta = +25°C)
Vdrop [V]
VOUT = 6.0 V
0.30
0.05
36
0.00
600
Dropout voltage vs. Junction temperature
4. 1
5.
0.20
0.10
Vdrop [V]
4.
Tj = +150°C
Tj = +125°C
Tj = +25°C
Tj = −40°C
0.30
Vdrop [V]
Vdrop [V]
0.30
0.00
VOUT = 6.0 V
6.0
0.00
−40 −25
50 75 100 125 150
Tj [°C]
Rev.3.3_00
S-19243xxxA Series
6.
Output voltage vs. Junction temperature
6. 1
VOUT = 1.0 V
6. 2
VOUT = 3.0 V
VIN = 2.5 V
VIN = 4.0 V
3.30
3.20
1.05
VOUT [V]
VOUT [V]
1.10
1.00
0.95
3.10
3.00
2.90
2.80
0.90
−40 −25
2.70
−40 −25
50 75 100 125 150
Tj [°C]
50 75 100 125 150
Tj [°C]
VOUT = 6.0 V
6. 3
VIN = 7.0 V
VOUT [V]
6.60
6.30
6.00
5.70
5.40
−40 −25
25
50 75 100 125 150
Tj [°C]
Current consumption during operation vs. Input voltage (When ON / OFF pin is ON, no load)
ISS1 [μA]
7. 1
VOUT = 1.0 V
7. 2
160
120
120
Tj = −40°C
Tj = +25°C
Tj = +125°C
Tj = +150°C
80
40
VOUT = 3.0 V
160
ISS1 [μA]
7.
2
3
4
5 6
VIN [V]
Tj = −40°C
80
Tj = +25°C
Tj = +125°C
Tj = +150°C
40
7
8
9 10
8
9 10
2
3
4
5 6
VIN [V]
7
8
9 10
VOUT = 6.0 V
160
Tj = +150°C
ISS1 [μA]
120
Tj = +125°C
80
Tj = +25°C
40
Tj = −40°C
2
3
4
5 6
VIN [V]
7
37
S-19243xxxA Series
Rev.3.3_00
8.
Current consumption during operation vs. Junction temperature
8. 1
VOUT = 1.0 V
8. 2
VOUT = 3.0 V
VIN = 4.0 V
160
160
120
120
ISS1 [μA]
ISS1 [μA]
VIN = 2.5 V
80
40
80
40
−40 −25
−40 −25
50 75 100 125 150
Tj [°C]
50 75 100 125 150
Tj [°C]
VOUT = 6.0 V
8. 3
VIN = 7.0 V
160
ISS1 [μA]
120
80
40
−40 −25
50 75 100 125 150
Tj [°C]
Current consumption during operation vs. Output current (Ta = +25°C)
9.
9. 1
VOUT = 1.0 V
9. 2
VIN = 2.5 V
250
250
200
200
150
100
50
200
300 400
IOUT [mA]
500
600
VIN = 7.0 V
300
ISS1 [μA]
250
200
150
100
50
38
150
100
50
VOUT = 6.0 V
VIN = 4.0 V
300
ISS1 [μA]
ISS1 [μA]
300
VOUT = 3.0 V
200
300 400
IOUT [mA]
500
600
200
300 400
IOUT [mA]
500
600
Rev.3.3_00
S-19243xxxA Series
10.
10. 1
Ripple rejection (Ta = +25°C)
10. 2
VOUT = 1.0 V
VOUT = 3.0 V
100
IOUT = 1 mA
IOUT = 30 mA
IOUT = 100 mA
80
60
40
10. 3
100
1k
10k
Frequency [Hz]
100k
VIN = 4.0 V, CL = 2.2 μF
Ripple Rejection [dB]
VIN = 3.0 V, CL = 2.2 μF
1M
100
IOUT = 1 mA
IOUT = 30 mA
IOUT = 100 mA
80
60
40
100
1k
10k
Frequency [Hz]
100k
1M
VOUT = 6.0 V
VIN = 7.0 V, CL = 2.2 μF
100
IOUT = 1 mA
IOUT = 30 mA
IOUT = 100 mA
80
60
40
100
1k
10k
Frequency [Hz]
100k
1M
39
S-19243xxxA Series
Rev.3.3_00
Reference Data
Characteristics of input transient response (Ta = +25°C)
0.0
1.05
1.00
3.15
2.0
VIN
VIN [V]
VOUT [V]
1.10
1. 2 VOUT = 3.0 V
IOUT = 100 mA, CL = 2.2 μF, VIN = 4.0 V ↔ 5.0 V, tr = tf = 5.0 μs
6.0
3.20
−2.0
VOUT
−4.0
0.95
t [μs]
8.0
7.0
VIN
6.0
6.10
6.00
5.0
VOUT
4.0
5.90
t [μs]
40
VIN [V]
VOUT [V]
6.20
4.0
VIN
2.0
3.05
3.00
0.0
−2.0
VOUT
2.95
−4.0
2.90
−6.0
t [μs]
1. 3 VOUT = 6.0 V
IOUT = 100 mA, CL = 2.2 μF, VIN = 7.0 V ↔ 8.0 V, tr = tf = 5.0 μs
6.40
9.0
6.30
3.10
VIN [V]
1. 1 VOUT = 1.0 V
IOUT = 100 mA, CL = 2.2 μF, VIN = 2.5 V ↔ 3.5 V, tr = tf = 5.0 μs
1.15
4.0
VOUT [V]
1.
Rev.3.3_00
S-19243xxxA Series
Characteristics of load transient response (Ta = +25°C)
2. 1 VOUT = 1.0 V
VIN = 2.5 V, CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA
1.20
150
1.00
1.30
50
1.20
VOUT
−50
1.10
1.00
400
−200
0.95
−100
0.90
−400
0.90
−150
0.80
−600
t [μs]
2. 2 VOUT = 3.0 V
VIN = 4.0 V, CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA
3.20
150
3.10
3.05
3.00
IOUT
VIN = 4.0 V, CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA
3.40
600
100
3.30
50
3.20
IOUT [mA]
VOUT [V]
3.15
VOUT [V]
VOUT
t [μs]
VOUT
−50
3.10
3.00
400
200
IOUT
VOUT
−200
2.95
−100
2.90
−400
2.90
−150
2.80
−600
t [μs]
t [μs]
2. 3 VOUT = 6.0 V
VIN = 7.0 V, CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA
6.20
150
6.05
100
6.50
50
6.30
VOUT
6.00
−50
5.95
5.90
t [μs]
VOUT [V]
6.10
IOUT
VIN = 7.0 V, CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA
6.70
600
IOUT [mA]
6.15
VOUT [V]
200
IOUT
IOUT [mA]
1.05
100
IOUT [mA]
1.10
IOUT
IOUT [mA]
VOUT [V]
VOUT [V]
1.15
VIN = 2.5 V, CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA
1.40
600
6.10
400
200
IOUT
VOUT
−200
−100
5.70
−400
−150
5.50
−600
IOUT [mA]
2.
t [μs]
41
S-19243xxxA Series
Rev.3.3_00
3. Transient response characteristics of ON / OFF pin (Ta = +25°C) (S-19243xxxA Series A / B / C / D type)
VOUT = 1.0 V
VIN = 2.5 V, CIN = CL = 2.2 μF,
IOUT = 100 mA, VON / OFF = 0 V → 2.5 V
5.00
3.0
4.00
2.0
8.00
4.0
3.00
1.0
6.00
2.0
2.00
1.00
0.00
−1.00
3. 2
0.0
VON / OFF
−1.0
VOUT
VOUT = 3.0 V
VIN = 4.0 V, CIN = CL = 2.2 μF,
IOUT = 100 mA, VON / OFF = 0 V → 4.0 V
10.00
VOUT [V]
VOUT [V]
3. 1
4.00
2.00
−2.0
0.00
−3.0
−2.00
0.0
VON / OFF
−2.0
−4.0
VOUT
t [μs]
−6.0
t [μs]
3. 3
VOUT [V]
VOUT = 6.0 V
VIN = 7.0 V, CIN = CL = 2.2 μF,
IOUT = 100 mA, VON / OFF = 0 V → 7.0 V
20.00
9.0
16.00
6.0
12.00
3.0
8.00
4.00
0.00
−4.00
0.0
V ON / OFF
−3.0
−6.0
VOUT
−9.0
t [μs]
4.
Soft-start time vs. Characteristics of operation ambient temperature
VIN = 2.5 V, VON / OFF = 0 V → 2.5 V (VOUT(S) < 1.5 V),
VIN = VOUT + 1.0 V, VON / OFF = 0 V → VOUT + 1.0 V (1.5 V ≤ VOUT(S)),
CIN = CL = 2.2 μF, CSS = 10 nF
10.0
tSS [ms]
8.0
VOUT = 1.0 V
6.0
4.0
2.0
0.0
−40 −25
5.
VOUT = 6.0 V
VOUT = 3.0 V
50 75 100 125 150
Ta [°C]
Soft-start time vs. Characteristics of soft-start capacitance (Ta = +25°C)
tSS [ms]
CIN = CL = 2.2 μF
100.0
VOUT = 1.0 V
10.0
VOUT = 3.0 V
1.0
VOUT = 6.0 V
0.1
0.1
42
1.0
10.0
CSS [nF]
100.0
1000.0
6.0
Rev.3.3_00
S-19243xxxA Series
Inrush current characteristics (Ta = +25°C) (S-19243xxxA Series E / F / G / H type)
VOUT = 1.0 V
VIN = 2.5 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 1 nF
1200
3.00
VON / OFF
1000
2.00
1.00
VOUT
0.00
−1.00
−2.00
IIN
200
VIN = 2.5 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 10 nF
1200
3.00
VON / OFF
1000
2.00
1.00
VOUT
0.00
−1.00
800
600
400
−2.00
IIN
200
−3.00
t [μs]
t [μs]
VIN = 4.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 1 nF
1200
6.00
VON / OFF
1000
4.00
VIN = 4.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 10 nF
1200
6.00
VON / OFF
1000
4.00
VOUT = 3.0 V
VOUT
2.00
800
0.00
600
−2.00
400
−4.00
IIN
200
VOUT, VON / OFF [V]
6. 2
VOUT, VON / OFF [V]
600
400
−3.00
−6.00
VOUT
2.00
800
0.00
600
−2.00
400
−4.00
IIN
200
−6.00
t [μs]
t [μs]
VIN = 7.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 1 nF
1200
8.00
VIN = 7.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 10 nF
1200
8.00
6. 3
VOUT, VON / OFF [V]
800
VOUT = 6.0 V
6.00
VOUT
4.00
1000
800
2.00
600
0.00
400
−2.00
IIN
200
−4.00
t [μs]
VOUT, VON / OFF [V]
VOUT, VON / OFF [V]
6. 1
VOUT, VON / OFF [V]
6.
6.00
VOUT
4.00
1000
800
2.00
600
0.00
400
−2.00
IIN
200
−4.00
t [μs]
43
S-19243xxxA Series
Rev.3.3_00
7.
Output capacitance vs. Characteristics of discharge time (Ta = +25°C)
VIN = 2.5 V, VON / OFF = 2.5 V → VSS (VOUT(S) < 1.5 V),
VIN = VOUT + 1.0 V, VON / OFF = VOUT + 1.0 V → VSS (1.5 V ≤ VOUT(S)),
IOUT = 1 mA, tf = 1 μs
30
25
VOUT(S) = 1.0 V
tDSC [ms]
VSS
15
VOUT(S) = 3.0 V
10
tDSC
VOUT
VOUT(S) = 6.0 V
5
1 μs
VON / OFF
60
80
CL [μF]
100
120
VOUT × 10%
Figure 35 S-19243xxxA Series A / B type
(with discharge shunt function)
8.
Figure 36
Measurement Condition of Discharge Time
Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C)
CIN = CL = 2.2 μF
100
VIN
RESR [Ω]
VOUT
CIN
Stable
ON / OFF
S-19243xxxA
Series
SSC
VSS
500
CSS
CL
*1
RESR
IOUT [mA]
*1.
Figure 37
44
CL: TDK Corporation CGA6M2X8R1E225K (2.2 μF)
Figure 38
Rev.3.3_00
S-19243xxxA Series
Power Dissipation
TO-252-5S(A)
HSOP-8A
Tj = +150°C max.
E
4
D
3 C
2 B
A
1
50
75
100
125
150
Tj = +150°C max.
5
Power dissipation (PD) [W]
5
D
3 C
2
B
1 A
E
4
Ambient temperature (Ta) [°C]
100
125
150
Board
Power Dissipation (PD)
Board
A
1.45 W
A
1.20 W
B
2.08 W
B
1.69 W
C
3.29 W
C
3.21 W
D
4.03 W
D
3.38 W
E
4.46 W
E
4.03 W
175
SOT-89-5
Tj = +150°C max.
4
E
3
D
2 B
1 A
50
75
100
125
150
175
Tj = +150°C max.
5
5
75
HSOP-6
4
E
3
D
2
B
1
A
50
75
100
125
150
175
Board
Board
A
1.30 W
A
1.05 W
B
C
D
1.69 W
1.49 W
2.84 W
B
C
D
E
3.05 W
E
3.57 W
2.72 W
45
S-19243xxxA Series
Rev.3.3_00
HSNT-8(2030)
Tj = +150°C max.
5
E
4
C
3
D
2
B
1
A
50
75
100
125
150
46
Board
A
0.69 W
B
0.93 W
C
3.13 W
D
2.98 W
E
3.91 W
175
TO-252-5S Test Board
(1) Board A
IC Mount Area
Item
Size [mm]
Material
Number of copper foil layer
Copper foil layer [mm]
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
2
Land pattern and wiring for testing: t0.070
74.2 x 74.2 x t0.070
(2) Board B
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
74.2 x 74.2 x t0.035
(3) Board C
Item
Size [mm]
Material
Thermal via
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
Number: 4
Diameter: 0.3 mm
No. TO252-5S-A-Board-SD-1.0
enlarged view
ABLIC Inc.
(4) Board D
IC Mount Area
Item
Size [mm]
Material
Specification
114.3 x 76.2 x t1.6
FR-4
4
Thermal via
2
Pattern for heat radiation: 2000mm t0.070
Item
Size [mm]
Material
Specification
114.3 x 76.2 x t1.6
FR-4
4
1
2
3
4
(5) Board E
Thermal via
1
2
3
4
2
Number: 4
Diameter: 0.3 mm
enlarged view
ABLIC Inc.
HSOP-8A Test Board
(1) Board A
IC Mount Area
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
2
(2) Board B
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
(3) Board C
Item
Size [mm]
Material
Thermal via
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
Number: 4
Diameter: 0.3 mm
enlarged view
No. HSOP8A-A-Board-SD-1.0
ABLIC Inc.
HSOP-8A Test Board
(4) Board D
IC Mount Area
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
Pattern for heat radiation: 2000mm2 t0.070
Item
Size [mm]
Material
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
Number: 4
Diameter: 0.3 mm
(5) Board E
Thermal via
enlarged view
ABLIC Inc.
HSOP-6 Test Board
IC Mount Area
(1) Board A
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
2
1
2
3
4
Thermal via
(2) Board B
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
4
1
2
3
4
Thermal via
(3) Board D
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
4
1
2
3
4
Thermal via
(4) Board E
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
Number: 4
Diameter: 0.3 mm
No. HSOP6-A-Board-SD-1.0
enlarged view
ABLIC Inc.
SOT-89-5 Test Board
IC Mount Area
(1) Board A
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
2
1
2
3
4
Thermal via
(2) Board B
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
4
1
2
3
4
Thermal via
(3) Board D
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
4
2
3
4
1
Thermal via
(4) Board E
Item
Specification
Size [mm]
114.3 x 76.2 x t1.6
Material
FR-4
Thermal via
4
1
2
3
4
Number: 4
Diameter: 0.3 mm
No. SOT895-A-Board-SD-1.0
enlarged view
ABLIC Inc.
HSNT-8(2030) Test Board
IC Mount Area
(1) Board A
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
2
(2) Board B
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
(3) Board C
Item
Size [mm]
Material
Thermal via
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
Number: 4
Diameter: 0.3 mm
enlarged view
No. HSNT8-A-Board-SD-2.0
ABLIC Inc.
IC Mount Area
(4) Board D
Item
Size [mm]
Material
Specification
114.3 x 76.2 x t1.6
FR-4
4
Thermal via
2
Item
Size [mm]
Material
Specification
114.3 x 76.2 x t1.6
FR-4
4
1
2
3
4
enlarged view
(5) Board E
Thermal via
1
2
3
4
2
Number: 4
Diameter: 0.3 mm
enlarged view
ABLIC Inc.
6.5±0.2
5.8
1.2±0.1
(5.2)
0.80
0.6±0.1
0.22±0.05
1.27
No. VA005-A-P-SD-2.0
TITLE
TO-252-5S-A-PKG Dimensions
VA005-A-P-SD-2.0
No.
ANGLE
UNIT
mm
ABLIC Inc.
4.0±0.1(10 pitches:40.0±0.2)
2.0±0.05
+0.1
ø1.5 -0.0
0.2±0.05
ø1.7±0.1
8.0±0.1
1.5±0.1
6.9±0.1
5
1
Feed direction
No. VA005-A-C-SD-1.0
TITLE
TO-252-5S-A-C a r r i e r T a p e
No.
VA005-A-C-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
60°
13.4±1.0
Enlarged drawing in the central part
ø21±0.8
17.4±1.0
2±0.5
ø13±0.2
No. VA005-A-R-SD-1.0
TO-252-5S-A-Reel
TITLE
VA005-A-R-SD-1.0
No.
ANGLE
UNIT
QTY.
mm
ABLIC Inc.
4,000
6.0
0.8
2.54
1.27
No. VA005-A-L-SD-1.0
TITLE
TO-252-5S-A
-Land Recommendation
No.
VA005-A-L-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
5.02±0.2
8
5
1
4
1.27
3.0
5
0.20±0.05
4
8
1
0.4±0.05
No. FH008-A-P-SD-2.0
TITLE
HSOP8A-A-PKG Dimensions
No.
FH008-A-P-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
2.0±0.05
ø1.5 +0.1
-0.0
0.3±0.05
ø2.0±0.05
8.0±0.1
2.1±0.1
6.7±0.1
1
8
4
5
Feed direction
No. FH008-A-C-SD-1.0
TITLE
HSOP8A-A-Carrier Tape
FH008-A-C-SD-1.0
No.
ANGLE
UNIT
mm
ABLIC Inc.
17.4±1.0
13.4±1.0
ø21±0.8
2±0.5
ø13±0.2
No. FH008-A-R-SD-1.0
TITLE
HSOP8A-A-Reel
No.
FH008-A-R-SD-1.0
QTY.
ANGLE
UNIT
mm
ABLIC Inc.
4,000
0.76
3.2
1.27
1.27
1.27
No. FH008-A-L-SD-1.0
TITLE
HSOP8A-A
No.
FH008-A-L-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
5.02±0.2
6
1
0.4±0.05
5
4
2
3
0.20±0.05
1.67±0.05
1.91
1.91
No. FH006-A-P-SD-2.1
TITLE
HSOP6-A-PKG Dimensions
No.
FH006-A-P-SD-2.1
ANGLE
UNIT
mm
ABLIC Inc.
2.0±0.05
ø1.55±0.05
0.3±0.05
ø2.0±0.05
8.0±0.1
2.1±0.1
6.7±0.1
1
6
3
4
Feed direction
No. FH006-A-C-SD-2.0
TITLE
HSOP6-A-Carrier Tape
No.
FH006-A-C-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
60°
2±0.5
13.5±0.5
ø21±0.8
2±0.5
ø13±0.2
No. FH006-A-R-S1-1.0
TITLE
HSOP6-A-Reel
No.
FH006-A-R-S1-1.0
ANGLE
UNIT
QTY.
mm
ABLIC Inc.
4,000
2.03
0.76
1.91
1.91
No. FH006-A-L-SD-2.0
TITLE
HSOP6-A
No.
FH006-A-L-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
4.5±0.1
1.5±0.1
1.6±0.2
5
4
0.3
45°
1
2
3
1.5±0.1 1.5±0.1
0.4±0.05
0.4±0.1
0.4±0.1
0.45±0.1
No. UP005-A-P-SD-2.0
TITLE
SOT895-A-PKG Dimensions
No.
UP005-A-P-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
4.0±0.1(10 pitches : 40.0±0.2)
ø1.5 +0.1
-0
2.0±0.05
+0.1
ø1.5 -0
0.3±0.05
8.0±0.1
2.0±0.1
4.75±0.1
3 2 1
4
5
Feed direction
No. UP005-A-C-SD-2.0
TITLE
SOT895-A-Carrier Tape
UP005-A-C-SD-2.0
No.
ANGLE
UNIT
mm
ABLIC Inc.
16.5max.
13.0±0.3
(60°)
(60°)
No. UP005-A-R-SD-1.1
TITLE
SOT895-A-Reel
No.
UP005-A-R-SD-1.1
ANGLE
UNIT
QTY.
mm
ABLIC Inc.
1,000
2.0±0.1
8
5
(1.70)
1
4
+0.05
0.08 -0.02
0.5
0.23±0.1
The heat sink of back side has different electric
potential depending on the product.
Confirm specifications of each product.
Do not use it as the function of electrode.
No. PP008-A-P-SD-2.0
TITLE
HSNT-8-A-PKG Dimensions
No.
PP008-A-P-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
+0.1
ø1.5 -0
2.0±0.05
4.0±0.1
0.25±0.05
+0.1
ø1.0 -0
0.60±0.05
4.0±0.1
2.3±0.05
4 321
5 6 78
Feed direction
No. PP008-A-C-SD-1.0
TITLE
HSNT-8-A-Carrier Tape
No.
PP008-A-C-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
+1.0
9.0 - 0.0
11.4±1.0
ø13±0.2
(60°)
(60°)
No. PP008-A-R-SD-1.0
HSNT-8-A-Reel
TITLE
No.
PP008-A-R-SD-1.0
ANGLE
QTY.
UNIT
mm
ABLIC Inc.
5,000
1.6
0.30
0.50
No. PP008-A-L-SD-1.0
TITLE
No.
HSNT-8-A
PP008-A-L-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
Disclaimers (Handling Precautions)
1.
All the information described herein (product data, specifications, figures, tables, programs, algorithms and
application circuit examples, etc.) is current as of publishing date of this document and is subject to change without
notice.
2.
The circuit examples and the usages described herein are for reference only, and do not guarantee the success of
any specific mass-production design.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products
described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other
right due to the use of the information described herein.
3.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described
herein.
4.
Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute
maximum ratings, operation voltage range and electrical characteristics, etc.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to
the use of the products outside their specified ranges.
5.
Before using the products, confirm their applications, and the laws and regulations of the region or country where they
are used and verify suitability, safety and other factors for the intended use.
6.
When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related
laws, and follow the required procedures.
7.
The products are strictly prohibited from using, providing or exporting for the purposes of the development of
weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands
caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear,
biological or chemical weapons or missiles, or use any other military purposes.
8.
The products are not designed to be used as part of any device or equipment that may affect the human body, human
life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control
systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment,
aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by
ABLIC, Inc. Do not apply the products to the above listed devices and equipments.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of
the products.
9.
In general, semiconductor products may fail or malfunction with some probability. The user of the products should
therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread
prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social
damage, etc. that may ensue from the products' failure or malfunction.
The entire system in which the products are used must be sufficiently evaluated and judged whether the products are
allowed to apply for the system on customer's own responsibility.
10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the
product design by the customer depending on the intended use.
11. The products do not affect human health under normal use. However, they contain chemical substances and heavy
metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be
careful when handling these with the bare hands to prevent injuries, etc.
12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used.
13. The information described herein contains copyright information and know-how of ABLIC Inc. The information
described herein does not convey any license under any intellectual property rights or any other rights belonging to
ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this
document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express
permission of ABLIC Inc.
14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales
representative.
15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into
the English language and the Chinese language, shall be controlling.
2.4-2019.07
www.ablic.com
