PD30CNB20NASA
PD30CNB20NASA
    CARLOGAVAZZI
    SENSOR REFLECTIVE 200MM NPN
PD30CNB20NASA 数据手册
Photoelectrics Diffuse-reflective, Background Suppression Type PD30CNB20....SA • Miniature sensor range • Range: 200 mm • Sensitivity adjustment by potentiometer • Modulated, red light 625 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Exelent colour matching Product Description Ordering Key The PD30CNB20 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Sensitivity adjustment The potentiometer function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is NO and NC output. PD30CNB20NAM5SA Type Selection Housing Range Connection WxHxD Sn Ordering no. NPN Make and break switching Ordering no. PNP Make and break switching 10 x 30 x 20 mm 10 x 30 x 20 mm PD 30 CNB 20 NASA PD 30 CNB 20 NAM5SA PD 30 CNB 20 PASA PD 30 CNB 20 PAM5SA Specifications 200 mm 200 mm Cable Plug EN 60947-5-2 Rated operating distance (Sn) Up to 200 mm, reference target, Kodak test card R27, white, 90% reflective, 100 x 100 mm Maximum detecting distance @ 200 mm white background White object 90% refl. ≤ 200 mm Grey object 18% refl. ≤ 200 mm Black object 6% refl. ≤ 200 mm Blind zone 10 mm Sensitivity Electrical adjustmment 210˚ Mechanical adjustment 240˚ Temperature drift ≤ 0.05%/ºC Hysteresis (H) ≤ 10% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) Specifications are subject to change without notice (13.06.2016) No load supply current (Io) ≤ 20 mA @ UB max ≤ 40 mA @ UB min Minimum operational current (Im) ≤ 0.5 mA OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2 VDC @ Ie max Protection Short-circuit, reverse polarity and transients Light source InGaAlP, LED, 625 nm Light type Red, modulated Emitter angle ± 2.5º @ half sensing distance Ambient light ≤ 10,000 lux Operating frequency (f) ≤ 500 Hz Response time OFF-ON (tON) ≤ 1 ms ON-OFF (tOFF ) ≤ 1 ms Power ON delay (tv) ≤ 200 ms Output function Open collector NPN or PNP by sensor type Output switching function N.O. and N.C. 1 PD30CNB20....SA Specifications (cont.) Indication Output ON Power ON Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock LED, yellow LED, green III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +60°C (-13° to +140°F) -40° to +70°C (-40° to +158°F) 10 to 150 Hz, 1.0 mm/15 G (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage ≤ 500 VAC (rms) Housing material Body ABS Light Grey Frontglas PMMA Red Trimmer shaft POM Dark Grey Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON. 54-series) Weight Cable version ≤ 50 g Plug version ≤ 20 g CE-marking Yes Approvals cULus (UL508 + CSA) Operation Diagram Tv = Power ON delay ON OFF Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Object Tv Detection Diagram 2 2,0 Sensing range (inches) 3,9 5,9 7,9 0,0 16,0% 9,8 0,16 2 0,08 1 0,04 0 0,00 -1 -0,04 -2 -0,08 2,0% -3 -0,12 0,0% -4 -0,16 250 50 100 150 200 Sensing range (mm) 2,0 25 50 White background 90% [inches] 3,0 3,9 4,9 5,9 6,9 7,9 8,9 9,8 200 225 250 12,0% 0,12 0 1,0 14,0% 3 (Inches) (mm) 4 0 Sensing Conditions Distance from background [%] Power supply 10,0% 8,0% 6,0% 4,0% 0 Poly. (Black on White 6%/90%) 75 100 125 150 175 White background 90% [mm] Poly. (Grey on White 18%/90%) Poly. (White on White 90%/90%) Specifications are subject to change without notice (13.06.2016) PD30CNB20....SA Wiring Diagrams 1BN NPN 1BN PNP 4BK 2WH 2WH 4BK 3BU 3BU Dimensions Plug version 10.6 20 20 10.6 Cable version Incorrect Receiver Optical axis xxxxxxS Two M3 Potentiometer Two, 9.5 dia. Lenses 15 30 Correct 15 22 25.4 10.8 17 7 Optical axis Two, 9.5 dia. Lenses R 22 Receiver Potentiometer Power / Stability LED Green 10.6 25.4 17 R 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 1.1 10.8 xxxxxxS 30 PD30CNP 06NPM5T 10.6 7 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 5.5 5.5 1.1 PD30CNP 06NPM5T Output LED Yellow Power / Stability LED Green 5.5 5.5 Output LED Yellow Emitter Two M3 > 100 mm Emitter 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Accessories Delivery Contents • Mounting bracket APD30-MB1 or APD30-MB2 to be purchased separately. • Photoelectric switch: PD30CNB20 ... • Screwdriver • Packaging: Plastic bag Specifications are subject to change without notice (13.06.2016) 3
PD30CNB20NASA 价格&库存
很抱歉,暂时无法提供与“PD30CNB20NASA”相匹配的价格&库存,您可以联系我们找货
PD30CNB20NASA
  • 1+1113.522801+144.73080
  • 5+1057.849005+137.49460
  • 10+1024.4424010+133.15260
  • 25+991.0358025+128.81050
库存:5
PD30CNB20NASA
  • 1+786.018981+102.16330
  • 5+733.507605+95.33810
  • 10+681.1700910+88.53550
