VS25EVQ5
VS25EVQ5
    BANNER(邦纳)
    VS25EVQ5 4-PIN EURO PIGTAIL
VS25EVQ5 数据手册
VS2 Convergent Mode Sensor Datasheet Low Profile Miniature Self-Contained Sensors • • • • • • Extremely low profile self-contained miniature Visible red sensing beam 10 v dc to 30 v dc supply voltage NPN or PNP output, depending on model 15 mm or 30 mm convergent point, depending on model Available in dark- or light- operate models WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Model1 Output Type VS2AN5CV15 NPN Light Operate VS2RN5CV15 NPN Dark Operate VS2AP5CV15 PNP Light Operate VS2RP5CV15 PNP Dark Operate VS2AN5CV30 NPN Light Operate VS2RN5CV30 NPN Dark Operate VS2AP5CV30 PNP Light Operate VS2RP5CV30 PNP Dark Operate Range Supply Voltage 15 mm (0.6 inch) ±5 mm 10 V dc to 30 V dc 30 mm (1.2 inch) ±10 mm Overview VS2 Series miniature self-contained sensors are designed for precision sensing in small areas previously accessible only to remote or fiber optic models. Typical applications include mounting inside vibrating feeders and electronic component handling equipment. 1 Integral 2 m (6.5 ft) unterminated cable models are listed. • To order the 3-pin M8/Pico-style integral quick disconnect model, add the suffix "Q" to the model number. For example, VS2AN5CV15Q. • Models with a quick disconnect require a mating cordset. Original Document 65411 Rev. B 1 November 2017 65411 VS2 Convergent Mode Sensor Wiring Diagrams NPN PNP 3 4 1 – 10-30 V dc + 1 + 10-30 V dc – 3 4 Load Load Specifications Supply Voltage and Current 10 V dc to 30 V dc (10% max. ripple) at less than 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPST solid-state switch Choose NPN or PNP models Choose light operate or dark operate models Indicators Two LEDs: Green and Amber Green ON = power to sensor is ON Green flashing = output overload Amber ON = light is sensed Construction Black ABS housing with acrylic lens Output Rating 50 mA maximum Off-state leakage current: < 1 microamp at 24 V dc On-state saturation voltage: < 0.25 V at 10 mA dc; < 0.5 V at 50 mA dc Output Protection Circuitry Protected against output short-circuit, continuous overload, and false pulse on power-up Overload trip point ≥ 100 mA Output Response Time 1 millisecond ON and OFF Note: 150 millisecond delay maximum on powerup: output does not conduct during this time Connections 2 m (6.5 in)PVC integral cable: three #28 ga stranded conductors with PE insulation; 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect (QD). Quick disconnect cables are ordered separately. Environmental Rating IEC IP67; NEMA 6 Operating Conditions –20 °C to +55 °C (–4 °F to +131°F) 80% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock Vibration and Mechanical Shock Vibration: All models meet IEC 60068-2-6, IEC 60947-5-2, UL491 Section 40, MIL-STD-202F Method 201A; 10 to 60 Hz, 0.5 mm peak to peak Shock: All models meet IEC 60068-2-27, IEC 60947-5-2; 30g peak acceleration, 11 millisecond pulse duration, half-sine wave pulse shape Application Notes M2 stainless steel mounting hardware included. Optional mounting brackets are available. Repeatability 160 microseconds Certifications Dimensions 12.0 mm (0.47") Green Power Indicator VS2CV30 VS2CV15 21.2 mm 20.6 mm (0.84") (0.81") 4.8 mm (0.19") 2 10.9 mm (0.43") CL 8.0 mm (0.31") 2.0 mm (0.08") Amber Signal Indicator (Receiver only) 3.6 mm (0.14") 4.7 mm (0.19") 25.1 mm (0.99") 2x ø2.2 mm (0.09") www.bannerengineering.com - Tel: +1-763-544-3164 P/N 65411 Rev. B VS2 Convergent Mode Sensor Performance Curves Excess Gain Curve — 15 mm Models Beam Pattern — 15 mm Models 1000 E X C E S S 100 VS2CV15 6 mm Convergent Mode 4 mm VS2CV15 0.24 in 0.16 in Convergent Mode 2 mm 0.08 in 0 G A I N 10 1 1 mm 0.04 in 0 2 mm 0.08 in 4 mm 0.16 in 6 mm 0.24 in 0 10 mm 0.4 in 100 mm 4 in 20 mm .8 in 1000 mm 40 in 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.0 in DISTANCE DISTANCE Excess Gain Curve — 30 mm Models Beam Pattern — 30 mm Models 1000 E X C E S S G A I N 0.36 in 6 mm Convergent Mode 100 VS2CV30 9 mm VS2CV30 0.24 in Convergent Mode 3 mm 0.12 in 0 10 1 1 mm 0.04 in 0 3 mm 0.12 in 6 mm 0.24 in 9 mm 0.36 in 0 10 mm 0.4 in 100 mm 4 in 1000 mm 40 in 40 mm 1.6 in 80 mm 3.2 in 120 mm 4.8 in 160 mm 200 mm 6.4 in 8.0 in DISTANCE DISTANCE Accessories Quick-Disconnect Cables 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2 m (6.56 ft) PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 9 m (29.53 ft) PKG3M-10 10 m (32.81 ft) P/N 65411 Rev. B Style Dimensions Pinout (Female) 4 35 Typ. Straight M8 x 1 www.bannerengineering.com - Tel: +1-763-544-3164 1 3 ø 9.5 1 = Brown 3 = Blue 4 = Black 3 VS2 Convergent Mode Sensor Brackets SMBVS2RA • Right-angle bracket • Stainless steel Hole center spacing: A = 80.0 14 4 X Ø2.3 20 2 X Ø3.2 Hole size: A = 3.2 x 6.0 20 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
VS25EVQ5
物料型号:VS2系列传感器 器件简介:VS2系列传感器是用于小范围精密传感的超低轮廓自包含微型传感器,适用于之前只能通过远程或光纤模型访问的小区域。
引脚分配:3针M8/Pico式连接器,包括棕色(1号针)、蓝色(3号针)、黑色(4号针)。
参数特性:工作电压10Vdc至30Vdc,最大纹波10%,工作电流小于25mA(不包括负载),具有NPN或PNP输出配置,SPST固态开关,最大输出电流50mA,关闭状态下漏电流小于1微安培,导通状态下饱和电压小于0.25V(10mA dc时)或小于0.5V(50mA dc时)。
功能详解:VS2系列传感器具有集成2米(6.5英尺)未端接电缆型号,可订购3针M8/Pico式整体快速断开型号,型号后加"Q"后缀。
具有环境等级IEC IP67;NEMA 6,工作温度范围-20°C至+55°C,80%最大相对湿度(非凝结),满足振动和机械冲击标准。
应用信息:典型应用包括在振动给料机和电子元件处理设备内安装。
封装信息:黑色ABS外壳,丙烯酸透镜,2米(6.5英寸)PVC整体电缆,带有3针M8/Pico式公快速断开(QD)。
快速断开电缆需单独订购。
VS25EVQ5 价格&库存
很抱歉,暂时无法提供与“VS25EVQ5”相匹配的价格&库存,您可以联系我们找货
VS25EVQ5
  • 1+878.123631+113.59870
库存:3
