SPX2815AT-L-2-5
SPX2815AT-L-2-5
    ROCHESTER(罗切斯特)
    TO263-4
    IC REG LINEAR 2.45V 500MA
SPX2815AT-L-2-5 数据手册
SPX2815 1.5A Low Dropout Voltage Regulator APPLICATIONS ■ Desktop PCs, Servers ■ Powering VGA and Sound Cards ■ Cordless Phones ■ Battery Chargers ■ Adjustable Power Supplies ■ Portable Instrumentation ■ SMPS Post-Regulator ■ Constant Current Regulators ■ Disk Drives FEATURES ■ Guaranteed 1.5A Output Current ■ Three Terminal Adjustable or Fixed 2.5V, 3.3V and 5.0V ■ Low Quiescent Current ■ Low Dropout Voltage of 1.1V @ 1.5A ■ 0.1% Line and 0.1% Load Regulation ■ Stable with 10uF Ceramic Capacitor ■ Overcurrent and Thermal Protection ■ Available Packages: TO-252, TO-220, and TO-263 ■ Similar to Industry Standard LT1086/ LT1586 Refer to Page 5 for Pinouts Now Available in Lead Free Packaging DESCRIPTION The SPX2815 is a low power positive-voltage regulator designed to satisfy moderate power requirements with a cost effective, small footprint solution. This device is an excellent choice for use in battery-powered applications and portable computers. The SPX2815 features very low quiescent current and a low dropout voltage of 1.1V at a full load. As output current decreases, quiescent current flows into the load, increasing efficiency. SPX2815 is available in adjustable or fixed 2.5V, 3.3V and 5.0V output voltages. The SPX2815 is offered in several 3-pin surface mount packages: TO-252, TO-220 and TO-263. An output capacitor of 10μF ceramic or tantalum provides unconditional stability. FUNCTIONAL DIAGRAM (Adjustable) VIN + Current Limit VOUT ICL Thermal Limit _ AMP + 1.25V VREF + – ADJ/GND IADJ ~ 50μA – I TL Date: 6/21/06 Rev C SPX2815 1.5A Low Dropout Voltage Regulator 1 © 2006 Sipex Corporation ABSOLUTE MAXIMUM RATINGS Operating Junction Temperature Range.....-40°C to +125°C Input Supply Voltage .................................................... +10V Input to Output Voltage ................................................ +8.8V ESD Rating .............................................................. 2kV min Power Dissipation.......................................Internally Limited Lead Temperature (soldering, 5 seconds) ...............260°C Storage Temperature Range.......................-65°C to +150°C ELECTRICAL CHARACTERISTICS at VIN=VOUT + 1.5V, TA = 25°C, CIN = COUT = 10μF, IOUT =10mA, unless otherwise specified. The Boldface applies over the full operating temperature range. PARAMETER MIN 2.5V Version Output Voltage TYP MAX MIN SPX2815A TYP MAX UNITS CONDITIONS SPX2815 2.475 2.500 2.450 2.525 2.450 2.500 2.550 2.425 2.550 2.575 V IOUT = 10mA, VIN =4.5V 10mA ≤ IOUT ≤ 1.5A, 4.25V ≤ VIN ≤ 10V 3.267 3.300 3.234 3.333 3.234 3.300 3.366 3.201 3.366 3.399 V IOUT = 10mA, VIN =5V 10mA ≤ IOUT ≤ 1.5A, 4.75V ≤ VIN ≤ 10V 4.950 5.000 4.900 5.050 4.900 5.000 5.100 4.850 5.100 5.150 V IOUT=10mA, VIN=7V 10mA ≤ IOUT ≤ 1.5A, 6.50V ≤ VIN ≤ 10V 1.238 1.250 1.225 1.262 1.225 1.250 1.275 1.212 1.275 1.287 V IOUT=10mA, (VIN - VOUT )= 2V 10mA≤IOUT≤ 1.5A, 1.5V≤(VIN-VOUT)≤ 10V 3.30V Version Output Voltage 5.0V Version Output Voltage All Voltage Options Reference Voltage Output Voltage Temperature Stability 0.3 Line Regulation 0.1 0.1 0.1 0.2 0.2 0.2 0.1 0.1 0.1 0.2 0.2 0.2 % 4.25V≤VIN≤ 10V,VOUT=2.5V,IOUT=10mA 4.75V≤VIN≤ 10V,VOUT=3.3V,IOUT=10mA 6.50V≤VIN≤ 10V,VOUT=5.0V,IOUT=10mA Load Regulation 0.1 0.1 0.1 0.3 0.3 0.3 0.1 0.1 0.1 0.3 0.3 0.3 % 10mA≤IOUT≤ 1.5A, VOUT=2.5V 10mA≤IOUT≤ 1.5A, VOUT=3.3V 10mA≤IOUT≤ 1.5A, VOUT=5.0V Dropout Voltage (Note 2) 1.00 1.10 1.00 1.10 V 1.2 1.2 IOUT=0.5A IOUT=1.5A 4 10 4 10 mA Fixed voltage versions 50 120 50 120 μA A (VIN-VOUT)=5V 0.01 0.1 %/W 25°C, 30mS pulse 75 dB fRIPPLE=120Hz, (VIN-VOUT)=2V, VRIPPLE=1VPP Quiescent Current Adjust Pin Current Current Limit 2.5 Thermal Regulation Ripple Rejection 0.5 2.5 0.01 60 % 75 0.1 60 Long Term Stability 0.03 0.03 % 125°C, 1000Hrs RMS Output Noise 0.003 0.003 % % of VOUT, 10Hz≤f≤10kHz Thermal Resistance 3 29.3 3 31.4 6 50 3 29.3 3 31.4 6 50 °C/W TO-220 Junction to Case, at Tab TO-220 Junction to Ambient TO-263 Junction to Case, at Tab TO-263 Junction to Ambient TO-252 Junction to Case, at Tab TO-252 Junction to Ambient Date: 6/21/06 Rev C SPX2815 1.5A Low Dropout Voltage Regulator 2 © 2006 Sipex Corporation TYPICAL PERFORMANCE CHARACTERISTICS 1.275 3.325 1.27 3.315 Vout (V) Vout (V) 3.320 3.310 3.305 3.300 4.5 6.5 8.5 10.5 12.5 14.5 1.265 1.26 1.255 1.25 1.245 1.24 1.235 1.23 1.225 -50 1.25v Adj -30 -10 10 Vin (V) 70 90 110 130 Figure 2. VOUT vs Temperature, VIN=2.5V, IOUT=10mA 3.38 2.5v Adj 2.5v Fixed 3.3v Adj 3.3v Fixed 3.36 3.34 Vout (V) Vout (V) 50 Temp (C) Figure 1. Line Regulation for SPX2815U-3.3; IOUT=10mA 2.55 2.54 2.53 2.52 2.51 2.5 2.49 2.48 2.47 2.46 2.45 -50 30 3.32 3.3 3.28 -30 -10 10 30 50 Temp (C) 70 90 110 3.26 -50 130 -30 -10 10 30 50 70 90 110 130 Temp (C) Figure 3. VIN=4.0V, IOUT=10mA Figure 4. VIN=5.0V, IOUT=10mA APPLICATION INFORMATION Output Capacitor tions. Special care needs to be taken during continuous load conditions such that the maximum junction temperature does not exceed 125°C. Thermal protection is activated at >179°C and deactiviated at
SPX2815AT-L-2-5 价格&库存
很抱歉,暂时无法提供与“SPX2815AT-L-2-5”相匹配的价格&库存,您可以联系我们找货
