Q85VR3LP-T9
Q85VR3LP-T9
    BANNER(邦纳)
    PHOTO SEN RETRO 80MM-4.6M TIMER
Q85VR3LP-T9 数据手册
t ns uc tio od ca Pr ne ifi Li pec S Q85 Series Sensors Self-contained ac/dc and dc-only sensors with e/m relay or solid-state output and optional timing logic • Economical sensors in rugged, NEMA-6P (IEC IP67) Cycolac® ABS housings; totally self-contained • Models for 24 to 240V ac/12 to 240V dc with SPDT e/m relay or SPST solid-state output • Models for 10 to 48V dc with solid-state NPN sinking and PNP sourcing outputs (switchable light/dark operate); special low-saturation sinking output for interfacing to TTL also provided • Available with either basic on/off output or eightfunction programmable timing logic • Wiring chamber with two conduit entrances for wiring ease and mounting versatility • LED indicators for OUTPUT ON and LIGHT SENSED (AID™ signal strength indicator system; see text) • Models for opposed, short-range and long-range diffuse, and polarized retroreflective sensing modes T9 (logic) model shown with cover removed SMB85B bracket and hardware included Printed in USA P/N 32891A5A Q85 Series Sensors Q85s are compact, economical, photoelectric sensors in rugged NEMA-6P rated ABS housings. They are ideally suited for conveyor control and similar applications. The timing logic functions offered in the "T9" models provide additional control capabilities over and above the ON/OFF (no delay) function of the basic models. Q85 Series sensors are available for the opposed, diffuse, and polarized retroreflective sensing modes. The special lens of the Q85 polarized retroreflective sensor polarizes the emitted light and filters out unwanted reflections, allowing its use in many applications that are otherwise unsuited to retroreflective sensing. All Q85 sensors feature a convenient wiring chamber with two conduit entrances for ease of wiring, positioning, and mounting. Q85 Series sensors are available in models to operate either from 24-240V ac/12-240V dc or from 10-48V dc. AC/DC models are available with either an SPDT electromechanical output relay or an SPST solid-state switch. Q85VR3 Series electromechanical relay models are capable of switching 250V ac, 30V dc, 3 amps (maximum values, resistive load). Q85BW13 Series ac/dc solid-state output models switch up to 250V ac, 250V dc, 300 mA maximum. Model listings and optical performance data are given on page 3. Complete specifications for Q85 sensors appear on pages 4 and 5. See pages 6 and 7 for hookup and logic programming information. Generalized Features, Q85 Series Sensors Q85BB62 Series 10-48V dc-only models have switchable light/dark operate solid-state NPN (current sinking) and PNP (current sourcing) outputs, each capable of 150 mA maximum continuous load. Also included on dc-only models is an alternative low-saturation NPN output specially designed for direct interfacing to TTL and similar circuitry. Q85 Series sensors are available with a choice of either ON/ OFF or programmable timing output logic. Models with programmable timing logic ("T9" models) provide eight switch-selectable logic functions: ON/OFF (no delay), ON delay, OFF delay, ON/OFF delay, one-shot (pulse), on-delayed one-shot, limit timer, and on-delayed limit timer. The adjustable time range for delay functions and pulse length is 0.1 to 5 seconds (see pages 6 and 7). Two top-mounted LED indicators are provided. A red indicator (Banner's exclusive, patented AID™ system*) lights whenever the sensor "sees" its modulated light source, and pulses at a rate proportional to the strength of the received light signal. A yellow output indicator lights whenever the Q85's output is energized. Q85 Series sensors have rugged yellow Cycolac® ABS housings with ultrasonically-welded acrylic lenses. A gasketed ABS cover protects the wiring chamber and the timing and sensitivity adjustment controls. Two 1/2-14 NPSM conduit entrances are provided; a plug and gasket are included for sealing a possible unused entrance. Q85 Series sensors are rated NEMA 1, 2, 3, 3S, 4, 4X, 6, 6P, 12, and 13 (IEC IP67). An 11-gauge plated steel mounting bracket and two plated mounting bolts and nuts (cover photo and drawing, page 5) are included. 2 Cycolac® is a registered trademark of General Electric Co. *Alignment Indicating Device system, US patent number 4356393 WARNING... Q85 Series photoelectric presence sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety applications. A sensor failure or malfunction can result in either an energized or a deenergized sensor output condition. ! Never use these products as sensing devices for personnel protection. Their use as a safety device may create an unsafe condition which could lead to serious injury or death. Only MACHINE-GUARD and PERIMETER-GUARD Systems, and other systems so designated, are designed to meet OSHA and ANSI machine safety standards for point-of-operation guarding devices. No other Banner sensors or controls are designed to meet these standards, and they must NOT be used as sensing devices for personnel protection. Q85 Series Sensors: Optical Performance and Model Listing Opposed Mode Excess Gain Curve Sensing range: 75 feet (23 meters) Sensing beam: 680 nanometers, visible red Effective beam diameter: 0.38 inches (9,6 mm) Models for 24-240V ac/12-240V dc, SPDT electromechanical relay: Q853E emitter Q85VR3R receiver Q85VR3R-T9 receiver 31648; use with either receiver, below 31651; SPDT e/m relay, on/off output 31650; SPDT e/m relay, programmable timer Models for 24-240V ac/12-240V dc, SPST solid-state switch: Q853E emitter Q85BW13R receiver Q85BW13R-T9 receiver 31648; use with either receiver, below 35572; solid-state, on/off output 35571; solid-state, programmable timer Beam Pattern 1000 Q85 Series opposed mode sensors E X 100 C E S S 10 G A I N Q85 Series 500 mm 20 in 10 in 250 mm 0 0 10 in 250 mm 500 mm 20 in opposed mode sensors 1 .1 m .33 ft 1m 10 m 3.3 ft 33 ft DISTANCE 23 m 75 ft 0 5m 16 ft 10 m 15 m 33 ft 49 ft Distance 20 m 66 ft 25 m 82 ft Models for 10-48V dc, solid-state sinking and sourcing outputs : Q8562E emitter Q85BB62R receiver Q85BB62R-T9 receiver 34262; use with either receiver, below 34264; solid-state, on/off output 34265; solid-state, programmable timer Polarized Retroreflective Mode Sensing range: 3 inches (8 cm) to 15 feet (4,6 m) when used with Banner model BRT-3 3-inch retroreflective target Sensing beam: 680 nanometers, visible red (polarized) Models for 24-240V ac/12-240V dc, SPDT electromechanical relay: Q85VR3LP 31213; SPDT e/m relay, on/off output Q85VR3LP-T9 30872; SPDT e/m relay, programmable timer Models for 24-240V ac/12-240V dc, SPST solid-state switch: Q85BW13LP 35564; solid-state, on/off output Q85BW13LP-T9 35563; solid-state, programmable timer Models for 10-48V dc, solid-state sinking and sourcing outputs : Q85BB62LP 34255; solid-state, on/off output Q85BB62LP-T9 34254; solid-state, programmable timer Excess Gain Curve Beam Pattern 1000 75 mm Q85 Series polarized retroreflective sensors E X C 100 E S S 3 in 50mm with BRT-3 3" reflector 2 in Q85 Series 25 mm 1 in polarized retro sensors 0 G A 10 I N 25 mm 1 .01 m 4.6 m .1 m 1m 15 ft .33 ft 3.3 ft DISTANCE TO RETROREFLECTOR with BRT-3 3" reflector 1 in 50mm 2 in 75 mm 3 in 4m 1m 2m 3m 13 ft 3.3 ft 6.6 ft 9.9 ft Distance to retroreflector 0 5m 16 ft Short-range Diffuse Mode Sensing range: 10 inches (250 millimeters) referenced to a 90% reflectance white test card Sensing beam: 880 nanometers, infrared Models for 24-240V ac/12-240V dc, SPDT electromechanical relay: Q85VR3D 31655; SPDT e/m relay, on/off output Q85VR3D-T9 31654; SPDT e/m relay, programmable timer Models for 24-240V ac/12-240V dc, SPST solid-state switch: Q85BW13D 35576; solid-state, on/off output Q85BW13D-T9 35575; solid-state, programmable timer Models for 10-48V dc, solid-state sinking and sourcing outputs: Q85BB62DL 34269; solid-state, on/off output Q85BB62DL-T9 34268; solid-state, programmable timer Excess Gain Curve Beam Pattern 1000 Q85 Series short-range diffuse mode sensors E X 100 C E S S Range is referenced to a 90% reflectance white test card Q85 Series 50 mm 2 in 25 mm 1 in 0 25 mm G 10 A I N 1 in 50 mm 2 in short-range diffuse sensors 1 10 mm .4 in 0 100 mm 250 mm 3.9 in 10 in DISTANCE 50mm 2 in 100mm 150mm 200mm 250mm 8 in 10 in 6 in 4 in Distance to 90% white test card Long-range Diffuse Mode Sensing range: 39 inches (1 meter) referenced to a 90% reflectance white test card Sensing beam: 880 nanometers, infrared Models for 24-240V ac/12-240V dc, SPDT electromechanical relay: Q85VR3DL 31539; SPDT e/m relay, on/off output Q85VR3DL-T9 31537; SPDT e/m relay, programmable timer Models for 24-240V ac/12-240V dc, SPST solid-state switch: Q85BW13DL 35568; solid-state, on/off output Q85BW13DL-T9 35567; solid-state, programmable timer Models for 10-48V dc, solid-state sinking and sourcing outputs: Q85BB62DL 34259; solid-state, on/off output Q85BB62DL-T9 34258; solid-state, programmable timer Excess Gain Curve Beam Pattern 1000 E X 100 C E S S G A I N Q85 Series long-range diffuse mode sensors Q85 Series 25 mm 1 in Range is referenced to a 90% reflectance white test card 10 0 25 mm 1 in long-range diffuse sensors 1 .01 m .4 in .1 m 3.9 in 1m 39 in DISTANCE 10 m 0 .2 m 7.9 in .4 m 16 in .6 m 24 in .8 m 31 in 1m 39 in Distance to 90% white test card 3 Q85 Series Sensors Specifications, Q85VR3x Models Specifications, Q85BW13x Models (24-240V ac or 12 to 240V dc, electromechanical output) (24 to 240V ac/12 to 240V dc, solid-state output) Sensing range: See sensor descriptions by mode (page 3). Sensing beam: See sensor descriptions by mode (page 3). Supply voltage: 24 to 240V ac, 50/60 Hz or 12 to 240V dc Sensing range: See sensor descriptions by mode (page 3). Sensing beam: See sensor descriptions by mode (page 3). Supply voltage: 24 to 240V ac (50/60 Hz) or 12 to 240V dc (2 watts maximum). No polarity for power supply hookup. (2 watts maximum). No polarity for power supply hookup. Outputs (all models except emitters) : Q85BW13x models = optically isolated solid-state switch (as described below), on/off output Q85BW13x-T9 models = optically isolated solid-state switch (as described below), programmable timer Optically-isolated SPST solid-state switch: Maximum ratings: 250V ac, 250V dc, 300 mA. Output saturation voltage: 3V at 300 mA, 2V at 15 mA. Output leakage curent:
Q85VR3LP-T9 价格&库存
很抱歉,暂时无法提供与“Q85VR3LP-T9”相匹配的价格&库存,您可以联系我们找货
Q85VR3LP-T9
  • 1+2298.509151+297.34725
库存:6
