SL30VB6V
SL30VB6V
    BANNER(邦纳)
    PHOTO SEN SLOT 30MM BIPOLAR
SL30VB6V 数据手册
SL30 Series Slot Sensor Datasheet Self-Contained Opposed-Mode Sensor Pair • • • • • • • • • • • • • An easy-to-use self-contained opposed-mode sensor pair in a rugged U-shaped housing Easy and economical to mount Molded-in beam guides simplify mounting and beam placement 30 mm slot width for a wide variety of sensing applications Applications include label detection, hole detection, gear tooth detection, edge guiding and counting 10 V dc to 30 V dc operation Bipolar PNP/NPN outputs Visible red beam Choose 1 millisecond or 300 microsecond response 4-turn potentiometer sensitivity adjustment 2 mm effective beam Dark or light operate Choose integral, unterminated cable or QD models WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Models Sensing Beam Slot Width SL30VB6V SL30VB6VQ SL30VB6VY SL30VB6VYQ Cable1 Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN and PNP 2 m (6.5 ft) 5-wire cable Visible red, 680 nm 30 mm (1.2 in) 5-Pin Euro-style QD 2 m (6.5 ft) 5-wire cable 5-Pin Euro-style QD Response Repeatability 1 ms 250 µs 300 µs 75 µs Overview The SL30 Series Slot Sensor (sometimes called a “Fork Sensor”) comprises an opposed-mode emitter and its receiver inside a single convenient housing. Opposed-mode sensing is very reliable, and the single self-contained housing provides easy installation, with no sensor alignment required. In addition, the molded-in arrow on the emitter portion of the housing and the slotted design on the receiver portion of the housing show at a glance the position of the beam, simplifying installation placement. Emitter Signal LED Power ON LED Receiver (Beam Aligns at Groove) Sensitivity Selector Figure 1. Features 1 To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, Models with a quick disconnect require a mating cordset. Original Document 56407 Rev. D 23 February 2018 56407 SL30 Series Slot Sensor Gear Tooth Detection Edge Detection Register Mark Detection on Clear Film Packaging Film Register Marks Figure 2. Typical Applications LED Indicators The Slot Sensor features two LED Indicators: Power (green) and Signal (amber). They indicate the following: Green ON: Power ON Amber ON: Sensor sees light Amber flashing: Excess gain is marginal (1 to 1.5×) in light condition Select Light Operate/Dark Operate Connect the gray wire to +V (10 V dc to 30 V dc) for Dark Operate; and to dc common (or open) for Light Operate. See wiring diagrams. Wiring Diagrams 1 + 10-30V dc – 3 2 4 L L Wiring Key 1. Brown 2. White 3. Blue 4. Black 5. Gray* *For Dark operate, connect gray wire to + (brown). For Light operate, connect gray wire to - (blue). 5* Note: Quick disconnect (QD) wiring diagrams are functionally identical. Adjust the Sensitivity Adjust the sensitivity by turning the 4-turn clutched Sensitivity potentiometer with a small slotted screwdriver. 1. Apply power to the sensor. 2. Turn the potentiometer fully counter-clockwise, 4 full turns or more to set the sensor to the minimum sensitivity. 3. Present the Light condition. If the amber Signal Condition indicator is ON, that is the Light condition sensitivity position. If not, proceed to the next step. 4. Turn the potentiometer clockwise, just until the amber Signal Condition indicator turns ON and note the position of the potentiometer. 5. Present the Dark condition. 6. Turn the potentiometer clockwise, just until the amber Signal Condition indicator turns ON, and note the position of the potentiometer. 7. For maximum reliability, the difference between these two positions should be at least one full turn. Set the sensitivity midway between the two positions for best sensing results. If the object to be sensed is very thin and non-metallic, the sensor may emit too much light energy for the object to completely block the beam. To test this, place the object in the sensing position, and decrease the sensitivity until the amber LED goes OFF. Remove the object; verify that the indicator comes ON solidly. If this does not occur, investigate other sensing alternatives. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 56407 Rev. D SL30 Series Slot Sensor Specifications Supply Voltage and Current 10 to 30V dc, 30 mA Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: NPN and PNP Output Rating 150 mA, each output Output Protection Circuitry Protected against output short-circuit and false pulse on power up Output Response Time 1 millisecond or 300 microseconds, depending on model Repeatability 250 microseconds or 75 microseconds, depending on model Adjustments 4-turn clutched potentiometer sensitivity adjustment Slot Opening 30 mm (1.2 in) wide x 45 mm (1.8 in) deep overall; beam set in 10 mm (0.4 in) from outer edge Indicators Green: Power on/off indicator Amber: Signal condition indicator Construction Housing: ABS/polycarbonate blend Optic windows: acrylic Connections 2 m (6.5 ft) or 9 m (30 ft) 5-conductor PVC-jacketed attached cable or 5-pin Euro-style quick-disconnect (QD) connector Environmental Rating IEC IP67; NEMA 6 Operating Conditions −40 °C to +70 °C (−40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications E224071 Dimensions 30.2 mm (1.19") 10.9 mm (0.43") 10.0 mm (0.39) 45.0 mm (1.77") 72.0 mm (2.84") Power LED (Green) Signal LED (Amber) 6.0 mm (0.24") 6.0 mm (0.24") 40.0 mm (1.58") 2x ø5.6 mm (0.22") 20.2 mm (0.80") M12 x 1 52.0 mm (2.05") 18.8 mm (0.74") All measurements are listed in millimeters [inches], unless noted otherwise. P/N 56407 Rev. D www.bannerengineering.com - Tel: +1-763-544-3164 3 SL30 Series Slot Sensor Accessories Cordsets 5-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC1-501.5 Style 0.50 m (1.5 ft) MQDC1-506 1.83 m (6 ft) MQDC1-515 4.57 m (15 ft) MQDC1-530 9.14 m (30 ft) MQDC1-506RA 1.83 m (6 ft) MQDC1-515RA 4.57 m (15 ft) Dimensions 44 Typ. Straight M12 x 1 ø 14.5 2 1 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC1-530RA Pinout (Female) 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray 9.14 m (30 ft) M12 x 1 ø 14.5 [0.57"] Brackets SMBSL • • • 52 Angled bracket 304 stainless steel Hardware included 6X Ø5.5 40 41 19 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
SL30VB6V 价格&库存
很抱歉,暂时无法提供与“SL30VB6V”相匹配的价格&库存,您可以联系我们找货
SL30VB6V
  • 1+1472.180191+191.31357
库存:3
