MAR4816NX485Q
MAR4816NX485Q
    BANNER(邦纳)
    MAR4816NX485Q 16CH 2-STICK MA RE
MAR4816NX485Q 数据手册
A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen Quick Start Guide A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen Configured for Vehicle Separation with 2 Discrete Outputs with EIA-485 Communication This guide is designed to help you set up and install the A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen. For complete information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at www.bannerengineering.com. Search for p/n 117167 to view the Instruction Manual. Use of this document assumes familiarity with pertinent industry standards and practices. With Bracket Flanges “Out” With Bracket Flanges “In” L1 Y L2 L3 75.1 mm (2.95") WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Sensor Scan Time 1 Distance Between Bracket Holes Emitter/Receiver Models Array Length (Y) Housing Length (L1) L2 L3 Total Beams Interlaced Scan 2 Straight Scan MAE616Q Emitter MAR616NX485Q Receiver 143 mm (5.6 in) 231 mm (9.1 in) 262 mm (10.3 in) 205 mm (8.1 in) 8 1.4 ms 0.9 ms MAE1216Q Emitter MAR1216NX485Q Receiver 295 mm (11.62 in) 384 mm (15.1 in) 414 mm (16.3 in) 357 mm (14.1 in) 16 2.5 ms 1.5 ms 1 Worst-case response time is twice the scan time. 2 Scan time for Vehicle Separation scanning configuration. Original Document 119169 Rev. F 27 August 2019 119169 A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen Sensor Scan Time 1 Distance Between Bracket Holes Emitter/Receiver Models Housing Length (L1) Array Length (Y) L2 L3 Total Beams Interlaced Scan 2 Straight Scan MAE1816Q Emitter MAR1816NX485Q Receiver 448 mm (17.62 in) 536 mm (21.1 in) 567 mm (22.3 in) 510 mm (20.1 in) 24 3.6 ms 2.0 ms MAE2416Q Emitter MAR2416NX485Q Receiver 600 mm (23.62 in) 689 mm (27.1 in) 719 mm (28.3 in) 662 mm (26.1 in) 32 4.8 ms 2.6 ms MAE3016Q Emitter MAR3016NX485Q Receiver 752 mm (29.62 in) 841 mm (33.1 in) 871 mm (34.3 in) 815 mm (32.1 in) 40 5.9 ms 3.2 ms MAE3616Q Emitter MAR3616NX485Q Receiver 905 mm (35.62 in) 993 mm (39.1 in) 1024 mm (40.3 in) 967 mm (38.1 in) 48 7.0 ms 3.7 ms MAE4216Q Emitter MAR4216NX485Q Receiver 1057 mm (41.62 in) 1146 mm (45.1 in) 1176 mm (46.3 in) 1119 mm (44.1 in) 56 8.1 ms 4.3 ms MAE4816Q Emitter MAR4816NX485Q Receiver 1210 mm (47.62 in) 1298 mm (51.1 in) 1329 mm (52.3 in) 1272 mm (50.1 in) 64 9.2 ms 4.8 ms MAE5416Q Emitter MAR5416NX485Q Receiver 1362 mm (53.62 in) 1451 mm (57.1 in) 1481 mm (58.3 in) 1424 mm (56.1 in) 72 10.4 ms 5.4 ms MAE6016Q Emitter MAR6016NX485Q Receiver 1514 mm (59.62 in) 1603 mm (63.1 in) 1633 mm (64.3 in) 1577 mm (62.1 in) 80 11.5 ms 6.0 ms MAE6616Q Emitter MAR6616NX485Q Receiver 1667 mm (65.62 in) 1755 mm (69.1 in) 1786 mm (70.3 in) 1729 mm (68.1 in) 88 12.6 ms 6.5 ms MAE7216Q Emitter MAR7216NX485Q Receiver 1819 mm (71.62 in) 1908 mm (75.1 in) 1938 mm (76.3 in) 1881 mm (74.1 in) 96 13.7 ms 7.1 ms Emitter and Receiver Wiring Connect the emitter and receiver cables as shown. Receiver Output 1: (OUT1) is an open-collector transistor switch rated at 30 V dc maximum, 150 mA maximum. It is protected against overload and short circuits. Receiver Alarm: (ALARM) is an open-collector transistor switch rated at 30 V dc maximum, 150 mA maximum. It is protected against overload and short circuits. Both outputs can be configured as NPN (current sinking) or PNP (current sourcing). 1 Worst-case response time is twice the scan time. 2 Scan time for Vehicle Separation scanning configuration. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 119169 Rev. F A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen 16–30 V dc 16–30 V dc + DC Power Supply P.S. V + P.S. V – SYNC + SYNC – + – DC Power Supply – bn bu bn bu pk pk wh wh P.S. V + bn bn P.S. V– P.S. V – bu bu SYNC + SYNC + pk pk SYNC – SYNC – wh wh P.S. V+ OUT2/ALARM EIA 485 + EIA 485 – SHIELD gy ye rd gn ye no connection Load 1 OUT1 rd gn Load 2 OUT2/ALARM to external EIA-485 device terminal EIA 485 + EIA 485 – bare SHIELD SHIELD Receiver P.S. V– SYNC + SYNC – gy gy OUT1 P.S. V+ Emitter gy Load 1 ye no connection Load 2 rd to external EIA-485 device terminal gn bare Receiver Figure 1. NPN Wiring Diagram ye rd gn SHIELD Emitter Figure 2. PNP Wiring Diagram Specifications Supply Voltage and Power 16 V dc to 30 V dc; maximum power 12 watts Sensor Scan Time Worst-case response time is twice the scan time Supply Protection Circuitry Protected against reverse polarity and transient voltages Cable Connections Emitter and receiver cables may not exceed 80 m (250 ft) each 150 mm (6.5 inch) PVC cable with M12/Euro-style quick disconnect Quick disconnect cordsets available separately Discrete Output Configuration Two discrete outputs: Output 1 and Output 2 Outputs can be configured as either open collector NPN or PNP transistors. For the vehicle separation application, the outputs are factory configured as NPN outputs. Discrete Output (either NPN or PNP) Ratings Rated at 30 V dc max, 150 mA max load, short circuit protected OFF-State Leakage Current: < 10 μA at 30 V dc ON-State Saturation Voltage: < 1 V dc at 10 mA, < 1.5 V dc at 150 mA Status Indicators Emitter: Red LED lights for proper operation Receiver: Green – sensors aligned (> 3x excess gain); Yellow – marginal alignment (1x-3x excess gain); Red – sensors misaligned or beam(s) blocked Environmental Rating IEC IP65 UL Type 1 enclosure Serial Data Outputs EIA-485 interface Baud rate 9600, 19.2 K, 38.4 K 8 data bits, 1 start bit, 1 stop bit, no parity Construction Aluminum housing with black anodized finish; acrylic lens cover Controller Programming Via EIA-485 to Banner Sensors GUI software Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) 95% maximum relative humidity (non-condensing) Emitter/Receiver Range Sensors < 1220 mm (4 ft) long: 16.5 m (55 ft) Sensors ≥ 1220 mm (4 ft) long: 13.5 m (45 ft) Application Notes The emitter and receiver sync lines (pink and white wires) will be damaged if connected to the power supply The receiver EIA-485 interface (red and green wires) will be damaged if connected to the power supply Minimum Object Sensitivity Interlaced Mode: 25.4 mm (1.0 in) 3, 4 Other Scan Modes: 38.1 mm (1.5 in)4 3 4 Certifications Assumes sensing is in middle one-third of scanning range. Requires minimum separation of emitter/receiver of 0.9 m (3 ft). P/N 119169 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 3 A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
MAR4816NX485Q 价格&库存
很抱歉,暂时无法提供与“MAR4816NX485Q”相匹配的价格&库存,您可以联系我们找货
MAR4816NX485Q
  • 1+14919.631741+1933.86833
库存:1
