Installation
Guide
S30 Sensors – ac-Voltage Series
Self-contained, ac-operated sensors
Additional information on this product is immediately available online at www.bannerengineering.com/116158
View or download additional information, including excess gain curves, beam patterns and accessories.
For further assistance, contact a Banner Engineering Applications Engineer at (763) 544-3164 or (888) 373-6767.
Sensing Mode
Range
LED
Output
Opposed
Polarized
Retroreflective
P
R
60 m (200')
6 m (20')
Infrared
950 nm
Visible
Red
680 nm
LISTED
200 mm (8")
cutoff
Cabled Emitters
Fixed
Field
400 mm (16")
cutoff
Infrared
880 nm
bn
20-250V ac
bu
QD Emitters
(4-pin Micro-Style)
rd/bk
rd/wh
20-250V ac
600 mm (24")
cutoff
Model*
S303E
LO
S30AW3R
DO
S30RW3R
LO
S30AW3LP
DO
S30RW3LP
LO
S30AW3FF200
DO
S30RW3FF200
LO
S30AW3FF400
DO
S30RW3FF400
LO
S30AW3FF600
DO
S30RW3FF600
* Standard 2 m (6.5') cable models are listed.
• 9 m (30') cable: add suffix “W/30” (e.g., S303E W/30).
• 4-pin Micro-style QD models: add suffix “Q1” (e.g., S303EQ1). A model with a QD connector
requires a mating cable.
rd
No connection
gn
Dimensions
All Other Cabled Models
QD Models
Cabled Models
bn
20-250V ac
bu
bk
Yellow LED
Output Indicator
Load
2 m (6.5') Cable
All Other QD Models
(4-pin Micro-Style)
Jam Nuts
(2 Provided)
Green LED
Power Indicator
M30 x 1.5
Thread
rd/bk
rd/wh
rd
gn
Printed in USA
89.4 mm
(3.52")
20-250V ac
80.7 mm
(3.18")
Load
65.0 mm
(2.56")
65.0 mm
(2.56")
No Connection
WARNING . . .
Not To Be Used for Personnel Protection
Never use these products as sensing devices for personnel protection. Doing so could lead to serious injury or death.
These sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition.
Consult your current Banner Safety Products catalog for safety products which meet OSHA, ANSI and IEC standards for
10/04
P/N 116158
Specifications
Supply Voltage and Current
20 to 250V ac (50/60 Hz). Average current: 20 mA
Peak current: 200 mA at 20V ac, 500 mA at 120V ac, 750 mA at 250V ac
Supply Protection Circuitry
Protected against transient voltages
Output Configuration
SPST solid-state ac switch; Three-wire hookup; Choose light operate or dark
operate models
Light Operate: Output conducts when sensor sees its own (or the emitter’s)
modulated light
Dark Operate: Output conducts when the sensor sees dark
Output Rating
300 mA maximum (continuous);
Fixed-Field Models: derate 5 mA/°C above +50°C (+122°F)
Inrush Capability 1 amp for 20 milliseconds, non-repetitive
OFF-state leakage current: < 100 microamps
ON-state saturation voltage: 3V at 300 mA ac; 2V at 15 mA ac
Output Protection Circuitry
Protected against false pulse on power-up
Output Response Time
Opposed Mode: 16 milliseconds ON, 8 milliseconds OFF
Other Models: 16 milliseconds ON and OFF
NOTE: 100 millisecond delay on power-up
Repeatability
Opposed Mode: 2 milliseconds
Other Models: 4 milliseconds
Repeatability and response are independent of signal strength.
Indicators
Two LEDs (Green and Yellow)
Green ON steady: power to sensor is ON
Yellow ON steady: sensor sees light
Yellow flashing: excess gain marginal (1 to 1.5x) in light condition
Construction
PBT polyester housing; polycarbonate (opposed mode) or acrylic lens
Environmental Rating
Leakproof design rated NEMA 6P, DIN 40050 (IP69K)
Connections
2 m (6.5') attached cable, or 4-pin Micro-style quick-disconnect fitting
Operating Conditions
Temperature: -40° to +70°C (-40° to +158°F);
Maximum relative humidity: 90% at 50°C (non-condensing)
Vibration and Mechanical Shock
All models meet Mil. Std. 202F requirements. Method 201A (Vibration;
frequency 10 to 60 Hz, max., double amplitude 0.06" acceleration 10G).
Method 213B conditions H&I (Shock: 75G with unit operating; 100G for
non-operation)
Certifications
R
LISTED
Quick-Disconnect (QD) Cables
Style
4-pin
Micro-style
Straight
Model
MQAC-406
MQAC-415
MQAC-430
Length
2 m (6.5')
5 m (15')
9 m (30')
Dimensions
Pin-Out
38 mm max.
(1.5")
4-pin
Micro-style
Right-angle
MQAC-406RA
MQAC-415RA
MQAC-430RA
2 m (6.5')
5 m (15')
9 m (30')
Green Wire
Red Wire
Red/White
Wire
Red/Black
Wire
38 mm max.
(1.5")
1/2-20UNF-2B
ø 15 mm
(0.6")
WARRANTY: Banner Engineering Corp. warrants its products to be free from defects for
one year. Banner Engineering Corp. will repair or replace, free of charge, any product of its
manufacture found to be defective at the time it is returned to the factory during the warranty
period. This warranty does not cover damage or liability for the improper application of
Banner products. This warranty is in lieu of any other warranty either expressed or implied.
P/N 116158
Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN USA 55441 • Phone: 763.544.3164 • www.bannerengineering.com • Email: sensors@bannerengineering.com
很抱歉,暂时无法提供与“S30AW3FF400 W/30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2357.583571+306.41478
