RL28-8-H-1500-LAS/47/105
    PEPPERL+FUCHS(倍加福)
    PHT SEN 100-150MM BACK SUPPRESS
RL28-8-H-1500-LAS/47/105 数据手册
Background suppression sensor RL28-8-H-1500-LAS/47/105 < < < < Universal series with highly versatile fields of use Resistant against noise: reliable operation under all conditions Laser version for long ranges Small light beam diameter for detection of small parts Background suppression sensor Safety Information Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 180708_eng.pdf Safety Information Laser Class 1 Information The irradiation can lead to irritation especially in a dark environment. Do not point at people! Maintenance and repairs should only be carried out by authorized service personnel! Attach the device so that the warning is clearly visible and readable. Caution – Use of controls or adjustments or performance of procedures other than those specified herein may result in hazardous radiation exposure. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Background suppression sensor RL28-8-H-1500-LAS/47/105 Dimensions 54.3 14.8 8 25.8 17.8 9.8 2 10 4 11 5 25 88 62 16 6 ø5 M12 x 1 10 51.8 Technical Data Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 180708_eng.pdf General specifications Detection range 100 ... 1500 mm Detection range min. 50 ... 200 mm Detection range max. 100 ... 1500 mm Background suppression max. + 10 % of the upper limit of the detection range Light source laser diode Light type modulated visible red light Laser nominal ratings Note LASER LIGHT , DO NOT STARE INTO BEAM Laser class 1 Wave length 650 nm Beam divergence < 1.5 mrad Pulse length 4.5 µs Repetition rate approx. 1.5 kHz max. pulse energy 17 nJ Light spot representation max. 1.5 mm x 4 mm , light spot perpendicular to housing Black-white difference (6 %/90 %) ≤ 40 % Ambient light limit 50000 Lux Functional safety related parameters MTTFd 590 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Background suppression sensor RL28-8-H-1500-LAS/47/105 Technical Data Indicators/operating means Operation indicator LED green Function indicator 2 LEDs yellow ON: object inside the scanning range OFF: object outside the scanning range Control elements Sensing range adjuster , Light-on/dark-on changeover switch Electrical specifications Operating voltage UB Ripple No-load supply current 10 % I0 Protection class Time delay before availability 10 ... 30 V DC ≤ 40 mA II, rated insulation voltage ≤ 250 V AC with pollution degree 1-2 according to IEC 60664-1 tv ≤2s Output Switching type light/dark on, switchable Signal output 2 PNP outputs, complementary, short-circuit protected, reverse polarity protected, open collector Switching voltage max. 30 V DC Switching current Switching frequency Response time max. 200 mA f 140 Hz 3.5 ms Conformity Product standard EN 60947-5-2 Laser safety EN 60825-1 Approvals and certificates EAC conformity TR CU 020/2011 Protection class II, rated voltage ≤ 250 V AC with pollution degree 1-2 according to IEC 60664-1 UL approval E87056 , cULus Listed , class 2 power supply , type rating 1 FDA approval IEC 60825-1:2007 Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated June 24, 2007 Ambient conditions Ambient temperature -10 ... 50 °C (14 ... 122 °F) Storage temperature -25 ... 75 °C (-13 ... 167 °F) Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 180708_eng.pdf Mechanical specifications Housing width 25.8 mm Housing height 88 mm Housing depth 54.3 mm Degree of protection IP67 Connection 5-pin, M12 x 1 plastic connector Material Housing Plastic ABS Optical face Plastic pane Mass approx. 70 g Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Background suppression sensor RL28-8-H-1500-LAS/47/105 Connection Assignment Option: /47 1 +UB 2 Q 3 0V 4 Q 5 n.c. = Light on = Dark on Connection Assignment 1 5 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 5 BN WH BU BK GY (brown) (white) (blue) (black) (gray) Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 180708_eng.pdf Assembly 5 6 1 2 3 1 Operating display green 4 2 Switch state yellow 3 Bright/dark switch 2 4 Detection range adjuster 5 Receiver 6 Emitter Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Background suppression sensor RL28-8-H-1500-LAS/47/105 Characteristic Curve RL28-8-H-1500-LAS... Characteristic response curve Offset Y [mm] 10 8 6 4 2 0 -2 -4 -6 -8 -10 0 200 400 600 800 1000 1200 x 1400 1600 Distance X [mm] y white 90 % grey 18 % black 6 % Difference in detection distance RL28-8-H-1500-LAS... Measured detection distance X [mm] 1600 1400 1200 1000 800 600 400 200 0 0 200 400 x 600 800 1000 1200 1400 1600 Adjusted detection distance X [mm] white 90 % grey 18 % black 6 % Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 180708_eng.pdf Application Accessories OMH-05 Mounting aid for round steel ø 12 mm or sheet 1.5 mm ... 3 mm OMH-21 Mounting bracket: mounting aid for sensors in the RL* series Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5 Background suppression sensor RL28-8-H-1500-LAS/47/105 Accessories Mounting aid for RL* series OMH-RLK29-HW Mounting bracket for rear wall mounting OMH-RL28-C Weld slag cover model Release date: 2021-11-11 Date of issue: 2021-11-11 Filename: 180708_eng.pdf OMH-22 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 6
RL28-8-H-1500-LAS/47/105 价格&库存
很抱歉,暂时无法提供与“RL28-8-H-1500-LAS/47/105”相匹配的价格&库存,您可以联系我们找货
