HTB18-P4A2BAD04
HTB18-P4A2BAD04
    SICK
    SENSOR 100MM PNP LO/DO M12
HTB18-P4A2BAD04 数据手册
Product data sheet HTB18-P4A2BAD04 SureSense HYBRID PHOTOELECTRIC SENSORS HTB18-P4A2BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. HTB18-P4A2BAD04 1074758 Other models and accessories www.sick.com/SureSense Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 16.2 mm x 48.5 mm x 31.8 mm Housing design (light emission) Hybrid Thread diameter (housing) M18 Mounting system type M18, nose / side (24.1 … 25.4 mm) Housing color Blue Sensing range max. 5 mm ... 300 mm 1) Sensing range 5 mm ... 150 mm 2) Type of light Visible red light Light source PinPoint LED 3) Light spot size (distance) 7 mm (300 mm) Wave length 631 nm Adjustment Potentiometer, right None Potentiometer, left None Special features 1) 2) 3) 2 Signal strength light bar Sensing range pre-set: 100 mm  Object with 90 % reflectance (referred to standard white, DIN 5033).  Object with 6 % reflectance (referred to standard black, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HTB18-P4A2BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple
HTB18-P4A2BAD04 价格&库存
很抱歉,暂时无法提供与“HTB18-P4A2BAD04”相匹配的价格&库存,您可以联系我们找货
