CGHV31500F
CGHV31500F
    WOLFSPEED
    RF MOSFET HEMT 50V 440217
CGHV31500F 数据手册
CGHV31500F 500 W, 2.7 - 3.1 GHz, 50-Ohm Input/Output Matched, GaN HEMT for S-Band Radar Systems Description CGHV31500F is a gallium nitride (GaN) high electron mobility transistor (HEMT) designed specifically with high efficiency, high gain and wide bandwidth capabilities, which makes the CGHV31500F ideal for 2.7 3.1 GHz S-Band radar amplifier applications. The transistor is supplied in a ceramic/metal flange package, type 440226. PN: CGHV31500F Package Type: 440226 Typical Performance Over 2.7-3.1 GHz (TC = 25˚C) of Demonstration Amplifier Parameter 2.7 GHz 2.9 GHz 3.1 GHz Units Output Power 650 705 506 W Gain 12.1 12.5 11.8 dB Drain Efficiency 70 68 58 % Note: Measured in the CGHV31500F-AMP application circuit, under 100 μs pulse width, 10% duty cycle, PIN = 46 dBm Features • • • • • • 2.7 - 3.1 GHz Operation 650 W Typical Output Power 12 dB Power Gain 65% Typical Drain Efficiency 50 Ohm Internally MatcheD PLZ, 0.1CEN LK 9POS 1 J4 CONNECTOR; SMB, Straight, JACK, SMD 1 W1 CABLE, 18 AWG, 4.2 1 - PCB, RO4350, 2.5 X 4.0 X 0.030 1 Q1 CGHV31500F 1 CGHV31500F Power Dissipation De-rating Curve CGHV31500F Transient Power Dissipation De-Rating Curve 400 Power Dissipation (W) Power Dissipation (W) 350 Note 1 300 250 200 150 100 100 us 10 % 500 us 10 % 50 0 0 25 50 75 100 125 150 175 Maximum Case Temperature (°C) 200 225 250 Maximum Case Temperature (°C) Note 1. Area exceeds Maximum Case Temperature (See Page 2). Rev 3.2 - April 2020 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV31500F 7 CGHV31500F-AMP Application Circuit Outline CGHV31500F-AMP Application Circuit Schematic Rev 3.2 - April 2020 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV31500F 8 Product Dimensions CGHV31500F (Package Type — 440226) Rev 3.2 - April 2020 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV31500F 9 Part Number System CGHV31500F Package Power Output (W) Upper Frequency (GHz) Cree GaN High Voltage Table 1. Parameter Value Units Upper Frequency1 3.1 GHz Power Output 500 W Package Flange - Note1: Alpha characters used in frequency code indicate a value greater than 9.9 GHz. See Table 2 for value. Table 2. Rev 3.2 - April 2020 Character Code Code Value A 0 B 1 C 2 D 3 E 4 F 5 G 6 H 7 J 8 K 9 Examples: 1A = 10.0 GHz 2H = 27.0 GHz 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV31500F 10 Product Ordering Information Order Number Description Unit of Measure CGHV31500F GaN HEMT Each CGHV31500F-AMP Test board with GaN HEMT installed Each Rev 3.2 - April 2020 Image 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV31500F 11 For more information, please contact: 4600 Silicon Drive Durham, North Carolina, USA 27703 www.wolfspeed.com/RF Sales Contact RFSales@cree.com Notes Disclaimer Specifications are subject to change without notice. Cree, Inc. believes the information contained within this data sheet to be accurate and reliable. However, no responsibility is assumed by Cree for any infringement of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Cree. Cree makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose. “Typical” parameters are the average values expected by Cree in large quantities and are provided for information purposes only. These values can and do vary in different applications and actual performance can vary over time. All operating parameters should be validated by customer’s technical experts for each application. Cree products are not designed, intended or authorized for use as components in applications intended for surgical implant into the body or to support or sustain life, in applications in which the failure of the Cree product could result in personal injury or death or in applications for planning, construction, maintenance or direct operation of a nuclear facility. © 2015-2020 Cree, Inc. All rights reserved. Wolfspeed® and the Wolfspeed logo are registered trademarks of Cree, Inc. Rev 3.2 - April 2020 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com
CGHV31500F 价格&库存
很抱歉,暂时无法提供与“CGHV31500F”相匹配的价格&库存,您可以联系我们找货
