CRF24060FE
CRF24060FE
    WOLFSPEED
    FET RF 120V 1.1GHZ 440193
CRF24060FE 数据手册
CRF24060 60 W, SiC RF Power MESFET Cree’s CRF24060 is an unmatched silicon carbide (SiC) RF power MetalSemiconductor Field-Effect Transistor (MESFET). SiC has superior properties compared to silicon or gallium arsenide, including higher breakdown voltage, higher saturated electron drift velocity, and higher thermal conductivity. SiC MESFETs offer greater efficiency, greater power density, and wider bandwidths compared to Si and GaAs transistors. FEATURES Package Type : 440193 PN: CRF240 60F APPLICATIONS • 13 dB Small Signal Gain • Wideband Military Communications • High Efficiency • Secure Comms for Homeland Defense • 50 W minimum P1dB • Class A, A/B Amplifiers • Up to 2400 MHz Operation • TDMA, EDGE, CDMA, W-CDMA • 48 V Operation • Broadband Amplifiers • High Breakdown Voltage • MMDS • High Temperature Operation il 2010 Rev 2.0 – Apr Typical Performance • • • • • Drain Efficiency of 45% at 1500 MHz at 60 W POUT IMD -31 dBc at 1000 MHz at 50 W PEP 13 dB Small Signal Gain at 1500 MHz 60 W @ P1dB at 1500 MHz 80 W P3dB at 1500 MHz Note: Measured in amplifier circuit CRF24060-TB at VDS = 48 V, IDQ = 2000 mA. Subject to change without notice. www.cree.com/wireless 1 Absolute Maximum Ratings (not simultaneous) at 25˚C Case Temperature Parameter Symbol Rating Units Drain-source Voltage VDSS 120 Volts Gate to source Voltage VGS -20, +3 Volts Storage Temperature TSTG -55, +150 ˚C TJ 255 ˚C Operating Junction Temperature Thermal Resistance, Junction to Case RθJC 1.4 ˚C/W Screw Torque T 80 in-oz Soldering Temperature TS 225 ˚C Electrical Characteristics (TC = 25˚C) Characteristics Symbol Min. Typ. Max. Units Conditions Gate Threshold Voltage VGS(th) -13 -10 – VDC VDS = 10 V, ID = 2.5 mA Gate Quiescent Voltage VGS(Q) – -7 – VDC VDS = 48 V, ID = 2000 mA Zero Gate Voltage Drain Current IDSS 6.0 7.5 9.0 A VDS = 10 V, VGS = 0 V Drain-Source Breakdown Voltage V(BR)DSS 100 – – VDC VGS = -18, ID = 50 mA Forward Transconductance gm 700 800 – mS VDS = 48 V, ID = 2000 mA Case Operating Temperature TC -30 – 125 ˚C Gain GSS 10 13 – dB VDD = 48 V, IDQ = 2000 mA, f = 1100 MHz Power Output at 1 dB Compression P1dB 50 60 – W VDD = 48 V, IDQ = 2000 mA, f = 1100 MHz Power Output at 3 dB Compression P3dB - 80 – W VDD = 48 V, IDQ = 2000 mA, f = 1100 MHz η 40 45 – % VDD = 48 V, IDQ = 2000 mA, f = 1100 MHz POUT = P1dB IMD3 – -31 – dBc VSWR 10 : 1 – – Y No damage at all phase angles, VDD = 48 V, IDQ = 2000 mA, f = 1000 MHz, POUT = 50W CW Input Capacitance CDS – 5.0 – pF VDS = 48 V, Vgs = -16 V, f = 1 MHz Output Capacitance CGS – 15 – pF VDS = 48 V, Vgs = -16 V, f = 1 MHz Reverse Transfer Capacitance CGD – 2.8 – pF VDS = 48 V, Vgs = -16 V, f = 1 MHz DC Characteristics3 RF Characteristics Drain Efficiency1,2 Intermodulation Distortion Output Mismatch Stress VDD = 48 V, IDQ = 2000 mA, f1 = 1000 MHz, f2 = 1000.1 MHz, POUT = 50W PEP Dynamic Characteristics Notes: 1 Drain Efficiency = POUT / PDC 2 Power Added Efficiency (PAE) = (POUT - PIN) / PDC 3 Measured on wafer prior to packaging. Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 2 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless CRF-24060-101 CRF-24060-101 Typical Performance (TC = 25˚C, = 48 V,=I48 = 2000 mA in Flange Package) Typical Power Performance (TC =V25°C, VDS DS DQ V, IDQ = 2000 mA) Typical Power Performance (TC = 25°C, VDS = 48 V, IDQ = 2000 mA) Typical Power Performance Swept CW CW Data Data vs vs Power Power at at 1000 1000MHz MHz Swept Swept CW Data vs Power at 1000 MHz 51 51 60.00 60.00 56.00 56.00 49 49 52.00 52.00 47 47 48.00 48.00 44.00 44.00 K (Drain Efficiency) (%) K (Drain Efficiency) (%) Pout (dBm) (dBm) Pout 45 45 40.00 40.00 43 43 36.00 36.00 32.00 32.00 41 41 28.00 28.00 39 39 24.00 24.00 20.00 20.00 37 37 16.00 16.00 35 35 12.00 12.00 8.00 8.00 33 33 4.00 4.00 31 31 18 20 22 24 24 26 26 28 28 30 30 32 32 34 34 36 36 38 38 0.00 0.00 40 40 Pin Pin (dBm) (dBm) Typical Wideband Performance (TCC == 25°C, Typical 25°C, V VDS = 48 48 V, V, IIDQ 2000mA) mA) DS = DQ ==2000 Typical Wideband Performance 15 55 55 14 14 54 54 13 13 53 53 12 12 52 52 11 11 51 51 10 10 50 50 99 49 49 88 48 48 77 47 47 6 6 46 46 5 5 0.8 0.8 Psat dB (dBm) Psat dB (dBm) Gain Gain(dB) (dB) Swept CW Data Swept CW Data vs vs Frequency Swept CW Data vsFrequency Frequency 0.9 0.9 1 1 1.1 1.1 1.2 1.2 Frequency (GHz) Frequency (GHz) 1.3 1.3 1.4 1.4 1.5 1.5 Specifications subject to change without notice Specifications subject to change without notice http://www.cree.com/ http://www.cree.com/ Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 3 CRF24060F Rev 2.0 45 45 1.6 1.6 © Cree, Inc. 2005 © Cree, Inc. 2005 3 3Inc. Cree, 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless CRF-24060-TB CRF-24060-TB Typical Performance (VDS = 48 V, IDQ = 2000 mA in the Flange Package) Typical 2.0A TypicalPerformance Performance CRF-24060 CRF-24060 at VDS = 48V, IDQ = 2.0A CW Frequency CWGain and P1 vs Frequency Typical CW Gain and P1dB vs Frequency 50 50 19 19 49 49 18 18 48 48 17 17 47 47 16 16 46 46 15 15 45 45 14 14 44 44 13 13 43 43 12 12 42 42 11 11 41 41 10 10 0.8 0.8 P1 (dBm) (dBm) P1 Gain Gain (dB) (dB) 20 20 0.85 0.85 0.9 0.9 0.95 0.95 11 1.05 1.1 1.05 1.1 Frequency (GHz) Frequency (GHz) 1.15 1.15 1.2 1.2 1.25 1.25 40 40 1.3 1.3 CW Power Sweep at1GHz 1.0 GHz CW Power Sweep @ CW Power Sweep @ 1GHz 60 60 45 45 50 50 40 40 40 40 Pout (dBm) Pout (dBm) Drain Efficiency (%) Drain Efficiency (%) 50 50 35 35 30 30 30 30 20 20 25 25 10 10 20 20 15 15 20 20 25 25 Pin (dBm) Pin (dBm) 30 30 35 35 Specifications subject to change without notice Specificationshttp://www.cree.com/ subject to change without notice http://www.cree.com/ Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 4 CRF24060F Rev 2.0 0 40 0 40 © Cree, Inc. 2005 © Cree, Inc. 2005 5 Cree, Inc. 4600 Silicon 5 Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless Typical Package S-Parameters (Small Signal, VDS = 48 V, IDQ = 2000 mA, magnitude / angle) Frequency S(1,1) S(2,1) S(1,2) S(2,2) 100.0MHz 0.938 / -118.952 11.369 / 117.037 0.027 / 27.543 0.733 / -167.222 200.0MHz 0.924 / -147.861 6.296 / 100.583 0.030 / 11.594 0.786 / -173.220 300.0MHz 0.921 / -159.138 4.291 / 92.762 0.031 / 4.279 0.798 / -175.909 400.0MHz 0.919 / -165.208 3.247 / 87.448 0.031 / -0.529 0.803 / -177.489 500.0MHz 0.919 / -169.113 2.610 / 83.182 0.031 / -4.290 0.806 / -178.595 600.0MHz 0.919 / -171.919 2.183 / 79.451 0.031 / -7.515 0.807 / -179.462 700.0MHz 0.919 / -174.094 1.878 / 76.032 0.031 / -10.429 0.809 / 179.805 800.0MHz 0.919 / -175.877 1.648 / 72.813 0.031 / -13.144 0.810 / 179.152 900.0MHz 0.919 / -177.401 1.470 / 69.730 0.031 / -15.722 0.811 / 178.547 1.000GHz 0.919 / -178.747 1.328 / 66.746 0.031 / -18.201 0.812 / 177.972 1.100GHz 0.919 / -179.968 1.212 / 63.837 0.032 / -20.607 0.813 / 177.413 1.200GHz 0.919 / 178.901 1.116 / 60.986 0.032 / -22.954 0.814 / 176.861 1.300GHz 0.919 / 177.835 1.036 / 58.182 0.032 / -25.254 0.815 / 176.310 1.400GHz 0.919 / 176.816 0.967 / 55.418 0.032 / -27.516 0.816 / 175.755 1.500GHz 0.920 / 175.830 0.908 / 52.686 0.032 / -29.746 0.817 / 175.192 1.600GHz 0.920 / 174.867 0.858 / 49.982 0.032 / -31.948 0.818 / 174.618 1.700GHz 0.920 / 173.917 0.813 / 47.301 0.033 / -34.128 0.819 / 174.029 1.800GHz 0.920 / 172.974 0.775 / 44.640 0.033 / -36.288 0.820 / 173.425 1.900GHz 0.920 / 172.032 0.741 / 41.996 0.033 / -38.432 0.821 / 172.802 2.000GHz 0.920 / 171.086 0.711 / 39.365 0.033 / -40.563 0.821 / 172.158 2.100GHz 0.920 / 170.130 0.685 / 36.744 0.034 / -42.685 0.821 / 171.492 2.200GHz 0.920 / 169.160 0.661 / 34.131 0.034 / -44.800 0.822 / 170.802 2.300GHz 0.919 / 168.172 0.641 / 31.522 0.035 / -46.911 0.822 / 170.086 2.400GHz 0.919 / 167.163 0.623 / 28.915 0.035 / -49.022 0.823 / 169.342 2.500GHz 0.919 / 166.127 0.607 / 26.305 0.035 / -51.135 0.823 / 168.568 2.600GHz 0.918 / 165.062 0.594 / 23.689 0.036 / -53.255 0.823 / 167.762 2.700GHz 0.918 / 163.962 0.582 / 21.064 0.037 / -55.386 0.823 / 166.921 2.800GHz 0.917 / 162.824 0.572 / 18.426 0.037 / -57.530 0.822 / 166.043 2.900GHz 0.916 / 161.642 0.564 / 15.770 0.038 / -59.694 0.821 / 165.125 3.000GHz 0.915 / 160.412 0.557 / 13.091 0.039 / -61.880 0.820 / 164.164 Download this s-parameter file in “.s2p” format at http://www.cree.com/products/wireless_s-parameters.asp Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 5 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless Typical Package S-Parameters (Small Signal, VDS = 48 V, IDQ = 1000 mA, magnitude / angle) Frequency S(1,1) S(2,1) S(1,2) S(2,2) 100.0MHz 0.927 / -116.548 11.083 / 117.528 0.033 / 28.066 0.682 / -162.593 200.0MHz 0.909 / -146.266 6.173 / 100.326 0.037 / 11.402 0.745 / -170.406 300.0MHz 0.904 / -157.893 4.209 / 91.937 0.038 / 3.552 0.760 / -173.673 400.0MHz 0.903 / -164.137 3.182 / 86.138 0.038 / -1.708 0.767 / -175.463 500.0MHz 0.903 / -168.127 2.554 / 81.430 0.038 / -5.879 0.771 / -176.632 600.0MHz 0.903 / -170.973 2.132 / 77.286 0.039 / -9.485 0.774 / -177.490 700.0MHz 0.903 / -173.162 1.829 / 73.477 0.039 / -12.756 0.777 / -178.179 800.0MHz 0.904 / -174.945 1.602 / 69.888 0.039 / -15.808 0.780 / -178.772 900.0MHz 0.905 / -176.460 1.424 / 66.455 0.039 / -18.705 0.783 / -179.309 1.000GHz 0.906 / -177.792 1.282 / 63.140 0.039 / -21.483 0.785 / -179.817 1.100GHz 0.906 / -178.998 1.167 / 59.919 0.039 / -24.169 0.788 / 179.689 1.200GHz 0.907 / 179.888 1.070 / 56.776 0.039 / -26.777 0.791 / 179.195 1.300GHz 0.908 / 178.839 0.989 / 53.699 0.039 / -29.319 0.794 / 178.696 1.400GHz 0.909 / 177.835 0.920 /50.680 0.039 / -31.803 0.797 / 178.185 1.500GHz 0.910 / 176.863 0.861 / 47.714 0.039 / -34.236 0.800 / 177.657 1.600GHz 0.911 / 175.912 0.809 / 44.794 0.039 / -36.623 0.803 / 177.111 1.700GHz 0.912 / 174.974 0.764 / 41.917 0.039 / -38.968 0.806 / 176.543 1.800GHz 0.912 / 174.040 0.725 / 39.077 0.039 / -41.277 0.809 / 175.952 1.900GHz 0.913 / 173.105 0.690 / 36.272 0.039 / -43.551 0.811 / 175.335 2.000GHz 0.914 / 172.165 0.659 / 33.498 0.039 / -45.796 0.814 / 174.693 2.100GHz 0.914 / 171.213 0.632 / 30.751 0.040 / -48.014 0.816 / 174.023 2.200GHz 0.915 / 170.247 0.608 / 28.027 0.040 / -50.210 0.819 / 173.325 2.300GHz 0.915 / 169.262 0.587 / 25.323 0.040 / -52.387 0.821 / 172.596 2.400GHz 0.916 / 168.255 0.568 / 22.635 0.040 / -54.549 0.823 / 171.837 2.500GHz 0.916 / 167.221 0.552 / 19.959 0.041 / -56.701 0.824 / 171.046 2.600GHz 0.916 / 166.157 0.537 / 17.290 0.041 / -58.846 0.826 / 170.220 2.700GHz 0.916 / 165.058 0.525 / 14.625 0.042 / -60.988 0.827 / 169.358 2.800GHz 0.916 / 163.922 0.514 / 11.959 0.042 / -63.134 0.828 / 168.459 2.900GHz 0.916 / 162.742 0.505 / 9.286 0.043 / -65.287 0.829 / 167.519 3.000GHz 0.915 / 161.514 0.497 / 6.601 0.044 / -67.452 0.829 / 166.536 Download this s-parameter file in “.s2p” format at http://www.cree.com/products/wireless_s-parameters.asp Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 6 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless CRF24060-TB Demonstration Test Fixture CRF24060-TB Demonstration Test Fixture Diagram Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 7 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless CRF-24060-TB CRF24060-TB Demonstration Test Fixture Schematic Schematic (Rev. -) L5 VG C7 C11 C10 C9 GND C12 C13 C11 L1 J1 RF IN R1 VD L3 C8 C2 L6 C14 C5 Q1 J2 RF OUT C4 C1 C6 C3 L4 L2 Parts List Designator Value Designator Value R1 27 : 0.1 W, 1206 Chip Resistor C1 12 pF, DILABS C17AH 120F 7UXL L3. L4 4T microspring, Coilcraft 0906-4J C4 9.1 pF, DILABS C17AH 9R1A 7UXL L5, L6 Ferrite, Murata BLM21P220SG C5, C6 2.4 pF, DILABS C17AH 2R4A 4UXL J1, J2 Flange Mount SMA Female Connector C7, C8, C13 27 pF, DILABS C17AH 270M 7UXL Q1 CRF-24060 CRF24060-TB Demonstration Test Fixture Bill of Materials L1. L2 3T microspring, Coilcraft 0906-3J C2, C3 2.4 pF, DILABS C17AH 5R6B 7UXL Substrate Designator C1 Description Qty CAP, 10pF, DILABS C17AH, 100F, 7UXL 1 C2,C3 CAP, 3.9pF, DILABS C17AH, 3R9B, 7UXL 2 Rogers RO4350, Hr=3.48, h=20 mil C9 C10, C12 10 uF, 25V Tantalum Capacitor 180 pF, DILABS C17AH 181J 3UX C4 CAP, 8.2pF, DILABS C17AH, 8R2A, 7UXL 1 C5,C6 CAP, 2.7pF, DILABS C17AH, 2R7A, 4UXL 2 C7,C8,C13 CAP, 30pF, DILABS C17AH, 300M, 7UXL 3 C9 C11, C14 0.1 uF, 100V, 1206 Ceramic Capacitor CAP, 10uF, 25V, TANTALUM 1 C10,C12 CAP, 180pF, DILABS C17AH, 181J, 3UX 2 C11,C14 CAP, 0.1uF, 100V, 1206, CERAMIC 2 R1 due to substitution RES, 27 in OHM, 0.1W, of 1206 Note: Some values may differ the event temporarily unavailable parts 1 L1,L2, L3,L4 © Cree, Inc. 2005 2 Note: MICROSPRING, 3T, COILCRAFT, 0906-3J 4 L5,L6 FERRITE, MURATA BLM21P220SG 2 J1,J2 CONNECTOR, SMA, FLANGE MOUNT, FEMALE 2 Q1 CRF24060 Specifications subject to change without notice http://www.cree.com/ Some values may differ due to substitution temporarily unavailable parts. 1 in the event of Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 8 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless Product Dimensions - CRF24060F (Package Type ­— 440193) PRELIMINARY Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 9 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless Disclaimer Specifications are subject to change without notice. Cree, Inc. believes the information contained within this data sheet to be accurate and reliable. However, no responsibility is assumed by Cree for any infringement of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Cree. Cree makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose. “Typical” parameters are the average values expected by Cree in large quantities and are provided for information purposes only. These values can and do vary in different applications, and actual performance can vary over time. All operating parameters should be validated by customer’s technical experts for each application. Cree products are not designed, intended, or authorized for use as components in applications intended for surgical implant into the body or to support or sustain life, in applications in which the failure of the Cree product could result in personal injury or death, or in applications for planning, construction, maintenance or direct operation of a nuclear facility. Cree and the Cree logo are registered trademarks of Cree, Inc. For more information, please contact: Cree, Inc. 4600 Silicon Drive Durham, NC 27703 www.cree.com/wireless Ryan Baker Cree, Marketing 919.287.7816 Tom Dekker Cree, Sales Director 919.313.5639 Copyright © 2002-2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Wireless by Cree is a trademark of Cree, Inc. 10 CRF24060F Rev 2.0 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/wireless
CRF24060FE 价格&库存
很抱歉,暂时无法提供与“CRF24060FE”相匹配的价格&库存,您可以联系我们找货
