CGHV27015S
CGHV27015S
    WOLFSPEED
    VFDFN12
    RF MOSFET HEMT 50V 12DFN
CGHV27015S 数据手册
CGHV27015S 15 W, DC - 6.0 GHz, 50 V, GaN HEMT Description Cree’s CGHV27015S is an unmatched, gallium nitride (GaN) high electron mobility transistor (HEMT) designed specifically for high efficiency, high gain and wide bandwidth capabilities, which makes the CGHV27015S ideal for LTE, 4G Telecom and BWA amplifier applications. The CGHV27015S GaN HEMT device is unmatched so it is suitable for power amplifier applications from 10 MHz through 6000 MHz, such as tactical communications, CATV, UAV data links, as well as a driver stage amplifier for RADAR, EW, and SatCom devices. At a VDD of 50 V, the device provide 2.5 W of average power or 15 W of peak power. At a VDD of 28 V, the device provides 1 W of average power and 7 W of peak power. The transistor is available in a 3 mm x 4 mm, surface mount, dualflat-no-lead (DFN) package. Package Type: 3x4 DFN PN: CGHV27015S Typical Performance Over 2.4-2.7 GHz (TC = 25˚C), 50 V Parameter 2.4 GHz 2.5 GHz 2.6 GHz 2.7 GHz Units Small Signal Gain 23 22 21.7 21.2 dB Adjacent Channel Power @ PAVE = 2.5 W -36.7 -40.7 -42.4 -42.5 dBc Drain Efficiency @ PAVE = 2.5 W 35.9 33.5 30.4 30.2 % Input Return Loss -9.3 -9.6 -8.6 -7.8 dB Note: Measured in the CGHV27015S-AMP1 application circuit. Under 7.5 dB PAR single carrier WCDMA signal test model 1 with 64 DPCH. Features for 50 V in CGHV27015S-AMP1 • • • • • • 2.4 - 2.7 GHz Operation 15 W Typical Output Power 21 dB Gain at 2.5 W PAVE -38 dBc ACLR at 2.5 W PAVE 32% efficiency at 2.5 W PAVE High degree of APD and DPD correction can be applied Large Signal Models Available for ADS and MWO Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 2 Absolute Maximum Ratings (not simultaneous) at 25˚C Case Temperature Parameter Symbol Rating Units Notes Drain-Source Voltage VDSS 150 Volts 25˚C Gate-to-Source Voltage VGS -10, +2 Volts 25˚C Storage Temperature TSTG -65, +150 ˚C Operating Junction Temperature TJ 225 ˚C Maximum Forward Gate Current IGMAX 2 mA 25˚C Maximum Drain Current1 IDMAX 0.9 A 25˚C Soldering Temperature TS 245 ˚C TC -40, +150 ˚C RθJC 11.1 ˚C/W 2 Case Operating Temperature3 Thermal Resistance, Junction to Case 4 Notes: 1 Current limit for long term, reliable operation 2 Refer to the Application Note on soldering at wolfspeed.com/RF/Document-Library 3 TC = Case temperature for the device. It refers to the temperature at the ground tab underneath the package. The PCB will add additional thermal resistance 85˚C Measured for the CGHV27015S at PDISS = 5 W The RTH for Cree’s demonstration amplifier, CGHV27015S-AMP1, with 31 x 0.011 via holes designed on a 20 mil thick Rogers 4350 PCB, is 3.9°C. The total RTH from the heat sink to the junction is 11.1°C + 3.9°C = 15°C/W 4 5 Electrical Characteristics (TC = 25˚C) Characteristics Symbol Min. Typ. Max. Units Conditions Gate Threshold Voltage VGS(th) -3.8 -3.0 -2.3 VDC VDS = 10 V, ID = 2 mA Gate Quiescent Voltage VGS(Q) – -2.6 – VDC VDS = 50 V, ID = 60 mA Saturated Drain Current IDS 1.29 1.84 – A VDS = 6.0 V, VGS = 2.0 V Drain-Source Breakdown Voltage V (BR)DSS 125 – – VDC VGS = -8 V, ID = 2 mA DC Characteristics1 RF Characteristics2 (TC = 25˚C, F0 = 2.65 GHz unless otherwise noted) Gain G – 22 – dB VDD = 50 V, IDQ = 60 mA, PIN = 10 dBm POUT – 42.3 – dBm VDD = 50 V, IDQ = 60 mA, PIN = 25 dBm Drain Efficiency3 η – 72 – % VDD = 50 V, IDQ = 60 mA, PIN = 25 dBm Output Mismatch Stress3 VSWR – 10:1 – Y No damage at all phase angles, VDD = 50 V, IDQ = 60 mA, PIN = 25 dBm CGS – 3.15 – pF VDS = 50 V, Vgs = -8 V, ƒ = 1 MHz Output Capacitance CDS – 1.06 – pF VDS = 50 V, Vgs = -8 V, ƒ= 1 MHz Feedback Capacitance CGD – 0.058 – pF VDS = 50 V, Vgs = -8 V, ƒ= 1 MHz Output Power 3 Dynamic Characteristics Input Capacitance4 4 Notes: 1 Measured on wafer prior to packaging 2 Measured in Cree’s production test fixture. This fixture is designed for high volume test at 2.65 GHz Rev 3.4 – May 2021 Un-modulated pulsed signal, 100 μs, 10% duty cycle Includes package and internal matching components 3 4 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 3 Typical Performance in Application Circuit CGHV27015S-AMP1 Figure 1. Small Signal Gain and Return Losses vs Frequency VDD = 50 V, IDQ = 60 mA 30 20 Input and Output Return Loss Gain (dB) Input and Output Return Loss Gain (dB) 25 15 10 5 0 -5 -10 -15 S11 S21 -20 -25 S22 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 3 3.1 3.2 Frequency (GHz) Frequency (GHz) Figure 2. Typical Drain Efficiency and ACLR vs. Output Power VDD = 50 V, IDQ = 60 mA, 1 Carrier WCDMA, PAR = 7.5 dB 0 45 ACLR_2p5 ACLR_2p7 -15 ACLR (dBc) 35 ACLR_2P6 Efficiency 30 EFF_2p4 EFF_2p5 -20 25 EFF_2P6 EFF_2p7 -25 20 -30 15 -35 10 Efficiency (%) -10 ACLR (dBc) 40 ACLR_2p4 Efficiency (%) -5 ACLR -40 -45 5 18 19 20 21 22 23 24 25 26 27 28 29 30 Output Power (dBm) 31 32 33 34 35 36 37 38 0 Output Power (dBm) Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 4 Typical Performance in Application Circuit CGHV27015S-AMP1 Figure 3. Typical Gain, Drain Efficiency and ACLR vs Frequency VDD = 50 V , IDQ = 60 mA, PAVE = 2.5 W, 1 Carrier WCDMA, PAR = 7.5 dB -25.0 35 -27.5 Drain Efficiency -30.0 25 -32.5 Gain 20 -35.0 15 -37.5 10 5 -40.0 ACLR GAIN ACLR (dBc) 30 ACLR (dBc) Gain (dB) & Drain Efficiency (%) Gain (dB) Drain Efficiency (%) 40 -42.5 EFF ACLR 0 2.35 2.40 2.45 2.50 2.55 Frequency (GHz) 2.60 2.65 2.70 -45.0 2.75 Frequency (GHz) Electrostatic Discharge (ESD) Classifications Parameter Symbol Class Test Methodology Human Body Model HBM 1A (> 250 V) JEDEC JESD22 A114-D Charge Device Model CDM 2 (125 V to 250 V) JEDEC JESD22 C101-C Moisture Sensitivity Level (MSL) Classification Parameter Symbol Level Test Methodology Moisture Sensitivity Level MSL 3 (168 hours) IPC/JEDEC J-STD-20 Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 5 Typical Performance GMAX and K-Factor vs Frequency Maximum & K-Factor VDD = 50 V, IDQ =Avaliable 60 mA,Gain Tcase = 25°C CGHV27015S Vdd = 50 V, Idq = 60 mA, Tcase = 25°C 40 1.25 Gmax K-Factor 1 0.75 25 0.5 K-Factor 30 K-Factor GMAX (dB) GMAX (dB) 35 20 0.25 15 10 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 0 Frequency (GHz) Frequency (GHz) Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 6 Source and Load Impedances for Application Circuit CGHV27015S-AMP1 D Z Source Z Load G Frequency Z Source Z Load 2400 7.9 + j2.14 15.8 + j43.1 2500 8 + j2.9 18.3 + j43.7 2600 7.9 + j3.6 19.7 + j43.4 2700 7.7 - j4.4 19.7 + j43.4 S Note1. VDD = 50 V, IDQ = 60 mA in the DFN package Note2. Impedances are extracted from the CGHV27015S-AMP1 application circuit and are not source and load pull data derived from the transistor CGHV27015S-AMP1 Application Circuit Bill of Materials Rev 3.4 – May 2021 Designator Description Qty R1 RES, 332,OHM, +/- 1%, Vishay 1 R2 RES, 22.6,OHM, +/- 1%, 1/16W, 0603 1 R3, R4 RES, 2.2,OHM, +/- 1%, 1/16W, 0603 1 C1, C4 CAP, 27pF, +/- 5%, 0603, ATC 2 C2 CAP, 2.0pF,+/-0.1pF, 0603 ATC 1 C3 CAP, 0.1pF,+/-0.05 pF, 0603, ATC 2 C8 CAP, 6.2pF, +/-0.1pF, 0603, ATC 1 C13 CAP, 10pF +/-5%, 0603, ATC 1 C6, C11 CAP, 33000pF, 0805, ATC 2 C7, C12 CAP, 470PF, 5%, 100V, 0603, 2 C10 CAP, 1.0UF, 100V, 10%, X7R, 1210 1 C5 CAP 10UF 16V TANTALUM 1 C9 CAP, 33UF, 20%, G CASE 1 J1, J2 CONN, SMA, PANEL MOUNT JACK, FLANGE, 4-HOLE, BLUNT POST 2 J3 HEADER RT>PLZ .1CEN LK 5POS 1 Q1 CGHV27015S, DFN 1 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 7 CGHV27015S-AMP1 Application Circuit, 50 V CGHV27015S-AMP1 Application Circuit Schematic, 50 V Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 8 CGHV27015S-AMP1 Application Circuit, 50 V Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 9 Product Dimensions CGHV27015S (Package 3 x 4 DFN) Pin Input/Output 1 GND 2 NC 3 RF IN 4 RF IN 5 NC 6 GND 7 GND 8 NC 9 RF OUT 10 RF OUT 11 NC 12 GND Note: Leadframe finish for 3x4 DFN package is Nickel/Palladium/Gold. Gold is the outer layer. Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 10 Part Number System CGHV27015S Package Power Output (W) Upper Frequency (GHz) Cree GaN High Voltage Table 1. Parameter Value Units Upper Frequency1 2.7 GHz Power Output 15 W Package Surface Mount - Note1: Alpha characters used in frequency code indicate a value greater than 9.9 GHz. See Table 2 for value. Table 2. Rev 3.4 – May 2021 Character Code Code Value A 0 B 1 C 2 D 3 E 4 F 5 G 6 H 7 J 8 K 9 Examples: 1A = 10.0 GHz 2H = 27.0 GHz 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 11 Product Ordering Information Order Number Description Unit of Measure CGHV27015S GaN HEMT Each CGHV27015S-AMP1 Test board with GaN HEMT installed Each Rev 3.4 – May 2021 Image 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com CGHV27015S 12 For more information, please contact: 4600 Silicon Drive Durham, North Carolina, USA 27703 www.wolfspeed.com/RF Sales Contact RFSales@cree.com Notes Disclaimer Specifications are subject to change without notice. “Typical” parameters are the average values expected by Cree in large quantities and are provided for information purposes only. Cree products are not warranted or authorized for use as critical components in medical, life-saving, or life-sustaining applications, or other applications where a failure would reasonably be expected to cause severe personal injury or death. No responsibility is assumed by Cree for any infringement of patents or other rights of third parties which may result from use of the information contained herein. No license is granted by implication or otherwise under any patent or patent rights of Cree. © 2014-2021 Cree, Inc. All rights reserved. Wolfspeed® and the Wolfspeed logo are registered trademarks of Cree, Inc. Rev 3.4 – May 2021 4600 Silicon Drive | Durham, NC 27703 | wolfspeed.com
CGHV27015S 价格&库存
很抱歉,暂时无法提供与“CGHV27015S”相匹配的价格&库存,您可以联系我们找货
