M032LD2AE
M032LD2AE
    NUVOTON(新唐)
    LQFP-48
    M032LD2AE
M032LD2AE 数据手册
M031/M032 Arm® Cortex® -M 32-bit Microcontroller NuMicro® Family M031/M032 Series Product Brief Nuvoton is providing this document only for reference purposes of NuMicro microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. www.nuvoton.com Feb. 19, 2019 Page 1 of 22 Rev.1.01 M031/M032 SERIES PRODUCT BRIEF The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. M031/M032 1 GENERAL DESCRIPTION ® ® ® The NuMicro M031/M032 series 32-bit microcontroller is based on Arm Cortex -M0 core with 32-bit hardware multiplier/divider. It features 1.8 ~ 3.6V operating voltage, 5V I/O tolerant, and runs up to 48/72 MHz within -40°C ~105°C. The M031/M032 series provides a solution for the applications that need 1.8V low-voltage interface connection with enhanced fast 2 MSPS conversion rate 12-bit ADC, comparators and up-to 24-ch 96/144 MHz PWM control. It supports a fast and precise data conversion for the voltage, current, and sensor data, then fast response control to the external device. Additionally, the M031/M032 series also provides plenty of peripherals including Universal Serial Control 2 Interface(USCI) that can be set as UART/SPI/I C flexibly, up to 10 sets of UART, 4 sets of 2 2 SPI/I S, 4 sets of I C, and 1-wire UART interface for data communication between master and slave devices. The M031/M032 series provides Flash size from 16 Kbytes to 512 Kbytes, SRAM size from 2 Kbytes to 96 Kbytes. Supported packages from small form factor TSSOP 20-pin, TSSOP 28-pin, QFN 33-pin, LQFP 48-pin to LQFP 64-pin and LQFP 128-pin with pin-compatible for different part numbers makes the system design and parts change easily. Part Numbers with the M032 series are all based on the M031 series and enhanced with the crystal-less USB 2.0 full-speed device feature for USB related applications. For the development, Nuvoton provides the NuMaker-PFM evaluation board and Nuvoton Nu-Link rd debugger. The 3 Party IDE such as Keil MDK, IAR EWARM, Eclippse IDE with GNU GCC compilers are also supported. Product Line UART I2C SPI/ I2S Timer USCI PWM PDMA EBI ADC ACMP Divider USBD M031/M032 8 2 2 4 2 24 9 1 16 2 1 1 ® Table 1-1 NuMicro M031/M032 Series Key Features Support Table M031/M032 SERIES PRODUCT BRIEF ® The NuMicro M031/M032 series is suitable for a wide range of applications such as:  Laser Distance Meter  Air Detector/Cleaner  Mobile LCD Panel Controller  IoT Sensing Device  HMI Controller  Micro Printer  Gaming Keyboard and Mouse  WPC Wireless Charger Feb. 19, 2019 Page 2 of 22 Rev.1.01 M031/M032 2 FEATURES  Operating Characteristics – – – –  Analog Voltage range: 1.8V to 3.6V Temperature range: -40°C to +105°C EFT 4.4 KV ESD HBM 6 KV – Up to 16 channels 12-bit 2 MSPS SAR ADC – Two rail-to-rail comparators (ACMP)  Communication interfaces  Core ® ® – Arm Cortex -M0 processor running up to 48/72 MHz  Memories – Up to 512 KB Flash – Up to 96 KB SRAM – Up to 8 KB Flash for user program loader (LDROM) – ISP/ICP/IAP programming – External Bus Interface (EBI) supports maximum external address space of 1 Mbytes – Up to 2 KB SPROM – Dual-Bank for Over-The–Air (OTA) upgrade  Clocks – 4 to 32 MHz HXT crystal oscillator or external input clock – 32.768 kHz LXT crystal oscillator or external input clock for low-power system operation – Internal 48 MHz HIRC oscillator with variation ±2 % within all temperature range – Internal 38.4 kHz LIRC for low-power operating mode. – One PLL up to 96/144 MHz for high speed module operation. – Integrated with Power-on Reset, Brown-out Reset and Low voltage Reset – Normal run: 180 uA/MHz – Power-down: 12 uA – Supports wake up from Power-down mode by: 2 ACMP, GPIO, WDT, TIMER, UART, USCI, I C, SPI, WWDT, ADC, PDMA, PWM, USBD  Timers – – – – – – Up to four 32-bit timers 96/144 MHz 16-bit PWM (Up to 24 channels) One 24-bit SysTick timer One Independent watchdog One window watchdog RTC with Calendar and Alarm  PDMA – Up to 9 channels  Cryptography Accelerator – Supports CRC accelerator: CRC-CCITT, CRC-8, CRC-16, and CRC-32 polynomials  IEC-60730 Feb. 19, 2019 – USB 2.0 full speed device with on-chip PHY [1] (crystal-less design)  Up to 111 I/O with interrupt capability – Schmitt trigger input – Four I/O modes – Supports Schmitt type (Not support TTL input) – 5V tolerant I/O except analog pins  Serial Wire Debug (SWD) – Nuvoton Nu-Link debugger support  32-bit H/W Divider(HDIV) – 32-bit dividend with 16-bit divisor calculation capacity – 6 HCLK clocks taken for one cycle calculation  Utility Support ® – Arm Keil RVMDK and IAR EWARM IDE support for debugging – Free GNU compiler with Eclipse IDE support – ICP (In Circuit Programmer) support for updating internal code via Nu-Link debugger – ISP (In System Programmer) support for 2 updating internal code through UART, SPI, I C, RS-485 peripheral interface – Pin Viewer for real time monitor the status of all IO pins – PinConfigure tool for pin assignment, initial code generation and OrCAD/Protel part generation – ClockConfigure tool for generating the initial source code of system clock  96-bit Unique ID (UID)  128-bit Unique Customer ID (UCID)  Package – Channel can be operated by – software trigger, 2 2 SPI/I S, USPI, UART, UUART, I C, ADC, USBD, PWM and Timer – Supports IEC-60730 Safety specifications.  Advanced Communication Interface M031/M032 SERIES PRODUCT BRIEF  Power management – Up to 4 sets of 6 MHz UART interfaces with UART, RS-485 and IrDA mode – Up to 4 sets of UART for simple TX/RX operation 2 – 2 sets of 400 kHz I C interfaces 2 – 1 set of 24 MHz SPI/I S interface – Up to 1 set of quad SPI – Up to 2 sets of USCI interfaces that supports 2 UART, SPI and I C mode Pin Count 128 64 48 33 28 20 Type LQFP LQFP LQFP QFN TSSOP TSSOP I/O Pin 111 55 42 27 23 15 Lead Pitch 0.4 0.4 0.5 0.4 0.65 0.65 Dimensions (nm ) 14x14 x1.4 7x7x1. 4 7x7x1. 4 4x4x0. 8 4.4x9.7 x1.0 4.4x6. 5x0.9 Note Page 3 of 22 [1] : M032 series Rev.1.01 M031/M032 3 BLOCK DIAGRAM Figure 3-1 NuMicro® M031/M032 Block Diagram M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 4 of 22 Rev.1.01 M031/M032 4 4.1 PARTS INFORMATION M031/M032 Series Naming Rule M0 31 S E 3 A E Core Line Package Flash SRAM Reserve Temperature Cortex®-M0 31: Control F: TSSOP20 B: 16 KB 0: 2 KB 32: USB (4.4x6.5 mm) C: 32 KB 1: 4 KB E: TSSOP28 D: 64 KB 2: 8/12 KB (4.4x9.7 mm) E: 128 KB 3: 16 KB T: QFN33 G: 256 KB 6: 32 KB (4x4 mm) I: 512 KB 8: 64 KB L: LQFP48 E:-40°C ~ 105°C A: 96 KB (7x7 mm) S: LQFP64 (7x7 mm) K: LQFP128 (14x14 mm) M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 5 of 22 Rev.1.01 M031/M032 M031/M032 Series Selection Guide 4.2.1 M031 Control Series Part Number M031FB0 AE M031FC1 AE M031EB0 AE M031EC1 AE M031TB0 AE M031TC1 AE M031TD2 AE M031LC2 AE M031LD2 AE M031LE3A E M031LG6 AE M031LG8 AE M031SC2 AE M031SD2 AE M031SE3 AE M031SG6 AE M031SG8 AE M031SIAA E M031KG6 AE M031KG8 AE M031KIAA E 4.2 Flash (KB) 16 32 16 32 16 32 64 32 64 128 256 256 32 64 128 256 256 512 256 256 512 SRAM (KB) 2 4 2 4 2 4 8 8 8 16 8 8 16 System Frequency (MHz) 48 ISP ROM (KB) 15 PWM 2 23 4 2 96 MHz 4 0 USCI* 2 - 64 512 4 96 8 2048 111 M031/M032 SERIES PRODUCT BRIEF 12 - 24 - 24 5 7 5 1 2 1 6 3 1 - 3 7 9 7 9 6 8 2 6 8 1 QSPI - I2C 2 USB FS - EBI - 1 CRC 1 - 1 V PLL(MHz) - 96 IEC-60730 - LXT 144 96 144 V - V - V - V RTC - ACMP V - 2 Divider Package 8 - SPI /I2S 12-bit ADC 32 4 0 UART 96 55 12 2 4 42 2 64 72 2 2 6 0 32 48 2048 27 144 MHz PDMA Connectivity 4 512 I/O 64 72 2 SPROM (Bytes) Timer/PWM 32 1 7 9 TSSOP20 TSSOP28 10 12 QFN33 LQFP48 16 LQFP64 LQFP128 2 USCI*: supports UART, SPI or I C; Note: 256/512 KB version is under developing. Feb. 19, 2019 Page 6 of 22 Rev.1.01 M031/M032 Part Number M032LG6AE M032LG8AE M032SE3AE M032SG6AE M032SG8AE M032SIAAE M032KG6AE M032KG8AE M032KIAAE M032 USB Series M032LE3AE 4.2.2 Flash (KB) 128 256 256 128 256 256 512 256 256 512 SRAM (KB) 16 32 64 16 32 64 96 32 64 96 System Frequency (MHz) 48 72 72 4 ISP ROM (KB) SPROM 48 512 2048 8 512 4 8 2048 (Bytes) 38 I/O 51 4 PWM Timer/PWM 96 MHz 12 - 12 - 144 MHz - 24 - 24 5 7 5 USCI 1 2 1 UART 3 6 3 PDMA 9 9 6 8 2 6 8 - 1 - 1 I2C 2 USB FS 1 EBI 1 CRC V PLL(MHz) 96 144 96 144 IEC-60730 - V - V V LXT RTC 7 1 SPI /I2S QSPI 7 M031/M032 SERIES PRODUCT BRIEF Connectivity 107 - V - V ACMP 2 Divider 1 12-bit ADC 12 Package LQFP48 16 LQFP64 LQFP128 2 USCI*: supports UART, SPI or I C; Note: 256/512 KB version is under developing. Feb. 19, 2019 Page 7 of 22 Rev.1.01 M031/M032 5 PIN CONFIGURATION 5.1 M031 Series Pin Diagram 5.1.1 M031 Series TSSOP 20-Pin Diagram 1 20 PF.1 LDO_CAP 2 19 PF.0 VDD 3 18 nRESET PB.14 4 17 PA.0 PB.13 5 16 PA.1 PB.12 6 15 PA.2 AVDD 7 14 PA.3 PB.5 8 13 PF.2 PB.4 9 12 PF.3 PB.3 10 11 PB.2 TSSOP20 VSS Figure 5-1 M031 Control Series TSSOP 20-pin Diagram M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 8 of 22 Rev.1.01 M031/M032 5.1.2 M031 Series TSSOP 28-Pin Diagram 1 28 PC.0 PA.13 2 27 PC.1 PA.14 3 26 PF.1 PA.15 4 25 PF.0 VSS 5 24 nRESET LDO_CAP 6 23 PA.0 VDD 7 22 PA.1 PB.14 8 21 PA.2 PB.13 9 20 PA.3 PB.12 10 19 PF.2 AVDD 11 18 PF.3 PB.5 12 17 PB.0 PB.4 13 16 PB.1 PB.3 14 15 PB.2 TSSOP28 PA.12 Figure 5-2 M031 Control Series TSSOP 28-pin Diagram M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 9 of 22 Rev.1.01 M031/M032 VSS 25 LDO_CAP PA.15 PA.14 PA.13 PA.12 PC.0 PC.1 PF.1 PF.0 24 23 22 21 20 19 18 17 M031 Series QFN 33-Pin Diagram 16 nRESET 26 15 PF.15 VDD 27 14 PA.0 PB.15 28 13 PA.1 PB.14 29 12 PA.2 PB.13 30 11 PA.3 PB.12 31 10 PF.2 9 PF.3 QFN33 33 VSS 2 3 4 5 6 7 8 PB.4 PB.3 PB.2 PB.1 PB.0 PF.5 PF.4 32 1 AVDD Top transparent view PB.5 5.1.3 M031/M032 SERIES PRODUCT BRIEF Figure 5-3 M031 Control Series QFN 33-pin Diagram Feb. 19, 2019 Page 10 of 22 Rev.1.01 M031/M032 PA.15 PA.14 PA.13 PA.12 PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 36 35 34 33 32 31 30 29 28 27 26 25 M031 Series LQFP 48-Pin Diagram VSS 37 24 nRESET LDO_CAP 38 23 PF.15 VDD 39 22 PA.0 PC.14 40 21 PA.1 PB.15 41 20 PA.2 PB.14 42 19 PA.3 PB.13 43 18 PA.4 PB.12 44 17 PA.5 AVDD 45 16 PA.6 AVSS 46 15 PA.7 PB.7 47 14 PF.2 PB.6 48 13 PF.3 1 2 3 4 5 6 7 8 9 10 11 12 PB.3 PB.2 PB.1 PB.0 PA.11 PA.10 PA.9 PA.8 PF.5 PF.4 M031/M032 SERIES PRODUCT BRIEF PB.4 LQFP48 PB.5 5.1.4 Figure 5-4 M031 Control Series LQFP 48-pin Diagram Feb. 19, 2019 Page 11 of 22 Rev.1.01 M031/M032 PA.15 PA.14 PA.13 PA.12 PD.0 PD.1 PD.2 PD.3 PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 M031 Series LQFP 64-Pin Diagram VSS 49 32 nRESET LDO_CAP 50 31 PF.15 VDD 51 30 PA.0 PC.14 52 29 PA.1 PB.15 53 28 PA.2 PB.14 54 27 PA.3 PB.13 55 26 PA.4 PB.12 56 25 PA.5 AVDD 57 24 PD.15 VREF 58 23 VDD LQFP64 9 10 11 12 13 14 15 16 PA.9 PA.8 PF.6 PF.14 PF.5 PF.4 PF.3 M031/M032 SERIES PRODUCT BRIEF PA.10 PF.2 8 17 7 64 PB.0 PC.7 PB.7 PA.11 PB.8 18 6 PC.6 63 PB.1 19 5 62 PB.2 PA.7 PB.9 4 20 PB.3 61 3 PA.6 PB.10 PB.4 VSS 21 PB.5 22 60 2 59 1 AVSS PB.11 PB.6 5.1.5 ® Figure 5-5 NuMicro M031 Control Series LQFP 64-pin Diagram Feb. 19, 2019 Page 12 of 22 Rev.1.01 M031/M032 M032 Series Pin Diagram USB_VDD33_CAP USB_D+ USB_D- USB_VBUS PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 36 35 34 33 32 31 30 29 28 27 26 25 M032 Series LQFP 48-Pin Diagram VSS 37 24 nRESET LDO_CAP 38 23 PF.15 VDD 39 22 PA.0 PC.14 40 21 PA.1 PB.15 41 20 PA.2 PB.14 42 19 PA.3 PB.13 43 18 PA.4 PB.12 44 17 PA.5 AVDD 45 16 PA.6 AVSS 46 15 PA.7 PB.7 47 14 PF.2 PB.6 48 13 PF.3 5 6 7 8 9 10 11 12 PB.0 PA.11 PA.10 PA.9 PA.8 PF.5 PF.4 4 PB.2 PB.1 3 PB.3 2 M031/M032 SERIES PRODUCT BRIEF 1 LQFP48 PB.4 5.2.1 PB.5 5.2 ® Figure 5-6 NuMicro M032 USB Series LQFP 48-pin Diagram Feb. 19, 2019 Page 13 of 22 Rev.1.01 M031/M032 USB_VDD33_CAP USB_D+ USB_D- USB_VBUS PD.0 PD.1 PD.2 PD.3 PC.0 PC.1 PC.2 PC.3 PC.4 PC.5 PF.1 PF.0 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 M032 Series LQFP 64-Pin Diagram VSS 49 32 nRESET LDO_CAP 50 31 PF.15 VDD 51 30 PA.0 PC.14 52 29 PA.1 PB.15 53 28 PA.2 PB.14 54 27 PA.3 PB.13 55 26 PA.4 PB.12 56 25 PA.5 AVDD 57 24 PD.15 VREF 58 23 VDD AVSS 59 22 VSS PB.11 60 21 PA.6 PB.10 61 20 PA.7 PB.9 62 19 PC.6 PB.8 63 18 PC.7 PB.7 64 17 PF.2 11 12 13 14 15 16 PA.8 PF.6 PF.14 PF.5 PF.4 PF.3 7 PB.0 10 6 PB.1 PA.9 5 PB.2 9 4 PB.3 PA.10 3 PB.4 8 2 PA.11 1 M031/M032 SERIES PRODUCT BRIEF PB.5 LQFP64 PB.6 5.2.2 Figure 5-7 M032 USB Series LQFP 64-pin Multi-function Diagram Feb. 19, 2019 Page 14 of 22 Rev.1.01 M031/M032 6 UTILITIES 6.1 Programmer and Debugger Nu-Link Basic full speed USB2.0 hardware debugger/programmer Nu-Link-Pro Advance hardware debugger/programmer with programming counter Nu-Link 2.0 Advance high speed USB2.0 hardware debugger/programmer with multi-functions Nu-Link-Gang Off-line hardware programmer supports up to four chips programming for mass-production ISP In system programming, a software programming tool support UART/USB ICP In Chip Programming, a software programming tool support Nu-Link programmer 6.2 Development Environment Programming IDE Keil MDK, IAR, NuEclipse(GCC) Software Package Board Support Package(BSP), Sample Code, Development IDE NuTool Pin-View, NuTool-PinView, NuTool-ClockConfig, NuConsole RTOS Mbed, FreeRTOS, Amazon FreeRTOS, Ali-OS HMI Support emWin with font create tool and easy GUI builder Programming IDE Keil MDK, IAR, NuEclipse(GCC) EVB NuMaker Part Number NK-M031TB M031FB0AE, M031EB0AE, M031TB0AE NK-M031TC M031FC1AE, M031EC1AE, M031TC1AE NK-M031SD M031LC2AE, M031SC2AE, M031TD2AE Feature M031LD2AE, M031SD2AE NK-M031SE M031LE3AE, M031SE3AE, NK-M032SE M032LE3AE, M032SE3AE NK-M031KG M031LG6AE, M031SG6AE, M031KG6AE, Support Expand Connector, Arduino Uno Interface M031LG8AE, M031SG8AE, M031KG8AE NK-M032KG M032LG6AE, M032SG6AE, M032KG6AE, M032LG8AE, M032SG8AE, M032KG8AE NK-M031KI M031SIAAE, M031KIAAE NK-M032KI M032SIAAE, M032KIAAE Feb. 19, 2019 Page 15 of 22 Rev.1.01 M031/M032 SERIES PRODUCT BRIEF 6.3 Development Board M031/M032 7 PACKAGE DIMENSIONS 7.1 TSSOP 20-Pin (4.4x6.5x0.9 mm) M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 16 of 22 Rev.1.01 M031/M032 7.2 TSSOP 28-Pin (4.4x9.7x1.0 mm) M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 17 of 22 Rev.1.01 M031/M032 7.3 QFN 33-pin (4X4x0.8 mm Pitch:0.40 mm) M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 18 of 22 Rev.1.01 M031/M032 7.4 LQFP 48-pin (7x7x1.4 mm Footprint 2.0mm) H 36 25 37 24 48 13 H 12 1  M031/M032 SERIES PRODUCT BRIEF Controlling dimension : Millimeters Symbol A A1 A2 b c D E e HD HE L L1 Y 0 Feb. 19, 2019 Dimension in inch Dimension in mm Min Nom Max Min Nom Max 0.002 0.004 0.006 0.05 0.055 0.057 1.35 1.40 1.45 0.006 0.008 0.010 0.15 0.20 0.25 0.004 0.006 0.008 0.10 0.15 0.20 0.272 0.276 0.280 6.90 7.00 7.10 0.272 0.276 0.280 6.90 7.00 7.10 0.020 0.026 0.35 0.50 0.65 0.053 0.014 0.10 0.15 0.350 0.354 0.358 8.90 9.00 9.10 0.350 0.354 0.358 8.90 9.00 9.10 0.018 0.024 0.030 0.45 0.60 0.75 1.00 0.039 0.004 0 7 Page 19 of 22 0.10 0 7 Rev.1.01 M031/M032 7.5 LQFP 64-pin (7x7x1.4 mm footprint 2.0 mm) M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 20 of 22 Rev.1.01 M031/M032 8 REVISION HISTORY Date Revision Description 2019.01.03 1.00 Initial version. 2019.02.19 1.01 Updated 128KB ISP ROM size. M031/M032 SERIES PRODUCT BRIEF Feb. 19, 2019 Page 21 of 22 Rev.1.01 M031/M032 M031/M032 SERIES PRODUCT BRIEF Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Feb. 19, 2019 Page 22 of 22 Rev.1.01
M032LD2AE 价格&库存
很抱歉,暂时无法提供与“M032LD2AE”相匹配的价格&库存,您可以联系我们找货
